/* * ili9341_gfx.c * * Created on: Jan 17, 2020 * Author: andrew */ // ----------------------------------------------------------------- includes -- #include "ili9341_gfx.h" #include "stdlib.h" #include "string.h" // memset() // ---------------------------------------------------------- private defines -- /* nothing */ // ----------------------------------------------------------- private macros -- /* nothing */ // ----------------------------------------------------------- private types -- /* nothing */ // ------------------------------------------------------- exported variables -- ili9341_color_t const ILI9341_BLACK = (ili9341_color_t)0x0000; ili9341_color_t const ILI9341_NAVY = (ili9341_color_t)0x000F; ili9341_color_t const ILI9341_DARKGREEN = (ili9341_color_t)0x03E0; ili9341_color_t const ILI9341_DARKCYAN = (ili9341_color_t)0x03EF; ili9341_color_t const ILI9341_MAROON = (ili9341_color_t)0x7800; ili9341_color_t const ILI9341_PURPLE = (ili9341_color_t)0x780F; ili9341_color_t const ILI9341_OLIVE = (ili9341_color_t)0x7BE0; ili9341_color_t const ILI9341_LIGHTGREY = (ili9341_color_t)0xC618; ili9341_color_t const ILI9341_DARKGREY = (ili9341_color_t)0x7BEF; ili9341_color_t const ILI9341_BLUE = (ili9341_color_t)0x001F; ili9341_color_t const ILI9341_GREEN = (ili9341_color_t)0x07E0; ili9341_color_t const ILI9341_CYAN = (ili9341_color_t)0x07FF; ili9341_color_t const ILI9341_RED = (ili9341_color_t)0xF800; ili9341_color_t const ILI9341_MAGENTA = (ili9341_color_t)0xF81F; ili9341_color_t const ILI9341_YELLOW = (ili9341_color_t)0xFFE0; ili9341_color_t const ILI9341_WHITE = (ili9341_color_t)0xFFFF; ili9341_color_t const ILI9341_ORANGE = (ili9341_color_t)0xFD20; ili9341_color_t const ILI9341_GREENYELLOW = (ili9341_color_t)0xAFE5; ili9341_color_t const ILI9341_PINK = (ili9341_color_t)0xF81F; // ------------------------------------------------------- private variables -- static uint16_t spi_tx_block[__SPI_TX_BLOCK_MAX__]; // default DMA TX buffer // ------------------------------------------------------ function prototypes -- static ili9341_bool_t ili9341_clip_rect(ili9341_t *lcd, int16_t *x, int16_t *y, uint16_t *w, uint16_t *h); static void ili9341_fill_quarter_circle(ili9341_t *lcd, ili9341_color_t color, int16_t x, int16_t y, int16_t r, uint8_t corners, int16_t delta); // ------------------------------------------------------- exported functions -- ili9341_color_rgb_t ili9341_rgb_wheel(uint8_t *pos) { ili9341_color_rgb_t rgb; uint8_t curr = *pos; *pos += 1; curr = 0xFF - curr; if (curr < 0x55) { rgb.red = 0x03 * curr; rgb.green = 0xFF - curr * 0x03; rgb.blue = 0x00; } else if (curr < 0xAA) { curr -= 0x55; rgb.red = 0xFF - curr * 0x03; rgb.green = 0x00; rgb.blue = 0x03 * curr; } else { curr -= 0xAA; rgb.red = 0x00; rgb.green = 0x03 * curr; rgb.blue = 0xFF - curr * 0x03; } return rgb; } ili9341_color_t ili9341_color_wheel(uint8_t *pos) { ili9341_color_rgb_t rgb = ili9341_rgb_wheel(pos); return __ILI9341_COLOR565_RGB(rgb); } void ili9341_spi_tft_set_address_rect(ili9341_t *lcd, uint16_t x0, uint16_t y0, uint16_t x1, uint16_t y1) { ili9341_spi_tft_select(lcd); // column address set ili9341_spi_write_command_data(lcd, issNONE, 0x2A, 4, (uint8_t[]){ (x0 >> 8) & 0xFF, x0 & 0xFF, (x1 >> 8) & 0xFF, x1 & 0xFF }); // row address set ili9341_spi_write_command_data(lcd, issNONE, 0x2B, 4, (uint8_t[]){ (y0 >> 8) & 0xFF, y0 & 0xFF, (y1 >> 8) & 0xFF, y1 & 0xFF }); // write to RAM ili9341_spi_write_command(lcd, issNONE, 0x2C); ili9341_spi_tft_release(lcd); } void ili9341_transmit_wait(ili9341_t *lcd) { if (NULL == lcd) { return; } while (HAL_DMA_STATE_BUSY == HAL_DMA_GetState(lcd->spi_hal->hdmatx)) { continue; } } void ili9341_transmit_color(ili9341_t *lcd, uint16_t size, uint16_t color[]/* already byte-swapped (LE) */, ili9341_bool_t wait) { if ((NULL == lcd) || (0 == size) || (NULL == color)) { return; } HAL_SPI_Transmit(lcd->spi_hal, (uint8_t *)color, size,500); if (ibOK(wait)) { ili9341_transmit_wait(lcd); } } void ili9341_draw_pixel(ili9341_t *lcd, ili9341_color_t color, int16_t x, int16_t y) { if (ibNOT(ili9341_clip_rect(lcd, &x, &y, NULL, NULL))) { return; } uint16_t color_le = __LEu16(&color); // select target region ili9341_spi_tft_set_address_rect(lcd, x, y, x + 1, y + 1); ili9341_spi_tft_select(lcd); HAL_GPIO_WritePin(lcd->data_command_port, lcd->data_command_pin, __GPIO_PIN_SET__); HAL_SPI_Transmit(lcd->spi_hal, (uint8_t *)&color_le, 2U, __SPI_MAX_DELAY__); ili9341_spi_tft_release(lcd); } void ili9341_draw_line(ili9341_t *lcd, ili9341_color_t color, int16_t x0, int16_t y0, int16_t x1, int16_t y1) { int16_t dx = x1 - x0; int16_t dy = y1 - y0; int16_t x, y; int16_t err; int16_t step; if (0 == dx) { // vertical line if (0 == dy) { return; } // distance = 0, no line to draw ili9341_fill_rect(lcd, color, x0, y0, 1, abs(dy)); return; } else if (0 == dy) { // horizontal line if (0 == dx) { return; } // distance = 0, no line to draw ili9341_fill_rect(lcd, color, x0, y0, abs(dx), 1); return; } ili9341_bool_t is_steep = abs(dy) > abs(dx); if (is_steep) { __SWAP(int16_t, x0, y0); __SWAP(int16_t, x1, y1); } if (x0 > x1) { __SWAP(int16_t, x0, x1); __SWAP(int16_t, y0, y1); } dx = x1 - x0; dy = abs(y1 - y0); err = dx >> 1; if (y0 < y1) { step = 1; } else { step = -1; } while (x0 <= x1) { if (is_steep) { x = y0; y = x0; } else { x = x0; y = y0; } // continue algorithm even if current pixel is outside of screen // bounds, so that the line is drawn at correct position once // it actually enters screen bounds (if ever). if ( (x >= 0) && (x <= lcd->screen_size.width) && (y >= 0) && (y <= lcd->screen_size.height) ) { ili9341_draw_pixel(lcd, color, x, y); } err -= dy; if (err < 0) { y0 += step; err += dx; } ++x0; } } void ili9341_draw_rect(ili9341_t *lcd, ili9341_color_t color, int16_t x, int16_t y, uint16_t w, uint16_t h) { ili9341_draw_line(lcd, color, x, y, x+w, y ); ili9341_draw_line(lcd, color, x, y+h-1, x+w, y+h-1 ); ili9341_draw_line(lcd, color, x, y, x, y+h ); ili9341_draw_line(lcd, color, x+w-1, y, x+w-1, y+h ); } void ili9341_fill_rect(ili9341_t *lcd, ili9341_color_t color, int16_t x, int16_t y, uint16_t w, uint16_t h) { // verify we have something within screen dimensions to be drawn if (ibNOT(ili9341_clip_rect(lcd, &x, &y, &w, &h))) { return; } uint32_t num_pixels = w * h; uint32_t rect_wc = num_pixels; uint32_t block_wc = rect_wc; if (block_wc > __SPI_TX_BLOCK_MAX__) { block_wc = __SPI_TX_BLOCK_MAX__; } // fill entire block with ordered color data uint16_t color_le = __LEu16(&color); for (uint16_t i = 0; i < block_wc; ++i) { spi_tx_block[i] = color_le; } // select target region ili9341_spi_tft_set_address_rect(lcd, x, y, (x + w - 1), (y + h - 1)); ili9341_spi_tft_select(lcd); HAL_GPIO_WritePin(lcd->data_command_port, lcd->data_command_pin, __GPIO_PIN_SET__); // repeatedly send MIN(remaining-words, block-words) words of color data until // all rect words have been sent. uint32_t curr_wc; while (rect_wc > 0) { curr_wc = rect_wc; if (curr_wc > block_wc) { curr_wc = block_wc; } ili9341_transmit_color(lcd, curr_wc * 2/*16-bit words*/, spi_tx_block, ibYes); rect_wc -= curr_wc; } ili9341_spi_tft_release(lcd); } void ili9341_draw_circle(ili9341_t *lcd, ili9341_color_t color, int16_t x, int16_t y, int16_t r) { int16_t f = 1 - r; int16_t fx = 1; int16_t fy = -2 * r; int16_t ix = 0; int16_t iy = r; ili9341_draw_pixel(lcd, color, x, y + r); ili9341_draw_pixel(lcd, color, x, y - r); ili9341_draw_pixel(lcd, color, x + r, y); ili9341_draw_pixel(lcd, color, x - r, y); while (ix < iy) { if (f >= 0) { iy--; fy += 2; f += fy; } ix++; fx += 2; f += fx; ili9341_draw_pixel(lcd, color, x + ix, y + iy); ili9341_draw_pixel(lcd, color, x - ix, y + iy); ili9341_draw_pixel(lcd, color, x + ix, y - iy); ili9341_draw_pixel(lcd, color, x - ix, y - iy); ili9341_draw_pixel(lcd, color, x + iy, y + ix); ili9341_draw_pixel(lcd, color, x - iy, y + ix); ili9341_draw_pixel(lcd, color, x + iy, y - ix); ili9341_draw_pixel(lcd, color, x - iy, y - ix); } } void ili9341_fill_circle(ili9341_t *lcd, ili9341_color_t color, int16_t x, int16_t y, int16_t r) { ili9341_draw_line(lcd, color, x, y - r, x, (y - r) + (2 * r) + 1); ili9341_fill_quarter_circle(lcd, color, x, y, r, 3, 0); } void ili9341_fill_screen(ili9341_t *lcd, ili9341_color_t color) { ili9341_fill_rect(lcd, color, 0, 0, lcd->screen_size.width, lcd->screen_size.height); } void ili9341_draw_bitmap_1b(ili9341_t *lcd, ili9341_color_t fg_color, ili9341_color_t bg_color, int16_t x, int16_t y, uint16_t w, uint16_t h, uint8_t *bmp) { if ((NULL == lcd) || (NULL == bmp)) { return; } int16_t _x = x, _y = y; uint16_t _w = w, _h = h; if (ibNOT(ili9341_clip_rect(lcd, &_x, &_y, &_w, &_h))) { return; } int16_t byteWidth = (w + 7) / 8; uint8_t byte = 0; uint16_t fg_le = __LEu16(&(fg_color)); uint16_t bg_le = __LEu16(&(bg_color)); // select target region ili9341_spi_tft_set_address_rect(lcd, x, y, w, h); ili9341_spi_tft_select(lcd); HAL_GPIO_WritePin(lcd->data_command_port, lcd->data_command_pin, __GPIO_PIN_SET__); for (int16_t j = 0; j < h; ++j, ++y) { for (int16_t i = 0; i < w; ++i) { if (i & 7) { byte <<= 1; } else { byte = bmp[j * byteWidth + i / 8]; } if (byte & 0x80) { spi_tx_block[((j&1) * w) + i] = fg_le; } else { spi_tx_block[((j&1) * w) + i] = bg_le; } } ili9341_transmit_wait(lcd); ili9341_transmit_color(lcd, w * 2, &(spi_tx_block[(j&1) * w]), ibNo); } ili9341_spi_tft_release(lcd); ili9341_transmit_wait(lcd); } void ili9341_draw_char(ili9341_t *lcd, ili9341_text_attr_t attr, char ch) { // verify we have something within screen dimensions to be drawn int16_t _x = attr.origin_x; int16_t _y = attr.origin_y; uint16_t _w = attr.font->width; uint16_t _h = attr.font->height; if (ibNOT(ili9341_clip_rect(lcd, &_x, &_y, &_w, &_h))) { return; } // 16-bit color, so need 2 bytes for each pixel being filled uint32_t num_pixels = attr.font->width * attr.font->height; uint32_t rect_wc = num_pixels; uint16_t fg_le = __LEu16(&(attr.fg_color)); uint16_t bg_le = __LEu16(&(attr.bg_color)); uint32_t block_wc = rect_wc; if (block_wc > __SPI_TX_BLOCK_MAX__) { block_wc = __SPI_TX_BLOCK_MAX__; } // initialize the buffer with glyph from selected font uint8_t ch_index = glyph_index(ch); for (uint32_t yi = 0; yi < attr.font->height; ++yi) { uint32_t gl = (uint32_t)attr.font->glyph[ch_index * attr.font->height + yi]; for (uint32_t xi = 0; xi < attr.font->width; ++xi) { if ((gl << xi) & 0x8000) { spi_tx_block[yi * attr.font->width + xi] = fg_le; } else { spi_tx_block[yi * attr.font->width + xi] = bg_le; } } } // select target region ili9341_spi_tft_set_address_rect(lcd, attr.origin_x, attr.origin_y, attr.origin_x + attr.font->width - 1, attr.origin_y + attr.font->height - 1); ili9341_spi_tft_select(lcd); HAL_GPIO_WritePin(lcd->data_command_port, lcd->data_command_pin, __GPIO_PIN_SET__); // repeatedly send MIN(remaining-words, block-words) words of color data until // all rect words have been sent. uint32_t curr_wc; while (rect_wc > 0) { curr_wc = rect_wc; if (curr_wc > block_wc) { curr_wc = block_wc; } ili9341_transmit_color(lcd, curr_wc * 2/*16-bit words*/, spi_tx_block, ibYes); rect_wc -= curr_wc; } ili9341_spi_tft_release(lcd); } void ili9341_draw_string(ili9341_t *lcd, ili9341_text_attr_t attr, char str[]) { int16_t curr_x = attr.origin_x; int16_t curr_y = attr.origin_y; int16_t start_x = attr.origin_x; while ('\0' != *str) { if('\r' == *str) { curr_x = start_x; } else if('\n' == *str) { curr_y += attr.font->height; curr_x = start_x; } else { if ( (curr_x > lcd->screen_size.width) || (curr_y > lcd->screen_size.height) ) { break; } attr.origin_x = curr_x; attr.origin_y = curr_y; ili9341_draw_char(lcd, attr, *str); curr_x += attr.font->width; } ++str; } } // ------------------------------------------------------- private functions -- static ili9341_bool_t ili9341_clip_rect(ili9341_t *lcd, int16_t *x, int16_t *y, uint16_t *w, uint16_t *h) { // must have an origin to do anything if ((NULL == x) || (NULL == y)) { return ibFalse; } // 1. rect origin beyond screen dimensions, nothing to draw if ((*x >= lcd->screen_size.width) || (*y >= lcd->screen_size.height)) { return ibFalse; } // 2. rect width or height is 0, nothing to draw if ((NULL != w) && (NULL != h)) { if ((0U == *w) || (0U == *h)) { return ibFalse; } } // 3. rect origin has negative component, adjust origin and dimensions if (*x < 0) { if (NULL != w) { *w -= *x; } *x = 0; } if (*y < 0) { if (NULL != h) { *h -= *y; } *y = 0; } if ((NULL != w) && (NULL != h)) { // 4. rect width beyond screen width, reduce rect width if ((*x + *w - 1) >= lcd->screen_size.width) { *w = lcd->screen_size.width - *x; } // 5. rect height beyond screen height, reduce rect height if ((*y + *h - 1) >= lcd->screen_size.height) { *h = lcd->screen_size.height - *y; } return (*w > 0U) && (*h > 0U); } return ibTrue; } static void ili9341_fill_quarter_circle(ili9341_t *lcd, ili9341_color_t color, int16_t x, int16_t y, int16_t r, uint8_t corners, int16_t delta) { int16_t f = 1 - r; int16_t fx = 1; int16_t fy = -2 * r; int16_t ix = 0; int16_t iy = r; int16_t px = ix; int16_t py = iy; int16_t tx; int16_t ty; delta += 1; while (ix < iy) { if (f >= 0) { iy--; fy += 2; f += fy; } ix++; fx += 2; f += fx; if (ix < (iy + 1)) { if (corners & 1) { tx = x + ix; ty = y - iy; ili9341_draw_line(lcd, color, tx, ty, tx, ty + 2 * iy + delta); } if (corners & 2) { tx = x - ix; ty = y - iy; ili9341_draw_line(lcd, color, tx, ty, tx, ty + 2 * iy + delta); } } if (iy != py) { if (corners & 1) { tx = x + py; ty = y - px; ili9341_draw_line(lcd, color, tx, ty, tx, ty + 2 * px + delta); } if (corners & 2) { tx = x - py; ty = y - px; ili9341_draw_line(lcd, color, tx, ty, tx, ty + 2 * px + delta); } py = iy; } px = ix; } }
