---------------------------------------------------------------------------------- -- Company: Circuit-Break -- Engineer: Jens Weiss -- -- Create Date: 15:14:22 01/01/2025 -- Design Name: VHDL Library -- Module Name: DualPort_SRamInterface - Behavioral -- Project Name: -- Target Devices: -- Tool versions: ISE 14.7 (P20121013) -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity DualPort_SRamInterface is Port ( clk : in std_logic; reset : in std_logic; --Status Signals busy : out std_logic; error : out std_logic; --PortA PortA_Adress : in std_logic_vector (18 downto 0); PortA_DataIn : in std_logic_vector (7 downto 0); PortA_DataOut : out std_logic_vector (7 downto 0); PortA_CE : in std_logic; PortA_OE : in std_logic; PortA_WE : in std_logic; --PortB PortB_Adress : in std_logic_vector (18 downto 0); PortB_DataIn : in std_logic_vector (7 downto 0); PortB_DataOut : out std_logic_vector (7 downto 0); PortB_CE : in std_logic; PortB_OE : in std_logic; PortB_WE : in std_logic; --SRam Memory Interface SRam_Adress : out std_logic_vector (18 downto 0); SRam_Data : inout std_logic_vector (7 downto 0); SRam_nCE : out std_logic; SRam_nOE : out std_logic; SRam_nWE : out std_logic); end DualPort_SRamInterface; architecture Behavioral of DualPort_SRamInterface is signal internal_SRamAdress : std_logic_vector(18 downto 0); signal internal_SRamData : std_logic_vector(7 downto 0); signal internal_SRam_CE : std_logic; signal internal_SRam_OE : std_logic; signal internal_SRam_WE : std_logic; signal internal_busy : std_logic; signal internal_error : std_logic; begin --Memory Controller process process begin wait until rising_edge(clk); if(reset = '1') then internal_busy <= '0'; internal_error <= '0'; internal_SRamAdress <= (others => '0'); internal_SRamData <= (others => 'Z'); internal_SRam_CE <= '0'; internal_SRam_OE <= '0'; internal_SRam_WE <= '0'; else --PortA selects Ram if(PortA_CE = '1') and (PortB_CE = '0') then internal_busy <= '1'; internal_SRam_CE <= '1'; internal_SRamAdress <= PortA_Adress; if(PortA_OE = '1') then internal_SRam_OE <= '1'; PortA_DataOut <= SRam_Data; else internal_SRam_OE <= '0'; end if; if(PortA_WE = '1') then internal_SRam_WE <= '1'; internal_SRamData <= PortA_DataIn; else internal_SRam_WE <= '0'; end if; --PortB selects Ram elsif(PortA_CE = '0') and (PortB_CE = '1') then internal_busy <= '1'; internal_SRam_CE <= '1'; internal_SRamAdress <= PortB_Adress; if(PortB_OE = '1') then internal_SRam_OE <= '1'; PortB_DataOut <= SRam_Data; else internal_SRam_OE <= '0'; end if; if(PortB_WE = '1') then internal_SRam_WE <= '1'; internal_SRamData <= PortB_DataIn; else internal_SRam_WE <= '0'; end if; --nobody selects Ram elsif(PortA_CE = '0') and (PortB_CE = '0') then internal_busy <= '0'; internal_error <= '0'; internal_SRam_CE <= '0'; internal_SRam_OE <= '0'; internal_SRam_WE <= '0'; internal_SRamData <= (others => 'Z'); --both Ports select Ram else --elsif(PortA_CE = '1') and (PortB_CE = '1') then internal_busy <= '1'; internal_error <= '1'; internal_SRam_CE <= '0'; internal_SRam_OE <= '0'; internal_SRam_WE <= '0'; internal_SRamData <= (others => 'Z'); end if; end if; end process; SRam_Adress <= internal_SramAdress; SRam_Data <= internal_SramData; SRam_nCE <= not internal_SRam_CE; SRam_nOE <= not internal_SRam_OE; SRam_nWE <= not internal_SRam_WE; error <= internal_error; busy <= internal_busy; end Behavioral;
