---------------------------------------------------------------------------------- -- Company: Circuit-Break -- Engineer: Jens Weiss -- -- Create Date: 12:39:50 01/01/2025 -- Design Name: VHDL Library -- Module Name: EBI_Interface - Behavioral -- Project Name: -- Target Devices: -- Tool versions: ISE 14.7 (P20121013) -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity EBI_Interface is Port ( clk : in std_logic; reset : in std_logic; --EBI Interface DataAdress : inout std_logic_vector (7 downto 0); Adress16 : in std_logic; Adress17 : in std_logic; Adress18 : in std_logic; ALE0 : in std_logic; ALE1 : in std_logic; nCE : in std_logic; nOE : in std_logic; nWE : in std_logic; --Internal Interface DataOut : out std_logic_vector(7 downto 0); DataIn : in std_logic_vector(7 downto 0); Adress : out std_logic_vector(18 downto 0); CE : out std_logic; OE : out std_logic; WE : out std_logic ); end EBI_Interface; architecture Behavioral of EBI_Interface is signal internal_DataAdress : std_logic_vector(7 downto 0); signal internal_Adress : std_logic_vector(18 downto 0); signal internal_DataOut : std_logic_vector(7 downto 0); signal internal_CE : std_logic; signal internal_OE : std_logic; signal internal_WE : std_logic; begin -- latch Data EBI-Bus for Adress process begin wait until rising_edge(clk); if (reset = '1') then internal_Adress <= (others => '0'); else if (ALE1 = '1') and (ALE0 = '0') then internal_Adress(15 downto 8) <= DataAdress; else internal_Adress(15 downto 8) <= internal_Adress(15 downto 8); end if; if (ALE0 = '1') and (ALE1 = '0') then internal_Adress(7 downto 0) <= DataAdress; else internal_Adress(7 downto 0) <= internal_Adress(7 downto 0); end if; internal_Adress(16) <= Adress16; internal_Adress(17) <= Adress17; internal_Adress(18) <= Adress18; end if; end process; -- transfer Data process begin wait until (rising_edge(clk)); if (reset = '1') then internal_CE <= '0'; internal_OE <= '0'; internal_WE <= '0'; internal_DataAdress <= (others => '0'); internal_DataOut <= (others => '0'); else --EBI selects RAM if(nCE = '0')then internal_CE <= '1'; if (nOE = '0') then internal_DataAdress <= DataIn; internal_OE <= '1'; else internal_OE <= '0'; end if; if (nWE = '0') then internal_DataOut <= DataAdress; internal_WE <= '1'; else internal_WE <= '0'; end if; --EBI deselects RAM else internal_CE <= '0'; internal_OE <= '0'; internal_WE <= '0'; internal_DataAdress <= (others => 'Z'); internal_DataOut <= (others => 'Z'); end if; end if; end process; Adress <= internal_Adress; DataOut <= internal_DataOut; DataAdress <= internal_DataAdress; CE <= internal_CE; OE <= internal_OE; WE <= internal_WE; end Behavioral;
