-------------------------------------------------------------------------------- -- Company: Circuit-Break -- Engineer: Jens Weiss -- -- Create Date: 20:57:27 01/01/2025 -- Design Name: VHDL Library -- Module Name: DualPort_SRamInterface_tb.vhd -- Project Name: -- Target Device: -- Tool versions: ISE 14.7 (P20121013) -- Description: -- -- VHDL Test Bench Created by ISE for module: DualPort_MemoryController -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- -------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; ENTITY DualPort_SRamInterface_tb IS END DualPort_SRamInterface_tb; ARCHITECTURE behavior OF DualPort_SRamInterface_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT DualPort_SRamInterface PORT( clk : IN std_logic; reset : IN std_logic; busy : OUT std_logic; error : OUT std_logic; PortA_Adress : IN std_logic_vector(18 downto 0); PortA_DataIn : IN std_logic_vector(7 downto 0); PortA_DataOut : OUT std_logic_vector(7 downto 0); PortA_CE : IN std_logic; PortA_OE : IN std_logic; PortA_WE : IN std_logic; PortB_Adress : IN std_logic_vector(18 downto 0); PortB_DataIn : IN std_logic_vector(7 downto 0); PortB_DataOut : OUT std_logic_vector(7 downto 0); PortB_CE : IN std_logic; PortB_OE : IN std_logic; PortB_WE : IN std_logic; SRam_Adress : OUT std_logic_vector(18 downto 0); SRam_Data : INOUT std_logic_vector(7 downto 0); SRam_nCE : OUT std_logic; SRam_nOE : OUT std_logic; SRam_nWE : OUT std_logic ); END COMPONENT; --Inputs signal clk : std_logic := '0'; signal reset : std_logic := '0'; signal PortA_Adress : std_logic_vector(18 downto 0) := (others => '0'); signal PortA_DataIn : std_logic_vector(7 downto 0) := (others => '0'); signal PortA_CE : std_logic := '0'; signal PortA_OE : std_logic := '0'; signal PortA_WE : std_logic := '0'; signal PortB_Adress : std_logic_vector(18 downto 0) := (others => '0'); signal PortB_DataIn : std_logic_vector(7 downto 0) := (others => '0'); signal PortB_CE : std_logic := '0'; signal PortB_OE : std_logic := '0'; signal PortB_WE : std_logic := '0'; --BiDirs signal SRam_Data : std_logic_vector(7 downto 0); --Outputs signal busy : std_logic; signal error : std_logic; signal PortA_DataOut : std_logic_vector(7 downto 0); signal PortB_DataOut : std_logic_vector(7 downto 0); signal SRam_Adress : std_logic_vector(18 downto 0); signal SRam_nCE : std_logic; signal SRam_nOE : std_logic; signal SRam_nWE : std_logic; -- Clock period definitions constant clk_period : time := 10 ns; -- Steuerleitung für SRAM signal file_download : boolean := FALSE; signal file_dump : boolean := FALSE; -- signal nCE : std_logic := '1'; -- signal nOE : std_logic := '1'; -- signal nWE : std_logic := '1'; -- signal A : std_logic_vector(18 downto 0) := (others => '0'); -- signal D : std_logic_vector(7 downto 0) := (others => '0'); BEGIN -- Instantiate the Unit Under Test (UUT) uut: DualPort_SRamInterface PORT MAP ( clk => clk, reset => reset, busy => busy, error => error, PortA_Adress => PortA_Adress, PortA_DataIn => PortA_DataIn, PortA_DataOut => PortA_DataOut, PortA_CE => PortA_CE, PortA_OE => PortA_OE, PortA_WE => PortA_WE, PortB_Adress => PortB_Adress, PortB_DataIn => PortB_DataIn, PortB_DataOut => PortB_DataOut, PortB_CE => PortB_CE, PortB_OE => PortB_OE, PortB_WE => PortB_WE, SRam_Adress => SRam_Adress, SRam_Data => SRam_Data, SRam_nCE => SRam_nCE, SRam_nOE => SRam_nOE, SRam_nWE => SRam_nWE ); Sram_Model: entity work.Sram_Model PORT MAP( nCE => SRam_nCE, nOE => SRam_nOE, nWE => SRam_nWE, download => file_download, dump => file_dump, A => SRam_Adress, D => SRam_Data ); -- Clock process definitions clk_process :process begin clk <= '0'; wait for clk_period/2; clk <= '1'; wait for clk_period/2; end process; -- Stimulus process stim_proc: process begin -- hold reset state for 100 ns. wait for 100 ns; -- insert stimulus here reset <= '1'; wait for 100ns; reset <= '0'; PortA_CE <= '0'; PortA_OE <= '0'; PortA_WE <= '0'; PortA_Adress <= (others => '0'); PortA_DataOut <= (others => '0'); PortB_CE <= '0'; PortB_OE <= '0'; PortB_WE <= '0'; PortB_Adress <= (others => '0'); PortB_DataOut <= (others => '0'); wait for 100ns; PortA_CE <= '1'; -- PortB_CE <= '1'; PortA_Adress <= std_logic_vector(to_unsigned(1, 19)); PortA_DataIn <= std_logic_vector(to_unsigned(100, 8)); wait for 32ns; PortA_WE <= '1'; wait for 32ns; PortA_WE <= '0'; wait for 10ns; PortA_CE <= '0'; -- PortB_CE <= '0'; wait; end process; END;
