-------------------------------------------------------------------------------- -- Company: Circuit-Break -- Engineer: Jens Weiss -- -- Create Date: 14:01:05 01/01/2025 -- Design Name: VHDL Library -- Module Name: EBI_Interface_tb.vhd -- Project Name: -- Target Device: -- Tool versions: ISE 14.7 (P20121013) -- Description: -- -- VHDL Test Bench Created by ISE for module: EBI_Interface -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- -------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; ENTITY EBI_Interface_tb IS END EBI_Interface_tb; ARCHITECTURE behavior OF EBI_Interface_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT EBI_Interface PORT( clk : IN std_logic; reset : IN std_logic; DataAdress : INOUT std_logic_vector(7 downto 0); Adress16 : IN std_logic; Adress17 : IN std_logic; Adress18 : IN std_logic; ALE0 : IN std_logic; ALE1 : IN std_logic; nCE : IN std_logic; nOE : IN std_logic; nWE : IN std_logic; DataOut : OUT std_logic_vector(7 downto 0); DataIn : IN std_logic_vector(7 downto 0); Adress : OUT std_logic_vector(18 downto 0); CE : OUT std_logic; OE : OUT std_logic; WE : OUT std_logic ); END COMPONENT; --Inputs signal clk : std_logic := '0'; signal reset : std_logic := '0'; signal Adress16 : std_logic := '0'; signal Adress17 : std_logic := '0'; signal Adress18 : std_logic := '0'; signal ALE0 : std_logic := '0'; signal ALE1 : std_logic := '0'; signal nCE : std_logic := '1'; signal nOE : std_logic := '1'; signal nWE : std_logic := '1'; signal DataIn : std_logic_vector(7 downto 0) := (others => '0'); --BiDirs signal DataAdress : std_logic_vector(7 downto 0); --Outputs signal DataOut : std_logic_vector(7 downto 0); signal Adress : std_logic_vector(18 downto 0); signal CE : std_logic; signal OE : std_logic; signal WE : std_logic; --Signal for Testbench signal EBI_memory_address : integer range 0 to 525287; signal EBI_memory_address_vector : std_logic_vector(18 downto 0); signal EBI_memory_data : integer range 0 to 255; -- Clock period definitions constant clk_period : time := 10 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: EBI_Interface PORT MAP ( clk => clk, reset => reset, DataAdress => DataAdress, Adress16 => Adress16, Adress17 => Adress17, Adress18 => Adress18, ALE0 => ALE0, ALE1 => ALE1, nCE => nCE, nOE => nOE, nWE => nWE, DataOut => DataOut, DataIn => DataIn, Adress => Adress, CE => CE, OE => OE, WE => WE ); -- Clock process definitions clk_process :process begin clk <= '0'; wait for clk_period/2; clk <= '1'; wait for clk_period/2; end process; -- Stimulus process stim_proc: process begin -- hold reset state for 100 ns. wait for 100 ns; -- insert stimulus here reset <= '1'; wait for 100ns; reset <= '0'; nCE <= '1'; nOE <= '1'; nWE <= '1'; Adress16 <= '0'; Adress17 <= '0'; Adress18 <= '0'; ALE0 <= '0'; ALE1 <= '0'; DataAdress <= (others => '0'); EBI_memory_address <= 0; EBI_memory_data <= 0; EBI_memory_address_vector <= (others => '0'); DataIn <= (others => '0'); wait for 100ns; -- for J in 0 to 1024 loop -- --uc write -- EBI_memory_address <= EBI_memory_address + 1; -- EBI_memory_address_vector <= std_logic_vector(to_unsigned(EBI_memory_address, 19)); -- EBI_memory_data <= J; -- wait for 100ns; -- -- nCE <= '0'; -- Adress16 <= EBI_memory_address_vector(16); -- Adress17 <= EBI_memory_address_vector(17); -- Adress18 <= EBI_memory_address_vector(18); -- DataAdress <= EBI_memory_address_vector(15 downto 8); --High Address -- ALE1 <= '1'; -- wait for 24ns; -- ALE1 <= '0'; -- wait for 32ns; -- -- DataAdress <= EBI_memory_address_vector(7 downto 0); --Low Address -- ALE0 <= '1'; -- wait for 25ns; -- ALE0 <= '0'; -- wait for 32ns; -- -- DataAdress <= std_logic_vector(to_unsigned(EBI_memory_data, 8)); --Data -- nWE <= '0'; -- wait for 32ns; -- nWE <= '1'; -- wait for 18ns; -- DataAdress <= (others => 'Z'); -- nCE <= '1'; -- wait for 120ns; -- end loop; for J in 0 to 1024 loop --uc read EBI_memory_address <= EBI_memory_address + 1; EBI_memory_address_vector <= std_logic_vector(to_unsigned(EBI_memory_address, 19)); EBI_memory_data <= J; wait for 100ns; nCE <= '0'; Adress16 <= EBI_memory_address_vector(16); Adress17 <= EBI_memory_address_vector(17); Adress18 <= EBI_memory_address_vector(18); DataAdress <= EBI_memory_address_vector(15 downto 8); --High Address ALE1 <= '1'; wait for 24ns; ALE1 <= '0'; wait for 32ns; DataAdress <= EBI_memory_address_vector(7 downto 0); --Low Address ALE0 <= '1'; wait for 25ns; ALE0 <= '0'; wait for 32ns; DataAdress <= std_logic_vector(to_unsigned(J+5, 8)); --Data nOE <= '0'; wait for 32ns; nOE <= '1'; wait for 18ns; DataAdress <= (others => 'Z'); nCE <= '1'; wait for 120ns; end loop; wait; end process; END;
