#include #include #include int willPickUpDisk(byte disk, byte targetPosition, byte direction, byte fullRotation); void testOpen(); void rotateDial(byte position, byte direction); void rotateFull(byte direction); void dialCombination(byte disk0, byte disk1, byte disk2); void setDisk2(byte position); void setDisk1(byte position); void setDisk0(byte position); void printAllDiskState(); void printDiskState(byte disk); // Define stepper motor connections and motor interface type. Motor interface type must be set to 1 when using a driver #define motorInterfaceType 1 #define dirPin D2 #define stepPin D3 // Stepper motor speed configuration #define microStepsFactor 8 #define maxStepperSpeed 4000 #define inversionPause 50 // Create a new instance of the AccelStepper class: AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin); // Runtime data byte currentDialPosition = 255; byte currentDiskPosition[] = {255, 255, 255}; byte rotationMode[] = {0, 0, 0}; byte startOffset = 0; void setup() { Serial.begin(115200); // Set the maximum speed in steps per second: stepper.setMaxSpeed(maxStepperSpeed); stepper.setAcceleration(40000); Serial.println("Usage:"); Serial.println("=================="); Serial.println("1 - One full rotation counter-clockwise"); Serial.println("2 - One full rotation clockwise"); Serial.println("3 - Quarter rotation counter-clockwise"); Serial.println("4 - Quarter rotation clockwise"); Serial.println("5 - Rotate one number counter-clockwise"); Serial.println("6 - Rotate one number clockwise"); Serial.println("p - Rotate couter-clockwise three times to pick up all disks"); Serial.println("0 - Set current dial position as 0"); Serial.println("+ - Increment start number for first disk"); Serial.println("o - Try opening by rotating counterclockwise almost one turn"); Serial.println("s - Start autodialing numbers"); } void loop() { if (Serial.available()) { int input = Serial.read(); if (input == '1') { Serial.println("Doing a full rotation counter-clockwise"); rotateFull(2); } else if (input == '2') { Serial.println("Doing a full rotation clockwise"); rotateFull(1); } else if (input == '3') { Serial.println("Doing a quarter rotation counter-clockwise"); rotateDial((currentDialPosition + 25) % 100, 2); } else if (input == '4') { Serial.println("Doing a quarter rotation clockwise"); rotateDial((currentDialPosition + 75) % 100, 1); } else if (input == '5') { Serial.println("Moving one number counter-clockwise"); rotateDial((currentDialPosition + 1) % 100, 2); } else if (input == '6') { Serial.println("Moving one number clockwise"); rotateDial((currentDialPosition + 99) % 100, 1); } else if (input == 'p') { Serial.println("Rotating three times couter-clockwise to pick up all disks"); rotateFull(2); rotateFull(2); rotateFull(2); } else if (input == '0') { Serial.println("Current dial position stored as 0."); stepper.setCurrentPosition(0); currentDialPosition = 0; } else if (input == '+') { startOffset += 1; Serial.print("Start offset incremented to "); Serial.println(startOffset); } else if (input == 'o') { Serial.println("Try opening by rotating counterclockwise almost one turn"); testOpen(); } else if (input == 's') { Serial.println("Starting to test combinations"); for (byte k = startOffset; k < 100; k+=2) { for (byte j = 98; j < 100; j-=2) { for (byte i = 0; i < 100; i+=2) { Serial.print("Testing combination "); Serial.print(k); Serial.print(" - "); Serial.print(j); Serial.print(" - "); Serial.println(i); dialCombination(k, j, i); testOpen(); } } } } } delay(200); } /** * Predicate to determine whether moving the dial to * in direction will change the position of disk number . * If is true, a movement to the current dial position is interpreted * as a full rotation instead of no rotation. */ int willPickUpDisk(byte disk, byte targetPosition, byte direction, byte fullRotation) { byte startPosition = disk == 0 ? currentDialPosition : currentDiskPosition[disk - 1]; byte drivingDiskRotationMode = disk == 0 ? direction : rotationMode[disk - 1]; if (startPosition < targetPosition) { return (direction == 2 && (currentDiskPosition[disk] > startPosition && currentDiskPosition[disk] < targetPosition)) || (direction == 1 && (currentDiskPosition[disk] < startPosition || currentDiskPosition[disk] > targetPosition)) || (currentDiskPosition[disk] == targetPosition) || (currentDiskPosition[disk] == startPosition && rotationMode[disk] == direction); } else if (startPosition > targetPosition) { return (direction == 2 && (currentDiskPosition[disk] > startPosition || currentDiskPosition[disk] < targetPosition)) || (direction == 1 && (currentDiskPosition[disk] < startPosition && currentDiskPosition[disk] > targetPosition)) || (currentDiskPosition[disk] == targetPosition) || (currentDiskPosition[disk] == startPosition && rotationMode[disk] == direction); } else if (fullRotation == 1) { // Start is the same as end, with full rotation return drivingDiskRotationMode == direction; } else { // Start is the same as end without movement, just check if already picked up. return rotationMode[disk] == direction; } } /** * Try opening the lock by moving close to a full rotation clockwise, * wait a moment and rotate back to the previous position. */ void testOpen() { rotateDial((currentDialPosition + 5) % 100, 1); delay(100); rotateDial((currentDialPosition + 95) % 100, 2); } /** * Rotate the dial to , moving in the given . * If is 1 the rotation is done clockwise, * if it is 2 the rotation is counter-clockwise. */ void rotateDial(byte position, byte direction) { if (direction == 1) { Serial.print(" - Clockwise rotation of dial from position "); Serial.print(currentDialPosition); Serial.print(" to position "); Serial.println(position); } else if (direction == 2) { Serial.print(" - Counter-clockwise rotation of dial from position "); Serial.print(currentDialPosition); Serial.print(" to position "); Serial.println(position); } // Check which disks we will move here. int diskMoving[3] = {0, 0, 0}; if (willPickUpDisk(0, position, direction, 0)) { Serial.println(" - Disk 0 will be moved"); diskMoving[0] = 1; } if (diskMoving[0] && willPickUpDisk(1, position, direction, 0)) { Serial.println(" - Disk 1 will be moved"); diskMoving[1] = 1; } if (diskMoving[1] && willPickUpDisk(2, position, direction, 0)) { Serial.println(" - Disk 2 will be moved"); diskMoving[2] = 1; } // Calc stepper motor movement int steps = 0; if (direction == 1 && currentDialPosition > position) { steps = (currentDialPosition - position) * 2 * microStepsFactor; } if (direction == 1 && currentDialPosition < position) { steps = (currentDialPosition + (100 - position)) * 2 * microStepsFactor; } if (direction == 2 && currentDialPosition < position) { steps = (position - currentDialPosition) * -2 * microStepsFactor; } if (direction == 2 && currentDialPosition > position) { steps = ((100 - currentDialPosition) + position) * -2 * microStepsFactor; } stepper.move(steps); stepper.runToPosition(); // Store new dial position currentDialPosition = position; // Save new position for moved disk if (diskMoving[0]) { rotationMode[0] = direction; currentDiskPosition[0] = position; } if (diskMoving[1]) { rotationMode[1] = direction; currentDiskPosition[1] = position; } if (diskMoving[2]) { rotationMode[2] = direction; currentDiskPosition[2] = position; } printAllDiskState(); } /** * Do a full rotation of the dial, either clockwise or counter-clockwise. */ void rotateFull(byte direction) { if (direction == 1) { Serial.print(" - Full clockwise rotation of dial at position "); Serial.println(currentDialPosition); } else if (direction == 2) { Serial.print(" - Full counter-clockwise rotation of dial at position "); Serial.println(currentDialPosition); } // Check which disks we will move here. int diskMoving[3] = {0, 0, 0}; if (willPickUpDisk(0, currentDialPosition, direction, 1)) { Serial.println(" - Disk 0 will be moved"); diskMoving[0] = 1; } if (diskMoving[0] && willPickUpDisk(1, currentDialPosition, direction, 1)) { Serial.println(" - Disk 1 will be moved"); diskMoving[1] = 1; } if (diskMoving[1] && willPickUpDisk(2, currentDialPosition, direction, 1)) { Serial.println(" - Disk 2 will be moved"); diskMoving[2] = 1; } // Calc stepper motor movement int steps = direction == 1 ? 200 * microStepsFactor : -200 * microStepsFactor; stepper.move(steps); stepper.runToPosition(); // Save new position for moved disk if (diskMoving[0]) { rotationMode[0] = direction; currentDiskPosition[0] = currentDialPosition; } if (diskMoving[1]) { rotationMode[1] = direction; currentDiskPosition[1] = currentDialPosition; } if (diskMoving[2]) { rotationMode[2] = direction; currentDiskPosition[2] = currentDialPosition; } printAllDiskState(); } /** * Dial the given combination. */ void dialCombination(byte disk2, byte disk1, byte disk0) { setDisk2(disk2); setDisk1(disk1); setDisk0(disk0); } /** * Move disk 2 to the given position counter-clockwise. * If the disk is already at the given position, * no movement is performed. */ void setDisk2(byte position) { if (currentDiskPosition[2] != position || rotationMode[0] != 2) { Serial.print(" Repositioning disk 2 to "); Serial.print(position); Serial.println(" (counter-clockwise)"); while (!(willPickUpDisk(0, position, 2, 0) && willPickUpDisk(1, position, 2, 0) && willPickUpDisk(2, position, 2, 0))) { Serial.println(" Full rotation needed"); rotateFull(2); } rotateDial(position, 2); } } /** * Move disk 1 to the given position clockwise. * If the disk is already at the given position, * no movement is performed. */ void setDisk1(byte position) { if (currentDiskPosition[1] != position || rotationMode[1] != 1) { Serial.print(" Repositioning disk 1 to "); Serial.print(position); Serial.println(" (clockwise)"); while (!(willPickUpDisk(0, position, 1, 0) && willPickUpDisk(1, position, 1, 0))) { Serial.println(" Full rotation needed"); rotateFull(1); } rotateDial(position, 1); } } /** * Move disk 0 to the given position counter-clockwise. * If the disk is already at the given position, * no movement is performed. */ void setDisk0(byte position) { if (currentDiskPosition[0] != position || rotationMode[0] != 2) { Serial.print(" Repositioning disk 0 to "); Serial.print(position); Serial.println(" (counter-clockwise)"); while (!(willPickUpDisk(0, position, 2, 0))) { Serial.println(" Full rotation needed"); rotateFull(2); } rotateDial(position, 2); } } /** * Debug output to print the current state of all disks */ void printAllDiskState() { printDiskState(2); printDiskState(1); printDiskState(0); } void printDiskState(byte disk) { Serial.print("Disk "); Serial.print(disk); Serial.print(" currently at position "); if (currentDiskPosition[disk] == 255) { Serial.print(""); } else { Serial.print(currentDiskPosition[disk]); } Serial.print(" with rotation Mode "); if (rotationMode[disk] == 0) { Serial.print(""); } else if (rotationMode[disk] == 1) { Serial.print("clockwise"); } else { Serial.print("counter-clockwise"); } Serial.println("."); }
