using keys found in /config/keys chmod: changing permissions of '/config/nginx/site-confs': Bad address chmod: changing permissions of '/config/nginx/site-confs/default.conf.sample': Bad address chmod: changing permissions of '/config/nginx/site-confs/default.conf': Bad address chmod: changing permissions of '/config/nginx/nginx.conf.sample': Bad address chmod: changing permissions of '/config/nginx/ssl.conf.sample': Bad address chmod: changing permissions of '/config/nginx/nginx.conf': Bad address chmod: changing permissions of '/config/nginx/ssl.conf': Bad address chmod: changing permissions of '/config/nginx/dhparams.pem': Bad address chmod: changing permissions of '/config/nginx/resolver.conf': Bad address chmod: changing permissions of '/config/nginx/worker_processes.conf': Bad address chmod: changing permissions of '/etc/logrotate.d/acpid': Bad address chmod: changing permissions of '/etc/logrotate.d/rsyncd': Bad address chmod: changing permissions of '/etc/logrotate.d/samba': Bad address chmod: changing permissions of '/etc/logrotate.d/nginx': Bad address chmod: changing permissions of '/etc/logrotate.d/php-fpm': Bad address chmod: changing permissions of '/etc/logrotate.d/php-fpm83': Bad address After completing the web-based installer, restart the Nextcloud container to apply default memory caching and transactional file locking configurations. Alternatively, you can apply your own configurations by editing /config/www/nextcloud/config/config.php following the documentation: https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/caching_configuration.html https://docs.nextcloud.com/server/latest/admin_manual/configuration_files/files_locking_transactional.html [custom-init] No custom files found, skipping... [ls.io-init] done. Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused in /app/www/public/lib/private/DB/Connection.php:233 Stack trace: #0 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(453): OC\DB\Connection->connect() #1 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(411): Doctrine\DBAL\Connection->getDatabasePlatformVersion() #2 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(318): Doctrine\DBAL\Connection->detectDatabasePlatform() #3 /app/www/public/lib/private/DB/Connection.php(899): Doctrine\DBAL\Connection->getDatabasePlatform() #4 /app/www/public/lib/private/DB/ConnectionAdapter.php(235): OC\DB\Connection->getDatabaseProvider() #5 /app/www/public/lib/private/DB/QueryBuilder/QueryBuilder.php(96): OC\DB\ConnectionAdapter->getDatabaseProvider() #6 /app/www/public/lib/private/AppConfig.php(1211): OC\DB\QueryBuilder\QueryBuilder->expr() #7 /app/www/public/lib/private/AppConfig.php(237): OC\AppConfig->loadConfig() #8 /app/www/public/lib/private/AppConfig.php(1351): OC\AppConfig->searchValues() #9 /app/www/public/lib/private/App/AppManager.php(126): OC\AppConfig->getValues() #10 /app/www/public/lib/private/App/AppManager.php(147): OC\App\AppManager->getInstalledAppsValues() #11 /app/www/public/lib/private/legacy/OC_App.php(191): OC\App\AppManager->getInstalledApps() #12 /app/www/public/lib/private/AppFramework/Bootstrap/Coordinator.php(48): OC_App::getEnabledApps() #13 /app/www/public/lib/base.php(659): OC\AppFramework\Bootstrap\Coordinator->runInitialRegistration() #14 /app/www/public/lib/base.php(1134): OC::init() #15 /app/www/public/cron.php(24): require_once('...') #16 {main} Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused in /app/www/public/lib/private/DB/Connection.php:233 Stack trace: #0 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(453): OC\DB\Connection->connect() #1 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(411): Doctrine\DBAL\Connection->getDatabasePlatformVersion() #2 /app/www/public/3rdparty/doctrine/dbal/src/Connection.php(318): Doctrine\DBAL\Connection->detectDatabasePlatform() #3 /app/www/public/lib/private/DB/Connection.php(899): Doctrine\DBAL\Connection->getDatabasePlatform() #4 /app/www/public/lib/private/DB/ConnectionAdapter.php(235): OC\DB\Connection->getDatabaseProvider() #5 /app/www/public/lib/private/DB/QueryBuilder/QueryBuilder.php(96): OC\DB\ConnectionAdapter->getDatabaseProvider() #15 /app/www/public/cron.php(24): require_once('...') #16 {main}
