/* ****************************************************************************************************** */ /* demo2106_blink_flash.cmd LINKER SCRIPT */ /* */ /* */ /* The Linker Script defines how the code and data emitted by the GNU C compiler and assembler are */ /* to be loaded into memory (code goes into FLASH, variables go into RAM). */ /* */ /* Any symbols defined in the Linker Script are automatically global and available to the rest of the */ /* program. */ /* */ /* To force the linker to use this LINKER SCRIPT, just add the -T demo2106_blink_flash.cmd directive */ /* to the linker flags in the makefile. */ /* */ /* LFLAGS = -Map main.map -nostartfiles -T demo2106_blink_flash.cmd */ /* */ /* */ /* The Philips boot loader supports the ISP (In System Programming) via the serial port and the IAP */ /* (In Application Programming) for flash programming from within your application. */ /* */ /* The boot loader uses RAM memory and we MUST NOT load variables or code in these areas. */ /* */ /* RAM used by boot loader: 0x40000120 - 0x400001FF (223 bytes) for ISP variables */ /* 0x4000FFE0 - 0x4000FFFF (32 bytes) for ISP and IAP variables */ /* 0x4000FEE0 - 0x4000FFDF (256 bytes) stack for ISP and IAP */ /* */ /* */ /* MEMORY MAP */ /* | |0x40010000 */ /* .-------->|---------------------------------| */ /* . | |0x4000FFFF */ /* ram_isp_high | variables and stack | */ /* . | for Philips boot loader | */ /* . | 288 bytes | */ /* . | Do not put anything here |0x4000FEE0 */ /* .-------->|---------------------------------| */ /* | UDF Stack 4 bytes |0x4000FEDC <---------- _stack_end */ /* .-------->|---------------------------------| */ /* | ABT Stack 4 bytes |0x4000FED8 */ /* .-------->|---------------------------------| */ /* | FIQ Stack 4 bytes |0x4000FED4 */ /* .-------->|---------------------------------| */ /* | IRQ Stack 4 bytes |0x4000FED0 */ /* .-------->|---------------------------------| */ /* | SVC Stack 4 bytes |0x4000FECC */ /* .-------->|---------------------------------| */ /* . | |0x4000FEC8 */ /* . | stack area for user program | */ /* . | | */ /* . | | */ /* . | | */ /* . | | */ /* . | | */ /* . | | */ /* . | | */ /* . | free ram | */ /* ram | | */ /* . | | */ /* . | | */ /* . |.................................|0x40000234 <---------- _bss_end */ /* . | | */ /* . | .bss uninitialized variables | */ /* . |.................................|0x40000218 <---------- _bss_start, _edata */ /* . | | */ /* . | | */ /* . | | */ /* . | .data initialized variables | */ /* . | | */ /* . | | */ /* . | |0x40000200 <---------- _data */ /* .-------->|---------------------------------| */ /* . | variables used by |0x400001FF */ /* ram_isp_low | Philips boot loader | */ /* . | 223 bytes |0x40000120 */ /* .-------->|---------------------------------| */ /* . | |0x4000011F */ /* ram_vectors | free ram | */ /* . |---------------------------------|0x40000040 */ /* . | |0x4000003F */ /* . | Interrupt Vectors (re-mapped) | */ /* . | 64 bytes |0x40000000 */ /* .-------->|---------------------------------| */ /* | | */ /* */ /* */ /* */ /* | | */ /* .--------> |---------------------------------| */ /* . | |0x0001FFFF */ /* . | | */ /* . | | */ /* . | | */ /* . | | */ /* . | | */ /* . | unused flash eprom | */ /* . | | */ /* . |.................................| */ /* . | | */ /* . | | */ /* . | | */ /* . | copy of .data area | */ /* flash | | */ /* . | | */ /* . | | */ /* . |---------------------------------|0x00000284 <----------- _etext */ /* . | | */ /* . | |0x00000180 main */ /* . | |0x00000104 Initialize */ /* . | C code |0x00000100 UNDEF_Routine */ /* . | |0x000000fc SWI_Routine */ /* . | |0x000000f8 FIQ_Routine */ /* . | |0x000000f4 IRQ_Routine */ /* . |---------------------------------|0x000000d8 feed */ /* . | |0x000000D4 */ /* . | Startup Code | */ /* . | (assembler) | */ /* . | | */ /* . |---------------------------------|0x00000040 Reset_Handler */ /* . | |0x0000003F */ /* . | Interrupt Vector Table (unused) | */ /* . | 64 bytes | */ /* .--------->|---------------------------------|0x00000000 _startup * /* */ /* */ /* The easy way to prevent the linker from loading anything into a memory area is to define */ /* a MEMORY region for it and then avoid assigning any .text, .data or .bss sections into it. */ /* */ /* */ /* MEMORY */ /* { */ /* ram_isp_low(A) : ORIGIN = 0x40000120, LENGTH = 223 */ /* */ /* } */ /* */ /* */ /* Author: James P. Lynch */ /* */ /* ****************************************************************************************************** */ /* identify the Entry Point */ ENTRY(_startup) /* specify the LPC2378 memory areas */ MEMORY { flash : ORIGIN = 0, LENGTH = 512K /* FLASH ROM */ ram_isp_low(A) : ORIGIN = 0x40000120, LENGTH = 223 /* variables used by Philips ISP bootloader */ ram : ORIGIN = 0x40000200, LENGTH = 32224 /* free RAM area */ ram_isp_high(A) : ORIGIN = 0x40007FE0, LENGTH = 32 /* variables used by Philips ISP bootloader */ } /* define a global symbol _stack_end */ _stack_end = 0x40007EDC; /* now define the output sections */ SECTIONS { . = 0; /* set location counter to address zero */ .startup : { *(.startup)} >flash /* the startup code goes into FLASH */ .text : /* collect all sections that should go into FLASH after startup */ { *(.text) /* all .text sections (code) */ *(.rodata) /* all .rodata sections (constants, strings, etc.) */ *(.rodata*) /* all .rodata* sections (constants, strings, etc.) */ *(.glue_7) /* all .glue_7 sections (no idea what these are) */ *(.glue_7t) /* all .glue_7t sections (no idea what these are) */ _etext = .; /* define a global symbol _etext just after the last code byte */ } >flash /* put all the above into FLASH */ .data : /* collect all initialized .data sections that go into RAM */ { _data = .; /* create a global symbol marking the start of the .data section */ *(.data) /* all .data sections */ _edata = .; /* define a global symbol marking the end of the .data section */ } >ram AT >flash /* put all the above into RAM (but load the LMA copy into FLASH) */ .bss : /* collect all uninitialized .bss sections that go into RAM */ { _bss_start = .; /* define a global symbol marking the start of the .bss section */ *(.bss) /* all .bss sections */ } >ram /* put all the above in RAM (it will be cleared in the startup code */ . = ALIGN(4); /* advance location counter to the next 32-bit boundary */ _bss_end = . ; /* define a global symbol marking the end of the .bss section */ } _end = .; /* define a global symbol marking the end of application RAM */
