ERROR: Node U1:11 is floating and connected to current source G:U1:U2:R1 ERROR: Node U1:U_TF:VP1 is floating and connected to current source G:U1:U_TF:P1 ERROR: Node U1:U_TF:VP2 is floating and connected to current source G:U1:U_TF:P2 ERROR: Node U1:U_TF:VP3 is floating and connected to current source G:U1:U_TF:P3 ERROR: Node U1:U_TF:VP4 is floating and connected to current source G:U1:U_TF:P4 ERROR: Node U1:U_TF:VZ1 is floating and connected to current source G:U1:U_TF:Z1 ERROR: Node U1:U_TF:VZ2 is floating and connected to current source G:U1:U_TF:Z2 ERROR: Node U1:U_TF:VZ3 is floating and connected to current source G:U1:U_TF:Z3 ERROR: Node U1:U_TF:VZ4 is floating and connected to current source G:U1:U_TF:Z4 ERROR: Node U1:17 is floating and connected to current source G:U1:U_TF:Z5 Direct Newton iteration for .op point succeeded. Heightened Def Con from 6.42898e-011 to 6.42898e-011 Date: Tue Mar 18 09:41:31 2025 Total elapsed time: 7.565 seconds. tnom = 27 temp = 27 method = modified trap totiter = 422573 traniter = 422568 tranpoints = 93911 accept = 70431 rejected = 23481 matrix size = 82 fillins = 74 solver = Normal Thread vector: 21.8/18.7[2] 4.8/10.1[1] 5.7/9.6[1] 0.6/7.4[1] 2592/500 Matrix Compiler1: 6.04 KB object code size 3.1/1.9/[0.7] Matrix Compiler2: 7.88 KB object code size 1.5/2.2/[0.6]
