#include // Standard Arduino header #include #include // Define the serial port using PF0 (TX) and PF1 (RX) HardwareSerial Serial2(PF0, PF1); // Pin definitions for the LCD #define LCD_BL_PWR PA9 #define LCD_VDD_PWR PF_3 // PY32Core! PF_3 IS RIGHT! #define LCD_PIN_RESET PB4 #define LCD_PIN_SCK PB3 #define LCD_PIN_DATA PB5 #define LCD_PIN_CS PA8 #define LCD_PIN_CMD_DATA PA12 #define LCD_PIN_BACKLIGHT PA11 #define LCD_WIDTH 128 #define LCD_HEIGHT 160 // Some RGB565 colors #define LCD_RGB565_BLACK 0x0000 #define LCD_RGB565_WHITE 0xFFFF #define LCD_RGB565_RED 0xF800 #define LCD_RGB565_GREEN 0x07E0 #define LCD_RGB565_BLUE 0x001F void setup() { Serial2.begin(115200); Serial2.println("Initializing LCD..."); pinMode(LCD_VDD_PWR, OUTPUT); pinMode(LCD_BL_PWR, OUTPUT); pinMode(LCD_PIN_RESET, OUTPUT); pinMode(LCD_PIN_CS, OUTPUT); pinMode(LCD_PIN_CMD_DATA, OUTPUT); digitalWrite(LCD_VDD_PWR, LOW); digitalWrite(LCD_BL_PWR, HIGH); digitalWrite(LCD_PIN_BACKLIGHT, HIGH); digitalWrite(LCD_PIN_CS, HIGH); digitalWrite(LCD_PIN_RESET, LOW); delay(100); digitalWrite(LCD_PIN_RESET, HIGH); delay(100); // Configure SPI for LCD SPI.setSCLK(LCD_PIN_SCK); SPI.setMOSI(LCD_PIN_DATA); SPI.setMISO(NC); SPI.begin(); SPI.beginTransaction(SPISettings(400000, MSBFIRST, SPI_MODE0)); pinMode(LCD_PIN_BACKLIGHT, OUTPUT); digitalWrite(LCD_PIN_BACKLIGHT, HIGH); lcdInit(1); //LCD_transfer_test(); } void loop() { Serial2.println("loop"); delay(1000); } void lcdInit(char v) { if(v==1){ lcdCommand(0xFF); lcdData(0xA5); lcdCommand(0xFF); lcdData(0xA5); lcdCommand(0xFF); lcdData(0xA5); lcdCommand(0x3E); lcdData(0x08); lcdCommand(0x3A); lcdData(0x65); lcdCommand(0x82); lcdData(0x00); lcdCommand(0x98); lcdData(0x00); lcdCommand(0x63); lcdData(0x0F); lcdCommand(0x64); lcdData(0x0F); lcdCommand(0xB4); lcdData(0x34); lcdCommand(0xB5); lcdData(0x30); lcdCommand(0x83); lcdData(0x13); lcdCommand(0x86); lcdData(0x04); lcdCommand(0x87); lcdData(0x16); lcdCommand(0x88); lcdData(0x28); lcdCommand(0x89); lcdData(0x2F); lcdCommand(0x93); lcdData(0x63); lcdCommand(0x96); lcdData(0x81); lcdCommand(0xC3); lcdData(0x11); lcdCommand(0xE6); lcdData(0x00); lcdCommand(0x99); lcdData(0x01); lcdCommand(0x44); lcdData(0x00); lcdCommand(0x70); lcdData(0x07); lcdCommand(0x71); lcdData(0x19); lcdCommand(0x72); lcdData(0x1A); lcdCommand(0x73); lcdData(0x13); lcdCommand(0x74); lcdData(0x19); lcdCommand(0x75); lcdData(0x1D); lcdCommand(0x76); lcdData(0x47); lcdCommand(0x77); lcdData(0x0A); lcdCommand(0x78); lcdData(0x07); lcdCommand(0x79); lcdData(0x47); lcdCommand(0x7A); lcdData(0x05); lcdCommand(0x7B); lcdData(0x09); lcdCommand(0x7C); lcdData(0x0D); lcdCommand(0x7D); lcdData(0x0C); lcdCommand(0x7E); lcdData(0x0C); lcdCommand(0x7F); lcdData(0x08); lcdCommand(0xA0); lcdData(0x0B); lcdCommand(0xA1); lcdData(0x36); lcdCommand(0xA2); lcdData(0x09); lcdCommand(0xA3); lcdData(0x0D); lcdCommand(0xA4); lcdData(0x08); lcdCommand(0xA5); lcdData(0x23); lcdCommand(0xA6); lcdData(0x3B); lcdCommand(0xA7); lcdData(0x04); lcdCommand(0xA8); lcdData(0x07); lcdCommand(0xA9); lcdData(0x38); lcdCommand(0xAA); lcdData(0x0A); lcdCommand(0xAB); lcdData(0x12); lcdCommand(0xAC); lcdData(0x0C); lcdCommand(0xAD); lcdData(0x07); lcdCommand(0xAE); lcdData(0x2F); lcdCommand(0xAF); lcdData(0x07); lcdCommand(0xFF); lcdData(0x00); lcdCommand(0x36); lcdData(0x40); lcdCommand(0x11); }else { lcdCommand(0xFF); lcdData(0xA5); lcdCommand(0x3E); lcdData(0x08); lcdCommand(0x3A); lcdData(0x65); lcdCommand(0x82); lcdData(0x00); lcdCommand(0x98); lcdData(0x00); lcdCommand(0x63); lcdData(0x0F); lcdCommand(0x64); lcdData(0x0F); lcdCommand(0xB4); lcdData(0x34); lcdCommand(0xB5); lcdData(0x30); lcdCommand(0x83); lcdData(0x13); lcdCommand(0x86); lcdData(0x04); lcdCommand(0x87); lcdData(0x12); lcdCommand(0x88); lcdData(0x09); lcdCommand(0x89); lcdData(0x2F); lcdCommand(0x93); lcdData(0x63); lcdCommand(0x96); lcdData(0x81); lcdCommand(0xC3); lcdData(0x11); lcdCommand(0xE6); lcdData(0x00); lcdCommand(0x99); lcdData(0x01); lcdCommand(0x44); lcdData(0x00); lcdCommand(0x70); lcdData(0x07); lcdCommand(0x71); lcdData(0x1B); lcdCommand(0x72); lcdData(0x08); lcdCommand(0x73); lcdData(0x0F); lcdCommand(0x74); lcdData(0x16); lcdCommand(0x75); lcdData(0x1A); lcdCommand(0x76); lcdData(0x3C); lcdCommand(0x77); lcdData(0x0A); lcdCommand(0x78); lcdData(0x05); lcdCommand(0x79); lcdData(0x3A); lcdCommand(0x7A); lcdData(0x06); lcdCommand(0x7B); lcdData(0x0B); lcdCommand(0x7C); lcdData(0x12); lcdCommand(0x7D); lcdData(0x0B); lcdCommand(0x7E); lcdData(0x0A); lcdCommand(0x7F); lcdData(0x08); lcdCommand(0xA0); lcdData(0x0B); lcdCommand(0xA1); lcdData(0x36); lcdCommand(0xA2); lcdData(0x0B); lcdCommand(0xA3); lcdData(0x0C); lcdCommand(0xA4); lcdData(0x08); lcdCommand(0xA5); lcdData(0x22); lcdCommand(0xA6); lcdData(0x43); lcdCommand(0xA7); lcdData(0x04); lcdCommand(0xA8); lcdData(0x05); lcdCommand(0xA9); lcdData(0x3F); lcdCommand(0xAA); lcdData(0x0A); lcdCommand(0xAB); lcdData(0x11); lcdCommand(0xAC); lcdData(0x0D); lcdCommand(0xAD); lcdData(0x06); lcdCommand(0xAE); lcdData(0x3B); lcdCommand(0xAF); lcdData(0x07); lcdCommand(0xFF); lcdData(0x00); lcdCommand(0x36); lcdData(0x40); lcdCommand(0x11); } } void lcdCommand(uint8_t command) { digitalWrite(LCD_PIN_CS, LOW); digitalWrite(LCD_PIN_CMD_DATA, LOW); // Command mode SPI.transfer(command); digitalWrite(LCD_PIN_CS, HIGH); } void lcdData(uint8_t data) { digitalWrite(LCD_PIN_CS, LOW); digitalWrite(LCD_PIN_CMD_DATA, HIGH); // Data mode SPI.transfer(data); digitalWrite(LCD_PIN_CS, HIGH); } void LCD_transfer_test() { uint8_t col_start = 0, col_end = LCD_WIDTH - 1; uint8_t row_start = 0, row_end = LCD_HEIGHT - 1; // Turn on the backlight digitalWrite(LCD_PIN_BACKLIGHT, HIGH); // Display ON command lcdCommand(0x29); // Memory Access Control lcdCommand(0x36); lcdData(0x00); // Column Address Set lcdCommand(0x2A); lcdData(0x00); // Start high byte lcdData(col_start); // Start low byte lcdData(0x00); // End high byte lcdData(col_end); // End low byte // Row Address Set lcdCommand(0x2B); lcdData(0x00); // Start high byte lcdData(row_start); // Start low byte lcdData(0x00); // End high byte lcdData(row_end); // End low byte // Memory Write lcdCommand(0x2C); // Send the pixels as 8 color bars for (uint8_t row = row_start; row <= row_end; row++) { uint16_t color; uint8_t which_color = (row - row_start) / ((row_end + 1 - row_start) / 8); switch (which_color) { case 0: color = LCD_RGB565_WHITE; break; case 1: color = LCD_RGB565_RED; break; case 2: color = LCD_RGB565_GREEN; break; case 3: color = LCD_RGB565_BLUE; break; case 4: color = LCD_RGB565_BLACK; break; case 5: color = LCD_RGB565_RED | LCD_RGB565_GREEN; break; case 6: color = LCD_RGB565_RED | LCD_RGB565_BLUE; break; default: color = LCD_RGB565_BLUE | LCD_RGB565_GREEN; break; } for (uint8_t col = col_start; col <= col_end; col++) { SPI.transfer(color << 8); SPI.transfer(color & 0xFF); } } }
