#usage "Limit drill diameter of pads, vias and holes for easier manual drilling.\n"
"Draws small circles in layer 116 inside the drilling of pads, vias and holes, "
"which should make it easier to center the tool while drilling the "
"board manually."
"Usage: RUN drill-aid [ diameter ]"
"Activate layer 116 in addition to the bottom side layers in the "
"CAM processor or use the DISPLAY command to activate it for printing."
"To delete the elements in layer 116 afterwards, display it without "
"any other layers, and use GROUP and DELETE. Then remove the whole "
"layer with the command LAYER -116."
"Author: support@cadsoft.de"
// THIS PROGRAM IS PROVIDED AS IS AND WITHOUT WARRANTY OF ANY KIND, EXPRESSED OR IMPLIED
real drilcent = 0.3; // center drill diameter
string cmd = "GRID mm;\nLayer 116 centerDrill;\nchange layer 116;\n";
void center(int x, int y, int drill) {
real width = 0; //(u2mm(drill) - drilcent) / 2 + 0.05; // overlap 0.05mm 2008-09-01 alf
real radius = 0.1; //width / 2 + (drilcent / 2);
if (radius < (drilcent / 2 + 0.025) ) return;
string h;
sprintf(h, "circle %.3f (%.3f %.3f) (%.3f %.3f) ;\n",
width,
u2mm(x), u2mm(y), u2mm(x) + radius, u2mm(y) );
cmd += h;
return;
if (board) board(B) {
if (argv[1]) drilcent = strtod(argv[1]);
else {
int Result = dlgDialog("Drill AID V2") {
dlgLabel(usage);
dlgLabel("&Drill center diameter mm");
dlgHBoxLayout {
dlgRealEdit(drilcent);
dlgStretch(1);
dlgPushButton("+OK") dlgAccept();
dlgStretch(1);
dlgPushButton("-&Cancel") dlgReject();
if (!Result) exit (0);
B.holes(L) {
center(L.x, L.y, L.drill);
B.elements(E) {
E.package.holes(H) {
center(H.x, H.y, H.drill);
E.package.contacts(C) {
if (C.pad) {
center(C.pad.x, C.pad.y, C.pad.drill);
B.signals(S) {
S.vias(V) {
center(V.x, V.y, V.drill);
exit (cmd);
else dlgMessageBox("Start this ULP in a Board!", "OK");
exit (0);
