; ; 328P_Timer2Mode0 ; ; Created: 19.03.2025 15:33:59 ; Author : Andreas ; C:\Program Files (x86)\Atmel\Studio\7.0\packs\atmel\ATmega_DFP\1.7.374\avrasm\inc\m328Pdef.inc ;.include "file" .device ATmega328P .EQU takt = 16000000 ; Systemtakt 16 MHz intern => 1 CPU clk = 62,5ns .equ T2Go = 250 ; T2 prevalue .DEF akku = r16 ; Arbeitsregister, 'akku' = r16 .def dummy = r17 ; Dummy verwendung .def toggle1 = r20 ; portd by I_TIMER2_OVF .def toggle2 = r21 ; portc by I_TIMER2_COMPA .def T2_PREVAL = r22 ; timer2 preset value ;********************************************************************** .CSEG ; Programm-Flash => 'CodeSegment' .org $00 ; Beginn Flash section for interrupt vectors jmp I_RESET ; #1 Reset, 3 cycl jmp I_INT0 ; #2 INT0 - Externer Interrupt 0 jmp I_INT1 ; #3 INT1 - Externer Interrupt 1 jmp I_PCINT0 ; #4 PCINT0 - Pin Change Interrupt Request 0 jmp I_PCINT1 ; #5 PCINT1 - Pin Change Interrupt Request 1 jmp I_PCINT2 ; #6 PCINT2 - Pin Change Interrupt Request 2 jmp I_WDT ; #7 WDT - Watchdog Time-out Interrupt jmp I_TIMER2_COMPA ; #8 TIMER2_COMPA - Timer/Counter2 Compare Match A jmp I_TIMER2_COMPB ; #9 TIMER2_COMPB - Timer/Counter2 Compare Match B jmp I_TIMER2_OVF ; #10 TIMER2_OVF - Timer/Counter2 Overflow, 3 cycl jmp I_TIMER1_CAPT ; #11 TIMER1_CAPT Timer/Counter1 Capture Event jmp I_TIMER1_COMPA ; #12 TIMER1_COMPA Timer/Counter1 Compare Match A jmp I_TIMER1_COMPB ; #13 TIMER1_COMPB Timer/Counter1 Compare Match B jmp I_TIMER1_OVF ; #14 TIMER1_OVF Timer/Counter1 Overflow jmp I_TIMER0_COMPA ; #15 TIMER0_COMPA Timer/Counter0 Compare Match A jmp I_TIMER0_COMPB ; #16 TIMER0_COMPB Timer/Counter0 Compare Match B jmp I_TIMER0_OVF ; #17 TIMER0_OVF Timer/Counter0 Overflow jmp I_SPI_STC ; #18 SPI_STC SPI-Übertragung abgeschlossen jmp I_USART_RX ; #19 USART_RX USART-Empfang abgeschlossen jmp I_USART_UDRE ; #20 USART_UDRE USART-Datenregister leer jmp I_USART_TX ; #21 USART_TX USART-Sendung abgeschlossen jmp I_ADC ; #22 ADC ADC Conversion Complete jmp I_EE_READY ; #23 EE_READY EEPROM bereit jmp I_ANALOG_COMP ; #24 ANALOG_COMP Analogkomparator jmp I_TWI ; #25 TWI Two-Wire Interface jmp I_SPM_RDY ; #26 SPM_RDY Store Program Memory Ready ;********************************************************************** ; Reset ;********************************************************************** I_RESET: ; Init the stackpointer, no subroutines will be fine before ldi akku,LOW(RAMEND) ; 1 cycl, load immeddiate, R16 = LB(RAM Ende), Stapel anlegen out SPL,akku ; 1 cycl, Store register to I/O, Stackpointer L = R16 ldi akku,HIGH(RAMEND) ; 1 cycl, load immeddiate, R16 = HB(RAM Ende), out SPH,akku ; 1 cycl, Store register to I/O, Stackpointer H = R16 ; Set all ports (B,C,D) to output ldi akku,0xff ; 1 cycl, output out DDRB,akku ; 1 cycl, set portb out DDRC,akku ; 1 cycl, set portc out DDRD,akku ; 1 cycl, set portd sbi portd,7 ; 2 cycl, enable pullup D7 ; generate interrupt on each Timer overflow/Timer output compare sei ; 1 cycl, enable global interrupts ; ocie2a = "Output Compare Flag 2 A2"; TOIE2 = "Timer/Counter2 Overflow Flag" ldi dummy,(0< out to portc ;nop ; 1 cycl ldi akku,0x00 ; 1 cycl, write $00 out portc,akku ; 1 cycl, --> out to portc nop ; 1 cycl ldi akku,0xff ; 1 cycl, write $ff out portc,akku ; 1 cycl, --> out to portc ;nop ; 1 cycl ldi akku,0x00 ; 1 cycl, write $00 out portc,akku ; 1 cycl, --> out to portc nop ; 1 cycl x1: jmp x1 ; 3 cycl ldi dummy,0b00001000 ; load value for output out DDRB,akku ; set portb ldi dummy,0b00000001 ; load value for output out DDRC,akku ; set portc ldi dummy,0b10000000 ; load value for output out DDRD,akku ; set portd ldi toggle1,0x00 ; Clear dummyreg for toggle1 */ ;sei ; enable global interrupts ; Timer/Counter2 Interrupt Mask Register ; ocie2a = "Output Compare Flag 2 A2"; TOIE2 = "Timer/Counter2 Overflow Flag" ;ldi dummy,(1< (62,5ns*256) = 16.000ns toggle (on freerunning) ;.equ CS2 = 0b010 ; clkT2S/8 (From prescaler) -> (62,5ns*256*8) = 128.000ns toggle (on freerunning) ;.equ CS2 = 0b011 ; clkT2S/32 (From prescaler) -> (62,5ns*256*32) = 512.000ns toggle (on freerunning) ;.equ CS2 = 0b100 ; clkT2S/64 (From prescaler) -> (62,5ns*256*64) = 1024.000ns toggle (on freerunning) ;.equ CS2 = 0b101 ; clkT2S/128 (From prescaler) -> (62,5ns*256*128) = 2.048.000ns toggle (on freerunning) ;.equ CS2 = 0b110 ; clkT2S/256 (From prescaler) -> (62,5ns*256*256) = 4.096.000ns toggle (on freerunning) ;.equ CS2 = 0b111 ; clkT2S/1024 (From prescaler) -> (62,5ns*256*1024) = 16.384.000ns toggle (on freerunning) #if (false) ; preset timer value ldi dummy,(T2Go + 2); 1 cycl, preset T2 compare A value sts ocr2a,dummy ; 2 cycl, SFR B3, Output Compare Register A ldi T2_PREVAL,T2Go ; 1 cycl, preset timervalue sts tcnt2,T2_PREVAL ; 2 cycl, SFR B2, Timer/Counter Register #endif ; TCCR2A Timer/Counter Control Register A, SFR B0 ; CompOutputA (COM2Ax), CompOutputB (COM2Bx), Waveform Generation Mode (WGM20/21) ldi dummy,(COM2A<<6)|(COM2B<<4)|(0< CS22-CS20, F=(62,5ns*256*prescaler) ldi dummy,(0<
