/****************************************************************************** * * Author : Konstantin Chizhov * Date : 2010 * All rights reserved. * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * Redistributions of source code must retain the above copyright notice, * this list of conditions and the following disclaimer. * Redistributions in binary form must reproduce the above copyright notice, * this list of conditions and the following disclaimer in the documentation and/or * other materials provided with the distribution. * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. * IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, * INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ****************************************************************************** * ******************************************************************************/ #ifndef HD44780_HPP #define HD44780_HPP #include // #include // #include // namespace Mcucpp { class LcdBase { protected: static void Delay() { delay_us<200, F_CPU>(); } }; template< class RS, class RW, class E, class D4, class D5, class D6, class D7, uint8_t LINE_WIDTH=8, uint8_t LINES =2 > //*********************** class Lcd: public LcdBase { //********* using DataBus = IO::PinList2 ; using LcdPins = IO::PinList2 ; public: static uint8_t LineWidth() { return LINE_WIDTH; } static uint8_t Lines() { return LINES; } static void Init() { //**** LcdPins:: template SetConfiguration(); IO :: PinList2 ::template Clear<0x03>(); DataBus:: template Write<0x03>(); Strobe(); Strobe(); Strobe(); delay_ms<60, F_CPU>(); DataBus::template Write<0x02>(); // set 4 bit mode Strobe(); Write(0x28); // 4 bit mode, 1/16 duty, 5x8 font Write(0x08); // display off Write(0x0E); // display on, blink curson on Write(0x06); // entry mode } Lcd() { Init(); } static void Clear( ) { RS::Clear(); Write(0x01); Write(0x02); } static void Goto ( uint8_t pos) { RS::Clear(); Write(0x80+pos); } static void Goto ( uint8_t x, uint8_t y) { RS::Clear(); if(y == 1) x += 0x40; Write(0x80+x); } static void Home ( ) { RS::Clear(); Write(0x02); } static void Puts (const char *s, uint8_t len) { RS::Set (); while(len-- && *s) { Write(*s++); } } static void Putch( char c) { RS::Set(); Write(c); } static bool Busy() { RS::Clear(); return Read() & 0x80; } protected: static void Strobe() { E::Set(); Delay(); E::Clear(); Delay(); } static void Write(uint8_t c) { //***** RW::Clear(); DataBus::template SetConfiguration(); DataBus::Write(c>>4); Strobe(); DataBus::Write(c); Strobe(); } static uint8_t Read() { //****** DataBus::template SetConfiguration(); RW ::Set(); E ::Set(); // Delay(); uint8_t res = DataBus::Read() << 4; E ::Clear(); Delay(); E ::Set(); res |= DataBus::Read(); E ::Clear(); RW ::Clear(); return res; } }; //.LCD } //.McuCpp #endif
