import sys import serial import serial.tools.list_ports import struct import json def load_config(path="config.json"): try: with open(path, 'r') as f: config = json.load(f) dateiname = config.get("filename") com_port = config.get("com_port") if not dateiname or not com_port: raise ValueError("Missing entries in the configuration file.") return dateiname, com_port except FileNotFoundError: print(f"File '{path}' not found.") except json.JSONDecodeError: print("Error reading the JSON file.") except Exception as e: print(f"An error has occurred: {e}") return None, None def read_csv(filename): channels = [] with open(filename) as inf: for line in inf: line = line.strip() line = line.split(",") line = [i.strip() for i in line] channels.append(line) return channels def pack(string): return (ord(string[0]) << 24) + (ord(string[1]) << 16) + (ord(string[2]) << 8) + ord(string[3]) def convert_channel_to_hex(channel): name, frequency, min_frequency, max_frequency, mode, agc_speed, step = channel if len(name) < 16: name += " " * (16-len(name)) modes = { "AM" :0, "AMS":1, "LSB":2, "USB":3, "NFM":4, "CW" :5 } agc_speeds = {"FAST": 0, "NORMAL": 1, "SLOW": 2, "VERY SLOW": 3} steps = { "10Hz": 0, "50Hz": 1, "100Hz": 2, "1kHz": 3, "5kHz": 4, "10kHz": 5, "12.5kHz": 6, "25kHz": 7, "50kHz": 8, "100kHz": 9,} data = [ int(frequency)&0xffffffff, #0 modes[mode], #1 agc_speeds[agc_speed], #2 steps[step], #3 int(max_frequency)&0xffffffff, #4 int(min_frequency)&0xffffffff, #5 pack(name[0:4]), #6 pack(name[4:8]), #7 pack(name[8:12]), #8 pack(name[12:16]), #9 0xffffffff, #a 0xffffffff, #b 0xffffffff, #c 0xffffffff, #d 0xffffffff, #e 0xffffffff, #f ] return data def read_memory(filename): data = read_csv(filename)[1:] data = [convert_channel_to_hex(i) for i in data] data = data[:512] return data """ if len(sys.argv) < 2 or "-h" in sys.argv or "--help" in sys.argv: print("Upload Memory Contents to Pi Pico Rx") print("") print("Usage: python upload_memory.py [filename]") sys.exit(-1) filename = sys.argv[1] #prompt user for port to connect to print("!! This will overwrite the memory contents of the pi-pico Rx !!") print("Are you sure? Y/N") idx = input() if idx.strip().upper() != "Y": sys.exit(-1) print("1. Connect USB cable to Pico Rx") print("2. Select *USB Memory Upload* menu item") print("3. When ready press any key") idx = input() #get a list of available serial ports print("Available Ports") portinfo = dict(enumerate(serial.tools.list_ports.comports())) for idx, info in portinfo.items(): port, desc, hwid = info print(idx, "{}: {} [{}]".format(port, desc, hwid)) #prompt user for port to connect to while 1: print("Select COM port >") idx = input() port = portinfo.get(int(idx), None) if port is not None: port = port[0] break """ filename, port = load_config() #send csv file to pico via USB buffer = read_memory(filename) with serial.Serial(port, 12000000, rtscts=1) as ser: #clear any data in buffer while ser.in_waiting: ser.read(ser.in_waiting) with open(filename, 'rb') as input_file: for channel in buffer: for location in channel: data = bytes("%x\n" % (location), "utf8") ser.write(bytes("%x\n"%(location), "utf8")) ser.readline() print(f"send: {data.strip().decode('utf-8')}") ser.write(bytes("q\n", "utf8"))
