#pragma once /* Boxlib (c) 2025 by Malte Marwedel SPDX-License-Identifier: BSD-3-Clause */ #include #include #include #include "main.h" #define SPIQUEUEDEPTH 4 /*Initalizes the SPI to run in master mode with 8 bit data width, manual chip select and a divider of 64. The clock to the SPI has to be enabled before. pSpi: Give the desired SPI: SPI1, SPI2, SPI3 etc. Defined in the stm32******.h */ static inline void SpiPlatformInit(SPI_TypeDef * pSpi) { pSpi->CR1 = 0; pSpi->CR1 = SPI_CR1_MSTR | SPI_BAUDRATEPRESCALER_64 | SPI_CR1_SSM | SPI_CR1_SSI; pSpi->CR2 = SPI_CR2_DS_0 | SPI_CR2_DS_1 | SPI_CR2_DS_2| SPI_CR2_FRXTH; //8Bit, 8Bit RX threshold pSpi->CR1 |= SPI_CR1_SPE; } /*Initializes the SPI DMA. To be called after SpiPlatformInit. Currently only supports SPI1 and SPI2. SPI3 is on DMA2. Look up the correct values in the reference manual. */ static inline void SpiPlatformInitDma(SPI_TypeDef * pSpi, DMA_Channel_TypeDef * pDmaTx, DMA_Channel_TypeDef * pDmaRx, uint32_t clearMask, uint32_t setMask) { pDmaTx->CPAR = (uint32_t)(&(pSpi->DR)); //low priority, 8 bit memory, 8 bit peripheral, memory increment, memory to peripheral pDmaTx->CCR = DMA_CCR_MINC | DMA_CCR_DIR; pDmaRx->CPAR = (uint32_t)(&(pSpi->DR)); //low priority, 8 bit memory, 8 bit peripheral, memory increment, peripheral to memory pDmaRx->CCR = DMA_CCR_MINC; //Note: The read-modify-write might conflict with other functions using DMA in a multithreading app uint32_t cselr = DMA1_CSELR->CSELR; cselr &= ~clearMask; cselr |= setMask; DMA1_CSELR->CSELR = cselr; } /*Print the registers of the SPI. Helps debugging. */ static inline void SpiPlatformRegisterPrint(SPI_TypeDef * pSpi) { uint32_t sr = pSpi->SR; printf("CR1: %08x\r\n", (unsigned int)pSpi->CR1); printf("CR2: %08x\r\n", (unsigned int)pSpi->CR2); printf("SR : %08x\r\n", (unsigned int)sr); if (sr & SPI_SR_RXNE) { printf(" RXNE\r\n");} if (sr & SPI_SR_TXE) { printf(" TXE\r\n");} if (sr & SPI_SR_CRCERR) { printf(" CRCERR\r\n");} if (sr & SPI_SR_MODF) { printf(" MODF\r\n");} if (sr & SPI_SR_OVR) { printf(" OVER\r\n");} if (sr & SPI_SR_BSY) { printf(" BSY\r\n");} if (sr & SPI_SR_FRE) { printf(" FRE\r\n");} printf(" FRLVL %u\r\n", (unsigned int)((sr >> SPI_SR_FRLVL_Pos) & 3)); printf(" FTLVL %u\r\n", (unsigned int)((sr >> SPI_SR_FTLVL_Pos) & 3)); } static inline void SpiPlatformDmaRegisterPrint(DMA_Channel_TypeDef * pDmaTx, DMA_Channel_TypeDef * pDmaRx) { uint32_t itemsTx = pDmaTx->CNDTR; uint32_t itemsRx = pDmaRx->CNDTR; printf("Waiting tx: %u, rx: %u\r\n", (unsigned int)itemsTx, (unsigned int)itemsRx); } /*Starts a transfer using DMA. pSpi: Use some SPI1, SPI2. SPI3 needs adjustments as it is on DMA2... pDmaTx: Use the DMA channel supported by the selected SPI for transfer from buffer to peripheral, like DMA1_Channel5 for SPI2. pDmaRx: Use the DMA channel supported by the selected SPI for transfer from peripheral to buffer, like DMA1_Channel4 for SPI2. dmaClearMask: Use bitmask which clears the transfer complete or error state of the selected pDmaTx and pDmaRx. example: DMA_IFCR_CGIF4 | DMA_IFCR_CGIF5 dataOut: Array to the data to send. May be NULL. In this case 0xFF is sent as data. dataIn: Array to the data to receive. May be NULL. len: Lenght of dataOut and dataIn. If 0, the function returns without starting a new transfer. returns: 0: No transfer started, 1 tx only transfer stared, 2, rx or tx + rx transfer started */ static inline uint8_t SpiPlatformTransferBackground(SPI_TypeDef * pSpi, DMA_Channel_TypeDef * pDmaTx, DMA_Channel_TypeDef * pDmaRx, uint32_t dmaClearMask, const uint8_t * dataOut, uint8_t * dataIn, size_t len) { if (len == 0) { return 0; } static uint8_t dummyTransfer = 0xFF; //pattern to send if dataOut is NULL uint8_t result; //printf("Len %u-%u %u\r\n", dataOut ? 1 : 0, dataIn ? 1 : 0, len); pDmaTx->CNDTR = len; DMA1->IFCR = dmaClearMask; if (dataIn) { pSpi->CR2 |= SPI_CR2_RXDMAEN; pDmaRx->CMAR = (uint32_t)dataIn; pDmaRx->CNDTR = len; pDmaRx->CCR |= DMA_CCR_EN; result = 2; } else { result = 1; } pSpi->CR2 |= SPI_CR2_TXDMAEN; if (dataOut) { pDmaTx->CMAR = (uint32_t)dataOut; pDmaTx->CCR |= DMA_CCR_MINC; } else { pDmaTx->CMAR = (uint32_t)&dummyTransfer; pDmaTx->CCR &= ~DMA_CCR_MINC; } pDmaTx->CCR |= DMA_CCR_EN; //SpiPlatformRegisterPrint(pSpi); //SpiPlatformDmaRegisterPrint(pDmaTx, pDmaRx); return result; } /*Waits until an ongoing SPI transfer is stopped. pSpi: Use some SPI1, SPI2, SPI3 */ static inline void SpiPlatformWaitDone(SPI_TypeDef * pSpi) { while (pSpi->SR & SPI_SR_FTLVL_Msk); while (pSpi->SR & SPI_SR_BSY); while (pSpi->SR & SPI_SR_FRLVL_Msk) { *(__IO uint8_t *)&(pSpi->DR); } } //Disables the DMA channel static inline void SpiPlatformDisableDma(DMA_Channel_TypeDef * pDma) { pDma->CCR &= ~DMA_CCR_EN; }
