(footprint 629722000214 (layer F.Cu) (tedit 6823B148)
  (descr "")
  (attr smd)
  (fp_text reference REF** (at 0.0 -6.815 0) (layer F.SilkS)
    (effects (font (size 1.0 1.0) (thickness 0.15)))
  (fp_text value 629722000214 (at 0.0 4.185 0) (layer F.Fab)
  (pad S1 thru_hole circle (at -4.32 -4.18) (size 1.0 1.0) (drill 0.6) (layers *.Cu))
  (pad S2 thru_hole circle (at 4.32 -4.18) (size 1.0 1.0) (drill 0.6) (layers *.Cu))
  (pad S3 thru_hole circle (at -4.32 0.0) (size 1.0 1.0) (drill 0.6) (layers *.Cu))
  (pad S4 thru_hole circle (at 4.32 0.0) (size 1.0 1.0) (drill 0.6) (layers *.Cu))
  (pad A1 smd custom (at -3.35 -4.745) (size 0.3 1.15) (layers F.Cu) (options (clearance outline) (anchor rect))
    (primitives
      (gr_poly
        (pts
          (xy -0.15 -0.575)
          (xy -0.15 0.575)
          (xy 0.45 0.575)
          (xy 0.45 -0.575)
        ) (width 0.01)
  (pad B12 smd rect (at -3.05 -4.745) (size 0.3 1.15) (layers F.Cu))
  (pad A4 smd custom (at -2.55 -4.745) (size 0.3 1.15) (layers F.Cu) (options (clearance outline) (anchor rect))
    (primitives
      (gr_poly
        (pts
          (xy -0.15 -0.575)
          (xy -0.15 0.575)
          (xy 0.45 0.575)
          (xy 0.45 -0.575)
        ) (width 0.01)
  (pad B9 smd rect (at -2.25 -4.745) (size 0.3 1.15) (layers F.Cu))
  (pad B8 smd rect (at -1.75 -4.745) (size 0.3 1.15) (layers F.Cu F.Mask F.Paste) (solder_mask_margin 0.102))
  (pad A5 smd rect (at -1.25 -4.745) (size 0.3 1.15) (layers F.Cu F.Mask F.Paste) (solder_mask_margin 0.102))
  (pad B7 smd rect (at -0.75 -4.745) (size 0.3 1.15) (layers F.Cu F.Mask F.Paste) (solder_mask_margin 0.102))
  (pad A6 smd rect (at -0.25 -4.745) (size 0.3 1.15) (layers F.Cu F.Mask F.Paste) (solder_mask_margin 0.102))
  (pad A7 smd rect (at 0.25 -4.745) (size 0.3 1.15) (layers F.Cu F.Mask F.Paste) (solder_mask_margin 0.102))
  (pad B6 smd rect (at 0.75 -4.745) (size 0.3 1.15) (layers F.Cu F.Mask F.Paste) (solder_mask_margin 0.102))
  (pad A8 smd rect (at 1.25 -4.745) (size 0.3 1.15) (layers F.Cu F.Mask F.Paste) (solder_mask_margin 0.102))
  (pad B5 smd rect (at 1.75 -4.745) (size 0.3 1.15) (layers F.Cu F.Mask F.Paste) (solder_mask_margin 0.102))
  (pad A12 smd custom (at 3.35 -4.745) (size 0.3 1.15) (layers F.Cu) (options (clearance outline) (anchor rect))
    (primitives
      (gr_poly
        (pts
          (xy -0.45 -0.575)
          (xy -0.45 0.575)
          (xy 0.15 0.575)
          (xy 0.15 -0.575)
        ) (width 0.01)
  (pad B1 smd rect (at 3.05 -4.745) (size 0.3 1.15) (layers F.Cu))
  (pad A9 smd custom (at 2.55 -4.745) (size 0.3 1.15) (layers F.Cu) (options (clearance outline) (anchor rect))
    (primitives
      (gr_poly
        (pts
          (xy -0.45 -0.575)
          (xy -0.45 0.575)
          (xy 0.15 0.575)
          (xy 0.15 -0.575)
        ) (width 0.01)
  (pad B4 smd rect (at 2.25 -4.745) (size 0.3 1.15) (layers F.Cu))
  (pad None np_thru_hole circle (at -2.89 -3.68) (size 0.65 0.65) (drill 0.65) (layers *.Cu *.Mask))
  (pad None np_thru_hole circle (at 2.89 -3.68) (size 0.65 0.65) (drill 0.65) (layers *.Cu *.Mask))
  (fp_text user "Product Edge" (at 0.0 2.22) (layer Dwgs.User)
    (effects (font (size 0.48 0.48) (thickness 0.15)))
  (fp_text user "PCB Cutout Area" (at 4.3 -4.18) (layer Dwgs.User)
    (effects (font (size 0.1 0.1) (thickness 0.15)))
  (fp_text user "Milling Layer the hole size should  follow the Milling Layer" (at 5.6 0.42) (layer Dwgs.User)
    (effects (font (size 0.2 0.2) (thickness 0.15)))
  (fp_text user "PCB Cutout Area" (at 4.3 -4.18) (layer Edge.Cuts)
  (fp_text user "PCB Cutout Area" (at -4.3 -4.18) (layer Dwgs.User)
  (fp_text user "PCB Cutout Area" (at -4.3 -4.18) (layer Edge.Cuts)
  (fp_text user "PCB Cutout Area" (at -4.3 0.02) (layer Dwgs.User)
  (fp_text user "PCB Cutout Area" (at -4.3 0.02) (layer Edge.Cuts)
  (fp_text user "PCB Cutout Area" (at 4.3 0.02) (layer Dwgs.User)
  (fp_text user "PCB Cutout Area" (at 4.3 0.02) (layer Edge.Cuts)
  (fp_poly
    (pts
      (xy -3.82 -3.63)
      (xy -3.823 -3.578)
      (xy -3.831 -3.526)
      (xy -3.844 -3.475)
      (xy -3.863 -3.427)
      (xy -3.887 -3.38)
      (xy -3.915 -3.336)
      (xy -3.948 -3.295)
      (xy -3.985 -3.258)
      (xy -4.026 -3.225)
      (xy -4.07 -3.197)
      (xy -4.117 -3.173)
      (xy -4.165 -3.154)
      (xy -4.216 -3.141)
      (xy -4.268 -3.133)
      (xy -4.32 -3.13)
      (xy -4.372 -3.133)
      (xy -4.424 -3.141)
      (xy -4.475 -3.154)
      (xy -4.523 -3.173)
      (xy -4.57 -3.197)
      (xy -4.614 -3.225)
      (xy -4.655 -3.258)
      (xy -4.692 -3.295)
      (xy -4.725 -3.336)
      (xy -4.753 -3.38)
      (xy -4.777 -3.427)
      (xy -4.796 -3.475)
      (xy -4.809 -3.526)
      (xy -4.817 -3.578)
      (xy -4.82 -3.63)
      (xy -4.82 -4.73)
      (xy -4.817 -4.782)
      (xy -4.809 -4.834)
      (xy -4.796 -4.885)
      (xy -4.777 -4.933)
      (xy -4.753 -4.98)
      (xy -4.725 -5.024)
      (xy -4.692 -5.065)
      (xy -4.655 -5.102)
      (xy -4.614 -5.135)
      (xy -4.57 -5.163)
      (xy -4.523 -5.187)
      (xy -4.475 -5.206)
      (xy -4.424 -5.219)
      (xy -4.372 -5.227)
      (xy -4.32 -5.23)
      (xy -4.268 -5.227)
      (xy -4.216 -5.219)
      (xy -4.165 -5.206)
      (xy -4.117 -5.187)
      (xy -4.07 -5.163)
      (xy -4.026 -5.135)
      (xy -3.985 -5.102)
      (xy -3.948 -5.065)
      (xy -3.915 -5.024)
      (xy -3.887 -4.98)
      (xy -3.863 -4.933)
      (xy -3.844 -4.885)
      (xy -3.831 -4.834)
      (xy -3.823 -4.782)
      (xy -3.82 -4.73)
      (xy -3.82 -3.63)
    ) (layer Dwgs.User) (width 0.1)
  (fp_poly
    (pts
      (xy -3.72 -3.63)
      (xy -3.723 -3.567)
      (xy -3.733 -3.505)
      (xy -3.749 -3.445)
      (xy -3.772 -3.386)
      (xy -3.8 -3.33)
      (xy -3.835 -3.277)
      (xy -3.874 -3.229)
      (xy -3.919 -3.184)
      (xy -3.967 -3.145)
      (xy -4.02 -3.11)
      (xy -4.076 -3.082)
      (xy -4.135 -3.059)
      (xy -4.195 -3.043)
      (xy -4.257 -3.033)
      (xy -4.32 -3.03)
      (xy -4.383 -3.033)
      (xy -4.445 -3.043)
      (xy -4.505 -3.059)
      (xy -4.564 -3.082)
      (xy -4.62 -3.11)
      (xy -4.673 -3.145)
      (xy -4.721 -3.184)
      (xy -4.766 -3.229)
      (xy -4.805 -3.277)
      (xy -4.84 -3.33)
      (xy -4.868 -3.386)
      (xy -4.891 -3.445)
      (xy -4.907 -3.505)
      (xy -4.917 -3.567)
      (xy -4.92 -3.63)
      (xy -4.92 -4.73)
      (xy -4.917 -4.793)
      (xy -4.907 -4.855)
      (xy -4.891 -4.915)
      (xy -4.868 -4.974)
      (xy -4.84 -5.03)
      (xy -4.805 -5.083)
      (xy -4.766 -5.131)
      (xy -4.721 -5.176)
      (xy -4.673 -5.215)
      (xy -4.62 -5.25)
      (xy -4.564 -5.278)
      (xy -4.505 -5.301)
      (xy -4.445 -5.317)
      (xy -4.383 -5.327)
      (xy -4.32 -5.33)
      (xy -4.257 -5.327)
      (xy -4.195 -5.317)
      (xy -4.135 -5.301)
      (xy -4.076 -5.278)
      (xy -4.02 -5.25)
      (xy -3.967 -5.215)
      (xy -3.919 -5.176)
      (xy -3.874 -5.131)
      (xy -3.835 -5.083)
      (xy -3.8 -5.03)
      (xy -3.772 -4.974)
      (xy -3.749 -4.915)
      (xy -3.733 -4.855)
      (xy -3.723 -4.793)
      (xy -3.72 -4.73)
      (xy -3.72 -3.63)
    ) (layer F.Mask) (width 0.1)
  (fp_poly
    (pts
      (xy -3.72 -3.63)
      (xy -3.723 -3.567)
      (xy -3.733 -3.505)
      (xy -3.749 -3.445)
      (xy -3.772 -3.386)
      (xy -3.8 -3.33)
      (xy -3.835 -3.277)
      (xy -3.874 -3.229)
      (xy -3.919 -3.184)
      (xy -3.967 -3.145)
      (xy -4.02 -3.11)
      (xy -4.076 -3.082)
      (xy -4.135 -3.059)
      (xy -4.195 -3.043)
      (xy -4.257 -3.033)
      (xy -4.32 -3.03)
      (xy -4.383 -3.033)
      (xy -4.445 -3.043)
      (xy -4.505 -3.059)
      (xy -4.564 -3.082)
      (xy -4.62 -3.11)
      (xy -4.673 -3.145)
      (xy -4.721 -3.184)
      (xy -4.766 -3.229)
      (xy -4.805 -3.277)
      (xy -4.84 -3.33)
      (xy -4.868 -3.386)
      (xy -4.891 -3.445)
      (xy -4.907 -3.505)
      (xy -4.917 -3.567)
      (xy -4.92 -3.63)
      (xy -4.92 -4.73)
      (xy -4.917 -4.793)
      (xy -4.907 -4.855)
      (xy -4.891 -4.915)
      (xy -4.868 -4.974)
      (xy -4.84 -5.03)
      (xy -4.805 -5.083)
      (xy -4.766 -5.131)
      (xy -4.721 -5.176)
      (xy -4.673 -5.215)
      (xy -4.62 -5.25)
      (xy -4.564 -5.278)
      (xy -4.505 -5.301)
      (xy -4.445 -5.317)
      (xy -4.383 -5.327)
      (xy -4.32 -5.33)
      (xy -4.257 -5.327)
      (xy -4.195 -5.317)
      (xy -4.135 -5.301)
      (xy -4.076 -5.278)
      (xy -4.02 -5.25)
      (xy -3.967 -5.215)
      (xy -3.919 -5.176)
      (xy -3.874 -5.131)
      (xy -3.835 -5.083)
      (xy -3.8 -5.03)
      (xy -3.772 -4.974)
      (xy -3.749 -4.915)
      (xy -3.733 -4.855)
      (xy -3.723 -4.793)
      (xy -3.72 -4.73)
      (xy -3.72 -3.63)
    ) (layer B.Mask) (width 0.1)
  (fp_poly
    (pts
      (xy 3.82 -3.63)
      (xy 3.823 -3.578)
      (xy 3.831 -3.526)
      (xy 3.844 -3.475)
      (xy 3.863 -3.427)
      (xy 3.887 -3.38)
      (xy 3.915 -3.336)
      (xy 3.948 -3.295)
      (xy 3.985 -3.258)
      (xy 4.026 -3.225)
      (xy 4.07 -3.197)
      (xy 4.117 -3.173)
      (xy 4.165 -3.154)
      (xy 4.216 -3.141)
      (xy 4.268 -3.133)
      (xy 4.32 -3.13)
      (xy 4.372 -3.133)
      (xy 4.424 -3.141)
      (xy 4.475 -3.154)
      (xy 4.523 -3.173)
      (xy 4.57 -3.197)
      (xy 4.614 -3.225)
      (xy 4.655 -3.258)
      (xy 4.692 -3.295)
      (xy 4.725 -3.336)
      (xy 4.753 -3.38)
      (xy 4.777 -3.427)
      (xy 4.796 -3.475)
      (xy 4.809 -3.526)
      (xy 4.817 -3.578)
      (xy 4.82 -3.63)
      (xy 4.82 -4.73)
      (xy 4.817 -4.782)
      (xy 4.809 -4.834)
      (xy 4.796 -4.885)
      (xy 4.777 -4.933)
      (xy 4.753 -4.98)
      (xy 4.725 -5.024)
      (xy 4.692 -5.065)
      (xy 4.655 -5.102)
      (xy 4.614 -5.135)
      (xy 4.57 -5.163)
      (xy 4.523 -5.187)
      (xy 4.475 -5.206)
      (xy 4.424 -5.219)
      (xy 4.372 -5.227)
      (xy 4.32 -5.23)
      (xy 4.268 -5.227)
      (xy 4.216 -5.219)
      (xy 4.165 -5.206)
      (xy 4.117 -5.187)
      (xy 4.07 -5.163)
      (xy 4.026 -5.135)
      (xy 3.985 -5.102)
      (xy 3.948 -5.065)
      (xy 3.915 -5.024)
      (xy 3.887 -4.98)
      (xy 3.863 -4.933)
      (xy 3.844 -4.885)
      (xy 3.831 -4.834)
      (xy 3.823 -4.782)
      (xy 3.82 -4.73)
      (xy 3.82 -3.63)
  (fp_poly
    (pts
      (xy 3.72 -3.63)
      (xy 3.723 -3.567)
      (xy 3.733 -3.505)
      (xy 3.749 -3.445)
      (xy 3.772 -3.386)
      (xy 3.8 -3.33)
      (xy 3.835 -3.277)
      (xy 3.874 -3.229)
      (xy 3.919 -3.184)
      (xy 3.967 -3.145)
      (xy 4.02 -3.11)
      (xy 4.076 -3.082)
      (xy 4.135 -3.059)
      (xy 4.195 -3.043)
      (xy 4.257 -3.033)
      (xy 4.32 -3.03)
      (xy 4.383 -3.033)
      (xy 4.445 -3.043)
      (xy 4.505 -3.059)
      (xy 4.564 -3.082)
      (xy 4.62 -3.11)
      (xy 4.673 -3.145)
      (xy 4.721 -3.184)
      (xy 4.766 -3.229)
      (xy 4.805 -3.277)
      (xy 4.84 -3.33)
      (xy 4.868 -3.386)
      (xy 4.891 -3.445)
      (xy 4.907 -3.505)
      (xy 4.917 -3.567)
      (xy 4.92 -3.63)
      (xy 4.92 -4.73)
      (xy 4.917 -4.793)
      (xy 4.907 -4.855)
      (xy 4.891 -4.915)
      (xy 4.868 -4.974)
      (xy 4.84 -5.03)
      (xy 4.805 -5.083)
      (xy 4.766 -5.131)
      (xy 4.721 -5.176)
      (xy 4.673 -5.215)
      (xy 4.62 -5.25)
      (xy 4.564 -5.278)
      (xy 4.505 -5.301)
      (xy 4.445 -5.317)
      (xy 4.383 -5.327)
      (xy 4.32 -5.33)
      (xy 4.257 -5.327)
      (xy 4.195 -5.317)
      (xy 4.135 -5.301)
      (xy 4.076 -5.278)
      (xy 4.02 -5.25)
      (xy 3.967 -5.215)
      (xy 3.919 -5.176)
      (xy 3.874 -5.131)
      (xy 3.835 -5.083)
      (xy 3.8 -5.03)
      (xy 3.772 -4.974)
      (xy 3.749 -4.915)
      (xy 3.733 -4.855)
      (xy 3.723 -4.793)
      (xy 3.72 -4.73)
      (xy 3.72 -3.63)
  (fp_poly
    (pts
      (xy 3.72 -3.63)
      (xy 3.723 -3.567)
      (xy 3.733 -3.505)
      (xy 3.749 -3.445)
      (xy 3.772 -3.386)
      (xy 3.8 -3.33)
      (xy 3.835 -3.277)
      (xy 3.874 -3.229)
      (xy 3.919 -3.184)
      (xy 3.967 -3.145)
      (xy 4.02 -3.11)
      (xy 4.076 -3.082)
      (xy 4.135 -3.059)
      (xy 4.195 -3.043)
      (xy 4.257 -3.033)
      (xy 4.32 -3.03)
      (xy 4.383 -3.033)
      (xy 4.445 -3.043)
      (xy 4.505 -3.059)
      (xy 4.564 -3.082)
      (xy 4.62 -3.11)
      (xy 4.673 -3.145)
      (xy 4.721 -3.184)
      (xy 4.766 -3.229)
      (xy 4.805 -3.277)
      (xy 4.84 -3.33)
      (xy 4.868 -3.386)
      (xy 4.891 -3.445)
      (xy 4.907 -3.505)
      (xy 4.917 -3.567)
      (xy 4.92 -3.63)
      (xy 4.92 -4.73)
      (xy 4.917 -4.793)
      (xy 4.907 -4.855)
      (xy 4.891 -4.915)
      (xy 4.868 -4.974)
      (xy 4.84 -5.03)
      (xy 4.805 -5.083)
      (xy 4.766 -5.131)
      (xy 4.721 -5.176)
      (xy 4.673 -5.215)
      (xy 4.62 -5.25)
      (xy 4.564 -5.278)
      (xy 4.505 -5.301)
      (xy 4.445 -5.317)
      (xy 4.383 -5.327)
      (xy 4.32 -5.33)
      (xy 4.257 -5.327)
      (xy 4.195 -5.317)
      (xy 4.135 -5.301)
      (xy 4.076 -5.278)
      (xy 4.02 -5.25)
      (xy 3.967 -5.215)
      (xy 3.919 -5.176)
      (xy 3.874 -5.131)
      (xy 3.835 -5.083)
      (xy 3.8 -5.03)
      (xy 3.772 -4.974)
      (xy 3.749 -4.915)
      (xy 3.733 -4.855)
      (xy 3.723 -4.793)
      (xy 3.72 -4.73)
      (xy 3.72 -3.63)
  (fp_poly
    (pts
      (xy -3.82 0.4)
      (xy -3.823 0.452)
      (xy -3.831 0.504)
      (xy -3.844 0.555)
      (xy -3.863 0.603)
      (xy -3.887 0.65)
      (xy -3.915 0.694)
      (xy -3.948 0.735)
      (xy -3.985 0.772)
      (xy -4.026 0.805)
      (xy -4.07 0.833)
      (xy -4.117 0.857)
      (xy -4.165 0.876)
      (xy -4.216 0.889)
      (xy -4.268 0.897)
      (xy -4.32 0.9)
      (xy -4.372 0.897)
      (xy -4.424 0.889)
      (xy -4.475 0.876)
      (xy -4.523 0.857)
      (xy -4.57 0.833)
      (xy -4.614 0.805)
      (xy -4.655 0.772)
      (xy -4.692 0.735)
      (xy -4.725 0.694)
      (xy -4.753 0.65)
      (xy -4.777 0.603)
      (xy -4.796 0.555)
      (xy -4.809 0.504)
      (xy -4.817 0.452)
      (xy -4.82 0.4)
      (xy -4.82 -0.4)
      (xy -4.817 -0.452)
      (xy -4.809 -0.504)
      (xy -4.796 -0.555)
      (xy -4.777 -0.603)
      (xy -4.753 -0.65)
      (xy -4.725 -0.694)
      (xy -4.692 -0.735)
      (xy -4.655 -0.772)
      (xy -4.614 -0.805)
      (xy -4.57 -0.833)
      (xy -4.523 -0.857)
      (xy -4.475 -0.876)
      (xy -4.424 -0.889)
      (xy -4.372 -0.897)
      (xy -4.32 -0.9)
      (xy -4.268 -0.897)
      (xy -4.216 -0.889)
      (xy -4.165 -0.876)
      (xy -4.117 -0.857)
      (xy -4.07 -0.833)
      (xy -4.026 -0.805)
      (xy -3.985 -0.772)
      (xy -3.948 -0.735)
      (xy -3.915 -0.694)
      (xy -3.887 -0.65)
      (xy -3.863 -0.603)
      (xy -3.844 -0.555)
      (xy -3.831 -0.504)
      (xy -3.823 -0.452)
      (xy -3.82 -0.4)
      (xy -3.82 0.4)
  (fp_poly
    (pts
      (xy 3.82 0.4)
      (xy 3.823 0.452)
      (xy 3.831 0.504)
      (xy 3.844 0.555)
      (xy 3.863 0.603)
      (xy 3.887 0.65)
      (xy 3.915 0.694)
      (xy 3.948 0.735)
      (xy 3.985 0.772)
      (xy 4.026 0.805)
      (xy 4.07 0.833)
      (xy 4.117 0.857)
      (xy 4.165 0.876)
      (xy 4.216 0.889)
      (xy 4.268 0.897)
      (xy 4.32 0.9)
      (xy 4.372 0.897)
      (xy 4.424 0.889)
      (xy 4.475 0.876)
      (xy 4.523 0.857)
      (xy 4.57 0.833)
      (xy 4.614 0.805)
      (xy 4.655 0.772)
      (xy 4.692 0.735)
      (xy 4.725 0.694)
      (xy 4.753 0.65)
      (xy 4.777 0.603)
      (xy 4.796 0.555)
      (xy 4.809 0.504)
      (xy 4.817 0.452)
      (xy 4.82 0.4)
      (xy 4.82 -0.4)
      (xy 4.817 -0.452)
      (xy 4.809 -0.504)
      (xy 4.796 -0.555)
      (xy 4.777 -0.603)
      (xy 4.753 -0.65)
      (xy 4.725 -0.694)
      (xy 4.692 -0.735)
      (xy 4.655 -0.772)
      (xy 4.614 -0.805)
      (xy 4.57 -0.833)
      (xy 4.523 -0.857)
      (xy 4.475 -0.876)
      (xy 4.424 -0.889)
      (xy 4.372 -0.897)
      (xy 4.32 -0.9)
      (xy 4.268 -0.897)
      (xy 4.216 -0.889)
      (xy 4.165 -0.876)
      (xy 4.117 -0.857)
      (xy 4.07 -0.833)
      (xy 4.026 -0.805)
      (xy 3.985 -0.772)
      (xy 3.948 -0.735)
      (xy 3.915 -0.694)
      (xy 3.887 -0.65)
      (xy 3.863 -0.603)
      (xy 3.844 -0.555)
      (xy 3.831 -0.504)
      (xy 3.823 -0.452)
      (xy 3.82 -0.4)
      (xy 3.82 0.4)
  (fp_poly
    (pts
      (xy -3.72 0.4)
      (xy -3.723 0.463)
      (xy -3.733 0.525)
      (xy -3.749 0.585)
      (xy -3.772 0.644)
      (xy -3.8 0.7)
      (xy -3.835 0.753)
      (xy -3.874 0.801)
      (xy -3.919 0.846)
      (xy -3.967 0.885)
      (xy -4.02 0.92)
      (xy -4.076 0.948)
      (xy -4.135 0.971)
      (xy -4.195 0.987)
      (xy -4.257 0.997)
      (xy -4.32 1.0)
      (xy -4.383 0.997)
      (xy -4.445 0.987)
      (xy -4.505 0.971)
      (xy -4.564 0.948)
      (xy -4.62 0.92)
      (xy -4.673 0.885)
      (xy -4.721 0.846)
      (xy -4.766 0.801)
      (xy -4.805 0.753)
      (xy -4.84 0.7)
      (xy -4.868 0.644)
      (xy -4.891 0.585)
      (xy -4.907 0.525)
      (xy -4.917 0.463)
      (xy -4.92 0.4)
      (xy -4.92 -0.4)
      (xy -4.917 -0.463)
      (xy -4.907 -0.525)
      (xy -4.891 -0.585)
      (xy -4.868 -0.644)
      (xy -4.84 -0.7)
      (xy -4.805 -0.753)
      (xy -4.766 -0.801)
      (xy -4.721 -0.846)
      (xy -4.673 -0.885)
      (xy -4.62 -0.92)
      (xy -4.564 -0.948)
      (xy -4.505 -0.971)
      (xy -4.445 -0.987)
      (xy -4.383 -0.997)
      (xy -4.32 -1.0)
      (xy -4.257 -0.997)
      (xy -4.195 -0.987)
      (xy -4.135 -0.971)
      (xy -4.076 -0.948)
      (xy -4.02 -0.92)
      (xy -3.967 -0.885)
      (xy -3.919 -0.846)
      (xy -3.874 -0.801)
      (xy -3.835 -0.753)
      (xy -3.8 -0.7)
      (xy -3.772 -0.644)
      (xy -3.749 -0.585)
      (xy -3.733 -0.525)
      (xy -3.723 -0.463)
      (xy -3.72 -0.4)
      (xy -3.72 0.4)
  (fp_poly
    (pts
      (xy -3.72 0.4)
      (xy -3.723 0.463)
      (xy -3.733 0.525)
      (xy -3.749 0.585)
      (xy -3.772 0.644)
      (xy -3.8 0.7)
      (xy -3.835 0.753)
      (xy -3.874 0.801)
      (xy -3.919 0.846)
      (xy -3.967 0.885)
      (xy -4.02 0.92)
      (xy -4.076 0.948)
      (xy -4.135 0.971)
      (xy -4.195 0.987)
      (xy -4.257 0.997)
      (xy -4.32 1.0)
      (xy -4.383 0.997)
      (xy -4.445 0.987)
      (xy -4.505 0.971)
      (xy -4.564 0.948)
      (xy -4.62 0.92)
      (xy -4.673 0.885)
      (xy -4.721 0.846)
      (xy -4.766 0.801)
      (xy -4.805 0.753)
      (xy -4.84 0.7)
      (xy -4.868 0.644)
      (xy -4.891 0.585)
      (xy -4.907 0.525)
      (xy -4.917 0.463)
      (xy -4.92 0.4)
      (xy -4.92 -0.4)
      (xy -4.917 -0.463)
      (xy -4.907 -0.525)
      (xy -4.891 -0.585)
      (xy -4.868 -0.644)
      (xy -4.84 -0.7)
      (xy -4.805 -0.753)
      (xy -4.766 -0.801)
      (xy -4.721 -0.846)
      (xy -4.673 -0.885)
      (xy -4.62 -0.92)
      (xy -4.564 -0.948)
      (xy -4.505 -0.971)
      (xy -4.445 -0.987)
      (xy -4.383 -0.997)
      (xy -4.32 -1.0)
      (xy -4.257 -0.997)
      (xy -4.195 -0.987)
      (xy -4.135 -0.971)
      (xy -4.076 -0.948)
      (xy -4.02 -0.92)
      (xy -3.967 -0.885)
      (xy -3.919 -0.846)
      (xy -3.874 -0.801)
      (xy -3.835 -0.753)
      (xy -3.8 -0.7)
      (xy -3.772 -0.644)
      (xy -3.749 -0.585)
      (xy -3.733 -0.525)
      (xy -3.723 -0.463)
      (xy -3.72 -0.4)
      (xy -3.72 0.4)
  (fp_poly
    (pts
      (xy 3.72 0.4)
      (xy 3.723 0.463)
      (xy 3.733 0.525)
      (xy 3.749 0.585)
      (xy 3.772 0.644)
      (xy 3.8 0.7)
      (xy 3.835 0.753)
      (xy 3.874 0.801)
      (xy 3.919 0.846)
      (xy 3.967 0.885)
      (xy 4.02 0.92)
      (xy 4.076 0.948)
      (xy 4.135 0.971)
      (xy 4.195 0.987)
      (xy 4.257 0.997)
      (xy 4.32 1.0)
      (xy 4.383 0.997)
      (xy 4.445 0.987)
      (xy 4.505 0.971)
      (xy 4.564 0.948)
      (xy 4.62 0.92)
      (xy 4.673 0.885)
      (xy 4.721 0.846)
      (xy 4.766 0.801)
      (xy 4.805 0.753)
      (xy 4.84 0.7)
      (xy 4.868 0.644)
      (xy 4.891 0.585)
      (xy 4.907 0.525)
      (xy 4.917 0.463)
      (xy 4.92 0.4)
      (xy 4.92 -0.4)
      (xy 4.917 -0.463)
      (xy 4.907 -0.525)
      (xy 4.891 -0.585)
      (xy 4.868 -0.644)
      (xy 4.84 -0.7)
      (xy 4.805 -0.753)
      (xy 4.766 -0.801)
      (xy 4.721 -0.846)
      (xy 4.673 -0.885)
      (xy 4.62 -0.92)
      (xy 4.564 -0.948)
      (xy 4.505 -0.971)
      (xy 4.445 -0.987)
      (xy 4.383 -0.997)
      (xy 4.32 -1.0)
      (xy 4.257 -0.997)
      (xy 4.195 -0.987)
      (xy 4.135 -0.971)
      (xy 4.076 -0.948)
      (xy 4.02 -0.92)
      (xy 3.967 -0.885)
      (xy 3.919 -0.846)
      (xy 3.874 -0.801)
      (xy 3.835 -0.753)
      (xy 3.8 -0.7)
      (xy 3.772 -0.644)
      (xy 3.749 -0.585)
      (xy 3.733 -0.525)
      (xy 3.723 -0.463)
      (xy 3.72 -0.4)
      (xy 3.72 0.4)
  (fp_poly
    (pts
      (xy 3.72 0.4)
      (xy 3.723 0.463)
      (xy 3.733 0.525)
      (xy 3.749 0.585)
      (xy 3.772 0.644)
      (xy 3.8 0.7)
      (xy 3.835 0.753)
      (xy 3.874 0.801)
      (xy 3.919 0.846)
      (xy 3.967 0.885)
      (xy 4.02 0.92)
      (xy 4.076 0.948)
      (xy 4.135 0.971)
      (xy 4.195 0.987)
      (xy 4.257 0.997)
      (xy 4.32 1.0)
      (xy 4.383 0.997)
      (xy 4.445 0.987)
      (xy 4.505 0.971)
      (xy 4.564 0.948)
      (xy 4.62 0.92)
      (xy 4.673 0.885)
      (xy 4.721 0.846)
      (xy 4.766 0.801)
      (xy 4.805 0.753)
      (xy 4.84 0.7)
      (xy 4.868 0.644)
      (xy 4.891 0.585)
      (xy 4.907 0.525)
      (xy 4.917 0.463)
      (xy 4.92 0.4)
      (xy 4.92 -0.4)
      (xy 4.917 -0.463)
      (xy 4.907 -0.525)
      (xy 4.891 -0.585)
      (xy 4.868 -0.644)
      (xy 4.84 -0.7)
      (xy 4.805 -0.753)
      (xy 4.766 -0.801)
      (xy 4.721 -0.846)
      (xy 4.673 -0.885)
      (xy 4.62 -0.92)
      (xy 4.564 -0.948)
      (xy 4.505 -0.971)
      (xy 4.445 -0.987)
      (xy 4.383 -0.997)
      (xy 4.32 -1.0)
      (xy 4.257 -0.997)
      (xy 4.195 -0.987)
      (xy 4.135 -0.971)
      (xy 4.076 -0.948)
      (xy 4.02 -0.92)
      (xy 3.967 -0.885)
      (xy 3.919 -0.846)
      (xy 3.874 -0.801)
      (xy 3.835 -0.753)
      (xy 3.8 -0.7)
      (xy 3.772 -0.644)
      (xy 3.749 -0.585)
      (xy 3.733 -0.525)
      (xy 3.723 -0.463)
      (xy 3.72 -0.4)
      (xy 3.72 0.4)
  (fp_poly
    (pts
      (xy -3.5 -5.32)
      (xy -3.5 -4.17)
      (xy -2.9 -4.17)
      (xy -2.9 -5.32)
    ) (layer F.Paste) (width 0.01)
  (fp_poly
    (pts
      (xy -3.6 -5.42)
      (xy -3.6 -4.07)
      (xy -2.8 -4.07)
      (xy -2.8 -5.42)
    ) (layer F.Mask) (width 0.01)
  (fp_poly
    (pts
      (xy -2.7 -5.32)
      (xy -2.7 -4.17)
      (xy -2.1 -4.17)
      (xy -2.1 -5.32)
  (fp_poly
    (pts
      (xy -2.8 -5.42)
      (xy -2.8 -4.07)
      (xy -2.0 -4.07)
      (xy -2.0 -5.42)
  (fp_poly
    (pts
      (xy 2.9 -5.32)
      (xy 2.9 -4.17)
      (xy 3.5 -4.17)
      (xy 3.5 -5.32)
  (fp_poly
    (pts
      (xy 2.8 -5.42)
      (xy 2.8 -4.07)
      (xy 3.6 -4.07)
      (xy 3.6 -5.42)
  (fp_poly
    (pts
      (xy 2.1 -5.32)
      (xy 2.1 -4.17)
      (xy 2.7 -4.17)
      (xy 2.7 -5.32)
  (fp_poly
    (pts
      (xy 2.0 -5.42)
      (xy 2.0 -4.07)
      (xy 2.8 -4.07)
      (xy 2.8 -5.42)
  (fp_poly
    (pts
      (xy -5.1 -5.58)
      (xy -5.1 2.92)
      (xy 5.1 2.92)
      (xy 5.1 -5.58)
    ) (layer F.CrtYd) (width 0.1)
  (fp_line (start -4.47 -4.55) (end -4.47 -3.43) (layer F.Fab) (width 0.1))
  (fp_line (start -4.47 -3.43) (end -4.47 2.6) (layer F.Fab) (width 0.1))
  (fp_line (start -4.47 2.6) (end 4.47 2.6) (layer F.Fab) (width 0.1))
  (fp_line (start 4.36 -4.93) (end -4.36 -4.93) (layer F.Fab) (width 0.1))
  (fp_line (start -5.2 2.62) (end 5.2 2.62) (layer F.Fab) (width 0.1))
  (fp_line (start -4.79 -4.48) (end -4.79 -3.13) (layer F.Fab) (width 0.1))
  (fp_line (start -4.79 -3.13) (end -4.64 -3.13) (layer F.Fab) (width 0.1))
  (fp_line (start -4.34 -4.63) (end 4.34 -4.63) (layer F.Fab) (width 0.1))
  (fp_arc (start -4.33977788897 -4.48023220502) (end -4.36 -4.93) (angle -87.455196) (layer F.Fab) (width 0.1))
  (fp_line (start -4.64 -3.13) (end -4.47 -3.43) (layer F.Fab) (width 0.1))
  (fp_line (start -4.49 -4.48) (end -4.49 -3.395) (layer F.Fab) (width 0.1))
  (fp_arc (start -4.34 -4.48) (end -4.34 -4.63) (angle -90.0) (layer F.Fab) (width 0.1))
  (fp_line (start 4.47 -4.55) (end 4.47 -3.43) (layer F.Fab) (width 0.1))
  (fp_line (start 4.79 -4.48) (end 4.79 -3.13) (layer F.Fab) (width 0.1))
  (fp_line (start 4.79 -3.13) (end 4.64 -3.13) (layer F.Fab) (width 0.1))
  (fp_arc (start 4.33977788897 -4.48023220502) (end 4.36 -4.93) (angle 87.455196) (layer F.Fab) (width 0.1))
  (fp_line (start 4.64 -3.13) (end 4.47 -3.43) (layer F.Fab) (width 0.1))
  (fp_line (start 4.49 -4.48) (end 4.49 -3.395) (layer F.Fab) (width 0.1))
  (fp_arc (start 4.34 -4.48) (end 4.34 -4.63) (angle 90.0) (layer F.Fab) (width 0.1))
  (fp_line (start 4.47 -3.43) (end 4.47 2.6) (layer F.Fab) (width 0.1))
  (fp_line (start -4.57 -2.78) (end -4.57 -1.28) (layer F.SilkS) (width 0.2))
  (fp_line (start 4.57 -1.28) (end 4.57 -2.78) (layer F.SilkS) (width 0.2))
  (fp_line (start -4.57 1.32) (end -4.57 2.7) (layer F.SilkS) (width 0.2))
  (fp_line (start -4.57 2.7) (end 4.57 2.7) (layer F.SilkS) (width 0.2))
  (fp_line (start 4.57 2.7) (end 4.57 1.32) (layer F.SilkS) (width 0.2))
  (fp_line (start 2.7 2.02) (end 3.1 2.02) (layer Dwgs.User) (width 0.1))
  (fp_line (start 3.3 2.22) (end 3.3 2.62) (layer Dwgs.User) (width 0.1))
  (fp_line (start 3.3 2.62) (end 3.5 2.42) (layer Dwgs.User) (width 0.1))
  (fp_line (start 3.3 2.62) (end 3.1 2.42) (layer Dwgs.User) (width 0.1))
  (fp_line (start 5.4 0.02) (end 4.7 0.02) (layer Dwgs.User) (width 0.1))
  (fp_line (start 4.7 0.02) (end 4.8 -0.08) (layer Dwgs.User) (width 0.1))
  (fp_line (start 4.7 0.02) (end 4.8 0.12) (layer Dwgs.User) (width 0.1))
  (fp_line (start 3.1 2.02) (end 3.3 2.22) (layer Dwgs.User) (width 0.1))
  (fp_arc (start -4.32 -3.63) (end -4.62 -3.63) (angle -180.0) (layer Edge.Cuts) (width 0.01))
  (fp_line (start -4.62 -3.63) (end -4.62 -4.73) (layer Edge.Cuts) (width 0.01))
  (fp_arc (start -4.32 -4.73) (end -4.02 -4.73) (angle -180.0) (layer Edge.Cuts) (width 0.01))
  (fp_line (start -4.02 -4.73) (end -4.02 -3.63) (layer Edge.Cuts) (width 0.01))
  (fp_arc (start 4.32 -3.63) (end 4.62 -3.63) (angle 180.0) (layer Edge.Cuts) (width 0.01))
  (fp_line (start 4.62 -3.63) (end 4.62 -4.73) (layer Edge.Cuts) (width 0.01))
  (fp_arc (start 4.32 -4.73) (end 4.02 -4.73) (angle 180.0) (layer Edge.Cuts) (width 0.01))
  (fp_line (start 4.02 -4.73) (end 4.02 -3.63) (layer Edge.Cuts) (width 0.01))
  (fp_arc (start -4.32 0.4) (end -4.62 0.4) (angle -180.0) (layer Edge.Cuts) (width 0.01))
  (fp_line (start -4.62 0.4) (end -4.62 -0.4) (layer Edge.Cuts) (width 0.01))
  (fp_arc (start -4.32 -0.4) (end -4.02 -0.4) (angle -180.0) (layer Edge.Cuts) (width 0.01))
  (fp_line (start -4.02 -0.4) (end -4.02 0.4) (layer Edge.Cuts) (width 0.01))
  (fp_arc (start 4.32 0.4) (end 4.62 0.4) (angle 180.0) (layer Edge.Cuts) (width 0.01))
  (fp_line (start 4.62 0.4) (end 4.62 -0.4) (layer Edge.Cuts) (width 0.01))
  (fp_arc (start 4.32 -0.4) (end 4.02 -0.4) (angle 180.0) (layer Edge.Cuts) (width 0.01))
  (fp_line (start 4.02 -0.4) (end 4.02 0.4) (layer Edge.Cuts) (width 0.01))
