(footprint "629722000214" (version 20221018) (generator pcbnew)
  (layer "F.Cu")
  (attr smd)
  (fp_text reference "REF**" (at -2.25 -5.35) (layer "F.SilkS") hide
      (effects (font (size 1 1) (thickness 0.15)))
    (tstamp c848c23b-cdc3-422e-b200-484b45565dc4)
  (fp_text value "629722000214" (at 0 4.95) (layer "F.Fab") hide
    (tstamp 101b8869-2d38-4c38-a235-7f64c64141d7)
  (fp_line (start -4.47 -0.065) (end -4.47 -1.695)
    (stroke (width 0.12) (type default)) (layer "F.SilkS") (tstamp df53ef6a-0a95-406f-a317-f2b431f8dbf6))
  (fp_line (start -4.47 3.765) (end -4.47 2.355)
    (stroke (width 0.12) (type default)) (layer "F.SilkS") (tstamp bded52a3-e265-49cf-9b47-6e4acf3f381c))
  (fp_line (start -4.47 3.765) (end 4.47 3.765)
    (stroke (width 0.12) (type default)) (layer "F.SilkS") (tstamp 4738cebe-9173-4b16-8432-8495263da342))
  (fp_line (start 4.47 -0.065) (end 4.47 -1.695)
    (stroke (width 0.12) (type default)) (layer "F.SilkS") (tstamp 6d6fec46-36ba-4cde-971a-0982658d81a7))
  (fp_line (start 4.47 3.765) (end 4.47 2.355)
    (stroke (width 0.12) (type default)) (layer "F.SilkS") (tstamp ca15d0e9-1942-403c-b66d-2514820fd7f3))
  (fp_line (start -5.02 -4.375) (end -5.02 3.965)
    (stroke (width 0.05) (type default)) (layer "F.CrtYd") (tstamp abe91a1d-4c63-4951-a797-042f2f25b639))
  (fp_line (start -5.02 3.965) (end 5.02 3.965)
    (stroke (width 0.05) (type default)) (layer "F.CrtYd") (tstamp 9752d8a8-921a-434e-81a5-3ae3e27148ae))
  (fp_line (start 5.02 -4.375) (end -5.02 -4.375)
    (stroke (width 0.05) (type default)) (layer "F.CrtYd") (tstamp fa2d112e-3e08-46b0-a1aa-56e9e661f665))
  (fp_line (start 5.02 3.965) (end 5.02 -4.375)
    (stroke (width 0.05) (type default)) (layer "F.CrtYd") (tstamp f1850913-0abd-4b2b-a75d-864f92ffefa5))
  (pad "" np_thru_hole circle (at -2.89 -2.535) (size 0.65 0.65) (drill 0.65) (layers "*.Mask") (tstamp 8ec0cf10-2933-4fb7-95e5-ea6f4daec0c6))
  (pad "" np_thru_hole circle (at 2.89 -2.535) (size 0.65 0.65) (drill 0.65) (layers "*.Mask") (tstamp bd94dcaa-65fa-4526-9fae-ea4bcb0a1849))
  (pad "A1/B12" smd rect (at -3.2 -3.6) (size 0.6 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp 5a4ef60a-d5b9-404c-99ea-decd4cdbf73d))
  (pad "A4/B9" smd rect (at -2.4 -3.6) (size 0.6 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp acb27627-e107-4aa4-914a-d6188c24fb0e))
  (pad "A5" smd rect (at -1.25 -3.6) (size 0.3 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp 896443e1-2a3e-4cc1-82fd-085816296edb))
  (pad "A6" smd rect (at -0.25 -3.6) (size 0.3 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp f3747fb4-9a3a-46da-bf08-c41b760f86f9))
  (pad "A7" smd rect (at 0.75 -3.6) (size 0.3 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp 935e5b88-e07f-4ff4-8fe3-a5abbc3e31ed))
  (pad "A8" smd rect (at 1.75 -3.6) (size 0.3 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp ad0412f4-280e-4910-9e48-2f76a096f0af))
  (pad "A9/B4" smd rect (at 2.4 -3.6) (size 0.6 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp 14af6a37-8872-4d05-993f-8ac2efd96e38))
  (pad "A12/B1" smd rect (at 3.2 -3.6) (size 0.6 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp 19a41d91-dbed-4e6f-9f18-260cee6759fb))
  (pad "B5" smd rect (at 1.25 -3.6) (size 0.3 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp b61b0377-16dd-45f8-b34f-075b9fa9511c))
  (pad "B6" smd rect (at 0.25 -3.6) (size 0.3 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp ae184225-b22f-477e-8ffa-01d1d3b651c5))
  (pad "B7" smd rect (at -0.75 -3.6) (size 0.3 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp 2b50ca85-28a3-417c-af54-65e56a7616c1))
  (pad "B8" smd rect (at -1.75 -3.6) (size 0.3 1.14) (layers "F.Cu" "F.Paste" "F.Mask") (tstamp f75a4c6a-fb36-4ced-8fc7-1e7d4196ac78))
  (pad "Shell" thru_hole oval (at -4.32 -3.035) (size 1 2.1) (drill oval 0.6 1.7) (layers "*.Cu" "*.Mask") (tstamp b01fc63a-4352-4aa6-a9f3-b70fc08791d6))
  (pad "Shell" thru_hole oval (at -4.32 1.145) (size 1 2.1) (drill oval 0.6 1.7) (layers "*.Cu" "*.Mask") (tstamp 38e41c66-60cf-448c-b26b-9e163bdfc1d0))
  (pad "Shell" thru_hole oval (at 4.32 -3.035) (size 1 2.1) (drill oval 0.6 1.7) (layers "*.Cu" "*.Mask") (tstamp cb8f009b-079f-43db-a402-0f9563df21ca))
  (pad "Shell" thru_hole oval (at 4.32 1.145) (size 1 2.1) (drill oval 0.6 1.7) (layers "*.Cu" "*.Mask") (tstamp 9f889158-6e3d-4604-832b-f5ba6fecccd7))
