/* * Board: ESP 32 38 Pin * * Ydlidar <-> ESP32 38 Pin * 1 (+5V, red) <-> 5V * 2 (TX, green) <-> GPIO 16 (RX verbunden mit TX des Lidar) * 3 (RX, yellow) <-> GPIO 17 (TX verbunden mit RX des Lidar) * 4 (GND, black) <-> GND * 5 (M_SCTR, nc) <-> IO ? Motor speed control (noch nicht verbunden) * 6 (M_DEV, nc) * 7 (M_EN, blue) <-> GPIO 22 Motor enable * 8 (NC, nc) * * Author: Wilfried * History: * started: 02.04.2024 finished: * This sketch was created with Arduino IDE 1.8.16. */ #include #include "LidarFunctions.h" #define RXD2 16 #define TXD2 17 const int ydlidar_en_pin = 4 ; // Motor enable const int start_pin = 23 ; // Starte den Scan über den Schalter int start_pin_state ; int look = 0 ; int nudge = 0 ; int turn = 0 ; char start ; void ydlidar_start() { look = 0 ; digitalWrite(ydlidar_en_pin,HIGH); Serial.println("Start Scan") ; Serial2.write(0xA5); Serial.print(0xA5, HEX) ; Serial.print(" ") ; Serial2.write(0x60); // Schaltet in den Scan-Modus Serial.println(0x60, HEX) ; } void ydlidar_stop() { Serial2.write(0xA5); Serial.print(0xA5, HEX) ; Serial.print(" ") ; Serial2.write(0x65); Serial.println(0x65, HEX) ; Serial.println("gestoppt ! ") ; } void setup() { pinMode(motorPin1, OUTPUT); pinMode(motorPin2, OUTPUT); pinMode(motorPin3, OUTPUT); pinMode(motorPin4, OUTPUT); digitalWrite(motorPin1, LOW); // Motor 1 steht digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); // Motor 2 steht digitalWrite(motorPin4, LOW); pinMode(ydlidar_en_pin,OUTPUT); digitalWrite(ydlidar_en_pin,HIGH); pinMode(start_pin,INPUT); Serial.begin(500000); Serial2.begin(128000, SERIAL_8N1, RXD2, TXD2); Serial.println("Esp32 38 PIN listening on Serial 2, sending on Serial 0"); } void loop() { // char start = Serial.read() ; // können wir über die Eingabe am seriellen Monitor starten // if (start == 's') int new_sign = 0 ; start_pin_state = digitalRead(start_pin) ; // hier bauen wir ein: --> if LOW "nomove() sonst --> den Rest ...." if (start_pin_state == HIGH) { forward() ; { ydlidar_start() ; int look = 0 ; int sect = 0 ; while(look <= 4 ) { if (Serial2.available()) { pre_sign_scan = sign_scan ; sign_scan = (Serial2.read()) ; new_sign = sign_scan ; if (pre_sign_scan == 0xAA && sign_scan == 0x55) { read_header() ; if (header[2] == 1) { // Serial.println("Anfang gefunden "); raw_data_einlesen() ; extract_winkel(); arrays_umsortieren() ; sectors_einlesen(sect); look++ ; sect++; // Serial.print("look ist: ") ; // Serial.println(look) ; } } } } ydlidar_stop(); summieren() ; //ermittelt den Mittelwert der Zeilen und legt ihn in [i][5] ab sektoren_ermitteln() ; if (sektor_d <= 200) { // Serial.print("sektor_d ist kleiner als 20 cm ") ; nomove() ; delay (30) ; backward() ; delay (50) ; turn = highest_distance() ; // Serial.print("turn ist: ") ; // Serial.println(turn) ; switch (turn) { case 11 : //Serial.println("case 11 ") ; nomove() ; delay (30) ; turnright() ; delay (200) ; nomove() ; delay (30) ; forward() ; break ; case 12 : //Serial.println("case 12 ") ; nomove() ; delay (30) ; turnright() ; delay (400) ; nomove() ; delay (30) ; forward() ; break ; case 13 : //Serial.println("case 13 ") ; nomove() ; delay (30) ; turnright() ; delay (600) ; nomove() ; delay (30) ; forward() ; break ; case 14 : //Serial.println("case 14 ") ; nomove() ; delay (30) ; turnleft() ; delay (200) ; nomove() ; delay (30) ; forward() ; break ; case 15 : //Serial.println("case 15 ") ; nomove() ; delay (30) ; turnleft() ; delay (400) ; nomove() ; delay (30) ; forward() ; break ; case 16 : //Serial.println("case 16 ") ; nomove() ; delay (30) ; turnleft() ; delay (600) ; nomove() ; delay (30) ; forward() ; break ; } } } } else { nomove(); } } int highest_distance() { int highest_distance = sektor_1 ; int nudge = 11 ; if (sektor_2 > highest_distance) { highest_distance = sektor_2 ; nudge = 12 ; } if (sektor_3 > highest_distance) { highest_distance = sektor_3 ; nudge = 13 ; } if (sektor_4 > highest_distance) { highest_distance = sektor_4 ; nudge = 14 ; } if (sektor_5 > highest_distance) { highest_distance = sektor_5 ; nudge = 15 ; } if (sektor_6 > highest_distance) { highest_distance = sektor_6 ; nudge = 16 ; } return nudge ; }
