arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -tools /usr/share/arduino/hardware/tools/avr -libraries /home/mike/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_466420 -warnings=none -build-cache /tmp/arduino_cache_132696 -prefs=build.warn_data_percentage=75 -verbose /tmp/arduino_modified_sketch_604168/AnalogReadSerial.ino arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -tools /usr/share/arduino/hardware/tools/avr -libraries /home/mike/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_466420 -warnings=none -build-cache /tmp/arduino_cache_132696 -prefs=build.warn_data_percentage=75 -verbose /tmp/arduino_modified_sketch_604168/AnalogReadSerial.ino Using board 'uno' from platform in folder: /usr/share/arduino/hardware/arduino/avr Using core 'arduino' from platform in folder: /usr/share/arduino/hardware/arduino/avr Detecting libraries used... "/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/standard" "/tmp/arduino_build_466420/sketch/AnalogReadSerial.ino.cpp" -o "/dev/null" Generating function prototypes... "/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/standard" "/tmp/arduino_build_466420/sketch/AnalogReadSerial.ino.cpp" -o "/tmp/arduino_build_466420/preproc/ctags_target_for_gcc_minus_e.cpp" "/usr/bin/arduino-ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/tmp/arduino_build_466420/preproc/ctags_target_for_gcc_minus_e.cpp" Sketch wird kompiliert... "/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/standard" "/tmp/arduino_build_466420/sketch/AnalogReadSerial.ino.cpp" -o "/tmp/arduino_build_466420/sketch/AnalogReadSerial.ino.cpp.o" Compiling libraries... Compiling core... Using precompiled core Linking everything together... "/usr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "/tmp/arduino_build_466420/AnalogReadSerial.ino.elf" "/tmp/arduino_build_466420/sketch/AnalogReadSerial.ino.cpp.o" "/tmp/arduino_build_466420/../arduino_cache_132696/core/core_arduino_avr_uno_1621df717313d057c92202babd71649a.a" "-L/tmp/arduino_build_466420" -lm "/usr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "/tmp/arduino_build_466420/AnalogReadSerial.ino.elf" "/tmp/arduino_build_466420/AnalogReadSerial.ino.eep" "/usr/bin/avr-objcopy" -O ihex -R .eeprom "/tmp/arduino_build_466420/AnalogReadSerial.ino.elf" "/tmp/arduino_build_466420/AnalogReadSerial.ino.hex" Der Sketch verwendet 1904 Bytes (5%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes. Globale Variablen verwenden 188 Bytes (9%) des dynamischen Speichers, 1860 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes. /usr/bin/avrdude -C/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/arduino_build_466420/AnalogReadSerial.ino.hex:i avrdude: Version 7.1 Copyright the AVRDUDE authors; see https://github.com/avrdudes/avrdude/blob/main/AUTHORS System wide configuration file is /etc/avrdude.conf User configuration file is /home/mike/.avrduderc User configuration file does not exist or is not a regular file, skipping Using Port : /dev/ttyUSB0 Using Programmer : arduino Overriding Baud Rate : 115200 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : possible i/o RETRY pulse : SCK Serial program mode : yes Parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Alias Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- -------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00 signature 0 0 0 0 no 3 1 0 0 0 0x00 0x00 calibration 0 0 0 0 no 1 1 0 0 0 0x00 0x00 Programmer Type : Arduino Description : Arduino for bootloader using STK500 v1 protocol Hardware Version: 3 Firmware Version: 4.4 avrdude: AVR device initialized and ready to accept instructions avrdude: device signature = 0x1e950f (probably m328p) avrdude: reading input file /tmp/arduino_build_466420/AnalogReadSerial.ino.hex for flash with 1904 bytes in 1 section within [0, 0x76f] using 15 pages and 16 pad bytes avrdude: writing 1904 bytes flash ... Writing | ################################################## | 100% 0.33s avrdude: 1904 bytes of flash written avrdude: verifying flash memory against /tmp/arduino_build_466420/AnalogReadSerial.ino.hex Reading | ################################################## | 100% 0.25s avrdude: 1904 bytes of flash verified avrdude done. Thank you.
