/*****************************************************/ // W5500_config.h // brief WIZCHIP Config Header File. // version 1.0.0 // date 2013/10/21 /*****************************************************/ #ifndef _WIZCHIP_CONF_H_ #define _WIZCHIP_CONF_H_ #include /** * @brief Select WIZCHIP. * @todo You should select one, \b 5100, \b 5200, \b 5300, \b 5500 or etc. \n\n * ex> #define \_WIZCHIP_ 5500 */ #ifndef _WIZCHIP_ #define _WIZCHIP_ 5500 // 5100, 5200, 5300, 5500 #endif #define _WIZCHIP_ID_ "W5500\0" /** * @brief Define interface mode. \n * @todo Should select interface mode as chip. * - @ref \_WIZCHIP_IO_MODE_SPI_ \n * -@ref \_WIZCHIP_IO_MODE_SPI_VDM_ : Valid only in @ref \_WIZCHIP_ == 5500 \n * -@ref \_WIZCHIP_IO_MODE_SPI_FDM_ : Valid only in @ref \_WIZCHIP_ == 5500 \n * - @ref \_WIZCHIP_IO_MODE_BUS_ \n * - @ref \_WIZCHIP_IO_MODE_BUS_DIR_ \n * - @ref \_WIZCHIP_IO_MODE_BUS_INDIR_ \n * - Others will be defined in future. \n\n * ex> #define \_WIZCHIP_IO_MODE_ \_WIZCHIP_IO_MODE_SPI_VDM_ */ #define _WIZCHIP_SOCK_NUM_ 8 ///< The count of independant socket of @b WIZCHIP /** * @ingroup DATA_TYPE * WIZCHIP control type enumration used in @ref ctlwizchip(). */ typedef enum { CW_RESET_WIZCHIP, ///< Resets WIZCHIP by softly CW_INIT_WIZCHIP, ///< Initializes to WIZCHIP with SOCKET buffer size 2 or 1 dimension array typed uint8_t. CW_GET_INTERRUPT, ///< Get Interrupt status of WIZCHIP CW_CLR_INTERRUPT, ///< Clears interrupt CW_SET_INTRMASK, ///< Masks interrupt CW_GET_INTRMASK, ///< Get interrupt mask CW_SET_INTRTIME, ///< Set interval time between the current and next interrupt. CW_GET_INTRTIME, ///< Set interval time between the current and next interrupt. CW_GET_ID, ///< Gets WIZCHIP name. //D20150601 : For no modification your application code //#if _WIZCHIP_ == 5500 CW_RESET_PHY, ///< Resets internal PHY. Valid Only W5500 CW_SET_PHYCONF, ///< When PHY configured by internal register, PHY operation mode (Manual/Auto, 10/100, Half/Full). Valid Only W5000 CW_GET_PHYCONF, ///< Get PHY operation mode in internal register. Valid Only W5500 CW_GET_PHYSTATUS, ///< Get real PHY status on operating. Valid Only W5500 CW_SET_PHYPOWMODE, ///< Set PHY power mode as normal and down when PHYSTATUS.OPMD == 1. Valid Only W5500 //#endif //D20150601 : For no modification your application code //#if _WIZCHIP_ == 5200 || _WIZCHIP_ == 5500 CW_GET_PHYPOWMODE, ///< Get PHY Power mode as down or normal, Valid Only W5100, W5200 CW_GET_PHYLINK ///< Get PHY Link status, Valid Only W5100, W5200 //#endif } ctlwizchip_type; /** * @ingroup DATA_TYPE * Network control type enumration used in @ref ctlnetwork(). */ typedef enum { CN_SET_NETINFO, ///< Set Network with @ref wiz_NetInfo CN_GET_NETINFO, ///< Get Network with @ref wiz_NetInfo CN_SET_NETMODE, ///< Set network mode as WOL, PPPoE, Ping Block, and Force ARP mode CN_GET_NETMODE, ///< Get network mode as WOL, PPPoE, Ping Block, and Force ARP mode CN_SET_TIMEOUT, ///< Set network timeout as retry count and time. CN_GET_TIMEOUT, ///< Get network timeout as retry count and time. } ctlnetwork_type; /** * @ingroup DATA_TYPE * Interrupt kind when CW_SET_INTRRUPT, CW_GET_INTERRUPT, CW_SET_INTRMASK * and CW_GET_INTRMASK is used in @ref ctlnetwork(). * It can be used with OR operation. */ typedef enum { IK_WOL = (1 << 4), ///< Wake On Lan by receiving the magic packet. Valid in W500. IK_PPPOE_TERMINATED = (1 << 5), ///< PPPoE Disconnected IK_DEST_UNREACH = (1 << 6), ///< Destination IP & Port Unreachable, No use in W5200 IK_IP_CONFLICT = (1 << 7), ///< IP conflict occurred IK_SOCK_0 = (1 << 8), ///< Socket 0 interrupt IK_SOCK_1 = (1 << 9), ///< Socket 1 interrupt IK_SOCK_2 = (1 << 10), ///< Socket 2 interrupt IK_SOCK_3 = (1 << 11), ///< Socket 3 interrupt IK_SOCK_4 = (1 << 12), ///< Socket 4 interrupt, No use in 5100 IK_SOCK_5 = (1 << 13), ///< Socket 5 interrupt, No use in 5100 IK_SOCK_6 = (1 << 14), ///< Socket 6 interrupt, No use in 5100 IK_SOCK_7 = (1 << 15), ///< Socket 7 interrupt, No use in 5100 IK_SOCK_ALL = (0xFF << 8) ///< All Socket interrupt }intr_kind; #define PHY_CONFBY_HW 0 ///< Configured PHY operation mode by HW pin #define PHY_CONFBY_SW 1 ///< Configured PHY operation mode by SW register #define PHY_MODE_MANUAL 0 ///< Configured PHY operation mode with user setting. #define PHY_MODE_AUTONEGO 1 ///< Configured PHY operation mode with auto-negotiation #define PHY_SPEED_10 0 ///< Link Speed 10 #define PHY_SPEED_100 1 ///< Link Speed 100 #define PHY_DUPLEX_HALF 0 ///< Link Half-Duplex #define PHY_DUPLEX_FULL 1 ///< Link Full-Duplex #define PHY_LINK_OFF 0 ///< Link Off #define PHY_LINK_ON 1 ///< Link On #define PHY_POWER_NORM 0 ///< PHY power normal mode #define PHY_POWER_DOWN 1 ///< PHY power down mode /** * @ingroup DATA_TYPE * It configures PHY configuration when CW_SET PHYCONF or CW_GET_PHYCONF in W5500, * and it indicates the real PHY status configured by HW or SW in all WIZCHIP. \n * Valid only in W5500. */ typedef struct wiz_PhyConf_t { uint8_t by; ///< set by @ref PHY_CONFBY_HW or @ref PHY_CONFBY_SW uint8_t mode; ///< set by @ref PHY_MODE_MANUAL or @ref PHY_MODE_AUTONEGO uint8_t speed; ///< set by @ref PHY_SPEED_10 or @ref PHY_SPEED_100 uint8_t duplex; ///< set by @ref PHY_DUPLEX_HALF @ref PHY_DUPLEX_FULL //uint8_t power; ///< set by @ref PHY_POWER_NORM or @ref PHY_POWER_DOWN //uint8_t link; ///< Valid only in CW_GET_PHYSTATUS. set by @ref PHY_LINK_ON or PHY_DUPLEX_OFF } wiz_PhyConf; /** * @ingroup DATA_TYPE * It used in setting dhcp_mode of @ref wiz_NetInfo. */ typedef enum { NETINFO_STATIC = 1, ///< Static IP configuration by manually. NETINFO_DHCP ///< Dynamic IP configruation from a DHCP sever } dhcp_mode; /** * @ingroup DATA_TYPE * Network Information for WIZCHIP */ typedef struct wiz_NetInfo_t { uint8_t mac[6]; ///< Source Mac Address uint8_t ip[4]; ///< Source IP Address uint8_t sn[4]; ///< Subnet Mask uint8_t gw[4]; ///< Gateway IP Address uint8_t dns[4]; ///< DNS server IP Address dhcp_mode dhcp; ///< 1 - Static, 2 - DHCP } wiz_NetInfo; /** * @ingroup DATA_TYPE * Network mode */ typedef enum { NM_FORCEARP = (1<<1), ///< Force to APP send whenever udp data is sent. Valid only in W5500 NM_WAKEONLAN = (1<<5), ///< Wake On Lan NM_PINGBLOCK = (1<<4), ///< Block ping-request NM_PPPOE = (1<<3), ///< PPPoE mode } netmode_type; /** * @ingroup DATA_TYPE * Used in CN_SET_TIMEOUT or CN_GET_TIMEOUT of @ref ctlwizchip() for timeout configruation. */ typedef struct wiz_NetTimeout_t { uint8_t retry_cnt; ///< retry count uint16_t time_100us; ///< time unit 100us } wiz_NetTimeout; /* @ingroup extra_functions * @brief Controls to the WIZCHIP. * @details Resets WIZCHIP & internal PHY, Configures PHY mode, Monitor PHY(Link,Speed,Half/Full/Auto), * controls interrupt & mask and so on. * @param cwtype : Decides to the control type * @param arg : arg type is dependent on cwtype. * @return 0 : Success \n * -1 : Fail because of invalid \ref ctlwizchip_type or unsupported \ref ctlwizchip_type in WIZCHIP */ int8_t ctlwizchip (ctlwizchip_type cwtype, void* arg); /* @ingroup extra_functions * @brief Controls to network. * @details Controls to network environment, mode, timeout and so on. * @param cntype : Input. Decides to the control type * @param arg : Inout. arg type is dependent on cntype. * @return -1 : Fail because of invalid \ref ctlnetwork_type or unsupported \ref ctlnetwork_type in WIZCHIP \n * 0 : Success */ int8_t ctlnetwork (ctlnetwork_type cntype, void* arg); /* The following functions are implemented for internal use. * but You can call these functions for code size reduction instead of ctlwizchip() and ctlnetwork(). */ /* @ingroup extra_functions * @brief Reset WIZCHIP by softly. */ void w5500cfg_sw_reset (void); /* @ingroup extra_functions * @brief Initializes WIZCHIP with socket buffer size * @param txsize Socket tx buffer sizes. If null, initialized the default size 2KB. * @param rxsize Socket rx buffer sizes. If null, initialized the default size 2KB. * @return 0 : succcess \n * -1 : fail. Invalid buffer size */ int8_t w5500cfg_init (uint8_t* txsize, uint8_t* rxsize); /* @ingroup extra_functions * @brief Clear Interrupt of WIZCHIP. * @param intr : @ref intr_kind value operated OR. It can type-cast to uint16_t. */ void w5500cfg_clrinterrupt (intr_kind intr); /* @ingroup extra_functions * @brief Get Interrupt of WIZCHIP. * @return @ref intr_kind value operated OR. It can type-cast to uint16_t. */ intr_kind w5500cfg_getinterrupt (void); /* @ingroup extra_functions * @brief Mask or Unmask Interrupt of WIZCHIP. * @param intr : @ref intr_kind value operated OR. It can type-cast to uint16_t. */ void w5500cfg_setinterruptmask (intr_kind intr); /* @ingroup extra_functions * @brief Get Interrupt mask of WIZCHIP. * @return : The operated OR vaule of @ref intr_kind. It can type-cast to uint16_t. */ intr_kind w5500cfg_getinterruptmask (void); int8_t wizphy_getphylink(void); ///< get the link status of phy in WIZCHIP. No use in W5100 int8_t wizphy_getphypmode(void); ///< get the power mode of PHY in WIZCHIP. No use in W5100 void wizphy_reset(void); ///< Reset phy. Vailid only in W5500 /* @ingroup extra_functions * @brief Set the phy information for WIZCHIP without power mode * @param phyconf : @ref wiz_PhyConf */ void wizphy_setphyconf(wiz_PhyConf* phyconf); /* @ingroup extra_functions * @brief Get phy configuration information. * @param phyconf : @ref wiz_PhyConf */ void wizphy_getphyconf(wiz_PhyConf* phyconf); /* @ingroup extra_functions * @brief Get phy status. * @param phyconf : @ref wiz_PhyConf */ void wizphy_getphystat(wiz_PhyConf* phyconf); /* @ingroup extra_functions * @brief set the power mode of phy inside WIZCHIP. Refer to @ref PHYCFGR in W5500, @ref PHYSTATUS in W5200 * @param pmode Settig value of power down mode. */ int8_t wizphy_setphypmode(uint8_t pmode); /* @ingroup extra_functions * @brief Set the network information for WIZCHIP * @param pnetinfo : @ref wizNetInfo */ void w5500cfg_setnetinfo(wiz_NetInfo* pnetinfo); /* @ingroup extra_functions * @brief Get the network information for WIZCHIP * @param pnetinfo : @ref wizNetInfo */ void w5500cfg_getnetinfo(wiz_NetInfo* pnetinfo); /* @ingroup extra_functions * @brief Set the network mode such WOL, PPPoE, Ping Block, and etc. * @param pnetinfo Value of network mode. Refer to @ref netmode_type. */ int8_t w5500cfg_setnetmode(netmode_type netmode); /* @ingroup extra_functions * @brief Get the network mode such WOL, PPPoE, Ping Block, and etc. * @return Value of network mode. Refer to @ref netmode_type. */ netmode_type w5500cfg_getnetmode(void); /* @ingroup extra_functions * @brief Set retry time value(@ref _RTR_) and retry count(@ref _RCR_). * @details @ref _RTR_ configures the retransmission timeout period and @ref _RCR_ configures the number of time of retransmission. * @param nettime @ref _RTR_ value and @ref _RCR_ value. Refer to @ref wiz_NetTimeout. */ void w5500cfg_settimeout(wiz_NetTimeout* nettime); /* @ingroup extra_functions * @brief Get retry time value(@ref _RTR_) and retry count(@ref _RCR_). * @details @ref _RTR_ configures the retransmission timeout period and @ref _RCR_ configures the number of time of retransmission. * @param nettime @ref _RTR_ value and @ref _RCR_ value. Refer to @ref wiz_NetTimeout. */ void w5500cfg_gettimeout(wiz_NetTimeout* nettime); #endif // _WIZCHIP_CONF_H_ /* ----------------------------------------------*/ /* -------- End of file W5500_config.h --------- */ /* ----------------------------------------------*/
