//#define DEBUG_PRINT #define SIGNAL_PIN 8 // (Speed) Beliebigen Pin hier setzen (z. B. 8, 9, A0, etc.) #define CADENCE_PIN 3 // This is fixed for IRQ #define BRAKE_PIN 5 // Connection to ebike-Controller #define LED_PIN 13 // ON: Motor allowed #include #include // Hilfs-Makros zur Auflösung von Arduino-Pins in Register-Zugehörigkeiten #if (SIGNAL_PIN >= 0 && SIGNAL_PIN <= 7) // Digital 0–7 = PORTD #define PCINT_VECTOR PCINT2_vect #define PCICR_BIT PCIE2 #define PCMSK_REG PCMSK2 #define PIN_REG PIND #define PIN_BIT SIGNAL_PIN #define PCINT_BIT SIGNAL_PIN #elif (SIGNAL_PIN >= 8 && SIGNAL_PIN <= 13) // Digital 8–13 = PORTB #define PCINT_VECTOR PCINT0_vect #define PCICR_BIT PCIE0 #define PCMSK_REG PCMSK0 #define PIN_REG PINB #define PIN_BIT (SIGNAL_PIN - 8) #define PCINT_BIT (SIGNAL_PIN - 8) #elif (SIGNAL_PIN >= A0 && SIGNAL_PIN <= A5) // Analog Pins A0–A5 = PORTC #define PCINT_VECTOR PCINT1_vect #define PCICR_BIT PCIE1 #define PCMSK_REG PCMSK1 #define PIN_REG PINC #define PIN_BIT (SIGNAL_PIN - A0) #define PCINT_BIT (SIGNAL_PIN - A0) #else #error "SIGNAL_PIN ist nicht gültig für PCINT" #endif // Parameter to controll the Pedelec #define TIMEOUT_CADENCE 1000 // after 1s no signal we are inactive #define TIMEOUT_MS 3000 // 8s = 2.2m * 60*60s/1000m) = 7.92 s #define DIAMETER 2.224 // distance a wheel makes with 1 turn #define SPEED_MIN 6 // 6km/h below no cadence required #define SPEED_MAX 27.5 // above that no support by motor (25km/h+10%) void setup() { pinMode(SIGNAL_PIN, INPUT_PULLUP); pinMode(CADENCE_PIN, INPUT_PULLUP); pinMode(BRAKE_PIN, OUTPUT); digitalWrite(BRAKE_PIN, LOW); // brake - motor not active digitalWrite(LED_PIN, HIGH); // LED on: Motor on / Brake not active // Pin Change Interrupt für ausgewählten Pin aktivieren PCICR |= (1 << PCICR_BIT); PCMSK_REG |= (1 << PCINT_BIT); attachInterrupt(digitalPinToInterrupt(CADENCE_PIN), cadenceISR, RISING); sei(); // Globale Interrupts aktivieren Serial.begin(115200); } volatile uint32_t lastMicros = 0; volatile bool readyToSend = false; volatile uint32_t lastEventMillis = 0; volatile uint32_t speed_time_us = 0; ISR(PCINT_VECTOR) { static uint8_t lastState = 1; // is only 1 at first call - as static! static uint32_t lastMicros = 0; // is only 0 at first call - as static! static uint32_t last_LH_Micros = 0; // static bool currentState = PIN_REG & (1 << PIN_BIT); if (currentState && !lastState) { // Ignore RISING Edge lastState = currentState; return; } uint32_t now = micros(); // FALLING Edge uint32_t delta = now - lastMicros; // delta to last FALLING lastMicros = now; if (delta < 150000) // check if this the right FALLING Edge return; // debounce // Now we have a FALLING EDGE and H was stable for 150ms speed_time_us = now - last_LH_Micros; last_LH_Micros = now; lastEventMillis = millis(); // for set speed to "0" after timeout readyToSend = true; } unsigned long lastCadenceMillis = 0; // global variable, output of ISR // === ISR Kadenz (INT1) === void cadenceISR() { bool currentLevel = digitalRead(CADENCE_PIN); uint32_t now = millis(); uint32_t delta = now - lastCadenceMillis; if (delta < 100 || currentLevel != HIGH ) // 100ms debounce, Rising should give HIGH level return; // Serial.println("Cadence"); lastCadenceMillis = now; // copy to global variable } float speed_now = 0; float speed_filtered = 0; uint32_t lastEventDiff; float speed_old=0; void loop() { // delay(200); // return; #ifdef DEBUG_PRINT // Serial.print("Level at D8 :\t"); // Serial.println(digitalRead(8)); // delay(200); // return; #endif bool cadenceActive = false; uint32_t now = millis(); if (now - lastCadenceMillis < TIMEOUT_CADENCE) cadenceActive = true; #ifdef DEBUG_PRINT Serial.print("C_diff:\t"); Serial.print(now - lastCadenceMillis); Serial.print("\tcadenceActive: "); Serial.print(cadenceActive ? "H " : "L "); #endif lastEventDiff = now - lastEventMillis; // update auch wenn keine IRQs mehr kommen if (readyToSend == true || lastEventDiff > TIMEOUT_MS) { if ( readyToSend == false ) { // Serial.print("\tTimeout\t"); speed_now = 0; speed_filtered = 0; lastEventMillis = millis(); } else { speed_now = DIAMETER * 3.6 * 1e6 / speed_time_us; #ifdef DEBUG_PRINT Serial.print(speed_time_us/1e3); Serial.print(" ms / "); Serial.print(speed_now); Serial.print(" km/h"); #endif readyToSend = false; } if ( (speed_old < 2) && (speed_now > 4)) speed_now = 2; speed_old = speed_now; speed_filtered = 1.0 * speed_now + 0.0 * speed_filtered; #ifdef DEBUG_PRINT // Serial.print("speed: \t"); // Serial.print(speed_now,1); // Serial.print(" km/h"); #endif } // set the Brake-Signal (Low = Brake, High = Run) if ( (speed_now < SPEED_MIN) || ( speed_now <= SPEED_MAX && cadenceActive )) { // if ( true ) { digitalWrite(BRAKE_PIN, HIGH); // motor active digitalWrite(LED_PIN, HIGH); // LED on: Motor on / Brake not active #ifdef DEBUG_PRINT Serial.print(" -> RUN\n"); #endif } else { digitalWrite(BRAKE_PIN, LOW); // brake active digitalWrite(LED_PIN, LOW); // LED off: Motor off / Brake active #ifdef DEBUG_PRINT Serial.print(" -> BRAKE\n"); #endif } delay(200); }
