;Blink LED mit Timer ISR .include "m328Pdef.inc" .def temp = r16 .equ LED = PD3 .equ LED_PORT = PORTD .equ LED_DDR = DDRD .equ LED_PIN = PIND .org 0x0000 ; IRQ Tabelle jmp RESET .org OC1Aaddr jmp Timer_ISR RESET: ;------------------------------------------------------------------------------------------ ldi temp, LOW(RAMEND) ; LOW-Byte der obersten RAM-Adresse out SPL, temp ldi temp, HIGH(RAMEND) ; HIGH-Byte der obersten RAM-Adresse out SPH, temp ;------------------------------------------------------------------------------------------ ;setup port ldi temp, 1<
