// --- Pin Definitions for ESP8266 NodeMCU --- // 74HC595 Control Pins const int SER_PIN = 14; // ESP8266 GPIO14 (NodeMCU D5) const int SRCLK_PIN = 12; // ESP8266 GPIO12 (NodeMCU D6) const int RCLK_PIN = 13; // ESP8266 GPIO13 (NodeMCU D7) // LCD Control Pins (Directly connected to ESP8266, will go through Level Shifter IC2) const int LCD_CS_PIN = 16; // ESP8266 GPIO16 (NodeMCU D0) const int LCD_RS_PIN = 5; // ESP8266 GPIO5 (NodeMCU D1) const int LCD_RESET_PIN = 4; // ESP8266 GPIO4 (NodeMCU D2) const int LCD_WR_PIN = 0; // ESP8266 GPIO0 (NodeMCU D3) const int LCD_RD_PIN = 2; // ESP8266 GPIO2 (NodeMCU D4) - For STROBING read only // --- HD66766 Register Definitions --- #define REG_OSC_START 0x00 // Start Oscillation #define REG_DRIVER_OUTPUT_CTRL 0x01 // Driver Output Control #define REG_AC_DRIVE_CTRL 0x02 // LCD-Driving-Waveform Control #define REG_POWER_CTRL_1 0x03 // Power Control 1 (BS, BT, DC, AP, SLP) #define REG_CONTRAST_CTRL 0x04 // Contrast Control (VR, CT) #define REG_ENTRY_MODE 0x05 // Entry Mode (AM, I/D, SPR, HWM, LG) -> MADCTL equivalent #define REG_DISPLAY_CTRL 0x07 // Display Control (D, REV, B/W, SPT, VLE) #define REG_FRAME_CYCLE_CTRL 0x0B // Frame Cycle Control (DIV, RTN) #define REG_POWER_CTRL_2 0x0C // Power Control 2 (VC) #define REG_H_RAM_ADDR_POS 0x16 // Horizontal RAM Address Position (Window X: HEA, HSA) #define REG_V_RAM_ADDR_POS 0x17 // Vertical RAM Address Position (Window Y: VEA, VSA) #define REG_RAM_WRITE_MASK 0x20 // RAM Write Data Mask (WM) #define REG_RAM_ADDR_SET 0x21 // RAM Address Set (AC pointer) #define REG_GRAM_DATA_RW 0x22 // Write/Read Data to/from GRAM // --- RGB565 Color Definitions --- const uint16_t COLOR_BLACK = 0x0000; const uint16_t COLOR_BLUE = 0x001F; const uint16_t COLOR_RED = 0xF800; const uint16_t COLOR_GREEN = 0x07E0; const uint16_t COLOR_CYAN = 0x07FF; const uint16_t COLOR_MAGENTA = 0xF81F; const uint16_t COLOR_YELLOW = 0xFFE0; const uint16_t COLOR_WHITE = 0xFFFF; // Helper function to convert 24-bit RGB to 16-bit RGB565 uint16_t colorToRGB565(uint8_t r, uint8_t g, uint8_t b) { return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3); } // Helper function to put data on 74HC595 outputs void shift_out_to_lcd_data_bus(uint8_t dataByte) { digitalWrite(RCLK_PIN, LOW); for (int i = 7; i >= 0; i--) { digitalWrite(SER_PIN, (dataByte >> i) & 0x01); digitalWrite(SRCLK_PIN, LOW); digitalWrite(SRCLK_PIN, HIGH); } digitalWrite(RCLK_PIN, HIGH); delayMicroseconds(2); // Ensure data is latched and settled on 595 outputs } // Sends one raw byte with WR pulse (assumes /CS and RS are already set) void hd66766_send_one_byte_raw(uint8_t byte_val) { shift_out_to_lcd_data_bus(byte_val); delayMicroseconds(2); // Let data settle through TXS0108E to LCD inputs digitalWrite(LCD_WR_PIN, LOW); delayMicroseconds(2); // WR low pulse width digitalWrite(LCD_WR_PIN, HIGH); delayMicroseconds(2); // WR recovery time } // --- HD66766 16-bit Operations (Corrected /CS Handling) --- void hd66766_write_to_ir(uint16_t index_val) { digitalWrite(LCD_CS_PIN, LOW); digitalWrite(LCD_RS_PIN, LOW); hd66766_send_one_byte_raw((index_val >> 8) & 0xFF); hd66766_send_one_byte_raw(index_val & 0xFF); digitalWrite(LCD_CS_PIN, HIGH); delayMicroseconds(2); // Recovery time after /CS high } void hd66766_write_to_wdr(uint16_t data_val) { digitalWrite(LCD_CS_PIN, LOW); digitalWrite(LCD_RS_PIN, HIGH); hd66766_send_one_byte_raw((data_val >> 8) & 0xFF); hd66766_send_one_byte_raw(data_val & 0xFF); digitalWrite(LCD_CS_PIN, HIGH); delayMicroseconds(2); // Recovery time } // Synchronization void hd66766_synchronize_transfer() { for (int i = 0; i < 4; i++) { hd66766_write_to_ir(0x0000); // This will use the corrected /CS logic } } // LCD Initialization void lcd_reset() { digitalWrite(LCD_RESET_PIN, HIGH); delayMicroseconds(100); digitalWrite(LCD_RESET_PIN, LOW); delayMicroseconds(200); // Recommendation from Tech. Document HD66766 digitalWrite(LCD_RESET_PIN, HIGH); delay(15); // Oscillator stabilization (>10ms) } void lcd_init() { Serial.println("Starting LCD Init..."); lcd_reset(); Serial.println("Init: Power On Initialized Bits (Step 5 - R03h, R04h, R0Ch)"); hd66766_write_to_ir(REG_POWER_CTRL_1); // R03h hd66766_write_to_wdr(0x9000); // BS=1/12 (0x9), BT3=0, AP=off hd66766_write_to_ir(REG_CONTRAST_CTRL); // R04h hd66766_write_to_wdr(0x0040); // CT=mid_range (64) - STARTING POINT FOR EXPERIMENTATION // Have to Try 0x0000, 0x0020, 0x0040, 0x0060, 0x007F hd66766_write_to_ir(REG_POWER_CTRL_2); // R0Ch hd66766_write_to_wdr(0x0000); // VC=0.92xVcc delay(60); // Step 6: Wait >50ms Serial.println("Init: Start Voltage Inverter (Step 7 - R03h)"); hd66766_write_to_ir(REG_POWER_CTRL_1); // R03h hd66766_write_to_wdr(0x9800); // BT3=1 (inverter on), BS=0x9 delay(220); // Step 8: Wait >200ms Serial.println("Init: Other Mode Settings (Step 9)"); hd66766_write_to_ir(REG_POWER_CTRL_1); // R03h hd66766_write_to_wdr(0x9804); // AP=Small current, BT3=1, BS=0x9 hd66766_write_to_ir(REG_DRIVER_OUTPUT_CTRL); // R01h hd66766_write_to_wdr(0x0013); // NL=160 lines (0x13), CMS=0, SGS=0 hd66766_write_to_ir(REG_AC_DRIVE_CTRL); // R02h hd66766_write_to_wdr(0x0000); hd66766_write_to_ir(REG_ENTRY_MODE); // R05h hd66766_write_to_wdr(0x0030); // SPR=0 (direct RGB565), HWM=0, I/D=inc (11), AM=horizontal (0), LG=replace (000) // Set GRAM Window to 120x160 hd66766_write_to_ir(REG_H_RAM_ADDR_POS); // R16h hd66766_write_to_wdr( ((uint16_t)(120-1) << 8) | 0x00 ); // EndX=119 (0x77), StartX=0 hd66766_write_to_ir(REG_V_RAM_ADDR_POS); // R17h hd66766_write_to_wdr( ((uint16_t)(160-1) << 8) | 0x00 ); // EndY=159 (0x9F), StartY=0 hd66766_write_to_ir(REG_FRAME_CYCLE_CTRL); // R0Bh hd66766_write_to_wdr(0x0000); hd66766_write_to_ir(REG_RAM_WRITE_MASK); // R20h hd66766_write_to_wdr(0x0000); // No mask hd66766_write_to_ir(REG_RAM_ADDR_SET); // R21h hd66766_write_to_wdr(0x0000); // Set AC to (0,0) within window Serial.println("Init: Display ON (Step 10 - R07h)"); hd66766_write_to_ir(REG_DISPLAY_CTRL); // R07h hd66766_write_to_wdr(0x0003); hd66766_synchronize_transfer(); Serial.println("LCD Init sequence completed."); } // Basic Drawing Functions void lcd_set_window(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1) { hd66766_write_to_ir(REG_H_RAM_ADDR_POS); hd66766_write_to_wdr( ((uint16_t)x1 << 8) | x0 ); hd66766_write_to_ir(REG_V_RAM_ADDR_POS); hd66766_write_to_wdr( ((uint16_t)y1 << 8) | y0 ); hd66766_write_to_ir(REG_RAM_ADDR_SET); hd66766_write_to_wdr(0x0000); } void lcd_clear_screen(uint16_t color) { lcd_set_window(0, 0, 120 - 1, 160 - 1); hd66766_write_to_ir(REG_GRAM_DATA_RW); for (long i = 0; i < 120L * 160L; i++) { hd66766_write_to_wdr(color); if ((i & 0x7F) == 0) { yield(); } } yield(); } void lcd_draw_pixel(uint8_t x, uint8_t y, uint16_t color) { if (x >= 120 || y >= 160) return; lcd_set_window(x, y, x, y); hd66766_write_to_ir(REG_GRAM_DATA_RW); hd66766_write_to_wdr(color); } void setup() { Serial.begin(115200); while (!Serial); Serial.println("\nESP8266 HD66766 LCD Test Program - Corrected CS/Timings"); pinMode(SER_PIN, OUTPUT); pinMode(SRCLK_PIN, OUTPUT); pinMode(RCLK_PIN, OUTPUT); pinMode(LCD_CS_PIN, OUTPUT); pinMode(LCD_RS_PIN, OUTPUT); pinMode(LCD_WR_PIN, OUTPUT); pinMode(LCD_RD_PIN, OUTPUT); pinMode(LCD_RESET_PIN, OUTPUT); digitalWrite(LCD_CS_PIN, HIGH); digitalWrite(LCD_WR_PIN, HIGH); digitalWrite(LCD_RD_PIN, HIGH); digitalWrite(LCD_RESET_PIN, HIGH); lcd_init(); Serial.println("Drawing test patterns..."); lcd_clear_screen(COLOR_BLACK); delay(200); lcd_clear_screen(COLOR_RED); delay(200); lcd_clear_screen(COLOR_GREEN); delay(200); lcd_clear_screen(COLOR_BLUE); delay(200); lcd_clear_screen(COLOR_BLACK); for(int i=0; i<120; i+=4){ for(int j=0; j<160; j+=4){ if ((i/4 + j/4) % 2 == 0) { lcd_draw_pixel(i, j, COLOR_WHITE); } if ((j & 0x0F) == 0) yield(); } yield(); } delay(500); for(int y=0; y<160; y++){ lcd_draw_pixel(0, y, COLOR_YELLOW); lcd_draw_pixel(119, y, COLOR_YELLOW); if ((y & 0x0F) == 0) yield(); } for(int x=0; x<120; x++){ lcd_draw_pixel(x, 0, COLOR_CYAN); lcd_draw_pixel(x, 159, COLOR_CYAN); if ((x & 0x0F) == 0) yield(); } Serial.println("Test patterns complete."); } void loop() { delay(1000); }
