SRAM_start = 0x20000000 SRAM_end = 0x20000800 STACK = 0x20000800 TIM2_BASE = 0x40000000 W_WDG_BASE = 0x40002C00 I_WDG_BASE = 0x40003000 I2C_BASE = 0x40005400 PWR_BASE = 0x40007000 AFIO_BASE = 0x40010000 EXTI_BASE = 0x40010400 PORTA_BASE = 0x40010800 PORTC_BASE = 0x40011000 PORTD_BASE = 0x40011400 ADC_BASE = 0x40012400 TIM1_BASE = 0x40012C00 SPI_BASE = 0x40013000 USART_BASE = 0x40013800 DMA_BASE = 0x40020000 RCC_BASE = 0x40021000 FLASH_INTERFACE_BASE = 0x40022000 EXTENDED_MEM_BASE = 0x40023800 CORE_PRIVATE_BASE = 0xE0000000 FLASH_BASE = 0x08000000 R32_PWR_CTLR = 0x40007000 #Power control register R32_PWR_CSR = 0x40007004 #Power control/status register R32_PWR_AWUCSR = 0x40007008 #Auto-wakeup control/status register R32_PWR_AWUWR = 0x4000700C #Auto-wakeup window comparison value register R32_PWR_AWUPSC = 0x40007010 #Auto-wakeup crossover factor register R32_RCC_CTLR = 0x40021000 #Clock control register 0x0000xx83 R32_RCC_CFGR0 = 0x40021004 #Clock configuration register 0 0x00000000 R32_RCC_INTR = 0x40021008 #Clock interrupt register 0x00000000 R32_RCC_APB2PRSTR = 0x4002100C #APB2 peripheral reset register 0x00000000 R32_RCC_APB1PRSTR = 0x40021010 # APB1 peripheral reset register 0x00000000 R32_RCC_AHBPCENR = 0x40021014 #AHB peripheral clock enable register 0x00000014 R32_RCC_APB2PCENR = 0x40021018 #APB2 peripheral clock enable register 0x00000000 R32_RCC_APB1PCENR = 0x4002101C #APB1 peripheral clock enable register 0x00000000 R32_RCC_RSTSCKR = 0x40021024 #Control/status register R16_IWDG_CTLR = 0x40003000 #Control register 0x0000 R16_IWDG_PSCR = 0x40003004 #Prescaler register 0x0000 R16_IWDG_RLDR = 0x40003008 #Reload register 0x0FFF R16_IWDG_STATR = 0x4000300C #Status register R16_WWDG_CTLR = 0x40002C00 #Control register 0x007F R16_WWDG_CFGR = 0x40002C04 #Configuration Register 0x007F R16_WWDG_STATR = 0x40002C08 #Status Register R32_EXTI_INTENR = 0x40010400 #Interrupt enable register 0x00000000 R32_EXTI_EVENR = 0x40010404 #Event enable register 0x00000000 R32_EXTI_RTENR = 0x40010408 #Rising edge trigger enable register 0x00000000 R32_EXTI_FTENR = 0x4001040C #Falling edge trigger enable register 0x00000000 R32_EXTI_SWIEVR = 0x40010410 #Soft interrupt event register 0x00000000 R32_EXTI_INTFR = 0x40010414 #Interrupt flag register R32_PFIC_ISR1 = 0xE000E000 #PFIC interrupt enable status register 1 R32_PFIC_ISR2 = 0xE000E004 #PFIC interrupt enable status register 2 R32_PFIC_IPR1 = 0xE000E020 #PFIC interrupt pending status register 1 R32_PFIC_IPR2 = 0xE000E024 #PFIC interrupt pending status register 2 R32_PFIC_ITHRESDR = 0xE000E040 #PFIC interrupt priority threshold configuration register R32_PFIC_CFGR = 0xE000E048 #PFIC interrupt configuration register R32_PFIC_GISR = 0xE000E04C #PFIC interrupt global status register R32_PFIC_VTFIDR = 0xE000E050 #PFIC VTF interrupt ID configuration register R32_PFIC_VTFADDRR0 = 0xE000E060 #PFIC VTF interrupt 0 offset address register R32_PFIC_VTFADDRR1 = 0xE000E064 #PFIC VTF interrupt 1 offset address register R32_PFIC_IENR1 = 0xE000E100 #PFIC interrupt enable setting register 1 R32_PFIC_IENR2 = 0xE000E104 #PFIC interrupt enable setting register 2 R32_PFIC_IRER1 = 0xE000E180 #PFIC interrupt enable clear register 1 R32_PFIC_IRER2 = 0xE000E184 #PFIC interrupt enable clear register 2 R32_PFIC_IPSR1 = 0xE000E200 #PFIC interrupt pending setting register 1 R32_PFIC_IPSR2 = 0xE000E204 #PFIC interrupt pending setting register 2 R32_PFIC_IPRR1 = 0xE000E280 #PFIC interrupt hang clear register 1 R32_PFIC_IPRR2 = 0xE000E284 #PFIC interrupt hang clear register 2 R32_PFIC_IACTR1 = 0xE000E300 #PFIC interrupt activation status register1 R32_PFIC_IACTR2 = 0xE000E304 #PFIC interrupt activation status register2 R32_PFIC_IPRIORx = 0xE000E400 #PFIC interrupt priority configuration register R32_PFIC_SCTLR = 0xE000ED10 #PFIC system control register INTSYSCR = 0x804 #Interrupt System Control Register MTVEC = 0x305 #Exception Entry Base Address Register DBGMCU_CR = 0x7C0 #Debug MCU Configuration Register (CSR) R32_STK_CTLR = 0xE000F000 #System count control register R32_STK_SR = 0xE000F004 #System count status register R32_STK_CNTL = 0xE000F008 # System counter low register R32_STK_CMPLR = 0xE000F010 #Counting comparison low register R32_GPIOA_CFGLR = 0x40010800 #PA port configuration register low 0x44444444 R32_GPIOC_CFGLR = 0x40011000 #PC port configuration register low 0x44444444 R32_GPIOD_CFGLR = 0x40011400 #PD port configuration register low 0x44444444 R32_GPIOA_INDR = 0x40010808 #PA port input data register 0x0000XXXX R32_GPIOC_INDR = 0x40011008 #PC port input data register 0x0000XXXX R32_GPIOD_INDR = 0x40011408 #PD port input data register 0x0000XXXX R32_GPIOA_OUTDR = 0x4001080C #PA port output data register 0x00000000 R32_GPIOC_OUTDR = 0x4001100C #PC port output data register 0x00000000 R32_GPIOD_OUTDR = 0x4001140C #PD port output data register 0x00000000 R32_GPIOA_BSHR = 0x40010810 #PA port set/reset register 0x00000000 R32_GPIOC_BSHR = 0x40011010 #PC port set/reset register 0x00000000 R32_GPIOD_BSHR = 0x40011410 #PD port set/reset register 0x00000000 R32_GPIOA_BCR = 0x40010814 #PA port reset register 0x00000000 R32_GPIOC_BCR = 0x40011014 #PC port reset register R32_GPIOD_BCR = 0x40011414 #PD port reset register 0x00000000 R32_GPIOA_LCKR = 0x40010818 #PA port configuration lock register 0x00000000 R32_GPIOC_LCKR = 0x40011018 #PC port configuration lock register 0x00000000 R32_GPIOD_LCKR = 0x40011418 #PD port configuration lock register R32_AFIO_PCFR1 = 0x40010004 #AFIO Remap Register 1 R32_AFIO_EXTICR = 0x40010008 #External interrupt configuration register 1 R32_DMA_INTFR = 0x40020000 #DMA interrupt status register 0x00000000 R32_DMA_INTFCR = 0x40020004 #DMA interrupt flag clear register 0x00000000 R32_DMA_CFGR1 = 0x40020008 #DMA channel 1 configuration register 0x00000000 R32_DMA_CNTR1 = 0x4002000C #DMA channel 1 number of data register R32_DMA_PADDR1 = 0x40020010 #DMA channel 1 peripheral address register 0x00000000 R32_DMA_MADDR1 = 0x40020014 #DMA channel 1 memory address register 0x00000000 R32_DMA_CFGR2 = 0x4002001C #DMA channel 2 configuration register 0x00000000 R32_DMA_CNTR2 = 0x40020020 #DMA channel 2 number of data register 0x00000000 R32_DMA_PADDR2 = 0x40020024 #DMA channel 2 peripheral address register 0x00000000 R32_DMA_MADDR2 = 0x40020028 #DMA channel 2 memory address register 0x00000000 R32_DMA_CFGR3 = 0x40020030 #DMA channel 3 configuration register 0x00000000 R32_DMA_CNTR3 = 0x40020034 #DMA channel 3 number of data register 0x00000000 R32_DMA_PADDR3 = 0x40020038 #DMA channel 3 peripheral address register 0x00000000 R32_DMA_MADDR3 = 0x4002003C #DMA channel 3 memory address register 0x00000000 R32_DMA_CFGR4 = 0x40020044 #DMA channel 4 configuration register 0x00000000 R32_DMA_CNTR4 = 0x40020048 #DMA channel 4 number of data register 0x00000000 R32_DMA_PADDR4 = 0x4002004C #DMA channel 4 peripheral address register 0x00000000 R32_DMA_MADDR4 = 0x40020050 #DMA channel 4 memory address register 0x00000000 R32_DMA_CFGR5 = 0x40020058 #DMA channel 5 configuration register 0x00000000 R32_DMA_CNTR5 = 0x4002005C #DMA channel 5 number of data register 0x00000000 R32_DMA_PADDR5 = 0x40020060 #DMA channel 5 peripheral address register 0x00000000 R32_DMA_MADDR5 = 0x40020064 #DMA channel 5 memory address register 0x00000000 R32_DMA_CFGR6 = 0x4002006C #DMA channel 6 configuration register 0x00000000 R32_DMA_CNTR6 = 0x40020070 #DMA channel 6 number of data register 0x00000000 R32_DMA_PADDR6 = 0x40020074 #DMA channel 6 peripheral address register 0x00000000 R32_DMA_MADDR6 = 0x40020078 #DMA channel 6 memory address register 0x00000000 R32_DMA_CFGR7 = 0x40020080 #DMA channel 7 configuration register 0x00000000 R32_DMA_CNTR7 = 0x40020084 #DMA channel 7 number of data register 0x00000000 R32_DMA_PADDR7 = 0x40020088 #DMA channel 7 peripheral address register 0x00000000 R32_DMA_MADDR7 = 0x4002008C #DMA channel 7 memory address register R32_ADC_STATR = 0x40012400 #ADC status register 0x00000000 R32_ADC_CTLR1 = 0x40012404 #ADC control register 1 0x00000000 R32_ADC_CTLR2 = 0x40012408 #ADC control register 2 0x00000000 R32_ADC_SAMPTR1 = 0x4001240C #ADC sample time register 1 0x00000000 R32_ADC_SAMPTR2 = 0x40012410 #ADC sample time register 2 0x00000000 R32_ADC_IOFR1 = 0x40012414 #ADC injected channel data offset register 1 0x00000000 R32_ADC_IOFR2 = 0x40012418 #ADC injected channel data offset register 2 0x00000000 R32_ADC_IOFR3 = 0x4001241C #ADC injected channel data offset register 3 0x00000000 R32_ADC_IOFR4 = 0x40012420 #ADC injected channel data offset register 4 0x00000000 R32_ADC_WDHTR = 0x40012424 #ADC watchdog high threshold register 0x00000000 R32_ADC_WDLTR = 0x40012428 #ADC watchdog low threshold register 0x00000000 R32_ADC_RSQR1 = 0x4001242C #ADC regular sequence register 1 0x00000000 R32_ADC_RSQR2 = 0x40012430 #ADC regular sequence register 2 0x00000000 R32_ADC_RSQR3 = 0x40012434 #ADC regular sequence register 3 0x00000000 R32_ADC_ISQR = 0x40012438 #ADC injected sequence register 0x00000000 R32_ADC_IDATAR1 = 0x4001243C #ADC injected data register 1 0x00000000 R32_ADC_IDATAR2 = 0x40012440 #ADC injected data register 2 0x00000000 R32_ADC_IDATAR3 = 0x40012444 #ADC injected data register 3 0x00000000 R32_ADC_IDATAR4 = 0x40012448 #ADC injected data register 4 0x00000000 R32_ADC_RDATAR = 0x4001244C #ADC regular data register 0x00000000 R32_ADC_DLYR = 0x40012450 #ADC delayed data register R16_TIM1_CTLR1 = 0x40012C00 #Control register 1 0x0000 R16_TIM1_CTLR2 = 0x40012C04 #Control register 2 0x0000 R16_TIM1_SMCFGR = 0x40012C08 #Slave mode control register 0x0000 R16_TIM1_DMAINTENR = 0x40012C0C #DMA/interrupt enable register 0x0000 R16_TIM1_INTFR = 0x40012C10 #Interrupt status register 0x0000 R16_TIM1_SWEVGR = 0x40012C14 #Event generation register 0x0000 R16_TIM1_CHCTLR1 = 0x40012C18 #Compare/capture control register 1 0x0000 R16_TIM1_CHCTLR2 = 0x40012C1C #Compare/capture control register 2 0x0000 R16_TIM1_CCER = 0x40012C20 #Compare/capture enable register 0x0000 R16_TIM1_CNT = 0x40012C24 #Counters 0x0000 R16_TIM1_PSC = 0x40012C28 #Counting clock prescaler 0x0000 R16_TIM1_ATRLR = 0x40012C2C #Auto-reload value register 0x0000 R16_TIM1_RPTCR = 0x40012C30 #Recurring count value register 0x0000 R16_TIM1_CH1CVR = 0x40012C34 #Compare/capture register 1 0x0000 R16_TIM1_CH2CVR = 0x40012C38 #Compare/capture register 2 0x0000 R16_TIM1_CH3CVR = 0x40012C3C #Compare/capture register 3 0x0000 R16_TIM1_CH4CVR = 0x40012C40 #Compare/capture register 4 0x0000 R16_TIM1_BDTR = 0x40012C44 #Brake and deadband registers 0x0000 R16_TIM1_DMACFGR = 0x40012C48 #DMA control register 0x0000 R16_TIM1_DMAADR = 0x40012C4C #DMA address register for continuous mode R16_TIM2_BASE = 0x40000000 #TIM2 start of register cluster R16_TIM2_CTLR1 = 0x40000000 #TIM2 control register1 0x0000 R16_TIM2_CTLR2 = 0x40000004 #TIM2 control register2 0x0000 R16_TIM2_SMCFGR = 0x40000008 #TIM2 Slave mode control register 0x0000 R16_TIM2_DMAINTENR = 0x4000000C #TIM2 DMA/interrupt enable register R16_TIM2_INTFR = 0x40000010 #TIM2 interrupt status register 0x0000 R16_TIM2_SWEVGR = 0x40000014 #TIM2 event generation register 0x0000 R16_TIM2_CHCTLR1 = 0x40000018 #TIM2 compare/capture control register1 0x0000 R16_TIM2_CHCTLR2 = 0x4000001C #TIM2 compare/capture control register2 0x0000 R16_TIM2_CCER = 0x40000020 #TIM2 compare/capture enable register 0x0000 R16_TIM2_CNT = 0x40000024 #TIM2 counter 0x0000 R16_TIM2_PSC = 0x40000028 #TIM2 count clock prescaler 0x0000 R16_TIM2_ATRLR = 0x4000002C #TIM2 auto-reload register 0x0000 R32_TIM2_CH1CVR = 0x40000034 #TIM2 compare/capture register1 0x0000 R32_TIM2_CH2CVR = 0x40000038 #TIM2 compare/capture register2 0x0000 R32_TIM2_CH3CVR = 0x4000003C #TIM2 compare/capture register3 0x0000 R32_TIM2_CH4CVR = 0x40000040 #TIM2 compare/capture register4 0x0000 R16_TIM2_DMACFGR = 0x40000048 #TIM2 DMA control register 0x0000 R16_TIM2_DMAADR = 0x4000004C #TIM2 DMA address register in continuous mode R32_USART_STATR = 0x40013800 #UASRT status register 0x000000C0 R32_USART_DATAR = 0x40013804 #UASRT data register 0x000000XX R32_USART_BRR = 0x40013808 #UASRT baud rate register 0x00000000 R32_USART_CTLR1 = 0x4001380C #UASRT control register 1 0x00000000 R32_USART_CTLR2 = 0x40013810 #UASRT control register 2 0x00000000 R32_USART_CTLR3 = 0x40013814 #UASRT control register 3 0x00000000 R32_USART_GPR = 0x40013818 #UASRT protection time and prescaler register R16_I2C_CTLR1 = 0x40005400 #I2C control register 1 0x0000 R16_I2C_CTLR2 = 0x40005404 #I2C control register 2 0x0000 R16_I2C_OADDR1 = 0x40005408 #I2C address register 1 0x0000 R16_I2C_OADDR2 = 0x4000540C #I2C address register 2 0x0000 R16_I2C_DATAR = 0x40005410 #I2C data register 0x0000 R16_I2C_STAR1 = 0x40005414 #I2C status register 1 0x0000 R16_I2C_STAR2 = 0x40005418 #I2C status register 2 0x0000 R16_I2C_CKCFGR = 0x4000541C #I2C clock register R16_SPI_CTLR1 = 0x40013000 #SPI Control register1 0x0000 R16_SPI_CTLR2 = 0x40013004 #SPI Control register2 0x0000 R16_SPI_STATR = 0x40013008 #SPI Status register 0x0002 R16_SPI_DATAR = 0x4001300C #SPI Data register 0x0000 R16_SPI_CRCR = 0x40013010 #SPI Polynomial register 0x0007 R16_SPI_RCRCR = 0x40013014 #SPI Receive CRC register 0x0000 R16_SPI_TCRCR = 0x40013018 #SPI Transmit CRC register 0x0000 R16_SPI_HSCR = 0x40013024 #SPI High-speed control register R16_ESIG_FLACAP = 0x1FFFF7E0 #Flash capacity register 0xXXXX R32_ESIG_UNIID1 = 0x1FFFF7E8 #UID register 1 0xXXXXXXXX R32_ESIG_UNIID2 = 0x1FFFF7EC #UID register 2 0xXXXXXXXX R32_ESIG_UNIID3 = 0x1FFFF7F0 #UID register 3 R32_FLASH_ACTLR = 0x40022000 #Control register R32_FLASH_KEYR = 0x40022004 #FPEC key register X R32_FLASH_OBKEYR = 0x40022008 #OBKEY register X R32_FLASH_STATR = 0x4002200C #Status register 0x00008000 R32_FLASH_CTLR = 0x40022010 #Configuration register 0x00008080 R32_FLASH_ADDR = 0x40022014 #Address register X R32_FLASH_OBR = 0x4002201C #Select word register 0x03FFFFFE R32_FLASH_WPR = 0x40022020 #Write protection register 0xFFFFFFF R32_FLASH_MODEKEYR = 0x40022024 #Extended key register X R32_FLASH_BOOT_MODEKEYR = 0x40022028 #Unlock BOOT key register R32_EXTEN_CTR = 0x40023800 #Configure extended control registers PFIC_KEY1 = 0xFA050000 PFIC_KEY2 = 0xBCAF0000 PFIC_KEY3 = 0xBEEF0000
