library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx leaf cells in this code. --library UNISIM; --use UNISIM.VComponents.all; entity tb is -- Port ( ); end tb; architecture Behavioral of tb is subtype slv16 is std_logic_vector(15 downto 0); type slv16_array is array (natural range <>) of slv16; signal count : unsigned(15 downto 0) := (others => '0'); signal clk_int : std_logic := '0'; constant c_clk_del : natural := 2; signal time_stamp : slv16_array(c_clk_del downto 0) := (others => (others => '0')); signal time_stamp2 : slv16_array(c_clk_del downto 0) := (others => (others => '0')); signal time_stamp_final : std_logic_vector(15 downto 0); signal time_stamp_final2 : std_logic_vector(15 downto 0); begin process begin clk_int <= '0'; wait for 5 ns; clk_int <= '1'; wait for 5 ns; end process; process(clk_int) begin if rising_edge(clk_int) then count <= count + 1; end if; end process; -- Beispeil1: time_stamp(0) <= std_logic_vector(count); clk_del: process(clk_int) begin if rising_edge(clk_int) then if c_clk_del > 0 then for i in 1 to c_clk_del loop time_stamp(i) <= time_stamp(i-1); end loop; end if; end if; end process clk_del; time_stamp_final <= time_stamp(c_clk_del); -- Beispiel2: time_stamp2(0) <= std_logic_vector(count); clk_del2 : FOR i in 1 TO c_clk_del+1 GENERATE begin del_reg: process(clk_int) begin if rising_edge(clk_int) then time_stamp2(i) <= time_stamp2(i-1); end if; end process del_reg; end; END GENERATE clk_del2; time_stamp_final2 <= time_stamp2(c_clk_del); end Behavioral;
