module arm_test( input wire xosc, /* oscillator, system clock */ input wire ext_reset_n, /* reset, active low */ output wire [1:0] gpio, /* GPIO */ output wire test1, /* testpin */ output wire test2, /* testpin */ output wire cpuclkout, /* CPU clock output */ output wire cpureset /* synchroneous CPU reset, active high */ ) ; parameter CLKDIV_WIDTH = 8 ; /* width of CPU clock prescaler */ parameter DLYDIV_WIDTH = 4 ; /* width of reset delay clock prescaler */ parameter COUNT_LOW = 'd12 ; /* clock count-1 for low phase */ parameter COUNT_HIGH = 'd13 ; /* clock count-1 for high phase */ reg [CLKDIV_WIDTH-1:0] clkdiv_cpu ; reg [DLYDIV_WIDTH-1:0] reset_delay ; /* CPU clock count during active reset */ reg cpuclk ; reg cpuresetn_sync ; wire [15:0] gpioout ; wire [15:0] gpioouten ; wire [15:0] gpioin ; assign cpuclkout = cpuclk ; assign cpureset = ~cpuresetn_sync ; assign test1 = ext_reset_n ; assign test2 = xosc ; assign gpioin[15:0] = 16'h0000 ; assign gpio[1:0] = gpioout[1:0] ; /* ╭─────────────────────────────────────────────────────────────────────────────────────────────────╮ │ xosc clock domain │ ╰─────────────────────────────────────────────────────────────────────────────────────────────────╯ */ always @(posedge xosc or negedge ext_reset_n) begin if (~ext_reset_n) begin clkdiv_cpu <= 0 ; reset_delay <= 0 ; cpuclk <= 0 ; cpuresetn_sync <= 0 ; end else begin /* generate 1 MHz CPU clock */ if (cpuclk & (clkdiv_cpu == COUNT_HIGH)) /* clock count-1 for high phase */ begin clkdiv_cpu <= 0 ; cpuclk <= 0 ; if (reset_delay <= 'd10) begin reset_delay <= reset_delay + {{DLYDIV_WIDTH-1{1'b0}},1'b1} ; end end else if (~cpuclk & (clkdiv_cpu == COUNT_LOW)) /* clock count-1 for low phase */ begin clkdiv_cpu <= 0 ; cpuclk <= 1 ; if (reset_delay == 'd10) begin cpuresetn_sync <= 1 ; end end else begin clkdiv_cpu <= clkdiv_cpu + {{CLKDIV_WIDTH-1{1'b0}},1'b1} ; end end end /* ╭─────────────────────────────────────────────────────────────────────────────────────────────────╮ │ ARM CPU-core instantiation │ ╰─────────────────────────────────────────────────────────────────────────────────────────────────╯ */ Gowin_EMPU_Top cpu_core( .sys_clk(cpuclk), //input sys_clk .gpioin(gpioin), //input [15:0] gpioin .gpioout(gpioout), //output [15:0] gpioout .gpioouten(gpioouten), //output [15:0] gpioouten .reset_n(cpuresetn_sync) //synchronous reset_n // .reset_n(ext_reset_n) //input reset_n ); endmodule
