#include const int CS_PIN = 10; void setup() { Serial.begin(115200); pinMode(CS_PIN, OUTPUT); digitalWrite(CS_PIN, HIGH); SPI.begin(6, 2, 7, 10); // SCK, MISO, MOSI SPI.beginTransaction(SPISettings(6000000, MSBFIRST, SPI_MODE0)); //6 MHz delay(10); //Soft-Reset //writeRegister(0x2A, 0b00000010); writeRegister(0x2A, 0x52); //Seite 69 uint8_t softReset = readRegister(0x2A); Serial.print("Soft-Reset:\t0x"); Serial.print(softReset, HEX); Serial.print("\t0b"); Serial.println(softReset, BIN); delay(10); //NVM Control //writeRegister(0x29, 0b11000000); //delay(10); //Modus-Wahl writeRegister(0x26, 0b00000000); //Standby-Mode uint8_t mode1 = readRegister(0x26); Serial.print("Mode_1:\t\t0x"); Serial.print(mode1, HEX); Serial.print("\t0b"); Serial.println(mode1, BIN); writeRegister(0x27, 0b11100000); //0x27 = DIGITAL ENABLE Reg uint8_t dig_En = readRegister(0x27); Serial.print("Dig_En:\t\t0x"); Serial.print(dig_En, HEX); Serial.print("\t0b"); Serial.println(dig_En, BIN); writeRegister(0x26, 0b00001100); //0x26 = OP_Mode-Reg. uint8_t mode2 = readRegister(0x26); Serial.print("Mode_2:\t\t0x"); Serial.print(mode2, HEX); Serial.print("\t0b"); Serial.println(mode2, BIN); //Status uint8_t status0 = readRegister(0x11); uint8_t status1 = readRegister(0x12); uint8_t status2 = readRegister(0x13); uint8_t status3 = readRegister(0x14); //Status Serial.print("Status0:\t0x"); Serial.print(status0, HEX); Serial.print("\t0b"); Serial.println(status0, BIN); Serial.print("Status1:\t0x"); Serial.print(status1, HEX); Serial.print("\t0b"); Serial.println(status1, BIN); Serial.print("Status2:\t0x"); Serial.print(status2, HEX); Serial.print("\t0b"); Serial.println(status2, BIN); Serial.print("Status3:\t0x"); Serial.print(status3, HEX); Serial.print("\t0b"); Serial.println(status3, BIN); } void loop() { //x-Achse lesen uint8_t ID1 = readRegister(0x00); uint8_t ID2 = readRegister(0x01); uint8_t ID3 = readRegister(0x02); uint8_t ID4 = readRegister(0x03); uint8_t xH_Data = readRegister(0x15); uint8_t xL_Data = readRegister(0x16); uint8_t yH_Data = readRegister(0x17); uint8_t yL_Data = readRegister(0x18); uint8_t zH_Data = readRegister(0x19); uint8_t zL_Data = readRegister(0x1A); //ID lesen Serial.print("ID1: "); Serial.println(ID1,HEX); Serial.print("ID2: "); Serial.println(ID2,HEX); Serial.print("ID3: "); Serial.println(ID3,HEX); Serial.print("ID4: "); Serial.println(ID4,HEX); //x-Achse Serial.print("xL_Data: "); Serial.println(xL_Data); Serial.print("xH_Data: "); Serial.println(xH_Data); //y-Achse Serial.print("yL_Data: "); Serial.println(yL_Data); Serial.print("yH_Data: "); Serial.println(yH_Data); //z-Achse Serial.print("zL_Data: "); Serial.println(zL_Data); Serial.print("zH_Data: "); Serial.println(zH_Data); delay(400); } //Register write void writeRegister(uint8_t registerAddress, uint8_t value) { //uint16_t command = ((registerAddress << 9) | value); // R/W-Bit = 0 uint16_t command = (((uint16_t)registerAddress << 9) | value); digitalWrite(CS_PIN, LOW); SPI.transfer16(command); digitalWrite(CS_PIN, HIGH); } //Register read uint8_t readRegister(uint8_t registerAddress){ digitalWrite(CS_PIN, LOW); //uint16_t data = SPI.transfer16((registerAddress << 9) | (0x01<<8)); int8_t data = SPI.transfer16((registerAddress<<9) | (0x01<<8)); digitalWrite(CS_PIN, HIGH); return data; }
