#include const int CS_PIN = 10; void setup() { Serial.begin(115200); pinMode(CS_PIN, OUTPUT); digitalWrite(CS_PIN, HIGH); SPI.begin(); // SCK = 13, MISO = 12, MOSI = 11 SPI.beginTransaction(SPISettings(5000000, MSBFIRST, SPI_MODE3)); //1 MHz //Device ID lesen (soll 0xE5 sein) uint8_t deviceID = readRegister(0x00); Serial.print("Device ID: 0x"); Serial.println(deviceID, HEX); delay(100); writeRegister(0x31, 0x01); //DATA-Format writeRegister(0x2D, 0x08); // Measurement Mode writeRegister(0x2C, 0x0C); // 400 Hz ODR writeRegister(0x38, 0x00); // FIFO aus } void loop() { // X-, Y-, Z-Daten lesen uint8_t x0 = readRegister(0x32); uint8_t x1 = readRegister(0x33); uint8_t y0 = readRegister(0x34); uint8_t y1 = readRegister(0x35); uint8_t z0 = readRegister(0x36); uint8_t z1 = readRegister(0x37); int16_t x = (x1 << 8) | x0; int16_t y = (y1 << 8) | y0; int16_t z = (z1 << 8) | z0; Serial.print("X = "); Serial.print(x); Serial.print("\t| Y = "); Serial.print(y); Serial.print("\t| Z = "); Serial.println(z); delay(100); } //Register write void writeRegister(uint8_t registerAddress, uint8_t value) { //Erstes Byte = Read/Write (Bit 15) + mehrere Bytes (Bit 14) + Adresse (Bit 13-8) + Daten (Bit 7 - 0) uint8_t address = (registerAddress & 0x3F); // Bit 15=0 (Write), Bit 14=0 (Einzelbyte) uint16_t command = ((address << 8) | value); digitalWrite(CS_PIN, LOW); SPI.transfer16(command); digitalWrite(CS_PIN, HIGH); } //Register read uint16_t readRegister(uint8_t registerAddress){ //Erstes Byte = Read/Write (Bit 15) + mehrere Bytes (Bit 14) + Adresse (Bit 13-8) + Daten (Bit 7 - 0) uint8_t address = ((registerAddress & 0x3F) | 0x80); // Bit 15=1 (Read), Bit 14=0 (Einzelbyte) digitalWrite(CS_PIN, LOW); int16_t data = SPI.transfer16((address<<8)); digitalWrite(CS_PIN, HIGH); return data; }
