! Copyright (C) 2014 Mark Green and contributors. ! See http://factorcode.org/license.txt for BSD license. USING: accessors arrays assocs bitstreams byte-arrays fr8x-data-format-syntax fry io io.directories io.encodings.binary io.files kernel math math.parser sequences sequences.deep strings xml xml.traversal locals ; FROM: io => read ; FROM: assocs => change-at ; RENAME: read bitstreams => bsread IN: fr8x-data TUPLE: chunkinfo { name string } { size integer } { count integer } { offset integer } ; ERROR: loading-error desc ; ! Reads preamble part of a set file : read-header ( -- bin ) "\x8d" read-until [ "Missing end of preamble marker" loading-error ] unless ; ! Skips over bytes at the start of a setfile ! Note: although this seems to be "junk", the FR8X will reject files if it is changed : chop-junk ( bin -- slice ) CHAR: < over index [ tail-slice ] [ "Missing XML document in preamble" loading-error ] if* ; : get-chunk-tags ( head -- vector ) children>> second children-tags ; : get-int-attr ( attrs name -- int ) swap at* [ "Missing expected attribute in XML preamble" loading-error ] unless string>number ; : parse-chunk-tag ( tag -- chunkspec ) [ name>> main>> ] [ attrs>> ] bi "size" "number" "offset" [ get-int-attr ] tri-curry@ tri chunkinfo boa ; : parse-chunk-tags ( vector -- chunks ) [ parse-chunk-tag ] map ; : parse-header ( -- chunks ) read-header chop-junk bytes>xml get-chunk-tags parse-chunk-tags ; : load-chunk ( chunkinfo offset -- chunkdata ) swap [ offset>> + seek-absolute seek-input ] keep [ name>> ] [ count>> ] [ size>> ] tri '[ _ read ] replicate 2array ; : load-chunks ( chunkinfos -- chunkdatas ) tell-input 1 - [ load-chunk ] curry map ; ! File format specs - these are based on the FR7X specs ! Defines scData, pack-scData, unpack-scData ROLAND-CHUNK-FORMAT: scData creator ascii 4 7 type ascii 4 7 ver ascii 4 7 num ascii 4 7 name ascii 8 7 reverb-character integer 7 reverb-prelpf integer 7 reverb-time integer 7 reverb-delay integer 7 reverb-predelay integer 7 reverb-level integer 7 reverb-selected integer 7 chorus-prelpf integer 7 chorus-feedback integer 7 chorus-delay integer 7 chorus-rate integer 7 chorus-depth integer 7 chorus-sendrev integer 7 chorus-senddelay integer 7 chorus-level integer 7 chorus-selected integer 7 delay-prelpf integer 7 delay-time-center integer 7 delay-time-ratio-left integer 7 delay-time-ratio-right integer 7 delay-level-center integer 7 delay-level-left integer 7 delay-level-right integer 7 delay-feedback integer 7 delay-send-reverb integer 7 delay-level integer 7 delay-selected integer 7 master-bar-recall integer 7 index-icon integer 7 bassoon integer 7 edited integer 7 dummy integer 15 unknown intlist 89 7 ; ! Defines: trData, pack-trData, unpack-trData ROLAND-CHUNK-FORMAT: trData register-name ascii 8 7 voice-timbre-cc00 intlist 10 7 voice-timbre-cc32 intlist 10 7 voice-timbre-pc intlist 10 7 voice-on-off intlist 10 7 voice-cassotto intlist 10 7 voice-volume intlist 10 7 orchestral-mode integer 7 orchestral-tone-num integer 7 musette-detune integer 7 reverb-send integer 7 chorus-send integer 7 delay-send integer 7 bellow-pitch-detune integer 7 octave integer 7 valve-noise-on-off integer 7 valve-noise-volume integer 7 valve-noise-cc00 integer 7 valve-noise-cc32 integer 7 valve-noise-pc integer 7 link-bass integer 7 link-orch-bass integer 7 link-orch-chord-freebass integer 7 aftertouch-pitch-down integer 7 note-tx-filter integer 7 note-on-velocity integer 7 midi-octave integer 7 midi-cc0 integer 12 midi-cc32 integer 12 midi-pc integer 12 midi-aftertouch integer 12 midi-volume integer 12 midi-panpot integer 12 midi-reverb integer 12 midi-chorus integer 12 edited integer 7 unknown intlist 244 7 ; ! Defines orData, pack-orData, unpack-orData ROLAND-CHUNK-FORMAT: orData custom-name ascii 12 7 patch-cc00 integer 7 patch-cc32 integer 7 patch-pc integer 7 patch-1-cc00 integer 7 patch-1-cc32 integer 7 patch-1-pc integer 7 patch-1-volume integer 7 patch-1-octave integer 7 dynamic-mode integer 7 reg-edited integer 7 vtw-preset-ref integer 7 vtw-preset-edited integer 7 unknown intlist 74 7 overhang integer 2 ; ! Defines obrData, pack-obrData, unpack-obrData ROLAND-CHUNK-FORMAT: obrData custom-name ascii 12 7 patch-cc00 integer 7 patch-cc32 integer 7 patch-pc integer 7 dynamic-mode integer 7 reg-edited integer 7 vtw-preset-ref integer 7 vtw-preset-edited integer 7 unknown intlist 56 7 overhang integer 3 ; ! Defines obcrfData, pack-obcrfData, unpack-obcrfData ! These seem to work for OBC_R and OBF_R although unknowns may be different ROLAND-CHUNK-FORMAT: obcrfData custom-name ascii 12 7 patch-cc00 integer 7 patch-cc32 integer 7 patch-pc integer 7 dynamic-mode integer 7 reg-edited integer 7 vtw-preset-ref integer 7 vtw-preset-edited integer 7 unknown intlist 63 7 overhang integer 2 ; ! Defines brData, pack-brData, unpack-brData ROLAND-CHUNK-FORMAT: brData register-name ascii 13 7 voice-timbre-cc00 intlist 10 7 voice-timbre-cc32 intlist 10 7 voice-timbre-pc intlist 10 7 voice-on-off intlist 10 7 voice-volume intlist 10 7 keyrange-16 integer 7 keyrange-8 integer 7 active-bass-state integer 7 note-tx-filter integer 7 note-on-velocity integer 7 midi-octave integer 7 drumkit-note-number intlist 3 12 drumkit-note-volume intlist 3 12 midi-cc00 integer 12 midi-cc32 integer 12 midi-pc integer 12 midi-volume integer 12 midi-panpot integer 12 midi-reverb integer 12 midi-chorus integer 12 midi-bellow integer 7 edited integer 1 unknown intlist 3 7 overhang integer 4 ; ! Defines bcrData, pack-bcrData, unpack-bcrData ROLAND-CHUNK-FORMAT: bcrData register-name ascii 13 7 voice-timbre-cc00 intlist 10 7 voice-timbre-cc32 intlist 10 7 voice-timbre-pc intlist 10 7 voice-on-off intlist 10 7 voice-volume intlist 10 7 drumkit-note-number intlist 3 12 drumkit-note-volume intlist 3 12 reverb-send integer 7 chorus-send integer 7 delay-send integer 7 bellow-pitch-detune integer 7 growl-on-off integer 7 growl-volume integer 7 growl-16-cc00 integer 7 growl-16-cc32 integer 7 growl-16-pc integer 7 growl-84-cc00 integer 7 growl-84-cc32 integer 7 growl-84-pc integer 7 bnoise-on-off integer 7 bnoise-volume integer 7 bnoise-cc00 integer 7 bnoise-cc32 integer 7 bnoise-pc integer 7 note-tx-filter integer 7 note-on-velocity integer 7 midi-octave integer 7 midi-cc00 integer 12 midi-cc32 integer 12 midi-pc integer 12 midi-volume integer 12 midi-panpot integer 12 midi-reverb integer 12 midi-chorus integer 12 midi-bellow integer 7 edited integer 7 midi-drum-tx integer 1 dummy-edited integer 5 dummy integer 7 overhang integer 4 ; ! Encode or decode all known chunks and replace content of setfile dictionary with decoded version ! DO NOT PUT ANY PACKS/UNPACKERS IN HERE IF THEY DO NOT PAST CHUNK-SYMMETRY-TEST ! AND CHECK FILE-SYMMETRY-TEST IS PASSED BEFORE COMMIT !! : decode-known-chunks ( chunks -- chunks ) "TR" over [ [ unpack-trData ] map ] change-at "SC" over [ first unpack-scData ] change-at "O_R" over [ [ unpack-orData ] map ] change-at "OB_R" over [ [ unpack-obrData ] map ] change-at "OBC_R" over [ [ unpack-obcrfData ] map ] change-at "OFB_R" over [ [ unpack-obcrfData ] map ] change-at "BR" over [ [ unpack-brData ] map ] change-at "BCR" over [ [ unpack-bcrData ] map ] change-at ; : encode-known-chunks ( chunks -- chunks ) "TR" over [ [ pack-trData ] map ] change-at "SC" over [ pack-scData { } swap suffix ] change-at "O_R" over [ [ pack-orData ] map ] change-at "OB_R" over [ [ pack-obrData ] map ] change-at "OBC_R" over [ [ pack-obcrfData ] map ] change-at "OFB_R" over [ [ pack-obcrfData ] map ] change-at "BR" over [ [ pack-brData ] map ] change-at "BCR" over [ [ pack-bcrData ] map ] change-at ; : parse-set-file ( -- data ) parse-header load-chunks decode-known-chunks ; : load-set-file ( fn -- data ) binary [ parse-set-file ] with-file-reader ; : get-chunk ( alist id -- chunk ) swap at* [ "Missing chunk type" loading-error ] unless ; : write-chunks ( chunks -- ) encode-known-chunks values flatten >byte-array write flush ; : save-set-file ( data fn -- ) "vocab:fr8x-data/standard.preamble" over copy-file binary [ write-chunks ] with-file-appender ; ! Name of any set file to use for testing purposes ! Recommended to use one of the exported FR8X system files - ! these are not included due to potential Roland copyright ! If you can't get one, try the Dallape sets from the Yahoo group CONSTANT: test-file-name "FR-8X_SET_012.ST8" ! For quickly loading the test file for testing at the console : load-test-file ( -- head ) test-file-name load-set-file ;
