! Copyright (C) 2014 Mark Green. ! See http://factorcode.org/license.txt for BSD license. USING: arrays byte-arrays classes.parser classes.tuple combinators fry grouping io.encodings.ascii io.encodings.string kernel lexer locals make math math.bits parser sequences words ; IN: fr8x-data-format-syntax RENAME: read bitstreams => bsread : packbits ( bitseq value width -- bitseq ) reverse append ; : packlist ( bitseq list width -- bitseq ) swapd '[ _ packbits ] reduce ; : packstring ( bitseq string width -- bitseq ) [ ascii encode ] dip packlist ; : padbitseq ( bitseq -- bitseq ) dup length 8 mod [ 8 swap - f append ] unless-zero ; : dumpbitseq ( bitseq -- ints ) padbitseq 8 group [ reverse bits>number ] map >byte-array ; ! Huge thanks to John Benediktsson for the metaprogramming code below : bsread-list ( bitreader count width -- list ) rot '[ _ _ bsread ] replicate ; : bsread-string ( bitreader count width -- string ) bsread-list ascii decode ; SYNTAX: ROLAND-CHUNK-FORMAT: scan-token [ "unpack-" prepend create-word-in ] [ "pack-" prepend create-word-in ] [ create-class-in ] tri [ [ scan-token dup ";" = ] [ scan-token { { "ascii" [ scan-number scan-number [ '[ _ _ bsread-string ] ] [ '[ _ packstring ] ] bi ] } { "integer" [ scan-number [ '[ _ swap bsread ] ] [ '[ _ packbits ] ] bi ] } { "intlist" [ scan-number scan-number [ '[ _ _ bsread-list ] ] [ '[ _ packlist ] ] bi ] } } case 3array , ] until drop ] { } make [ tuple swap [ first ] map define-tuple-class ] [ [ third ] map swap drop '[ tuple-slots _ [ curry ] 2map { } swap [ call( oldbits -- newbits ) ] each dumpbitseq ] ( tuple -- bits ) define-declared ] [ [ second ] map swap '[ _ cleave _ boa ] ( bitreader -- object ) define-declared ] 2tri ;
