/* * ATmega8A Pin Cycling Test * Version 2: Array in RAM * * Cycles through PB0–PB5, PC0–PC5, PD0–PD7. * Every 200 ms: one pin is driven low, then returned to input with pull-up, * then the next pin is selected. * * Same as version 1, but lookup table loaded to RAM on startup. */ #include #include #include #include #ifndef F_CPU # define F_CPU 1E6 #endif #include typedef struct { volatile uint8_t *ddrAddr; volatile uint8_t *portAddr; uint8_t mask; } PinDesc; // --- Array of test pins in flash (PROGMEM) --- // Use addresses cast to uint16_t PinDesc testPins[] = { { &DDRB, &PORTB, _BV(PB0) }, { &DDRB, &PORTB, _BV(PB1) }, { &DDRB, &PORTB, _BV(PB2) }, { &DDRB, &PORTB, _BV(PB3) }, { &DDRB, &PORTB, _BV(PB4) }, { &DDRB, &PORTB, _BV(PB5) }, { &DDRC, &PORTC, _BV(PC0) }, { &DDRC, &PORTC, _BV(PC1) }, { &DDRC, &PORTC, _BV(PC2) }, { &DDRC, &PORTC, _BV(PC3) }, { &DDRC, &PORTC, _BV(PC4) }, { &DDRC, &PORTC, _BV(PC5) }, { &DDRD, &PORTD, _BV(PD0) }, { &DDRD, &PORTD, _BV(PD1) }, { &DDRD, &PORTD, _BV(PD2) }, { &DDRD, &PORTD, _BV(PD3) }, { &DDRD, &PORTD, _BV(PD4) }, { &DDRD, &PORTD, _BV(PD5) }, { &DDRD, &PORTD, _BV(PD6) }, { &DDRD, &PORTD, _BV(PD7) } }; #define NUM_PINS (sizeof(testPins)/sizeof(testPins[0])) // --- Timer1 Compare ISR --- ISR(TIMER1_COMPA_vect) { static PinDesc *pd = testPins; static uint8_t toggleState; PORTB ^= _BV(PB0); // toggle PB0 to signal ISR run // Get current pin description from RAM volatile uint8_t *ddr = pd->ddrAddr; volatile uint8_t *port = pd->portAddr; uint8_t mask = pd->mask; if (toggleState == 0) { // --- Switch current pin to OUTPUT, drive low --- *ddr |= mask; // set DDRx bit = 1 → output *port &= ~mask; // clear PORTx bit = 0 → low toggleState = 1; } else { // --- Switch current pin back to INPUT, pull-up on --- *ddr &= ~mask; // clear DDRx bit = 0 → input *port |= mask; // set PORTx bit = 1 → pull-up enabled // advance to next pin pd++; if (pd >= testPins + NUM_PINS) pd = testPins; toggleState = 0; } } static void pins_init(void) { DDRB = 0x00; DDRC = 0x00; DDRD = 0x00; PORTB = 0xFF; PORTC = 0xFF; PORTD = 0xFF; DDRB |= _BV(PB0); // PB0 as output PORTB &= ~_BV(PB0); } static void timer1_init(void) { //TCCR1A = 0; TCCR1B = (1 << WGM12) | (1 << CS12); // CTC, prescaler 256 //TCNT1 = 0; OCR1A = 12500 - 1; TIMSK |= (1 << OCIE1A); } int main(void) { pins_init(); timer1_init(); sei(); set_sleep_mode(SLEEP_MODE_IDLE); for (;;) sleep_mode(); }
