ROM VER: 2.1.0 CFG 09 B . . . * ROM VER: 2.1.0 CFG 09 B . . . * * * * Detected PXB4583el V1.2-2000 .[piglet] Suceeded (AVM) EVA Revision: 1.3578 (C) Copyright 2005 AVM Date: Nov 27 2018 Time: 13:38:30 (0) 3 0x0-0x46409 [NAND:] 512MB TOSHIBA 4096 Pagesize 256k Blocksize 2048 Blocks HW [SYSTEM:] GRX5 (ID 0x24 Revision 2) on 1000MHz/600MHz/666MHz .. Eva_AVM >#Loading compressed kernel to 0x85284A30 ..................................................................................................................................................Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 ------------------------------------------- Switching to Bootcore Console ------------------------------------------- [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000000c00059638b ases 0x00000001 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 00019074 (MIPS 4KEc) [ 0.000000][ T0] MIPS: machine is GRX550 ANYWAN BOOTCORE (MIPS 4Kec) [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 02000000 @ 0e000000 (usable) [ 0.000000][ T0] memory: 00001be8 @ 0e7bc030 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 0dfc0000 (reserved) [ 0.000000][ T0] Initial ramdisk at: 0x8e000000 (4194304 bytes) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000000c0005d638b icache.flags 0x00000000 dcache.flags 0x00000004 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 16 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 16 bytes [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000000c0005d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] Normal [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] On node 0 totalpages: 8192 [ 0.000000][ T0] free_area_init_node: node 0, pgdat 8e7bb1c4, node_mem_map 8f005a00 [ 0.000000][ T0] Normal zone: 64 pages used for memmap [ 0.000000][ T0] Normal zone: 0 pages reserved [ 0.000000][ T0] Normal zone: 8192 pages, LIFO batch:0 [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000][ T0] pcpu-alloc: [0] 0 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200n8r root=/dev/ram rw loglevel=8 [ 0.000000][ T0] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Memory: 23752K/32768K available (2931K kernel code, 461K rwdata, 680K rodata, 208K init, 262K bss, 9016K reserved, 0K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] grx500_bootcore_register_static_irq: irq_in = 0x0000001f, irq_out = 0x0000001f [ 0.000000][ T0] grx500_bootcore_register_static_irq: mapper_reg = 0x0000015c, mapper_offset = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: int_line = 0x0000001f, map_address = 0x0000015c, num = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x0000001f [ 0.000000][ T0] CPU Clock: 300MHz [ 0.000000][ T0] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns [ 0.000019][ T0] sched_clock: 32 bits at 150MHz, resolution 6ns, wraps every 14316557820ns [ 0.016983][ T0] : grx500_bootcore_console_init: call register [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.041328][ T0] bootconsole [early0] disabled [ 0.041328][ T0] bootconsole [early0] disabled [ 0.054934][ T0] bootconsole [early0] disabled [ 0.054934][ T0] bootconsole [early0] disabled [ 0.064284][ T0] Calibrating delay loop... 299.26 BogoMIPS (lpj=598528) [ 0.107047][ T0] pid_max: default: 32768 minimum: 301 [ 0.113279][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.120435][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.134910][ T1] Performance counters: No available PMU. [ 0.143943][ T1] devtmpfs: initialized [ 0.153240][ T1] ngi: Protecting Bootcore: [0x2e000000, 0x2fffffff] [ 0.159647][ T1] ngi: 512MB attached. Protecting: [0x40000000, 0x9fffffff] [ 0.166661][ T1] ngi: Unattached: [0x60000000, 0x9fffffff] [ 0.172362][ T1] ngi: Unattached: [0x40000000, 0x5fffffff] [ 0.178788][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.189121][ T1] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.196225][ T1] pinctrl core: initialized pinctrl subsystem [ 0.204928][ T1] NET: Registered protocol family 16 [ 0.227426][ T1] irq: no irq domain found for /interrupt-controller@0x14900140 ! [ 0.328116][ T1] clocksource: Switched to clocksource MIPS [ 0.356627][ T1] NET: Registered protocol family 2 [ 0.362158][ T1] IP idents hash table entries: 2048 (order: 2, 16384 bytes) [ 0.371266][ T1] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.378955][ T1] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.385887][ T1] TCP: Hash tables configured (established 1024 bind 1024) [ 0.393434][ T1] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.399932][ T1] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.407363][ T1] NET: Registered protocol family 1 [ 0.416887][ T1] Unpacking initramfs... [ 1.157677][ T1] Freeing initrd memory: 4096K [ 1.164938][ T1] No memory allocated for crashlog [ 1.178295][ T1] workingset: timestamp_bits=30 max_order=13 bucket_order=0 [ 1.259582][ T1] Serial: grx500_bootcore driver init [ 1.273628][ T1] NET: Registered protocol family 10 [ 1.291608][ T1] NET: Registered protocol family 17 [ 1.304930][ T1] Serial: grx500_bootcore driver startup [ 1.310374][ T1] grx500_bootcore_register_static_irq: irq_in = 0x0000001c, irq_out = 0x00000008 [ 1.319157][ T1] grx500_bootcore_register_static_irq: mapper_reg = 0x00000158, mapper_offset = 0x00000003 [ 1.328914][ T1] EXCEP_remap_line: int_line = 0x00000008, map_address = 0x00000158, num = 0x00000003 [ 1.338330][ T1] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x00040000 [ 1.351264][ T1] Freeing unused kernel memory: 208K [ 1.356311][ T1] This architecture does not have kernel memory protection. [ 1.593428][ T194] eip123_hw: module license 'Proprietary' taints kernel. [ 1.600297][ T194] Disabling lock debugging due to kernel taint [ 1.611523][ T194] eip123: no symbol version for eip123_hw_asset_derive [ 1.620012][ T194] eip123 1e000000.eip123: Detected hardware version 2.2.2 [ 1.626958][ T194] eip123 1e000000.eip123: my_id=0 master_id=0 num_mailboxes=4 mailbox_size=256 [ 1.635544][ T194] eip123 1e000000.eip123: Configured mailbox lockout: 0x00000000 [ 1.643059][ T194] eip123 1e000000.eip123: Linked mailbox number 1 [ 1.676183][ T194] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=0 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0 [ 1.912120][ T194] eip123 1e000000.eip123: eip123_hw init successful [ 1.972146][ T194] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c [ 1.981248][ T194] eip123 1e000000.eip123: Could not find rootkey in OTP [ 2.016379][ T197] random: crng init done [ 2.021308][ T109] shm-rng-seed shm-rng-seed@3dfb0000: Added 4088 random bytes to the shared memory area [ 3.794172][ T261] eip123 1e000000.eip123: Unlinked mailboxes [ 3.811446][ T180] interaptiv_start: starting interaptiv ź ------------------------------------------- Switching to Interaptiv Console ------------------------------------------- .. Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 [ 0.000000][ T0] shm-rng-seed-mem@3dfb0000: Added 4088 random bytes to the system pool [ 0.000000][ T0] OF: fdt:[0x35ea0000, 0x37163b70) is not contained in the RAM region at [0x20000000, 0x2e000000) [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e69638b ases 0x00000030 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.000000][ T0] Enhanced Virtual Addressing (EVA Legacy 512MB) activated [ 0.000000][ T0] MIPS: machine is AVM7590 (GRX550, HW226) Main model [ 0.000000][ T0] Coherence Manager IOCU detected [ 0.000000][ T0] Hardware DMA cache coherency disabled [ 0.000000][ T0] OF: reserved mem: initialized node shm-rng-seed-mem@3dfb0000, compatible id avm,shm-rng-seed-early [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'urlader': base 0x20010000, size 0x00030000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'VMB': base 0x20000000, size 0x00001000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'avm_reboot_string': base 0x20001000, size 0x00000200 [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 10000000 @ 30000000 (usable) [ 0.000000][ T0] memory: 0e000000 @ 20000000 (usable) [ 0.000000][ T0] memory: 0000cf68 @ 36aca038 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 2dfc0000 (reserved) [ 0.000000][ T0] memory: 00400000 @ 20100000 (reserved) [ 0.000000][ T0] memory: 00030000 @ 20010000 (reserved) [ 0.000000][ T0] memory: 00001200 @ 20000000 (reserved) [ 0.000000][ T0] Kernel relocated by 0x159a0000 [ 0.000000][ T0] .text @ 0x95ea0000 [ 0.000000][ T0] .data @ 0x96762874 [ 0.000000][ T0] .bss @ 0x96cb0000 [ 0.000000][ T0] Initrd not found or empty - disabling initrd [ 0.000000][ T0] cma: Reserved 64 MiB at 0x24000000 [ 0.000000][ T0] SMPCMP: initialized the EVA stub code: 400@0x28029480 [ 0.000000][ T0] SMPCMP: CPU0: cmp_smp_setup [ 0.000000][ T0] VPE topology {2,2} total 4 [ 0.000000][ T0] Detected 3 available secondary CPU(s) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.000000][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] DMA [mem 0x0000000020000000-0x0000000027ffffff] [ 0.000000][ T0] Normal [mem 0x0000000028000000-0x000000003fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x0000000020000000-0x000000002dffffff] [ 0.000000][ T0] node 0: [mem 0x0000000030000000-0x000000003fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x0000000020000000-0x000000003fffffff] [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] [module-mem] Use 0x3270a000-0x33256fff (mapped at 9270a000-93256fff) for 95 modules [ 0.000000][ T0] percpu: Embedded 12 pages/cpu s18288 r8192 d22672 u49152 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121728 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200 pcmlink.abmode=0x8103 Piglet_noemif.piglet_dectmode=0x110 Piglet_noemif.piglet_bitfile=bitfile.bit audit=1 slub_debug=fl [ 0.000000][ T0] audit: enabled (after initialization) [ 0.000000][ T0] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000][ T0] Writing ErrCtl register=00000000 [ 0.000000][ T0] Readback ErrCtl register=00000000 [ 0.000000][ T0] Memory: 385240K/491520K available (8745K kernel code, 1849K rwdata, 1892K rodata, 1688K init, 4814K bss, 40744K reserved, 65536K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000][ T0] Hierarchical RCU implementation. [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] EIC is off [ 0.000000][ T0] VINT is on [ 0.000000][ T0] CPU Clock: 1000000000Hz mips_hpt_frequency 500000000Hz [ 0.000000][ T0] clocksource: gptc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302233 ns [ 0.010151][ T0] Calibrating delay loop... 718.84 BogoMIPS (lpj=1437696) [ 0.046806][ T0] pid_max: default: 32768 minimum: 301 [ 0.052301][ T0] Security Framework initialized [ 0.057083][ T0] AppArmor: AppArmor initialized [ 0.061975][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.069294][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.078848][ T1] CCA is coherent, multi-core is fine [ 0.084512][ T1] avm_register_cpuid: cpu_id=0: LINUX core=0 tc=0 [ 0.090749][ T1] Performance counters: mips/interAptiv PMU enabled, 2 32-bit counters available to each CPU, irq 9 GOT IPI to launch from CPU 1 GOT IPI to launch from CPU 2 GOT IPI to launch from CPU 3 [ 0.109276][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.109320][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.109325][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.109344][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.109351][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.109356][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.109367][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.109371][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.109571][ T0] CPU1 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.139600][ T0] avm_register_cpuid: cpu_id=1: LINUX core=0 tc=1 [ 0.142046][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.142084][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.142088][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.142107][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.142114][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.142119][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.142130][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.142134][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.142273][ T0] CPU2 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.169877][ T0] avm_register_cpuid: cpu_id=2: LINUX core=1 tc=0 [ 0.172357][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.172393][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.172397][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.172415][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.172421][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.172425][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.172436][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.172440][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.172576][ T0] CPU3 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.200182][ T0] avm_register_cpuid: cpu_id=3: LINUX core=1 tc=1 [ 0.200454][ T1] Brought up 4 CPUs [ 0.470631][ T1] avm_yield_setup: YIELD_PCMFRAME_ID : id=0x0004000f: cpu=0 tc=4 prio=3 signal=15 [ 0.480260][ T1] avm_yield_setup: YIELD_PCMLINK_ID : id=0x0003000c: cpu=0 tc=3 prio=2 signal=12 [ 0.489894][ T1] avm_yield_setup: YIELD_MONITOR_IPI0_ID : id=0x0002000e: cpu=0 tc=2 prio=1 signal=14 [ 0.499530][ T1] avm_yield_setup: YIELD_PROFILE_IPI0_ID : id=0x0002000d: cpu=0 tc=2 prio=1 signal=13 [ 0.509166][ T1] avm_yield_setup: YIELD_GPTC_ID : id=0x0005000b: cpu=0 tc=5 prio=3 signal=11 [ 0.519333][ T3] [0][yield_context_init] cpu=0 tc=2 mask=6000 tc_prio=1 [ 0.526478][ T29] [0][yield_context_init] cpu=0 tc=3 mask=1000 tc_prio=2 [ 0.533641][ T29] [0][yield_context_init] cpu=0 tc=4 mask=8000 tc_prio=3 [ 0.540749][ T29] [0][yield_context_init] cpu=0 tc=5 mask=0800 tc_prio=3 [ 0.547762][ T1] avm_yield_setup: YIELD_MONITOR_IPI1_ID : id=0x0202000e: cpu=2 tc=2 prio=1 signal=14 [ 0.557207][ T1] avm_yield_setup: YIELD_PROFILE_IPI1_ID : id=0x0202000d: cpu=2 tc=2 prio=1 signal=13 [ 0.567248][ T21] [2][yield_context_init] cpu=2 tc=2 mask=6000 tc_prio=1 [ 0.575157][ T1] devtmpfs: initialized [ 0.594440][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.604965][ T1] futex hash table entries: 1024 (order: 3, 32768 bytes) [ 0.616631][ T1] pinctrl core: initialized pinctrl subsystem [ 0.624085][ T1] NET: Registered protocol family 16 [ 0.633713][ T1] dma-grx500 1e300000.dma: dma3 base address be300000 chained_irq 29 irq_base 30 [ 0.645588][ T1] dma-grx500 1e300000.dma: Init done - rev: a, ports: 1, channels: 64 [ 0.656056][ T1] dma-grx500 1c100000.dma: dma2tx base address bc100000 chained_irq 100 irq_base 101 [ 0.666917][ T1] dma-grx500 1c100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.675397][ T1] dma-grx500 1c200000.dma: dma2rx base address bc200000 chained_irq 117 irq_base 118 [ 0.686741][ T1] dma-grx500 1c200000.dma: Init done - rev: a, ports: 1, channels: 32 [ 0.695777][ T1] dma-grx500 1a100000.dma: dma1tx base address ba100000 chained_irq 150 irq_base 151 [ 0.706687][ T1] dma-grx500 1a100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.715212][ T1] dma-grx500 1a200000.dma: dma1rx base address ba200000 chained_irq 167 irq_base 168 [ 0.725920][ T1] dma-grx500 1a200000.dma: Init done - rev: a, ports: 1, channels: 12 [ 0.741513][ T1] dma0-grx500 16e00000.dma: base address b6e00000 chained_irq 218 irq_base 219 [ 0.750196][ T1] dma0-grx500 16e00000.dma: Init done - hw rev: A, ports: 4, channels: 16 [ 0.758909][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 0, reg: 0xb6c80000, pinbase: 0, pin number: 32, pinmap: 0xf1efefff [ 0.770568][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 1, reg: 0xb6c80100, pinbase: 32, pin number: 32, pinmap: 0x3bff0c1f [ 0.782698][ T1] intel-pinctrl 16c80000.pinctrl: Total 14 groups, 12 functions [ 0.791085][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00000 [ 0.799021][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00100 [ 0.815857][ T1] gic_timer_probe [ 0.819372][ T1] gic_timer_probe: irq=287 freq=1000000000 [ 0.863089][ T1] avm_alloc_page_extension node_extension_table[0] entries=131072 (size=524288) alloced [ 0.873092][ T1] Reboot Status is: Power-On [ 0.877609][ T1] Unable to get node cqm for prx300-cqm [ 0.882933][ T1] add_cqm_dev(#152): parse_dts fail for prx300-cqm [ 0.889529][ T1] No rcu reset for cbm [ 0.893348][ T1] No syscon phandle specified for wan mux [ 0.898992][ T1] Invalid args in ltq_dqm_ports [ 0.903760][ T1] Invalid args in ltq_eqm_ports [ 0.978671][ T1] [cbm] { cbm_xrx500_probe : 5697 }reserving 18874368 bytes @ 84000000 for CBM [ 1.018617][ T1] [cbm] { cbm_xrx500_probe : 5707 }reserving 8388608 bytes @ 85200000 for CBM [ 1.027210][ T1] [cbm] { cbm_xrx500_probe : 5722 }94 irq [ 1.032974][ T1] [cbm] { cbm_xrx500_probe : 5745 }2 [ 1.038101][ T1] [drv_tmu_ll] { get_cbm_clock : 7605 }CBM Clock: 0Hz=0MHZ [ 1.045214][ T1] [drv_tmu_ll] { get_cbm_clock : 7608 }Wrong cbm clock [ 1.051985][ T1] Initializing TMU with Base Address=be700000: ... [ 1.061245][ T1] TMU Initialization Done [ 1.065297][ T1] 0x84000000 0x1200000 0x800 [ 1.069782][ T1] 0x84000000 0x1200000 [ 1.073772][ T1] 0x85200000 0x800000 0x2000 [ 1.078285][ T1] 0x85200000 0x800000 [ 1.082506][ T1] [cbm] { init_fsqm_buf_std : 1173 }init fsqm std successfully [ 1.089768][ T1] [cbm] { init_fsqm_buf_jumbo : 1213 }init fsqm jbo successfully [ 1.097372][ T1] [cbm] { init_fsqm : 1236 }fsqm init successfully [ 1.103799][ T1] [cbm] { init_cbm_basic : 1271 }PHY ADDR STD 0x24000000 [ 1.110740][ T1] [cbm] { init_cbm_basic : 1272 }PHY ADDR JBO 0x25200000 [ 1.117929][ T1] [cbm] { init_cbm_basic : 1290 }init basic CBM successfully [ 1.124988][ T1] [cbm] { cbm_hw_init : 2206 }CBM HW init [ 1.130753][ T1] [cbm] { setup_DMA_p2p : 5102 }setup_DMA_p2p executed [ 1.137406][ T1] [cbm] { reserved_ports_highest : 5161 }2 2 19 35 [ 1.143831][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.149500][ T1] [cbm] { assign_port_from_DT : 654 }0x0 2 [ 1.155198][ T1] [cbm] { assign_port_from_DT : 654 }0x20 2 [ 1.161189][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.166048][ T1] [cbm] { reserved_ports_highest : 5161 }1 1 18 34 [ 1.172465][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.178120][ T1] [cbm] { assign_port_from_DT : 654 }0x80 1 [ 1.183927][ T1] [cbm] { reserved_ports_highest : 5161 }3 3 20 36 [ 1.190349][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.195999][ T1] [cbm] { assign_port_from_DT : 654 }0x2000000 3 [ 1.202242][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.207283][ T1] [cbm] { reserved_ports_highest : 5161 }6 6 0 16 [ 1.213614][ T1] [cbm] { dma_port_enable : 4670 }6 0x4 [ 1.219091][ T1] [cbm] { reserved_ports_highest : 5161 }7 7 1 17 [ 1.225423][ T1] [cbm] { dma_port_enable : 4670 }7 0x4 [ 1.230901][ T1] [cbm] { reserved_ports_highest : 5161 }8 8 2 18 [ 1.237225][ T1] [cbm] { dma_port_enable : 4670 }8 0x4 [ 1.242700][ T1] [cbm] { reserved_ports_highest : 5161 }9 9 3 19 [ 1.249028][ T1] [cbm] { dma_port_enable : 4670 }9 0x4 [ 1.254505][ T1] [cbm] { reserved_ports_highest : 5161 }10 10 4 20 [ 1.261006][ T1] [cbm] { dma_port_enable : 4670 }10 0x4 [ 1.266571][ T1] [cbm] { reserved_ports_highest : 5161 }11 11 5 21 [ 1.273073][ T1] [cbm] { dma_port_enable : 4670 }11 0x4 [ 1.278636][ T1] [cbm] { reserved_ports_highest : 5161 }12 12 6 22 [ 1.285139][ T1] [cbm] { dma_port_enable : 4670 }12 0x4 [ 1.290758][ T1] [cbm] { reserved_ports_highest : 5161 }13 13 7 23 [ 1.297210][ T1] [cbm] { dma_port_enable : 4670 }13 0x4 [ 1.302770][ T1] [cbm] { reserved_ports_highest : 5161 }14 14 8 24 [ 1.309269][ T1] [cbm] { dma_port_enable : 4670 }14 0x4 [ 1.314833][ T1] [cbm] { reserved_ports_highest : 5161 }15 15 9 25 [ 1.321335][ T1] [cbm] { dma_port_enable : 4670 }15 0x4 [ 1.326899][ T1] [cbm] { reserved_ports_highest : 5161 }16 16 10 26 [ 1.333487][ T1] [cbm] { dma_port_enable : 4670 }16 0x4 [ 1.339051][ T1] [cbm] { reserved_ports_highest : 5161 }17 17 11 27 [ 1.345640][ T1] [cbm] { dma_port_enable : 4670 }17 0x4 [ 1.351203][ T1] [cbm] { reserved_ports_highest : 5161 }18 18 -16 0 [ 1.357791][ T1] [cbm] { dma_port_enable : 4670 }18 0x4 [ 1.363372][ T1] [cbm] { reserved_ports_highest : 5161 }19 19 12 28 [ 1.369944][ T1] [cbm] { dma_port_enable : 4670 }19 0x4 [ 1.375513][ T1] [cbm] { reserved_ports_highest : 5161 }20 20 13 29 [ 1.382102][ T1] [cbm] { dma_port_enable : 4670 }20 0x4 [ 1.387662][ T1] [cbm] { init_special_ports : 5168 }20 [ 1.393122][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.398155][ T1] [cbm] { reserved_ports_highest : 5161 }21 21 14 30 [ 1.404751][ T1] [cbm] { dma_port_enable : 4670 }21 0x4 [ 1.410314][ T1] [cbm] { init_special_ports : 5168 }21 [ 1.415776][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.420809][ T1] [cbm] { reserved_ports_highest : 5161 }22 22 25 41 [ 1.427408][ T1] [cbm] { dma_port_enable : 4670 }22 0x4 [ 1.432972][ T1] [cbm] { reserved_ports_highest : 5161 }23 23 15 31 [ 1.439560][ T1] [cbm] { init_cbm_dqm_ldma_port : 1476 }23 [ 1.445385][ T1] [cbm] { reserved_ports_highest : 5161 }5 5 21 37 [ 1.451800][ T1] [cbm] { init_cbm_dqm_scpu_port : 1457 }5 [ 1.457707][ T1] [cbm] { reserved_ports_highest : 5161 }4 4 16 32 [ 1.463951][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }4 [ 1.469601][ T1] [cbm] { assign_port_from_DT : 654 }0x18 4 [ 1.475411][ T1] [cbm] { reserved_ports_highest : 5161 }24 24 22 38 [ 1.482004][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }24 [ 1.487744][ T1] [cbm] { assign_port_from_DT : 654 }0x8 24 [ 1.493551][ T1] [cbm] { reserved_ports_highest : 5161 }25 25 23 39 [ 1.500147][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }25 [ 1.505884][ T1] [cbm] { assign_port_from_DT : 654 }0x8 25 [ 1.511694][ T1] [cbm] { reserved_ports_highest : 5161 }26 26 24 40 [ 1.518287][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }26 [ 1.524032][ T1] [cbm] { assign_port_from_DT : 654 }0x8 26 [ 1.529833][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }0 [ 1.535477][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }1 [ 1.541116][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }2 [ 1.546760][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }3 [ 1.552402][ T1] [cbm] { dma_port_enable : 4670 }5 0x1 [ 1.557879][ T1] [cbm] { dma_port_enable : 4670 }5 0x2 [ 1.563367][ T1] [cbm] { dma_port_enable : 4670 }6 0x1 [ 1.568810][ T1] [cbm] { dma_port_enable : 4670 }6 0x2 [ 1.574284][ T1] [cbm] { dma_port_enable : 4670 }7 0x1 [ 1.579747][ T1] [cbm] { dma_port_enable : 4670 }7 0x2 [ 1.585214][ T1] [cbm] { dma_port_enable : 4670 }8 0x1 [ 1.590684][ T1] [cbm] { dma_port_enable : 4670 }8 0x2 [ 1.596151][ T1] [cbm] { dma_toe_port_enable : 4697 }9 0x1 [ 1.601969][ T1] [cbm] { dma_vrx318_port_enable : 4709 }15 0x1 [ 1.608139][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }0 [ 1.613772][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.619412][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.625055][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.630700][ T1] Load spreader init successfully [ 1.635807][ T1] [cbm] { cbm_xrx500_probe : 5801 }CBM Clock: 0Hz [ 1.641984][ T1] [cbm] { cbm_xrx500_probe : 5803 }EQM delay Enabled [ 1.648582][ T1] [cbm] { igp_delay_set : 4782 }port0 delay16 [ 1.654568][ T1] [cbm] { igp_delay_set : 4782 }port1 delay16 [ 1.660558][ T1] [cbm] { igp_delay_set : 4782 }port2 delay16 [ 1.666546][ T1] [cbm] { igp_delay_set : 4782 }port3 delay16 [ 1.672537][ T1] [cbm] { igp_delay_set : 4782 }port4 delay16 [ 1.678525][ T1] [cbm] { igp_delay_set : 4782 }port5 delay16 [ 1.684544][ T1] [cbm] { igp_delay_set : 4782 }port6 delay16 [ 1.690506][ T1] [cbm] { igp_delay_set : 4782 }port7 delay16 [ 1.696493][ T1] [cbm] { igp_delay_set : 4782 }port8 delay16 [ 1.702484][ T1] [cbm] { igp_delay_set : 4782 }port9 delay16 [ 1.708472][ T1] [cbm] { igp_delay_set : 4782 }port10 delay16 [ 1.714550][ T1] [cbm] { igp_delay_set : 4782 }port11 delay16 [ 1.720624][ T1] [cbm] { igp_delay_set : 4782 }port12 delay16 [ 1.726702][ T1] [cbm] { igp_delay_set : 4782 }port13 delay16 [ 1.732777][ T1] [cbm] { igp_delay_set : 4782 }port14 delay16 [ 1.738854][ T1] [cbm] { igp_delay_set : 4782 }port15 delay16 [ 1.744933][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x2 2 0 30 [ 1.751549][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x1 2 14 0 [ 1.758129][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x2 2 0 31 [ 1.764728][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x1 2 15 0 [ 1.771323][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x2 1 0 6 [ 1.777836][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x1 1 0 0 [ 1.784342][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x2 1 0 11 [ 1.790943][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x1 1 5 0 [ 1.797489][ T1] [cbm] { cbm_xrx500_probe : 5850 }CBM: Init Done !! [ 1.798490][ T1] pstore: using zlib compression [ 1.809794][ T1] pstore: Registered ramoops as persistent store backend [ 1.816668][ T1] ramoops: attached 0x400000@0x20100000, ecc: 0/0 [ 1.856789][ T1] SCSI subsystem initialized [ 1.861838][ T1] usbcore: registered new interface driver usbfs [ 1.868097][ T1] usbcore: registered new interface driver hub [ 1.874065][ T1] usbcore: registered new device driver usb [ 1.880515][ T1] mp8864 0-0068: MP8864 probe started. [ 1.890777][ T1] mp8864 0-0068: [MP8864 Init] Status is 0x11 Vsel is 0x37 Syscntl is 0xa5 [ 1.899086][ T1] i2c-gpio i2c: using pins 501 (SDA) and 502 (SCL) [ 1.905659][ T1] try to register spd_mon driver [ 1.905903][ T1] spdmon 16080110.speedm: base address: 0xb6080110 [ 1.917049][ T1] spdmon 16080110.speedm: PHY base address: 0x16080110 [ 1.924121][ T1] spdmon 16080110.speedm: spd_mon driver : init done !! [ 1.935260][ T1] spd_mon driver registered [ 1.940807][ T1] AVM PA for Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 1.940807][ T1] (early init) [ 1.957444][ T1] NET: Registered protocol family 8 [ 1.962377][ T1] NET: Registered protocol family 20 [ 1.968100][ T1] clocksource: Switched to clocksource gptc [ 1.998175][ T1] AppArmor: AppArmor Filesystem Enabled [ 2.007376][ T1] NET: Registered protocol family 2 [ 2.012552][ T1] IP idents hash table entries: 8192 (order: 4, 65536 bytes) [ 2.048520][ T1] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 2.056210][ T1] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.063396][ T1] TCP: Hash tables configured (established 4096 bind 4096) [ 2.070558][ T1] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.077077][ T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.084400][ T1] NET: Registered protocol family 1 [ 2.091049][ T1] yield_probe: cpu 0 irq 275 [ 2.095614][ T1] yield_probe: cpu 1 irq 276 [ 2.099950][ T1] yield_probe: cpu 2 irq 277 [ 2.104448][ T1] yield_probe: cpu 3 irq 278 [ 2.108975][ T1] yield_probe: interrupts set up [ 2.115896][ T1] audit: initializing netlink subsys (enabled) [ 2.121952][ T1] audit: type=2000 audit(1.468:1): initialized [ 2.128361][ T1] No memory allocated for crashlog [ 2.133729][ T1] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 2.162273][ T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.168722][ T1] ANTFS Module: Version 2.56 [ 2.173458][ T1] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 2.185994][ T1] fuse init (API version 7.26) [ 2.199498][ T1] io scheduler noop registered [ 2.203996][ T1] io scheduler deadline registered (default) [ 2.210354][ T1] bthelper_probe: core 0 initialized [ 2.215345][ T1] bthelper_probe: core 1 initialized [ 2.222740][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe slim phy[0] init success! [ 2.231226][ T1] intel-pcie-slim-phy 18000000.pciephy: PCIe slim phy[1] init success! [ 2.239722][ T1] intel-pcie-slim-phy 18a00000.pciephy: PCIe slim phy[2] init success! [ 2.248367][ T1] 1a400000.phy supply vbus not found, using dummy regulator [ 2.255834][ T1] 1a600000.phy supply vbus not found, using dummy regulator [ 2.372109][ T1] OF: PCI: host bridge /pcie@18900000 ranges: [ 2.377939][ T1] OF: PCI: MEM 0xb8000000..0xbaffffff -> 0xb8000000 [ 2.384579][ T1] OF: PCI: IO 0xbb800000..0xbb80ffff -> 0xbb800000 [ 2.393614][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe LCPLL SSC Mode Enabled [ 2.535112][ T1] intel-pcie 18900000.pcie: PCI host bridge to bus 0000:00 [ 2.542043][ T1] pci_bus 0000:00: root bus resource [bus 00-08] [ 2.548253][ T1] pci_bus 0000:00: root bus resource [mem 0xb8000000-0xbaffffff] [ 2.555890][ T1] pci_bus 0000:00: root bus resource [io 0xbb800000-0xbb80ffff] [ 2.563966][ T1] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.573231][ T1] pci 0000:00:00.0: PCI bridge to [bus 01-08] [ 2.579283][ T1] pci 0000:00:00.0: BAR 8: assigned [mem 0xb8000000-0xb81fffff] [ 2.586618][ T1] pci 0000:00:00.0: BAR 9: assigned [mem 0xb8200000-0xb82fffff pref] [ 2.594593][ T1] pci 0000:00:00.0: BAR 7: assigned [io 0xbb800000-0xbb800fff] [ 2.602150][ T1] pci 0000:01:00.0: BAR 0: assigned [mem 0xb8000000-0xb81fffff 64bit] [ 2.610228][ T1] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.615940][ T1] pci 0000:00:00.0: bridge window [io 0xbb800000-0xbb800fff] [ 2.623495][ T1] pci 0000:00:00.0: bridge window [mem 0xb8000000-0xb81fffff] [ 2.631046][ T1] pci 0000:00:00.0: bridge window [mem 0xb8200000-0xb82fffff pref] [ 2.639187][ T1] pcieport 0000:00:00.0: enabling device (0000 -> 0003) [ 2.646140][ T1] intel-pcie 18900000.pcie: Intel AXI PCIe Root Complex Port 0 Init Done [ 2.760110][ T1] OF: PCI: host bridge /pcie@18400000 ranges: [ 2.765912][ T1] OF: PCI: MEM 0xb4000000..0xb6ffffff -> 0xb4000000 [ 2.772570][ T1] OF: PCI: IO 0xb7800000..0xb780ffff -> 0xb7800000 [ 2.780378][ T1] intel-pcie-slim-phy 18000000.pciephy: SSC has been enabled, count: 2! [ 2.923028][ T1] intel-pcie 18400000.pcie: PCI host bridge to bus 0001:00 [ 2.929967][ T1] pci_bus 0001:00: root bus resource [bus 00-08] [ 2.936175][ T1] pci_bus 0001:00: root bus resource [mem 0xb4000000-0xb6ffffff] [ 2.943811][ T1] pci_bus 0001:00: root bus resource [io 0xb7800000-0xb780ffff] [ 2.951912][ T1] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.961170][ T1] pci 0001:00:00.0: PCI bridge to [bus 01-08] [ 2.967271][ T1] pci 0001:00:00.0: BAR 8: assigned [mem 0xb4000000-0xb41fffff] [ 2.974609][ T1] pci 0001:00:00.0: BAR 9: assigned [mem 0xb4200000-0xb42fffff pref] [ 2.982584][ T1] pci 0001:00:00.0: BAR 7: assigned [io 0xb7800000-0xb7800fff] [ 2.990139][ T1] pci 0001:01:00.0: BAR 0: assigned [mem 0xb4000000-0xb41fffff 64bit] [ 2.998218][ T1] pci 0001:00:00.0: PCI bridge to [bus 01] [ 3.003934][ T1] pci 0001:00:00.0: bridge window [io 0xb7800000-0xb7800fff] [ 3.011485][ T1] pci 0001:00:00.0: bridge window [mem 0xb4000000-0xb41fffff] [ 3.019036][ T1] pci 0001:00:00.0: bridge window [mem 0xb4200000-0xb42fffff pref] [ 3.027214][ T1] pcieport 0001:00:00.0: enabling device (0000 -> 0003) [ 3.034102][ T1] intel-pcie 18400000.pcie: Intel AXI PCIe Root Complex Port 1 Init Done [ 3.148108][ T1] OF: PCI: host bridge /pcie@18e00000 ranges: [ 3.153910][ T1] OF: PCI: MEM 0xbc000000..0xbeffffff -> 0xbc000000 [ 3.160569][ T1] OF: PCI: IO 0xbf800000..0xbf80ffff -> 0xbf800000 [ 3.168379][ T1] intel-pcie-slim-phy 18a00000.pciephy: SSC has been enabled, count: 3! [ 3.298451][ T1] intel-pcie 18e00000.pcie: PCI host bridge to bus 0002:00 [ 3.305387][ T1] pci_bus 0002:00: root bus resource [bus 00-08] [ 3.311596][ T1] pci_bus 0002:00: root bus resource [mem 0xbc000000-0xbeffffff] [ 3.319233][ T1] pci_bus 0002:00: root bus resource [io 0xbf800000-0xbf80ffff] [ 3.327334][ T1] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.336633][ T1] pci 0002:00:00.0: PCI bridge to [bus 01-08] [ 3.342784][ T1] pci 0002:00:00.0: BAR 8: assigned [mem 0xbc000000-0xbc7fffff] [ 3.350127][ T1] pci 0002:00:00.0: BAR 9: assigned [mem 0xbc800000-0xbc8fffff pref] [ 3.358102][ T1] pci 0002:00:00.0: BAR 7: assigned [io 0xbf800000-0xbf800fff] [ 3.365657][ T1] pci 0002:01:00.0: BAR 0: assigned [mem 0xbc000000-0xbc7fffff] [ 3.373208][ T1] pci 0002:00:00.0: PCI bridge to [bus 01] [ 3.378929][ T1] pci 0002:00:00.0: bridge window [io 0xbf800000-0xbf800fff] [ 3.386482][ T1] pci 0002:00:00.0: bridge window [mem 0xbc000000-0xbc7fffff] [ 3.394032][ T1] pci 0002:00:00.0: bridge window [mem 0xbc800000-0xbc8fffff pref] [ 3.402176][ T1] pcieport 0002:00:00.0: enabling device (0000 -> 0003) [ 3.409148][ T1] intel-pcie 18e00000.pcie: Intel AXI PCIe Root Complex Port 2 Init Done [ 3.419207][ T1] [mips_tc_init] dma_zalloc_coherent dev->name=(null) sizeof(struct mips_tc_sg_mem)=1680 shared_phy_mem=0x2380b000 [ 3.430993][ T1] [mips_tc_init] dma_zalloc_coherent shared_vir_uncached_mem=a380b000 shared_vir_cached_mem=8380b000 shared_working_vir_mem=8380b000 [ 3.444767][ T1] =MIPS TC Shared memory: a380b000 8380b000 8380b000 | Data: a3810000 [ 3.452691][ T1] UMT initialize success on processor: 0 ! [ 3.458375][ T1] HW MCPY driver: Version: 1.1.0, Init Done! [ 3.465450][ T1] 16600000.serial: ttyLTQ0 at MMIO 0x16600000 (irq = 210, base_baud = 0) is a lantiq,asc [ 3.475158][ T1] console [ttyLTQ0] enabled [ 3.475158][ T1] console [ttyLTQ0] enabled [ 3.483758][ T1] bootconsole [early0] disabled [ 3.483758][ T1] bootconsole [early0] disabled [ 3.493831][ T1] 16700000.serial: ttyLTQ1 at MMIO 0x16700000 (irq = 213, base_baud = 0) is a lantiq,asc [ 3.504172][ T29] random: crng init done [ 3.506885][ T1] avm_net_trace: Up and running. [ 3.512185][ T1] [avm_power]avm_power_pm_qos_init [ 3.516950][ T1] [loadcontrol] set auto - scale=1 [ 3.521504][ T1] [avm] configured: watchdog event debug [ 3.521509][ T1] [ 3.529795][ T1] Register push button event to receive the set_factory_kernel event [ 3.537926][ T1] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0) [ 3.545268][ T1] [grx:watchdog] start on cpu0 [ 3.549135][ C1] [grx:watchdog] start on cpu1 [ 3.553690][ C2] [grx:watchdog] start on cpu2 [ 3.558288][ C3] [grx:watchdog] start on cpu3 [ 3.565349][ T1] brd: module loaded [ 3.569053][ T1] zram: Added device: zram0 [ 3.574164][ T1] nand: device found, Manufacturer ID: 0x98, Chip ID: 0xdc [ 3.579826][ T1] nand: Toshiba NAND 512MiB 3,3V 8-bit [ 3.585066][ T1] nand: 512 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 128 [ 3.593409][ T1] try_avm_ecc_fixup: AVM ecc fixup is not yet implemented - skipping check [ 3.601829][ T1] Scanning device for bad blocks [ 3.987545][ T1] Bad eraseblock 1536 at 0x000018000000 [ 3.991617][ T1] Bad eraseblock 1537 at 0x000018040000 [ 4.123165][ T1] 5 fixed-partitions partitions found on MTD device 17c00000.nand-parts [ 4.129886][ T1] Creating 5 MTD partitions on "17c00000.nand-parts": [ 4.136496][ T1] 0x000000500000-0x000000d00000 : "kernel" [ 4.144275][ T1] 0x000000000000-0x000000100000 : "urlader" [ 4.150530][ T1] 0x000000100000-0x000000500000 : "nand-tffs" [ 4.157072][ T1] [TFFS3_Init] Called. [ 4.159529][ T1] [TFFS3_CACHE_Configure] Setting up caching for backend nand [ 4.166867][ T1] [TFFS3-CACHE] Caching module for TFFS 3.x [ 4.172594][ T1] [TFFS3-NAND] NAND storage backend for TFFS 3.x on mtd2 [ 4.317699][ T1] [TFFS3-NAND] Initialisation successful, 16/16/16 NAND blocks active, fill rate 6% [ 4.325492][ T1] [TFFS_Cache] Allocate segement buffer cache (size=4072) [ 4.334852][ T1] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0) [ 4.344959][ T1] [TFFS3-NANDSTAT][tffs_erase_stat_init] Erase counts: (min/max/mean): 1/1/1 - 0 bad blocks [ 4.353513][ T1] 0x000000d00000-0x000001500000 : "reserved-kernel" [ 4.361707][ T1] 0x000001500000-0x000020000000 : "ubi" [ 4.382906][ T1] lro_sram_membase_res0 from DT: a2013000 [ 4.387424][ T1] ltq_toe_membase: e2000000 and lro_sram_membase_res0: e2013000 [ 4.395265][ T1] TOE Init Done !! [ 5.044741][ T1] i2c /dev entries driver [ 5.049676][ T1] ltq_thermal 16000000.ssx4:ts@080000: ltq_thermal_probe: is done [ 5.060898][ T1] AVM PA 2.179-master for Linux Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 5.060898][ T1] (late init) [ 5.077633][ T1] Mirror/redirect action on [ 5.081317][ T1] u32 classifier [ 5.084652][ T1] Performance counters on [ 5.089158][ T1] input device check on [ 5.093500][ T1] Actions configured [ 5.097797][ T1] ipip: IPv4 and MPLS over IPv4 tunneling driver [ 5.104798][ T1] Initializing XFRM netlink socket [ 5.108769][ T1] IPsec XFRM device driver [ 5.114509][ T1] NET: Registered protocol family 10 [ 5.120881][ T1] NET: Registered protocol family 17 [ 5.124696][ T1] NET: Registered protocol family 15 [ 5.130026][ T1] Bridge flood ratelimiter registered [ 5.134973][ T1] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 5.148567][ T1] lec:lane_module_init: lec.c: initialized [ 5.154179][ T1] mpoa:atm_mpoa_init: mpc.c: initialized [ 5.159686][ T1] KOAM is loaded successfully. [ 5.164279][ T1] l2tp_core: L2TP core driver, V2.0 [ 5.169275][ T1] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 5.175805][ T1] l2tp_netlink: L2TP netlink interface [ 5.180919][ T1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 5.187427][ T1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 5.194835][ T1] 8021q: 802.1Q VLAN Support v1.8 [ 5.201575][ T1] audit: type=1400 audit(4.548:2): apparmor="STATUS" info="AppArmor sha1 policy hashing enabled" pid=1 comm="swapper/0" [ 5.212504][ T1] AppArmor: AppArmor sha1 policy hashing enabled [ 5.222902][ T1] ubi0: attaching mtd4 [ 5.602049][ T1] ubi0: scanning is finished [ 5.638078][ T1] ubi0: attached mtd4 (name "ubi", size 491 MiB) [ 5.642843][ T1] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [ 5.650363][ T1] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 1024 [ 5.657827][ T1] ubi0: VID header offset: 1024 (aligned 1024), data offset: 4096 [ 5.665466][ T1] ubi0: good PEBs: 1962, bad PEBs: 2, corrupted PEBs: 0 [ 5.672237][ T1] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128 [ 5.680140][ T1] ubi0: max/mean erase counter: 92/61, WL threshold: 4096, image sequence number: 1698721932 [ 5.690126][ T1] ubi0: available PEBs: 0, total reserved PEBs: 1962, PEBs reserved for bad PEB handling: 38 [ 5.700198][ T700] ubi0: background thread "ubi_bgt0d" started, PID 700 [ 5.702119][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.702137][ T1] [announce_root] filesystem (/dev/mtdblock5) will be used as root device [ 5.703891][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.705824][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.707588][ T1] Could not find Env 'linux_fs_start' in the[ 5.747712][ T1] squashfs: SQUASHFS error: unable to read id index table [ 5.757892][ T1] List of all partitions: [ 5.760674][ T1] 0100 30000 ram0 [ 5.760681][ T1] (driver?) [ 5.768110][ T1] 1f00 8192 mtdblock0 [ 5.768114][ T1] (driver?) [ 5.775985][ T1] 1f01 1024 mtdblock1 [ 5.775989][ T1] (driver?) [ 5.783884][ T1] 1f02 4096 mtdblock2 [ 5.783888][ T1] (driver?) [ 5.791785][ T1] 1f03 8192 mtdblock3 [ 5.791788][ T1] (driver?) [ 5.799684][ T1] 1f04 502784 mtdblock4 [ 5.799688][ T1] (driver?) [ 5.807582][ T1] 1f05 45108 mtdblock5 [ 5.807586][ T1] (driver?) [ 5.815483][ T1] 1f06 45108 mtdblock6 [ 5.815487][ T1] (driver?) [ 5.823387][ T1] 1f07 2268 mtdblock7 [ 5.823392][ T1] (driver?) [ 5.831284][ T1] 1f08 391356 mtdblock8 [ 5.831289][ T1] (driver?) [ 5.839178][ T1] No filesystem could mount root, tried: [ 5.839182][ T1] ext3 [ 5.844757][ T1] ext2 [ 5.847334][ T1] ext4 [ 5.849960][ T1] squashfs [ 5.852564][ T1] antfs [ 5.855494][ T1] fuseblk [ 5.858206][ T1] [ 5.863230][ T1] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,5) [ 5.872257][ T1] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.337 #1 [ 5.878935][ T1] Stack : 00000000 96960000 00000000 00000000 00000006 95f32f0c 00000001 00000000 [ 5.887960][ T1] 00000004 00000006 00000000 00000000 00000000 00000000 96cb90ba 00000034 [ 5.896988][ T1] 96cb6ca8 00000000 00000000 5206ce29 96950000 9695b167 96843388 00000000 [ 5.906016][ T1] 00000001 96cb4c44 96b50000 968414e8 fffffff3 95f330bc 00000000 00000000 [ 5.915044][ T1] 00000006 00000000 9684ba6c 9fc2bd54 96cb0000 95fd6094 00000000 00000000 [ 5.924072][ T1] ... [ 5.927344][ T1] Classified pointer on stack: [ 5.931800][ T1] 95f32f0c vprintk_emit+0x498/0x624 [ 5.936991][ T1] 95f330bc vprintk+0x24/0x30 [ 5.941304][ T1] 9fc2bd54 [stack(swapper/0): 9fc28000+0x3d54] [ 5.947258][ T1] 95fd6094 printk+0x34/0x58 [ 5.951631][ T1] 9fc2bc98 [stack(swapper/0): 9fc28000+0x3c98] [ 5.957586][ T1] 9fc2bd54 [stack(swapper/0): 9fc28000+0x3d54] [ 5.963581][ T1] 9629e70c dump_stack+0x9c/0xe0 [ 5.968260][ T1] Call Trace: [ 5.971406][ T1] [<95ead93c>] 0x95ead93c show_stack+0x3c/0xb0 [ 5.977385][ T1] [<9629e70c>] 0x9629e70c dump_stack+0x9c/0xe0 [ 5.983385][ T1] [<95fd5770>] 0x95fd5770 panic+0x120/0x2a0 [ 5.989111][ T1] [<96b0b4b8>] 0x96b0b4b8 mount_block_root+0x348/0x390 [ 5.995813][ C1] stop_cpu_hook cpu1 - stopped status=1100fc00 [ 5.995828][ C2] stop_cpu_hook cpu2 - stopped status=1100fc00 [ 5.995833][ C3] stop_cpu_hook cpu3 - stopped status=1100fc00 [ 5.995887][ T1] avm_set_reset_status: Soft-Reboot(PANIC) - PANIC(1)UP(5)UTC(5)FW(08.20)HW(226)HWS(4)BV(1.3578)BN(122916)FS(08.20)BT(1)BD(0) [ 6.026731][ T1] Kernel relocated by 0x159a0000 [ 6.031456][ T1] .text @ 0x95ea0000 [ 6.035276][ T1] .data @ 0x96762874 [ 6.039096][ T1] .bss @ 0x96cb0000 [ 6.066884][ T1] Rebooting in 1 seconds.. ROM VER: 2.1.0 CFG 09 B . . . * * * * * Detected PXB4583el V1.2-2000 .[piglet] Suceeded (AVM) EVA Revision: 1.3578 (C) Copyright 2005 AVM Date: Nov 27 2018 Time: 13:38:30 (1) 3 0x0-0x46409 [NAND:] 512MB TOSHIBA 4096 Pagesize 256k Blocksize 2048 Blocks HW [SYSTEM:] GRX5 (ID 0x24 Revision 2) on 1000MHz/600MHz/666MHz #Loading compressed kernel to 0x85284A30 ..................................................................................................................................................Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 ------------------------------------------- Switching to Bootcore Console ------------------------------------------- [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000000c00059638b ases 0x00000001 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 00019074 (MIPS 4KEc) [ 0.000000][ T0] MIPS: machine is GRX550 ANYWAN BOOTCORE (MIPS 4Kec) [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 02000000 @ 0e000000 (usable) [ 0.000000][ T0] memory: 00001be8 @ 0e7bc030 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 0dfc0000 (reserved) [ 0.000000][ T0] Initial ramdisk at: 0x8e000000 (4194304 bytes) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000000c0005d638b icache.flags 0x00000000 dcache.flags 0x00000004 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 16 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 16 bytes [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000000c0005d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] Normal [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] On node 0 totalpages: 8192 [ 0.000000][ T0] free_area_init_node: node 0, pgdat 8e7bb1c4, node_mem_map 8f005a00 [ 0.000000][ T0] Normal zone: 64 pages used for memmap [ 0.000000][ T0] Normal zone: 0 pages reserved [ 0.000000][ T0] Normal zone: 8192 pages, LIFO batch:0 [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000][ T0] pcpu-alloc: [0] 0 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200n8r root=/dev/ram rw loglevel=8 [ 0.000000][ T0] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Memory: 23752K/32768K available (2931K kernel code, 461K rwdata, 680K rodata, 208K init, 262K bss, 9016K reserved, 0K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] grx500_bootcore_register_static_irq: irq_in = 0x0000001f, irq_out = 0x0000001f [ 0.000000][ T0] grx500_bootcore_register_static_irq: mapper_reg = 0x0000015c, mapper_offset = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: int_line = 0x0000001f, map_address = 0x0000015c, num = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x0000001f [ 0.000000][ T0] CPU Clock: 300MHz [ 0.000000][ T0] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns [ 0.000019][ T0] sched_clock: 32 bits at 150MHz, resolution 6ns, wraps every 14316557820ns [ 0.016981][ T0] : grx500_bootcore_console_init: call register [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.041329][ T0] bootconsole [early0] disabled [ 0.041329][ T0] bootconsole [early0] disabled [ 0.054926][ T0] bootconsole [early0] disabled [ 0.054926][ T0] bootconsole [early0] disabled [ 0.064275][ T0] Calibrating delay loop... 299.26 BogoMIPS (lpj=598528) [ 0.107039][ T0] pid_max: default: 32768 minimum: 301 [ 0.113272][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.120427][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.134875][ T1] Performance counters: No available PMU. [ 0.143903][ T1] devtmpfs: initialized [ 0.153182][ T1] ngi: Protecting Bootcore: [0x2e000000, 0x2fffffff] [ 0.159596][ T1] ngi: 512MB attached. Protecting: [0x40000000, 0x9fffffff] [ 0.166610][ T1] ngi: Unattached: [0x60000000, 0x9fffffff] [ 0.172309][ T1] ngi: Unattached: [0x40000000, 0x5fffffff] [ 0.178733][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.189062][ T1] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.196166][ T1] pinctrl core: initialized pinctrl subsystem [ 0.204880][ T1] NET: Registered protocol family 16 [ 0.227275][ T1] irq: no irq domain found for /interrupt-controller@0x14900140 ! [ 0.327557][ T1] clocksource: Switched to clocksource MIPS [ 0.356141][ T1] NET: Registered protocol family 2 [ 0.361656][ T1] IP idents hash table entries: 2048 (order: 2, 16384 bytes) [ 0.370777][ T1] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.378465][ T1] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.385396][ T1] TCP: Hash tables configured (established 1024 bind 1024) [ 0.392946][ T1] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.399453][ T1] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.406882][ T1] NET: Registered protocol family 1 [ 0.416091][ T1] Unpacking initramfs... [ 1.158612][ T1] Freeing initrd memory: 4096K [ 1.165806][ T1] No memory allocated for crashlog [ 1.178981][ T1] workingset: timestamp_bits=30 max_order=13 bucket_order=0 [ 1.260179][ T1] Serial: grx500_bootcore driver init [ 1.274130][ T1] NET: Registered protocol family 10 [ 1.292323][ T1] NET: Registered protocol family 17 [ 1.305639][ T1] Serial: grx500_bootcore driver startup [ 1.311108][ T1] grx500_bootcore_register_static_irq: irq_in = 0x0000001c, irq_out = 0x00000008 [ 1.319859][ T1] grx500_bootcore_register_static_irq: mapper_reg = 0x00000158, mapper_offset = 0x00000003 [ 1.329615][ T1] EXCEP_remap_line: int_line = 0x00000008, map_address = 0x00000158, num = 0x00000003 [ 1.339030][ T1] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x00040000 [ 1.352168][ T1] Freeing unused kernel memory: 208K [ 1.357207][ T1] This architecture does not have kernel memory protection. [ 1.595110][ T195] eip123_hw: module license 'Proprietary' taints kernel. [ 1.602005][ T195] Disabling lock debugging due to kernel taint [ 1.613277][ T195] eip123: no symbol version for eip123_hw_asset_derive [ 1.621760][ T195] eip123 1e000000.eip123: Detected hardware version 2.2.2 [ 1.628704][ T195] eip123 1e000000.eip123: my_id=0 master_id=0 num_mailboxes=4 mailbox_size=256 [ 1.637289][ T195] eip123 1e000000.eip123: Configured mailbox lockout: 0x00000000 [ 1.644805][ T195] eip123 1e000000.eip123: Linked mailbox number 1 [ 1.675626][ T195] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=0 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0 [ 1.911559][ T195] eip123 1e000000.eip123: eip123_hw init successful [ 1.971590][ T195] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c [ 1.980696][ T195] eip123 1e000000.eip123: Could not find rootkey in OTP [ 2.015767][ T198] random: crng init done [ 2.020701][ T110] shm-rng-seed shm-rng-seed@3dfb0000: Added 4088 random bytes to the shared memory area [ 3.790383][ T262] eip123 1e000000.eip123: Unlinked mailboxes [ 3.807698][ T181] interaptiv_st$$HHŖW-×,­Zė× RŹ‹W–®,\]Z»Console ------------------------------------------- .. Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 [ 0.000000][ T0] shm-rng-seed-mem@3dfb0000: Added 4088 random bytes to the system pool [ 0.000000][ T0] OF: fdt:[0x36e50000, 0x38113b70) is not contained in the RAM region at [0x20000000, 0x2e000000) [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e69638b ases 0x00000030 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.000000][ T0] Enhanced Virtual Addressing (EVA Legacy 512MB) activated [ 0.000000][ T0] MIPS: machine is AVM7590 (GRX550, HW226) Main model [ 0.000000][ T0] Coherence Manager IOCU detected [ 0.000000][ T0] Hardware DMA cache coherency disabled [ 0.000000][ T0] OF: reserved mem: initialized node shm-rng-seed-mem@3dfb0000, compatible id avm,shm-rng-seed-early [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'urlader': base 0x20010000, size 0x00030000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'VMB': base 0x20000000, size 0x00001000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'avm_reboot_string': base 0x20001000, size 0x00000200 [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 10000000 @ 30000000 (usable) [ 0.000000][ T0] memory: 0e000000 @ 20000000 (usable) [ 0.000000][ T0] memory: 0000cf68 @ 37a7a038 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 2dfc0000 (reserved) [ 0.000000][ T0] memory: 00400000 @ 20100000 (reserved) [ 0.000000][ T0] memory: 00030000 @ 20010000 (reserved) [ 0.000000][ T0] memory: 00001200 @ 20000000 (reserved) [ 0.000000][ T0] Kernel relocated by 0x16950000 [ 0.000000][ T0] .text @ 0x96e50000 [ 0.000000][ T0] .data @ 0x97712874 [ 0.000000][ T0] .bss @ 0x97c60000 [ 0.000000][ T0] Initrd not found or empty - disabling initrd [ 0.000000][ T0] cma: Reserved 64 MiB at 0x24000000 [ 0.000000][ T0] SMPCMP: initialized the EVA stub code: 400@0x28029480 [ 0.000000][ T0] SMPCMP: CPU0: cmp_smp_setup [ 0.000000][ T0] VPE topology {2,2} total 4 [ 0.000000][ T0] Detected 3 available secondary CPU(s) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.000000][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] DMA [mem 0x0000000020000000-0x0000000027ffffff] [ 0.000000][ T0] Normal [mem 0x0000000028000000-0x000000003fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x0000000020000000-0x000000002dffffff] [ 0.000000][ T0] node 0: [mem 0x0000000030000000-0x000000003fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x0000000020000000-0x000000003fffffff] [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] [module-mem] Use 0x3f3f3000-0x3ff3ffff (mapped at 9f3f3000-9ff3ffff) for 95 modules [ 0.000000][ T0] percpu: Embedded 12 pages/cpu s18288 r8192 d22672 u49152 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121728 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200 pcmlink.abmode=0x8103 Piglet_noemif.piglet_dectmode=0x110 Piglet_noemif.piglet_bitfile=bitfile.bit audit=1 slub_debug=fl [ 0.000000][ T0] audit: enabled (after initialization) [ 0.000000][ T0] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000][ T0] Writing ErrCtl register=00000000 [ 0.000000][ T0] Readback ErrCtl register=00000000 [ 0.000000][ T0] Memory: 385240K/491520K available (8745K kernel code, 1849K rwdata, 1892K rodata, 1688K init, 4814K bss, 40744K reserved, 65536K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000][ T0] Hierarchical RCU implementation. [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] EIC is off [ 0.000000][ T0] VINT is on [ 0.000000][ T0] CPU Clock: 1000000000Hz mips_hpt_frequency 500000000Hz [ 0.000000][ T0] clocksource: gptc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302233 ns [ 0.010150][ T0] Calibrating delay loop... 718.84 BogoMIPS (lpj=1437696) [ 0.046807][ T0] pid_max: default: 32768 minimum: 301 [ 0.052302][ T0] Security Framework initialized [ 0.057084][ T0] AppArmor: AppArmor initialized [ 0.061976][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.069296][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.078843][ T1] CCA is coherent, multi-core is fine [ 0.084503][ T1] avm_register_cpuid: cpu_id=0: LINUX core=0 tc=0 [ 0.090741][ T1] Performance counters: mips/interAptiv PMU enabled, 2 32-bit counters available to each CPU, irq 9 GOT IPI to launch from CPU 1 GOT IPI to launch from CPU 2 GOT IPI to launch from CPU 3 [ 0.109266][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.109311][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.109317][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.109337][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.109343][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.109349][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.109359][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.109364][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.109563][ T0] CPU1 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.139602][ T0] avm_register_cpuid: cpu_id=1: LINUX core=0 tc=1 [ 0.142047][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.142084][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.142088][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.142107][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.142114][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.142119][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.142129][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.142134][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.142269][ T0] CPU2 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.169881][ T0] avm_register_cpuid: cpu_id=2: LINUX core=1 tc=0 [ 0.172357][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.172394][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.172398][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.172416][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.172423][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.172428][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.172438][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.172442][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.172577][ T0] CPU3 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.200184][ T0] avm_register_cpuid: cpu_id=3: LINUX core=1 tc=1 [ 0.200456][ T1] Brought up 4 CPUs [ 0.470631][ T1] avm_yield_setup: YIELD_PCMFRAME_ID : id=0x0004000f: cpu=0 tc=4 prio=3 signal=15 [ 0.480261][ T1] avm_yield_setup: YIELD_PCMLINK_ID : id=0x0003000c: cpu=0 tc=3 prio=2 signal=12 [ 0.489896][ T1] avm_yield_setup: YIELD_MONITOR_IPI0_ID : id=0x0002000e: cpu=0 tc=2 prio=1 signal=14 [ 0.499531][ T1] avm_yield_setup: YIELD_PROFILE_IPI0_ID : id=0x0002000d: cpu=0 tc=2 prio=1 signal=13 [ 0.509166][ T1] avm_yield_setup: YIELD_GPTC_ID : id=0x0005000b: cpu=0 tc=5 prio=3 signal=11 [ 0.519338][ T3] [0][yield_context_init] cpu=0 tc=2 mask=6000 tc_prio=1 [ 0.526490][ T29] [0][yield_context_init] cpu=0 tc=3 mask=1000 tc_prio=2 [ 0.533653][ T29] [0][yield_context_init] cpu=0 tc=4 mask=8000 tc_prio=3 [ 0.540763][ T29] [0][yield_context_init] cpu=0 tc=5 mask=0800 tc_prio=3 [ 0.547771][ T1] avm_yield_setup: YIELD_MONITOR_IPI1_ID : id=0x0202000e: cpu=2 tc=2 prio=1 signal=14 [ 0.557219][ T1] avm_yield_setup: YIELD_PROFILE_IPI1_ID : id=0x0202000d: cpu=2 tc=2 prio=1 signal=13 [ 0.567258][ T21] [2][yield_context_init] cpu=2 tc=2 mask=6000 tc_prio=1 [ 0.575113][ T1] devtmpfs: initialized [ 0.594401][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.604924][ T1] futex hash table entries: 1024 (order: 3, 32768 bytes) [ 0.616606][ T1] pinctrl core: initialized pinctrl subsystem [ 0.624063][ T1] NET: Registered protocol family 16 [ 0.633610][ T1] dma-grx500 1e300000.dma: dma3 base address be300000 chained_irq 29 irq_base 30 [ 0.645481][ T1] dma-grx500 1e300000.dma: Init done - rev: a, ports: 1, channels: 64 [ 0.655980][ T1] dma-grx500 1c100000.dma: dma2tx base address bc100000 chained_irq 100 irq_base 101 [ 0.666841][ T1] dma-grx500 1c100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.675315][ T1] dma-grx500 1c200000.dma: dma2rx base address bc200000 chained_irq 117 irq_base 118 [ 0.686662][ T1] dma-grx500 1c200000.dma: Init done - rev: a, ports: 1, channels: 32 [ 0.695684][ T1] dma-grx500 1a100000.dma: dma1tx base address ba100000 chained_irq 150 irq_base 151 [ 0.706593][ T1] dma-grx500 1a100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.714973][ T1] dma-grx500 1a200000.dma: dma1rx base address ba200000 chained_irq 167 irq_base 168 [ 0.725682][ T1] dma-grx500 1a200000.dma: Init done - rev: a, ports: 1, channels: 12 [ 0.740897][ T1] dma0-grx500 16e00000.dma: base address b6e00000 chained_irq 218 irq_base 219 [ 0.749635][ T1] dma0-grx500 16e00000.dma: Init done - hw rev: A, ports: 4, channels: 16 [ 0.758273][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 0, reg: 0xb6c80000, pinbase: 0, pin number: 32, pinmap: 0xf1efefff [ 0.769936][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 1, reg: 0xb6c80100, pinbase: 32, pin number: 32, pinmap: 0x3bff0c1f [ 0.782069][ T1] intel-pinctrl 16c80000.pinctrl: Total 14 groups, 12 functions [ 0.790450][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00000 [ 0.798352][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00100 [ 0.814793][ T1] gic_timer_probe [ 0.818246][ T1] gic_timer_probe: irq=287 freq=1000000000 [ 0.854421][ T1] avm_alloc_page_extension node_extension_table[0] entries=131072 (size=524288) alloced [ 0.864499][ T1] Reboot Status is: Soft-Reboot(PANIC) PANIC(1) [ 0.870571][ T1] Unable to get node cqm for prx300-cqm [ 0.875901][ T1] add_cqm_dev(#152): parse_dts fail for prx300-cqm [ 0.882497][ T1] No rcu reset for cbm [ 0.886318][ T1] No syscon phandle specified for wan mux [ 0.891963][ T1] Invalid args in ltq_dqm_ports [ 0.896730][ T1] Invalid args in ltq_eqm_ports [ 0.971521][ T1] [cbm] { cbm_xrx500_probe : 5697 }reserving 18874368 bytes @ 84000000 for CBM [ 1.011334][ T1] [cbm] { cbm_xrx500_probe : 5707 }reserving 8388608 bytes @ 85200000 for CBM [ 1.019967][ T1] [cbm] { cbm_xrx500_probe : 5722 }94 irq [ 1.025694][ T1] [cbm] { cbm_xrx500_probe : 5745 }2 [ 1.030833][ T1] [drv_tmu_ll] { get_cbm_clock : 7605 }CBM Clock: 0Hz=0MHZ [ 1.037940][ T1] [drv_tmu_ll] { get_cbm_clock : 7608 }Wrong cbm clock [ 1.044713][ T1] Initializing TMU with Base Address=be700000: ... [ 1.053961][ T1] TMU Initialization Done [ 1.057985][ T1] 0x84000000 0x1200000 0x800 [ 1.062497][ T1] 0x84000000 0x1200000 [ 1.066481][ T1] 0x85200000 0x800000 0x2000 [ 1.070996][ T1] 0x85200000 0x800000 [ 1.075215][ T1] [cbm] { init_fsqm_buf_std : 1173 }init fsqm std successfully [ 1.082479][ T1] [cbm] { init_fsqm_buf_jumbo : 1213 }init fsqm jbo successfully [ 1.090082][ T1] [cbm] { init_fsqm : 1236 }fsqm init successfully [ 1.096507][ T1] [cbm] { init_cbm_basic : 1271 }PHY ADDR STD 0x24000000 [ 1.103450][ T1] [cbm] { init_cbm_basic : 1272 }PHY ADDR JBO 0x25200000 [ 1.110638][ T1] [cbm] { init_cbm_basic : 1290 }init basic CBM successfully [ 1.117697][ T1] [cbm] { cbm_hw_init : 2206 }CBM HW init [ 1.123459][ T1] [cbm] { setup_DMA_p2p : 5102 }setup_DMA_p2p executed [ 1.130113][ T1] [cbm] { reserved_ports_highest : 5161 }2 2 19 35 [ 1.136539][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.142214][ T1] [cbm] { assign_port_from_DT : 654 }0x0 2 [ 1.147907][ T1] [cbm] { assign_port_from_DT : 654 }0x20 2 [ 1.153900][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.158758][ T1] [cbm] { reserved_ports_highest : 5161 }1 1 18 34 [ 1.165175][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.170830][ T1] [cbm] { assign_port_from_DT : 654 }0x80 1 [ 1.176637][ T1] [cbm] { reserved_ports_highest : 5161 }3 3 20 36 [ 1.183057][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.188709][ T1] [cbm] { assign_port_from_DT : 654 }0x2000000 3 [ 1.194958][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.199986][ T1] [cbm] { reserved_ports_highest : 5161 }6 6 0 16 [ 1.206325][ T1] [cbm] { dma_port_enable : 4670 }6 0x4 [ 1.211800][ T1] [cbm] { reserved_ports_highest : 5161 }7 7 1 17 [ 1.218132][ T1] [cbm] { dma_port_enable : 4670 }7 0x4 [ 1.223610][ T1] [cbm] { reserved_ports_highest : 5161 }8 8 2 18 [ 1.229935][ T1] [cbm] { dma_port_enable : 4670 }8 0x4 [ 1.235410][ T1] [cbm] { reserved_ports_highest : 5161 }9 9 3 19 [ 1.241738][ T1] [cbm] { dma_port_enable : 4670 }9 0x4 [ 1.247215][ T1] [cbm] { reserved_ports_highest : 5161 }10 10 4 20 [ 1.253716][ T1] [cbm] { dma_port_enable : 4670 }10 0x4 [ 1.259280][ T1] [cbm] { reserved_ports_highest : 5161 }11 11 5 21 [ 1.265781][ T1] [cbm] { dma_port_enable : 4670 }11 0x4 [ 1.271346][ T1] [cbm] { reserved_ports_highest : 5161 }12 12 6 22 [ 1.277847][ T1] [cbm] { dma_port_enable : 4670 }12 0x4 [ 1.283411][ T1] [cbm] { reserved_ports_highest : 5161 }13 13 7 23 [ 1.289913][ T1] [cbm] { dma_port_enable : 4670 }13 0x4 [ 1.295477][ T1] [cbm] { reserved_ports_highest : 5161 }14 14 8 24 [ 1.301983][ T1] [cbm] { dma_port_enable : 4670 }14 0x4 [ 1.307548][ T1] [cbm] { reserved_ports_highest : 5161 }15 15 9 25 [ 1.314046][ T1] [cbm] { dma_port_enable : 4670 }15 0x4 [ 1.319608][ T1] [cbm] { reserved_ports_highest : 5161 }16 16 10 26 [ 1.326196][ T1] [cbm] { dma_port_enable : 4670 }16 0x4 [ 1.331760][ T1] [cbm] { reserved_ports_highest : 5161 }17 17 11 27 [ 1.338351][ T1] [cbm] { dma_port_enable : 4670 }17 0x4 [ 1.343913][ T1] [cbm] { reserved_ports_highest : 5161 }18 18 -16 0 [ 1.350502][ T1] [cbm] { dma_port_enable : 4670 }18 0x4 [ 1.356081][ T1] [cbm] { reserved_ports_highest : 5161 }19 19 12 28 [ 1.362654][ T1] [cbm] { dma_port_enable : 4670 }19 0x4 [ 1.368218][ T1] [cbm] { reserved_ports_highest : 5161 }20 20 13 29 [ 1.374806][ T1] [cbm] { dma_port_enable : 4670 }20 0x4 [ 1.380369][ T1] [cbm] { init_special_ports : 5168 }20 [ 1.385835][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.390870][ T1] [cbm] { reserved_ports_highest : 5161 }21 21 14 30 [ 1.397463][ T1] [cbm] { dma_port_enable : 4670 }21 0x4 [ 1.403024][ T1] [cbm] { init_special_ports : 5168 }21 [ 1.408484][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.413519][ T1] [cbm] { reserved_ports_highest : 5161 }22 22 25 41 [ 1.420117][ T1] [cbm] { dma_port_enable : 4670 }22 0x4 [ 1.425681][ T1] [cbm] { reserved_ports_highest : 5161 }23 23 15 31 [ 1.432270][ T1] [cbm] { init_cbm_dqm_ldma_port : 1476 }23 [ 1.438094][ T1] [cbm] { reserved_ports_highest : 5161 }5 5 21 37 [ 1.444509][ T1] [cbm] { init_cbm_dqm_scpu_port : 1457 }5 [ 1.450416][ T1] [cbm] { reserved_ports_highest : 5161 }4 4 16 32 [ 1.456660][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }4 [ 1.462311][ T1] [cbm] { assign_port_from_DT : 654 }0x18 4 [ 1.468120][ T1] [cbm] { reserved_ports_highest : 5161 }24 24 22 38 [ 1.474714][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }24 [ 1.480452][ T1] [cbm] { assign_port_from_DT : 654 }0x8 24 [ 1.486262][ T1] [cbm] { reserved_ports_highest : 5161 }25 25 23 39 [ 1.492855][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }25 [ 1.498595][ T1] [cbm] { assign_port_from_DT : 654 }0x8 25 [ 1.504402][ T1] [cbm] { reserved_ports_highest : 5161 }26 26 24 40 [ 1.510999][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }26 [ 1.516736][ T1] [cbm] { assign_port_from_DT : 654 }0x8 26 [ 1.522545][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }0 [ 1.528184][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }1 [ 1.533827][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }2 [ 1.539471][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }3 [ 1.545114][ T1] [cbm] { dma_port_enable : 4670 }5 0x1 [ 1.550588][ T1] [cbm] { dma_port_enable : 4670 }5 0x2 [ 1.556051][ T1] [cbm] { dma_port_enable : 4670 }6 0x1 [ 1.561518][ T1] [cbm] { dma_port_enable : 4670 }6 0x2 [ 1.566994][ T1] [cbm] { dma_port_enable : 4670 }7 0x1 [ 1.572455][ T1] [cbm] { dma_port_enable : 4670 }7 0x2 [ 1.577926][ T1] [cbm] { dma_port_enable : 4670 }8 0x1 [ 1.583392][ T1] [cbm] { dma_port_enable : 4670 }8 0x2 [ 1.588863][ T1] [cbm] { dma_toe_port_enable : 4697 }9 0x1 [ 1.594677][ T1] [cbm] { dma_vrx318_port_enable : 4709 }15 0x1 [ 1.600851][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }0 [ 1.606479][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.612123][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.617764][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.623411][ T1] Load spreader init successfully [ 1.628511][ T1] [cbm] { cbm_xrx500_probe : 5801 }CBM Clock: 0Hz [ 1.634696][ T1] [cbm] { cbm_xrx500_probe : 5803 }EQM delay Enabled [ 1.641292][ T1] [cbm] { igp_delay_set : 4782 }port0 delay16 [ 1.647279][ T1] [cbm] { igp_delay_set : 4782 }port1 delay16 [ 1.653266][ T1] [cbm] { igp_delay_set : 4782 }port2 delay16 [ 1.659257][ T1] [cbm] { igp_delay_set : 4782 }port3 delay16 [ 1.665245][ T1] [cbm] { igp_delay_set : 4782 }port4 delay16 [ 1.671237][ T1] [cbm] { igp_delay_set : 4782 }port5 delay16 [ 1.677224][ T1] [cbm] { igp_delay_set : 4782 }port6 delay16 [ 1.683215][ T1] [cbm] { igp_delay_set : 4782 }port7 delay16 [ 1.689203][ T1] [cbm] { igp_delay_set : 4782 }port8 delay16 [ 1.695194][ T1] [cbm] { igp_delay_set : 4782 }port9 delay16 [ 1.701182][ T1] [cbm] { igp_delay_set : 4782 }port10 delay16 [ 1.707259][ T1] [cbm] { igp_delay_set : 4782 }port11 delay16 [ 1.713334][ T1] [cbm] { igp_delay_set : 4782 }port12 delay16 [ 1.719411][ T1] [cbm] { igp_delay_set : 4782 }port13 delay16 [ 1.725486][ T1] [cbm] { igp_delay_set : 4782 }port14 delay16 [ 1.731564][ T1] [cbm] { igp_delay_set : 4782 }port15 delay16 [ 1.737642][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x2 2 0 30 [ 1.744258][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x1 2 14 0 [ 1.750838][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x2 2 0 31 [ 1.757438][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x1 2 15 0 [ 1.764032][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x2 1 0 6 [ 1.770545][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x1 1 0 0 [ 1.777052][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x2 1 0 11 [ 1.783652][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x1 1 5 0 [ 1.790196][ T1] [cbm] { cbm_xrx500_probe : 5850 }CBM: Init Done !! [ 1.791314][ T1] pstore: using zlib compression [ 1.802630][ T1] pstore: Registered ramoops as persistent store backend [ 1.809500][ T1] ramoops: attached 0x400000@0x20100000, ecc: 0/0 [ 1.852287][ T1] SCSI subsystem initialized [ 1.857295][ T1] usbcore: registered new interface driver usbfs [ 1.863642][ T1] usbcore: registered new interface driver hub [ 1.869632][ T1] usbcore: registered new device driver usb [ 1.876103][ T1] mp8864 0-0068: MP8864 probe started. [ 1.886393][ T1] mp8864 0-0068: [MP8864 Init] Status is 0x11 Vsel is 0x37 Syscntl is 0xe5 [ 1.894694][ T1] i2c-gpio i2c: using pins 501 (SDA) and 502 (SCL) [ 1.901291][ T1] try to register spd_mon driver [ 1.901620][ T1] spdmon 16080110.speedm: base address: 0xb6080110 [ 1.912769][ T1] spdmon 16080110.speedm: PHY base address: 0x16080110 [ 1.919822][ T1] spdmon 16080110.speedm: spd_mon driver : init done !! [ 1.931185][ T1] spd_mon driver registered [ 1.936788][ T1] AVM PA for Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 1.936788][ T1] (early init) [ 1.953417][ T1] NET: Registered protocol family 8 [ 1.958376][ T1] NET: Registered protocol family 20 [ 1.964170][ T1] clocksource: Switched to clocksource gptc [ 1.994233][ T1] AppArmor: AppArmor Filesystem Enabled [ 2.003358][ T1] NET: Registered protocol family 2 [ 2.008569][ T1] IP idents hash table entries: 8192 (order: 4, 65536 bytes) [ 2.032532][ T1] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 2.040250][ T1] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.047416][ T1] TCP: Hash tables configured (established 4096 bind 4096) [ 2.054563][ T1] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.061086][ T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.068401][ T1] NET: Registered protocol family 1 [ 2.075118][ T1] yield_probe: cpu 0 irq 275 [ 2.079651][ T1] yield_probe: cpu 1 irq 276 [ 2.084051][ T1] yield_probe: cpu 2 irq 277 [ 2.088486][ T1] yield_probe: cpu 3 irq 278 [ 2.093014][ T1] yield_probe: interrupts set up [ 2.100250][ T1] audit: initializing netlink subsys (enabled) [ 2.106269][ T1] audit: type=2000 audit(1.432:1): initialized [ 2.112672][ T1] No memory allocated for crashlog [ 2.118046][ T1] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 2.151261][ T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.157711][ T1] ANTFS Module: Version 2.56 [ 2.162437][ T1] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 2.175259][ T1] fuse init (API version 7.26) [ 2.189079][ T1] io scheduler noop registered [ 2.193568][ T1] io scheduler deadline registered (default) [ 2.199934][ T1] bthelper_probe: core 0 initialized [ 2.204940][ T1] bthelper_probe: core 1 initialized [ 2.212629][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe slim phy[0] init success! [ 2.221289][ T1] intel-pcie-slim-phy 18000000.pciephy: PCIe slim phy[1] init success! [ 2.229805][ T1] intel-pcie-slim-phy 18a00000.pciephy: PCIe slim phy[2] init success! [ 2.238309][ T1] 1a400000.phy supply vbus not found, using dummy regulator [ 2.245714][ T1] 1a600000.phy supply vbus not found, using dummy regulator [ 2.364072][ T1] OF: PCI: host bridge /pcie@18900000 ranges: [ 2.369904][ T1] OF: PCI: MEM 0xb8000000..0xbaffffff -> 0xb8000000 [ 2.376542][ T1] OF: PCI: IO 0xbb800000..0xbb80ffff -> 0xbb800000 [ 2.385612][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe LCPLL SSC Mode Enabled [ 2.527034][ T1] intel-pcie 18900000.pcie: PCI host bridge to bus 0000:00 [ 2.533966][ T1] pci_bus 0000:00: root bus resource [bus 00-08] [ 2.540174][ T1] pci_bus 0000:00: root bus resource [mem 0xb8000000-0xbaffffff] [ 2.547809][ T1] pci_bus 0000:00: root bus resource [io 0xbb800000-0xbb80ffff] [ 2.555881][ T1] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.565155][ T1] pci 0000:00:00.0: PCI bridge to [bus 01-08] [ 2.571203][ T1] pci 0000:00:00.0: BAR 8: assigned [mem 0xb8000000-0xb81fffff] [ 2.578540][ T1] pci 0000:00:00.0: BAR 9: assigned [mem 0xb8200000-0xb82fffff pref] [ 2.586513][ T1] pci 0000:00:00.0: BAR 7: assigned [io 0xbb800000-0xbb800fff] [ 2.594069][ T1] pci 0000:01:00.0: BAR 0: assigned [mem 0xb8000000-0xb81fffff 64bit] [ 2.602147][ T1] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.607862][ T1] pci 0000:00:00.0: bridge window [io 0xbb800000-0xbb800fff] [ 2.615414][ T1] pci 0000:00:00.0: bridge window [mem 0xb8000000-0xb81fffff] [ 2.622965][ T1] pci 0000:00:00.0: bridge window [mem 0xb8200000-0xb82fffff pref] [ 2.631105][ T1] pcieport 0000:00:00.0: enabling device (0000 -> 0003) [ 2.638059][ T1] intel-pcie 18900000.pcie: Intel AXI PCIe Root Complex Port 0 Init Done [ 2.752068][ T1] OF: PCI: host bridge /pcie@18400000 ranges: [ 2.757863][ T1] OF: PCI: MEM 0xb4000000..0xb6ffffff -> 0xb4000000 [ 2.764523][ T1] OF: PCI: IO 0xb7800000..0xb780ffff -> 0xb7800000 [ 2.772333][ T1] intel-pcie-slim-phy 18000000.pciephy: SSC has been enabled, count: 2! [ 2.914968][ T1] intel-pcie 18400000.pcie: PCI host bridge to bus 0001:00 [ 2.921903][ T1] pci_bus 0001:00: root bus resource [bus 00-08] [ 2.928112][ T1] pci_bus 0001:00: root bus resource [mem 0xb4000000-0xb6ffffff] [ 2.935748][ T1] pci_bus 0001:00: root bus resource [io 0xb7800000-0xb780ffff] [ 2.943862][ T1] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.953097][ T1] pci 0001:00:00.0: PCI bridge to [bus 01-08] [ 2.959196][ T1] pci 0001:00:00.0: BAR 8: assigned [mem 0xb4000000-0xb41fffff] [ 2.966539][ T1] pci 0001:00:00.0: BAR 9: assigned [mem 0xb4200000-0xb42fffff pref] [ 2.974513][ T1] pci 0001:00:00.0: BAR 7: assigned [io 0xb7800000-0xb7800fff] [ 2.982069][ T1] pci 0001:01:00.0: BAR 0: assigned [mem 0xb4000000-0xb41fffff 64bit] [ 2.990146][ T1] pci 0001:00:00.0: PCI bridge to [bus 01] [ 2.995862][ T1] pci 0001:00:00.0: bridge window [io 0xb7800000-0xb7800fff] [ 3.003415][ T1] pci 0001:00:00.0: bridge window [mem 0xb4000000-0xb41fffff] [ 3.010964][ T1] pci 0001:00:00.0: bridge window [mem 0xb4200000-0xb42fffff pref] [ 3.019145][ T1] pcieport 0001:00:00.0: enabling device (0000 -> 0003) [ 3.026029][ T1] intel-pcie 18400000.pcie: Intel AXI PCIe Root Complex Port 1 Init Done [ 3.140058][ T1] OF: PCI: host bridge /pcie@18e00000 ranges: [ 3.145854][ T1] OF: PCI: MEM 0xbc000000..0xbeffffff -> 0xbc000000 [ 3.152514][ T1] OF: PCI: IO 0xbf800000..0xbf80ffff -> 0xbf800000 [ 3.160323][ T1] intel-pcie-slim-phy 18a00000.pciephy: SSC has been enabled, count: 3! [ 3.290386][ T1] intel-pcie 18e00000.pcie: PCI host bridge to bus 0002:00 [ 3.297320][ T1] pci_bus 0002:00: root bus resource [bus 00-08] [ 3.303533][ T1] pci_bus 0002:00: root bus resource [mem 0xbc000000-0xbeffffff] [ 3.311170][ T1] pci_bus 0002:00: root bus resource [io 0xbf800000-0xbf80ffff] [ 3.319277][ T1] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.328593][ T1] pci 0002:00:00.0: PCI bridge to [bus 01-08] [ 3.334733][ T1] pci 0002:00:00.0: BAR 8: assigned [mem 0xbc000000-0xbc7fffff] [ 3.342073][ T1] pci 0002:00:00.0: BAR 9: assigned [mem 0xbc800000-0xbc8fffff pref] [ 3.350047][ T1] pci 0002:00:00.0: BAR 7: assigned [io 0xbf800000-0xbf800fff] [ 3.357603][ T1] pci 0002:01:00.0: BAR 0: assigned [mem 0xbc000000-0xbc7fffff] [ 3.365154][ T1] pci 0002:00:00.0: PCI bridge to [bus 01] [ 3.370875][ T1] pci 0002:00:00.0: bridge window [io 0xbf800000-0xbf800fff] [ 3.378427][ T1] pci 0002:00:00.0: bridge window [mem 0xbc000000-0xbc7fffff] [ 3.385978][ T1] pci 0002:00:00.0: bridge window [mem 0xbc800000-0xbc8fffff pref] [ 3.394118][ T1] pcieport 0002:00:00.0: enabling device (0000 -> 0003) [ 3.401081][ T1] intel-pcie 18e00000.pcie: Intel AXI PCIe Root Complex Port 2 Init Done [ 3.411123][ T1] [mips_tc_init] dma_zalloc_coherent dev->name=(null) sizeof(struct mips_tc_sg_mem)=1680 shared_phy_mem=0x2380b000 [ 3.422915][ T1] [mips_tc_init] dma_zalloc_coherent shared_vir_uncached_mem=a380b000 shared_vir_cached_mem=8380b000 shared_working_vir_mem=8380b000 [ 3.436693][ T1] =MIPS TC Shared memory: a380b000 8380b000 8380b000 | Data: a3810000 [ 3.444620][ T1] UMT initialize success on processor: 0 ! [ 3.450303][ T1] HW MCPY driver: Version: 1.1.0, Init Done! [ 3.457291][ T1] 16600000.serial: ttyLTQ0 at MMIO 0x16600000 (irq = 210, base_baud = 0) is a lantiq,asc [ 3.466992][ T1] console [ttyLTQ0] enabled [ 3.466992][ T1] console [ttyLTQ0] enabled [ 3.475592][ T1] bootconsole [early0] disabled [ 3.475592][ T1] bootconsole [early0] disabled [ 3.485665][ T1] 16700000.serial: ttyLTQ1 at MMIO 0x16700000 (irq = 213, base_baud = 0) is a lantiq,asc [ 3.495628][ T29] random: crng init done [ 3.498424][ T1] avm_net_trace: Up and running. [ 3.503600][ T1] [avm_power]avm_power_pm_qos_init [ 3.508424][ T1] [loadcontrol] set auto - scale=1 [ 3.512976][ T1] [avm] configured: watchdog event debug [ 3.512981][ T1] [ 3.521425][ T1] Register push button event to receive the set_factory_kernel event [ 3.529406][ T1] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0) [ 3.536717][ T1] [grx:watchdog] start on cpu0 [ 3.540603][ C1] [grx:watchdog] start on cpu1 [ 3.545158][ C2] [grx:watchdog] start on cpu2 [ 3.549757][ C3] [grx:watchdog] start on cpu3 [ 3.556690][ T1] brd: module loaded [ 3.560380][ T1] zram: Added device: zram0 [ 3.565445][ T1] nand: device found, Manufacturer ID: 0x98, Chip ID: 0xdc [ 3.571074][ T1] nand: Toshiba NAND 512MiB 3,3V 8-bit [ 3.576346][ T1] nand: 512 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 128 [ 3.584687][ T1] try_avm_ecc_fixup: AVM ecc fixup is not yet implemented - skipping check [ 3.593107][ T1] Scanning device for bad blocks [ 3.979410][ T1] Bad eraseblock 1536 at 0x000018000000 [ 3.983484][ T1] Bad eraseblock 1537 at 0x000018040000 [ 4.114708][ T1] 5 fixed-partitions partitions found on MTD device 17c00000.nand-parts [ 4.121423][ T1] Creating 5 MTD partitions on "17c00000.nand-parts": [ 4.128032][ T1] 0x000000500000-0x000000d00000 : "kernel" [ 4.135667][ T1] 0x000000000000-0x000000100000 : "urlader" [ 4.141976][ T1] 0x000000100000-0x000000500000 : "nand-tffs" [ 4.148450][ T1] [TFFS3_Init] Called. [ 4.150912][ T1] [TFFS3_CACHE_Configure] Setting up caching for backend nand [ 4.158234][ T1] [TFFS3-CACHE] Caching module for TFFS 3.x [ 4.163944][ T1] [TFFS3-NAND] NAND storage backend for TFFS 3.x on mtd2 [ 4.309788][ T1] [TFFS3-NAND] Initialisation successful, 16/16/16 NAND blocks active, fill rate 6% [ 4.317566][ T1] tffs/panic: Reboot after panic detected [ 4.323125][ T1] [TFFS_Cache] Allocate segement buffer cache (size=4072) [ 4.332652][ T1] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0) [ 4.342762][ T1] [TFFS3-NANDSTAT][tffs_erase_stat_init] Erase counts: (min/max/mean): 1/1/1 - 0 bad blocks [ 4.351323][ T1] 0x000000d00000-0x000001500000 : "reserved-kernel" [ 4.359549][ T1] 0x000001500000-0x000020000000 : "ubi" [ 4.380864][ T1] lro_sram_membase_res0 from DT: a2013000 [ 4.385368][ T1] ltq_toe_membase: e2000000 and lro_sram_membase_res0: e2013000 [ 4.393254][ T1] TOE Init Done !! [ 5.044653][ T1] i2c /dev entries driver [ 5.049611][ T1] ltq_thermal 16000000.ssx4:ts@080000: ltq_thermal_probe: is done [ 5.060610][ T1] AVM PA 2.179-master for Linux Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 5.060610][ T1] (late init) [ 5.077255][ T1] Mirror/redirect action on [ 5.081024][ T1] u32 classifier [ 5.084360][ T1] Performance counters on [ 5.088865][ T1] input device check on [ 5.093206][ T1] Actions configured [ 5.097502][ T1] ipip: IPv4 and MPLS over IPv4 tunneling driver [ 5.104441][ T1] Initializing XFRM netlink socket [ 5.108478][ T1] IPsec XFRM device driver [ 5.114512][ T1] NET: Registered protocol family 10 [ 5.121022][ T1] NET: Registered protocol family 17 [ 5.124833][ T1] NET: Registered protocol family 15 [ 5.130182][ T1] Bridge flood ratelimiter registered [ 5.135116][ T1] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 5.148717][ T1] lec:lane_module_init: lec.c: initialized [ 5.154320][ T1] mpoa:atm_mpoa_init: mpc.c: initialized [ 5.159829][ T1] KOAM is loaded successfully. [ 5.164421][ T1] l2tp_core: L2TP core driver, V2.0 [ 5.169414][ T1] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 5.175971][ T1] l2tp_netlink: L2TP netlink interface [ 5.181068][ T1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 5.187569][ T1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 5.194963][ T1] 8021q: 802.1Q VLAN Support v1.8 [ 5.201590][ T1] audit: type=1400 audit(4.528:2): apparmor="STATUS" info="AppArmor sha1 policy hashing enabled" pid=1 comm="swapper/0" [ 5.212521][ T1] AppArmor: AppArmor sha1 policy hashing enabled [ 5.222873][ T1] ubi0: attaching mtd4 [ 5.602910][ T1] ubi0: scanning is finished [ 5.639303][ T1] ubi0: attached mtd4 (name "ubi", size 491 MiB) [ 5.644071][ T1] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [ 5.651587][ T1] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 1024 [ 5.659051][ T1] ubi0: VID header offset: 1024 (aligned 1024), data offset: 4096 [ 5.666689][ T1] ubi0: good PEBs: 1962, bad PEBs: 2, corrupted PEBs: 0 [ 5.673461][ T1] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128 [ 5.681363][ T1] ubi0: max/mean erase counter: 92/61, WL threshold: 4096, image sequence number: 1698721932 [ 5.691358][ T1] ubi0: available PEBs: 0, total reserved PEBs: 1962, PEBs reserved for bad PEB handling: 38 [ 5.701365][ T700] ubi0: background thread "ubi_bgt0d" started, PID 700 [ 5.703294][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.703316][ T1] [announce_root] filesystem (/dev/mtdblock5) will be used as root device [ 5.705115][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.706960][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.708758][ T1] Could not find Env 'linux_fs_start' in the[ 5.748956][ T1] squashfs: SQUASHFS error: unable to read id index table [ 5.759042][ T1] List of all partitions: [ 5.761883][ T1] 0100 30000 ram0 [ 5.761889][ T1] (driver?) [ 5.769296][ T1] 1f00 8192 mtdblock0 [ 5.769300][ T1] (driver?) [ 5.777189][ T1] 1f01 1024 mtdblock1 [ 5.777193][ T1] (driver?) [ 5.785057][ T1] 1f02 4096 mtdblock2 [ 5.785061][ T1] (driver?) [ 5.792960][ T1] 1f03 8192 mtdblock3 [ 5.792964][ T1] (driver?) [ 5.800858][ T1] 1f04 502784 mtdblock4 [ 5.800862][ T1] (driver?) [ 5.808756][ T1] 1f05 45108 mtdblock5 [ 5.808760][ T1] (driver?) [ 5.816657][ T1] 1f06 45108 mtdblock6 [ 5.816661][ T1] (driver?) [ 5.824554][ T1] 1f07 2268 mtdblock7 [ 5.824558][ T1] (driver?) [ 5.832464][ T1] 1f08 391356 mtdblock8 [ 5.832468][ T1] (driver?) [ 5.840351][ T1] No filesystem could mount root, tried: [ 5.840355][ T1] ext3 [ 5.845908][ T1] ext2 [ 5.848511][ T1] ext4 [ 5.851095][ T1] squashfs [ 5.853720][ T1] antfs [ 5.856671][ T1] fuseblk [ 5.859342][ T1] [ 5.864405][ T1] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,5) [ 5.873413][ T1] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.337 #1 [ 5.880091][ T1] Stack : 00000000 97910000 00000000 00000000 00000006 96ee2f0c 00000001 00000000 [ 5.889116][ T1] 00000004 00000006 00000000 00000000 00000000 00000000 97c690ba 00000034 [ 5.898144][ T1] 97c66ca8 00000000 00000000 78a9a717 97900000 9790b167 977f3388 00000000 [ 5.907172][ T1] 00000001 97c64c44 97b00000 977f14e8 fffffff3 96ee30bc 00000000 00000000 [ 5.916200][ T1] 00000006 00000000 977fba6c 9ec2bd54 97c60000 96f86094 00000000 00000000 [ 5.925228][ T1] ... [ 5.928498][ T1] Classified pointer on stack: [ 5.932956][ T1] 96ee2f0c vprintk_emit+0x498/0x624 [ 5.938142][ T1] 96ee30bc vprintk+0x24/0x30 [ 5.942459][ T1] 9ec2bd54 [stack(swapper/0): 9ec28000+0x3d54] [ 5.948414][ T1] 96f86094 printk+0x34/0x58 [ 5.952784][ T1] 9ec2bc98 [stack(swapper/0): 9ec28000+0x3c98] [ 5.958742][ T1] 9ec2bd54 [stack(swapper/0): 9ec28000+0x3d54] [ 5.964737][ T1] 9724e70c dump_stack+0x9c/0xe0 [ 5.969416][ T1] Call Trace: [ 5.972562][ T1] [<96e5d93c>] 0x96e5d93c show_stack+0x3c/0xb0 [ 5.978541][ T1] [<9724e70c>] 0x9724e70c dump_stack+0x9c/0xe0 [ 5.984542][ T1] [<96f85770>] 0x96f85770 panic+0x120/0x2a0 [ 5.990267][ T1] [<97abb4b8>] 0x97abb4b8 mount_block_root+0x348/0x390 [ 5.996971][ C1] stop_cpu_hook cpu1 - stopped status=1100fc00 [ 5.996987][ C2] stop_cpu_hook cpu2 - stopped status=1100fc00 [ 5.996992][ C3] stop_cpu_hook cpu3 - stopped status=1100fc00 [ 5.997046][ T1] avm_set_reset_status: Soft-Reboot(PANIC) - PANIC(2)UP(5)UTC(5)FW(08.20)HW(226)HWS(4)BV(1.3578)BN(122916)FS(08.20)BT(1)BD(0) [ 6.027883][ T1] Kernel relocated by 0x16950000 [ 6.032612][ T1] .text @ 0x96e50000 [ 6.036432][ T1] .data @ 0x97712874 [ 6.040251][ T1] .bss @ 0x97c60000 [ 6.068243][ T1] Rebooting in 1 seconds.. ROM VER: 2.1.0 CFG 09 B . . . * * * * * Detected PXB4583el V1.2-2000 .[piglet] Suceeded (AVM) EVA Revision: 1.3578 (C) Copyright 2005 AVM Date: Nov 27 2018 Time: 13:38:30 (1) 3 0x0-0x46409 [NAND:] 512MB TOSHIBA 4096 Pagesize 256k Blocksize 2048 Blocks HW [SYSTEM:] GRX5 (ID 0x24 Revision 2) on 1000MHz/600MHz/666MHz #Loading compressed kernel to 0x85284A30 ..................................................................................................................................................Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 ------------------------------------------- Switching to Bootcore Console ------------------------------------------- [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000000c00059638b ases 0x00000001 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 00019074 (MIPS 4KEc) [ 0.000000][ T0] MIPS: machine is GRX550 ANYWAN BOOTCORE (MIPS 4Kec) [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 02000000 @ 0e000000 (usable) [ 0.000000][ T0] memory: 00001be8 @ 0e7bc030 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 0dfc0000 (reserved) [ 0.000000][ T0] Initial ramdisk at: 0x8e000000 (4194304 bytes) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000000c0005d638b icache.flags 0x00000000 dcache.flags 0x00000004 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 16 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 16 bytes [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000000c0005d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] Normal [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] On node 0 totalpages: 8192 [ 0.000000][ T0] free_area_init_node: node 0, pgdat 8e7bb1c4, node_mem_map 8f005a00 [ 0.000000][ T0] Normal zone: 64 pages used for memmap [ 0.000000][ T0] Normal zone: 0 pages reserved [ 0.000000][ T0] Normal zone: 8192 pages, LIFO batch:0 [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000][ T0] pcpu-alloc: [0] 0 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200n8r root=/dev/ram rw loglevel=8 [ 0.000000][ T0] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Memory: 23752K/32768K available (2931K kernel code, 461K rwdata, 680K rodata, 208K init, 262K bss, 9016K reserved, 0K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] grx500_bootcore_register_static_irq: irq_in = 0x0000001f, irq_out = 0x0000001f [ 0.000000][ T0] grx500_bootcore_register_static_irq: mapper_reg = 0x0000015c, mapper_offset = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: int_line = 0x0000001f, map_address = 0x0000015c, num = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x0000001f [ 0.000000][ T0] CPU Clock: 300MHz [ 0.000000][ T0] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns [ 0.000019][ T0] sched_clock: 32 bits at 150MHz, resolution 6ns, wraps every 14316557820ns [ 0.016984][ T0] : grx500_bootcore_console_init: call register [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.041328][ T0] bootconsole [early0] disabled [ 0.041328][ T0] bootconsole [early0] disabled [ 0.054925][ T0] bootconsole [early0] disabled [ 0.054925][ T0] bootconsole [early0] disabled [ 0.064275][ T0] Calibrating delay loop... 299.26 BogoMIPS (lpj=598528) [ 0.107038][ T0] pid_max: default: 32768 minimum: 301 [ 0.113272][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.120427][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.134930][ T1] Performance counters: No available PMU. [ 0.143961][ T1] devtmpfs: initialized [ 0.153260][ T1] ngi: Protecting Bootcore: [0x2e000000, 0x2fffffff] [ 0.159674][ T1] ngi: 512MB attached. Protecting: [0x40000000, 0x9fffffff] [ 0.166686][ T1] ngi: Unattached: [0x60000000, 0x9fffffff] [ 0.172388][ T1] ngi: Unattached: [0x40000000, 0x5fffffff] [ 0.178814][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.189150][ T1] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.196249][ T1] pinctrl core: initialized pinctrl subsystem [ 0.204964][ T1] NET: Registered protocol family 16 [ 0.227424][ T1] irq: no irq domain found for /interrupt-controller@0x14900140 ! [ 0.327921][ T1] clocksource: Switched to clocksource MIPS [ 0.356455][ T1] NET: Registered protocol family 2 [ 0.361970][ T1] IP idents hash table entries: 2048 (order: 2, 16384 bytes) [ 0.371089][ T1] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.378777][ T1] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.385707][ T1] TCP: Hash tables configured (established 1024 bind 1024) [ 0.393254][ T1] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.399764][ T1] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.407191][ T1] NET: Registered protocol family 1 [ 0.416408][ T1] Unpacking initramfs... [ 1.158764][ T1] Freeing initrd memory: 4096K [ 1.166032][ T1] No memory allocated for crashlog [ 1.179198][ T1] workingset: timestamp_bits=30 max_order=13 bucket_order=0 [ 1.260862][ T1] Serial: grx500_bootcore driver init [ 1.274812][ T1] NET: Registered protocol family 10 [ 1.292923][ T1] NET: Registered protocol family 17 [ 1.306302][ T1] Serial: grx500_bootcore driver startup [ 1.311773][ T1] grx500_bootcore_register_static_irq: irq_in = 0x0000001c, irq_out = 0x00000008 [ 1.320523][ T1] grx500_bootcore_register_static_irq: mapper_reg = 0x00000158, mapper_offset = 0x00000003 [ 1.330280][ T1] EXCEP_remap_line: int_line = 0x00000008, map_address = 0x00000158, num = 0x00000003 [ 1.339695][ T1] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x00040000 [ 1.352796][ T1] Freeing unused kernel memory: 208K [ 1.357839][ T1] This architecture does not have kernel memory protection. [ 1.596842][ T195] eip123_hw: module license 'Proprietary' taints kernel. [ 1.603650][ T195] Disabling lock debugging due to kernel taint [ 1.614962][ T195] eip123: no symbol version for eip123_hw_asset_derive [ 1.623449][ T195] eip123 1e000000.eip123: Detected hardware version 2.2.2 [ 1.630397][ T195] eip123 1e000000.eip123: my_id=0 master_id=0 num_mailboxes=4 mailbox_size=256 [ 1.638983][ T195] eip123 1e000000.eip123: Configured mailbox lockout: 0x00000000 [ 1.646497][ T195] eip123 1e000000.eip123: Linked mailbox number 1 [ 1.679988][ T195] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=0 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0 [ 1.915923][ T195] eip123 1e000000.eip123: eip123_hw init successful [ 1.975953][ T195] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c [ 1.985060][ T195] eip123 1e000000.eip123: Could not find rootkey in OTP [ 2.020137][ T198] random: crng init done [ 2.025060][ T110] shm-rng-seed shm-rng-seed@3dfb0000: Added 4088 random bytes to the shared memory area [ 3.788631][ T262] eip123 1e000000.eip123: Unlinked mailboxes [ 3.806009][ T181] interaptiv_start: starting interaptiv zC…KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKC…C…C…C… Switching to Interaptiv Console ------------------------------------------- .. Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 [ 0.000000][ T0] shm-rng-seed-mem@3dfb0000: Added 4088 random bytes to the system pool [ 0.000000][ T0] OF: fdt:[0x383f0000, 0x396b3b70) is not contained in the RAM region at [0x20000000, 0x2e000000) [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e69638b ases 0x00000030 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.000000][ T0] Enhanced Virtual Addressing (EVA Legacy 512MB) activated [ 0.000000][ T0] MIPS: machine is AVM7590 (GRX550, HW226) Main model [ 0.000000][ T0] Coherence Manager IOCU detected [ 0.000000][ T0] Hardware DMA cache coherency disabled [ 0.000000][ T0] OF: reserved mem: initialized node shm-rng-seed-mem@3dfb0000, compatible id avm,shm-rng-seed-early [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'urlader': base 0x20010000, size 0x00030000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'VMB': base 0x20000000, size 0x00001000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'avm_reboot_string': base 0x20001000, size 0x00000200 [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 10000000 @ 30000000 (usable) [ 0.000000][ T0] memory: 0e000000 @ 20000000 (usable) [ 0.000000][ T0] memory: 0000cf68 @ 3901a038 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 2dfc0000 (reserved) [ 0.000000][ T0] memory: 00400000 @ 20100000 (reserved) [ 0.000000][ T0] memory: 00030000 @ 20010000 (reserved) [ 0.000000][ T0] memory: 00001200 @ 20000000 (reserved) [ 0.000000][ T0] Kernel relocated by 0x17ef0000 [ 0.000000][ T0] .text @ 0x983f0000 [ 0.000000][ T0] .data @ 0x98cb2874 [ 0.000000][ T0] .bss @ 0x99200000 [ 0.000000][ T0] Initrd not found or empty - disabling initrd [ 0.000000][ T0] cma: Reserved 64 MiB at 0x24000000 [ 0.000000][ T0] SMPCMP: initialized the EVA stub code: 400@0x28029480 [ 0.000000][ T0] SMPCMP: CPU0: cmp_smp_setup [ 0.000000][ T0] VPE topology {2,2} total 4 [ 0.000000][ T0] Detected 3 available secondary CPU(s) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.000000][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] DMA [mem 0x0000000020000000-0x0000000027ffffff] [ 0.000000][ T0] Normal [mem 0x0000000028000000-0x000000003fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x0000000020000000-0x000000002dffffff] [ 0.000000][ T0] node 0: [mem 0x0000000030000000-0x000000003fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x0000000020000000-0x000000003fffffff] [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] [module-mem] Use 0x3d2db000-0x3de27fff (mapped at 9d2db000-9de27fff) for 95 modules [ 0.000000][ T0] percpu: Embedded 12 pages/cpu s18288 r8192 d22672 u49152 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121728 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200 pcmlink.abmode=0x8103 Piglet_noemif.piglet_dectmode=0x110 Piglet_noemif.piglet_bitfile=bitfile.bit audit=1 slub_debug=fl [ 0.000000][ T0] audit: enabled (after initialization) [ 0.000000][ T0] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000][ T0] Writing ErrCtl register=00000000 [ 0.000000][ T0] Readback ErrCtl register=00000000 [ 0.000000][ T0] Memory: 385240K/491520K available (8745K kernel code, 1849K rwdata, 1892K rodata, 1688K init, 4814K bss, 40744K reserved, 65536K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000][ T0] Hierarchical RCU implementation. [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] EIC is off [ 0.000000][ T0] VINT is on [ 0.000000][ T0] CPU Clock: 1000000000Hz mips_hpt_frequency 500000000Hz [ 0.000000][ T0] clocksource: gptc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302233 ns [ 0.010149][ T0] Calibrating delay loop... 718.84 BogoMIPS (lpj=1437696) [ 0.046809][ T0] pid_max: default: 32768 minimum: 301 [ 0.052304][ T0] Security Framework initialized [ 0.057085][ T0] AppArmor: AppArmor initialized [ 0.061977][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.069297][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.078847][ T1] CCA is coherent, multi-core is fine [ 0.084504][ T1] avm_register_cpuid: cpu_id=0: LINUX core=0 tc=0 [ 0.090742][ T1] Performance counters: mips/interAptiv PMU enabled, 2 32-bit counters available to each CPU, irq 9 GOT IPI to launch from CPU 1 GOT IPI to launch from CPU 2 GOT IPI to launch from CPU 3 [ 0.109268][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.109313][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.109318][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.109338][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.109344][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.109350][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.109361][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.109365][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.109565][ T0] CPU1 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.139602][ T0] avm_register_cpuid: cpu_id=1: LINUX core=0 tc=1 [ 0.142049][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.142086][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.142090][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.142109][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.142115][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.142121][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.142131][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.142136][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.142271][ T0] CPU2 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.169881][ T0] avm_register_cpuid: cpu_id=2: LINUX core=1 tc=0 [ 0.172359][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.172395][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.172399][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.172417][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.172423][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.172428][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.172438][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.172442][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.172575][ T0] CPU3 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.200184][ T0] avm_register_cpuid: cpu_id=3: LINUX core=1 tc=1 [ 0.200452][ T1] Brought up 4 CPUs [ 0.470632][ T1] avm_yield_setup: YIELD_PCMFRAME_ID : id=0x0004000f: cpu=0 tc=4 prio=3 signal=15 [ 0.480262][ T1] avm_yield_setup: YIELD_PCMLINK_ID : id=0x0003000c: cpu=0 tc=3 prio=2 signal=12 [ 0.489897][ T1] avm_yield_setup: YIELD_MONITOR_IPI0_ID : id=0x0002000e: cpu=0 tc=2 prio=1 signal=14 [ 0.499532][ T1] avm_yield_setup: YIELD_PROFILE_IPI0_ID : id=0x0002000d: cpu=0 tc=2 prio=1 signal=13 [ 0.509168][ T1] avm_yield_setup: YIELD_GPTC_ID : id=0x0005000b: cpu=0 tc=5 prio=3 signal=11 [ 0.519336][ T3] [0][yield_context_init] cpu=0 tc=2 mask=6000 tc_prio=1 [ 0.526477][ T29] [0][yield_context_init] cpu=0 tc=3 mask=1000 tc_prio=2 [ 0.533642][ T29] [0][yield_context_init] cpu=0 tc=4 mask=8000 tc_prio=3 [ 0.540755][ T29] [0][yield_context_init] cpu=0 tc=5 mask=0800 tc_prio=3 [ 0.547760][ T1] avm_yield_setup: YIELD_MONITOR_IPI1_ID : id=0x0202000e: cpu=2 tc=2 prio=1 signal=14 [ 0.557212][ T1] avm_yield_setup: YIELD_PROFILE_IPI1_ID : id=0x0202000d: cpu=2 tc=2 prio=1 signal=13 [ 0.567250][ T21] [2][yield_context_init] cpu=2 tc=2 mask=6000 tc_prio=1 [ 0.575104][ T1] devtmpfs: initialized [ 0.594381][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.604907][ T1] futex hash table entries: 1024 (order: 3, 32768 bytes) [ 0.616580][ T1] pinctrl core: initialized pinctrl subsystem [ 0.624037][ T1] NET: Registered protocol family 16 [ 0.633654][ T1] dma-grx500 1e300000.dma: dma3 base address be300000 chained_irq 29 irq_base 30 [ 0.645525][ T1] dma-grx500 1e300000.dma: Init done - rev: a, ports: 1, channels: 64 [ 0.655996][ T1] dma-grx500 1c100000.dma: dma2tx base address bc100000 chained_irq 100 irq_base 101 [ 0.666855][ T1] dma-grx500 1c100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.675334][ T1] dma-grx500 1c200000.dma: dma2rx base address bc200000 chained_irq 117 irq_base 118 [ 0.686673][ T1] dma-grx500 1c200000.dma: Init done - rev: a, ports: 1, channels: 32 [ 0.695708][ T1] dma-grx500 1a100000.dma: dma1tx base address ba100000 chained_irq 150 irq_base 151 [ 0.706616][ T1] dma-grx500 1a100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.715002][ T1] dma-grx500 1a200000.dma: dma1rx base address ba200000 chained_irq 167 irq_base 168 [ 0.725725][ T1] dma-grx500 1a200000.dma: Init done - rev: a, ports: 1, channels: 12 [ 0.740528][ T1] dma0-grx500 16e00000.dma: base address b6e00000 chained_irq 218 irq_base 219 [ 0.749264][ T1] dma0-grx500 16e00000.dma: Init done - hw rev: A, ports: 4, channels: 16 [ 0.757927][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 0, reg: 0xb6c80000, pinbase: 0, pin number: 32, pinmap: 0xf1efefff [ 0.769587][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 1, reg: 0xb6c80100, pinbase: 32, pin number: 32, pinmap: 0x3bff0c1f [ 0.781721][ T1] intel-pinctrl 16c80000.pinctrl: Total 14 groups, 12 functions [ 0.790104][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00000 [ 0.798120][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00100 [ 0.814270][ T1] gic_timer_probe [ 0.817785][ T1] gic_timer_probe: irq=287 freq=1000000000 [ 0.858810][ T1] avm_alloc_page_extension node_extension_table[0] entries=131072 (size=524288) alloced [ 0.868886][ T1] Reboot Status is: Soft-Reboot(PANIC) PANIC(2) [ 0.874969][ T1] Unable to get node cqm for prx300-cqm [ 0.880287][ T1] add_cqm_dev(#152): parse_dts fail for prx300-cqm [ 0.886884][ T1] No rcu reset for cbm [ 0.890702][ T1] No syscon phandle specified for wan mux [ 0.896348][ T1] Invalid args in ltq_dqm_ports [ 0.901115][ T1] Invalid args in ltq_eqm_ports [ 0.975954][ T1] [cbm] { cbm_xrx500_probe : 5697 }reserving 18874368 bytes @ 84000000 for CBM [ 1.015737][ T1] [cbm] { cbm_xrx500_probe : 5707 }reserving 8388608 bytes @ 85200000 for CBM [ 1.024369][ T1] [cbm] { cbm_xrx500_probe : 5722 }94 irq [ 1.030096][ T1] [cbm] { cbm_xrx500_probe : 5745 }2 [ 1.035235][ T1] [drv_tmu_ll] { get_cbm_clock : 7605 }CBM Clock: 0Hz=0MHZ [ 1.042342][ T1] [drv_tmu_ll] { get_cbm_clock : 7608 }Wrong cbm clock [ 1.049114][ T1] Initializing TMU with Base Address=be700000: ... [ 1.058364][ T1] TMU Initialization Done [ 1.062396][ T1] 0x84000000 0x1200000 0x800 [ 1.066908][ T1] 0x84000000 0x1200000 [ 1.070891][ T1] 0x85200000 0x800000 0x2000 [ 1.075407][ T1] 0x85200000 0x800000 [ 1.079626][ T1] [cbm] { init_fsqm_buf_std : 1173 }init fsqm std successfully [ 1.086881][ T1] [cbm] { init_fsqm_buf_jumbo : 1213 }init fsqm jbo successfully [ 1.094484][ T1] [cbm] { init_fsqm : 1236 }fsqm init successfully [ 1.100909][ T1] [cbm] { init_cbm_basic : 1271 }PHY ADDR STD 0x24000000 [ 1.107852][ T1] [cbm] { init_cbm_basic : 1272 }PHY ADDR JBO 0x25200000 [ 1.115041][ T1] [cbm] { init_cbm_basic : 1290 }init basic CBM successfully [ 1.122100][ T1] [cbm] { cbm_hw_init : 2206 }CBM HW init [ 1.127862][ T1] [cbm] { setup_DMA_p2p : 5102 }setup_DMA_p2p executed [ 1.134516][ T1] [cbm] { reserved_ports_highest : 5161 }2 2 19 35 [ 1.140941][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.146616][ T1] [cbm] { assign_port_from_DT : 654 }0x0 2 [ 1.152309][ T1] [cbm] { assign_port_from_DT : 654 }0x20 2 [ 1.158300][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.163161][ T1] [cbm] { reserved_ports_highest : 5161 }1 1 18 34 [ 1.169582][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.175232][ T1] [cbm] { assign_port_from_DT : 654 }0x80 1 [ 1.181039][ T1] [cbm] { reserved_ports_highest : 5161 }3 3 20 36 [ 1.187460][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.193111][ T1] [cbm] { assign_port_from_DT : 654 }0x2000000 3 [ 1.199353][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.204395][ T1] [cbm] { reserved_ports_highest : 5161 }6 6 0 16 [ 1.210726][ T1] [cbm] { dma_port_enable : 4670 }6 0x4 [ 1.216202][ T1] [cbm] { reserved_ports_highest : 5161 }7 7 1 17 [ 1.222534][ T1] [cbm] { dma_port_enable : 4670 }7 0x4 [ 1.228012][ T1] [cbm] { reserved_ports_highest : 5161 }8 8 2 18 [ 1.234337][ T1] [cbm] { dma_port_enable : 4670 }8 0x4 [ 1.239812][ T1] [cbm] { reserved_ports_highest : 5161 }9 9 3 19 [ 1.246140][ T1] [cbm] { dma_port_enable : 4670 }9 0x4 [ 1.251617][ T1] [cbm] { reserved_ports_highest : 5161 }10 10 4 20 [ 1.258118][ T1] [cbm] { dma_port_enable : 4670 }10 0x4 [ 1.263682][ T1] [cbm] { reserved_ports_highest : 5161 }11 11 5 21 [ 1.270183][ T1] [cbm] { dma_port_enable : 4670 }11 0x4 [ 1.275748][ T1] [cbm] { reserved_ports_highest : 5161 }12 12 6 22 [ 1.282249][ T1] [cbm] { dma_port_enable : 4670 }12 0x4 [ 1.287813][ T1] [cbm] { reserved_ports_highest : 5161 }13 13 7 23 [ 1.294315][ T1] [cbm] { dma_port_enable : 4670 }13 0x4 [ 1.299879][ T1] [cbm] { reserved_ports_highest : 5161 }14 14 8 24 [ 1.306385][ T1] [cbm] { dma_port_enable : 4670 }14 0x4 [ 1.311951][ T1] [cbm] { reserved_ports_highest : 5161 }15 15 9 25 [ 1.318448][ T1] [cbm] { dma_port_enable : 4670 }15 0x4 [ 1.324010][ T1] [cbm] { reserved_ports_highest : 5161 }16 16 10 26 [ 1.330598][ T1] [cbm] { dma_port_enable : 4670 }16 0x4 [ 1.336162][ T1] [cbm] { reserved_ports_highest : 5161 }17 17 11 27 [ 1.342751][ T1] [cbm] { dma_port_enable : 4670 }17 0x4 [ 1.348315][ T1] [cbm] { reserved_ports_highest : 5161 }18 18 -16 0 [ 1.354904][ T1] [cbm] { dma_port_enable : 4670 }18 0x4 [ 1.360484][ T1] [cbm] { reserved_ports_highest : 5161 }19 19 12 28 [ 1.367056][ T1] [cbm] { dma_port_enable : 4670 }19 0x4 [ 1.372620][ T1] [cbm] { reserved_ports_highest : 5161 }20 20 13 29 [ 1.379208][ T1] [cbm] { dma_port_enable : 4670 }20 0x4 [ 1.384771][ T1] [cbm] { init_special_ports : 5168 }20 [ 1.390280][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.395271][ T1] [cbm] { reserved_ports_highest : 5161 }21 21 14 30 [ 1.401862][ T1] [cbm] { dma_port_enable : 4670 }21 0x4 [ 1.407429][ T1] [cbm] { init_special_ports : 5168 }21 [ 1.412886][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.417923][ T1] [cbm] { reserved_ports_highest : 5161 }22 22 25 41 [ 1.424518][ T1] [cbm] { dma_port_enable : 4670 }22 0x4 [ 1.430085][ T1] [cbm] { reserved_ports_highest : 5161 }23 23 15 31 [ 1.436670][ T1] [cbm] { init_cbm_dqm_ldma_port : 1476 }23 [ 1.442498][ T1] [cbm] { reserved_ports_highest : 5161 }5 5 21 37 [ 1.448910][ T1] [cbm] { init_cbm_dqm_scpu_port : 1457 }5 [ 1.454822][ T1] [cbm] { reserved_ports_highest : 5161 }4 4 16 32 [ 1.461061][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }4 [ 1.466715][ T1] [cbm] { assign_port_from_DT : 654 }0x18 4 [ 1.472526][ T1] [cbm] { reserved_ports_highest : 5161 }24 24 22 38 [ 1.479116][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }24 [ 1.484854][ T1] [cbm] { assign_port_from_DT : 654 }0x8 24 [ 1.490664][ T1] [cbm] { reserved_ports_highest : 5161 }25 25 23 39 [ 1.497257][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }25 [ 1.502998][ T1] [cbm] { assign_port_from_DT : 654 }0x8 25 [ 1.508804][ T1] [cbm] { reserved_ports_highest : 5161 }26 26 24 40 [ 1.515401][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }26 [ 1.521138][ T1] [cbm] { assign_port_from_DT : 654 }0x8 26 [ 1.526947][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }0 [ 1.532590][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }1 [ 1.538229][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }2 [ 1.543871][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }3 [ 1.549516][ T1] [cbm] { dma_port_enable : 4670 }5 0x1 [ 1.554989][ T1] [cbm] { dma_port_enable : 4670 }5 0x2 [ 1.560454][ T1] [cbm] { dma_port_enable : 4670 }6 0x1 [ 1.565920][ T1] [cbm] { dma_port_enable : 4670 }6 0x2 [ 1.571391][ T1] [cbm] { dma_port_enable : 4670 }7 0x1 [ 1.576863][ T1] [cbm] { dma_port_enable : 4670 }7 0x2 [ 1.582328][ T1] [cbm] { dma_port_enable : 4670 }8 0x1 [ 1.587794][ T1] [cbm] { dma_port_enable : 4670 }8 0x2 [ 1.593265][ T1] [cbm] { dma_toe_port_enable : 4697 }9 0x1 [ 1.599079][ T1] [cbm] { dma_vrx318_port_enable : 4709 }15 0x1 [ 1.605253][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }0 [ 1.610882][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.616525][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.622166][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.627813][ T1] Load spreader init successfully [ 1.632916][ T1] [cbm] { cbm_xrx500_probe : 5801 }CBM Clock: 0Hz [ 1.639099][ T1] [cbm] { cbm_xrx500_probe : 5803 }EQM delay Enabled [ 1.645692][ T1] [cbm] { igp_delay_set : 4782 }port0 delay16 [ 1.651681][ T1] [cbm] { igp_delay_set : 4782 }port1 delay16 [ 1.657669][ T1] [cbm] { igp_delay_set : 4782 }port2 delay16 [ 1.663659][ T1] [cbm] { igp_delay_set : 4782 }port3 delay16 [ 1.669647][ T1] [cbm] { igp_delay_set : 4782 }port4 delay16 [ 1.675639][ T1] [cbm] { igp_delay_set : 4782 }port5 delay16 [ 1.681626][ T1] [cbm] { igp_delay_set : 4782 }port6 delay16 [ 1.687617][ T1] [cbm] { igp_delay_set : 4782 }port7 delay16 [ 1.693605][ T1] [cbm] { igp_delay_set : 4782 }port8 delay16 [ 1.699596][ T1] [cbm] { igp_delay_set : 4782 }port9 delay16 [ 1.705584][ T1] [cbm] { igp_delay_set : 4782 }port10 delay16 [ 1.711661][ T1] [cbm] { igp_delay_set : 4782 }port11 delay16 [ 1.717736][ T1] [cbm] { igp_delay_set : 4782 }port12 delay16 [ 1.723813][ T1] [cbm] { igp_delay_set : 4782 }port13 delay16 [ 1.729888][ T1] [cbm] { igp_delay_set : 4782 }port14 delay16 [ 1.735966][ T1] [cbm] { igp_delay_set : 4782 }port15 delay16 [ 1.742044][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x2 2 0 30 [ 1.748660][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x1 2 14 0 [ 1.755241][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x2 2 0 31 [ 1.761840][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x1 2 15 0 [ 1.768434][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x2 1 0 6 [ 1.774947][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x1 1 0 0 [ 1.781454][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x2 1 0 11 [ 1.788054][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x1 1 5 0 [ 1.794600][ T1] [cbm] { cbm_xrx500_probe : 5850 }CBM: Init Done !! [ 1.795773][ T1] pstore: using zlib compression [ 1.807086][ T1] pstore: Registered ramoops as persistent store backend [ 1.813955][ T1] ramoops: attached 0x400000@0x20100000, ecc: 0/0 [ 1.852206][ T1] SCSI subsystem initialized [ 1.857273][ T1] usbcore: registered new interface driver usbfs [ 1.863575][ T1] usbcore: registered new interface driver hub [ 1.869559][ T1] usbcore: registered new device driver usb [ 1.875969][ T1] mp8864 0-0068: MP8864 probe started. [ 1.886223][ T1] mp8864 0-0068: [MP8864 Init] Status is 0x11 Vsel is 0x37 Syscntl is 0xe5 [ 1.894521][ T1] i2c-gpio i2c: using pins 501 (SDA) and 502 (SCL) [ 1.901097][ T1] try to register spd_mon driver [ 1.901341][ T1] spdmon 16080110.speedm: base address: 0xb6080110 [ 1.912484][ T1] spdmon 16080110.speedm: PHY base address: 0x16080110 [ 1.919561][ T1] spdmon 16080110.speedm: spd_mon driver : init done !! [ 1.930753][ T1] spd_mon driver registered [ 1.936248][ T1] AVM PA for Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 1.936248][ T1] (early init) [ 1.952761][ T1] NET: Registered protocol family 8 [ 1.957727][ T1] NET: Registered protocol family 20 [ 1.963420][ T1] clocksource: Switched to clocksource gptc [ 1.993544][ T1] AppArmor: AppArmor Filesystem Enabled [ 2.002522][ T1] NET: Registered protocol family 2 [ 2.007705][ T1] IP idents hash table entries: 8192 (order: 4, 65536 bytes) [ 2.031886][ T1] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 2.039570][ T1] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.046758][ T1] TCP: Hash tables configured (established 4096 bind 4096) [ 2.053914][ T1] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.060431][ T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.067748][ T1] NET: Registered protocol family 1 [ 2.074454][ T1] yield_probe: cpu 0 irq 275 [ 2.078973][ T1] yield_probe: cpu 1 irq 276 [ 2.083305][ T1] yield_probe: cpu 2 irq 277 [ 2.087823][ T1] yield_probe: cpu 3 irq 278 [ 2.092331][ T1] yield_probe: interrupts set up [ 2.099550][ T1] audit: initializing netlink subsys (enabled) [ 2.105566][ T1] audit: type=2000 audit(1.432:1): initialized [ 2.111964][ T1] No memory allocated for crashlog [ 2.117334][ T1] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 2.150487][ T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.156909][ T1] ANTFS Module: Version 2.56 [ 2.161650][ T1] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 2.174103][ T1] fuse init (API version 7.26) [ 2.187816][ T1] io scheduler noop registered [ 2.192307][ T1] io scheduler deadline registered (default) [ 2.198694][ T1] bthelper_probe: core 0 initialized [ 2.203713][ T1] bthelper_probe: core 1 initialized [ 2.211103][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe slim phy[0] init success! [ 2.219856][ T1] intel-pcie-slim-phy 18000000.pciephy: PCIe slim phy[1] init success! [ 2.228231][ T1] intel-pcie-slim-phy 18a00000.pciephy: PCIe slim phy[2] init success! [ 2.236726][ T1] 1a400000.phy supply vbus not found, using dummy regulator [ 2.244208][ T1] 1a600000.phy supply vbus not found, using dummy regulator [ 2.363434][ T1] OF: PCI: host bridge /pcie@18900000 ranges: [ 2.369253][ T1] OF: PCI: MEM 0xb8000000..0xbaffffff -> 0xb8000000 [ 2.375901][ T1] OF: PCI: IO 0xbb800000..0xbb80ffff -> 0xbb800000 [ 2.384930][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe LCPLL SSC Mode Enabled [ 2.526449][ T1] intel-pcie 18900000.pcie: PCI host bridge to bus 0000:00 [ 2.533383][ T1] pci_bus 0000:00: root bus resource [bus 00-08] [ 2.539595][ T1] pci_bus 0000:00: root bus resource [mem 0xb8000000-0xbaffffff] [ 2.547230][ T1] pci_bus 0000:00: root bus resource [io 0xbb800000-0xbb80ffff] [ 2.555335][ T1] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.564624][ T1] pci 0000:00:00.0: PCI bridge to [bus 01-08] [ 2.570678][ T1] pci 0000:00:00.0: BAR 8: assigned [mem 0xb8000000-0xb81fffff] [ 2.578020][ T1] pci 0000:00:00.0: BAR 9: assigned [mem 0xb8200000-0xb82fffff pref] [ 2.585994][ T1] pci 0000:00:00.0: BAR 7: assigned [io 0xbb800000-0xbb800fff] [ 2.593550][ T1] pci 0000:01:00.0: BAR 0: assigned [mem 0xb8000000-0xb81fffff 64bit] [ 2.601629][ T1] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.607343][ T1] pci 0000:00:00.0: bridge window [io 0xbb800000-0xbb800fff] [ 2.614896][ T1] pci 0000:00:00.0: bridge window [mem 0xb8000000-0xb81fffff] [ 2.622446][ T1] pci 0000:00:00.0: bridge window [mem 0xb8200000-0xb82fffff pref] [ 2.630589][ T1] pcieport 0000:00:00.0: enabling device (0000 -> 0003) [ 2.637540][ T1] intel-pcie 18900000.pcie: Intel AXI PCIe Root Complex Port 0 Init Done [ 2.751443][ T1] OF: PCI: host bridge /pcie@18400000 ranges: [ 2.757241][ T1] OF: PCI: MEM 0xb4000000..0xb6ffffff -> 0xb4000000 [ 2.763899][ T1] OF: PCI: IO 0xb7800000..0xb780ffff -> 0xb7800000 [ 2.771711][ T1] intel-pcie-slim-phy 18000000.pciephy: SSC has been enabled, count: 2! [ 2.914371][ T1] intel-pcie 18400000.pcie: PCI host bridge to bus 0001:00 [ 2.921306][ T1] pci_bus 0001:00: root bus resource [bus 00-08] [ 2.927515][ T1] pci_bus 0001:00: root bus resource [mem 0xb4000000-0xb6ffffff] [ 2.935151][ T1] pci_bus 0001:00: root bus resource [io 0xb7800000-0xb780ffff] [ 2.943257][ T1] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.952538][ T1] pci 0001:00:00.0: PCI bridge to [bus 01-08] [ 2.958644][ T1] pci 0001:00:00.0: BAR 8: assigned [mem 0xb4000000-0xb41fffff] [ 2.965984][ T1] pci 0001:00:00.0: BAR 9: assigned [mem 0xb4200000-0xb42fffff pref] [ 2.973959][ T1] pci 0001:00:00.0: BAR 7: assigned [io 0xb7800000-0xb7800fff] [ 2.981514][ T1] pci 0001:01:00.0: BAR 0: assigned [mem 0xb4000000-0xb41fffff 64bit] [ 2.989593][ T1] pci 0001:00:00.0: PCI bridge to [bus 01] [ 2.995307][ T1] pci 0001:00:00.0: bridge window [io 0xb7800000-0xb7800fff] [ 3.002861][ T1] pci 0001:00:00.0: bridge window [mem 0xb4000000-0xb41fffff] [ 3.010411][ T1] pci 0001:00:00.0: bridge window [mem 0xb4200000-0xb42fffff pref] [ 3.018588][ T1] pcieport 0001:00:00.0: enabling device (0000 -> 0003) [ 3.025476][ T1] intel-pcie 18400000.pcie: Intel AXI PCIe Root Complex Port 1 Init Done [ 3.139434][ T1] OF: PCI: host bridge /pcie@18e00000 ranges: [ 3.145230][ T1] OF: PCI: MEM 0xbc000000..0xbeffffff -> 0xbc000000 [ 3.151891][ T1] OF: PCI: IO 0xbf800000..0xbf80ffff -> 0xbf800000 [ 3.159736][ T1] intel-pcie-slim-phy 18a00000.pciephy: SSC has been enabled, count: 3! [ 3.289751][ T1] intel-pcie 18e00000.pcie: PCI host bridge to bus 0002:00 [ 3.296682][ T1] pci_bus 0002:00: root bus resource [bus 00-08] [ 3.302892][ T1] pci_bus 0002:00: root bus resource [mem 0xbc000000-0xbeffffff] [ 3.310530][ T1] pci_bus 0002:00: root bus resource [io 0xbf800000-0xbf80ffff] [ 3.318636][ T1] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.327950][ T1] pci 0002:00:00.0: PCI bridge to [bus 01-08] [ 3.334090][ T1] pci 0002:00:00.0: BAR 8: assigned [mem 0xbc000000-0xbc7fffff] [ 3.341433][ T1] pci 0002:00:00.0: BAR 9: assigned [mem 0xbc800000-0xbc8fffff pref] [ 3.349407][ T1] pci 0002:00:00.0: BAR 7: assigned [io 0xbf800000-0xbf800fff] [ 3.356962][ T1] pci 0002:01:00.0: BAR 0: assigned [mem 0xbc000000-0xbc7fffff] [ 3.364513][ T1] pci 0002:00:00.0: PCI bridge to [bus 01] [ 3.370233][ T1] pci 0002:00:00.0: bridge window [io 0xbf800000-0xbf800fff] [ 3.377788][ T1] pci 0002:00:00.0: bridge window [mem 0xbc000000-0xbc7fffff] [ 3.385338][ T1] pci 0002:00:00.0: bridge window [mem 0xbc800000-0xbc8fffff pref] [ 3.393479][ T1] pcieport 0002:00:00.0: enabling device (0000 -> 0003) [ 3.400438][ T1] intel-pcie 18e00000.pcie: Intel AXI PCIe Root Complex Port 2 Init Done [ 3.410456][ T1] [mips_tc_init] dma_zalloc_coherent dev->name=(null) sizeof(struct mips_tc_sg_mem)=1680 shared_phy_mem=0x2380b000 [ 3.422247][ T1] [mips_tc_init] dma_zalloc_coherent shared_vir_uncached_mem=a380b000 shared_vir_cached_mem=8380b000 shared_working_vir_mem=8380b000 [ 3.436021][ T1] =MIPS TC Shared memory: a380b000 8380b000 8380b000 | Data: a3810000 [ 3.443958][ T1] UMT initialize success on processor: 0 ! [ 3.449665][ T1] HW MCPY driver: Version: 1.1.0, Init Done! [ 3.456592][ T1] 16600000.serial: ttyLTQ0 at MMIO 0x16600000 (irq = 210, base_baud = 0) is a lantiq,asc [ 3.466403][ T1] console [ttyLTQ0] enabled [ 3.466403][ T1] console [ttyLTQ0] enabled [ 3.475050][ T1] bootconsole [early0] disabled [ 3.475050][ T1] bootconsole [early0] disabled [ 3.485187][ T1] 16700000.serial: ttyLTQ1 at MMIO 0x16700000 (irq = 213, base_baud = 0) is a lantiq,asc [ 3.494951][ T542] random: crng init done [ 3.497744][ T1] avm_net_trace: Up and running. [ 3.502922][ T1] [avm_power]avm_power_pm_qos_init [ 3.507776][ T1] [loadcontrol] set auto - scale=1 [ 3.512293][ T1] [avm] configured: watchdog event debug [ 3.512299][ T1] [ 3.520623][ T1] Register push button event to receive the set_factory_kernel event [ 3.528710][ T1] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0) [ 3.536138][ C0] [grx:watchdog] start on cpu0 [ 3.539883][ C1] [grx:watchdog] start on cpu1 [ 3.544479][ C2] [grx:watchdog] start on cpu2 [ 3.549071][ T1] [grx:watchdog] start on cpu3 [ 3.556274][ T1] brd: module loaded [ 3.559935][ T1] zram: Added device: zram0 [ 3.565138][ T1] nand: device found, Manufacturer ID: 0x98, Chip ID: 0xdc [ 3.570775][ T1] nand: Toshiba NAND 512MiB 3,3V 8-bit [ 3.576038][ T1] nand: 512 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 128 [ 3.584382][ T1] try_avm_ecc_fixup: AVM ecc fixup is not yet implemented - skipping check [ 3.592810][ T1] Scanning device for bad blocks [ 3.975927][ T1] Bad eraseblock 1536 at 0x000018000000 [ 3.979995][ T1] Bad eraseblock 1537 at 0x000018040000 [ 4.111428][ T1] 5 fixed-partitions partitions found on MTD device 17c00000.nand-parts [ 4.118140][ T1] Creating 5 MTD partitions on "17c00000.nand-parts": [ 4.124780][ T1] 0x000000500000-0x000000d00000 : "kernel" [ 4.132476][ T1] 0x000000000000-0x000000100000 : "urlader" [ 4.138626][ T1] 0x000000100000-0x000000500000 : "nand-tffs" [ 4.145056][ T1] [TFFS3_Init] Called. [ 4.147561][ T1] [TFFS3_CACHE_Configure] Setting up caching for backend nand [ 4.154820][ T1] [TFFS3-CACHE] Caching module for TFFS 3.x [ 4.160551][ T1] [TFFS3-NAND] NAND storage backend for TFFS 3.x on mtd2 [ 4.305890][ T1] [TFFS3-NAND] Initialisation successful, 16/16/16 NAND blocks active, fill rate 6% [ 4.313659][ T1] tffs/panic: Reboot after panic detected [ 4.319211][ T1] [TFFS_Cache] Allocate segement buffer cache (size=4072) [ 4.328676][ T1] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0) [ 4.338738][ T1] [TFFS3-NANDSTAT][tffs_erase_stat_init] Erase counts: (min/max/mean): 1/1/1 - 0 bad blocks [ 4.347316][ T1] 0x000000d00000-0x000001500000 : "reserved-kernel" [ 4.355601][ T1] 0x000001500000-0x000020000000 : "ubi" [ 4.376651][ T1] lro_sram_membase_res0 from DT: a2013000 [ 4.381195][ T1] ltq_toe_membase: e2000000 and lro_sram_membase_res0: e2013000 [ 4.389038][ T1] TOE Init Done !! [ 5.040028][ T1] i2c /dev entries driver [ 5.044769][ T1] ltq_thermal 16000000.ssx4:ts@080000: ltq_thermal_probe: is done [ 5.055774][ T1] AVM PA 2.179-master for Linux Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 5.055774][ T1] (late init) [ 5.072595][ T1] Mirror/redirect action on [ 5.076241][ T1] u32 classifier [ 5.079525][ T1] Performance counters on [ 5.084036][ T1] input device check on [ 5.088373][ T1] Actions configured [ 5.092684][ T1] ipip: IPv4 and MPLS over IPv4 tunneling driver [ 5.099686][ T1] Initializing XFRM netlink socket [ 5.103632][ T1] IPsec XFRM device driver [ 5.109719][ T1] NET: Registered protocol family 10 [ 5.116209][ T1] NET: Registered protocol family 17 [ 5.120057][ T1] NET: Registered protocol family 15 [ 5.125377][ T1] Bridge flood ratelimiter registered [ 5.130322][ T1] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 5.143905][ T1] lec:lane_module_init: lec.c: initialized [ 5.149517][ T1] mpoa:atm_mpoa_init: mpc.c: initialized [ 5.155020][ T1] KOAM is loaded successfully. [ 5.159619][ T1] l2tp_core: L2TP core driver, V2.0 [ 5.164612][ T1] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 5.171153][ T1] l2tp_netlink: L2TP netlink interface [ 5.176262][ T1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 5.182764][ T1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 5.190164][ T1] 8021q: 802.1Q VLAN Support v1.8 [ 5.197128][ T1] audit: type=1400 audit(4.524:2): apparmor="STATUS" info="AppArmor sha1 policy hashing enabled" pid=1 comm="swapper/0" [ 5.208059][ T1] AppArmor: AppArmor sha1 policy hashing enabled [ 5.218412][ T1] ubi0: attaching mtd4 [ 5.597463][ T1] ubi0: scanning is finished [ 5.633363][ T1] ubi0: attached mtd4 (name "ubi", size 491 MiB) [ 5.638129][ T1] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes [ 5.645653][ T1] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 1024 [ 5.653114][ T1] ubi0: VID header offset: 1024 (aligned 1024), data offset: 4096 [ 5.660753][ T1] ubi0: good PEBs: 1962, bad PEBs: 2, corrupted PEBs: 0 [ 5.667523][ T1] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128 [ 5.675426][ T1] ubi0: max/mean erase counter: 92/61, WL threshold: 4096, image sequence number: 1698721932 [ 5.685413][ T1] ubi0: available PEBs: 0, total reserved PEBs: 1962, PEBs reserved for bad PEB handling: 38 [ 5.695526][ T701] ubi0: background thread "ubi_bgt0d" started, PID 701 [ 5.697237][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.697254][ T1] [announce_root] filesystem (/dev/mtdblock5) will be used as root device [ 5.698910][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.700765][ T1] Could not find Env 'linux_fs_start' in the device tree [ 5.702507][ T1] Could not find Env 'linux_fs_start' in the [ 5.743077][ T1] squashfs: SQUASHFS error: unable to read id index table [ 5.753151][ T1] List of all partitions: [ 5.755935][ T1] 0100 30000 ram0 [ 5.755942][ T1] (driver?) [ 5.763353][ T1] 1f00 8192 mtdblock0 [ 5.763357][ T1] (driver?) [ 5.771248][ T1] 1f01 1024 mtdblock1 [ 5.771252][ T1] (driver?) [ 5.779149][ T1] 1f02 4096 mtdblock2 [ 5.779153][ T1] (driver?) [ 5.787046][ T1] 1f03 8192 mtdblock3 [ 5.787050][ T1] (driver?) [ 5.794946][ T1] 1f04 502784 mtdblock4 [ 5.794950][ T1] (driver?) [ 5.802844][ T1] 1f05 45108 mtdblock5 [ 5.802848][ T1] (driver?) [ 5.810745][ T1] 1f06 45108 mtdblock6 [ 5.810749][ T1] (driver?) [ 5.818644][ T1] 1f07 2268 mtdblock7 [ 5.818648][ T1] (driver?) [ 5.826544][ T1] 1f08 391356 mtdblock8 [ 5.826547][ T1] (driver?) [ 5.834439][ T1] No filesystem could mount root, tried: [ 5.834443][ T1] ext3 [ 5.840015][ T1] ext2 [ 5.842597][ T1] ext4 [ 5.845222][ T1] squashfs [ 5.847826][ T1] antfs [ 5.850757][ T1] fuseblk [ 5.853468][ T1] [ 5.858493][ T1] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,5) [ 5.867520][ T1] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.9.337 #1 [ 5.874198][ T1] Stack : 00000000 98eb0000 00000000 00000000 00000006 98482f0c 00000001 00000000 [ 5.883223][ T1] 00000004 00000006 00000000 00000000 00000000 00000000 992090ba 00000034 [ 5.892251][ T1] 99206ca8 00000000 00000000 47a62b8f 98ea0000 98eab167 98d93388 00000003 [ 5.901279][ T1] 00000001 99204c44 990a0000 98d914e8 fffffff3 984830bc 00000000 00000000 [ 5.910307][ T1] 00000006 00000000 98d9ba6c 9fc2bd54 99200000 98526094 00000000 00000000 [ 5.919335][ T1] ... [ 5.922603][ T1] Classified pointer on stack: [ 5.927063][ T1] 98482f0c vprintk_emit+0x498/0x624 [ 5.932232][ T1] 984830bc vprintk+0x24/0x30 [ 5.936563][ T1] 9fc2bd54 [stack(swapper/0): 9fc28000+0x3d54] [ 5.942521][ T1] 98526094 printk+0x34/0x58 [ 5.946891][ T1] 9fc2bc98 [stack(swapper/0): 9fc28000+0x3c98] [ 5.952849][ T1] 9fc2bd54 [stack(swapper/0): 9fc28000+0x3d54] [ 5.958843][ T1] 987ee70c dump_stack+0x9c/0xe0 [ 5.963523][ T1] Call Trace: [ 5.966669][ T1] [<983fd93c>] 0x983fd93c show_stack+0x3c/0xb0 [ 5.972647][ T1] [<987ee70c>] 0x987ee70c dump_stack+0x9c/0xe0 [ 5.978648][ T1] [<98525770>] 0x98525770 panic+0x120/0x2a0 [ 5.984373][ T1] [<9905b4b8>] 0x9905b4b8 mount_block_root+0x348/0x390 [ 5.991086][ C1] stop_cpu_hook cpu1 - stopped status=1100fc00 [ 5.991092][ T0] stop_cpu_hook cpu0 - stopped status=1100fc00 [ 5.991097][ C2] stop_cpu_hook cpu2 - stopped status=1100fc00 [ 5.991148][ T1] avm_set_reset_status: Soft-Reboot(PANIC) - PANIC(3)UP(5)UTC(5)FW(08.20)HW(226)HWS(4)BV(1.3578)BN(122916)FS(08.20)BT(1)BD(0) [ 6.021992][ T1] Kernel relocated by 0x17ef0000 [ 6.026719][ T1] .text @ 0x983f0000 [ 6.030539][ T1] .data @ 0x98cb2874 [ 6.034358][ T1] .bss @ 0x99200000 ROM VER: 2.1.0 CFG 09 B . . . * * * * * Detected PXB4583el V1.2-2000 .
