ROM VER: 2.1.0 CFG 0e B . . . pagesize = 00000800 no_of_pages_in_block = 00000040 * ROM VER: 2.1.0 CFG 0e B . . . pagesize = 00000800 no_of_pages_in_block = 00000040 * * * * Detected PXB4583el V1.2-2000 .[piglet] Suceeded (AVM) EVA Revision: 1.3578 (C) Copyright 2005 AVM Date: Nov 27 2018 Time: 13:38:30 (0) 3 0x0-0x46409 [NAND:] 512MB MACRONIX 2048 Pagesize 128k Blocksize 4096 Blocks HW [SYSTEM:] GRX5 (ID 0x24 Revision 2) on 1000MHz/600MHz/666MHz .. Eva_AVM >#Loading compressed kernel to 0x85284A30 ..................................................................................................................................................Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 ------------------------------------------- Switching to Bootcore Console ------------------------------------------- [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000000c00059638b ases 0x00000001 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 00019074 (MIPS 4KEc) [ 0.000000][ T0] MIPS: machine is GRX550 ANYWAN BOOTCORE (MIPS 4Kec) [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 02000000 @ 0e000000 (usable) [ 0.000000][ T0] memory: 00001b86 @ 0e7bc030 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 0dfc0000 (reserved) [ 0.000000][ T0] Initial ramdisk at: 0x8e000000 (4194304 bytes) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000000c0005d638b icache.flags 0x00000000 dcache.flags 0x00000004 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 16 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 16 bytes [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000000c0005d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] Normal [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] On node 0 totalpages: 8192 [ 0.000000][ T0] free_area_init_node: node 0, pgdat 8e7bb1c4, node_mem_map 8f005960 [ 0.000000][ T0] Normal zone: 64 pages used for memmap [ 0.000000][ T0] Normal zone: 0 pages reserved [ 0.000000][ T0] Normal zone: 8192 pages, LIFO batch:0 [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000][ T0] pcpu-alloc: [0] 0 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200n8r root=/dev/ram rw loglevel=8 [ 0.000000][ T0] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Memory: 23752K/32768K available (2931K kernel code, 461K rwdata, 680K rodata, 208K init, 262K bss, 9016K reserved, 0K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] grx500_bootcore_register_static_irq: irq_in = 0x0000001f, irq_out = 0x0000001f [ 0.000000][ T0] grx500_bootcore_register_static_irq: mapper_reg = 0x0000015c, mapper_offset = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: int_line = 0x0000001f, map_address = 0x0000015c, num = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x0000001f [ 0.000000][ T0] CPU Clock: 300MHz [ 0.000000][ T0] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns [ 0.000019][ T0] sched_clock: 32 bits at 150MHz, resolution 6ns, wraps every 14316557820ns [ 0.016981][ T0] : grx500_bootcore_console_init: call register [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.041328][ T0] bootconsole [early0] disabled [ 0.041328][ T0] bootconsole [early0] disabled [ 0.054934][ T0] bootconsole [early0] disabled [ 0.054934][ T0] bootconsole [early0] disabled [ 0.064283][ T0] Calibrating delay loop... 299.26 BogoMIPS (lpj=598528) [ 0.107056][ T0] pid_max: default: 32768 minimum: 301 [ 0.113289][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.120444][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.134919][ T1] Performance counters: No available PMU. [ 0.143933][ T1] devtmpfs: initialized [ 0.153192][ T1] ngi: Protecting Bootcore: [0x2e000000, 0x2fffffff] [ 0.159606][ T1] ngi: 512MB attached. Protecting: [0x40000000, 0x9fffffff] [ 0.166617][ T1] ngi: Unattached: [0x60000000, 0x9fffffff] [ 0.172319][ T1] ngi: Unattached: [0x40000000, 0x5fffffff] [ 0.178740][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.189071][ T1] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.196171][ T1] pinctrl core: initialized pinctrl subsystem [ 0.204882][ T1] NET: Registered protocol family 16 [ 0.227282][ T1] irq: no irq domain found for /interrupt-controller@0x14900140 ! [ 0.327740][ T1] clocksource: Switched to clocksource MIPS [ 0.356031][ T1] NET: Registered protocol family 2 [ 0.361565][ T1] IP idents hash table entries: 2048 (order: 2, 16384 bytes) [ 0.370680][ T1] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.378371][ T1] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.385301][ T1] TCP: Hash tables configured (established 1024 bind 1024) [ 0.392849][ T1] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.399358][ T1] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.406786][ T1] NET: Registered protocol family 1 [ 0.416327][ T1] Unpacking initramfs... [ 1.158164][ T1] Freeing initrd memory: 4096K [ 1.165328][ T1] No memory allocated for crashlog [ 1.178785][ T1] workingset: timestamp_bits=30 max_order=13 bucket_order=0 [ 1.260342][ T1] Serial: grx500_bootcore driver init [ 1.274221][ T1] NET: Registered protocol family 10 [ 1.292350][ T1] NET: Registered protocol family 17 [ 1.305661][ T1] Serial: grx500_bootcore driver startup [ 1.311133][ T1] grx500_bootcore_register_static_irq: irq_in = 0x0000001c, irq_out = 0x00000008 [ 1.319884][ T1] grx500_bootcore_register_static_irq: mapper_reg = 0x00000158, mapper_offset = 0x00000003 [ 1.329640][ T1] EXCEP_remap_line: int_line = 0x00000008, map_address = 0x00000158, num = 0x00000003 [ 1.339055][ T1] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x00040000 [ 1.352216][ T1] Freeing unused kernel memory: 208K [ 1.357237][ T1] This architecture does not have kernel memory protection. [ 1.594019][ T195] eip123_hw: module license 'Proprietary' taints kernel. [ 1.600905][ T195] Disabling lock debugging due to kernel taint [ 1.612294][ T195] eip123: no symbol version for eip123_hw_asset_derive [ 1.620867][ T195] eip123 1e000000.eip123: Detected hardware version 2.2.2 [ 1.627817][ T195] eip123 1e000000.eip123: my_id=0 master_id=0 num_mailboxes=4 mailbox_size=256 [ 1.636401][ T195] eip123 1e000000.eip123: Configured mailbox lockout: 0x00000000 [ 1.643912][ T195] eip123 1e000000.eip123: Linked mailbox number 1 [ 1.675809][ T195] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=0 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0 [ 1.911742][ T195] eip123 1e000000.eip123: eip123_hw init successful [ 1.971771][ T195] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c [ 1.980876][ T195] eip123 1e000000.eip123: Could not find rootkey in OTP [ 2.015974][ T198] random: crng init done [ 2.020908][ T110] shm-rng-seed shm-rng-seed@3dfb0000: Added 4088 random bytes to the shared memory area [ 3.788508][ T262] eip123 1e000000.eip123: Unlinked mail…KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKC…C…C…C… Switching to Interaptiv Console ------------------------------------------- .. Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 [ 0.000000][ T0] shm-rng-seed-mem@3dfb0000: Added 4088 random bytes to the system pool [ 0.000000][ T0] OF: fdt:[0x304d0000, 0x31793b70) is not contained in the RAM region at [0x20000000, 0x2e000000) [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e69638b ases 0x00000030 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.000000][ T0] Enhanced Virtual Addressing (EVA Legacy 512MB) activated [ 0.000000][ T0] MIPS: machine is AVM7590 (GRX550, HW226) Main model [ 0.000000][ T0] Coherence Manager IOCU detected [ 0.000000][ T0] Hardware DMA cache coherency disabled [ 0.000000][ T0] OF: reserved mem: initialized node shm-rng-seed-mem@3dfb0000, compatible id avm,shm-rng-seed-early [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'urlader': base 0x20010000, size 0x00030000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'VMB': base 0x20000000, size 0x00001000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'avm_reboot_string': base 0x20001000, size 0x00000200 [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 10000000 @ 30000000 (usable) [ 0.000000][ T0] memory: 0e000000 @ 20000000 (usable) [ 0.000000][ T0] memory: 0000cf06 @ 310fa038 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 2dfc0000 (reserved) [ 0.000000][ T0] memory: 00400000 @ 20100000 (reserved) [ 0.000000][ T0] memory: 00030000 @ 20010000 (reserved) [ 0.000000][ T0] memory: 00001200 @ 20000000 (reserved) [ 0.000000][ T0] Kernel relocated by 0x0ffd0000 [ 0.000000][ T0] .text @ 0x904d0000 [ 0.000000][ T0] .data @ 0x90d92874 [ 0.000000][ T0] .bss @ 0x912e0000 [ 0.000000][ T0] Initrd not found or empty - disabling initrd [ 0.000000][ T0] cma: Reserved 64 MiB at 0x24000000 [ 0.000000][ T0] SMPCMP: initialized the EVA stub code: 400@0x280293e0 [ 0.000000][ T0] SMPCMP: CPU0: cmp_smp_setup [ 0.000000][ T0] VPE topology {2,2} total 4 [ 0.000000][ T0] Detected 3 available secondary CPU(s) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.000000][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] DMA [mem 0x0000000020000000-0x0000000027ffffff] [ 0.000000][ T0] Normal [mem 0x0000000028000000-0x000000003fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x0000000020000000-0x000000002dffffff] [ 0.000000][ T0] node 0: [mem 0x0000000030000000-0x000000003fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x0000000020000000-0x000000003fffffff] [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] [module-mem] Use 0x38035000-0x38b81fff (mapped at 98035000-98b81fff) for 95 modules [ 0.000000][ T0] percpu: Embedded 12 pages/cpu s18288 r8192 d22672 u49152 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121728 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200 pcmlink.abmode=0x8103 Piglet_noemif.piglet_dectmode=0x110 Piglet_noemif.piglet_bitfile=bitfile.bit audit=1 slub_debug=fl [ 0.000000][ T0] audit: enabled (after initialization) [ 0.000000][ T0] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000][ T0] Writing ErrCtl register=00000000 [ 0.000000][ T0] Readback ErrCtl register=00000000 [ 0.000000][ T0] Memory: 385240K/491520K available (8745K kernel code, 1849K rwdata, 1892K rodata, 1688K init, 4814K bss, 40744K reserved, 65536K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000][ T0] Hierarchical RCU implementation. [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] EIC is off [ 0.000000][ T0] VINT is on [ 0.000000][ T0] CPU Clock: 1000000000Hz mips_hpt_frequency 500000000Hz [ 0.000000][ T0] clocksource: gptc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302233 ns [ 0.010144][ T0] Calibrating delay loop... 718.84 BogoMIPS (lpj=1437696) [ 0.046801][ T0] pid_max: default: 32768 minimum: 301 [ 0.052296][ T0] Security Framework initialized [ 0.057079][ T0] AppArmor: AppArmor initialized [ 0.061969][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.069289][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.078843][ T1] CCA is coherent, multi-core is fine [ 0.084505][ T1] avm_register_cpuid: cpu_id=0: LINUX core=0 tc=0 [ 0.090743][ T1] Performance counters: mips/interAptiv PMU enabled, 2 32-bit counters available to each CPU, irq 9 GOT IPI to launch from CPU 1 GOT IPI to launch from CPU 2 GOT IPI to launch from CPU 3 [ 0.109270][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.109314][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.109319][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.109338][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.109345][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.109350][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.109361][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.109366][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.109564][ T0] CPU1 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.139594][ T0] avm_register_cpuid: cpu_id=1: LINUX core=0 tc=1 [ 0.142041][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.142078][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.142082][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.142100][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.142107][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.142113][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.142123][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.142128][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.142263][ T0] CPU2 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.169872][ T0] avm_register_cpuid: cpu_id=2: LINUX core=1 tc=0 [ 0.172352][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.172388][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.172392][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.172410][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.172416][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.172421][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.172432][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.172436][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.172571][ T0] CPU3 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.200176][ T0] avm_register_cpuid: cpu_id=3: LINUX core=1 tc=1 [ 0.200446][ T1] Brought up 4 CPUs [ 0.470625][ T1] avm_yield_setup: YIELD_PCMFRAME_ID : id=0x0004000f: cpu=0 tc=4 prio=3 signal=15 [ 0.480254][ T1] avm_yield_setup: YIELD_PCMLINK_ID : id=0x0003000c: cpu=0 tc=3 prio=2 signal=12 [ 0.489889][ T1] avm_yield_setup: YIELD_MONITOR_IPI0_ID : id=0x0002000e: cpu=0 tc=2 prio=1 signal=14 [ 0.499524][ T1] avm_yield_setup: YIELD_PROFILE_IPI0_ID : id=0x0002000d: cpu=0 tc=2 prio=1 signal=13 [ 0.509160][ T1] avm_yield_setup: YIELD_GPTC_ID : id=0x0005000b: cpu=0 tc=5 prio=3 signal=11 [ 0.519330][ T3] [0][yield_context_init] cpu=0 tc=2 mask=6000 tc_prio=1 [ 0.526482][ T29] [0][yield_context_init] cpu=0 tc=3 mask=1000 tc_prio=2 [ 0.533638][ T29] [0][yield_context_init] cpu=0 tc=4 mask=8000 tc_prio=3 [ 0.540747][ T29] [0][yield_context_init] cpu=0 tc=5 mask=0800 tc_prio=3 [ 0.547751][ T1] avm_yield_setup: YIELD_MONITOR_IPI1_ID : id=0x0202000e: cpu=2 tc=2 prio=1 signal=14 [ 0.557202][ T1] avm_yield_setup: YIELD_PROFILE_IPI1_ID : id=0x0202000d: cpu=2 tc=2 prio=1 signal=13 [ 0.567247][ T21] [2][yield_context_init] cpu=2 tc=2 mask=6000 tc_prio=1 [ 0.575164][ T1] devtmpfs: initialized [ 0.594432][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.604954][ T1] futex hash table entries: 1024 (order: 3, 32768 bytes) [ 0.616622][ T1] pinctrl core: initialized pinctrl subsystem [ 0.624065][ T1] NET: Registered protocol family 16 [ 0.633433][ T1] dma-grx500 1e300000.dma: dma3 base address be300000 chained_irq 29 irq_base 30 [ 0.645297][ T1] dma-grx500 1e300000.dma: Init done - rev: a, ports: 1, channels: 64 [ 0.655584][ T1] dma-grx500 1c100000.dma: dma2tx base address bc100000 chained_irq 100 irq_base 101 [ 0.666441][ T1] dma-grx500 1c100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.674924][ T1] dma-grx500 1c200000.dma: dma2rx base address bc200000 chained_irq 117 irq_base 118 [ 0.686266][ T1] dma-grx500 1c200000.dma: Init done - rev: a, ports: 1, channels: 32 [ 0.695280][ T1] dma-grx500 1a100000.dma: dma1tx base address ba100000 chained_irq 150 irq_base 151 [ 0.706146][ T1] dma-grx500 1a100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.714624][ T1] dma-grx500 1a200000.dma: dma1rx base address ba200000 chained_irq 167 irq_base 168 [ 0.725345][ T1] dma-grx500 1a200000.dma: Init done - rev: a, ports: 1, channels: 12 [ 0.740871][ T1] dma0-grx500 16e00000.dma: base address b6e00000 chained_irq 218 irq_base 219 [ 0.749609][ T1] dma0-grx500 16e00000.dma: Init done - hw rev: A, ports: 4, channels: 16 [ 0.758288][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 0, reg: 0xb6c80000, pinbase: 0, pin number: 32, pinmap: 0xf1efefff [ 0.769959][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 1, reg: 0xb6c80100, pinbase: 32, pin number: 32, pinmap: 0x3bff0c1f [ 0.782087][ T1] intel-pinctrl 16c80000.pinctrl: Total 14 groups, 12 functions [ 0.790471][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00000 [ 0.798405][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00100 [ 0.815478][ T1] gic_timer_probe [ 0.818913][ T1] gic_timer_probe: irq=287 freq=1000000000 [ 0.863028][ T1] avm_alloc_page_extension node_extension_table[0] entries=131072 (size=524288) alloced [ 0.873047][ T1] Reboot Status is: Power-On [ 0.877566][ T1] Unable to get node cqm for prx300-cqm [ 0.882890][ T1] add_cqm_dev(#152): parse_dts fail for prx300-cqm [ 0.889490][ T1] No rcu reset for cbm [ 0.893305][ T1] No syscon phandle specified for wan mux [ 0.898957][ T1] Invalid args in ltq_dqm_ports [ 0.903719][ T1] Invalid args in ltq_eqm_ports [ 0.978562][ T1] [cbm] { cbm_xrx500_probe : 5697 }reserving 18874368 bytes @ 84000000 for CBM [ 1.018500][ T1] [cbm] { cbm_xrx500_probe : 5707 }reserving 8388608 bytes @ 85200000 for CBM [ 1.027093][ T1] [cbm] { cbm_xrx500_probe : 5722 }94 irq [ 1.032865][ T1] [cbm] { cbm_xrx500_probe : 5745 }2 [ 1.037994][ T1] [drv_tmu_ll] { get_cbm_clock : 7605 }CBM Clock: 0Hz=0MHZ [ 1.045107][ T1] [drv_tmu_ll] { get_cbm_clock : 7608 }Wrong cbm clock [ 1.051877][ T1] Initializing TMU with Base Address=be700000: ... [ 1.061134][ T1] TMU Initialization Done [ 1.065176][ T1] 0x84000000 0x1200000 0x800 [ 1.069664][ T1] 0x84000000 0x1200000 [ 1.073655][ T1] 0x85200000 0x800000 0x2000 [ 1.078171][ T1] 0x85200000 0x800000 [ 1.082389][ T1] [cbm] { init_fsqm_buf_std : 1173 }init fsqm std successfully [ 1.089652][ T1] [cbm] { init_fsqm_buf_jumbo : 1213 }init fsqm jbo successfully [ 1.097255][ T1] [cbm] { init_fsqm : 1236 }fsqm init successfully [ 1.103683][ T1] [cbm] { init_cbm_basic : 1271 }PHY ADDR STD 0x24000000 [ 1.110623][ T1] [cbm] { init_cbm_basic : 1272 }PHY ADDR JBO 0x25200000 [ 1.117837][ T1] [cbm] { init_cbm_basic : 1290 }init basic CBM successfully [ 1.124898][ T1] [cbm] { cbm_hw_init : 2206 }CBM HW init [ 1.130685][ T1] [cbm] { setup_DMA_p2p : 5102 }setup_DMA_p2p executed [ 1.137315][ T1] [cbm] { reserved_ports_highest : 5161 }2 2 19 35 [ 1.143740][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.149406][ T1] [cbm] { assign_port_from_DT : 654 }0x0 2 [ 1.155101][ T1] [cbm] { assign_port_from_DT : 654 }0x20 2 [ 1.161104][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.165955][ T1] [cbm] { reserved_ports_highest : 5161 }1 1 18 34 [ 1.172379][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.178027][ T1] [cbm] { assign_port_from_DT : 654 }0x80 1 [ 1.183839][ T1] [cbm] { reserved_ports_highest : 5161 }3 3 20 36 [ 1.190255][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.195918][ T1] [cbm] { assign_port_from_DT : 654 }0x2000000 3 [ 1.202148][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.207190][ T1] [cbm] { reserved_ports_highest : 5161 }6 6 0 16 [ 1.213521][ T1] [cbm] { dma_port_enable : 4670 }6 0x4 [ 1.219009][ T1] [cbm] { reserved_ports_highest : 5161 }7 7 1 17 [ 1.225333][ T1] [cbm] { dma_port_enable : 4670 }7 0x4 [ 1.230808][ T1] [cbm] { reserved_ports_highest : 5161 }8 8 2 18 [ 1.237129][ T1] [cbm] { dma_port_enable : 4670 }8 0x4 [ 1.242614][ T1] [cbm] { reserved_ports_highest : 5161 }9 9 3 19 [ 1.248935][ T1] [cbm] { dma_port_enable : 4670 }9 0x4 [ 1.254419][ T1] [cbm] { reserved_ports_highest : 5161 }10 10 4 20 [ 1.260913][ T1] [cbm] { dma_port_enable : 4670 }10 0x4 [ 1.266485][ T1] [cbm] { reserved_ports_highest : 5161 }11 11 5 21 [ 1.272979][ T1] [cbm] { dma_port_enable : 4670 }11 0x4 [ 1.278548][ T1] [cbm] { reserved_ports_highest : 5161 }12 12 6 22 [ 1.285045][ T1] [cbm] { dma_port_enable : 4670 }12 0x4 [ 1.290616][ T1] [cbm] { reserved_ports_highest : 5161 }13 13 7 23 [ 1.297110][ T1] [cbm] { dma_port_enable : 4670 }13 0x4 [ 1.302685][ T1] [cbm] { reserved_ports_highest : 5161 }14 14 8 24 [ 1.309184][ T1] [cbm] { dma_port_enable : 4670 }14 0x4 [ 1.314747][ T1] [cbm] { reserved_ports_highest : 5161 }15 15 9 25 [ 1.321241][ T1] [cbm] { dma_port_enable : 4670 }15 0x4 [ 1.326813][ T1] [cbm] { reserved_ports_highest : 5161 }16 16 10 26 [ 1.333394][ T1] [cbm] { dma_port_enable : 4670 }16 0x4 [ 1.338962][ T1] [cbm] { reserved_ports_highest : 5161 }17 17 11 27 [ 1.345546][ T1] [cbm] { dma_port_enable : 4670 }17 0x4 [ 1.351117][ T1] [cbm] { reserved_ports_highest : 5161 }18 18 -16 0 [ 1.357698][ T1] [cbm] { dma_port_enable : 4670 }18 0x4 [ 1.363286][ T1] [cbm] { reserved_ports_highest : 5161 }19 19 12 28 [ 1.369851][ T1] [cbm] { dma_port_enable : 4670 }19 0x4 [ 1.375422][ T1] [cbm] { reserved_ports_highest : 5161 }20 20 13 29 [ 1.382003][ T1] [cbm] { dma_port_enable : 4670 }20 0x4 [ 1.387577][ T1] [cbm] { init_special_ports : 5168 }20 [ 1.393036][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.398068][ T1] [cbm] { reserved_ports_highest : 5161 }21 21 14 30 [ 1.404658][ T1] [cbm] { dma_port_enable : 4670 }21 0x4 [ 1.410224][ T1] [cbm] { init_special_ports : 5168 }21 [ 1.415682][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.420719][ T1] [cbm] { reserved_ports_highest : 5161 }22 22 25 41 [ 1.427314][ T1] [cbm] { dma_port_enable : 4670 }22 0x4 [ 1.432882][ T1] [cbm] { reserved_ports_highest : 5161 }23 23 15 31 [ 1.439467][ T1] [cbm] { init_cbm_dqm_ldma_port : 1476 }23 [ 1.445294][ T1] [cbm] { reserved_ports_highest : 5161 }5 5 21 37 [ 1.451706][ T1] [cbm] { init_cbm_dqm_scpu_port : 1457 }5 [ 1.457616][ T1] [cbm] { reserved_ports_highest : 5161 }4 4 16 32 [ 1.463862][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }4 [ 1.469510][ T1] [cbm] { assign_port_from_DT : 654 }0x18 4 [ 1.475317][ T1] [cbm] { reserved_ports_highest : 5161 }24 24 22 38 [ 1.481913][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }24 [ 1.487650][ T1] [cbm] { assign_port_from_DT : 654 }0x8 24 [ 1.493461][ T1] [cbm] { reserved_ports_highest : 5161 }25 25 23 39 [ 1.500054][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }25 [ 1.505794][ T1] [cbm] { assign_port_from_DT : 654 }0x8 25 [ 1.511600][ T1] [cbm] { reserved_ports_highest : 5161 }26 26 24 40 [ 1.518197][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }26 [ 1.523934][ T1] [cbm] { assign_port_from_DT : 654 }0x8 26 [ 1.529743][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }0 [ 1.535386][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }1 [ 1.541026][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }2 [ 1.546667][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }3 [ 1.552312][ T1] [cbm] { dma_port_enable : 4670 }5 0x1 [ 1.557785][ T1] [cbm] { dma_port_enable : 4670 }5 0x2 [ 1.563250][ T1] [cbm] { dma_port_enable : 4670 }6 0x1 [ 1.568716][ T1] [cbm] { dma_port_enable : 4670 }6 0x2 [ 1.574192][ T1] [cbm] { dma_port_enable : 4670 }7 0x1 [ 1.579654][ T1] [cbm] { dma_port_enable : 4670 }7 0x2 [ 1.585123][ T1] [cbm] { dma_port_enable : 4670 }8 0x1 [ 1.590591][ T1] [cbm] { dma_port_enable : 4670 }8 0x2 [ 1.596061][ T1] [cbm] { dma_toe_port_enable : 4697 }9 0x1 [ 1.601875][ T1] [cbm] { dma_vrx318_port_enable : 4709 }15 0x1 [ 1.608049][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }0 [ 1.613678][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.619322][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.624962][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.630609][ T1] Load spreader init successfully [ 1.635708][ T1] [cbm] { cbm_xrx500_probe : 5801 }CBM Clock: 0Hz [ 1.641893][ T1] [cbm] { cbm_xrx500_probe : 5803 }EQM delay Enabled [ 1.648487][ T1] [cbm] { igp_delay_set : 4782 }port0 delay16 [ 1.654477][ T1] [cbm] { igp_delay_set : 4782 }port1 delay16 [ 1.660465][ T1] [cbm] { igp_delay_set : 4782 }port2 delay16 [ 1.666456][ T1] [cbm] { igp_delay_set : 4782 }port3 delay16 [ 1.672444][ T1] [cbm] { igp_delay_set : 4782 }port4 delay16 [ 1.678435][ T1] [cbm] { igp_delay_set : 4782 }port5 delay16 [ 1.684422][ T1] [cbm] { igp_delay_set : 4782 }port6 delay16 [ 1.690413][ T1] [cbm] { igp_delay_set : 4782 }port7 delay16 [ 1.696401][ T1] [cbm] { igp_delay_set : 4782 }port8 delay16 [ 1.702391][ T1] [cbm] { igp_delay_set : 4782 }port9 delay16 [ 1.708380][ T1] [cbm] { igp_delay_set : 4782 }port10 delay16 [ 1.714458][ T1] [cbm] { igp_delay_set : 4782 }port11 delay16 [ 1.720532][ T1] [cbm] { igp_delay_set : 4782 }port12 delay16 [ 1.726610][ T1] [cbm] { igp_delay_set : 4782 }port13 delay16 [ 1.732685][ T1] [cbm] { igp_delay_set : 4782 }port14 delay16 [ 1.738762][ T1] [cbm] { igp_delay_set : 4782 }port15 delay16 [ 1.744841][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x2 2 0 30 [ 1.751456][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x1 2 14 0 [ 1.758037][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x2 2 0 31 [ 1.764636][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x1 2 15 0 [ 1.771230][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x2 1 0 6 [ 1.777745][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x1 1 0 0 [ 1.784250][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x2 1 0 11 [ 1.790850][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x1 1 5 0 [ 1.797394][ T1] [cbm] { cbm_xrx500_probe : 5850 }CBM: Init Done !! [ 1.798369][ T1] pstore: using zlib compression [ 1.809678][ T1] pstore: Registered ramoops as persistent store backend [ 1.816551][ T1] ramoops: attached 0x400000@0x20100000, ecc: 0/0 [ 1.856452][ T1] SCSI subsystem initialized [ 1.861309][ T1] usbcore: registered new interface driver usbfs [ 1.867606][ T1] usbcore: registered new interface driver hub [ 1.873629][ T1] usbcore: registered new device driver usb [ 1.880019][ T1] mp8864 0-0068: MP8864 probe started. [ 1.890280][ T1] mp8864 0-0068: [MP8864 Init] Status is 0x11 Vsel is 0x37 Syscntl is 0xa5 [ 1.898585][ T1] i2c-gpio i2c: using pins 501 (SDA) and 502 (SCL) [ 1.905156][ T1] try to register spd_mon driver [ 1.905450][ T1] spdmon 16080110.speedm: base address: 0xb6080110 [ 1.916599][ T1] spdmon 16080110.speedm: PHY base address: 0x16080110 [ 1.923686][ T1] spdmon 16080110.speedm: spd_mon driver : init done !! [ 1.934947][ T1] spd_mon driver registered [ 1.940482][ T1] AVM PA for Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 1.940482][ T1] (early init) [ 1.956985][ T1] NET: Registered protocol family 8 [ 1.961947][ T1] NET: Registered protocol family 20 [ 1.967611][ T1] clocksource: Switched to clocksource gptc [ 1.997776][ T1] AppArmor: AppArmor Filesystem Enabled [ 2.006399][ T1] NET: Registered protocol family 2 [ 2.011573][ T1] IP idents hash table entries: 8192 (order: 4, 65536 bytes) [ 2.036077][ T1] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 2.043782][ T1] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.050954][ T1] TCP: Hash tables configured (established 4096 bind 4096) [ 2.058109][ T1] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.064623][ T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.071943][ T1] NET: Registered protocol family 1 [ 2.078587][ T1] yield_probe: cpu 0 irq 275 [ 2.083122][ T1] yield_probe: cpu 1 irq 276 [ 2.087482][ T1] yield_probe: cpu 2 irq 277 [ 2.091964][ T1] yield_probe: cpu 3 irq 278 [ 2.096478][ T1] yield_probe: interrupts set up [ 2.103195][ T1] audit: initializing netlink subsys (enabled) [ 2.109248][ T1] audit: type=2000 audit(1.440:1): initialized [ 2.115517][ T1] No memory allocated for crashlog [ 2.120871][ T1] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 2.149286][ T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.155706][ T1] ANTFS Module: Version 2.56 [ 2.160471][ T1] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 2.173128][ T1] fuse init (API version 7.26) [ 2.186749][ T1] io scheduler noop registered [ 2.191241][ T1] io scheduler deadline registered (default) [ 2.197587][ T1] bthelper_probe: core 0 initialized [ 2.202573][ T1] bthelper_probe: core 1 initialized [ 2.209879][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe slim phy[0] init success! [ 2.218498][ T1] intel-pcie-slim-phy 18000000.pciephy: PCIe slim phy[1] init success! [ 2.226842][ T1] intel-pcie-slim-phy 18a00000.pciephy: PCIe slim phy[2] init success! [ 2.235422][ T1] 1a400000.phy supply vbus not found, using dummy regulator [ 2.242884][ T1] 1a600000.phy supply vbus not found, using dummy regulator [ 2.359639][ T1] OF: PCI: host bridge /pcie@18900000 ranges: [ 2.365468][ T1] OF: PCI: MEM 0xb8000000..0xbaffffff -> 0xb8000000 [ 2.372109][ T1] OF: PCI: IO 0xbb800000..0xbb80ffff -> 0xbb800000 [ 2.381144][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe LCPLL SSC Mode Enabled [ 2.522629][ T1] intel-pcie 18900000.pcie: PCI host bridge to bus 0000:00 [ 2.529564][ T1] pci_bus 0000:00: root bus resource [bus 00-08] [ 2.535781][ T1] pci_bus 0000:00: root bus resource [mem 0xb8000000-0xbaffffff] [ 2.543441][ T1] pci_bus 0000:00: root bus resource [io 0xbb800000-0xbb80ffff] [ 2.551475][ T1] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.560683][ T1] pci 0000:00:00.0: PCI bridge to [bus 01-08] [ 2.566727][ T1] pci 0000:00:00.0: BAR 8: assigned [mem 0xb8000000-0xb81fffff] [ 2.574072][ T1] pci 0000:00:00.0: BAR 9: assigned [mem 0xb8200000-0xb82fffff pref] [ 2.582049][ T1] pci 0000:00:00.0: BAR 7: assigned [io 0xbb800000-0xbb800fff] [ 2.589605][ T1] pci 0000:01:00.0: BAR 0: assigned [mem 0xb8000000-0xb81fffff 64bit] [ 2.597684][ T1] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.603395][ T1] pci 0000:00:00.0: bridge window [io 0xbb800000-0xbb800fff] [ 2.610951][ T1] pci 0000:00:00.0: bridge window [mem 0xb8000000-0xb81fffff] [ 2.618501][ T1] pci 0000:00:00.0: bridge window [mem 0xb8200000-0xb82fffff pref] [ 2.626646][ T1] pcieport 0000:00:00.0: enabling device (0000 -> 0003) [ 2.633571][ T1] intel-pcie 18900000.pcie: Intel AXI PCIe Root Complex Port 0 Init Done [ 2.747632][ T1] OF: PCI: host bridge /pcie@18400000 ranges: [ 2.753433][ T1] OF: PCI: MEM 0xb4000000..0xb6ffffff -> 0xb4000000 [ 2.760090][ T1] OF: PCI: IO 0xb7800000..0xb780ffff -> 0xb7800000 [ 2.767900][ T1] intel-pcie-slim-phy 18000000.pciephy: SSC has been enabled, count: 2! [ 3.883681][ T1] intel-pcie 18400000.pcie: intel_pcie_wait_phy_link_up port 1 timeout [ 3.891653][ T1] intel-pcie-slim-phy 18000000.pciephy: SSC in use, count: 1! [ 3.899080][ T1] intel-pcie: probe of 18400000.pcie failed with error -145 [ 4.011638][ T1] OF: PCI: host bridge /pcie@18e00000 ranges: [ 4.017427][ T1] OF: PCI: MEM 0xbc000000..0xbeffffff -> 0xbc000000 [ 4.024093][ T1] OF: PCI: IO 0xbf800000..0xbf80ffff -> 0xbf800000 [ 4.031892][ T1] intel-pcie-slim-phy 18a00000.pciephy: SSC has been enabled, count: 2! [ 4.161963][ T1] intel-pcie 18e00000.pcie: PCI host bridge to bus 0002:00 [ 4.168926][ T1] pci_bus 0002:00: root bus resource [bus 00-08] [ 4.175108][ T1] pci_bus 0002:00: root bus resource [mem 0xbc000000-0xbeffffff] [ 4.182746][ T1] pci_bus 0002:00: root bus resource [io 0xbf800000-0xbf80ffff] [ 4.190863][ T1] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.200080][ T1] pci 0002:00:00.0: PCI bridge to [bus 01-08] [ 4.206172][ T1] pci 0002:00:00.0: BAR 8: assigned [mem 0xbc000000-0xbc7fffff] [ 4.213514][ T1] pci 0002:00:00.0: BAR 9: assigned [mem 0xbc800000-0xbc8fffff pref] [ 4.221491][ T1] pci 0002:00:00.0: BAR 7: assigned [io 0xbf800000-0xbf800fff] [ 4.229047][ T1] pci 0002:01:00.0: BAR 0: assigned [mem 0xbc000000-0xbc7fffff] [ 4.236596][ T1] pci 0002:00:00.0: PCI bridge to [bus 01] [ 4.242317][ T1] pci 0002:00:00.0: bridge window [io 0xbf800000-0xbf800fff] [ 4.249872][ T1] pci 0002:00:00.0: bridge window [mem 0xbc000000-0xbc7fffff] [ 4.257423][ T1] pci 0002:00:00.0: bridge window [mem 0xbc800000-0xbc8fffff pref] [ 4.265606][ T1] pcieport 0002:00:00.0: enabling device (0000 -> 0003) [ 4.272466][ T1] intel-pcie 18e00000.pcie: Intel AXI PCIe Root Complex Port 2 Init Done [ 4.282483][ T1] [mips_tc_init] dma_zalloc_coherent dev->name=(null) sizeof(struct mips_tc_sg_mem)=1680 shared_phy_mem=0x2380b000 [ 4.294277][ T1] [mips_tc_init] dma_zalloc_coherent shared_vir_uncached_mem=a380b000 shared_vir_cached_mem=8380b000 shared_working_vir_mem=8380b000 [ 4.308059][ T1] =MIPS TC Shared memory: a380b000 8380b000 8380b000 | Data: a3810000 [ 4.315992][ T1] UMT initialize success on processor: 0 ! [ 4.321665][ T1] HW MCPY driver: Version: 1.1.0, Init Done! [ 4.328581][ T1] 16600000.serial: ttyLTQ0 at MMIO 0x16600000 (irq = 210, base_baud = 0) is a lantiq,asc [ 4.338285][ T1] console [ttyLTQ0] enabled [ 4.338285][ T1] console [ttyLTQ0] enabled [ 4.346882][ T1] bootconsole [early0] disabled [ 4.346882][ T1] bootconsole [early0] disabled [ 4.356980][ T1] 16700000.serial: ttyLTQ1 at MMIO 0x16700000 (irq = 213, base_baud = 0) is a lantiq,asc [ 4.366831][ T29] random: crng init done [ 4.369639][ T1] avm_net_trace: Up and running. [ 4.374775][ T1] [avm_power]avm_power_pm_qos_init [ 4.379704][ T1] [loadcontrol] set auto - scale=1 [ 4.384175][ T1] [avm] configured: watchdog event debug [ 4.384180][ T1] [ 4.392387][ T1] Register push button event to receive the set_factory_kernel event [ 4.400559][ T1] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0) [ 4.408023][ T1] [grx:watchdog] start on cpu0 [ 4.411799][ C1] [grx:watchdog] start on cpu1 [ 4.416362][ C2] [grx:watchdog] start on cpu2 [ 4.420964][ C3] [grx:watchdog] start on cpu3 [ 4.427826][ T1] brd: module loaded [ 4.431320][ T1] zram: Added device: zram0 [ 4.436715][ T1] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc [ 4.442345][ T1] nand: Macronix MX30LF4GE8AB [ 4.446837][ T1] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64 [ 4.455091][ T1] macronix_nand_ecc_init: enabling ECC (hidden_ecc: 0): [ 4.461854][ T1] nand_avm_init_fixup: applying nand options fixup [ 4.468201][ T1] Scanning device for bad blocks [ 5.111344][ T1] 5 fixed-partitions partitions found on MTD device 17c00000.nand-parts [ 5.118078][ T1] Creating 5 MTD partitions on "17c00000.nand-parts": [ 5.124706][ T1] 0x000000500000-0x000000d00000 : "kernel" [ 5.132635][ T1] 0x000000000000-0x000000100000 : "urlader" [ 5.138784][ T1] 0x000000100000-0x000000500000 : "nand-tffs" [ 5.145169][ T1] [TFFS3_Init] Called. [ 5.147748][ T1] [TFFS3_CACHE_Configure] Setting up caching for backend nand [ 5.154939][ T1] [TFFS3-CACHE] Caching module for TFFS 3.x [ 5.160664][ T1] [TFFS3-NAND] NAND storage backend for TFFS 3.x on mtd2 [ 5.400908][ T1] [TFFS3-NAND] Initialisation successful, 32/32/32 NAND blocks active, fill rate 8% [ 5.408753][ T1] [TFFS_Cache] Allocate segement buffer cache (size=2024) [ 5.415950][ T1] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0) [ 5.426155][ T1] [TFFS3-NANDSTAT][tffs_erase_stat_init] Erase counts: (min/max/mean): 16/268/181 - 0 bad blocks [ 5.435163][ T1] 0x000000d00000-0x000001500000 : "reserved-kernel" [ 5.443390][ T1] 0x000001500000-0x000020000000 : "ubi" [ 5.467292][ T1] lro_sram_membase_res0 from DT: a2013000 [ 5.471819][ T1] ltq_toe_membase: e2000000 and lro_sram_membase_res0: e2013000 [ 5.479612][ T1] TOE Init Done !! [ 6.128320][ T1] i2c /dev entries driver [ 6.133266][ T1] ltq_thermal 16000000.ssx4:ts@080000: ltq_thermal_probe: is done [ 6.144471][ T1] AVM PA 2.179-master for Linux Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 6.144471][ T1] (late init) [ 6.161257][ T1] Mirror/redirect action on [ 6.164889][ T1] u32 classifier [ 6.168221][ T1] Performance counters on [ 6.172733][ T1] input device check on [ 6.177071][ T1] Actions configured [ 6.181392][ T1] ipip: IPv4 and MPLS over IPv4 tunneling driver [ 6.188323][ T1] Initializing XFRM netlink socket [ 6.192341][ T1] IPsec XFRM device driver [ 6.198343][ T1] NET: Registered protocol family 10 [ 6.204784][ T1] NET: Registered protocol family 17 [ 6.208611][ T1] NET: Registered protocol family 15 [ 6.213945][ T1] Bridge flood ratelimiter registered [ 6.218881][ T1] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 6.232472][ T1] lec:lane_module_init: lec.c: initialized [ 6.238082][ T1] mpoa:atm_mpoa_init: mpc.c: initialized [ 6.243608][ T1] KOAM is loaded successfully. [ 6.248235][ T1] l2tp_core: L2TP core driver, V2.0 [ 6.253180][ T1] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 6.259742][ T1] l2tp_netlink: L2TP netlink interface [ 6.264843][ T1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 6.271323][ T1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 6.278693][ T1] 8021q: 802.1Q VLAN Support v1.8 [ 6.285395][ T1] audit: type=1400 audit(5.616:2): apparmor="STATUS" info="AppArmor sha1 policy hashing enabled" pid=1 comm="swapper/0" [ 6.296338][ T1] AppArmor: AppArmor sha1 policy hashing enabled [ 6.306498][ T1] ubi0: attaching mtd4 [ 6.951060][ T1] ubi0: scanning is finished [ 6.991324][ T1] ubi0: attached mtd4 (name "ubi", size 491 MiB) [ 6.996085][ T1] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 7.003606][ T1] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 7.011070][ T1] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 7.018709][ T1] ubi0: good PEBs: 3928, bad PEBs: 0, corrupted PEBs: 0 [ 7.025480][ T1] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128 [ 7.033383][ T1] ubi0: max/mean erase counter: 18/12, WL threshold: 4096, image sequence number: 1997102724 [ 7.043369][ T1] ubi0: available PEBs: 0, total reserved PEBs: 3928, PEBs reserved for bad PEB handling: 80 [ 7.053365][ T695] ubi0: background thread "ubi_bgt0d" started, PID 695 [ 7.061836][ T1] [announce_root] filesystem (/dev/mtdblock5) will be used as root device [ 7.083060][ T1] VFS: Mounted root (squashfs filesystem) readonly on device 31:5. [ 7.094879][ T1] devtmpfs: mounted [ 7.103286][ T1] Freeing unused kernel: 1688k freed [ 7.107092][ T1] This architecture does not have kernel memory protection. [ 8.457502][ T733] eip123_hw: loading out-of-tree module taints kernel. [ 8.462813][ T733] eip123_hw: module license 'Proprietary' taints kernel. [ 8.469699][ T733] Disabling lock debugging due to kernel taint [ 8.476196][ T733] [module-mem] give 0x5000 bytes at 98037000 to module 'eip123_hw' (0xb46000 bytes left) [ 8.513086][ T733] [module-mem] give 0x2000 bytes at 9803c000 to module 'eip123' (0xb44000 bytes left) [ 8.521447][ T733] eip123: no symbol version for eip123_hw_asset_derive [ 8.528765][ T733] eip123 1e000000.eip123: Detected hardware version 2.2.2 [ 8.534742][ T733] eip123 1e000000.eip123: my_id=3 master_id=0 num_mailboxes=4 mailbox_size=256 [ 8.543528][ T733] eip123 1e000000.eip123: Linked mailbox number 1 [ 8.575638][ T733] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=3 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0 [ 8.615640][ T733] eip123 1e000000.eip123: Device responded with error_src=0x2 error=0x2 opcode=0x11 [ 8.923726][ T733] eip123 1e000000.eip123: eip123_hw init successful [ 8.983725][ T733] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c [ 8.991663][ T733] eip123 1e000000.eip123: Could not find rootkey in OTP [ 10.144346][ T0] [0]system-load 33% loadavg 0.8 0.2 0.1 - pgstat: sum=113116 free=100894 slab=2409 alloc=1058/s fault=312/s ai_sys:0.40/s 0x980386bc endian_convert_array+0x30/0x3c [eip12 (sleep 1) [ 12.129181][ T794] [module-mem] module 'hui' reserved size 188416 is to great for demand size 180224 - waste 8192 (module_alloc_waste=8192) [ 12.140458][ T794] [module-mem] give 0x2c000 bytes at 9803e000 to module 'hui' (0xb18000 bytes left) [ 12.156603][ T794] [hui] Initialize hardware user interface [ 12.165497][ T794] [avm_connect][state_machine_init] starting event worker thread [ 12.430167][ T839] [avm_debug] redirecting kernel-messages
