-- prbs_tx.vhd -- VHDL-93 synthesizable PRBS-16 transmitter (one 16-bit frame per clock when enable='1') -- Polynomial: x^16 + x^14 + x^13 + x^11 + 1 -- Frame is the current LFSR state; next frame advances per polynomial. library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity prbs_tx is generic ( SEED : std_logic_vector(15 downto 0) := "1010110011100001" -- non-zero seed ); port ( clk : in std_logic; rst : in std_logic; -- synchronous reset, active '1' enable : in std_logic; -- advance one frame when '1' frame_out : out std_logic_vector(15 downto 0) -- 16-bit PRBS frame ); end entity prbs_tx; architecture rtl of prbs_tx is -- LFSR state (LSB = bit 0). We use Fibonacci form: shift right, MSB gets XOR of taps. signal lfsr : std_logic_vector(15 downto 0) := SEED; -- Next-state function for PRBS-16 (poly x^16 + x^14 + x^13 + x^11 + 1) -- Taps map to bit positions: 0, 2, 3, 5 when using right-shift/insert-at-MSB form. function lfsr16_next(s : std_logic_vector(15 downto 0)) return std_logic_vector is variable fb : std_logic; -- feedback bit variable n : std_logic_vector(15 downto 0); begin fb := s(0) xor s(2) xor s(3) xor s(5); n := fb & s(15 downto 1); -- insert at MSB, shift right return n; end function; begin -- Output current frame (combinational) frame_out <= lfsr; -- State update (sequential) process(clk) begin if rising_edge(clk) then if rst = '1' then lfsr <= SEED; else if enable = '1' then lfsr <= lfsr16_next(lfsr); end if; end if; end if; end process; end architecture rtl;
