Strings.0=Yes Strings.1=No Strings.2=Enter Box description Strings.3=Box Already Exists Strings.4=Box already exists. Do you still want you use this record? Strings.5=Enter the Case description Strings.6=Case Exists Strings.7=Case already exists. Do you still want to use this record? Strings.8=Delete Strings.9=Are you sure you want to delete this record? Strings.10= Strings.11=Open Link: Strings.12=Open File: Strings.13=Exporting Is Finished. Strings.14=The picture is too large to be stored in the database!\r\nSize: %1\r\nUse smaller size picture. Strings.15=Picture Size: Strings.16=Byte Strings.17=Ordered. Strings.18=Do you want to order the component? Strings.19=There are no open positions for the supplier "Reichelt". Strings.20=The supplier "Reichelt" could not be found in "Address"! Strings.21=Enter the Address description Strings.22=Address Exists Strings.23=Address already exists. Do you still want to use this record? Strings.24=Enter the Component description Strings.25=Component Exists Strings.26=Component already exists. Do you still want to use this record? Strings.27=Enter the Description: Strings.28=Opened Strings.29=Ordered Strings.30=Delivered Strings.31=Stored Strings.32=Delete Strings.33=Some components use this case.\r\nDo you really want to delete this case? Strings.34=Enter The Password Strings.35=Enter the Database password: Strings.36=Ordering position already exists ! Strings.37=Component already exists in the order list. Do you still want to use this record? Strings.38=Enter the Type description Strings.39=Order No. Strings.40=Import Data Strings.41=Importing will delete all records from the selected tables and inserts the records from the file.\r\nDo you still want to start importing? Strings.42=Store/Compartment exists Strings.43=Store/Compartment already exists. Do you want to rename the entry? Strings.44=Store/Compartment Strings.45=Enter a new Description Strings.46=Enter the Project description Strings.47=Project Exists Strings.48='Project' already exists. Do you still want to use this record? Strings.49=Main picture Strings.50=Additional Picture Strings.54=Topic Selection Strings.55=Book the components for the Project Strings.56=The project is finished. Should the components used in the project be subtracted from the store? Strings.57=Enter the Description frmMain.tabBauteil=Component - F2 frmMain.tabBBauteil=Component frmMain.edLagerManiHint=Increase / Decrease Inventory frmMain.btnLagerManiM=- frmMain.btnLagerManiMHint=Decrease Inventory frmMain.btnLagerManiP=+ frmMain.btnLagerManiPHint=Increase Inventory frmMain.spGotoCaseHint=Go To Type frmMain.spGotoKisteHint=Go To Box frmMain.spGotoAdrLGHint=Go To Address frmMain.lbBauteilHandbuch1=&Manual frmMain.spHandbuch1Hint=Select Manual (File) frmMain.spHandbuch1ExecHint=Open Manual frmMain.spBNew1Hint=New Entry frmMain.spBCopy1Hint=Copy Data frmMain.spBSave1Hint=Save Data frmMain.spBAbort1Hint=Cancel Changes frmMain.spBDelete1Hint=Delete Data frmMain.lbDatum11=Date: frmMain.spBPrint1Hint=Print frmMain.tabBLief=Supplier frmMain.spBNew2Hint=New Entry frmMain.spBCopy2Hint=Copy Data frmMain.spBSave2Hint=Save Data frmMain.spBAbort2Hint=Cancel Changes frmMain.spBDelete2Hint=Delete Data frmMain.lbDatum12=Date: frmMain.spBPrint2Hint=Print frmMain.lbBLiefCaseLag=Store/&Case frmMain.lbBLiefAdr=&Address frmMain.lbBLiefBestNr=&Order Code frmMain.lbBLiefEPreis=&Price (Each) frmMain.spGotoAdrHint=Go To Address frmMain.spGotoLagerHint=Go To Store/Case frmMain.lbBauteilTyp=&Type frmMain.lbBauteilHandbuch=&Manual frmMain.lbBauteilBez=&Description frmMain.spBauteilTypHint=Select Type frmMain.spHandbuchHint=Select Manual (File) frmMain.spHandbuchExecHint=Open Manual frmMain.lbBauteilLibrary=&Library frmMain.spBNewHint=New Entry frmMain.spBCopyHint=Copy Data frmMain.spBSaveHint=Save Data frmMain.spBAbortHint=Cancel Changes frmMain.spBDeleteHint=Delete Data frmMain.lbDatum1=Date: frmMain.spBPrintHint=Print frmMain.edSchnellsucheHint=Quick Search frmMain.spBExpHint=Import/Export frmMain.tabProjekt=Project - F3 frmMain.lbProjektHandbuch=&Manual frmMain.lbProjektBez=&Description frmMain.spHandbuch2Hint=Select Manual (File) frmMain.spHandbuch2ExecHint=Open Manual frmMain.lbProjektMengeFertig=&Quantity Ready frmMain.lbProjektMengeOffen=Q&uantity Opened frmMain.lbProjektTermin=&Appointment frmMain.spProjektBuchHint=Store Bookkeeping frmMain.spPNewHint=New Entry frmMain.spPCopyHint=Copy Data frmMain.spPSaveHint=Save Data frmMain.spPAbortHint=Cancel Changes frmMain.spPDeleteHint=Delete Data frmMain.lbDatum7=Date: frmMain.spPPrintHint=Print frmMain.edSchnellsucheProjHint=Quick Search frmMain.spPExpHint=Import/Export frmMain.tabPUebers=Overview frmMain.tabPPos=Position frmMain.lbPPosSMD=S&MD frmMain.lbPPosMenge=Quantit&y frmMain.lbPPosBez=D&escription frmMain.lbPPosBauteil=&Component frmMain.spGotoBauteil1Hint=Go To Component frmMain.lbPPosLagCase=&Case/Variant frmMain.spGotoBauteilLG1Hint=Go To Store/Case frmMain.lbPPosSymbol=Symb&ol frmMain.lbPPosWert=&Value frmMain.lbPPosCase=C&ase frmMain.lbPPosVariante=Va&riant frmMain.lbPPosTop=To&p frmMain.lbPPosPosX=Pos &X frmMain.lbPPosPosY=Pos &Y frmMain.spFilterVarianteHint=Filter By Variant frmMain.spPNew1Hint=New Entry frmMain.spPCopy1Hint=Copy Data frmMain.spPSave1Hint=Save Data frmMain.spPAbort1Hint=Cancel Changes frmMain.spPDelete1Hint=Delete Data frmMain.lbDatum13=Date: frmMain.spPPrint1Hint=Print frmMain.spPPExpHint=Import/Export frmMain.tabPHistorie=History frmMain.lbProjektHistHandbuch=&Manual frmMain.lbProjektHistProjBez=&Project frmMain.spHandbuch3Hint=Select Manual (File) frmMain.spHandbuch3ExecHint=Open Manual frmMain.lbProjektHistVersion=&Version frmMain.lbProjektHistAufwand=T&ime frmMain.lbProjektHistDatum=D&ate frmMain.lbProjektHistBez=D&escription frmMain.spHNew1Hint=New Entry frmMain.spHCopy1Hint=Copy Data frmMain.spHSave1Hint=Save Data frmMain.spHAbort1Hint=Cancel Changes frmMain.spHDelete1Hint=Delete Data frmMain.lbDatum8=Date: frmMain.spHPrint1Hint=Print frmMain.tabBestell=Order - F4 frmMain.spONewHint=New Entry frmMain.spOCopyHint=Copy Data frmMain.spOSaveHint=Save Data frmMain.spOAbortHint=Cancel Changes frmMain.spODeleteHint=Delete Data frmMain.lbDatum2=Date: frmMain.spOPrintHint=Print frmMain.spOExpHint=Import/Export frmMain.edSchnellsucheBestHint=Quick Search frmMain.lbBestBez=&Description frmMain.lbBestMenge=&Quantity (Packing Unit) frmMain.lbBestBauteil=Co&mponent frmMain.lbBestLagCase=&Store/Case frmMain.lbBestLiefLagCase=Suppl&ier/Store/Case frmMain.lbBestStatus=Status frmMain.spBestelltFilterHint=Filter By Current Status frmMain.btnBestellLagerBuch=Book &In Store frmMain.spGotoBauteilHint=Go To Component frmMain.spGotoBauteilLGHint=Go To Store/Case frmMain.lbBestL1BestNr=&Order Code frmMain.lbBestL1EP=&Puchase Price frmMain.lbBestL1GP=Total Price frmMain.spGotoAdrL1Hint=Go To Address frmMain.lbBestL2GP=Total Price frmMain.spGotoAdrL2Hint=Go To Address frmMain.grpSum=Totals frmMain.lbBestSumOffen=Cost "Opened" frmMain.tabSuche=Search - F5 frmMain.lbSuchSuch=&Search frmMain.spSPrintHint=Print frmMain.rbSuchBaut=In &Components frmMain.rbSuchHist=In &History frmMain.rbSuchWissen=In &Knowledge frmMain.tabCase=Case - F6 frmMain.spCNewHint=New Entry frmMain.spCCopyHint=Copy Data frmMain.spCSaveHint=Save Data frmMain.spCAbortHint=Cancel Changes frmMain.spCDeleteHint=Delete Data frmMain.lbDatum3=Date: frmMain.spCPrintHint=Print frmMain.edSchnellsucheCaseHint=Quick Search frmMain.lbCaseBez=&Description frmMain.lbCasePin=&Pins frmMain.DBCheckBox2=&SMD frmMain.lbCaseRaster=&Raster frmMain.lbCasemm=mm frmMain.Panel37=Component With Selected Case frmMain.tabKiste=Box - F7 frmMain.spKNewHint=New Entry frmMain.spKCopyHint=Copy Data frmMain.spKSaveHint=Save Data frmMain.spKAbortHint=Cancel Changes frmMain.spKDeleteHint=Delete Data frmMain.lbDatum4=Date: frmMain.spKPrintHint=Print frmMain.edSchnellsucheKisteHint=Quick Search frmMain.spKFachHint=Manage Components In Box / Compartment frmMain.lbKisteBez=&Description frmMain.lbKisteLagO=&Location frmMain.lbKisteSize=&Size frmMain.lbKisteNr=&Number frmMain.lbKistePX=Pos &X frmMain.lbKistePY=Pos &Y frmMain.tabTyp=Type - F8 frmMain.spTNewHint=New Entry frmMain.spTCopyHint=New Subentry frmMain.spTSaveHint=Save Data frmMain.spTAbortHint=Cancel Changes frmMain.spTDeleteHint=Delete Data frmMain.lbDatum5=Date: frmMain.spTPrintHint=Print frmMain.rbTypAnsichtNur=&Only Selected Type frmMain.rbTypAnsichtAlle=&With Selected Subtypes frmMain.lbTypAnsicht=View frmMain.tabAdr=Address - F9 frmMain.lbAdrBez=&Description frmMain.lbAdrFirma=&Company frmMain.lbAdrStr=&Street frmMain.lbAdrPlz=&PostCode/Loc. frmMain.lbAdrName=&Name frmMain.lbAdrTel=&Telephone 1 frmMain.lbAdrMobil=Mobile P&hone frmMain.lbAdrFax=F&ax frmMain.lbAdrINet=&Internet Link frmMain.lbAdrMail=&E-Mail frmMain.lbAdrKundNr=C&ustomer No. frmMain.lbAdrUsId=&VAT ID frmMain.spInternetHint=Open Web Browser frmMain.lbAdrLand=C&ountry frmMain.spANewHint=New Entry frmMain.spACopyHint=Copy Data frmMain.spASaveHint=Save Data frmMain.spAAbortHint=Cancel Changes frmMain.spADeleteHint=Delete Data frmMain.lbDatum6=Date: frmMain.spAPrintHint=Print frmMain.edSchnellsucheAdrHint=Quick Search frmMain.tabExtras=Extras - F10 frmMain.tabExtraCalc=Calculator frmMain.grpTimer=Timer frmMain.lbTimerStartZeit=Start &Time frmMain.lbTimerHMS=H:M:S frmMain.lbTimeAktuell=Current Time frmMain.btnCalculator=Calculator frmMain.btnCalendar=Calendar frmMain.grpSMDCode=SMD Code frmMain.lbSMDCode=Value frmMain.lbSMDCodeHalbl=Semiconductors frmMain.lbSMDCodeHalblDesc=This semiconductor table has been made available by http://www.elektronik-kompendium.de/. Thank you!\r\nIf a component could not be found, you can search it online: frmMain.btnSmdCodeElKo=To http://www.elektronik-kompendium.de/ frmMain.btnCalcR=Voltage Divider frmMain.btnCalcLM317=LM317 / LM350 frmMain.tabExtraHistorie=History frmMain.lbHistExHandbuch=&Manual frmMain.lbHistExProjBez=P&roject frmMain.spHandbuch4Hint=Select Manual (File) frmMain.spHandbuch4ExecHint=Open Manual frmMain.lbHistExVersion=&Version frmMain.lbHistExAufwand=&Time frmMain.lbProjektTermin2=&Date frmMain.lbHistExBez=D&escription frmMain.lbHistExProj=&Project frmMain.spGotoProjektHint=Go To Project frmMain.spHNewHint=New Entry frmMain.spHCopyHint=Copy Data frmMain.spHSaveHint=Save Data frmMain.spHAbortHint=Cancel Changes frmMain.spHDeleteHint=Delete Data frmMain.lbDatum9=Date: frmMain.spHPrintHint=Print frmMain.tabExtraWissen=Information frmMain.lbWissenHandbuch=&Manual frmMain.spHandbuch5Hint=Select Manual (File) frmMain.spHandbuch5ExecHint=Open Manual frmMain.lbWissenThema=&Topic frmMain.lbWissenBez=&Description frmMain.spWNewHint=New Entry frmMain.spWCopyHint=Copy Data frmMain.spWSaveHint=Save Data frmMain.spWAbortHint=Cancel Changes frmMain.spWDeleteHint=Delete Data frmMain.lbDatum10=Date: frmMain.spWPrintHint=Print frmMain.tabExtraLog=Log frmMain.chkDebugPause=&Pause Log frmMain.tabExtraDatabase=Database frmMain.lbDDB=Database Manipulation With SQL Commands frmMain.spDPrintHint=Print frmMain.spDExpHint=Import/Export frmMain.spDSaveHint=Save Data frmMain.spDAbortHint=Cancel Changes frmMain.spDDeleteHint=Delete Data frmMain.btnDebugSQL=&Execute frmMain.btnDebugOeffnen=Open &All frmMain.btnDebugOeffnenHint=With this button all tables (other tabs) can be updated frmMain.chkDebErwIns=MultiInsert frmMain.chkDebErwInsHint=Several records with an INSERT command process frmMain.tabExtraInfo=Info frmMain.lbDInfo1=Management Of Warehouse And Production Orders frmMain.lbDInfo2=This program may be freely used and copied, it's freeware frmMain.btnHelp=Help - F1 frmMain.grpLanguage=Translation frmMain.btnLangSave=&Save Text frmMain.btnLangLoad=&Loading Text frmMain.btnLangTranslate=&Translations frmMain.qAdrfoto_ID=Photo ID frmMain.qAdrBezeichnung=Description frmMain.qAdrFirma=Company frmMain.qAdrStrasse=Street frmMain.qAdrPLZ=Postal Code frmMain.qAdrOrt=Location frmMain.qAdrName=Name frmMain.qAdrTelefon=Phone 1 frmMain.qAdrMobil=Mobile Phone frmMain.qAdrFax=Fax frmMain.qAdrEMail=EMail frmMain.qAdrInternet=Internet Link frmMain.qAdrUsSTID=VAT ID frmMain.qAdrKundNr=Customer ID frmMain.qAdrBemerkung=Note frmMain.qAdrLand=Country frmMain.qAdrAendDatum=Change Date frmMain.qKisteFoto_ID=Photo ID frmMain.qKisteBezeichnung=Description frmMain.qKisteLagerort=Location frmMain.qKisteNummer=Number frmMain.qKistePosX=PosX frmMain.qKistePosY=PosY frmMain.qKisteGroesse=Size frmMain.qKisteAendDatum=Change Date frmMain.qTypBezeichnung=Description frmMain.qTypAendDatum=Change Date frmMain.qBauteilFoto_ID=Photo ID frmMain.qBauteiltree_typ_ID=Type ID frmMain.qBauteilBezeichnung=Description frmMain.qBauteilBeschreibung=Text frmMain.qBauteilHandbuch=Manual frmMain.qBauteilLibrary=Library frmMain.qBauteilKennz=Flag frmMain.qBauteilAendDatum=Change Date frmMain.qBAdrBauteil_ID=Component ID frmMain.qBAdrAdr_ID=Address frmMain.qBAdrBestellNr=Order Code frmMain.qBAdrEPreis=Purchase Cost frmMain.qBAdrBemerkung=Note frmMain.qBAdrAendDatum=Change Date frmMain.qSuchtree_typ_ID=Type frmMain.qSuchBezeichnung=Description frmMain.qSuchCBez=Comp. Descr. frmMain.qSuchSMD=SMD frmMain.qSuchSMD_Text=SMD_Text frmMain.qSuchKBez=Box Descr. frmMain.qSuchLagerNr=Storage No. frmMain.qSuchMenge=Quantity frmMain.qSuchHaltbar=Preserved frmMain.qSuchBarcode=Barcode frmMain.qSuchAdrBez=AddrDescr. frmMain.qSuchBestellNr=Order Code No. frmMain.qSuchEPreis=Purchase Price frmMain.qSuchGPreis=Total Price frmMain.oDlg=Select Existing File frmMain.qFotoBezeichnung=Description frmMain.qFotoTabelle=Table frmMain.qFotoBildTyp=Picture Type frmMain.qFotoBild=Picture frmMain.qFotoAendDatum=Change Date frmMain.oPic=Select Picture frmMain.qBestellBezeichnung=Description frmMain.qBestellMenge=Quantity frmMain.qBestellStatus=Status frmMain.qBestellBemerkung=Note frmMain.qBestellBauteil_ID=Component frmMain.qBestellLief1_Adr_ID=Deliv1 Addr frmMain.qBestellLief1_BestellNr=Deliv1 Order No. frmMain.qBestellLief1_EPreis=Deliv1 Price frmMain.qBestellLief1_GPreis=Deliv1 Total frmMain.qBestellLief2_Adr_ID=Deliv2 Addr frmMain.qBestellLief2_BestellNr=Deliv2 Order No. frmMain.qBestellLief2_EPreis=Deliv2 Price frmMain.qBestellLief2_GPreis=Deliv2 Total frmMain.qBestellAendDatum=Change Date frmMain.mnBestMengeMin=Components With Quantity Less Than Minimum frmMain.mnExpReichelt=Reichelt Export frmMain.mnImpBest=Order Import frmMain.sDlgCsv=Export frmMain.oDlgCsv=Import frmMain.mnDebugLogCopy=Copy Line frmMain.mnDebugLogCopyAll=Copy All Lines frmMain.mnDebugLogClear=Clear Log frmMain.mnExpCSV=Export In CSV Format frmMain.mnExpXML=Export In XML Format frmMain.mnDBExport=Export/Import Database frmMain.sDlgXml=Export frmMain.mnBExpCsv=Export In CSV Format frmMain.mnBExpXML=Export In XML Format frmMain.mnTypNeu=New Entry frmMain.mnTypNeuU=New Subentry frmMain.mnTypEdit=Edit frmMain.mnTypDelete=Delete frmMain.qTypBLID=LID frmMain.qTypBBezeichnung=Description frmMain.qTypBBeschreibung=Text frmMain.qTypBLBez=Store Desc. frmMain.qTypBMenge=Quantity frmMain.qTypBKiste=Box frmMain.qTypBLagerNr=Storage No. frmMain.qTypBBemerkung=Note frmMain.qProjektFoto_ID=Photo ID frmMain.qProjektBezeichnung=Description frmMain.qProjektBeschreibung=Text frmMain.qProjektMengeFertig=Quantity Finished frmMain.qProjektMengeOffen=Quantity Opened frmMain.qProjektKennz=Flag frmMain.qProjektTermin=Appointment frmMain.qProjektHandbuch=Manual frmMain.qProjektAendDatum=Change Date frmMain.qPPosProjekt_ID=Project ID frmMain.qPPosBezeichnung=Description frmMain.qPPosBemerkung=Note frmMain.qPPosBauteil_ID=Component frmMain.qPPosSymbol=Symbol frmMain.qPPosWert=Value frmMain.qPPosMenge=Quantity frmMain.qPPosVariante=Variant frmMain.qPPosPosX=Pos X frmMain.qPPosPosY=Pos Y frmMain.qPPosTop=Top frmMain.qPPosSMD=SMD frmMain.qPPosKennz=Flag frmMain.qPPosAendDatum=Change Date frmMain.mnPPSchnell=Quick Entry frmMain.mnExpCSV1=Export in CSV Format frmMain.mnExpXML1=Export in XML Format frmMain.mnExpCSV2=Export In CSV Format frmMain.mnExpXML2=Export in XML Format frmMain.qHist1Projekt_ID=Project frmMain.qHist1Foto_ID=Photo ID frmMain.qHist1Datum=Date frmMain.qHist1Projekt=Project Descr. frmMain.qHist1Bezeichnung=Description frmMain.qHist1Beschreibung=Text frmMain.qHist1Version=Version frmMain.qHist1Kennz=Flag frmMain.qHist1Aufwand=Time frmMain.qHist1Handbuch=Manual frmMain.qHist1AendDatum=Change Date frmMain.qHistProjekt_ID=Project frmMain.qHistFoto_ID=Photo ID frmMain.qHistDatum=Date frmMain.qHistProjekt=Project Descr. frmMain.qHistBezeichnung=Description frmMain.qHistBeschreibung=Text frmMain.qHistVersion=Version frmMain.qHistKennz=Flag frmMain.qHistAufwand=Time frmMain.qHistHandbuch=Manual frmMain.qHistAendDatum=Change Date frmMain.qWissenFoto_ID=Photo ID frmMain.qWissenBezeichnung=Description frmMain.qWissenBeschreibung=Text frmMain.qWissenThema=Topic frmMain.qWissenKennz=Flag frmMain.qWissenHandbuch=Manual frmMain.qWissenAendDatum=Change Date frmMain.qSuchHProjekt_ID=Project frmMain.qSuchHFoto_ID=Photo ID frmMain.qSuchHDatum=Date frmMain.qSuchHProjekt=Project Descr. frmMain.qSuchHBezeichnung=Description frmMain.qSuchHBeschreibung=Text frmMain.qSuchHVersion=Version frmMain.qSuchHKennz=Flag frmMain.qSuchHAufwand=Time frmMain.qSuchHHandbuch=Manual frmMain.qSuchHAendDatum=Change Date frmMain.qSuchWFoto_ID=Photo ID frmMain.qSuchWBezeichnung=Description frmMain.qSuchWBeschreibung=Text frmMain.qSuchWThema=Topic frmMain.qSuchWKennz=Flag frmMain.qSuchWHandbuch=Manual frmMain.qSuchWAendDatum=Change Date frmMain.mnProjMengeTest=Check Quantity For Production frmMain.mnProjMengeBuche=Book quantity after production frmBestellMin=Below minimum reorder quantities frmBestellMin.btnClose=Close frmBestellMin.qryOID=OID frmBestellMin.qryBezeichnung=Description frmBestellMin.qryMenge=Quantity frmBestellMin.qryMengeMin=Quantity Min frmBestellMin.qryStatus=Status frmBestellMin.qryKiste=Box frmBestellMin.qryLagerNr=Storage No. frmBild=Picture View 100% frmPPosTest=Check inventory frmPPosTest.btnClose=Close frmDruckEtikett=EleLa - Printing Label frmDruckEtikett.lbAuswKiste=&Select Box frmDruckEtikett.rgrpAuswahl=Lab&el Format frmDruckEtikett.rgrpAuswahlItem0=Individual frmDruckEtikett.rgrpAuswahlItem1=39.5 x 17.5 mm (Standard Sort Box) frmDruckEtikett.lbBreite=Label &Width frmDruckEtikett.lbMM1=mm frmDruckEtikett.lbMM2=mm frmDruckEtikett.lbHoch=Label &Height frmDruckEtikett.lbFontGr=Font Height frmDruckEtikett.lbFont=&Font frmDruckEtikett.spDataHint=Display Components frmDruckEtikett.rGrpAusricht=Alignment frmDruckEtikett.rGrpAusrichtItem0=Left frmDruckEtikett.rGrpAusrichtItem1=Center frmDruckEtikett.chkGrpFelder=Select Fields frmDruckEtikett.chkGrpFelderItem0=Box frmDruckEtikett.chkGrpFelderItem1=Store/Compartment frmDruckEtikett.chkGrpFelderItem2=Component Description frmDruckEtikett.chkGrpFelderItem3=Store/Case Description frmDruckEtikett.chkGrpFelderItem4=Case frmDruckEtikett.btnPrint=Print frmDruckEtikett.btnAbbruch=Cancel frmDruckEtikett.qDataLagerNr=Storage No. frmDruckEtikett.qDataBezeichnung=Description frmDruckEtikett.qDataLBezeichnung=Store Description frmDruckEtikett.qDataGehuse=Case frmImportExport=Export/Import database frmImportExport.btnClose=Close frmImportExport.chkGrp=&Select Table frmImportExport.btnExport=&Export frmImportExport.lbFile=&File frmImportExport.btnImport=&Import frmKisteTausch=Store/compartment exchange frmKisteTausch.Panel3=Box/Storage No./Compartment frmKisteTausch.Panel5=Contents of Box/Storage No./Compartment frmKisteTausch.btnBauteilKisteEntf=Remove Component From Box frmKisteTausch.btnBauteilInFach=Add Component To Storage Compartment frmKisteTausch.btnFachAdd=Add Storage Compartment frmKisteTausch.btnBauteilFachEntf=Remove Component From Storage Compartment frmKisteTausch.btnFachRen=Rename Storage Compartment frmKisteTausch.btnFachMove=Move Content By Box / Storage No. frmKisteTausch.btnClose=Close frmKisteTausch.Panel8=Component List frmKisteTausch.lbSuch=Quick Search frmKisteTausch.qInhaltBauteilBez=Component Description frmKisteTausch.qInhaltCBez=Case frmKisteTausch.qBauteilBID=BID frmKisteTausch.qBauteilBauteilBez=Component Description frmKisteTausch.qBauteilCBez=Case frmKisteTausch.qBauteilKiste=Box frmKisteTausch.qBauteilLagerNr=Storage No. frmKisteTausch.mnTVRen=Rename Compartment frmKisteTausch.mnTVAdd=Add Storage Compartment frmKisteTausch.mnInhaltEntfKiste=Remove Component From Box frmKisteTausch.mnInhaltEntfFach=Remove Component From Storage Compartment frmKisteTausch.mnBauteilInFach=Add Component To The Storage Compartment frmKisteTausch.mnOpenKiste=Open Tree-View Box frmStatus=Status frmStatus.Panel1=Status Change During Import frmStatus.rGrpItem0=Do Not Change frmStatus.rGrpItem1=Opened frmStatus.rGrpItem2=Ordered frmStatus.rGrpItem3=Delivered frmStatus.rGrpItem4=Stored frmStatus.btnOK=OK frmTypAuswahl=Select type frmTypAuswahl.btnOK=OK frmTypAuswahl.btnAbbruch=Cancel frmKisteTauschDlg=Move content frmKisteTauschDlg.lbKiste=&Box frmKisteTauschDlg.lbLagerNr=Storage No./Compartment frmKisteTauschDlg.btnOK=&OK frmKisteTauschDlg.btnAbbruch=&Cancel frmKisteTauschDlg.lbVonKiste=From Box frmCalcR=Resistor divider frmCalcR.lbCaption=Calculate Resistive Voltage Divider frmCalcR.lbUges=&Uin frmCalcR.lbUfb=U&out frmCalcR.lbV=V frmCalcR.lbV1=V frmCalcR.btnClose=&Close frmCalcLM317=LM317/LM350 Calculator frmCalcLM317.lbCaption=Voltage Divider For LM317/LM350 frmCalcLM317.btnClose=&Close frmSchnell=Components Quick Entry frmSchnell.lbBauteil=&Component frmSchnell.lbCase=&Case/variant frmSchnell.lbBez=Id&entifier frmSchnell.lbStart=Number &Start frmSchnell.lbEnd=&Number End frmSchnell.lbFormat=Number &Format frmSchnell.btnErz=&Create >>> frmSchnell.btnDel=Delete frmSchnell.lbDemo=Demo frmSchnell.btnCancel=&Cancel frmSchnell.btnOK=&Add frmSchnell.btnClear=Clear frmSchnell.lbTyp=Type frmSchnell.spBauteilTypHint=Select type frmSchnell.spFilterTypHint=Set filter to selected type frmMain.chkTypCase=Filter By Case frmMain.grpExtraExchange=Currency Converter frmMain.lbExtraExchKurs=&Course frmMain.lbExtraExchBetrag=&Amount frmMain.lbExtraExchErg=Result frmMain.btnCalcLCD=LCD Display frmMain.qTypBGehause=Case frmCalcLCD=LCD Graphic Display frmCalcLCD.btnClose=&Close frmCalcLCD.Label1=Calculation Font / Size For Graphic LCD frmCalcLCD.lbLCDX=Display Size X frmCalcLCD.lbLCDPixel1=Pixel frmCalcLCD.lbLCDFont=Font frmCalcLCD.lbLCDTestText=Test Text frmCalcLCD.lbLCDAnsicht=View frmCalcLCD.rbLCDNormal=Normal frmCalcLCD.rbLCDStretched=Stretched frmCalcLCD.lbLCDFontSize=Font Size frmCalcLCD.lbLCDPixel2=Pixel frmCalcLCD.Label2=Contrast frmCalcLCD.chkBold=Bold frmCalcLCD.Label3=(0..255) frmCalcLCD.chkPixel=Pixilated frmCalcLCD.lbLCDFont1=Top Offset frmCalcLCD.lbLCDPixel3=Pixel frmCalcLCD.chkPixGrau=Grayscale frmCalcLCD.chk8Bit=In 8-bit crushing frmBestellMin.qryGehause=Case frmCalcLCD.lbLCDY=Y Strings.58=Date Reached frmMain.spTel1Hint=Dial Phone No. frmMain.spTel2Hint=Dial Phone No. frmMain.mnCpBautMit=Copy With Store/Case frmMain.mnTelKonfig=Configuration frmTelParam=Dial parameter frmTelParam.Label1=COM &Port With Modem frmTelParam.Label2=AT &Init Sequence frmTelParam.Label3=&Dial Prefix frmTelParam.btnOK=&OK frmTelParam.btnCancel=&Cancel frmMain.spGotoLiefOnlineHint=Go To Homepage Of Supplier frmMain.lbPPosEPreis=Pr&ice frmMain.lbPPosGPreis=Total Price frmMain.lbPPosSum=Sum frmMain.lbAdrGebDatum=Bi&rthday frmMain.qAdrGebDatum=Birthday frmMain.mnExpBestNr=Export Order Number frmMain.qPPosEPreis=Purchase Price frmMain.qPPosGPreis=Total Price frmMain.mnAdrDruck=Print Phone No. List frmMain.spFilterBauteilHint=Filter By Component frmMain.qTypFoto_ID=Photo ID frmDruckEtikett.grpBarcode=Barcode frmDruckEtikett.lbBarcode=Code frmDruckEtikett.lbFontGr1=Height frmDruckEtikett.lbFontGr2=Width frmDruckEtikett.chkMitCodeText=With bar codes as text frmExpBestNr=Export order numbers frmExpBestNr.Lieferant=Supplier frmExpBestNr.Lieferant1=Separator frmExpBestNr.btnClose=&Close frmMain.lbAdrKundNr1=Lo&gin frmMain.qAdrLogin=Login frmMain.qAdrPasswort=Password Strings.59=There are more identical positions to which no component / store has been linked.\r\nDo you want to set all the items to this component/store/case? Strings.60=Select type frmMain.lbCaseBez1=&Type frmMain.spFilterCaseTypHint=Filter By Type frmMain.mnPPCopyItemVal=Copy Component/Store/Case frmMain.mnCopySQL=Copy SQL Script frmMain.spBLCaseHint=Select Case frmMain.spPPBauteilHint=Select Component frmAuswahl=Select frmAuswahl.btnCancel=&Cancel frmAuswahl.btnOK=&OK frmAuswahl.lbSuche=Search: frmAuswahl.qryBFID=FID frmAuswahl.qryBBezeichnung=Description frmAuswahl.qryBBeschreibung=Text frmAuswahl.qryBGehause=Case frmAuswahl.qryBBemerkung=Note frmAuswahl.qryCFoto_ID=Photo ID frmAuswahl.qryCBezeichnung=Description frmAuswahl.qryCTyp=Type frmAuswahl.qryCPins=Pin frmAuswahl.qryCRaster=Raster frmAuswahl.qryCText=Text frmAuswahl.qryCSMD=SMD frmAuswahl.qryCAendDatum=Change Date frmMain.spBestelltFilterSuchHint=Filter By Order frmMain.lbSuchSum=Sum: frmMain.spFilterAdrHint=Filter By Address Strings.61=The configuration has been changed.\r\nTo activate the new configuration you must close and restart EleLa. frmMain.btnKonfig=&Options frmKonfig=Configuration frmKonfig.btnSave=Save frmKonfig.btnClose=Close frmKonfig.tabLanguage=Language frmKonfig.rgrpLanguageItem0=German Electronic Store frmKonfig.rgrpLanguageItem1=German Warehouse frmKonfig.rgrpLanguageItem2=English Electronic Store frmKonfig.lbTablefile1=Title EXE frmKonfig.tabDatbase=Database frmKonfig.lbProtocol=Protocol frmKonfig.lbHost=Host frmKonfig.lbPort=Port frmKonfig.lbDatabase=Database frmKonfig.lbPasswort=Password frmKonfig.lbUser=User frmKonfig.tabDir=Directories frmKonfig.tabTel=Phone frmKonfig.lbTPort=COM-Port frmKonfig.lbTStart=AT Init frmKonfig.lbTDial=Dial Prefix frmKonfig.tabExtra=Extras frmKonfig.lbTablefile=Table-File frmKonfig.chkTableSaveSort=Save Table Sorting Order frmKonfig.lbStartCopy=Start Copy frmKonfig.lbStartRun=Start Run frmKonfig.tabFile=INI File frmKonfig.oDB=Open Database File frmKonfig.oDir=Select Directory frmKonfig.btnTestDB=Test connection frmKonfig.tabLinux=Linux frmKonfig.lbLItem=Combo Item Height frmKonfig.lbLFont=Font Size frmMain.qAdrBank=Bank frmMain.qAdrBLZ=BLZ frmMain.qAdrKonto=Account frmMain.qBAdrEPMenge=From Quantity frmMain.mnBauteilMove=Move record frmMain.mnBauteilCopy=Copy Record frmAuswahl.qryDtree_typ_ID=tree_typ_ID frmAuswahl.qryDFoto_ID=Photo ID frmAuswahl.qryDBezeichnung=Description frmAuswahl.qryDBeschreibung=Text frmAuswahl.qryDHandbuch=Manual frmAuswahl.qryDLibrary=Library frmAuswahl.qryDKennz=Flag frmAuswahl.qryDAendDatum=Change Date frmKonfig.lbDirHandbuch=Components frmKonfig.lbDirProjekt=Project frmMain.lbPPosStatus=Status frmMain.spPPStatusHint=Select status frmMain.lbPPosSuchIn=(...) frmMain.spGotoBestL1OnlineHint=Go To Homepage Of Supplier frmMain.spGotoBestL2OnlineHint=Go To Homepage Of Supplier frmMain.spBestellBauteilHint=Select Component frmMain.spGeburtstagHint=Select Date frmMain.qPPosStatus=Status frmMain.mnPPImportCAD=Import CAD CSV frmMain.mnCpProjMit=Copy With Position frmMain.mnPPBuchen=Store booking frmMain.mnPPSetLoesch=All: Clear Status frmMain.mnPPSetOffen=All: Set Status Open frmMain.mnPPSetAktiv=All: Set Status Active frmMain.mnPPSetFertig=All: Set Status Ready frmMain.mnPPSetPruef=All: Set Status Test frmMain.mnPPSetNV=All: Set Status Not Used frmAuswahl.qryEFoto_ID=Photo ID frmAuswahl.qryEBezeichnung=Description frmAuswahl.qryEBeschreibung=Text frmAuswahl.qryEKennz=Flag frmAuswahl.qryEMengeFertig=Quantity Finished frmAuswahl.qryEMengeOffen=Quantity Opened frmAuswahl.qryETermin=Appointment frmAuswahl.qryEHandbuch=Manual frmAuswahl.qryEAendDatum=Change Date frmBauteil=inventory list frmBauteil.btnClose=Close frmBauteil.qryBezeichnung=Description frmBauteil.qryMenge=Quantity frmMain.lbBLiefVPE=Packaging &Unit frmMain.lbProjektBauteil=Component frmMain.spProjektBauteilHint=Select Component frmMain.spGotoBauteil2Hint=Go To Component frmMain.lbProjLagCase=Store/Case frmMain.spGotoBauteilLG2Hint=Go To Store/Case frmMain.spPPosNicht=D frmMain.spPPosNichtHint=Defective frmMain.spPPosPruefen=T frmMain.spPPosPruefenHint=test frmMain.spPPosFertigHint=Ready frmMain.spPPosAktiv=A frmMain.spPPosAktivHint=Active frmMain.spPPosOffen=O frmMain.spPPosOffenHint=Open frmMain.spPPosKeinHint= frmMain.lbProjektHistSN=Serial numbe&r frmMain.lbProjektHistGN=Devi&ce No. frmMain.lbProjektHistFDatum=Date Read&y frmMain.lbProjektHistFVersion=Versi&on Ready frmMain.spHist1FilterHint=Filter By Current Status frmMain.lbProjektHistStatus=Status frmMain.spHist1FilterBFHint=Filter By Current B/F frmMain.spHist1BugFHint=Feature frmMain.spHist1Bug=B frmMain.spHist1BugHint=Bug frmMain.spHist1BugN=N frmMain.spHist1BugNHint=Not Used frmMain.lbHistStatus2=B/F frmMain.spHist1Hist=H frmMain.spHist1HistHint=History frmMain.spHist1Offen=O frmMain.spHist1OffenHint=Open frmMain.spHist1Aktiv=A frmMain.spHist1AktivHint=Active frmMain.spHist1FertigHint=Ready frmMain.spHist1Nicht=N frmMain.spHist1NichtHint=not edit frmMain.spHist1Spaeter=L frmMain.spHist1SpaeterHint=later frmMain.lbBestSumBestellt=Cost "Ordered" frmMain.lbBestProjekt=Pro&ject frmMain.spGotoProjektBestellHint=Go To Project frmMain.spBestOffen=O frmMain.spBestOffenHint=Open frmMain.spBestBestellt=O frmMain.spBestBestelltHint=Ordered frmMain.spBestGeliefert=D frmMain.spBestGeliefertHint=Delivered frmMain.spBestEingelagertHint=stored frmMain.lbHistExFVersion=Versi&on Ready frmMain.lbHistExFDatum=Date Read&y frmMain.lbHistExGN=Devi&ce No. frmMain.lbHistExSN=&Serial Number frmMain.spHistFilterHint=Filter By Current Status frmMain.lbHistStatus=Status frmMain.lbHistStatus1=B/F frmMain.spHistBug=B frmMain.spHistBugHint=Bug frmMain.spHistBugN=N frmMain.spHistBugNHint=Not Used frmMain.spHistBugFHint=Feature frmMain.spHistFilterBFHint=Filter By Current B/F frmMain.spHistHist=H frmMain.spHistHistHint=History frmMain.spHistOffen=O frmMain.spHistOffenHint=Open frmMain.spHistAktiv=A frmMain.spHistAktivHint=Active frmMain.spHistFertigHint=Ready frmMain.spHistNicht=N frmMain.spHistNichtHint=not edit frmMain.spHistSpaeter=L frmMain.spHistSpaeterHint=later frmMain.qBAdrVPEMenge=Packaging Unit frmMain.qBestellProjekt_ID=Project frmMain.qProjektBauteil_ID=Component frmMain.qHist1Status=Status frmMain.qHist1FStatus=B/F frmMain.qHist1SNr=Serial number frmMain.qHist1GNr=Device No. frmMain.qHist1FDatum=Date Ready frmMain.qHist1FVersion=Version Ready frmMain.qHistStatus=Status frmMain.qHistFStatus=B/F frmMain.qHistSNr=Serial number frmMain.qHistGNr=Device No. frmMain.qHistFDatum=Date Ready frmMain.qHistFVersion=Version Ready frmMain.spHist1FilterDatumFHint=Filter By Date Ready frmMain.spHist1FilterVersionFHint=Filter By Version Ready frmMain.mnHPrintEinzel=Print Current Record frmMain.btnCalcURIP=U R I P frmKonfig.lbDirVorlage=Template frmKonfig.lbDirTemp=Temp frmCalcURIP=U R I P frmCalcURIP.lbU=&U frmCalcURIP.lbV=V frmCalcURIP.lbCaption=Calculate U R I P frmCalcURIP.lbOhm=Ω frmCalcURIP.lbR=&R frmCalcURIP.lbI=&I frmCalcURIP.lbA=A frmCalcURIP.lbW=W frmCalcURIP.lbP=&P Strings.62=Do you really want to archive all visible items? frmMain.spBEtikettHint=Print Label frmMain.spBestellFilterDatumHint=Filter by Status Date frmMain.dbBestArchiv=Archive frmMain.spKEtikettHint=Print Label frmMain.qBestellSDatum=SDatum frmMain.qBestellArchiv=Archive frmMain.mnOArchivSicht=Archive Visible Strings.63=Yes|Yes-x|No|"Not Relevant" Strings.64=Yes|No Strings.65=Yes|No Strings.66=Yes|No Strings.67=New|"2. Select"|Used|Useless|Defect|"Not available"|Obsolete Strings.68=Cancel Strings.69=Do you really want to cancel entry? frmMain.spBLBarFormatHint=Barcode frmMain.spBestSpaeter=L frmMain.spBestSpaeterHint=later frmMain.lbTypBarFormat=&Barcode Format frmMain.qTypBarFormat=BarFormat frmMain.qProjektOptA=Opt. A frmMain.qProjektOptB=Opt. A frmMain.qProjektOptC=Opt. C frmMain.qProjektAdr_ID=Address frmMain.qHist1Adr_ID=Address frmMain.qHistAdr_ID=Address frmMain.mnLGBarcGen=Create Barcode frmMain.mnLGBarcTest=Check Barcode frmKonfig.lbBarFormat=Barcode Format frmMain.tabBBestell=Orders frmMain.lbBBestellCaseLag=Store/&Case frmMain.spGotoLager1Hint=Go To Store/Case frmMain.lbBBestBez=D&escription frmMain.spGotoBestellHint=Go To Order frmMain.qBBestellBezeichnung=Description frmMain.qBBestellMenge=Quantity frmMain.qBBestellStatus=Status frmMain.qBBestellSDatum=SDatum frmMain.qBBestellArchiv=Archive frmMain.qBBestellBemerkung=Note frmMain.qBBestellBauteil_ID=Component frmMain.qBBestellLief1_Adr_ID=Deliv1 Addr frmMain.qBBestellLief1_BestellNr=Deliv1 OrderNo frmMain.qBBestellLief1_EPreis=Deliv1 Price frmMain.qBBestellLief1_GPreis=Deliv1 Total frmMain.qBBestellLief2_Adr_ID=Deliv2 Addr frmMain.qBBestellLief2_BestellNr=Deliv2 OrderNo. frmMain.qBBestellLief2_EPreis=Deliv2 Price frmMain.qBBestellLief2_GPreis=Deliv2 Total frmMain.qBBestellProjekt_ID=Project frmMain.qBBestellAendDatum=Change Date Strings.70=Sum components: Strings.71=Sum store/case: Strings.72=Quantity Components: Strings.73=Sum (quantity*price): Strings.74=Unit Price Update Strings.75=Do you really want to update all prices from components-table? frmMain.spHist1Testen=T frmMain.spHist1TestenHint=test frmMain.lbBestSumGeliefert=Cost "Delivered" frmMain.spBestellFilterProjektHint=Filter By Project frmMain.spCExpHint=Import/Export frmMain.lbCaseHerstellerBez=S&uplier Descr. frmMain.Panel57=Import/Export Case frmMain.spMailHint=Send E-Mail frmMain.spHistTesten=T frmMain.spHistTestenHint=test frmMain.grpInfoStatistik=Statistics frmMain.tabExtraMP3=MP3 frmMain.grpFile=File frmMain.GroupBox3=MPEG frmMain.spMNewHint=New Entry frmMain.spMCopyHint=Copy Data frmMain.spMSaveHint=Save Data frmMain.spMAbortHint=Cancel Changes frmMain.spMDeleteHint=Delete Data frmMain.lbDatum14=Date: frmMain.spMPrintHint=Print frmMain.spMExpHint=Import/Export frmMain.qTypBEPreis=Purchase Price frmMain.qTypBHaltbar=Preserved frmMain.qTypBBWare=BWare frmMain.qTypBRoHS=RoHS frmMain.qTypBKennz=Flag frmMain.qTypBGewicht=Weight frmMain.qTypBBarcode=Barcode frmMain.qTypBSMD=SMD frmMain.mnPPEPreis=Refresh Purchase Price frmMain.mnTblAll=All frmMain.qMP3Foto_ID=Photo ID frmMain.qMP3FileSize=File Size frmMain.qMP3IDV2Artist=IDV2Artist frmMain.qMP3IDV2Album=IDV2Album frmMain.qMP3IDV2Titel=IDV2Title frmMain.qMP3IDV2Year=IDV2Year frmMain.qMP3IDV2Genre=IDV2Genre frmMain.qMP3IDV2Track=IDV2Track frmMain.qMP3IDV2Comment=IDV2Comment frmMain.qMP3IDV2Encoder=IDV2Encoder frmMain.qMP3IDV2Copyright=IDV2Copyright frmMain.qMP3IDV2Language=IDV2Language frmMain.qMP3IDV2Link=IDV2Link frmMain.qMP3Rating=Rating frmMain.qMP3AendDatum=Change Date frmMain.mnMP3ReadVerz=Read Directory frmMain.mnMP3IDTagSave=Save ID Tag Into MP3 File frmMain.mnCaseImpExport=Import/Export Case frmMain.oDlgDB=Select Database File frmDruckEtikett.lbAnzahl=Count frmDruckEtikett.rGrpSort=Sorting frmDruckEtikett.rGrpSortItem0=Horizontal frmDruckEtikett.rGrpSortItem1=Vertical frmDruckEtikett.rGrpSortItem2=Horizontal By No. frmDruckEtikett.rGrpSortItem3=Vertical Number frmDruckEtikett.lbHeightAnzahl=Count frmMain.tabBProjekt=Projects frmMain.lbBProjektCaseLag=Store/&Case frmMain.spGotoLager2Hint=Go To Store/Case frmMain.lbBProjektBez=D&escription frmMain.spGotoProjekt1Hint=Go To Project frmMain.spAdrBankDet=▼ frmMain.lbAdrBank=&Bank frmMain.lbAdrBLZ=B&LZ frmMain.lbAdrSWIFT=SWIFT frmMain.lbAdrIBAN=IBAN frmMain.lbAdrKonto=Account frmMain.qAdrSWIFT=SWIFT frmMain.qAdrIBAN=IBAN frmMain.qSuchEPMenge=From quantity frmMain.qSuchVPEMenge=Packaging Unit frmMain.mnTypCut=Cut Type frmMain.mnTypInsert=Insert Type frmMain.qProjektVariante=Variant frmMain.qBProjektProjekt_ID=Project frmMain.qBProjektBezeichnung=Description frmMain.qBProjektStatus=Status frmMain.qBProjektBemerkung=Note frmMain.qBProjektBauteil_ID=Component frmMain.qBProjektSymbol=Symbol frmMain.qBProjektWert=Value frmMain.qBProjektMenge=Quantity frmMain.qBProjektEPreis=Purchase Price frmMain.qBProjektGPreis=Total Price frmMain.qBProjektVariante=Variant frmMain.qBProjektPosX=Pos X frmMain.qBProjektPosY=Pos Y frmMain.qBProjektTop=Top frmMain.qBProjektSMD=SMD frmMain.qBProjektKennz=Flag frmMain.qBProjektAendDatum=Change Date frmMain.mnBildEinfg=Insert Picture frmMain.mnBildEinfZW=from Clipboard frmMain.mnBildEinfDatei=from File frmMain.mnBildEinfgUebZW=Overwrite From Clipboard frmMain.mnBildEinfgUebDatei=Overwrite From File frmMain.mnBildCopy=Copy To Clipboard frmMain.mnBildDel=Delete Picture frmDruckEtikett.chkGrpFelderItem5=Only One Component Per Label frmMain.lbBLagerSumMenge=Quantity Total: frmKonfig.rgrpLanguageItem3=Polish Supplier Of Electronic Components Strings.76=n. in CSV import frmMain.spFilterProjektHint=Filter By Project frmMain.spFilterPPStatusHint=Filter By Current Status frmMain.lbBestSumAnz=Total Positions frmMain.lbBestTermin1=Appoin&tment frmMain.lbBestTermin2=D&ate Confirmed frmMain.edSchnellsucheCaseExpHint=Quick Search frmMain.spFilterCaseExpHint=Filter By Case frmMain.chkSchnellsucheCaseExpSMD=SMD frmMain.Panel39=Components From Box frmMain.qBestellTermin1=Appointment frmMain.qBestellTermin2=Date Ordered frmMain.mnBInventar=inventory list frmMain.qKisteBLID=LID frmMain.qKisteBBezeichnung=Description frmMain.qKIsteBBeschreibung=Text frmMain.qKisteBLBez=Store Desc. frmMain.qKisteBMenge=Quantity frmMain.qKisteBCBez=Case frmMain.qKisteBLagerNr=Storage No. frmMain.qKisteBBemerkung=Note frmMain.mnPopPrint=Print frmMain.mnPopRefresh=Update frmDruckEtikett.lbAuswFach=Selected compartment frmDruckEtikett.spDruckvHint=Print Prewiew frmBauteil.spPrintHint=Print frmBauteil.qryBID=BID frmBauteil.qryBBez=Comp. Descr. frmBauteil.qryMengeV=Quantity Used frmBauteil.qryMengeMin=Min Quantity frmBauteil.qryEPreis=Purchase Price frmBauteil.qryGPreis=Total Price frmBauteil.qryVPreis=Sale Price frmBauteil.qryHaltbar=Preserved frmBauteil.qryKiste_ID=Box frmBauteil.qryLagernr=Storage No. frmBauteil.qrySMD=SMD frmBauteil.qrySMD_Text=SMD_Text frmBauteil.qryBWare=BWare frmBauteil.qryRoHS=RoHS frmBauteil.qryBemerkung=Note frmBauteil.qryHandbuch=Manual frmBauteil.qryAdr_ID=Manufacturer frmBauteil.qryLibrary=Library frmBauteil.qryKennz=Flag frmBauteil.qryGewicht=Weight frmBauteil.qryBarcode=Barcode frmBauteil.qryAendDatum=Change Date frmMain.qSuchHStatus=Status frmMain.qSuchHFStatus=B/F frmMain.qSuchHSNr=Serial number frmMain.qSuchHGNr=Device No. frmMain.qSuchHFDatum=Date Ready frmMain.qSuchHFVersion=Version Ready frmMain.qSuchHAdr_ID=Address frmMain.btnInfoVersion=Check Version frmVersion=EleLa Downloads frmVersion.btnClose=Cancel frmSchnell.qMem_ID=ID frmSchnell.qMem_Symbol=Symbol frmSchnell.qMem_Bauteil=Component frmSchnell.qMem_Gehäuse=Gehäuse frmVersion.memVersion_Bezeichnung=Bezeichnung frmVersion.memVersion_Version=Version frmVersion.memVersion_Link=Link frmVersion.memVersion_Status=Status Strings.77=There are items without an order number or quantity available.\r\nDo you want to cancel ordering process? Strings.78=There are items without an order number or quantity available. frmMain.lbPPosSumM=Sum frmMain.panAdrBauteile=Components From Supplier frmMain.qBBestellTermin1=Appointment 1 frmMain.qBBestellTermin2=Appointment 2 frmMain.qKisteBEPreis=Purchase Price frmMain.qKisteBGPreis=Total Price frmMain.qAdrBLID=LID frmMain.qAdrBBezeichnung=Description frmMain.qAdrBBeschreibung=Text frmMain.qAdrBLBez=Store Desc. frmMain.qAdrBEPreis=Purchase Price frmMain.qAdrBCBez=Comp. Desc. frmMain.qAdrBBemerkung=Note frmVersion.btnOnline=WWW frmVersion.memVersion_MD5=MD5 Strings.79=Yes|No Strings.80=Yes|No Strings.81=Yes|No frmMain.spProjTerminHint=Select Date frmMain.spHist1FDatumHint=Select Date frmMain.spBestTerm1Hint=Select Date frmMain.spBestTerm2Hint=Select Date frmMain.spTelMobHint=Dial Phone No. frmMain.lbAdrMail2=E-Mail 2 frmMain.spMail2Hint=Send E-Mail frmMain.lbAdrTel2=Telephone &2 frmMain.chkAdrLief=Supplier frmMain.chkAdrHerst=Manufacturer frmMain.chkAdrPrivat=Private frmMain.chkAdrGesperrt=Blocked frmMain.tabAdrUeb=Overview frmMain.tabAdrKontakt=Contact frmMain.lbAdrKBez=Description frmMain.lbAdrKStr=Street frmMain.lbAdrKPlz=PostCode/Loc. frmMain.lbAdrKName=Name frmMain.lbAdrKTel=Phone frmMain.lbAdrKMobil=Mobile Phone frmMain.lbAdrKFax=Fax frmMain.lbAdrKINet=WWW frmMain.lbAdrKMail=E-Mail frmMain.lbAdrKKundNr=Customer No. frmMain.spInternetKHint=Open Web Browser frmMain.lbAdrKLand=Country frmMain.spTelK1Hint=Dial Phone No. frmMain.spTelKMobHint=Dial Phone No. frmMain.lbAdrKGebDatum=Birthday frmMain.spGeburtstagKHint=Select Date frmMain.spMailKHint=Send E-Mail frmMain.lbAdrKMail2=E-Mail 2 frmMain.spMailK2Hint=Send E-Mail frmMain.lbAdrKTel2=Phone 2 frmMain.spTelK2Hint=Dial Phone No. frmMain.chkAdrKPrivat=Private frmMain.chkAdrKGesperrt=Blocked frmMain.spAKNewHint=New entry frmMain.spAKCopyHint=Copy Data frmMain.spAKSaveHint=Save Data frmMain.spAKAbortHint=Cancel Changes frmMain.spAKDeleteHint=Delete Data frmMain.lbDatum15=Date: frmMain.spAKPrintHint=Print frmMain.spHistFDatumHint=Select Date frmMain.lbWissenInfo=&Info frmMain.lbProjektHistStatus1=Status frmMain.spWissenStat0=0 frmMain.spWissenStat0Hint=0 frmMain.spWissenStat1=1 frmMain.spWissenStat1Hint=1 frmMain.spWissenStat2=2 frmMain.spWissenStat2Hint=2 frmMain.spWissenStat3=3 frmMain.spWissenStat3Hint=3 frmMain.spWissenStat4=4 frmMain.spWissenStat4Hint=4 frmMain.spWissenStat5=5 frmMain.spWissenStat5Hint=5 frmMain.spWissenStat6=6 frmMain.spWissenStat6Hint=6 frmMain.spWissenFilterSHint=Filter By Current Status frmMain.tabExtraTermin=Appointment frmMain.lbTerminSuch=&Search frmMain.spTerminPrintHint=Print frmMain.chkTerminProjekt=&Project frmMain.chkTerminBestellung=&Order frmMain.chkTerminAdresse=&Address frmMain.qAdrTelefon2=Phone 2 frmMain.qAdrEMail2=EMail2 frmMain.qAdrLieferant=Supplier frmMain.qAdrHersteller=Manufacturer frmMain.qAdrPrivat=Private frmMain.qAdrGesperrt=Blocked frmMain.qGehauseFoto_ID=Photo ID frmMain.qGehauseBezeichnung=Description frmMain.qGehauseTyp=Type frmMain.qGehauseNormbez=Stamndard Name frmMain.qGehauseHerstellerbez=Manufacturer Description frmMain.qGehauseLibrary=Library frmMain.qGehausePins=Pins frmMain.qGehauseRaster=Raster frmMain.qGehauseSMD=SMD frmMain.qGehauseBemerkung=Note frmMain.qGehauseAendDatum=Change Date frmMain.qKisteBemerkung=Note frmMain.qTypBemerkung=Note frmMain.qBauteilInfo=Info frmMain.qBAdrFoto_ID=Photo ID frmMain.qSuchBBeschr=Comp. Descr. frmMain.qBestellFoto_ID=Photo ID frmMain.qGehauseBLID=LID frmMain.qGehauseBBezeichnung=Description frmMain.qGehauseBBeschreibung=Text frmMain.qGehauseBLBez=Store Desc. frmMain.qGehauseBMenge=Quantity frmMain.qGehauseBEPreis=Purchase Price frmMain.qGehauseBGPreis=Total Price frmMain.qGehauseBBemerkung=Note frmMain.qPPosFoto_ID=Photo ID frmMain.qPPosGehause=Case frmMain.qPPosBarcode=Barcode frmMain.qPPosInfo=Info frmMain.qWissenStatus=Status frmMain.qWissenOptA=Opt. A frmMain.qWissenOptB=Opt. B frmMain.qWissenOptC=Opt. C frmMain.qWissenInfo=Info frmMain.mnAdrNPDruck=Print Public Phone No. List frmMain.mnAdrPDruck=Print Private Phone No. List frmMain.qBBestellFoto_ID=Photo ID frmMain.qGehauseExpFoto_ID=Photo ID frmMain.qGehauseExpBezeichnung=Description frmMain.qGehauseExpTyp=Type frmMain.qGehauseExpNormbez=Standard Name frmMain.qGehauseExpHerstellerbez=Manufacturer Description frmMain.qGehauseExpLibrary=Library frmMain.qGehauseExpPins=Pin frmMain.qGehauseExpRaster=Raster frmMain.qGehauseExpSMD=SMD frmMain.qGehauseExpBemerkung=Note frmMain.qGehauseExpAendDatum=Change Date frmMain.qBProjektFoto_ID=Photo ID frmMain.qBProjektGehause=Case frmMain.qBProjektBarcode=Barcode frmMain.qBProjektInfo=Info frmMain.qTerminTyp=Type frmMain.qTerminBereich=Range frmMain.qTerminBezeichnung=Description frmMain.qTerminTermin1=Appointment 1 frmMain.qTerminTermin2=Appointment 2 frmMain.qAdrKfoto_ID=Photo ID frmMain.qAdrKBezeichnung=Description frmMain.qAdrKFirma=Company frmMain.qAdrKName=Name frmMain.qAdrKStrasse=Street frmMain.qAdrKPLZ=Postal Code frmMain.qAdrKOrt=Location frmMain.qAdrKTelefon=Phone frmMain.qAdrKTelefon2=Phone2 frmMain.qAdrKMobil=Mobile Phone frmMain.qAdrKFax=Fax frmMain.qAdrKEMail=EMail frmMain.qAdrKEMail2=EMail2 frmMain.qAdrKInternet=Internet frmMain.qAdrKUsSTID=VAT ID frmMain.qAdrKKundNr=Customer ID frmMain.qAdrKLogin=Login frmMain.qAdrKPasswort=Password frmMain.qAdrKBemerkung=Note frmMain.qAdrKLand=Country frmMain.qAdrKGebDatum=Birthday frmMain.qAdrKLieferant=Supplier frmMain.qAdrKHersteller=Manufacturer frmMain.qAdrKPrivat=Private frmMain.qAdrKGesperrt=Blocked frmMain.qAdrKBank=Bank frmMain.qAdrKBLZ=BLZ frmMain.qAdrKKonto=Account frmMain.qAdrKSWIFT=SWIFT frmMain.qAdrKIBAN=IBAN frmMain.qAdrKAendDatum=Change Date frmAuswahl.qryFFoto_ID=Photo ID frmAuswahl.qryFBezeichnung=Description frmAuswahl.qryFFirma=Company frmAuswahl.qryFName=Name frmKonfig.btnErzeugeDB=Create New Database frmBauteil.qryGehause_ID=Case frmMain.=test frmMain.lbBauteilInfo=Info frmMain.spHandbuch8ExecHint=Open Manual frmMain.spHandbuch8Hint=Select Manual (File) frmMain.lbPPosHandbuch=Ma&nual frmMain.spHandbuch9ExecHint=Open Manual frmMain.spHandbuch9Hint=Select Manual (File) frmMain.lbBestellHandbuch=&Manual frmMain.lbBestellInfo=I&nfo frmMain.lbCaseLibrary=&Footprints frmMain.lbCaseNormbez=&Norm Descr. frmMain.lbCaseHandbuch=&Manual frmMain.spHandbuch6ExecHint=Open Manual frmMain.spHandbuch6Hint=Select Manual (File) frmMain.spHandbuch7ExecHint=Open Manual frmMain.spHandbuch7Hint=Select Manual (File) frmMain.lbKisteHandbuch=&Manual frmMain.spHandbuch10ExecHint=Open Manual frmMain.spHandbuch10Hint=Select Manual (File) frmMain.lbAdrHandbuch=Ma&nual frmMain.spHandbuch11ExecHint=Open Manual frmMain.spHandbuch11Hint=Select Manual (File) frmMain.lbAdrKHandbuch=Manual frmMain.qAdrHandbuch=Manual frmMain.qAdrInfo=Info frmMain.qGehauseHandbuch=Manual frmMain.qGehauseInfo=Info frmMain.qKisteHandbuch=Manual frmMain.qSuchBInfo=CInfo frmMain.qFotoBildDatei=Picture File frmMain.qBestellHandbuch=Manual frmMain.qBestellInfo=Info frmMain.qPPosHandbuch=Manual frmMain.qBBestellHandbuch=Manual frmMain.qBBestellInfo=Info frmMain.qGehauseExpHandbuch=Manual frmMain.qGehauseExpInfo=Info frmMain.qBProjektHandbuch=Manual frmMain.qAdrKHandbuch=Manual frmMain.qAdrKInfo=Info Strings.82=Contact Form: Strings.83=Start / end code for data not found! Strings.84=Component|"Working Time"|"Small Material" Strings.85=Select the type of component ! frmMain.spHaltbarBisHint=Select Date frmMain.spProjektDet=▼ frmMain.lbProjektWartungNext=Next servicing frmMain.spProjWartungHint=Select Date frmMain.lbProjektWartungInv=Interval frmMain.spProjIntervallHint=Store booking frmMain.lbProjektAdr=Address frmMain.spGotoAdrPHint=Go To Address frmMain.lbPPosPosR=Rotation frmMain.lbPPosSNr=Serial number frmMain.lbProjektHistPPos=Position frmMain.spHist1Det=▼ frmMain.spH1GotoPPosHint=Go To Project Pos frmMain.lbProjektHistFehlerreport=Error Report C&ustomer frmMain.lbProjektHistRepReport=Repair Report frmMain.lbProjektHistRMA=RMA frmMain.spGetRMACodeHint=Generate RMA Code frmMain.spGetErrorCodeHint=Generate RMA Code frmMain.lbProjektHistFehlercode=Error Code frmMain.lbProjektHistVorgehen=Proceedin&g frmMain.lbProjektHistKostenv=Quotation frmMain.spH1GotoKostHint=Go To Quotation frmMain.tabPKost=Quotation frmMain.tabPKUeb=Overview frmMain.lbPKostAdrKont=&Address/Contact frmMain.lbPKostBez=D&escription frmMain.lbPKostLief=Supp&lier frmMain.lbPKostAngebot=&Offer frmMain.spGotoAdrPKHint=Go To Address frmMain.lbPKostStatus=Status frmMain.spPKSAngebot=A frmMain.spPKSAngebotHint=Offer frmMain.spPKSAngebotG=OS frmMain.spPKSAngebotGHint=Offer Sent frmMain.spPKSBestellt=B frmMain.spPKSBestelltHint=Ordered frmMain.spPKSFertigHint=Ready frmMain.spPKSGeliefert=D frmMain.spPKSGeliefertHint=Delivered frmMain.spPKSStorno=L frmMain.spPKSStornoHint=Canceled frmMain.spPKFilterHint=Filter By Current Status frmMain.lbPKostAuftrag=O&rder No. frmMain.spPKAngebotHint=Select Date frmMain.lbPKostGueltig=&Valid Until frmMain.spPKGueltigHint=Select Date frmMain.spPKLiefHint=Select Date frmMain.lbPKostAbnahme=Dec&rease frmMain.spPKAbnahmeHint=Select Date frmMain.lbPKostBestNr=&Order Code frmMain.lbPKostGPreis=Total Price frmMain.lbPKostInfo=&Info frmMain.spGetKVCodeHint=Generate RMA Code frmMain.spPKNewHint=New Entry frmMain.spPKCopyHint=Copy Data frmMain.spPKSaveHint=Save Data frmMain.spPKAbortHint=Cancel Changes frmMain.spPKDeleteHint=Delete Data frmMain.lbDatum17=Date: frmMain.spPKPrintHint=Print frmMain.spPKExpHint=Import/Export frmMain.tabPKPos=Position frmMain.lbPKostPBez=D&escription frmMain.lbPKostPLieferung=Supp&lier frmMain.lbPKostPStatus=Status frmMain.spPKPOffen=O frmMain.spPKPOffenHint=Open frmMain.spPKPAktiv=A frmMain.spPKPAktivHint=Active frmMain.spPKPTest=T frmMain.spPKPTestHint=test frmMain.spPKPFertigHint=Ready frmMain.spPKPNichtB=N frmMain.spPKPNichtBHint=Do Not Change frmMain.spPKPStorno=L frmMain.spPKPStornoHint=Canceled frmMain.spPKPFilterHint=Filter By Current Status frmMain.lbPKostPTermin=Ap&pointment frmMain.spPKPTerminHint=Select Date frmMain.spPKPLiefHint=Select Date frmMain.lbPKostPArtikelNr=&Item No. frmMain.lbPKostPVPreis=Sale Price frmMain.lbPKostPMenge=Qua&ntity frmMain.lbPKostPBauteil=&Component frmMain.lbPKostPLagCase=&Store/Case frmMain.spGotoBauteilLG3Hint=Go To Store/Case frmMain.spGotoBauteil3Hint=Go To Component frmMain.spPKPBauteilHint=Select Component frmMain.lbPKostPVSum=Total Position frmMain.lbPKostPPPos=&Position frmMain.spPKPVPreisHint=Update Price Of Component frmMain.lbPKostPInfo=In&fo frmMain.spPKPGotoProjPosHint=Go To Project Pos frmMain.spPKPNewHint=New Entry frmMain.spPKPCopyHint=Copy Data frmMain.spPKPSaveHint=Save Data frmMain.spPKPAbortHint=Cancel Changes frmMain.spPKPDeleteHint=Delete Data frmMain.lbDatum18=Date: frmMain.spPKPPrintHint=Print frmMain.spPKPExpHint=Import/Export frmMain.tabPBestell=Orders frmMain.lbPBestellBauteil=&Component frmMain.spGotoLager3Hint=Go To Store/Case frmMain.lbPBestBez=D&escription frmMain.spGotoBestell1Hint=Go To Order frmMain.chkPBestellArchiv=With archived frmMain.spBestTeil=T frmMain.spBestTeilHint=Partial Delivery frmMain.lbBestAuftrag=O&rder No. frmMain.spBestellFilterAuftragHint=Filter By Current Order frmMain.spBestAuftragFctHint=Order Functions frmMain.spBestellCalcHint=Calculator Quantity frmMain.spBestellResetStaffelHint=Update Price From Supplier frmMain.lbBestSumMenge=Total Quantity frmMain.lbBestSumMengeVPE=Count Quantity Each frmMain.btnBestellLiefBuch=Book as delivered frmMain.lbBestMengeLief=Q&uantity Store (Unit) frmMain.lbBestMengeLiefSum=Total Quantity Delivered (Unit) frmMain.spBestellDet=▲ frmMain.lbBestMengeLagSum=Total Quantity Stored (Unit) frmMain.lbBestL1EP1=Quantity (Unit) frmMain.chkBestellLief1=Supplier 1 frmMain.spGotoBauteilA1Hint=Go To Component / Supplier frmMain.spBestellFilterLief1Hint=Filter By Supplier frmMain.spBestellLief1SetStaffelHint=Copy Order nr/Price Into Component -> Supplier frmMain.chkBestellLief2=Supplier 2 frmMain.spBestellLief2SetStaffelHint=Copy Order nr/Price Into Component -> Supplier frmMain.spBestellFilterLief2Hint=Filter By Suppliers frmMain.spGotoBauteilA2Hint=Go To Component / Supplier frmMain.chkAdrProjekt=Project/History frmMain.qAdrProjekt=Project frmMain.qBestellAuftrag=Order frmMain.qBestellUseLief12=Supplier frmMain.qBestellLief_MengeVPE=Deliv. Quantity Unit frmMain.qBestellLief_MengeVPESum=Deliv. Quantity Unit Tot frmMain.qBestellLager_MengeVPESum=Storage Unit Total Quantity frmMain.qBestellLief1_BauteilAdr_ID=Deliv1 Supplier frmMain.qBestellLief1_MengeVPE=Deliv1 Quantity Unit frmMain.qBestellLief2_BauteilAdr_ID=Deliv2 Supplier frmMain.qBestellLief2_MengeVPE=Deliv2 Quantity Unit frmMain.mnBBarcodeTest=Find Double Barcode frmMain.qProjektWartung=Service frmMain.qProjektSNr=Serial No. frmMain.qProjektVPreis=Sale Price frmMain.qProjektArtikelNr=Store item No. frmMain.qPPosArtikelNr=Item No. frmMain.qPPosArt=Category frmMain.qPPosPosZ=Pos Z frmMain.qPPosPosR=Pos R frmMain.qPPosGBez=StoreCase frmMain.qPPosSNr=Serial No. frmMain.qHist1ProjektPos_ID=ProjectPos frmMain.qHist1Kosten_ID=Quotation frmMain.qHist1Vorgehen=Proceeding frmMain.qHist1KundeBes=Error Report Customer frmMain.qHist1RepNr=RMA frmMain.qHist1RepFehler=Error Code frmMain.qHist1RepBes=Repair Report frmMain.qHistProjektPos_ID=ProjectPos frmMain.qHistKosten_ID=Quotation frmMain.qHistVorgehen=Proceeding frmMain.qHistKundeBes=Error Report Customer frmMain.qHistRepNr=RMA frmMain.qHistRepFehler=Error Code frmMain.qHistRepBes=Repair Report frmMain.qBBestellAuftrag=Order No. frmMain.qBBestellUseLief12=Supplier frmMain.qBBestellLief_MengeVPE=Deliv. Quantity Unit frmMain.qBBestellLief_MengeVPESum=Deliv. Quantity Unit Tot frmMain.qBBestellLager_MengeVPESum=Storage Unit total quantity frmMain.qBBestellLief1_BauteilAdr_ID=Deliv1 Supplier frmMain.qBBestellLief1_MengeVPE=Deliv1 Quantity Unit frmMain.qBBestellLief2_BauteilAdr_ID=Deliv2 Supplier frmMain.qBBestellLief2_MengeVPE=Deliv2 Quantity Unit frmMain.qBProjektArtikelNr=Item No. frmMain.qBProjektArt=Category frmMain.qBProjektPosZ=Pos Z frmMain.qBProjektPosR=Pos R frmMain.mnPopBestellen=Order Component frmMain.qAdrKProjekt=Project frmMain.qPBestellFoto_ID=Photo ID frmMain.qPBestellBezeichnung=Description frmMain.qPBestellMenge=Quantity frmMain.qPBestellAuftrag=Order frmMain.qPBestellStatus=Status frmMain.qPBestellSDatum=SDatum frmMain.qPBestellTermin1=Appointment frmMain.qPBestellTermin2=Date Ordered frmMain.qPBestellArchiv=Archive frmMain.qPBestellBemerkung=Note frmMain.qPBestellBauteil_ID=Component frmMain.qPBestellHandbuch=Manual frmMain.qPBestellInfo=Info frmMain.qPBestellUseLief12=Supplier frmMain.qPBestellLief_MengeVPE=Deliv. Quantity Unit frmMain.qPBestellLief_MengeVPESum=Deliv. Quantity Unit Tot frmMain.qPBestellLager_MengeVPESum=Storage Unit total quantity frmMain.qPBestellLief1_Adr_ID=Deliv1 Addr frmMain.qPBestellLief1_BauteilAdr_ID=Deliv1 Supplier frmMain.qPBestellLief1_BestellNr=Deliv1 OrderNo frmMain.qPBestellLief1_MengeVPE=Deliv1 Quantity Unit frmMain.qPBestellLief1_EPreis=Deliv1 Price frmMain.qPBestellLief1_GPreis=Deliv1 Total frmMain.qPBestellLief2_Adr_ID=Deliv2 Addr frmMain.qPBestellLief2_BauteilAdr_ID=Deliv2 Supplier frmMain.qPBestellLief2_BestellNr=Deliv2 OrderNo. frmMain.qPBestellLief2_MengeVPE=Deliv2 Quantity Unit frmMain.qPBestellLief2_EPreis=Deliv2 Price frmMain.qPBestellLief2_GPreis=Deliv2 Total frmMain.qPBestellProjekt_ID=Project frmMain.qPBestellAendDatum=Change Date frmMain.mnOAuftGlob=Global Changes Order frmMain.mnOAuftAutoNum=Next order number frmMain.mnBTypAend=Alter Type frmMain.qPKostProjekt_ID=Project frmMain.qPKostAdr_ID=Address frmMain.qPKostAdrK_ID=Contact frmMain.qPKostFoto_ID=Photo ID frmMain.qPKostBezeichnung=Description frmMain.qPKostBeschreibung=Text frmMain.qPKostStatus=Status frmMain.qPKostGPreis=Total Price frmMain.qPKostAuftrag=Order No. frmMain.qPKostBestellnr=Order Code frmMain.qPKostDAngebot=Offer frmMain.qPKostDGueltig=Valid Until frmMain.qPKostDLief=Supply frmMain.qPKostDAbnahme=Decrease frmMain.qPKostInfo=Info frmMain.qPKostAendDatum=Change Date frmMain.qPKostPosProjekt_ID=Project ID frmMain.qPKostPosKosten_ID=Cost ID frmMain.qPKostPosProjektPos_ID=ProjectPos frmMain.qPKostPosBauteil_ID=Component frmMain.qPKostPosFoto_ID=Photo ID frmMain.qPKostPosNr=No. frmMain.qPKostPosBezeichnung=Description frmMain.qPKostPosBeschreibung=Text frmMain.qPKostPosStatus=Status frmMain.qPKostPosMenge=Quantity frmMain.qPKostPosVPreis=Sale Price frmMain.qPKostPosVPSum=VPSum frmMain.qPKostPosBarcode=Barcode frmMain.qPKostPosArtikelNr=Item No. frmMain.qPKostPosTermin=Appointment frmMain.qPKostPosDLief=DDeliver frmMain.qPKostPosInfo=Info frmMain.qPKostPosArt=Category frmMain.qPKostPosAendDatum=Change Date frmMain.mnHistRMA=Next RMA number frmMain.mnKVAuftrag=Next order number frmPPosTest.lbAuftNr=Order No. For Delivery frmStatus.rGrpItem5=later frmStatus.chkAuftrag=Change Order frmStatus.chkArchiv=Archive frmStatus.chkAendArchiv=Archive frmExpBestNr.btnErzeuge=v v v v v frmExpBestNr.Lieferant2=&Order No. frmExpBestNr.chkInfo2=With information project / order-No. frmExpBestNr.chkAnfz=Text in "..." frmExpBestNr.chkInfo1=With information from Info line frmExpBestNr.btnCopy=Copy To Clipboard frmAuswahl.qryBArtikelNr=Item No. frmAuswahl.qryFSort=Sort frmKonfig.chkVersionCheck=Automatically Check For New Version of EleLa And Its Components frmKonfig.lbLogInDatei=Log in file frmKonfig.tabGlobal=Global Param frmKonfig.lbBestellFormat=Order Format frmKonfig.lbISO9001=ISO9001 Compliant frmKonfig.lbDateFormat=Date Format frmKonfig.lbHistRMAFormat=History RMA Format frmKonfig.lbKVAuftragFormat=Quotation Order Format frmBauteil.qryArtikelNr=Item No. frmBauteil.qryArt=Category frmBauteil.qryInfo=Info frmBestellAenderung=Order global changes frmBestellAenderung.chkAendStatus=Status frmBestellAenderung.spBestSpaeter=L frmBestellAenderung.spBestSpaeterHint=later frmBestellAenderung.spBestEingelagertHint=stored frmBestellAenderung.spBestGeliefert=D frmBestellAenderung.spBestGeliefertHint=Delivered frmBestellAenderung.spBestTeil=T frmBestellAenderung.spBestTeilHint=Partial Delivery frmBestellAenderung.spBestBestellt=B frmBestellAenderung.spBestBestelltHint=Ordered frmBestellAenderung.spBestOffen=O frmBestellAenderung.spBestOffenHint=Open frmBestellAenderung.chkAendArchiv=Archive frmBestellAenderung.chkArchiv=Archive frmBestellAenderung.chkAendAuftrag=Order-No. frmBestellAenderung.Label1=Make global changes for all visible\r\nitems of the selected order frmBestellAenderung.btnOK=&OK frmBestellAenderung.btnCancel=&Cancel frmBestellAenderung.chkAlleSichtbare=Alter All Visible Positions,\r\nNot Only From The Selected Order frmBestellDruck=Print order frmBestellDruck.btnOK=&OK frmBestellDruck.btnCancel=&Cancel frmBestellDruck.lbFormular=Form: frmBestellDruck.Lieferant=Supplier frmBestellDruck.Lieferant2=&Order No. frmBestellDruck.chkSetTermin=Set an appointment frmBestellDruck.chkSetStatusB=Set status to "ordered" Strings.86="Single Error"|"Customer Error"|"Build Error"|"Soldering Defects"|"Software Update"|"Firmware Update"|"Update Document" Strings.87=Warranty|Goodwill|Paid Strings.88=For new contact write "EleLa" in the message an I accept the new conversation. Strings.89=File Not Found: Strings.90=Paper is too small. Label cannot be printed. frmMain.spPPosDet=▲ frmMain.lbProjektHistAbrechnung=Invoice frmMain.lbHist1AdrKont=Addre&ss/Contact frmMain.spGotoAdrH1Hint=Go To Address frmMain.lbProjektHistPPos1=Position frmMain.spHGotoPPosHint=Go To Project Pos frmMain.spHistDet=▼ frmMain.lbHistExFehlerreport=Error Report C&ustomer frmMain.lbHistExtRepReport=Repair Report frmMain.lbHistExRMA=R&MA frmMain.spGetRMACode1Hint=Generate RMA Code frmMain.spGetErrorCode1Hint=Generate RMA Code frmMain.lbHistExFehlercode=Error Code frmMain.lbHistExVorgehen=Proceeding frmMain.lbHistExKostenv=&Quotation frmMain.spHGotoKostHint=Go To Quotation frmMain.lbHistExAbrechnung=&Invoice frmMain.lbHistAdrKont=&Address/Contact frmMain.spGotoAdrHHint=Go To Address frmMain.qFotoPosX0=PosX0 frmMain.qFotoPosY0=PosY0 frmMain.qFotoPosXFak=PosXFak frmMain.qFotoPosYFak=PosYFak frmMain.qFotoPosTop=PosTop frmMain.qHist1Abrechnung=Invoice frmMain.qHist1AdrK_ID=Contact frmMain.qHistAbrechnung=Invoice frmMain.qHistAdrK_ID=Contact frmMain.qPKostPosLArtikelNr=Store item No. frmMain.qPKostPosLBarcode=Store Barcode frmMain.qPKostPosLArt=Store Art frmMain.mnPKPVPreis=Refresh Sale Price frmMain.mnPKPNr=Number Teassigned frmMain.mnPIntvEinstell=Select interval frmMain.mnPIntvWart=Service done frmBild.lbTop=Layer: frmBild.lbX=X Pos: frmBild.lbMas1=Measure frmBild.lbXFak=Measure/Pixel: frmBild.lbY=Y Pos: frmBild.lbMas2=Measure frmBild.lbYFak=Measure/Pixel: frmBild.btnSave=Save frmBild.mnCopyClp=Copy Picture To Clipboard frmBild.mnPos=Scale Picture frmIntervall=Interval frmIntervall.btnOK=&OK frmIntervall.btnAbbruch=&Cancel frmIntervall.rbTag=Days frmIntervall.rbWoche=Weeks frmIntervall.rbMonat=Month frmIntervall.rbJahr=Year frmMain.lbBLiefStueck=Mult&iple frmMain.lbProjektArtikelNr=Item No. frmMain.lbProjektArtikelNr2=Item No. 2 frmMain.lbProjektAuftrag=Order-No. frmMain.spProjAuftragFctHint=Order Functions frmMain.lbProjektHistGPreis1=Total Price frmMain.spFilterAdrChkHint=Filter By Checkbox frmMain.lbProjektHistGPreis=Total Price frmMain.qBAdrDivMenge=Multiple frmMain.qBAdrArtikelNr=Store item No. frmMain.qBAdrArtikelNr2=Store item No. 2 frmMain.qBestellArtikelNr=Store item No. frmMain.qBestellArtikelNr2=Store item No. 2 frmMain.qProjektAuftrag=Order frmMain.qProjektArtikelNr2=Store item No. 2 frmMain.qPPosLMenge=Store quantity frmMain.qPPosDruck=Print frmMain.qHist1GPreis=Total Price frmMain.qHistGPreis=Total Price frmMain.mnDruckAlle=All Print frmMain.mnDruckKein=All Do Not Print frmMain.qPKostPosLArtikelNr2=Store item No. 2 frmMain.mnProjAuftrag=Next order number frmMain.mnCpBestell=Order Again frmStatus.chkAuftragF=Filter By Current Order frmIntervall.btnDelete=&Delete frmMemoEdit=Memo-Edit frmMemoEdit.btnOK=OK frmMemoEdit.btnCancel=Cancel frmMain.spBLLEDHint=Send Box to COM Port frmMain.lbCaseInfo=&Info Strings.91=Reason For Store Movement Strings.92=Enter the reason for the Store movement: frmMain.tabBBeweg=Storage Movement frmMain.lbBBewegCaseLag=Store/&Case frmMain.spGotoProjekt2Hint=Go to project frmMain.spGotoLager4Hint=Go To Store/Case frmMain.spGotoBestell2Hint=Go To Order frmMain.qBBewBauteil_ID=Component frmMain.qBBewUserName=UserName frmMain.qBBewComputerName=Computer Name frmMain.qBBewGrund=Reason frmMain.qBBewPMMenge=P/M Quantity frmMain.qBBewMenge=Quantity frmMain.qBBewDatum=Date frmMain.qBBewBestellen_ID=Order frmMain.qBBewProjekt_ID=Project ID frmMain.qBBewProjektPos_ID=Project frmMain.qBBewAendDatum=Change Date frmMain.mnBLagbew=Last store movement frmBauteil.qryLBewBBez=Component frmBauteil.qryLBewVBez=Case/Variant frmBauteil.qryLBewGBez=Case frmBauteil.qryLBewKBez=Box frmBauteil.qryLBewLagerNr=Storage No. frmBauteil.qryLBewBestellen_ID=Order It frmBauteil.qryLBewProjekt_ID=Project ID frmBauteil.qryLBewUserName=UserName frmBauteil.qryLBewComputerName=Computer Name frmBauteil.qryLBewGrund=Reason frmBauteil.qryLBewPMMenge=P/M Quantity frmBauteil.qryLBewMenge=Quantity frmBauteil.qryLBewDatum=Date frmBauteil.qryLBewAendDatum=Change Date frmBauteil.qryLBewArtikelNr=Item No. frmBauteil.qryLBewArtikelNr2=Item No. 2 frmBauteil.qryLBewBarcode=Barcode frmBauteil.qryLBewBauteil_ID=Component ID frmMain.btnBestellBauteil2Hint=Take part in order proposal frmMain.btnBestellBauteil3Hint=Take part in order proposal frmMain.btnBestellBauteil1Hint=Take part in order proposal frmMain.btnBestellBauteil4Hint=Take part in order proposal frmMain.btnBestellBauteil5Hint=Take part in order proposal frmMain.spFilterWissenThemaHint=Filter By Variant frmMain.spFilterWissenHint=Filter By Component frmMain.edSchnellsucheWissenHint=Quick Search frmBestellMin.btnBestellHint=Take part in order proposal frmPPosTest.btnBestellBauteilHint=Take part in order proposal frmPPosTest.btnBestellBauteilAll=All Missing frmPPosTest.btnBestellBauteilAllHint=All Open Parts In Order To Take The Proposal frmPPosTest.btnBestellBauteilAllPos=All Positions frmPPosTest.btnBestellBauteilAllPosHint=Accept all components in order proposal\r\nwith the required quantity frmMain.spBInfoEtikettHint=Print Label frmMain.spHExp1Hint=Import/Export frmMain.spPKInfoEtikettHint=Print Label frmMain.spPKPInfoEtikettHint=Print Label frmMain.spOInfoEtikettHint=Print Label frmMain.spCInfoEtikettHint=Print Label frmMain.lbKisteInfo=&Info frmMain.spKInfoEtikettHint=Print Label frmMain.lbAdrInfo=Info frmMain.spAInfoEtikettHint=Print Label frmMain.spHExpHint=Import/Export frmMain.spWInfoEtikettHint=Print Label frmMain.qKisteInfo=Info frmMain.qProjektInfo=Info frmMain.mnPPInfoEtikett=Print Label "Info" frmMain.mnPInfoEtikett=Print Label "Info" frmMain.qHist1Info=Info frmMain.qHistInfo=Info frmMain.mnHInfoEtikett=Print Label "Info" frmPPosTest.spBestAuftragFctHint=Next order number frmPPosTest.mnOAuftAutoNum=Next order number frmMain.lbBestSumAll=Cost frmMain.qAdrRabatt=Discount frmMain.qBAdrRabatt=Discount frmMain.qSuchArtikelNr=Item No. frmMain.qSuchArtikelNr2=Item No. 2 frmMain.qPPosRabatt=Discount frmMain.qPKostRabatt=Discount frmMain.qPKostPosRabatt=Discount frmMain.qBestellLief1_Rabatt=Deliv1 Discount frmMain.qBestellLief2_Rabatt=Deliv2 Discount frmMain.spBestelltArchivHint=Archive View frmKisteTausch.qInhaltArtikelNr=Item No. frmKisteTausch.qInhaltArtikelNr2=Item No. 2 frmKisteTausch.qBauteilArtikelNr=Item No. frmKisteTausch.qBauteilArtikelNr2=Item No. 2 Strings.93=Yes|No Strings.94=Yes|No Strings.95=Yes|No frmMain.qBestellLagerMenge=Store quantity frmMain.qBestellKennz=Flag frmMain.qBestellPrio=Priority frmMain.qBestellOptA=Opt. A frmMain.qBestellOptB=Opt. B frmMain.qBestellOptC=Opt. C frmKonfig.lbDirBilder=Pictures Strings.96=Day Strings.97=Days Strings.98=Month Strings.99=Months Strings.100=Create Components Strings.101=Are you sure you want to create the new components? frmMain.panAdrBestellung=Orders frmMain.lbWissenBez1=Note frmMain.mnBGen=Create Components frmMain.qWissenBemerkung=Note frmMain.mnAdrAnsBaut=Show components from supplier/manufactur frmMain.mnAdrAnsBest=Show orders frmMain.mnCpPKostMit=Copy With All Positions frmMain.qAdrB1Foto_ID=Photo ID frmMain.qAdrB1Bezeichnung=Description frmMain.qAdrB1Menge=Quantity frmMain.qAdrB1Auftrag=Order frmMain.qAdrB1Status=Status frmMain.qAdrB1SDatum=SDatum frmMain.qAdrB1Termin1=Appointment 1 frmMain.qAdrB1Termin2=Date Ordered frmMain.qAdrB1Archiv=Archive frmMain.qAdrB1Bemerkung=Note frmMain.qAdrB1Bauteil_ID=Component frmMain.qAdrB1Handbuch=Manual frmMain.qAdrB1Info=Info frmMain.qAdrB1UseLief12=Supplier frmMain.qAdrB1Lief_MengeVPE=Deliv. Quantity Unit frmMain.qAdrB1Lief_MengeVPESum=Deliv. Quantity Unit Tot frmMain.qAdrB1Lager_MengeVPESum=Storage Unit total quantity frmMain.qAdrB1Lief1_Adr_ID=Deliv1 Addr frmMain.qAdrB1Lief1_BauteilAdr_ID=Deliv1 Supplier frmMain.qAdrB1Lief1_BestellNr=Deliv1 OrderNo frmMain.qAdrB1Lief1_MengeVPE=Deliv1 Quantity Unit frmMain.qAdrB1Lief1_EPreis=Deliv1 Price frmMain.qAdrB1Lief1_Rabatt=Deliv1 Discount frmMain.qAdrB1Lief1_GPreis=Deliv1 Total frmMain.qAdrB1Lief2_Adr_ID=Deliv2 Addr frmMain.qAdrB1Lief2_BauteilAdr_ID=Deliv2 Supplier frmMain.qAdrB1Lief2_BestellNr=Deliv2 OrderNo. frmMain.qAdrB1Lief2_MengeVPE=Deliv2 Quantity Unit frmMain.qAdrB1Lief2_EPreis=Deliv2 Price frmMain.qAdrB1Lief2_Rabatt=Deliv2 Discount frmMain.qAdrB1Lief2_GPreis=Deliv2 Total frmMain.qAdrB1Projekt_ID=Project ID frmMain.qAdrB1Kennz=Flag frmMain.qAdrB1Prio=Priority frmMain.qAdrB1OptA=Opt. A frmMain.qAdrB1OptB=Opt. B frmMain.qAdrB1OptC=Opt. C frmMain.qAdrB1AendDatum=Change Date frmBauteilErzeuge=Generate components frmBauteilErzeuge.lbReihe=&Preferred Number frmBauteilErzeuge.lbFaktor=&Factor frmBauteilErzeuge.lbEinheit=&Unit frmBauteilErzeuge.lbPrefix=P&refix frmBauteilErzeuge.lbCase=C&ase frmBauteilErzeuge.lbPrefix1=&Type frmBauteilErzeuge.spBauteilTypHint=Select type frmBauteilErzeuge.btnAnlegen=Create frmBauteilErzeuge.btnCancel=&Close Strings.102=Delete Picture Strings.103=Are you sure you want to delete this picture? frmBauteil.qryArtikelNr2=Item No. 2 frmBauteil.qryInv_Menge=Inv_Quantity frmBauteil.qryInv_Wert=Inv_Value frmBauteil.qryInv_Datum=Inv_Date frmBauteil.qryInv_Name=Inv_Name frmMain.qTypBArtikelNr=Item No. frmMain.qTypBArtikelNr2=Item No. 2 frmMain.mnPopSQLCopy=Copy SQL Command Into Clipboard frmPPosTest.btnAll=All frmPPosTest.btnKein=None frmAuswahl.qryBBarcode=Barcode frmAuswahl.qryBArtikelNr2=Item No. 2 Strings.104=Playlist Strings.105=.mp3.wmv.m4a Strings.106=.avi.mpg frmMain.lbMP3Size=Size frmMain.lbMP3FileName=Name frmMain.spHandbuch12Hint=Select Manual (File) frmMain.rbMP3Musik=Music frmMain.rbMP3Video=Video frmMain.spMP3FilterTypHint=Filter By Type frmMain.grpMP3ID=Title description frmMain.lbMP3Jahr=Year frmMain.lbMP3Titel=Title frmMain.lbMP3Album=Album frmMain.lbMP3Artist=Artist frmMain.lbMP3Track=Track frmMain.lbMP3Genre=Genre frmMain.lbMP3Comment=Note frmMain.spMP3FilterArtistHint=Filter By Artist frmMain.spMP3FilterAlbumHint=Filter By Album frmMain.spMP3FilterGenreHint=Filter By Genre frmMain.lbMP3Comment1=Info frmMain.spMP3InfoEtikettHint=Print Label frmMain.Panel29=Comment / Lyrics frmMain.lbMP3Duration=Timelength frmMain.lbMP3Bitrate=Bitrate frmMain.lbMP3Version=Version frmMain.btnMP3RatingM=- frmMain.btnMP3RatingMHint=Rating Minus frmMain.lbMp3Rating=Rating frmMain.btnMP3RatingP=+ frmMain.btnMP3RatingPHint=Rating Plus frmMain.tbMP3LautHint=Volume frmMain.tbMP3ZeitHint=Time frmMain.spFilterMP3Hint=Filter By Component frmMain.edSchnellsucheMP3Hint=Quick Search frmMain.chkMP3AendInFile=Save Changes Automatically Into MP3 File frmMain.qMP3FileTyp=Type frmMain.qMP3FileVersion=Version frmMain.qMP3FileBitrate=Bitrate frmMain.qMP3FileDuration=Timelength frmMain.qMP3Bemerkung=Note frmMain.qMP3Handbuch=Manual frmMain.qMP3Info=Info frmMain.qMP3Lagernr=Storage No. frmMain.qMP3Kennz=Flag frmMain.qMP3Prio=Prio frmMain.qMP3OptA=Opt. A frmMain.qMP3OptB=Opt. B frmMain.qMP3OptC=Opt. C frmMain.mnMP3GlobAend=Global Changes frmMain.mnMP3ID3TagRead=Read MP3 Tag ID From File frmMain.oDirDlgMP3=Select Directory frmKonfig.lbProxy=Proxy Parameters frmKonfig.lbProxyPort=Port Strings.107=Remainder Strings.108=Yes|No Strings.109=Yes|No Strings.110=Yes|No Strings.111=Do you really want to book all visible positions (ordered/partial delivery/delivered) to the store? Strings.112=Action Strings.113=MP3 ID frmMain.qBauteiltree_typ=Type frmMain.qBAdrAdr=Address frmMain.qBestellBauteil=Component frmMain.qBestellLief1_Adr=Deliv1 Addr frmMain.qBestellLief1_BauteilAdr=Deliv1 Supplier frmMain.qBestellLief2_Adr=Deliv2 Addr frmMain.qBestellLief2_BauteilAdr=Deliv2 Supplier frmMain.qBestellProjekt=Project ID frmMain.mnBestBucheLager=Book visible in store frmMain.qPPosBauteil=Component frmMain.mnAdrInfoEtikett=Print Label "Info" frmMain.mnMP3Integrieren=Integrate New Files frmMain.mnMP3Del=Delete Row And File Strings.114=This function will update all the MP3 files IDV2-tag, which are visible in the table.\r\nDo you really want to perform this function? frmMain.qGehauseGewicht=Weight frmMain.mnHandbOrdner=Open Folder frmBestellMin.qryProjSum=Quantity Project frmKisteTausch.qInhaltMenge=Quantity frmKisteTausch.qBauteilMenge=Quantity frmKonfig.edPortHint=3306 Strings.115=Enter a quantity of the produced Part: Strings.116=Input Error: Quantity cannot be reserved. frmMain.mnProjMengeBucheX=Book partial quantity after production frmMain.spPLEDHint=Send Box to COM Port frmDruckEtikett.chkRaster=Raster Strings.117=Yes|No Strings.118=Yes|No Strings.119=Yes|No Strings.120=Unlock version for changes Strings.121=Do you really want to change the versioned project? Strings.122="Single Module"|"Complete Unit" Strings.123= Strings.124=Yes|No Strings.125=Yes|No Strings.126=Yes|No Strings.127=Documentation Exists Strings.128=Documentation already exists. Do you still want to go to the record? Strings.129=Unlock version for changes Strings.130=Do you really want to change the versioned documentation? frmMain.tabPProjekt=Projects frmMain.panPPosVers=Version frmMain.tabPPDoku=Documentation frmMain.spPPDNewHint=New Entry frmMain.spPPDCopyHint=Copy Data frmMain.spPPDSaveHint=Save Data frmMain.spPPDAbortHint=Cancel Changes frmMain.spPPDDeleteHint=Delete Data frmMain.lbDatum21=Date: frmMain.spPPDPrintHint=Print frmMain.spPPDVersionHint=Import/Export frmMain.lbPPDokuBez=&Description frmMain.lbPPDokuStatus=Status frmMain.spPPDokuNichtFrg=NR frmMain.spPPDokuNichtFrgHint=Not Released frmMain.spPPDokuFrgAktiv=EA frmMain.spPPDokuFrgAktivHint=Enable (Activate) frmMain.spPPDokuFreigabeHint=Released frmMain.spPPDokuPrototyp=P frmMain.spPPDokuPrototypHint=Prototype frmMain.spPPDokuStorno=C frmMain.spPPDokuStornoHint=Canceled frmMain.spPPDokuGesperrt=B frmMain.spPPDokuGesperrtHint=Blocked frmMain.spPPDokuFilterHint=Filter By Current Status frmMain.spHandbuch17ExecHint=Open Manual frmMain.spHandbuch17Hint=Select Manual (File) frmMain.lbPPDokuHandbuch=&Manual frmMain.lbPPDokuKurzBez=Short Description frmMain.lbPPDokuDatum=D&ate frmMain.spPPDokuInfoEtikettHint=Print Label frmMain.lbPPDokuInfo=Info frmMain.spPPDokuDatumHint=Select Date frmMain.lbPPDokuVersion=&Version frmMain.spHandbuchPDF18ExecHint=Open Manual frmMain.spHandbuchPDF18Hint=Select Manual (File) frmMain.lbPPDokuHandbuchPDF=Manual &PDF frmMain.spGotoBauteilLG6Hint=Go To Store/Case frmMain.spGotoBauteil6Hint=Go To Component frmMain.spPPDBauteilHint=Select Component frmMain.lbPPDokuBauteil=&Component frmMain.lbPPDokuLagCase=&Case/Variant frmMain.spFilterPDokuThemaHint=Filter By Topic frmMain.lbPPDokuThema=&Topic frmMain.spGotoDoku1Hint=Go To The Documentation frmMain.spPPDokuHint=Select Documentation frmMain.lbPPDoku=D&ocumentation frmMain.chkPPDokuQuelle=Source Docu frmMain.tabPVersion=Version frmMain.spPVNewHint=New Entry frmMain.spPVCopyHint=Copy Data frmMain.spPVSaveHint=Save Data frmMain.spPVAbortHint=Cancel Changes frmMain.spPVDeleteHint=Delete Data frmMain.lbDatum19=Date: frmMain.spPVPrintHint=Print frmMain.spPVExpHint=Import/Export frmMain.lbPVersBez=&Description frmMain.lbPVersBauteil=&Component frmMain.lbPVersLagCase=&Case/variant frmMain.spPVersBauteilHint=Select Component frmMain.spGotoBauteil5Hint=Go To Component frmMain.lbPVersStatus=Status frmMain.spPVersNichtFrg=NR frmMain.spPVersNichtFrgHint=Not Released frmMain.spPVersFrgAktiv=EA frmMain.spPVersFrgAktivHint=Enable (Activate) frmMain.spPVersFreigabeHint=Released frmMain.spPVersPrototyp=P frmMain.spPVersPrototypHint=Prototype frmMain.spPVersStorno=C frmMain.spPVersStornoHint=Canceled frmMain.spPVersGesperrt=D frmMain.spPVersGesperrtHint=Blocked frmMain.spPVersFilterHint=Filter By Current Status frmMain.spGotoBauteilLG5Hint=Go To Store/Case frmMain.spHandbuch14ExecHint=Open Manual frmMain.spHandbuch14Hint=Select Manual (File) frmMain.lbPVersHandbuch=&Manual frmMain.lbPVersVersion=&Version frmMain.lbPVersRevision=&Revision frmMain.lbPVersDatum=D&ate frmMain.spPVersInfoEtikettHint=Print Label frmMain.lbPVersInfo=Info frmMain.spPVersDatumHint=Select Date frmMain.lbPVersTermin=&Appointment frmMain.spPVersTerminHint=Select Date frmMain.lbPVersBearb=Editor frmMain.lbPVersPruerf=Inspector frmMain.spPVersPruefungHint=Select Date frmMain.lbPVersPruerfD=Inspection frmMain.lbPVersFrg=Released By frmMain.spPVersDFreigHint=Select Date frmMain.lbPVersFrgD=Enabled frmMain.panPVersBaut=Changed Components frmMain.tabPGeraet=Devices frmMain.lbPGeraetHandbuch=&Manual frmMain.lbPGeraetBez=&Description frmMain.spHandbuch13Hint=Select Manual (File) frmMain.spHandbuch13ExecHint=Open Manual frmMain.lbPGeraetMengeFertig=&Quantity Ready frmMain.lbPGeraetMengeOffen=Q&uantity Open frmMain.lbPGeraetTermin=&Appointment frmMain.spPGeraetBuchHint=Store booking frmMain.spPGeraetTerminHint=Select Date frmMain.spPGeraetDet=▼ frmMain.spPGNewHint=New Entry frmMain.spPGCopyHint=Copy Data frmMain.spPGSaveHint=Save Data frmMain.spPGAbortHint=Cancel Changes frmMain.spPGDeleteHint=Delete Data frmMain.lbDatum16=Date: frmMain.spPGPrintHint=Print frmMain.edSchnellsuchePGeratHint=Quick Search frmMain.spPGExpHint=Import/Export frmMain.spFilterPGeratHint=Filter By Project frmMain.lbPGeraetBauteil=Component frmMain.spPGeraetBauteilHint=Select Component frmMain.spGotoBauteil4Hint=Go To Component frmMain.spGotoBauteilLG4Hint=Go To Store/Case frmMain.lbPGeraetLagCase=Store/Case frmMain.lbPGeraetWartungNext=Next servicing frmMain.spPGeraetWartungHint=Select Date frmMain.lbPGeraetWartungInv=Interval frmMain.spPGeraetIntervallHint=Store booking frmMain.lbPGeraetAdr=Address frmMain.spGotoAdrPGHint=Go To Address frmMain.lbPGeraetArtikelNr=Ite&m No. frmMain.lbPGeraetArtikelNr2=Item No. 2 frmMain.lbPGeraetAuftrag=O&rder No. frmMain.spPGeraetAuftragFctHint=Order Functions frmMain.tabPGUebers=Overview frmMain.tabPDoku=Documentation frmMain.spPDNewHint=New Entry frmMain.spPDCopyHint=Copy Data frmMain.spPDSaveHint=Save Data frmMain.spPDAbortHint=Cancel Changes frmMain.spPDDeleteHint=Delete Data frmMain.lbDatum20=Date: frmMain.spPDPrintHint=Print frmMain.dbPDokuArchiv=Archive frmMain.spPDokuArchivHint=Archive View frmMain.spPDokuVersionHint=Version History frmMain.lbPDokuBez=&Description frmMain.lbPDokuStatus=Status frmMain.spPDokuNichtFrg=NR frmMain.spPDokuNichtFrgHint=Not Released frmMain.spPDokuFrgAktiv=FA frmMain.spPDokuFrgAktivHint=Enable (Activate) frmMain.spPDokuFreigabeHint=Released frmMain.spPDokuPrototyp=T frmMain.spPDokuPrototypHint=Prototype frmMain.spPDokuStorno=L frmMain.spPDokuStornoHint=Canceled frmMain.spPDokuGesperrt=D frmMain.spPDokuGesperrtHint=Blocked frmMain.spPDokuFilterHint=Filter By Current Status frmMain.spHandbuch15ExecHint=Open Manual frmMain.spHandbuch15Hint=Select Manual (File) frmMain.lbPDokuHandbuch=&Manual frmMain.lbPDokuKurzBez=Short Description frmMain.lbPDokuDatum=D&ate frmMain.spPDokuInfoEtikettHint=Print Label frmMain.lbPDokuInfo=Info frmMain.spPDokuDatumHint=Select Date frmMain.lbPDokuVersion=&Version frmMain.lbPDokuDirZiel=&Destination Folder frmMain.spDirZielHint=Select Destination Folder frmMain.spDirZielExecHint=Open Destination Folder frmMain.lbPDokuNummer=&Number frmMain.spHandbuchPDF16ExecHint=Open Manual frmMain.spHandbuchPDF16Hint=Select Manual (File) frmMain.lbPDokuHandbuchPDF=Manual &PDF frmMain.lbDokuThema=&Topic frmMain.spFilterDokuThemaHint=Filter By Topic frmMain.panPVersBaut1=Used in project frmMain.spHandbuch12ExecHint=Open Manual frmMain.qKisteBarcode=Barcode frmMain.qBestellLEinheit=Unit frmMain.mnBVerz=Create Directories frmMain.qTypBLEinheit=Unit frmMain.qGehauseBRoHS=RoHS frmMain.qGehauseBKennz=Flag frmMain.qGehauseBGewicht=Weight frmMain.qGehauseBBarcode=Barcode frmMain.qGehauseBArtikelNr=Item No. frmMain.qGehauseBArtikelNr2=Item No. 2 frmMain.qGehauseBSMD=SMD frmMain.qProjektID_ID_Version=ID_ID_Version frmMain.qProjektProjektVersion_ID=Version frmMain.qProjektTyp=Type frmMain.qProjektVersionTyp=Version Type frmMain.qPPosID_ID_Version=ID_ID_Version frmMain.qPPosProjektVersion_ID=Version frmMain.qPPosLEinheit=Unit frmMain.qPPosGeloescht=Deleted frmMain.mnPVerz=Create Directories frmMain.mnPVersNew=Create version frmMain.mnPVersAend=Change Version frmMain.mnPVersZeig=Show version frmMain.mnPVersZeigAktuell=Current frmMain.qKisteBLEinheit=Unit frmMain.qKisteBHaltbar=Preserved frmMain.qKisteBBWare=BWare frmMain.qKisteBRoHS=RoHS frmMain.qKisteBKennz=Flag frmMain.qKisteBGewicht=Weight frmMain.qKisteBBarcode=Barcode frmMain.qKisteBArtikelNr=Item No. frmMain.qKisteBArtikelNr2=Item No. 2 frmMain.qKisteBSMD=SMD frmMain.qPVersFoto_ID=Photo ID frmMain.qPVersProjekt_ID=Project ID frmMain.qPVersDatum=Date frmMain.qPVersVersion=Version frmMain.qPVersRevision=Revision frmMain.qPVersStatus=Status frmMain.qPVersBezeichnung=Description frmMain.qPVersBauteil=Component frmMain.qPVersBauteil_ID=Component frmMain.qPVersBeschreibung=Text frmMain.qPVersBearbeiter=Editor frmMain.qPVersTermin=Appointment frmMain.qPVersPruefer=Inspector frmMain.qPVersPrueferD=Inspection Date frmMain.qPVersFreigeber=Released By frmMain.qPVersFreigeberD=Released Date frmMain.qPVersMengeFertig=Quantity Finished frmMain.qPVersMengeOffen=Quantity Opened frmMain.qPVersVPreis=Sale Price frmMain.qPVersHandbuch=Manual frmMain.qPVersInfo=Info frmMain.qPVersAuftrag=Order frmMain.qPVersSNr=Serial No. frmMain.qPVersArtikelNr=Item No. frmMain.qPVersArtikelNr2=Item No. 2 frmMain.qPVersBarcode=Barcode frmMain.qPVersOptA=Opt. A frmMain.qPVersOptB=Opt. B frmMain.qPVersOptC=Opt. C frmMain.qPVersKennz=Flag frmMain.qPVersAendDatum=Change Date frmMain.qPVersBProjekt_ID=Project ID frmMain.qPVersBFoto_ID=Photo ID frmMain.qPVersBID_ID_Version=ID_ID_Version frmMain.qPVersBProjektVersion_ID=Version frmMain.qPVersBBezeichnung=Description frmMain.qPVersBArtikelNr=Item No. frmMain.qPVersBStatus=Status frmMain.qPVersBBemerkung=Note frmMain.qPVersBBauteil_ID=Component frmMain.qPVersBSymbol=Symbol frmMain.qPVersBWert=Value frmMain.qPVersBGehause=Case frmMain.qPVersBMenge=Quantity frmMain.qPVersBEPreis=Purchase Price frmMain.qPVersBRabatt=Discount frmMain.qPVersBGPreis=Total Price frmMain.qPVersBArt=Category frmMain.qPVersBVariante=Variant frmMain.qPVersBPosX=Pos X frmMain.qPVersBPosY=Pos Y frmMain.qPVersBPosZ=Pos Z frmMain.qPVersBPosR=Pos R frmMain.qPVersBTop=Top frmMain.qPVersBSMD=SMD frmMain.qPVersBBarcode=Barcode frmMain.qPVersBKennz=Flag frmMain.qPVersBHandbuch=Manual frmMain.qPVersBInfo=Info frmMain.qPVersBSNr=Serial No. frmMain.qPVersBDruck=Print frmMain.qPVersBAendDatum=Change Date frmMain.qPVersBGeloescht=Deleted frmMain.qPPosVBProjekt_ID=Project ID frmMain.qPPosVBFoto_ID=Photo ID frmMain.qPPosVBID_ID_Version=ID_ID_Version frmMain.qPPosVBProjektVersion_ID=Version frmMain.qPPosVBBezeichnung=Description frmMain.qPPosVBArtikelNr=Item No. frmMain.qPPosVBStatus=Status frmMain.qPPosVBBemerkung=Note frmMain.qPPosVBBauteil_ID=Component frmMain.qPPosVBSymbol=Symbol frmMain.qPPosVBWert=Value frmMain.qPPosVBGehause=Case frmMain.qPPosVBMenge=Quantity frmMain.qPPosVBEPreis=Purchase Price frmMain.qPPosVBRabatt=Discount frmMain.qPPosVBGPreis=Total Price frmMain.qPPosVBArt=Category frmMain.qPPosVBVariante=Variant frmMain.qPPosVBPosX=Pos X frmMain.qPPosVBPosY=Pos Y frmMain.qPPosVBPosZ=Pos Z frmMain.qPPosVBPosR=Pos R frmMain.qPPosVBTop=Top frmMain.qPPosVBSMD=SMD frmMain.qPPosVBBarcode=Barcode frmMain.qPPosVBKennz=Flag frmMain.qPPosVBHandbuch=Manual frmMain.qPPosVBInfo=Info frmMain.qPPosVBSNr=Serial No. frmMain.qPPosVBDruck=Print frmMain.qPPosVBAendDatum=Change Date frmMain.qPPosVBGeloescht=Deleted frmMain.qDokuID_ID_Version=ID_ID_Version frmMain.qDokuFoto_ID=Photo ID frmMain.qDokuBezeichnung=Description frmMain.qDokuKurzBez=ShortDesc frmMain.qDokuThema=Topic frmMain.qDokuStatus=Status frmMain.qDokuDatum=Date frmMain.qDokuVersion=Version frmMain.qDokuRevision=Revision frmMain.qDokuBearbeiter=Editor frmMain.qDokuHandbuch=Manual frmMain.qDokuHandbuchPDF=ManualPDF frmMain.qDokuDirZiel=Dir Destination frmMain.qDokuBemerkung=Note frmMain.qDokuInfo=Info frmMain.qDokuArchiv=Archive frmMain.qDokuNr=No. frmMain.qDokuOptA=Opt. A frmMain.qDokuOptB=Opt. B frmMain.qDokuOptC=Opt. C frmMain.qDokuKennz=Flag frmMain.qDokuAendDatum=Change Date frmMain.oDir=Select Directory frmMain.qPDokuID_ID_Version=ID_ID_Version frmMain.qPDokuProjekt_ID=Project ID frmMain.qPDokuDoku_ID=Documentation frmMain.qPDokuFoto_ID=Photo ID frmMain.qPDokuBauteil=Component frmMain.qPDokuBauteil_ID=Component ID frmMain.qPDokuBezeichnung=Description frmMain.qPDokuKurzBez=ShortDesc frmMain.qPDokuThema=Topic frmMain.qPDokuStatus=Status frmMain.qPDokuDatum=Date frmMain.qPDokuVersion=Version frmMain.qPDokuRevision=Revision frmMain.qPDokuBearbeiter=Editor frmMain.qPDokuHandbuch=Manual frmMain.qPDokuHandbuchPDF=ManualPDF frmMain.qPDokuBemerkung=Note frmMain.qPDokuInfo=Info frmMain.qPDokuQuelleDoku=SourceDocu frmMain.qPDokuKennz=Flag frmMain.qPDokuOptA=Opt. A frmMain.qPDokuOptB=Opt. B frmMain.qPDokuOptC=Opt. C frmMain.qPDokuAendDatum=Change Date frmMain.qPDokuDokuBez=Docu. Descr. frmMain.qPDokuDokuKurzBez=Docu. Short Descr. frmMain.qPDokuDokuStatus=Docu. Status frmMain.qPDokuDokuDatum=Docu. Date frmMain.qPDokuDokuVersion=Docu. Version frmMain.qPDokuDokuThema=Docu. Topic frmMain.qPDokuDokuHandbuch=Docu. Manual frmMain.qPDokuDokuHandbuchPDF=Docu. Manual PDF frmMain.qPDokuDokuBemerkung=Docu. Remark frmMain.qPDokuDokuInfo=Docu. Info frmMain.qPDokuDokuArchiv=Docu. Archive frmMain.qPDokuDokuNr=Document No. frmMain.qDokuBFoto_ID=Photo ID frmMain.qDokuBID_ID_Version=ID_ID_Version frmMain.qDokuBProjektVersion_ID=Version frmMain.qDokuBTyp=Type frmMain.qDokuBVersionTyp=Version Type frmMain.qDokuBBezeichnung=Description frmMain.qDokuBBeschreibung=Text frmMain.qDokuBMengeFertig=Quantity Finished frmMain.qDokuBMengeOffen=Quantity Opened frmMain.qDokuBKennz=Flag frmMain.qDokuBTermin=Appointment frmMain.qDokuBHandbuch=Manual frmMain.qDokuBInfo=Info frmMain.qDokuBBauteil_ID=Component frmMain.qDokuBOptA=Opt. A frmMain.qDokuBOptB=Opt. B frmMain.qDokuBOptC=Opt. C frmMain.qDokuBWartung=Service frmMain.qDokuBIntervall=Interval frmMain.qDokuBVariante=Variant frmMain.qDokuBAuftrag=Order frmMain.qDokuBAdr_ID=Address frmMain.qDokuBSNr=Serial No. frmMain.qDokuBVPreis=Sale Price frmMain.qDokuBAendDatum=Change Date frmMain.qDokuBArtikelNr=Item No. frmMain.qDokuBArtikelNr2=Item No. 2 frmMain.mnPDVersNew=Create version frmMain.mnPDVersAend=Change Version frmMain.mnPDVersZeig=Show version frmMain.mnPPDVersNew=Create version frmMain.mnPPDVersAend=Change Version frmMain.mnPPDVersZeig=Show version frmPPosTest.chkProj=Projects frmPPosTest.chkGeraet=Devices frmAuswahl.qryGID_ID_Version=ID_ID_Version frmAuswahl.qryGFoto_ID=Photo ID frmAuswahl.qryGBezeichnung=Description frmAuswahl.qryGKurzBez=ShortDesc frmAuswahl.qryGThema=Topic frmAuswahl.qryGStatus=Status frmAuswahl.qryGDatum=Date frmAuswahl.qryGVersion=Version frmAuswahl.qryGHandbuch=Manual frmAuswahl.qryGHandbuchPDF=ManualPDF frmAuswahl.qryGBemerkung=Note frmAuswahl.qryGInfo=Info frmAuswahl.qryGNr=No. frmAuswahl.qryGKennz=Flag frmAuswahl.qryGOptA=Opt. A frmAuswahl.qryGOptB=Opt. B frmAuswahl.qryGOptC=Opt. C frmAuswahl.qryGAendDatum=Change Date frmKonfig.lbDirGeraet=Devices frmKonfig.lbDirDoku=Documents frmKonfig.tabFormat=Formats frmKonfig.tabGBauteil=Components frmKonfig.lbVerzBauteil=Create Directories For Components: frmKonfig.tabGProjekt=Project frmKonfig.lbVerzProjekt=Create Directories For Projects: frmBauteil.qryDokuID_ID_Version=ID_ID_Version frmBauteil.qryDokuFoto_ID=Photo ID frmBauteil.qryDokuBezeichnung=Description frmBauteil.qryDokuKurzBez=ShortDesc frmBauteil.qryDokuThema=Topic frmBauteil.qryDokuStatus=Status frmBauteil.qryDokuDatum=Date frmBauteil.qryDokuVersion=Version frmBauteil.qryDokuRevision=Revision frmBauteil.qryDokuBearbeiter=Editor frmBauteil.qryDokuHandbuch=Manual frmBauteil.qryDokuHandbuchPDF=ManualPDF frmBauteil.qryDokuDirZiel=Dir Destination frmBauteil.qryDokuBemerkung=Note frmBauteil.qryDokuInfo=Info frmBauteil.qryDokuArchiv=Archive frmBauteil.qryDokuNr=No. frmBauteil.qryDokuOptA=Opt. A frmBauteil.qryDokuOptB=Opt. B frmBauteil.qryDokuOptC=Opt. C frmBauteil.qryDokuKennz=Flag frmBauteil.qryDokuAendDatum=Change Date frmVersNew=New version frmVersNew.btnOK=&OK frmVersNew.btnCancel=&Cancel frmVersNew.lbMsg=Create A New Version frmVersNew.lbBezeichung=&Description frmVersNew.lbVersion=&Version frmVersNew.lbRevision=&Revision frmVersNew.lbBearbeiter=&Editor frmVersNew.lbDatum=D&ate frmVersNew.lbVersionOld=Last version frmVersNew.lbRevisionOld=Last revision Strings.131=Database is newer than the *.EXE version and can not be imported! Strings.132=Support the EleLa project with your donation Strings.133=This function automatically generates a barcode for ALL the case / store entries, if the entry does not have a barcode. Strings.134=Duplicate barcodes or errors can be created, so check the log afterwards and check for duplicate barcodes.\r\nThe function cannot be undone. Strings.135=Do you really want to do this? Strings.136=New data translation Strings.137=Enter the Description: Strings.138=Edit Data Translation Strings.139=Enter the Description: Strings.140=Do you really want to change the versioned device? Strings.141=Book device component Strings.142=The device has been produced and the components of the positions will be reduced from store? Strings.143=Enter the Device description, Strings.144=Device Exists Strings.145=Device already exists. Do you still want to use this record? Strings.146=Other Strings.147=Change All Visible Statuses Strings.148=Do you really want to change all visible statuses? frmMain.spBauteilCalcHint=Calculator frmMain.spBChartHint=Price Chart frmMain.lbBLiefAbMenge=&From Quantity frmMain.spBLiefWeb=Web query frmMain.spProjektCalcHint=Calculator frmMain.spProjektInfoEtikettHint=Print Label frmMain.lbPPDokuInfo1=Info frmMain.spFilterPHistHint=Filter By Project frmMain.edSchnellsuchePHistHint=Quick Search frmMain.spPGeraetCalcHint=Calculator frmMain.tabPGPos=Position frmMain.tabPGPPos=Components And Projects frmMain.lbPGPosMenge=Quantit&y frmMain.lbPGPosBez=D&escription frmMain.btnBestellBauteil6Hint=Take part in order proposal frmMain.lbPGPosBauteil=&Component frmMain.spGotoBauteil7Hint=Go To Component frmMain.lbPGPosLagCase=Case/Variant frmMain.spGotoBauteilLG7Hint=Go To Store/Case frmMain.lbPGPosVariante=Va&riant frmMain.spPGFilterVarianteHint=Filter By Type frmMain.spPGPBauteilHint=Select Component frmMain.lbPGPosStatus=Status frmMain.spPGPStatusHint=Select status frmMain.spPGPosNicht=D frmMain.spPGPosNichtHint=Defective frmMain.spPGPosPruefen=T frmMain.spPGPosPruefenHint=test frmMain.spPGPosFertigHint=Ready frmMain.spPGPosAktiv=A frmMain.spPGPosAktivHint=Active frmMain.spPGPosOffen=O frmMain.spPGPosOffenHint=Open frmMain.spPGPosKeinHint= frmMain.spFilterPGPStatusHint=Filter By Current Status frmMain.lbPGPosSumM=Sum frmMain.spPGPosDet=▼ frmMain.spPGLEDHint=Send Box to COM Port frmMain.spPGSave1Hint=Save Data frmMain.spPGAbort1Hint=Cancel Changes frmMain.lbDatum22=Date: frmMain.spPGPrint1Hint=Print frmMain.spPGPExpHint=Import/Export frmMain.lbPGPosSuchIn=(...) frmMain.spPGNew1Hint=New Entry frmMain.spPGCopy1Hint=Copy Data frmMain.spPGDelete1Hint=Delete Data frmMain.spHandbuch16ExecHint=Open Manual frmMain.spHandbuch16Hint=Select Manual (File) frmMain.lbPGPosHandbuch=&Manual frmMain.lbPGPosCase=&Case frmMain.lbPGPosSNr=Serial number frmMain.lbPGPosWert=&Value frmMain.lbPPosSum1=Sum frmMain.lbPGPosEPreis=Pr&ice frmMain.lbPGPosGPreis=Total Price frmMain.panPGPosVers=Version frmMain.tabPGPPPos=Project Position / Place Variant frmMain.tabPGHistorie=History frmMain.lbProjektGHistHandbuch=&Manual frmMain.lbProjektGHistProjBez=&Project frmMain.spHandbuch19Hint=Select Manual (File) frmMain.spHandbuch19ExecHint=Open Manual frmMain.lbProjektGHistVersion=&Version frmMain.lbProjektGHistAufwand=T&ime frmMain.lbProjektGHistDatum=D&ate frmMain.lbProjektGHistBez=D&escription frmMain.lbProjektGHistFDatum=Date Read&y frmMain.lbProjektGHistFVersion=Versi&on ready frmMain.spHist2FilterHint=Filter By Current Status frmMain.lbProjektGHistStatus=Status frmMain.spHist2FilterBFHint=Filter By Current B/F frmMain.spHist2BugFHint=Feature frmMain.spHist2Bug=B frmMain.spHist2BugHint=Bug frmMain.spHist2BugN=D frmMain.spHist2BugNHint=Defective frmMain.lbHistStatus3=B/F frmMain.spHist2Hist=H frmMain.spHist2HistHint=History frmMain.spHist2Offen=O frmMain.spHist2OffenHint=Open frmMain.spHist2Aktiv=A frmMain.spHist2AktivHint=Active frmMain.spHist2FertigHint=Ready frmMain.spHist2Nicht=D frmMain.spHist2NichtHint=not edit frmMain.spHist2Spaeter=L frmMain.spHist2SpaeterHint=later frmMain.spHist2FilterDatumFHint=Filter By Date Ready frmMain.spHist2FilterVersionFHint=Filter By Version Ready frmMain.spHist2Testen=T frmMain.spHist2TestenHint=test frmMain.spHist2FDatumHint=Select Date frmMain.lbProjektGHistPPos=Position frmMain.spHist2Det=▼ frmMain.spH2GotoPPosHint=Go To Project Pos frmMain.spHNew2Hint=New Entry frmMain.spHCopy2Hint=Copy Data frmMain.spHSave2Hint=Save Data frmMain.spHAbort2Hint=Cancel Changes frmMain.spHDelete2Hint=Delete Data frmMain.lbDatum23=Date: frmMain.spHPrint2Hint=Print frmMain.spHExp2Hint=Import/Export frmMain.spFilterPGHistHint=Filter By Project frmMain.edSchnellsuchePGHistHint=Quick Search frmMain.lbProjektHistGFehlerreport=Error Report C&ustomer frmMain.lbProjektGHistRepReport=Repair Report frmMain.lbProjektGHistRMA=RMA frmMain.spGetRMACode2Hint=Generate RMA Code frmMain.spGetErrorCode2Hint=Generate RMA Code frmMain.lbProjektGHistFehlercode=Error Code frmMain.lbProjektGHistVorgehen=Proceedin&g frmMain.lbProjektGHistKostenv=Quotation frmMain.spH2GotoKostHint=Go To Quotation frmMain.lbProjektGHistGN=Devi&ce No. frmMain.lbProjektGHistSN=Serial numbe&r frmMain.lbProjektGHistAbrechnung=Invoice frmMain.lbHist2AdrKont=&Address/Contact frmMain.spGotoAdrH2Hint=Go to Address frmMain.lbProjektGHistGPreis=Total Price frmMain.tabPGDoku=Documentation frmMain.spPGDNewHint=New Entry frmMain.spPGDCopyHint=Copy Data frmMain.spPGDSaveHint=Save Data frmMain.spPGDAbortHint=Cancel Changes frmMain.spPGDDeleteHint=Delete Data frmMain.lbDatum24=Date: frmMain.spPGDPrintHint=Print frmMain.spPGDVersionHint=Import/Export frmMain.lbPGDokuBez=&Description frmMain.lbPGDokuStatus=Status frmMain.spPGDokuNichtFrg=NR frmMain.spPGDokuNichtFrgHint=Not Released frmMain.spPGDokuFrgAktiv=EA frmMain.spPGDokuFrgAktivHint=Enable (Activate) frmMain.spPGDokuFreigabeHint=Released frmMain.spPGDokuPrototyp=T frmMain.spPGDokuPrototypHint=Prototype frmMain.spPGDokuStorno=L frmMain.spPGDokuStornoHint=Canceled frmMain.spPGDokuGesperrt=D frmMain.spPGDokuGesperrtHint=Blocked frmMain.spPGDokuFilterHint=Filter By Current Status frmMain.spHandbuch20ExecHint=Open Manual frmMain.spHandbuch20Hint=Select Manual (File) frmMain.lbPGDokuHandbuch=&Manual frmMain.lbPGDokuKurzBez=Short Description frmMain.lbPGDokuDatum=D&ate frmMain.spPGDokuInfoEtikettHint=Print Label frmMain.lbPGDokuInfo=Info frmMain.spPGDokuDatumHint=Select Date frmMain.lbPGDokuVersion=&Version frmMain.spHandbuchPDF21ExecHint=Open Manual frmMain.spHandbuchPDF21Hint=Select Manual (File) frmMain.lbPGDokuHandbuchPDF=Manual &PDF frmMain.spGotoBauteilLG8Hint=Go To Store/Case frmMain.spGotoBauteil8Hint=Go To Component frmMain.spPGDBauteilHint=Select Component frmMain.lbPGDokuBauteil=&Component frmMain.lbPGDokuLagCase=&Case/Variant frmMain.spFilterPGDokuThemaHint=Filter By Topic frmMain.lbPGDokuThema=&Topic frmMain.spGotoDoku2Hint=Go To Documentation frmMain.spPGDokuHint=Select Documentation frmMain.lbPGDoku=D&ocumentation frmMain.chkPGDokuQuelle=Source Documentation frmMain.tabPGVersion=Version frmMain.spPGVNewHint=New Entry frmMain.spPGVCopyHint=Copy Data frmMain.spPGVSaveHint=Save Data frmMain.spPGVAbortHint=Cancel Changes frmMain.spPGVDeleteHint=Delete Data frmMain.lbDatum25=Date: frmMain.spPGVPrintHint=Print frmMain.spPGVExpHint=Import/Export frmMain.lbPGVersBez=&Description frmMain.lbPGVersBauteil=&Component frmMain.lbPGVersLagCase=&Store/Case frmMain.spPGVersBauteilHint=Select Component frmMain.spGotoBauteil9Hint=Go To Component frmMain.lbPGVersStatus=Status frmMain.spPGVersNichtFrg=NR frmMain.spPGVersNichtFrgHint=Not Released frmMain.spPGVersFrgAktiv=EA frmMain.spPGVersFrgAktivHint=Enable (Activate) frmMain.spPGVersFreigabeHint=Released frmMain.spPGVersPrototyp=T frmMain.spPGVersPrototypHint=Prototype frmMain.spPGVersStorno=L frmMain.spPGVersStornoHint=Canceled frmMain.spPGVersGesperrt=D frmMain.spPGVersGesperrtHint=Blocked frmMain.spPGVersFilterHint=Filter By Current Status frmMain.spGotoBauteilLG9Hint=Go To Store/Case frmMain.spHandbuch22ExecHint=Open Manual frmMain.spHandbuch22Hint=Select Manual (File) frmMain.lbPGVersHandbuch=&Manual frmMain.lbPGVersVersion=&Version frmMain.lbPGVersRevision=&Revision frmMain.lbPGVersDatum=D&ate frmMain.spPGVersInfoEtikettHint=Print Label frmMain.lbPGVersInfo=Info frmMain.spPGVersDatumHint=Select Date frmMain.lbPGVersTermin=&Appointment frmMain.spPGVersTerminHint=Select Date frmMain.lbPGVersBearb=Editor frmMain.lbPGVersPruerf=Inspector frmMain.spPGVersPruefungHint=Select Date frmMain.lbPGVersPruerfD=Inspection frmMain.lbPGVersFrg=Released By frmMain.spPGVersDFreigHint=Select Date frmMain.lbPGVersFrgD=Enabled frmMain.panPGVersBaut=Changed Components frmMain.lbDatum28=Date: frmMain.tabPGKost=Quotation frmMain.tabPGKUeb=Overview frmMain.lbPGKostAdrKont=&Address/Contact frmMain.lbPGKostBez=&Description frmMain.lbPGKostLief=Supp&lier frmMain.lbPGKostAngebot=&Offer frmMain.spGotoAdrPGKHint=Go To Address frmMain.lbPGKostStatus=Status frmMain.spPGKSAngebot=A frmMain.spPGKSAngebotHint=&Offer frmMain.spPGKSAngebotG=OS frmMain.spPGKSAngebotGHint=Offer Sent frmMain.spPGKSBestellt=B frmMain.spPGKSBestelltHint=Ordered frmMain.spPGKSFertigHint=Ready frmMain.spPGKSGeliefert=D frmMain.spPGKSGeliefertHint=Delivered frmMain.spPGKSStorno=L frmMain.spPGKSStornoHint=Canceled frmMain.spPGKFilterHint=Filter By Current Status frmMain.lbPGKostAuftrag=O&rder No. frmMain.spPGKAngebotHint=Select Date frmMain.lbPGKostGueltig=&Valid to frmMain.spPGKGueltigHint=Select Date frmMain.spPGKLiefHint=Select Date frmMain.lbPGKostAbnahme=Dec&rease frmMain.spPGKAbnahmeHint=Select Date frmMain.lbPGKostBestNr=Order Code frmMain.lbPGKostGPreis=Total Price frmMain.lbPGKostInfo=Info frmMain.spGetPGKVCodeHint=Generate RMA Code frmMain.spPGKInfoEtikettHint=Print Label frmMain.spPGKNewHint=New Entry frmMain.spPGKCopyHint=Copy Data frmMain.spPGKSaveHint=Save Data frmMain.spPGKAbortHint=Cancel Changes frmMain.spPGKDeleteHint=Delete Data frmMain.lbDatum26=Date: frmMain.spPGKPrintHint=Print frmMain.spPGKExpHint=Import/Export frmMain.tabPGKPos=Position frmMain.lbPGKostPBez=&Description frmMain.lbPGKostPLieferung=Supp&lier frmMain.lbPGKostPStatus=Status frmMain.spPGKPOffen=O frmMain.spPGKPOffenHint=Open frmMain.spPGKPAktiv=A frmMain.spPGKPAktivHint=Active frmMain.spPGKPTest=T frmMain.spPGKPTestHint=test frmMain.spPGKPFertigHint=Ready frmMain.spPGKPNichtB=D frmMain.spPGKPNichtBHint=not edit frmMain.spPGKPStorno=L frmMain.spPGKPStornoHint=Canceled frmMain.spPGKPFilterHint=Filter By Current Status frmMain.lbPGKostPTermin=Appointment frmMain.spPGKPTerminHint=Select Date frmMain.spPGKPLiefHint=Select Date frmMain.lbPKostPArtikelNr1=Ite&m No. frmMain.lbPGKostPVPreis=Sale Price frmMain.lbPGKostPMenge=Quantit&y frmMain.btnBestellBauteil7Hint=Take part in order proposal frmMain.lbPGKostPBauteil=&Component frmMain.lbPGKostPLagCase=&Store/Case frmMain.spGotoBauteilLG10Hint=Go To Store/Case frmMain.spGotoBauteil10Hint=Go To Component frmMain.spPGKPBauteilHint=Select Component frmMain.lbPGKostPVSum=Total Position frmMain.lbPKostPPPos1=Position frmMain.spPGKPVPreisHint=Update Price Of Component frmMain.lbPGKostPInfo=Info frmMain.spPGKPGotoProjPosHint=Go To Project Pos frmMain.spPGKPInfoEtikettHint=Print Label frmMain.spPGKPNewHint=New Entry frmMain.spPGKPCopyHint=Copy Data frmMain.spPGKPSaveHint=Save Data frmMain.spPGKPAbortHint=Cancel Changes frmMain.spPGKPDeleteHint=Delete Data frmMain.lbDatum27=Date: frmMain.spPGKPPrintHint=Print frmMain.spPGKPExpHint=Import/Export frmMain.tabPGBestell=Orders frmMain.lbPGBestellBauteil=&Component frmMain.spGotoLager5Hint=Go To Store/Case frmMain.lbPGBestBez=D&escription frmMain.spGotoBestell3Hint=Go To Order frmMain.chkPGBestellArchiv=With archived frmMain.spBestChartHint=Price Chart frmMain.chkSuchMitLieferant=with supplier frmMain.spAdrCpyHint=Copy Address In Clipboard frmMain.chkAdrKunde=Customer frmMain.spAdrKCpyHint=Copy Address In Clipboard frmMain.chkAdrKLief=Supplier frmMain.chkAdrKHerst=Manufacturer frmMain.chkAdrKKunde=Customer frmMain.chkAdrKProjekt=Project/History frmMain.tabExtraTerminal=COM Terminal frmMain.spTermConnectHint=Connect / Disconnect frmMain.lbTermVerbindungParam=Connection Parameter: frmMain.spTermParamHint=Connection Parameter frmMain.spTermSaveHint=Save Protocol Into File frmMain.spTermSendFileHint=Send file frmMain.spTermClearHint=Clear log frmMain.rbTermAnsi=ANSI frmMain.rbTermHex=HEX frmMain.rbTermCustom=Userdefined: frmMain.chkTermZWms=New line after ms: frmMain.spTermDWHint=Parameter Data Translation frmMain.btnTermSend=Send frmMain.btnTermSendHint=Send text to COM Port frmMain.chkTermBreak=BREAK frmMain.chkTermCR=CR frmMain.chkTermLF=LF frmMain.spTermPause=Pause frmMain.spTermPauseHint=Pause Log frmMain.lbRXCnt=RX cnt.: frmMain.lbTXCnt=TX cnt.: frmMain.btn2048=2048 frmMain.qAdrSkype=Skype frmMain.qAdrFacebook=Facebook frmMain.qAdrWLanSSID=WLanSSID frmMain.qAdrWLanPasswort=WLanPassword frmMain.qAdrKunde=Customer frmMain.qSuchBAendDatum=Component Date frmMain.qBestellBarcode=Store Barcode frmMain.mnBBarcodeErzeuge=Generate Barcode Case/Store frmMain.mnBBarcodeWebcam=Read The Barcode With A Webcam frmMain.qTypBID=ID frmMain.qTypBSMD_Text=SMD_Text frmMain.qGehauseBID=ID frmMain.qProjektIntervall=Interval frmMain.qPPostree_typ=Type frmMain.qPPostree_typ_ID=Type ID frmMain.mnPPExpBOM=Export BOM frmMain.mnPExport=Export Project frmMain.mnMoveAdrKontakt=Move to contact frmMain.qBProjektPVBezeichnung=Project Verion Descr. frmMain.qBProjektPVVersion=Project Version frmMain.qKisteBID=ID frmMain.mnGotoBautLgGeh=Go To Store/Case frmMain.qAdrBID=ID frmMain.qAdrKKontaktArt=Contact Type frmMain.qAdrKSkype=Skype frmMain.qAdrKFacebook=Facebook frmMain.qAdrKWLanSSID=WLanSSID frmMain.qAdrKWLanPasswort=WLanPassword frmMain.qAdrKKunde=Customer frmMain.qPGeraetFoto_ID=Photo ID frmMain.qPGeraetID_ID_Version=ID_ID_Version frmMain.qPGeraetProjektVersion_ID=Version frmMain.qPGeraetTyp=Type frmMain.qPGeraetVersionTyp=Version Type frmMain.qPGeraetBezeichnung=Description frmMain.qPGeraetBeschreibung=Text frmMain.qPGeraetMengeFertig=Quantity Finished frmMain.qPGeraetMengeOffen=Quantity Opened frmMain.qPGeraetKennz=Flag frmMain.qPGeraetTermin=Appointment frmMain.qPGeraetHandbuch=Manual frmMain.qPGeraetInfo=Info frmMain.qPGeraetBauteil_ID=Component frmMain.qPGeraetOptA=Opt. A frmMain.qPGeraetOptB=Opt. B frmMain.qPGeraetOptC=Opt. C frmMain.qPGeraetWartung=Service frmMain.qPGeraetIntervall=Interval frmMain.qPGeraetVariante=Variant frmMain.qPGeraetAuftrag=Order frmMain.qPGeraetAdr_ID=Address frmMain.qPGeraetSNr=Serial No. frmMain.qPGeraetVPreis=Sale Price frmMain.qPGeraetAendDatum=Change Date frmMain.qPGeraetArtikelNr=Store item No. frmMain.qPGeraetArtikelNr2=Store item No. 2 frmMain.qDokuAutoNr=Auto No. frmMain.qPDokuAutoNr=Auto No. frmMain.qPDokuNr=No. frmMain.mnPGExpCSV=Export In CSV Format frmMain.mnPGExpXML=Export in XML Format frmMain.mnPGInfoEtikett=Print Label "Info" frmMain.mnPGVerz=Create Directories frmMain.mnPGVersNew=Create version frmMain.mnPGVersAend=Change Version frmMain.mnPGVersZeig=Show version frmMain.mnPGVersZeigAktuell=Current frmMain.qPGPosProjekt_ID=Project ID frmMain.qPGPosFoto_ID=Photo ID frmMain.qPGPosID_ID_Version=ID_ID_Version frmMain.qPGPosProjektVersion_ID=Version frmMain.qPGPosBezeichnung=Description frmMain.qPGPosArtikelNr=Only One Component Per Label frmMain.qPGPosStatus=Status frmMain.qPGPosBemerkung=Note frmMain.qPGPosBauteil=Component frmMain.qPGPosBauteil_ID=Component frmMain.qPGPostree_typ=Type frmMain.qPGPostree_typ_ID=Type ID frmMain.qPGPosSymbol=Symbol frmMain.qPGPosWert=Value frmMain.qPGPosGehause=Case frmMain.qPGPosMenge=Quantity frmMain.qPGPosEPreis=Purchase Price frmMain.qPGPosRabatt=Discount frmMain.qPGPosGPreis=Total Price frmMain.qPGPosArt=Category frmMain.qPGPosVariante=Variant frmMain.qPGPosPosX=Pos X frmMain.qPGPosPosY=Pos Y frmMain.qPGPosPosZ=Pos Z frmMain.qPGPosPosR=Pos R frmMain.qPGPosTop=Top frmMain.qPGPosSMD=SMD frmMain.qPGPosBarcode=Barcode frmMain.qPGPosKennz=Flag frmMain.qPGPosHandbuch=Manual frmMain.qPGPosInfo=Info frmMain.qPGPosLMenge=Store quantity frmMain.qPGPosGBez=StoreCase frmMain.qPGPosSNr=Serial No. frmMain.qPGPosDruck=Print frmMain.qPGPosAendDatum=Change Date frmMain.qPGPosGeloescht=Deleted frmMain.qHist2Projekt_ID=Project ID frmMain.qHist2ProjektPos_ID=Order It frmMain.qHist2Foto_ID=Photo ID frmMain.qHist2Datum=Date frmMain.qHist2Status=Status frmMain.qHist2FStatus=B/F frmMain.qHist2Projekt=Project Descr. frmMain.qHist2Bezeichnung=Description frmMain.qHist2Beschreibung=Text frmMain.qHist2Version=Version frmMain.qHist1SNr1=Serial number frmMain.qHist2GNr=Devi&ce No. frmMain.qHist2FDatum=Date Ready frmMain.qHist2FVersion=Version Ready frmMain.qHist2Aufwand=Time frmMain.qHist2Kennz=Flag frmMain.qHist2Handbuch=Manual frmMain.qHist2Info=Info frmMain.qHist2Kosten_ID=Quotation frmMain.qHist2Vorgehen=Proceedin&g frmMain.qHist2Abrechnung=Invoice frmMain.qHist2GPreis=Total Price frmMain.qHist2KundeBes=Error Report C&ustomer frmMain.qHist2RepNr=RMA frmMain.qHist2RepFehler=Error Code frmMain.qHist2RepBes=Repair Report frmMain.qHist2Adr_ID=Address frmMain.qHist2AdrK_ID=Contact frmMain.qHist2AendDatum=Change Date frmMain.qPGDokuID_ID_Version=ID_ID_Version frmMain.qPGDokuProjekt_ID=Project ID frmMain.qPGDokuDoku_ID=Documentation frmMain.qPGDokuFoto_ID=Photo ID frmMain.qPGDokuBauteil=Component frmMain.qPGDokuBauteil_ID=Component ID frmMain.qPGDokuBezeichnung=Description frmMain.qPGDokuKurzBez=ShortDesc frmMain.qPGDokuThema=Topic frmMain.qPGDokuStatus=Status frmMain.qPGDokuDatum=Date frmMain.qPGDokuVersion=Version frmMain.qPGDokuRevision=Revision frmMain.qPGDokuBearbeiter=Editor frmMain.qPGDokuHandbuch=Manual frmMain.qPGDokuHandbuchPDF=ManualPDF frmMain.qPGDokuBemerkung=Note frmMain.qPGDokuInfo=Info frmMain.qPGDokuQuelleDoku=SourceDocu frmMain.qPGDokuAutoNr=Auto No. frmMain.qPGDokuNr=No. frmMain.qPGDokuKennz=Flag frmMain.qPGDokuOptA=Opt. A frmMain.qPGDokuOptB=Opt. B frmMain.qPGDokuOptC=Opt. C frmMain.qPGDokuAendDatum=Change Date frmMain.qPGDokuDokuBez=Docu. Descr. frmMain.qPGDokuDokuKurzBez=Docu. Short Descr. frmMain.qPGDokuDokuStatus=Docu. Status frmMain.qPFDokuDokuDatum=Docu. Date frmMain.qPGDokuDokuVersion=Docu. Version frmMain.qPGDokuDokuThema=Docu. Topic frmMain.qPGDokuDokuHandbuch=Docu. Manual frmMain.qPGDokuDokuHandbuchPDF=Docu. Manual PDF frmMain.qPGDokuDokuBemerkung=Docu. Remark frmMain.qPGDokuDokuInfo=Docu. Info frmMain.qPGDokuDokuArchiv=Docu. Archive frmMain.qPGDokuDokuNr=Document No. frmMain.qPGVersFoto_ID=Photo ID frmMain.qPGVersProjekt_ID=Project ID frmMain.qPGVersDatum=Date frmMain.qPGVersVersion=Version frmMain.qPGVersRevision=Revision frmMain.qPGVersStatus=Status frmMain.qPGVersBezeichnung=Description frmMain.qPGVersBauteil=Component frmMain.qPGVersBauteil_ID=Component frmMain.qPGVersBeschreibung=Text frmMain.qPGVersBearbeiter=Editor frmMain.qPGVersTermin=Appointment frmMain.qPGVersPruefer=Inspector frmMain.qPGVersPrueferD=Inspection Date frmMain.qPGVersFreigeber=Released By frmMain.qPGVersFreigeberD=Released Date frmMain.qPGVersMengeFertig=Quantity Finished frmMain.qPGVersMengeOffen=Quantity Opened frmMain.qPGVersVPreis=Sale Price frmMain.qPGVersHandbuch=Manual frmMain.qPGVersInfo=Info frmMain.qPGVersAuftrag=Order frmMain.qPGVersSNr=Serial No. frmMain.qPGVersArtikelNr=Only One Component Per Label frmMain.qPGVersArtikelNr2=Item No. 2 frmMain.qPGVersBarcode=Barcode frmMain.qPGVersOptA=Opt. A frmMain.qPGVersOptB=Opt. B frmMain.qPGVersOptC=Opt. C frmMain.qPGVersKennz=Flag frmMain.qPGVersAendDatum=Change Date frmMain.qPGKostProjekt_ID=Project ID frmMain.qPGKostAdr_ID=Address frmMain.qPGKostAdrK_ID=Contact frmMain.qPGKostFoto_ID=Photo ID frmMain.qPGKostBezeichnung=Description frmMain.qPGKostBeschreibung=Text frmMain.qPGKostStatus=Status frmMain.qPGKostRabatt=Discount frmMain.qPGKostGPreis=Total Price frmMain.qPGKostAuftrag=Order No. frmMain.qPGKostBestellnr=Order Code frmMain.qPGKostDAngebot=&Offer frmMain.qPGKostDGueltig=&Valid to frmMain.qPGKostDLief=Supp&lier frmMain.qPGKostDAbnahme=Dec&rease frmMain.qPGKostInfo=Info frmMain.qPGKostAendDatum=Change Date frmMain.qPGKostPosProjekt_ID=Project ID frmMain.qPGKostPosKosten_ID=Cost ID frmMain.qPGKostPosProjektPos_ID=Order It frmMain.qPGKostPosBauteil_ID=Component frmMain.qPGKostPosFoto_ID=Photo ID frmMain.qPGKostPosNr=No. frmMain.qPGKostPosBezeichnung=Description frmMain.qPGKostPosBeschreibung=Text frmMain.qPGKostPosStatus=Status frmMain.qPGKostPosMenge=Quantity frmMain.qPGKostPosVPreis=Sale Price frmMain.qPGKostPosRabatt=Discount frmMain.qPGKostPosVPSum=VPSum frmMain.qPGKostPosBarcode=Barcode frmMain.qPGKostPosArtikelNr=Only One Component Per Label frmMain.qPGKostPosTermin=Appointment frmMain.qPGKostPosDLief=DDeliver frmMain.qPGKostPosInfo=Info frmMain.qPGKostPosArt=Category frmMain.qPGKostPosAendDatum=Change Date frmMain.qPGKostPosLArtikelNr=Store item No. frmMain.qPGKostPosLBarcode=Store Barcode frmMain.qPGKostPosLArt=Store Art frmMain.qPGKostPosLArtikelNr2=Store item No. 2 frmMain.qPGBestellFoto_ID=Photo ID frmMain.qPGBestellBezeichnung=Description frmMain.qPGBestellMenge=Quantity frmMain.qPGBestellAuftrag=Order frmMain.qPGBestellStatus=Status frmMain.qPGBestellSDatum=SDatum frmMain.qPGBestellTermin1=Appointment 1 frmMain.qPGBestellTermin2=Date Ordered frmMain.qPGBestellArchiv=Archive frmMain.qPGBestellBemerkung=Note frmMain.qPGBestellBauteil_ID=Component frmMain.qPGBestellHandbuch=Manual frmMain.qPGBestellInfo=Info frmMain.qPGBestellUseLief12=Supplier frmMain.qPGBestellLief_MengeVPE=Deliv. Quantity Unit frmMain.qPGBestellLief_MengeVPESum=Deliv. Quantity Unit Tot frmMain.qPGBestellLager_MengeVPESum=Storage Unit total quantity frmMain.qPGBestellLief1_Adr_ID=Deliv1 Addr frmMain.qPGBestellLief1_BauteilAdr_ID=Deliv1 Supplier frmMain.qPGBestellLief1_BestellNr=Deliv1 OrderNo frmMain.qPGBestellLief1_MengeVPE=Deliv1 Quantity Unit frmMain.qPGBestellLief1_EPreis=Deliv1 Price frmMain.qPGBestellLief1_GPreis=Deliv1 Total frmMain.qPGBestellLief2_Adr_ID=Deliv2 Addr frmMain.qPGBestellLief2_BauteilAdr_ID=Deliv2 Supplier frmMain.qPGBestellLief2_BestellNr=Deliv2 OrderNo. frmMain.qPGBestellLief2_MengeVPE=Deliv2 Quantity Unit frmMain.qPGBestellLief2_EPreis=Deliv2 Price frmMain.qPGBestellLief2_GPreis=Deliv2 Total frmMain.qPGBestellProjekt_ID=Project ID frmMain.qPGBestellAendDatum=Change Date frmMain.qPGVersBProjekt_ID=Project ID frmMain.qPGVersBFoto_ID=Photo ID frmMain.qPGVersBID_ID_Version=ID_ID_Version frmMain.qPGVersBProjektVersion_ID=Version frmMain.qPGVersBBezeichnung=Description frmMain.qPGVersBArtikelNr=Only One Component Per Label frmMain.qPGVersBStatus=Status frmMain.qPGVersBBemerkung=Note frmMain.qPGVersBBauteil_ID=Component frmMain.qPGVersBSymbol=Symbol frmMain.qPGVersBWert=Value frmMain.qPGVersBGehause=Case frmMain.qPGVersBMenge=Quantity frmMain.qPGVersBEPreis=Purchase Price frmMain.qPGVersBRabatt=Discount frmMain.qPGVersBGPreis=Total Price frmMain.qPGVersBArt=Category frmMain.qPGVersBVariante=Variant frmMain.qPGVersBPosX=Pos X frmMain.qPGVersBPosY=Pos Y frmMain.qPGVersBPosZ=Pos Z frmMain.qPGVersBPosR=Pos R frmMain.qPGVersBTop=Top frmMain.qPGVersBSMD=SMD frmMain.qPGVersBBarcode=Barcode frmMain.qPGVersBKennz=Flag frmMain.qPGVersBHandbuch=Manual frmMain.qPGVersBInfo=Info frmMain.qPGVersBSNr=Serial No. frmMain.qPGVersBDruck=Print frmMain.qPGVersBAendDatum=Change Date frmMain.qPGVersBGeloescht=Deleted frmMain.qPGPosVBProjekt_ID=Project ID frmMain.qPGPosVBFoto_ID=Photo ID frmMain.qPGPosVBID_ID_Version=ID_ID_Version frmMain.qPGPosVBProjektVersion_ID=Version frmMain.qPGPosVBBezeichnung=Description frmMain.qPGPosVBArtikelNr=Only One Component Per Label frmMain.qPGPosVBStatus=Status frmMain.qPGPosVBBemerkung=Note frmMain.qPGPosVBBauteil_ID=Component frmMain.qPGPosVBSymbol=Symbol frmMain.qPGPosVBWert=Value frmMain.qPGPosVBGehause=Case frmMain.qPGPosVBMenge=Quantity frmMain.qPGPosVBEPreis=Purchase Price frmMain.qPGPosVBRabatt=Discount frmMain.qPGPosVBGPreis=Total Price frmMain.qPGPosVBArt=Category frmMain.qPGPosVBVariante=Variant frmMain.qPGPosVBPosX=Pos X frmMain.qPGPosVBPosY=Pos Y frmMain.qPGPosVBPosZ=Pos Z frmMain.qPGPosVBPosR=Pos R frmMain.qPGPosVBTop=Top frmMain.qPGPosVBSMD=SMD frmMain.qPGPosVBBarcode=Barcode frmMain.qPGPosVBKennz=Flag frmMain.qPGPosVBHandbuch=Manual frmMain.qPGPosVBInfo=Info frmMain.qPGPosVBSNr=Serial No. frmMain.qPGPosVBDruck=Print frmMain.qPGPosVBAendDatum=Change Date frmMain.qPGPosVBGeloescht=Deleted frmMain.mnPGPEPreis=Refresh Purchase Price frmMain.mnExpCSV3=Export In CSV Format frmMain.mnExpXML3=Export in XML Format frmMain.mnPGPInfoEtikett=Print Label "Info" frmMain.mnPGDVersNew=Create version frmMain.mnPGDVersAend=Change Version frmMain.mnPGDVersZeig=Show version frmBestellMin.spAll=All frmBestellMin.spNix=None frmBestellMin.qryID=ID frmBestellMin.qryMengeBest=Quantity Ordered frmBestellMin.qryPosBestell=component frmBestellMin.qryMengeBestellen=OrderQuantity frmDruckEtikett.chkGrpFelderItem6=Case/Variant Descr. frmDruckEtikett.lbVersatz=Offset X/Y/Start frmDruckEtikett.lbMM3=mm frmDruckEtikett.lbVersatzAnzahl=Number frmDruckEtikett.qDataArtikelNr=Only One Component Per Label frmTelParam.tabModem=Modem / TAPI frmTelParam.tabEXE=External Software frmTelParam.lbEXE=Program To Be Executed: frmTelParam.lbEXE1=Startparameter (%TELNR% / %TELNAME%): frmTelParam.rgrpAuswahl=Select Dial Type frmTelParam.rgrpAuswahlItem0=Modem / TAPI frmTelParam.rgrpAuswahlItem1=External Software frmKisteTausch.mnGotoBauteil2=Go To Store/Case frmKisteTausch.mnGotoBauteil=Go To Store/Case frmTypAuswahl.chkSubItems=View WIth Subitems frmKonfig.lbDirLib=Library frmKonfig.rgrpTAuswahl=Select Dial Type frmKonfig.rgrpTAuswahlItem0=Modem / TAPI frmKonfig.rgrpTAuswahlItem1=External Software frmKonfig.lbEXE=Program To Be Executed: frmKonfig.lbEXE1=Startparameter (%TELNR% is the phone number / %TELNAME%): frmKonfig.tabGDesign=Design frmKonfig.btnAdrkontakt=Edit Address Contact frmKonfig.btnInfoStatistik=Edit Statistics frmKonfig.tabWeb=Web Query frmKonfig.tabWebFarnell=Farnell frmKonfig.lbAdrFarnell=Address: frmKonfig.lbKeyFarnell=API Key: frmKonfig.lbLandFarnell=Country: frmKonfig.lbRegisterFarnell=Where can I get an API key?\r\n1. Register as a partner: http://partner.element14.com/member/register\r\n2. API Key is offered directly after registration frmKonfig.tabWebMouser=Mouser frmKonfig.lbAdrMouser=Address: frmKonfig.lbKeyMouser=API Key: frmKonfig.lbLandMouser=Country: frmKonfig.lbRegisterMouser=Where can I get an API key?\r\n1. Create an account: https://www.mouser.de/MyMouser/MouserLogin.aspx\r\n2. Here: http://www.mouser.de/apihome/ "Sign Up" even more data enter\r\n3. An "API Verification Code" is sent by email, which is entered into the web interface,\r\nafter which the API key is displayed. frmKonfig.lbWaehrungMouser=Currency: frmParAdrkontakt=Edit address contract frmParAdrkontakt.spNewHint=New entry frmParAdrkontakt.spSaveHint=Save Data frmParAdrkontakt.spAbortHint=Cancel Changes frmParAdrkontakt.spDeleteHint=Delete Data frmParAdrkontakt.lbDatum=Date: frmParAdrkontakt.btnClose=Close frmParAdrkontakt.lbParameter=Parameter No. / Name: frmParAdrkontakt.lbValText=Tab Name: frmParAdrkontakt.lbValInt=Sequence: frmParAdrkontakt.lbValFloat=ValFloat: frmParAdrkontakt.lbValMemo=Text: frmParAdrkontakt.qParamParNr=ParNr frmParAdrkontakt.qParamParName=ParName frmParAdrkontakt.qParamLand=Country frmParAdrkontakt.qParamValInt=Sequence frmParAdrkontakt.qParamValFloat=ValFloat frmParAdrkontakt.qParamValText=Tab Name frmParAdrkontakt.qParamValMemo=Text frmParAdrkontakt.qParamAendDatum=Change Date frmParStatistik=Edit statistik frmParStatistik.spNewHint=New Entry frmParStatistik.spSaveHint=Save Data frmParStatistik.spAbortHint=Cancel Changes frmParStatistik.spDeleteHint=Delete Data frmParStatistik.lbDatum=Date: frmParStatistik.btnClose=Close frmParStatistik.lbParameter=Parameter No. / Name: frmParStatistik.lbValText=SQL-String alternative: frmParStatistik.lbValInt=Sequence: frmParStatistik.lbValFloat=ValFloat: frmParStatistik.lbValMemo=SQL-String: frmParStatistik.qParamParNr=ParNr frmParStatistik.qParamParName=ParName frmParStatistik.qParamLand=Country frmParStatistik.qParamValInt=Sequence frmParStatistik.qParamValFloat=ValFloat frmParStatistik.qParamValText=SQL-String alternative frmParStatistik.qParamValMemo=SQL-String frmParStatistik.qParamAendDatum=Change Date frmTermParam=Terminal Parameter frmTermParam.rgrpPort=COM Port frmTermParam.rgrpBaud=Baudrate frmTermParam.rgrpParity=Parity frmTermParam.rgrpParityItem0=None frmTermParam.rgrpParityItem1=Even frmTermParam.rgrpParityItem2=Odd frmTermParam.rgrpStopBits=Stopbits frmTermParam.lbBaud=Baudrate: frmTermParam.btnCancel=Cancel frmTermParam.btnOK=OK frmTermCustom=Terminal edit translation frmTermCustom.spNewHint=New data translation frmTermCustom.spCopyHint=Copy Data Translation frmTermCustom.spDeleteHint=Delete Data Conversion frmTermCustom.btnOK=OK frmTermCustom.btnCancel=Cancel frmTermCustom.mnVorlAnsi=ANSI frmTermCustom.mnVorlHex=HEX frmTermCustom.mnVorlDez=DEZ frmVersion.memVersion_Größe=Größe frmMain.qAdrIDGUID=IDGUID frmMain.qAdrIDGUIDT=IDGUIDT frmMain.qGehauseIDGUID=IDGUID frmMain.qGehauseIDGUIDT=IDGUIDT frmMain.qKisteIDGUID=IDGUID frmMain.qKisteIDGUIDT=IDGUIDT frmMain.qTypIDGUID=IDGUID frmMain.qTypIDGUIDT=IDGUIDT frmMain.qBauteilIDGUID=IDGUID frmMain.qBauteilIDGUIDT=IDGUIDT frmMain.qBAdrIDGUID=IDGUID frmMain.qBAdrIDGUIDT=IDGUIDT frmMain.qFotoIDGUID=IDGUID frmMain.qFotoIDGUIDT=IDGUIDT frmMain.qBestellIDGUID=IDGUID frmMain.qBestellIDGUIDT=IDGUIDT frmMain.qProjektIDGUID=IDGUID frmMain.qProjektIDGUIDT=IDGUIDT frmMain.qPPosIDGUID=IDGUID frmMain.qPPosIDGUIDT=IDGUIDT frmMain.qHist1IDGUID=IDGUID frmMain.qHist1IDGUIDT=IDGUIDT frmMain.qHistIDGUID=IDGUID frmMain.qHistIDGUIDT=IDGUIDT frmMain.qWissenIDGUID=IDGUID frmMain.qWissenIDGUIDT=IDGUIDT frmMain.qMP3IDGUID=IDGUID frmMain.qMP3IDGUIDT=IDGUIDT frmMain.qAdrKIDGUID=IDGUID frmMain.qAdrKIDGUIDT=IDGUIDT frmMain.qPKostIDGUID=IDGUID frmMain.qPKostIDGUIDT=IDGUIDT frmMain.qPKostPosIDGUID=IDGUID frmMain.qPKostPosIDGUIDT=IDGUIDT frmMain.qPGeraetIDGUID=IDGUID frmMain.qPGeraetIDGUIDT=IDGUIDT frmMain.qPVersIDGUID=IDGUID frmMain.qPVersIDGUIDT=IDGUIDT frmMain.qDokuIDGUID=IDGUID frmMain.qDokuIDGUIDT=IDGUIDT frmMain.qPDokuIDGUID=IDGUID frmMain.qPDokuIDGUIDT=IDGUIDT frmMain.qPGPosIDGUID=IDGUID frmMain.qPGPosIDGUIDT=IDGUIDT frmMain.qHist2IDGUID=IDGUID frmMain.qHist2IDGUIDT=IDGUIDT frmMain.qPGDokuIDGUID=IDGUID frmMain.qPGDokuIDGUIDT=IDGUIDT frmMain.qPGVersIDGUID=IDGUID frmMain.qPGVersIDGUIDT=IDGUIDT frmMain.qPGKostIDGUID=IDGUID frmMain.qPGKostIDGUIDT=IDGUIDT frmMain.qPGKostPosIDGUID=IDGUID frmMain.qPGKostPosIDGUIDT=IDGUIDT frmMain.spBLagerOctopartHint=Open Octopart frmMain.spBLagerArtOctopartHint=Open Octopart frmMain.spBLiefOctopartHint=Open Octopart frmMain.spBauteilOctopartHint=Open Octopart frmMain.spBestellOctopart1Hint=Open Octopart frmMain.spBestellOctopart2Hint=Open Octopart frmBauteil.qryBarcBID=BID frmBauteil.qryBarcBBez=Comp. Descr. frmBauteil.qryBarcBauteil_ID=Component ID frmBauteil.qryBarcGehause_ID=Case ID frmBauteil.qryBarcAdr_ID=Adr ID frmBauteil.qryBarcFoto_ID=Photo ID frmBauteil.qryBarcBezeichnung=Description frmBauteil.qryBarcBarcode=Barcode frmBauteil.qryBarcArtikelNr=Only One Component Per Label frmBauteil.qryBarcArtikelNr2=Item No. 2 frmBauteil.qryBarcSMD=SMD frmBauteil.qryBarcSMD_Text=SMD_Text frmBauteil.qryBarcMenge=Quantity frmBauteil.qryBarcMengeV=Quantity Used frmBauteil.qryBarcMengeMin=Quantity Opened frmBauteil.qryBarcMengeBestellen=Quantity Ordered frmBauteil.qryBarcEinheit=Unit frmBauteil.qryBarcEPreis=Purchase Price frmBauteil.qryBarcGPreis=Total Price frmBauteil.qryBarcVPreis=Sale Price frmBauteil.qryBarcHaltbar=Preserved frmBauteil.qryBarcKiste_ID=Box frmBauteil.qryBarcLagernr=Storage No. frmBauteil.qryBarcArt=Category frmBauteil.qryBarcBWare=BWare frmBauteil.qryBarcRoHS=RoHS frmBauteil.qryBarcBemerkung=Note frmBauteil.qryBarcHandbuch=Manual frmBauteil.qryBarcLibrary=Library frmBauteil.qryBarcKennz=Flag frmBauteil.qryBarcInfo=Info frmBauteil.qryBarcGewicht=Weight frmBauteil.qryBarcAendDatum=Change Date Strings.149=Enter Position in history Strings.150=This component is already noted in the history. Should a new history entry be created for the component? Strings.151=Are you sure you want to run the data integrity check?\r\nThis check automatically corrects the database. frmMain.spSTecDataHint=Tecnical data frmMain.spTypFTecDataHint=Tecnical data frmMain.mnPPTecData=Tecnical data frmMain.mnPPosToHist=Create History Entry frmMain.mnGPTecData=Tecnical data frmMain.mnPGPosToHist=Create History Entry frmCalcR.lbUges1=U&in frmCalcR.lbUfb1=Uou&t frmCalcR.lbV2=V frmCalcR.lbV3=V frmCalcR.lbV4=R frmCalcR.lbV5=R frmCalcR.chkFixUGes1=Fix frmCalcR.chkFixR1=Fix frmCalcR.chkFixR2=Fix frmCalcR.chkFixUFB1=Fix frmKonfig.tabTechData=Tecnical data frmKonfig.lbTechData=List of parameters of the technical data. One parameter per line. frmKonfig.mnCheck=Check Data Integrity frmKonfig.mnMyDesigner=phpMyAdmin Designer frmAdrInline_Lng.qAdrKTelefon2=Telephone 2 frmAdrInline_Lng.qAdrKTelefon=Telephone frmAdrInline_Lng.lbAdrKTel=Telephone frmAdrInline_Lng.qAdrKSWIFT=SWIFT frmAdrInline_Lng.qAdrKStrasse=Street frmAdrInline_Lng.lbAdrKStr=Street frmAdrInline_Lng.qAdrKSkype=Skype frmAdrInline_Lng.spMailK2Hint=Send E-Mail frmAdrInline_Lng.spMailKHint=Send E-Mail frmAdrInline_Lng.qAdrKPrivat=Private frmAdrInline_Lng.chkAdrKPrivat=Private frmAdrInline_Lng.qAdrKName=Name frmAdrInline_Lng.lbAdrKName=Name frmAdrInline_Lng.spAKNewHint=New entry frmAdrInline_Lng.qAdrKLogin=Login frmAdrInline_Lng.qAdrKKunde=Customer frmAdrInline_Lng.chkAdrKKunde=Customer frmAdrInline_Lng.qAdrKInternet=Internet frmAdrInline_Lng.lbAdrKINet=Internet frmAdrInline_Lng.qAdrKInfo=Info frmAdrInline_Lng.qAdrKIDGUIDT=IDGUIDT frmAdrInline_Lng.qAdrKIDGUID=IDGUID frmAdrInline_Lng.qAdrKIBAN=IBAN frmAdrInline_Lng.qAdrKHersteller=Manufactu&rer frmAdrInline_Lng.chkAdrKHerst=Manufactu&rer frmAdrInline_Lng.qAdrKGesperrt=Blocked frmAdrInline_Lng.chkAdrKGesperrt=Blocked frmAdrInline_Lng.lbAdrKGebDatum=Bi&rthday frmAdrInline_Lng.spAKDeleteHint=Delete Data frmAdrInline_Lng.qAdrKfoto_ID=Photo ID frmAdrInline_Lng.qAdrKFirma=Company frmAdrInline_Lng.qAdrKProjekt=P&roject frmAdrInline_Lng.qAdrKFax=Fax frmAdrInline_Lng.lbAdrKFax=Fax frmAdrInline_Lng.qAdrKFacebook=Facebook frmAdrInline_Lng.qAdrKEMail2=EMail2 frmAdrInline_Lng.lbAdrKMail=E-Mail frmAdrInline_Lng.qAdrKEMail=EMail frmAdrInline_Lng.spAKPrintHint=Print frmAdrInline_Lng.lbDatum15=Date: frmAdrInline_Lng.spAKCopyHint=Copy Data frmAdrInline_Lng.qAdrKPLZ=Code frmAdrInline_Lng.qAdrKBank=Bank frmAdrInline_Lng.qAdrKBezeichnung=D&esignation frmAdrInline_Lng.lbAdrKBez=D&esignation frmAdrInline_Lng.spAKSaveHint=Save Data frmAdrInline_Lng.spGeburtstagKHint=Select Date frmSuchTecDataInline_Lng.chkAktiv=Active frmAdrInline_Lng.spAKAbortHint=Cancel Changes frmAdrInline_Lng.qAdrKLieferant=Delivered By frmAdrInline_Lng.chkAdrKLief=Delivered By frmAdrInline_Lng.spHandbuch11Hint=Select Manual (File) frmAdrInline_Lng.oDlg=Select Existing File frmAdrInline_Lng.qAdrKWLanSSID=WLanSSID frmAdrInline_Lng.qAdrKWLanPasswort=WLanPassword frmSuchTecDataInline_Lng.spDelHint=Delete frmAdrInline_Lng.qAdrKUsSTID=VAT ID frmSuchTecDataInline_Lng.rbText=test frmAdrInline_Lng.lbAdrKTel2=Telephone 2 frmAdrInline_Lng.qAdrKLand=Country frmAdrInline_Lng.lbAdrKLand=Country frmAdrInline_Lng.chkAdrKProjekt=Project/History frmAdrInline_Lng.spTelK2Hint=Dial Phone No. frmAdrInline_Lng.spTelKMobHint=Dial Phone No. frmAdrInline_Lng.spTelK1Hint=Dial Phone No. frmAdrInline_Lng.qAdrKHandbuch=Manual frmAdrInline_Lng.lbAdrKHandbuch=Manual frmAdrInline_Lng.spHandbuch11ExecHint=Open Manual frmAdrInline_Lng.spInternetKHint=Open Web Browser frmAdrInline_Lng.qAdrKKundNr=Customer ID frmAdrInline_Lng.lbAdrKKundNr=Customer No. frmAdrInline_Lng.qAdrKMobil=Mobile Phone frmAdrInline_Lng.lbAdrKMobil=Mobile frmAdrInline_Lng.qAdrKOrt=Location frmSuchTecDataInline_Lng.rbZahl=Number frmAdrInline_Lng.spAdrKCpyHint=Copy Address In Clipboard frmAdrInline_Lng.qAdrKKonto=Account frmAdrInline_Lng.qAdrKKontaktArt=ContactType frmAdrInline_Lng.qAdrKBemerkung=Note frmAdrInline_Lng.qAdrKBLZ=BLZ frmAdrInline_Lng.lbAdrKPlz=Postal Code frmAdrInline_Lng.qAdrKPasswort=Pass&word frmAdrInline_Lng.lbAdrKMail2=E-Mail 2 frmAdrInline_Lng.qAdrKAendDatum=Change Date frmAdrInline_Lng.qAdrKGebDatum=Birthday Strings.152=Name already exists. Do you want to jump to the record? Strings.153=Do you really want to run the data integrity check?\r\nThis check automatically corrects the database. Strings.154=Do you really want to integrate this part variant into another one?\r\nThen it is transferred crate/storage and the supplier to the selected part. Strings.155=In the freemium version up to 2 storage bins can be used.\r\nTo use more storage bins To scan more, you should license the Pro version. Strings.156=In the freemium version, related parts cannot be grouped together.\r\nTo use this function To scan more, you should license the Pro version.. Strings.157=Component|"Working Time"|"Small Material"|"Testpoint" Strings.158=This component is still used in projects and therefore cannot be deleted. frmMain.tabBGehause=Case/Variant frmMain.lbBVariCase=&Case frmMain.dbBVariSMD=&SMD frmMain.lbBVarirBez=D&escription frmMain.lbBVariLib=L&ibrary frmMain.lbBVariHersteller=Manufactu&rer frmMain.lbBVariBarcode=B&arcode frmMain.lbBVariGewicht=&Weight frmMain.lbBVariEPreis=&Price frmMain.lbBVarirPinout=Pinout frmMain.lbBVariArtikelNr=Ite&m No. frmMain.lbBVariInfo=Info frmMain.lbBVariMenge=&Quantity frmMain.lbBVariArtikelNr2=Item No. 2 frmMain.lbBVariBWare=BWare frmMain.spBVerwandtHint=Replacement/Related Components frmMain.spBVarKisteHint=Variant box frmMain.tabBKiste=Box/Storage frmMain.spBKNewHint=New entry frmMain.spBKCopyHint=Copy Data frmMain.spBKSaveHint=Save Data frmMain.spBKAbortHint=Cancel Changes frmMain.spBKDeleteHint=Delete Data frmMain.lbDatum29=Date: frmMain.spBKPrintHint=Print frmMain.spBKFachHint=Components In Case / Tray Management frmMain.lbBLSumMenge=Quantity Total: frmMain.spBauteilKisteCalcHint=Calculator frmMain.lbBKGehauseVariante=Variant frmMain.spGotoKisteLagerHint=Go To Store/Case frmMain.lbBKKiste=&Box frmMain.lbBKLagerNr=Stock/&Field frmMain.lbBKMenge=&Quantity frmMain.edKisteManiHint=Stock with a plus / minus manipulate frmMain.btnKisteManiM=- frmMain.btnKisteManiMHint=Stock with a minus manipulate frmMain.btnKisteManiP=+ frmMain.btnKisteManiPHint=Stock with a plus manipulate frmMain.btnBestellBauteil8Hint=Take part in order proposal frmMain.lbBKBezeichnung=D&escription frmMain.lbBKHaltbar=Best Bef&ore frmMain.lbBKHaltbarRest=Time rest: frmMain.lbBKGewicht=&Weight frmMain.lbBKHandbuch=&Manual frmMain.spHandbuch18Hint=Select Manual (File) frmMain.spHandbuch18ExecHint=Open Manual frmMain.spBKInfoEtikettHint=Print Label frmMain.lbBKInfo=Info frmMain.lbBKLagerPosX=Component Description frmMain.lbBKLagerPosY=Y frmMain.lbBKLagerPosZ=Z frmMain.lbBKStatus=Status frmMain.spBKSFreiHint=Enabled frmMain.spBKSGesperrt=D frmMain.spBKSGesperrtHint=Blocked frmMain.spBKSLeeren=E frmMain.spBKSLeerenHint=Clear frmMain.spBKSProjekt=T frmMain.spBKSProjektHint=Project frmMain.spBKSNichtVerwenden=D frmMain.spBKSNichtVerwendenHint=Do Not Use frmMain.lbBKisteBWare=BWare frmMain.lbBLiefEPreisM=&E-Prices By Quantity frmMain.lbBLiefMengeEP=Quantity Per Purchase Price frmMain.spPPosKein=- frmMain.lbPPosVerwandt=Related frmMain.lbPPosVerwandtHint=Related Parts May Be Used frmMain.spHist1BugO=OPL frmMain.spHist1BugOHint=Open Items List frmMain.spPGPosKein=- frmMain.lbPPosVerwandt1=Related frmMain.lbPPosVerwandt1Hint=Related Parts May Be Used frmMain.spHist2BugO=OPL frmMain.spHist2BugOHint=Open Items List frmMain.spBestelltKisteHint=Box From Component frmMain.lbBestInKiste= frmMain.lbAdrPwd=Pass&word frmMain.btnCalcAntenne=Antenna Calculator frmMain.spHistBugO=OPL frmMain.spHistBugOHint=Open Items List frmMain.btnDebugSqlNew=+ SQL Tab frmMain.btnLiz=Pro Licensing frmMain.qBVariBauteil_ID=Component frmMain.qBVariFoto_ID=Photo ID frmMain.qBVariBezeichnung=Designation frmMain.qBVariArtikelNr=Item No. frmMain.qBVariGehause=Case frmMain.qBVariGehause_ID=Case frmMain.qBVariMenge=Quantity frmMain.qBVariMengeMin=Min Quantity frmMain.qBVariMengeBestellen=Quantity Ordered frmMain.qBVariProjSum=ec frmMain.qBVariEPreis=Price frmMain.qBVariVPreis=VPrice frmMain.qBVariSMD=SMD frmMain.qBVariSMD_Text=SMD_Text frmMain.qBVariPinout=Pinout frmMain.qBVariArt=Category frmMain.qBVariRoHS=RoHS frmMain.qBVariBemerkung=Note frmMain.qBVariHandbuch=Manual frmMain.qBVariAdr=Adr frmMain.qBVariAdr_ID=Manufacturer frmMain.qBVariLibrary=Library frmMain.qBVariBWare=BWare frmMain.qBVariKennz=Flag frmMain.qBVariGewicht=Weight frmMain.qBVariGehGewicht=Weight (Case) frmMain.qBVariGehSMD=SMD (case) frmMain.qBVariBarcode=Barcode frmMain.qBVariArtikelNr2=Item No. 2 frmMain.qBVariInfo=Info frmMain.qBVariVerwandt=Related frmMain.qBVariBauteilVerwandt_ID=Component Related ID frmMain.qBVariAendDatum=Change Date frmMain.qBVariIDGUID=IDGUID frmMain.qBVariIDGUIDT=IDGUIDT frmMain.qBVariTecData=Tecnical data frmMain.qBVariGeloescht=Deleted frmMain.qBVariEinheit=Unit frmMain.qBAdrBauteilVariante=Variant frmMain.qBAdrBauteilVariante_ID=Variant ID frmMain.qBAdrEPreisM=Price M frmMain.qBAdrMengeEP=Quantity Purchase Price frmMain.qSuchVID=LID frmMain.qSuchVBez=Variant Comment frmMain.qSuchVBemerk=Variant Comment frmMain.qSuchVInfo=VInfo frmMain.qSuchPinout=Pinout frmMain.qSuchEinheit=Unit frmMain.qSuchVAendDatum=Variant date frmMain.qBestellFracht=Cargo frmMain.qBestellBauteilVariante=Variant frmMain.qBestellBauteilVariante_ID=Variant ID frmMain.qBestellBauteilKiste_ID=Component Box frmMain.qProjektBauteilVariante_ID=Variant frmMain.qProjektKiste_ID=Box frmMain.qPPosBauteilVariante=Variant frmMain.qPPosBauteilVariante_ID=Variant ID frmMain.qPPosVerwandt=Related frmMain.qPPosVArtikelNr=Related Item No. 1 frmMain.qPPosVBarcode=Related Barcode frmMain.qPPosVArtikelNr2=Related Item No. 2 frmMain.qPPosVArt=Related Type frmMain.qPPosVHersteller=VProducer frmMain.qPPosVPinout=VPinout frmMain.mnPPKisteBauteil=Box From Component frmMain.mnBauteilZusammenfassen=Summarize variant frmMain.qBBestellBauteilVariante_ID=Variant frmMain.qBProjektBauteilVariante_ID=Variant frmMain.qKisteBLagerPosX=Stock pos X frmMain.qKisteBLagerPosY=Stock pos Y frmMain.qKisteBLagerPosZ=Stock pos Z frmMain.qPBestellBauteilVariante_ID=Stock/case frmMain.qPKostPosBauteilVariante_ID=Component Variant frmMain.qBBewBauteilVariante_ID=Component Variant frmMain.qBBewBauteilKiste_ID=Component Box frmMain.qBBewFracht=Cargo frmMain.qBBewEPreis=Price frmMain.qBBewIDGUID=IDGUID frmMain.qBBewIDGUIDT=IDGUIDT frmMain.qBBewGeloescht=Deleted frmMain.qAdrB1BauteilVariante_ID=Variant frmMain.qPGeraetBauteilVariante_ID=Variant frmMain.qPGeraetKiste_ID=Box frmMain.qPVersBauteilVariante=Variant frmMain.qPVersBauteilVariante_ID=Variant ID frmMain.qPVersBBauteilVariante_ID=Variant frmMain.qPPosVBBauteilVariante_ID=Variant frmMain.qPDokuBauteilVariante=Variant frmMain.qPDokuBauteilVariante_ID=Variant ID frmMain.qDokuBBauteilVariante_ID=Variant frmMain.qPGPosBauteilVariante=Variant frmMain.qPGPosBauteilVariante_ID=Variant ID frmMain.qPGPosVEinheit=Unit frmMain.qPGPosVerwandt=Related frmMain.qPGPosVArtikelNr=Store item No. frmMain.qPGPosVBarcode=Store Barcode frmMain.qPGPosVArtikelNr2=Store item No. 2 frmMain.qPGPosVArt=StoreArt frmMain.qPGPosVHersteller=VProducer frmMain.qPGPosVPinout=VPinout frmMain.qPGDokuBauteilVariante=Variant frmMain.qPGDokuBauteilVariante_ID=Variant ID frmMain.qPGVersBauteilVariante=Variant frmMain.qPGVersBauteilVariante_ID=Variant ID frmMain.qPGKostPosBauteilVariante_ID=Component Variant frmMain.qPGBestellBauteilVariante_ID=Variant frmMain.qPGVersBBauteilVariante_ID=Variant frmMain.qPGPosVBBauteilVariante_ID=Variant frmMain.mnPGPKisteBauteil=Box From Component frmMain.qBKisteBauteil_ID=Component ID frmMain.qBKisteBauteilVariante_ID=Component Variant ID frmMain.qBKisteKiste_ID=Box frmMain.qBKisteFoto_ID=Photo ID frmMain.qBKisteProjekt_ID=Project frmMain.qBKisteBezeichnung=Designation frmMain.qBKisteStatus=Status frmMain.qBKisteMenge=Quantity frmMain.qBKisteMengeV=Quantity Used frmMain.qBKisteMengeMin=Min Quantity frmMain.qBKisteMengeRes=Quantity Remained frmMain.qBKisteReserviertD=ReservedD frmMain.qBKisteHaltbar=Preserved frmMain.qBKisteLagernr=Stock No. frmMain.qBKisteLagerPosX=Stock pos X frmMain.qBKisteLagerPosY=Stock pos Y frmMain.qBKisteLagerPosZ=Stock pos Z frmMain.qBKisteBWare=BWare frmMain.qBKisteBemerkung=Note frmMain.qBKisteHandbuch=Manual frmMain.qBKisteKennz=Flag frmMain.qBKisteInfo=Info frmMain.qBKisteGewicht=Weight frmMain.qBKisteBarcode=Barcode frmMain.qBKisteGeloescht=Deleted frmMain.qBKisteAendDatum=Change Date frmMain.qBKisteIDGUID=IDGUID frmMain.qBKisteIDGUIDT=IDGUIDT frmBestellMin.qryVID=LID frmBestellMin.qryVBez=Variant Comment frmDruckEtikett.chkGrpFelderItem7=Case frmDruckEtikett.chkGrpFelderItem8=Item No. frmDruckEtikett.chkGrpFelderItem9=Only One Component Per Label frmDruckEtikett.chkGroupBy=Grouping Based On frmDruckEtikett.chkGroupByItem0=Stock/Field frmDruckEtikett.chkGroupByItem1=Component Description frmDruckEtikett.chkGroupByItem2=Stock/case description frmDruckEtikett.chkGroupByItem3=Case frmDruckEtikett.qDataLagerPosX=PosX frmDruckEtikett.qDataLagerPosY=PosY frmDruckEtikett.qDataLagerPosZ=PosZ frmKisteTausch.qInhaltVBez=Variant Description frmKisteTausch.qBauteilVID=LID frmKisteTausch.qBauteilKID=KID frmKisteTausch.qBauteilVariBez=Variant Descr. frmKisteTausch.qBauteilKBez=Box Descr. frmKisteTausch.qBauteilLagerPosX=Stock pos X frmKisteTausch.qBauteilLagerPosY=Stock pos Y frmKisteTausch.qBauteilLagerPosZ=Stock pos Z frmKisteTauschDlg.lbLagerNr1=Stock pos &X frmKisteTauschDlg.lbLagerNr2=Stock pos &Y frmKisteTauschDlg.lbLagerNr3=Stock pos &Z frmCalcR.lbTest=Against Test: frmSchnell.qMem_VID=VID frmCalcLambda=Antenna calculator lambda <> frequency frmCalcLambda.lbFreq=Frequency frmCalcLambda.lbLambda1=λ (Lambda, Wavelength) frmCalcLambda.lbLambda2=λ 1/2 frmCalcLambda.lbLambda4=λ 1/4 frmCalcLambda.lbLambda8=λ 1/8 frmCalcLambda.lbLambda16=λ 1/16 frmCalcLambda.btnClose=Close frmAuswahl.lbAnzahl=Quantity To Order: frmAuswahl.qryBVID=LID frmAuswahl.qryBVFID=VFID frmAuswahl.qryBVBez=Variant Comment frmAuswahl.qryHIDGUID=IDGUID frmAuswahl.qryHIDGUIDT=IDGUIDT frmAuswahl.qryHFoto_ID=Photo ID frmAuswahl.qryHBezeichnung=Designation frmAuswahl.qryHNummer=Number frmAuswahl.qryHPosX=PosX frmAuswahl.qryHPosY=PosY frmAuswahl.qryHLagerort=Location frmAuswahl.qryHGroesse=Size frmAuswahl.qryHBemerkung=Note frmAuswahl.qryHHandbuch=Manual frmAuswahl.qryHInfo=Info frmAuswahl.qryHBarcode=Barcode frmAuswahl.qryHParEtikett=ParLabel frmAuswahl.qryHGeloescht=Deleted frmAuswahl.qryHAendDatum=Change Date frmAuswahl.qryLagerPosIDGUID=IDGUID frmAuswahl.qryLagerPosIDGUIDT=IDGUIDT frmAuswahl.qryLagerPosBauteil_ID=Component ID frmAuswahl.qryLagerPosBauteilVariante_ID=Component Variant ID frmAuswahl.qryLagerPosKiste_ID=Box ID frmAuswahl.qryLagerPosFoto_ID=Photo ID frmAuswahl.qryLagerPosProjekt_ID=Project ID frmAuswahl.qryLagerPosKBez=Box Descr. frmAuswahl.qryLagerPosBezeichnung=Designation frmAuswahl.qryLagerPosMenge=Quantity frmAuswahl.qryLagerPosMengeRes=Quantity Remained frmAuswahl.qryLagerPosMengeV=Quantity Used frmAuswahl.qryLagerPosMengeMin=Min Quantity frmAuswahl.qryLagerPosStatus=Status frmAuswahl.qryLagerPosReserviertD=ReservedD frmAuswahl.qryLagerPosHaltbar=Preserved frmAuswahl.qryLagerPosLagernr=Stock No. frmAuswahl.qryLagerPosLagerPosX=Stock pos X frmAuswahl.qryLagerPosLagerPosY=Stock pos Y frmAuswahl.qryLagerPosLagerPosZ=Stock pos Z frmAuswahl.qryLagerPosBWare=BWare frmAuswahl.qryLagerPosBemerkung=Note frmAuswahl.qryLagerPosHandbuch=Manual frmAuswahl.qryLagerPosKennz=Flag frmAuswahl.qryLagerPosInfo=Info frmAuswahl.qryLagerPosGewicht=Weight frmAuswahl.qryLagerPosBarcode=Barcode frmAuswahl.qryLagerPosGeloescht=Deleted frmAuswahl.qryLagerPosAendDatum=Change Date frmAuswahl.qryIIDGUID=IDGUID frmAuswahl.qryIIDGUIDT=IDGUIDT frmAuswahl.qryIBauteil_ID=Component ID frmAuswahl.qryIBauteilVariante_ID=Component Variant ID frmAuswahl.qryIKiste_ID=Box ID frmAuswahl.qryIFoto_ID=Photo ID frmAuswahl.qryIProjekt_ID=Project ID frmAuswahl.qryIKBez=Box frmAuswahl.qryILagernr=Stock No. frmAuswahl.qryILagerPosX=Stock pos X frmAuswahl.qryILagerPosY=Stock pos Y frmAuswahl.qryILagerPosZ=Stock pos Z frmAuswahl.qryIMenge=Quantity frmAuswahl.qryIMengeRes=Quantity Remained frmAuswahl.qryIMengeV=Quantity Used frmAuswahl.qryIMengeMin=Min Quantity frmAuswahl.qryIStatus=Status frmAuswahl.qryIBezeichnung=Designation frmAuswahl.qryIReserviertD=ReservedD frmAuswahl.qryIHaltbar=Preserved frmAuswahl.qryIKNummer=Box No. frmAuswahl.qryIKPosX=Box PosX frmAuswahl.qryIKPosY=Box PosY frmAuswahl.qryIKLagerort=Box Storage Location frmAuswahl.qryIBWare=BWare frmAuswahl.qryIBemerkung=Note frmAuswahl.qryIHandbuch=Manual frmAuswahl.qryIKennz=Flag frmAuswahl.qryIInfo=Info frmAuswahl.qryIGewicht=Weight frmAuswahl.qryIBarcode=Barcode frmAuswahl.qryIGeloescht=Deleted frmAuswahl.qryIAendDatum=Change Date frmAuswahl.qryIKFoto_ID=KFoto_ID frmKonfig.lbScalForm=Scale Form frmKonfig.lbScalForm1=100..150% frmKonfig.lbWebabfrage=The deliverer can show the status from teh component frmKonfig.mnForeignKey=Create Foreign Key frmBauteil.qryLBewBauteilVariante_ID=Component Variant ID frmKisteTauschFach=Stock/Field frmKisteTauschFach.lbKiste=Box frmKisteTauschFach.lbLagerNr=Stock/Field frmKisteTauschFach.lbLagerPosX=Component Description frmKisteTauschFach.lbLagerPosY=Stock/case description frmKisteTauschFach.lbLagerPosZ=Case frmKisteTauschFach.btnOK=OK frmKisteTauschFach.btnCancel=Cancel frmLizenzierung=Licensing Pro version frmLizenzierung.tabLicAntrag=Request Pro License frmLizenzierung.btnWeiter1=Next frmLizenzierung.btnCancel=Cancel frmLizenzierung.lbFirma=Company frmLizenzierung.lbName=Name * frmLizenzierung.lbOrt=Postal Code * frmLizenzierung.lbStrasse=Street * frmLizenzierung.lbEMail=E-Mail * frmLizenzierung.lbLand=Country * frmLizenzierung.lbUsStID=VAT ID frmLizenzierung.tabLicSend=Request Pro License frmLizenzierung.btnSpeichern=Save frmLizenzierung.btnCancel1=Cancel frmLizenzierung.btnZuruck=Back frmLizenzierung.lbInfo=Copy Text And Email To elela@mmvisual.de. frmLizenzierung.tabLicAktiv=Licensing active frmLizenzierung.lbFirma1=Company frmLizenzierung.lbName1=Name frmLizenzierung.lbOrt1=Postal Code frmLizenzierung.lbStrasse1=Street frmLizenzierung.lbEMail1=E-Mail frmLizenzierung.lbLand1=Country frmLizenzierung.lbEMail2=License number frmLizenzierung.lbUsStID1=VAT ID frmLizenzierung.btnClose=Close frmLizenzierung.tabLic=Licenses frmLizenzierung.btnClose1=Close frmLizenzierung.btnLoad=Load lic frmLizenzierung.btnMake=Create frmLizenzierung.btnSaveLic=Save License frmLizenzierung.qParIDGUID=IDGUID frmLizenzierung.qParIDGUIDT=IDGUIDT frmLizenzierung.qParParNr=ParNr frmLizenzierung.qParParName=ParName frmLizenzierung.qParLand=Country frmLizenzierung.qParValFloat=ValFloat frmLizenzierung.qParGeloescht=Deleted frmLizenzierung.qParAendDatum=Change Date frmLizenzierung.SDlg=Save File As frmLizenzierung.qEleLaLicIDGUID=IDGUID frmLizenzierung.qEleLaLicIDGUIDT=IDGUIDT frmLizenzierung.qEleLaLicFirma=Company frmLizenzierung.qEleLaLicName=Name frmLizenzierung.qEleLaLicStrasse=Street frmLizenzierung.qEleLaLicOrt=Location frmLizenzierung.qEleLaLicLand=Country frmLizenzierung.qEleLaLicEMail=E-Mail frmLizenzierung.qEleLaLicUsStID=VAT ID frmLizenzierung.qEleLaLicDB=DB frmLizenzierung.qEleLaLicKdNr=Customer No. frmLizenzierung.qEleLaLicLizenz=License frmLizenzierung.qEleLaLicBemerkung=Note frmLizenzierung.qEleLaLicStatus=Status frmLizenzierung.qEleLaLicInfo=Info frmLizenzierung.qEleLaLicKennz=Flag frmLizenzierung.qEleLaLicGeloescht=Deleted frmLizenzierung.qEleLaLicAendDatum=Change Date frmLizenzierung.ODlg=Open License File frmLizenzierung.SDlgL=Create License File Strings.159=This function automatically generates a barcode for ALL crate/warehouse entries if the entry does not already have a barcode. frmMain.spBKBarFormatHint=Barcode frmMain.lbBKBarcode=B&arcode frmMain.qSuchLBarcode=SBarcode frmMain.mnBKBarcodeErzeuge=Generate Barcode Store frmMain.tabSQL1=SQL 1 frmLizenzierung.qParValInt=ValInt frmLizenzierung.qParValText=ValText frmLizenzierung.qParValMemo=ValMemo Strings.160=Individual devices are assigned to this project and therefore cannot be deleted. Strings.161=Do you really want to run the check of the images?\r\nThis check automatically deletes unused images. Strings.162=Do you really want to reduce the size of the database?\r\neverything should be backed up BEFORE! frmMain.tabPEinzelgeraet=Single device frmMain.spPENewHint=New Entry frmMain.spPECopyHint=Copy Data frmMain.spPESaveHint=Save Data frmMain.spPEAbortHint=Cancel Changes frmMain.spPEDeleteHint=Delete Data frmMain.spPEPrintHint=Print frmMain.spFilterPEinzelHint=Filter By Single Device frmMain.edSchnellsuchePEinzelHint=Quick Search frmMain.lbPEAdrKont=&Address/Contact frmMain.spGotoAdrPEHint=Go to Address frmMain.lbPEStatus=Status frmMain.spPE1=A frmMain.spPE1Hint=&Offer frmMain.spPE2=OS frmMain.spPE2Hint=Offer Sent frmMain.spPE3=B frmMain.spPE3Hint=Ordered frmMain.spPE4=D frmMain.spPE4Hint=Delivered frmMain.spPE5Hint=Ready frmMain.spPE6=V frmMain.spPE6Hint=Scrapped frmMain.spPEFilterHint=Filter By Current Status frmMain.spPEinzelInfoEtikettHint=Print Label frmMain.lbPEInfo=Info frmMain.lbPESN=Serial numbe&r frmMain.lbPEGerateNr=Devi&ce No. frmMain.spPE0=E frmMain.spPE0Hint=Store frmMain.lbPEProjekt=&Project/Device frmMain.spPEinzelDet=▼ frmMain.lbPEBauteil=&Component frmMain.spPEBauteilHint=Select Component frmMain.spGotoBauteil11Hint=Go To Component frmMain.lbPELagCase=Case/Variant frmMain.spGotoBauteilLG11Hint=Go To Store/Case frmMain.spPEFilterBauteilHint=Filter By Variant frmMain.spPEFilterProjektHint=Filter By Variant frmMain.spGotoProjekt3Hint=Go To Project frmMain.spHandbuch21ExecHint=Open Manual frmMain.spHandbuch21Hint=Select Manual (File) frmMain.lbPEHandbuch=&Manual frmMain.spPEBarFormatHint=Barcode frmMain.lbPEBarcode=B&arcode frmMain.lbPEBearb=Edited frmMain.spPEBearbHint=Select Date frmMain.spPEPruefHint=Select Date frmMain.lbPEPruef=Inspection frmMain.lbPEService=Service frmMain.spPEServiceHint=Select Date frmMain.lbPELief=Delivered frmMain.spPELiefHint=Select Date frmMain.lbPEVariante=Variant frmMain.lbPEVersion=Version frmMain.lbPEBez=&Description frmMain.chkTerminEinzelgeraet=&Devices frmMain.mnBEinzelgerat=Single device create frmMain.mnBEinzelgeratGo=Single device show frmMain.mnPEinzelgerat=Single device create frmMain.mnPEinzelgeratGo=Single device show frmMain.mnPGEinzelgerat=Single device create frmMain.mnPGEinzelgeratGo=Single device show frmMain.qPEinzelProjekt=Project frmMain.qPEinzelProjekt_ID=Project frmMain.qPEinzelBauteil=Component frmMain.qPEinzelBauteil_ID=Component frmMain.qPEinzelBauteilVariante=Component Variant frmMain.qPEinzelBauteilVariante_ID=Component Variant frmMain.qPEinzelAdr=Adr frmMain.qPEinzelAdr_ID=Adr frmMain.qPEinzelAdrK=AdrK frmMain.qPEinzelAdrK_ID=AdrK frmMain.qPEinzelKosten=Costs frmMain.qPEinzelKosten_ID=Prices frmMain.qPEinzelKostenPos=Cost Pos frmMain.qPEinzelKostenPos_ID=Cost Pos frmMain.qPEinzelFoto_ID=Photo ID frmMain.qPEinzelStatus=Status frmMain.qPEinzelBezeichnung=Designation frmMain.qPEinzelBemerkung=Note frmMain.qPEinzelMenge=Quantity frmMain.qPEinzelEPreis=Price frmMain.qPEinzelRabatt=Discount frmMain.qPEinzelGPreis=Total Price frmMain.qPEinzelVariante=Variant frmMain.qPEinzelArtikelNr=Item No. frmMain.qPEinzelBarcode=Barcode frmMain.qPEinzelSNr=Serial No. frmMain.qPEinzelGNr=G No. frmMain.qPEinzelFDatum=RDate frmMain.qPEinzelFVersion=RVersion frmMain.qPEinzelBearbeiter=Editor frmMain.qPEinzelBearbeiterD=EditorD frmMain.qPEinzelPruefer=Inspector frmMain.qPEinzelPrueferD=InspectorD frmMain.qPEinzelDLief=De&livery frmMain.qPEinzelService=Service frmMain.qPEinzelServiceD=ServiceD frmMain.qPEinzelHandbuch=Manual frmMain.qPEinzelInfo=Info frmMain.qPEinzelKennz=Flag frmMain.qPEinzelOptA=Opt. A frmMain.qPEinzelOptB=Opt. B frmMain.qPEinzelOptC=Opt. C frmMain.qPEinzelAendDatum=Change Date frmMain.qPEinzelIDGUID=IDGUID frmMain.qPEinzelIDGUIDT=IDGUIDT frmMain.mnPEBarcGen=Create Barcode frmMain.mnPEBarcFilter=Filter By Barcode frmKonfig.lbProjAuftFormat=Project Commission Format frmKonfig.lbPEBarFormat=Individual Projects Barcode Format frmKonfig.mnCheckFoto=Check Unused Images frmKonfig.mnVaccuumDB=VACUUM Database frmKonfig.mnMsSQLFeld=Check MsSQL fields frmEinzelgeratErz=Create single device frmEinzelgeratErz.lbProjGerat=Project/Device frmEinzelgeratErz.lbBauteil=Component frmEinzelgeratErz.lbBVariante=Variant frmEinzelgeratErz.lbAnzahl=Quantity Of Single Devices frmEinzelgeratErz.chkGenBarcode=Generate Barcode frmEinzelgeratErz.lbVersion=Version frmEinzelgeratErz.lbVariante=Variant frmEinzelgeratErz.lbBearbeitet=Edited frmEinzelgeratErz.btnOK=Create frmEinzelgeratErz.btnCancel=Cancel frmMain.spBKSFrei=R frmMain.spPPosFertig=R frmMain.spHist1BugF=R frmMain.spHist1Fertig=R frmMain.spPPDokuFreigabe=R frmMain.spPVersFreigabe=R frmMain.spPKSFertig=R frmMain.spPKPFertig=R frmMain.spPGPosFertig=R frmMain.spHist2BugF=R frmMain.spHist2Fertig=R frmMain.spPGDokuFreigabe=R frmMain.spPGVersFreigabe=R frmMain.spPGKSFertig=R frmMain.spPGKPFertig=R frmMain.spPDokuFreigabe=R frmMain.spHistBugF=R frmMain.spHistFertig=R frmBestellAenderung.spBestEingelagert=S frmMain.spPE5=R Strings.163=In the freemium version up to 2 2D scans can be performed./r/nTo scan more, you should license the Pro version. frmMain.spBestelltScannerHint=2D Code Scan frmMain.lbCaseFootprint=Librar&yRef frmMain.spCaseLibRefHint=Select Library Ref. frmMain.qAdrOptZ=Opt. Z frmMain.qAdrOptQ=Opt. Q frmMain.qAdrBewertung=Rating frmMain.qAdrBewDatum=Rating Date frmMain.qAdrUpdateDatum=UpdateDate frmMain.qAdrZNummer=Customs No. frmMain.qAdrZType=Customs type frmMain.qGehauseLibraryRef=LibraryRef frmMain.qBauteilLibraryRef=LibraryRef frmMain.qBVariBezKurz=Descr. Short frmMain.qBVariLibraryRef=LibraryRef frmMain.qBVariZNummer=Customs No. frmMain.qBVariZHersteller=Customs Manufacturer frmMain.qBVariZULand=Customs Country Of Origin frmMain.qBVariZURegion=Customs Origin Region frmMain.mnDBAltiumSQL=CAD AltiumView Create SQL frmMain.mnPProjKiste=Prefered Project Box frmMain.mnPPProjKiste=Prefered Project Box frmMain.mnLGBarcDruck=Print 2D Barcode frmMain.qAdrKOptZ=Opt. Z frmMain.qAdrKOptQ=Opt. Q frmMain.qPKostPosLZNummer=LCustoms number frmMain.qPKostPosLZHersteller=LCustomsManufacturer frmMain.qPKostPosLZULand=LCustomsCountryOfOrigin frmMain.qPKostPosLZURegion=LCustomsOriginRegion frmMain.qPGKostPosLZNummer=LCustoms number frmMain.qPGKostPosLZHersteller=LCustomsManufacturer frmMain.qPGKostPosLZULand=LCustomsCountryOfOrigin frmMain.qPGKostPosLZURegion=LCustomsOriginRegion frmPPosTest.tabProjekt=Project frmPPosTest.tabLagerort=Location frmPPosTest.panLagerort=Selection of storage locations from which the components may be removed. frmPPosTest.tabBauteil=Component frmPPosTest.qPBauteilBID=BID frmPPosTest.qPBauteilVID=LID frmPPosTest.qPBauteilBBez=Component frmPPosTest.qPBauteilVBez=Variant frmPPosTest.qPBauteilCBez=Case frmPPosTest.qPBauteilLMenge=Stocks frmPPosTest.qPBauteilPMenge=Pos Quantity frmPPosTest.qPBauteilLMengeRest=Store rest frmPPosTest.qPBauteilCanVerwandt=Related Allowed frmPPosTest.qPBauteilMengeVerwandt=Quantity Related frmPPosTest.qPBauteilMengeBestellt=Quantity Ordered frmPPosTest.qPBauteilBarcode=Barcode frmPPosTest.qPBauteilArtikelNr=Item No. frmPPosTest.qPBauteilArtikelNr2=Item No. 2 frmPPosTest.qProjID_ID_Version=ID_ID_Version frmPPosTest.qProjProjektVersion_ID=Project Version ID frmPPosTest.qProjTyp=Type frmPPosTest.qProjBezeichnung=Designation frmPPosTest.qProjBeschreibung=Text frmPPosTest.qProjMengeOffen=Quantity Opened frmPPosTest.qProjVariante=Variant frmPPosTest.qProjVBez=Version Desc. frmPPosTest.qProjVersion=Version frmPPosTest.qProjRevision=Revision frmPPosTest.qProjStatus=Status frmPPosTest.qProjVarianteAll=All Variants frmBauteilErzeuge.lbKiste=&Box frmAdrInline_Lng.qAdrKOptZ=Opt. Z frmAdrInline_Lng.qAdrKOptQ=Opt. Q frmMain.spFilterGehVarianteHint=Filter By Housing/Variant frmMain.spPGFilterGehVarianteHint=Filter By Housing/Variant frmMain.spBestEingelagert=S frmMain.mn2DDruck=Print 2D Barcode Strings.51= Strings.52= Strings.53= frmBildSize=Picture size frmBildSize.lbTxt=The image is very large and should be reduced in size so that it does not require too much memory when optimized to the desired resolution.\r\nSize: %1\r\nTo what size should it be reduced? frmBildSize.rb64=<= 64KB frmBildSize.rb128=<= 128KB frmBildSize.rb192=<= 192KB frmBildSize.Button1=OK frmBildSize.btnCancel=Cancel frmMain.edBLMengeHint= frmMain.lbDInfoTranslatedBy= frmStatus.rGrp= frmTypAuswahl.panWithSubItems= frmAuswahl.panMiddleMain= frmAuswahl.panMiddleKiste= frmAuswahl.panKisteBild= frmAuswahl.panTecData= frmKonfig.rgrpLanguage= frmAdrInline_Lng.panAdrKMain= frmAdrInline_Lng.panAdrDet1= frmAdrInline_Lng.panTopAdrK= frmAdrInline_Lng.panAdrKontaktBild= frmBildSize.panBtn= frmBildSize.rb1024=<= 1MB Strings.164=n.v. EleLa frmMain.chkBProjektAkt=Only The Current Project frmMain.spBestStorno=X frmMain.spBestStornoHint=Canceled frmMain.mnPPSetBauteil=Set component/case/variant frmMain.mnDruckInfo=Print Label "Info" frmMain.mnDruckInfo2=Print Label "Info" frmMain.mnPopExportCsv=Export In CSV Format frmMain.qBBewAuftrag=Commission frmMain.qBKisteLagerort=Location frmMain.qLagerBestellIDGUID=IDGUID frmMain.qLagerBestellIDGUIDT=IDGUIDT frmMain.qLagerBestellBauteil_ID=Component frmMain.qLagerBestellBauteilVariante_ID=Component Variant frmMain.qLagerBestellKiste_ID=Box ID frmMain.qLagerBestellKBez=Box frmMain.qLagerBestellLagernr=Stock No. frmMain.qLagerBestellLagerPosX=Stock pos X frmMain.qLagerBestellLagerPosY=Stock pos Y frmMain.qLagerBestellLagerPosZ=Stock pos Z frmMain.qLagerBestellLagerort=Location frmMain.qLagerBestellFoto_ID=Photo ID frmMain.qLagerBestellProjekt_ID=Project frmMain.qLagerBestellBezeichnung=Designation frmMain.qLagerBestellMenge=Quantity frmMain.qLagerBestellMengeRes=Quantity Remained frmMain.qLagerBestellMengeV=Quantity Used frmMain.qLagerBestellMengeMin=Min Quantity frmMain.qLagerBestellStatus=Status frmMain.qLagerBestellReserviertD=ReservedD frmMain.qLagerBestellHaltbar=Preserved frmMain.qLagerBestellBWare=BWare frmMain.qLagerBestellBemerkung=Note frmMain.qLagerBestellHandbuch=Manual frmMain.qLagerBestellKennz=Flag frmMain.qLagerBestellInfo=Info frmMain.qLagerBestellGewicht=Weight frmMain.qLagerBestellBarcode=Barcode frmMain.qLagerBestellGeloescht=Deleted frmMain.qLagerBestellAendDatum=Change Date frmMain.qLagerPPosIDGUID=IDGUID frmMain.qLagerPPosIDGUIDT=IDGUIDT frmMain.qLagerPPosBauteil_ID=Component frmMain.qLagerPPosBauteilVariante_ID=Component Variant frmMain.qLagerPPosKiste_ID=Box ID frmMain.qLagerPPosKBez=Box frmMain.qLagerPPosLagernr=Stock No. frmMain.qLagerPPosLagerPosX=Stock pos X frmMain.qLagerPPosLagerPosY=Stock pos Y frmMain.qLagerPPosLagerPosZ=Stock pos Z frmMain.qLagerPPosLagerort=Location frmMain.qLagerPPosFoto_ID=Photo ID frmMain.qLagerPPosProjekt_ID=Project frmMain.qLagerPPosBezeichnung=Designation frmMain.qLagerPPosMenge=Quantity frmMain.qLagerPPosMengeRes=Quantity Remained frmMain.qLagerPPosMengeV=Quantity Used frmMain.qLagerPPosMengeMin=Min Quantity frmMain.qLagerPPosStatus=Status frmMain.qLagerPPosReserviertD=ReservedD frmMain.qLagerPPosHaltbar=Preserved frmMain.qLagerPPosBWare=BWare frmMain.qLagerPPosBemerkung=Note frmMain.qLagerPPosHandbuch=Manual frmMain.qLagerPPosKennz=Flag frmMain.qLagerPPosInfo=Info frmMain.qLagerPPosGewicht=Weight frmMain.qLagerPPosBarcode=Barcode frmMain.qLagerPPosGeloescht=Deleted frmMain.qLagerPPosAendDatum=Change Date frmMain.qLagerPGPosIDGUID=IDGUID frmMain.qLagerPGPosIDGUIDT=IDGUIDT frmMain.qLagerPGPosBauteil_ID=Component frmMain.qLagerPGPosBauteilVariante_ID=Component Variant frmMain.qLagerPGPosKiste_ID=Box ID frmMain.qLagerPGPosKBez=Box frmMain.qLagerPGPosLagernr=Stock No. frmMain.qLagerPGPosLagerPosX=Stock pos X frmMain.qLagerPGPosLagerPosY=Stock pos Y frmMain.qLagerPGPosLagerPosZ=Stock pos Z frmMain.qLagerPGPosLagerort=Location frmMain.qLagerPGPosFoto_ID=Photo ID frmMain.qLagerPGPosProjekt_ID=Project frmMain.qLagerPGPosBezeichnung=Designation frmMain.qLagerPGPosMenge=Quantity frmMain.qLagerPGPosMengeRes=Quantity Remained frmMain.qLagerPGPosMengeV=Quantity Used frmMain.qLagerPGPosMengeMin=Min Quantity frmMain.qLagerPGPosStatus=Status frmMain.qLagerPGPosReserviertD=ReservedD frmMain.qLagerPGPosHaltbar=Preserved frmMain.qLagerPGPosBWare=BWare frmMain.qLagerPGPosBemerkung=Note frmMain.qLagerPGPosHandbuch=Manual frmMain.qLagerPGPosKennz=Flag frmMain.qLagerPGPosInfo=Info frmMain.qLagerPGPosGewicht=Weight frmMain.qLagerPGPosBarcode=Barcode frmMain.qLagerPGPosGeloescht=Deleted frmMain.qLagerPGPosAendDatum=Change Date frmMain.qLagerBVarIDGUID=IDGUID frmMain.qLagerBVarIDGUIDT=IDGUIDT frmMain.qLagerBVarBauteil_ID=Component frmMain.qLagerBVarBauteilVariante_ID=Component Variant frmMain.qLagerBVarKiste_ID=Box ID frmMain.qLagerBVarKBez=Box frmMain.qLagerBVarLagernr=Stock No. frmMain.qLagerBVarLagerPosX=Stock pos X frmMain.qLagerBVarLagerPosY=Stock pos Y frmMain.qLagerBVarLagerPosZ=Stock pos Z frmMain.qLagerBVarLagerort=Location frmMain.qLagerBVarFoto_ID=Photo ID frmMain.qLagerBVarProjekt_ID=Project frmMain.qLagerBVarBezeichnung=Designation frmMain.qLagerBVarMenge=Quantity frmMain.qLagerBVarMengeRes=Quantity Remained frmMain.qLagerBVarMengeV=Quantity Used frmMain.qLagerBVarMengeMin=Min Quantity frmMain.qLagerBVarStatus=Status frmMain.qLagerBVarReserviertD=ReservedD frmMain.qLagerBVarHaltbar=Preserved frmMain.qLagerBVarBWare=BWare frmMain.qLagerBVarBemerkung=Note frmMain.qLagerBVarHandbuch=Manual frmMain.qLagerBVarKennz=Flag frmMain.qLagerBVarInfo=Info frmMain.qLagerBVarGewicht=Weight frmMain.qLagerBVarBarcode=Barcode frmMain.qLagerBVarGeloescht=Deleted frmMain.qLagerBVarAendDatum=Change Date frmPPosTest.chkMMitBestVerw=With "Quantity ordered related" frmPPosTest.lbSumme=Different Components: frmPPosTest.qPBauteilMengeBestelltV=Quantity Ordered Related frmStatus.lbAdrLief=Delivered By: frmKonfig.lb2DCodePixel=2D Code Pixel Size [mm] frmBestellAenderung.spBestStorno=X frmBestellAenderung.spBestStornoHint=Canceled frmBestellAenderung.chkAendTermin1=Termin frmBestellAenderung.chkAendTermin2=D&ate Confirmed frmBestellAenderung.chkAendFracht=Cargo frmBestellAenderung.chkAendBemerkung=Note frmMain.edDemoHint=8486\r\n0x2126 frmMain.edDemo1Hint=182\r\n0xB6 frmMain.edDemo2Hint=8804\r\n0x2264 frmMain.edDemo3Hint=8805\r\n0x2265 frmMain.edDemo4Hint=177\r\n0xB1 frmMain.edDemo5Hint=8776\r\n0x2248 frmMain.edDemo6Hint=216\r\n0xD8 frmMain.edDemo7Hint=169\r\n0xA9 frmMain.spEx2DEleLaHint=2D EleLa Control Codes frmMain.mn2DEleLaPP=Project Store Booking frmMain.mn2DEleLaL=Order Delivered frmMain.mn2DEleLaE=Offer Stored frmMain.mnScanerAnalyse=Scanner Analysis frmMain.mn2DEleLaHilfe=Help frmScaner=Scanner analysis frmScaner.lbRaw=Raw Data (KeyPress): frmScaner.lbEleLa=EleLa Data: frmScaner.lbKey=Key Events (KeyDown/KeyPress): frmScaner.tab2D=2D frmScaner.tab2DSonder=2D Special Characters frmScaner.tab1D=1D frmScaner.spConnectHint=Recording Start/Stop frmScaner.spClearHint=Blank Record frmScaner.spPrintHint=Print frmScaner.mnCopy=Copy To Clipboard frmBVerwandt=Replacement/related components frmBVerwandt.lbBauteil=Component: frmBVerwandt.lbGruppeFilter=Filter By Group: frmBVerwandt.lbBauteil1=Selected group: frmBVerwandt.panVGruppe=Groups frmBVerwandt.spVNewHint=New entry frmBVerwandt.spVSaveHint=Save Data frmBVerwandt.spVDeleteHint=Delete Data frmBVerwandt.spVAbortHint=Cancel Changes frmBVerwandt.lbGBez=Description frmBVerwandt.panVBauteile=Components In The Group frmBVerwandt.btnOK=Add Into Group frmBVerwandt.btnCancel=Cancel frmBVerwandt.btnRemove=Remove From Group frmBVerwandt.qVerwandtBezeichnung=Description frmBVerwandt.qVerwandtAendDatum=Change Date frmBVerwandt.qVerwandtIDGUID=IDGUID frmBVerwandt.qVerwandtIDGUIDT=IDGUIDT frmBVerwandt.qBauteilBauteil=Component frmBVerwandt.qBauteilVariante=Store/&Case frmBVerwandt.qBauteilGehause=Case frmBVerwandt.qBauteilArtikelNr=Item No. frmBVerwandt.qBauteilArtikelNr2=Item No. 2 frmBVerwandt.qBauteilBarcode=Barcode frmBVerwandt.qBauteilHersteller=Manufacturer frmMP3Aend.chkArtist=IDV2Artist frmMP3Aend.chkAlbum=IDV2Album frmMP3Aend.chkJahr=IDV2Year frmMP3Aend.chkGenre=IDV2Genre frmMP3Aend.btnOK=OK frmMP3Aend.btnCancel=Cancel frmMP3Integrieren=Integrate new files frmMP3Integrieren.lbAktion=Action frmMP3Integrieren.lbMP3Artist=IDV2Artist frmMP3Integrieren.lbMP3Album=IDV2Album frmMP3Integrieren.lbMP3Titel=IDV2Title frmMP3Integrieren.lbMP3Jahr=IDV2Year frmMP3Integrieren.lbMP3Track=IDV2Track frmMP3Integrieren.lbMP3Genre=IDV2Genre frmMP3Integrieren.spMP3FilterArtistHint=Filter artist frmMP3Integrieren.spMP3FilterAlbumHint=Filter album frmMP3Integrieren.btnGlobAend=Global changes frmMP3Integrieren.spAkOverwrite=Overwrite existing file frmMP3Integrieren.spMSaveHint=Save data frmMP3Integrieren.spMAbortHint=Abort change frmMP3Integrieren.spMDeleteHint=Delete data frmMP3Integrieren.spFilterMP3Hint=Filter on component frmMP3Integrieren.edSchnellsucheMP3Hint=Quick Search frmMP3Integrieren.qMP3Foto_ID=Photo ID frmMP3Integrieren.qMP3FileTyp=Type frmMP3Integrieren.qMP3FileSize=FileSize frmMP3Integrieren.qMP3IDV2Artist=IDV2Artist frmMP3Integrieren.qMP3IDV2Album=IDV2Album frmMP3Integrieren.qMP3IDV2Titel=IDV2Title frmMP3Integrieren.qMP3IDV2Year=IDV2Year frmMP3Integrieren.qMP3IDV2Track=IDV2Track frmMP3Integrieren.qMP3IDV2Genre=IDV2Genre frmMP3Integrieren.qMP3IDV2Comment=Remark frmMP3Integrieren.qMP3IDV2Encoder=IDV2Encoder frmMP3Integrieren.qMP3IDV2Copyright=IDV2Copyright frmMP3Integrieren.qMP3IDV2Language=Language frmMP3Integrieren.qMP3IDV2Link=IDV2Link frmMP3Integrieren.qMP3FileVersion=Version frmMP3Integrieren.qMP3FileBitrate=Bitrate frmMP3Integrieren.qMP3FileDuration=Timelength frmMP3Integrieren.qMP3Bemerkung=Remark frmMP3Integrieren.qMP3Rating=Rating frmMP3Integrieren.qMP3Handbuch=Manual frmMP3Integrieren.qMP3Info=Info frmMP3Integrieren.qMP3Lagernr=Store no frmMP3Integrieren.qMP3Kennz=Flag frmMP3Integrieren.qMP3Prio=Prio frmMP3Integrieren.qMP3OptA=OptA frmMP3Integrieren.qMP3OptB=OptB frmMP3Integrieren.qMP3OptC=OptC frmMP3Integrieren.qMP3AendDatum=ChangeDate frmMP3Integrieren.mnMP3Del=Delete row and file frmMP3Integrieren.qMemIDV2Artist=IDV2Artist frmMP3Integrieren.qMemIDV2Album=IDV2Album frmMP3Integrieren.qMemIDV2Titel=IDV2Title frmMP3Integrieren.qMemIDV2Year=IDV2Year frmMP3Integrieren.qMemIDV2Track=IDV2Track frmMP3Integrieren.qMemIDV2Comment=Remark frmMP3Integrieren.qMemIDV2Genre=IDV2Genre frmMP3Integrieren.qMemFileBitrate=Bitrate frmMP3Integrieren.qMemFileSize=FileSize frmMP3Integrieren.qMemAction=Action frmMP3Integrieren.qMemMP3_ID=MP3 ID frmMP3Integrieren.qMemHandbuch=Manual frmMain.spBKSAktiv=A frmMain.spBKSAktivHint=Active frmMain.dbBKEinzel=Single frmMain.spHandbuch24ExecHint=Open Manual frmMain.spHandbuch24Hint=Select Manual frmMain.lbProjektHandbuch2=&Manual frmMain.spHandbuch23Hint=Select Manual frmMain.spHandbuch23ExecHint=Open Manual frmMain.lbProjektHandbuch1=&Manual frmMain.spHandbuch25ExecHint=Open Manual frmMain.spHandbuch25Hint=Select Manual frmMain.lbProjektHandbuch3=&Manual frmMain.spHandbuch26ExecHint=Open Manual frmMain.spHandbuch26Hint=Select Manual frmMain.lbProjektHandbuch4=&Manual frmMain.lbKisteSize1=B&arcode frmMain.lbKistePY1=Status frmMain.spKBarFormatHint=Barcode frmMain.spKFrei=R frmMain.spKFreiHint=Enabled frmMain.spKBest=B frmMain.spKBestHint=Assembly Box frmMain.spKExt=X frmMain.spKExtHint=Assembly Box External frmMain.spKPruefen=T frmMain.spKPruefenHint=Assembly Box To Check frmMain.lbKKorr=Correction - New quantity: frmMain.lbTypLibrary=&Library frmMain.tbTypInfo=&Info frmMain.lbTypBezKurz=Descr. &Short frmMain.spTypInfoEtikettHint=Print Label frmMain.qAdrEPreis=Purchase Price frmMain.qAdrVPreis=Sale Price frmMain.qKisteStatus=Status frmMain.qTypVLibrary=RLibrary frmMain.qTypVInfo=VInfo frmMain.qTypVBezKurz=V short comment frmMain.qBVariVerwandtPrio=Related Priority frmMain.qBVariEAN=EAN frmMain.qBAdrWDatum=Web Query Date frmMain.qProjektBKiste_ID=ABox frmMain.qProjektBKisteStatus=ABoxState frmMain.qProjektMengeLager=Quantity In Store frmMain.qProjektTecData=Tecnical data frmMain.qWissenTecData=Tecnical data frmMain.qAdrKEPreis=Purchase Price frmMain.qAdrKVPreis=Sale Price frmMain.qPKostHandbuch=Manual frmMain.qPKostPosHandbuch=Manual frmMain.qPGeraetBKiste_ID=ABox frmMain.qPGeraetBKisteStatus=ABoxState frmMain.qPGeraetMengeLager=Quantity Stored frmMain.qPGeraetTecData=Tecnical data frmMain.qPGKostHandbuch=Manual frmMain.qPGKostPosHandbuch=Manual frmMain.qBKisteKStatus=Box Status frmMain.qBKisteEinzel=Single frmMain.qLagerBestellEinzel=Single frmMain.qLagerBestellKStatus=Box Status frmMain.qLagerBestellVArtikelNr=Related Item No. 1 frmMain.qLagerBestellVArtikelNr2=Related Item No. 2 frmMain.qLagerBestellVBarcode=Related Barcode frmMain.qLagerPPosEinzel=Single frmMain.qLagerPPosKStatus=Box Status frmMain.qLagerPPosVArtikelNr=Related Item No. 1 frmMain.qLagerPPosVArtikelNr2=Related Item No. 2 frmMain.qLagerPPosVBarcode=Related Barcode frmMain.qLagerPGPosEinzel=Single frmMain.qLagerPGPosKStatus=Box Status frmMain.qLagerPGPosVArtikelNr=Related Item No. 1 frmMain.qLagerPGPosVArtikelNr2=Related Item No. 2 frmMain.qLagerPGPosVBarcode=Related Barcode frmMain.qLagerBVarEinzel=Single frmMain.qLagerBVarKStatus=Box Status frmMain.qLagerBVarVArtikelNr=Related Item No. 1 frmMain.qLagerBVarVArtikelNr2=Related Item No. 2 frmMain.qLagerBVarVBarcode=Related Barcode frmMain.mn2DEleLaPPS2=ProjektPos Set Status "Active" frmMain.mnInfoEtikettAdd=Additional Length For Label frmMain.qBVTypBarFormat=BarFormat frmMain.qBVTypVLibrary=RLibrary frmMain.qBVTypVInfo=VInfo frmMain.qBVTypVBezKurz=V short comment frmMain.qLagerKKisteIDGUID=IDGUID frmMain.qLagerKKisteIDGUIDT=IDGUIDT frmMain.qLagerKKisteBauteil_ID=Component frmMain.qLagerKKisteBauteilVariante_ID=Component Variant frmMain.qLagerKKisteKiste_ID=Box ID frmMain.qLagerKKisteKBez=Box frmMain.qLagerKKisteLagernr=Storage No. frmMain.qLagerKKisteLagerPosX=Stock pos X frmMain.qLagerKKisteLagerPosY=Stock pos Y frmMain.qLagerKKisteLagerPosZ=Stock pos Z frmMain.qLagerKKisteLagerort=Location frmMain.qLagerKKisteFoto_ID=Photo ID frmMain.qLagerKKisteProjekt_ID=Project ID frmMain.qLagerKKisteBezeichnung=Description frmMain.qLagerKKisteMenge=Quantity frmMain.qLagerKKisteMengeRes=Quantity Remained frmMain.qLagerKKisteMengeV=Quantity Used frmMain.qLagerKKisteMengeMin=Min Quantity frmMain.qLagerKKisteStatus=Status frmMain.qLagerKKisteEinzel=Single frmMain.qLagerKKisteKStatus=Box Status frmMain.qLagerKKisteReserviertD=ReservedD frmMain.qLagerKKisteHaltbar=Preserved frmMain.qLagerKKisteBWare=BWare frmMain.qLagerKKisteBemerkung=Note frmMain.qLagerKKisteHandbuch=Manual frmMain.qLagerKKisteKennz=Flag frmMain.qLagerKKisteInfo=Info frmMain.qLagerKKisteGewicht=Weight frmMain.qLagerKKisteBarcode=Barcode frmMain.qLagerKKisteVArtikelNr=Related Item No. 1 frmMain.qLagerKKisteVArtikelNr2=Related Item No. 2 frmMain.qLagerKKisteVBarcode=Related Barcode frmMain.qLagerKKisteGeloescht=Deleted frmMain.qLagerKKisteAendDatum=Change Date frmPPosTest.lbAuswahl=Select the projects for testing frmPPosTest.tabKiste=Project Box / Assembly Box frmPPosTest.lbKInKiste=Components In The Box (Project) frmPPosTest.chkKDel=Delete Box If Empty frmPPosTest.spInfoEtikettHint=Print Label frmPPosTest.lbKKorr=Correction - New quantity: frmPPosTest.lbKInKiste1=Components In The Box (Store) frmPPosTest.lbKBuch=Quantity to book: frmPPosTest.qKisteIDGUID=IDGUID frmPPosTest.qKisteIDGUIDT=IDGUIDT frmPPosTest.qKisteFoto_ID=Photo ID frmPPosTest.qKisteBezeichnung=Description frmPPosTest.qKisteNummer=Number frmPPosTest.qKisteStatus=Status frmPPosTest.qKistePosX=PosX frmPPosTest.qKistePosY=PosY frmPPosTest.qKisteLagerort=Location frmPPosTest.qKisteGroesse=Size frmPPosTest.qKisteBemerkung=Note frmPPosTest.qKisteHandbuch=Manual frmPPosTest.qKisteInfo=Info frmPPosTest.qKisteBarcode=Barcode frmPPosTest.qKisteParEtikett=ParLabel frmPPosTest.qKisteGeloescht=Deleted frmPPosTest.qKisteAendDatum=Change Date frmPPosTest.qLKisteIDGUID=IDGUID frmPPosTest.qLKisteIDGUIDT=IDGUIDT frmPPosTest.qLKisteBauteil_ID=Component frmPPosTest.qLKisteBauteilVariante_ID=Component Variant frmPPosTest.qLKisteKiste_ID=Box frmPPosTest.qLKisteFoto_ID=Photo ID frmPPosTest.qLKisteProjekt_ID=Project ID frmPPosTest.qLKisteBezeichnung=Description frmPPosTest.qLKisteMenge=Quantity frmPPosTest.qLKisteMengeRes=Quantity Remained frmPPosTest.qLKisteMengeV=Quantity Used frmPPosTest.qLKisteMengeMin=Min Quantity frmPPosTest.qLKisteStatus=Status frmPPosTest.qLKisteEinzel=Single frmPPosTest.qLKisteReserviertD=ReservedD frmPPosTest.qLKisteHaltbar=Preserved frmPPosTest.qLKisteLagernr=Storage No. frmPPosTest.qLKisteLagerPosX=Stock pos X frmPPosTest.qLKisteLagerPosY=Stock pos Y frmPPosTest.qLKisteLagerPosZ=Stock pos Z frmPPosTest.qLKisteBWare=BWare frmPPosTest.qLKisteBemerkung=Note frmPPosTest.qLKisteHandbuch=Manual frmPPosTest.qLKisteKennz=Flag frmPPosTest.qLKisteInfo=Info frmPPosTest.qLKisteGewicht=Weight frmPPosTest.qLKisteBarcode=Barcode frmPPosTest.qLKisteGeloescht=Deleted frmPPosTest.qLKisteAendDatum=Change Date frmPPosTest.qLKiste2IDGUID=IDGUID frmPPosTest.qLKiste2IDGUIDT=IDGUIDT frmPPosTest.qLKiste2Bauteil_ID=Component frmPPosTest.qLKiste2BauteilVariante_ID=Component Variant frmPPosTest.qLKiste2Kiste_ID=Box frmPPosTest.qLKiste2Foto_ID=Photo ID frmPPosTest.qLKiste2Projekt_ID=Project ID frmPPosTest.qLKiste2KBez=Box Descr. frmPPosTest.qLKiste2Lagerort=Location frmPPosTest.qLKiste2Bezeichnung=Description frmPPosTest.qLKiste2Menge=Quantity frmPPosTest.qLKiste2MengeRes=Quantity Remained frmPPosTest.qLKiste2MengeV=Quantity Used frmPPosTest.qLKiste2MengeMin=Min Quantity frmPPosTest.qLKiste2Status=Status frmPPosTest.qLKiste2Einzel=Single frmPPosTest.qLKiste2KStatus=Box Status frmPPosTest.qLKiste2ReserviertD=ReservedD frmPPosTest.qLKiste2Haltbar=Preserved frmPPosTest.qLKiste2Lagernr=Storage No. frmPPosTest.qLKiste2LagerPosX=Stock pos X frmPPosTest.qLKiste2LagerPosY=Stock pos Y frmPPosTest.qLKiste2LagerPosZ=Stock pos Z frmPPosTest.qLKiste2BWare=BWare frmPPosTest.qLKiste2Bemerkung=Note frmPPosTest.qLKiste2Handbuch=Manual frmPPosTest.qLKiste2Kennz=Flag frmPPosTest.qLKiste2Info=Info frmPPosTest.qLKiste2Gewicht=Weight frmPPosTest.qLKiste2Barcode=Barcode frmPPosTest.qLKiste2Geloescht=Deleted frmPPosTest.qLKiste2AendDatum=Change Date frmParAdrkontakt.qParamIDGUID=IDGUID frmParAdrkontakt.qParamIDGUIDT=IDGUIDT frmParStatistik.qParamIDGUID=IDGUID frmParStatistik.qParamIDGUIDT=IDGUIDT frmAdrInline_Lng.qAdrKEPreis=Purchase Price frmAdrInline_Lng.qAdrKVPreis=Sale Price frmTecDataDef=TecData default values frmTecDataDef.spNewHint=New Entry frmTecDataDef.spSaveHint=Save Data frmTecDataDef.spAbortHint=Cancel Changes frmTecDataDef.spDeleteHint=Delete Data frmTecDataDef.lbDatum=Date: frmTecDataDef.lbValText=Description frmTecDataDef.lbValInt=Rank Order: frmTecDataDef.btnClose=Close frmTecDataDef.qParamParNr=ParNr frmTecDataDef.qParamParName=ParName frmTecDataDef.qParamLand=Country frmTecDataDef.qParamValText=Description frmTecDataDef.qParamValInt=Rank Order frmTecDataDef.qParamValFloat=ValFloat frmTecDataDef.qParamValMemo=ValMemo frmTecDataDef.qParamAendDatum=Change Date frmTecDataDef.qParamIDGUID=IDGUID frmTecDataDef.qParamIDGUIDT=IDGUIDT frmBVerwandt.qBauteilBauteil_ID=Component ID frmBVerwandt.qBauteilBauteilVariante_ID=Component Variant ID frmMP3Aend= frmMP3Aend.chkComment= frmMP3Integrieren.lbDir=Directory of the new files: frmMP3Integrieren.spAkCopy=Copy frmMP3Integrieren.spAkCopyNo=not copy frmMP3Integrieren.grpAend= frmMP3Integrieren.btnStart=Start integrate frmMP3Integrieren.qMemFileDuration=Duration frmScaner.lbCode=[)>₪06↔PEleLa↔1PEleLa12345↔1VEleLa₪‡ frmMain.qSuchEAN=EAN frmMain.mn2DEleLaBL=Component Store Quantity -1 frmKonfig.lbInfoBauteilV=Component Variant Info frmMain.spVInfoEtikettHint=Print Label frmMain.panCaseBauteil= frmMain.panBVarKisteBild= frmMain.panBKisteBild= frmMain.panBauteilAdr= frmMain.panBauteilBild= frmMain.panProjektBild= frmMain.panProjektPosBild= frmMain.panPPosKisteBild= frmMain.panHist1Bild= frmMain.panPPDBild= frmMain.panPVBild= frmMain.panPKBild= frmMain.panPKPBild= frmMain.panPGeraetBild= frmMain.panProjektGPosBild= frmMain.panPGPosKisteBild= frmMain.panHist2Bild= frmMain.panPGDBild= frmMain.panPGVBild= frmMain.panPGKBild= frmMain.panPGKPBild= frmMain.panPGEBild= frmMain.panPDBild= frmMain.panBestellungBild= frmMain.panBestellKisteBild= frmMain.panCaseBild= frmMain.panCaseExpBild= frmMain.spKGesperrt=D frmMain.spKGesperrtHint=Blocked frmMain.panKisteBild= frmMain.panKKisteBild= frmMain.panTypBild= frmMain.panTypBildDet= frmMain.panAdrBild= frmMain.panAdrKontaktBild= frmMain.panHistBild= frmMain.panWissenBild= frmMain.spDebugClearHint=Clear log frmMain.panMP3Bild= frmMain.qBVariBestellSum=Quantity Ordered frmMain.mnPPExpMaterial=Export Store List frmMain.mnPopPrintInfo=Print Label "Info" frmMain.mnPKPProjPos=Take project position frmMain.mnPGPExpMaterial=Export Store List frmMain.mnBInfoBauteil=Print Label Component "Info" frmMain.mnBInfoVariante=Print Label Variant "Info" frmMain.mnBInfoKiste=Print Label Box "Info" frmPPosTest.qPBauteilBestellTermin2=Order Date frmKisteTausch.panImg= frmTypAuswahl.panBild= frmAuswahl.panBild= frmKonfig.lbProxyUser=Proxy User frmKonfig.lbProxyPwd=Proxy Password frmKonfig.lbInfoBauteilK=Component Box Info frmKonfig.chkBauteilMengeGrund=Enter reason for Quantity change frmVersion.qParValText=ValText frmVersion.qParValInt=ValInt frmVersion.qParValMemo=ValMemo Strings.165=Should the status of all crates/warehouse entries for these crate components be set to "Check quantity"? frmMain.spFilterVGehHint=Filter By Current Case frmMain.spBLagerS0=E frmMain.spBLagerS0Hint=Store frmMain.spBLagerS1=R frmMain.spBLagerS1Hint=Enabled frmMain.spBLagerS2=E frmMain.spBLagerS2Hint=Idle running frmMain.spBLagerS3=S frmMain.spBLagerS3Hint=End frmMain.spBLagerS4=T frmMain.spBLagerS4Hint=Expensive frmMain.spBLagerS5=W frmMain.spBLagerS5Hint=Wish frmMain.spBLagerS6=V frmMain.spBLagerS6Hint=Scrapped frmMain.spBLagerS7=X frmMain.spBLagerS7Hint=Blocked frmMain.spBKSMengePruefen=Q frmMain.spBKSMengePruefenHint=Test quantity frmMain.spProjektS7=X frmMain.spProjektS7Hint=Blocked frmMain.spProjektS6=V frmMain.spProjektS6Hint=Scrapped frmMain.spProjektS5=T frmMain.spProjektS5Hint=Prototype frmMain.spProjektS4=R frmMain.spProjektS4Hint=Error frmMain.spProjektS3=T frmMain.spProjektS3Hint=test frmMain.spProjektS2=B frmMain.spProjektS2Hint=Edit frmMain.spProjektS1=R frmMain.spProjektS1Hint=Enabled frmMain.spProjektS0=- frmMain.spProjektS0Hint=No status frmMain.spPPFilterSMDHint=Filter By Housing/Variant frmMain.spPPFilterTopHint=Filter By Housing/Variant frmMain.spPGeratS7=X frmMain.spPGeratS7Hint=Blocked frmMain.spPGeratS6=V frmMain.spPGeratS6Hint=Scrapped frmMain.spPGeratS5=T frmMain.spPGeratS5Hint=Prototype frmMain.spPGeratS4=R frmMain.spPGeratS4Hint=Error frmMain.spPGeratS3=T frmMain.spPGeratS3Hint=test frmMain.spPGeratS2=B frmMain.spPGeratS2Hint=Edit frmMain.spPGeratS1=R frmMain.spPGeratS1Hint=Enabled frmMain.spPGeratS0=- frmMain.spPGeratS0Hint=No status frmMain.tabPEUebers=Overview frmMain.tabPEHistorie=History frmMain.panHist3Bild= frmMain.lbProjektEHistHandbuch=&Manual frmMain.spHandbuch27Hint=Select Manual (File) frmMain.spHandbuch27ExecHint=Open Manual frmMain.lbProjektEHistVersion=&Version frmMain.lbProjektEHistAufwand=T&ime frmMain.lbProjektEHistDatum=D&ate frmMain.lbProjektEHistBez=D&escription frmMain.lbProjektEHistFDatum=Date Read&y frmMain.lbProjektEHistFVersion=Versi&on ready frmMain.spHist3FilterHint=Filter By Current Status frmMain.lbProjektEHistStatus=Status frmMain.spHist3FilterBFHint=Filter By Current B/F frmMain.spHist3BugF=R frmMain.spHist3BugFHint=Feature frmMain.spHist3Bug=B frmMain.spHist3BugHint=Bug frmMain.spHist3BugN=D frmMain.spHist3BugNHint=Defective frmMain.lbHistStatus4=B/F frmMain.spHist3Hist=H frmMain.spHist3HistHint=History frmMain.spHist3Offen=O frmMain.spHist3OffenHint=Open frmMain.spHist3Aktiv=A frmMain.spHist3AktivHint=Active frmMain.spHist3Fertig=R frmMain.spHist3FertigHint=Ready frmMain.spHist3Nicht=D frmMain.spHist3NichtHint=not edit frmMain.spHist3Spaeter=L frmMain.spHist3SpaeterHint=later frmMain.spHist3FilterDatumFHint=Filter By Date Ready frmMain.spHist3FilterVersionFHint=Filter By Version Ready frmMain.spHist3Testen=T frmMain.spHist3TestenHint=test frmMain.spHist3FDatumHint=Select Date frmMain.spHist3Det=▼ frmMain.spHist3BugO=OPL frmMain.spHist3BugOHint=Open Positions List frmMain.spHNew3Hint=New Entry frmMain.spHCopy3Hint=Copy Data frmMain.spHSave3Hint=Save Data frmMain.spHAbort3Hint=Cancel Change frmMain.spHDelete3Hint=Delete Data frmMain.lbDatum30=Date: frmMain.spHPrint3Hint=Print frmMain.spHExp3Hint=Import/Export frmMain.spFilterPEHistHint=Filter By Project frmMain.edSchnellsuchePEHistHint=Quick Search frmMain.lbProjektEHistFehlerreport=Error Report C&ustomer frmMain.lbProjektEHistRepReport=Repair Report frmMain.lbProjektEHistRMA=RMA frmMain.spGetRMACode3Hint=Generate RMA Code frmMain.spGetErrorCode3Hint=Generate RMA Code frmMain.lbProjektEHistFehlercode=Error Code frmMain.lbProjektEHistVorgehen=Proceedin&g frmMain.lbProjektEHistAbrechnung=Invoice frmMain.lbHist3AdrKont=&Address/Contact frmMain.spGotoAdrH3Hint=Go To Address frmMain.lbProjektEHistGPreis=Total Price frmMain.spCaseS1=R frmMain.spCaseS1Hint=Enabled frmMain.spCaseS0=U frmMain.spCaseS0Hint=Unrefined frmMain.spCaseS2=D frmMain.spCaseS2Hint=New frmMain.spCaseS3=R frmMain.spCaseS3Hint=Error frmMain.spCaseS4=T frmMain.spCaseS4Hint=test frmMain.spCaseS5=W frmMain.spCaseS5Hint=Wish frmMain.spCaseS6=V frmMain.spCaseS6Hint=Outdated frmMain.spCaseS7=X frmMain.spCaseS7Hint=Blocked frmMain.lbAdrLv= frmMain.lbAdrLvK=... frmMain.btnCalcW=TecData parts frmMain.spGotoProjektEinzelHint=Go To Single Device frmMain.lbHistExProjEinzel=Single Device frmMain.edSchnellsucheHistHint=Quick Search frmMain.spFilterHistHint=Filter By Project frmMain.qAdrStatus=Status frmMain.qGehauseStatus=Status frmMain.qGehauseVersatzX=OffsetX frmMain.qGehauseVersatzY=OffsetY frmMain.qGehauseVersatzZ=OffsetZ frmMain.qGehauseVersatzRZ=OffsetRZ frmMain.qGehauseTecData=Tecnical data frmMain.qBVariStatus=Status frmMain.qBestellLStatus=SStatus frmMain.mnTypExpand=Expand All frmMain.mnTypCollapse=Collapse All frmMain.qTypBStatus=Status frmMain.qGehauseBStatus=Status frmMain.qProjektStatus=Status frmMain.qPPosVStatus=VStatus frmMain.mnPPEPreisVon=from component frmMain.mnPPEPreisIn=In Linked Component frmMain.mnPMoveGerat=Move to device frmMain.qHistProjekteinzel_ID=Single device frmMain.qBProjektMengeOffen=Quantity Opened frmMain.qKisteBStatus=Status frmMain.mnGotoBautKiste=Go To Component / Storage Bin frmMain.qAdrBStatus=Status frmMain.mnBTypGoto=Go To Type frmMain.mnPKPProjPosEinzeln=Adopt Project Items (Individually) frmMain.qPGeraetStatus=Status frmMain.mnPGMoveProjekt=Move to project frmMain.qPGPosVStatus=VStatus frmMain.mnPGPEPreisVon=from component frmMain.mnPGPEPreisIn=In Linked Component frmMain.qPEinzelKiste_ID=Box frmMain.mn2DEleLaPES=Single device status frmMain.mn2DEleLaPES0=Single device status 0 frmMain.mn2DEleLaPES1=Single device status 1 frmMain.mn2DEleLaPES2=Single device status 2 frmMain.mn2DEleLaPES3=Single device status 3 frmMain.mn2DEleLaPES4=Single device status 4 frmMain.mn2DEleLaPES5=Single device status 5 frmMain.mn2DEleLaPES6=Single device status 6 frmMain.mn2DEleLaPHS=Project History Status frmMain.mn2DEleLaHS0=History Status 0 frmMain.mn2DEleLaHS1=History Status 1 frmMain.mn2DEleLaHS2=History Status 2 frmMain.mn2DEleLaHS3=History Status 3 frmMain.mn2DEleLaHS4=History Status 4 frmMain.mn2DEleLaHS5=History Status 5 frmMain.mn2DEleLaHS6=History Status 6 frmMain.mn2DEleLaHS0N=History Status 0 New frmMain.mn2DEleLaHS1N=History Status 1 New frmMain.mn2DEleLaHS2N=History Status 2 New frmMain.mn2DEleLaHS3N=History Status 3 New frmMain.mn2DEleLaHS4N=History Status 4 New frmMain.mn2DEleLaHS5N=History Status 5 New frmMain.mn2DEleLaHS6N=History Status 6 New frmMain.qHist3Projekteinzel_ID=Projekteinzel_ID frmMain.qHist3Foto_ID=Photo ID frmMain.qHist3Datum=Date frmMain.qHist3Status=Status frmMain.qHist3FStatus=B/F frmMain.qHist3Projekt=Project Descr. frmMain.qHist3Bezeichnung=Description frmMain.qHist3Beschreibung=Text frmMain.qHist3Version=Version frmMain.qHist3SNr=Serial number frmMain.qHist3GNr=Devi&ce No. frmMain.qHist3FDatum=Date Ready frmMain.qHist3FVersion=Version Ready frmMain.qHist3Aufwand=Time frmMain.qHist3Kennz=Flag frmMain.qHist3Handbuch=Manual frmMain.qHist3Info=Info frmMain.qHist3Vorgehen=Proceedin&g frmMain.qHist3Abrechnung=Invoice frmMain.qHist3GPreis=Total Price frmMain.qHist3KundeBes=Error Report C&ustomer frmMain.qHist3RepNr=RMA frmMain.qHist3RepFehler=Error Code frmMain.qHist3RepBes=Repair Report frmMain.qHist3Adr_ID=Address frmMain.qHist3AdrK_ID=Contact frmMain.qHist3AendDatum=Change Date frmMain.qHist3IDGUID=IDGUID frmMain.qHist3IDGUIDT=IDGUIDT frmDruckEtikett.chkGrpFelderItem10=Only 1 selected component frmDruckEtikett.qDataKID=KID frmDruckEtikett.qDataVID=LID frmCalcR.mnWahlR=Selection TecData resistance value frmExpBestNr.chkLief12Vorwahl=Only As Supplier 1/2 Preselected frmKonfig.lbInfoEinzelgerat=Single device info frmEinzelgeratErz.lbSeriennummer=Serial number Strings.166=From Site Strings.167=to Strings.168=Do you really want to delete all "%s" TecData parameters completely? frmKonfig.panTecdataTop= frmKonfig.btnTecdataRefreshHint=Refresh, Read Again frmKonfig.btnTecdataChangeHint=Change ID Strings.169=Yes|No Strings.170=Yes|No Strings.171=Sufficient components in stock for "Minimal quantity according to production" Strings.172=NOT enough components in stock for "Minimum quantity after the production" ! Strings.173=Yes: Allow stock to go into negative\r\Cancel: Do not update stock\Override: Set stock quantity to 0 frmMain.spProjMengePruefeHint=Check Quantity After Production frmMain.spProjMengeTestHint=Check Quantity For Production frmMain.spAdrS7=X frmMain.spAdrS7Hint=Blocked frmMain.spAdrS3=T frmMain.spAdrS3Hint=Expensive frmMain.spAdrS2=T frmMain.spAdrS2Hint=Test frmMain.spAdrS6=I frmMain.spAdrS6Hint=Import Restrictions frmMain.spAdrS5=S frmMain.spAdrS5Hint=Export Restrictions frmMain.spAdrS1=R frmMain.spAdrS1Hint=Enabled frmMain.spAdrS4=Z frmMain.spAdrS4Hint=Customs frmMain.spAdrS0=U frmMain.spAdrS0Hint=Unrefined frmMain.edDemo8Hint=169\r\n0xA9 frmMain.edDemo9Hint=169\r\n0xA9 frmMain.edDemo10Hint=169\r\n0xA9 frmMain.qAdrKontaktArt=Contact Type frmMain.qAdrTecData=Tecnical data frmMain.qBestellLagerMengeMin=Stock Quantity Min frmMain.qBestellProjSum=Quantity Project frmMain.qBestellBestellSum=Quantity Ordered frmMain.mnProjMengePruefe=Check Quantity After The Production frmMain.mnDruckInfoBVari=Print Label Component Variant "Info" frmMain.mnDruckInfoBKiste=Print Label Component Box "Info" frmMain.mnDruckInfoVari=Print Label Component Variant "Info" frmMain.mnDruckInfoKiste=Print Label Component Box "Info" frmPPosTest.qPBauteilProjSum=Quantity Project frmPPosTest.qPBauteilLagerMengeMin=Store Quantity Min frmTecDataShowInline_Lng.panTopRO=Technical Data frmTecDataShowInline_Lng.panTopEd= frmTecDataShowInline_Lng.spTecDataVorlHint=Template frmTecDataShowInline_Lng.lbTecData=Tecnical data frmTecDataShowInline_Lng.chkTecEdit=Change frmTecDataShowInline_Lng.mnTecVKonfig=Template Configuration frmTecDataShowInline_Lng.mnTecVAdd=Add frmTecDataShowInline_Lng.mnTecVUp=Up frmTecDataShowInline_Lng.mnTecVDown=Down Strings.174=Designation already exists. Identical designations are not permitted. Strings.175=The NEXAR API query cannot be used in the freeware version.\r\nTo activate this function you should license the Pro version. frmMain.spBLiefNexarHint=Open Nexar Price Inquiry frmKonfig.tabWebNexar=Nexar frmKonfig.lbNexarClientID=Client ID: frmKonfig.lbNexarClientSecret=Client Password: frmKonfig.lbRegisterNexar=Where can I get a Nexar API key? \r\n1. Create an account: https://www.nexar.com > Products > API\r\n2. Create an account\r\n3. Fill in the data\r\n4. You can view credentials under Apps > Evaluation app > Authorization frmNexarQuery=Nexar web query frmNexarQuery.panRoh= frmNexarQuery.Label1=Raw Data frmNexarQuery.panLeft= frmNexarQuery.rgBez=Description frmNexarQuery.btnAdrAdd=Create Supplier (Address) frmNexarQuery.Label2=Supplier frmNexarQuery.chkNone= frmNexarQuery.chkNoneHint=Selection: None frmNexarQuery.chkAdr= frmNexarQuery.chkAdrHint=Selection: With Stored Address frmNexarQuery.chkAll= frmNexarQuery.chkAllHint=Selection: All frmNexarQuery.lbMenge=Quantity Maximum From: frmNexarQuery.cboMengeMaxHint=Limit Of The "From Quantity" frmNexarQuery.Label3=Prices frmNexarQuery.lbSuch=Search: frmNexarQuery.spSucheHint=Start Nexar search frmNexarQuery.spRohHint=Show Raw Data frmNexarQuery.spGotoLiefOnlineHint=Go To The Supplier's Web frmNexarQuery.lbTreffer=Hits: frmNexarQuery.btnCancel=Cancel frmNexarQuery.btnOK=Accept frmNexarQuery.qAdrBezeichnung=Description frmNexarQuery.qAdrFirma=Company frmNexarQuery.qAdrName=Name frmNexarQuery.qAdrLieferant=Supplier frmNexarQuery.qBAdrIDGUID=IDGUID frmNexarQuery.qBAdrIDGUIDT=IDGUIDT frmNexarQuery.qBAdrBauteil_ID=Component ID frmNexarQuery.qBAdrAdr_ID=Adr ID frmNexarQuery.qBAdrBauteilVariante_ID=Component Variant ID frmNexarQuery.qBAdrFoto_ID=Photo ID frmNexarQuery.qBAdrBestellNr=Order Code frmNexarQuery.qBAdrEPreisM=Price M frmNexarQuery.qBAdrMengeEP=Quantity Purchase Price frmNexarQuery.qBAdrEPreis=Purchase Price frmNexarQuery.qBAdrRabatt=Discount frmNexarQuery.qBAdrEPMenge=From Quantity frmNexarQuery.qBAdrVPEMenge=Packaging Unit frmNexarQuery.qBAdrDivMenge=Multiple frmNexarQuery.qBAdrBemerkung=Note frmNexarQuery.qBAdrWDatum=Web Query Date frmNexarQuery.qBAdrGeloescht=Deleted frmNexarQuery.qBAdrAendDatum=Change Date frmNexarQuery.qParValText=ValText frmNexarQuery.qParValInt=ValInt frmNexarQuery.qParValMemo=ValMemo frmWebShop=Web query frmWebShop.panMain= frmWebShop.lbLiefBeschr=Supplier Description: frmWebShop.lbHerstBesch=Manufacturer Description frmWebShop.lbPreis=Prices: frmWebShop.chkLiefBeschr= frmWebShop.chkPreis= frmWebShop.lbDatenb=Data Sheets: frmWebShop.chkDatenb= frmWebShop.spGotoDataOnlineHint=Open Data Sheet frmWebShop.lbLief=Delivered By: frmWebShop.lbBestNr=Order Code: frmWebShop.spGotoLiefOnlineHint=Go To Supplier's Web frmWebShop.btnOK=Accept frmWebShop.Button1=Cancel frmWebShop.panTVJSON= frmWebShop.qParValText=ValText frmWebShop.qParValInt=ValInt frmWebShop.qParValMemo=ValMemo frmMain.dbedBautVarBezKurzHint=Bezeichnung Kurz frmMain.spFilterCaseHint=Filter By Case frmMain.mnDBKiCADSQL=CAD KiCAD View Create SQL frmMain.mnBildAnsicht=Open Picture View frmMain.mnHandbDownload=Download PDF frmMain.dlgPDF=Save PDF File As frmAuswahl.qryCStatus=Status frmAuswahl.qryCNormbez=Standard Name frmAuswahl.qryCHerstellerbez=Manufacturer Description frmAuswahl.qryCLibrary=Library frmAuswahl.qryCLibraryRef=LibraryRef frmAuswahl.qryCInfo=Info frmAuswahl.qryCTecData=Tecnical data frmKonfig.lbDirKiCadSym=KiCAD Symbols frmKonfig.lbDirKiCadFoot=KiCAD Footprints frmMemoEdit.panAuswahl= frmMemoEdit.lbAuswahl=Select: frmMemoEdit.spAdd=Add frmMain.spGotoLiefArtikelNrOnlineHint=Go To Homepage Of Supplier frmMain.lbBLiefArtikelNr=Item No. frmMain.btnSpielP=Play P frmMain.mnExpVorlage1=Export template frmKonfig.tabWebDigikey=Digikey frmKonfig.lbDigikeyAdr=Addresse: frmKonfig.lbDigikeyClientID=Client ID: frmKonfig.lbDigikeyClientSecret=Client Secret: frmKonfig.lbDigikeyWaehrung=Currency: frmKonfig.lbDigikeyOAuth=OAuth Callback: frmKonfig.lbDigikeyLocaleSite=Country: frmKonfig.lbDigikeyLang=Language: frmWebShop.lbInStock=In store: frmWebShop.qPar42ValText=ValText frmWebShop.qPar42ValInt=ValInt frmWebShop.qPar42ValMemo=ValMemo frmWebShop.qPar42ValFloat=ValFloat frmMain.mnExpVorlage1Dummy= Strings.176=This function cannot be executed in the freeware version. frmMain.spBauteilNeu1Hint=Create new Component frmCalcR.grdCalc.Column_0=R2 frmCalcR.grdCalc.Column_1=I frmCalcR.grdCalc.Column_2=R1 frmCalcR.grdCalc.Column_3=Tol % frmTecDataShowInline_Lng.mnTecVWeb=Web Query frmNexarQuery.lstAdr.Column_0=Supplier frmNexarQuery.lstAdr.Column_1=Stock frmNexarQuery.lstPreis.Column_0=Supplier frmNexarQuery.lstPreis.Column_1=Order Code frmNexarQuery.lstPreis.Column_2=From quantity frmNexarQuery.lstPreis.Column_3=Price frmWebShop.lstPreis.Column_0=From quantity frmWebShop.lstPreis.Column_1=Price frmWebShop.lstPreis.Column_2=Order Code frmWebShop.lstPreis.Column_3=Info frmWebShop.lstPreis.Column_4=Multiple frmWebShop.lstPreis.Column_5=Packaging Unit frmWebShop.chkHerstellerBez=In Description frmWebShop.lstDatenb.Column_0=Category frmWebShop.lstDatenb.Column_1=Link frmWebShop.chkArtikelNr=Into item No. frmTecDataOnline=Web query tecnical data frmTecDataOnline.panTVJSON= frmTecDataOnline.panMain= frmTecDataOnline.lbLief=Delivered By: frmTecDataOnline.lbBestNr=Order Code: frmTecDataOnline.spGotoLiefOnlineHint=Go To Homepage Of Supplier frmTecDataOnline.lbInStock=In store: frmTecDataOnline.lbArtikelNr=Manufacturer Descr. frmTecDataOnline.lbHersteller=Manufacturer: frmTecDataOnline.chkArtikelNr=As item No. frmTecDataOnline.chkHersteller=As manufacturer frmTecDataOnline.grdData.Column_0=ID frmTecDataOnline.grdData.Column_1=Bezeichnung frmTecDataOnline.grdData.Column_2=Value frmTecDataOnline.grdData.Column_3=Tecnical data frmTecDataOnline.grdData.Column_4=Value frmTecDataOnline.btnOK=Accept frmTecDataOnline.Button1=Cancel frmTecDataOnline.qPar42ValText=ValText frmTecDataOnline.qPar42ValInt=ValInt frmTecDataOnline.qPar42ValMemo=ValMemo frmTecDataOnline.qPar42ValFloat=ValFloat frmTecDataOnline.qParValText=ValText frmTecDataOnline.qParValInt=ValInt frmTecDataOnline.qParValMemo=ValMemo frmBauteilNeu=Create new Component frmBauteilNeu.lbBauteil=Component data: frmBauteilNeu.lbBauteilTyp=&Type frmBauteilNeu.spBauteilTypHint=Select Type frmBauteilNeu.lbBauteilBez=&Description frmBauteilNeu.spBauteilAuswHint=Select Component frmBauteilNeu.lbBauteil1=Case / Variant frmBauteilNeu.lbVBez=D&escription frmBauteilNeu.lbBauteilBez1=C&ase frmBauteilNeu.spVGehAuswHint=Select Case frmBauteilNeu.lbVBez1=Item No. frmBauteilNeu.btnOK=New frmBauteilNeu.btnCancel=Cancel frmBauteilNeu.lbAufgabe=Tasks: frmBauteilNeu.lbABauteil=Component: frmBauteilNeu.rbBauteilNeu=Component new frmBauteilNeu.rbBauteilExist=Use existing component frmBauteilNeu.lbAVari=Case/Variant frmBauteilNeu.chkVari=Create New frmBauteilNeu.chkGeh=Create New frmBauteilNeu.lbAGeh=Case: frmBauteilNeu.lbArtExist=Item No already exists! frmMain.spGotoHerstOnlineHint=Go To Homepage Of Manufakturer frmMain.qKisteBVID=LID Strings.177= frmSchnell.spBauteilSuchHint=Select Component frmTecDataShowInline_Lng.mnTecDelete=Delete
