/* PIO frequency measurement 2025-10-21 mchris https://www.mikrocontroller.net/topic/580993#7954679 PIO Assembler: https://wokwi.com/tools/pioasm */ #include "fmes.pio.h" // Includes the compiled PIO assembly program for blinking #include #include #include "hardware/clocks.h" #define TESTPIN 16 // Macro for frequency input // function to translate #if defined(ARDUINO_ARCH_MBED) #include static int translate_pin(int pin) { return digitalPinToPinName(pin); } #else static int translate_pin(int pin) { return pin; } #endif static PIO pio; static int sm; static inline void fmes_program_init(PIO pio, uint sm, uint pin) { pio_gpio_init(pio, pin); // Set pin direction: input pio_sm_set_consecutive_pindirs(pio, sm, pin, 1, false); pio_sm_config c = fmes_program_get_default_config(0); sm_config_set_in_pins(&c, pin); // for WAIT, IN sm_config_set_jmp_pin(&c, pin); // for jump // don't join FIFO's sm_config_set_fifo_join(&c, PIO_FIFO_JOIN_NONE); // always run at sysclk (125 MHz default) sm_config_set_clkdiv(&c, 1.0); pio_sm_init(pio, sm, 0, &c); // Use SDK function to enable state machine pio_sm_set_enabled(pio, sm, true); } void setup() { Serial.begin(115200); //while (!Serial) delay(10); //Serial.println("start"); //gpio_init(TESTPIN); // Initialize the GPIO pin //gpio_set_dir(TESTPIN, GPIO_IN); // Set the TESTPIN as input (standard GPIO) pinMode(TESTPIN,INPUT); // Assign pio to pio0 pio = pio0; // Claim an unused state machine sm = pio_claim_unused_sm(pio, true); int gpio_pin = translate_pin(TESTPIN); pio_add_program(pio, &fmes_program); // Initialize PIO program on the claimed state machine fmes_program_init(pio, sm, gpio_pin); Serial.printf("Using PIO instance %p, state machine %d on pin %d\n", pio, sm, gpio_pin); } static inline int32_t pio_read(PIO pio, uint sm) { int32_t value = -1; uint32_t ints; uint8_t count = pio_sm_get_rx_fifo_level(pio, sm); ints = save_and_disable_interrupts(); if (count > 0) value = pio_sm_get_blocking(pio, sm); else value = -1; restore_interrupts(ints); return value; } float get_freq() { //count = self.sm.get() # Read count from FIFO uint32_t count = pio_read(pio, sm); const int cyclesPerLoop = 3; const int correctionCycles = 1; uint32_t sigCycles = count * cyclesPerLoop - correctionCycles; float f; uint32_t fcpu = clock_get_hz(clk_sys); //Serial.print("fcpu:");Serial.println(fcpu); if (sigCycles != 0) f = fcpu / (sigCycles); else f = -1; return f; } void loop() { Serial.print("click "); Serial.println(get_freq()); delay(200); }
