/* ------------------------------------------------------- benchmark3.c MCU : ATmega328p Takt : 16 MHz 21.11.2025 R. Seelig ------------------------------------------------------- */ #include #include #include #include #include #include "uart_all.h" #include "my_printf.h" #define printf tiny_printf #define delay _delay_ms volatile uint32_t systick_millis = 0; volatile uint32_t bench_checksum = 0; uint32_t prog_millis8; uint32_t prog_millis16; uint32_t prog_millis32; uint32_t prog_millisfl; ISR (TIMER1_COMPA_vect) { systick_millis++; } void timer1_init(void) { TCCR1B = 1 << WGM12 | 1 << CS10; OCR1A = F_CPU / 1000; TCNT1 = 0; TIMSK1 = 1 << OCIE1A; sei(); } void my_putchar(char ch) { uart_putchar(ch); } #define loops_int8 500000 #define loops_int16 500000 #define loops_int32 200000 #define loops_float 10000 #define n_int8 16 #define n_int16 16 #define n_int32 16 #define n_float 16 void benchmark_int8(volatile uint8_t *array) { uint32_t loop, i; uint8_t a, b, c, mix; for(loop = 0; loop < loops_int8; loop++) { for(i = 0; i < n_int8; i++) { a = array[i]; b = (a * 17) + (i ^ 0x55); c = (b * 23) ^ a; mix = a ^ (b << 1) ^ (c >> 2); mix = (mix << 3) | (mix >> 5); array[i] = mix; } } uint32_t cs = 0; for(i = 0; i < n_int8; i++) cs += array[i]; bench_checksum += cs; } void benchmark_int16(volatile uint16_t *array) { uint32_t loop, i; uint16_t a, b, c, mix; for(loop = 0; loop < loops_int16; loop++) { for(i = 0; i < n_int16; i++) { a = array[i]; b = (a * 123) + (i ^ 0xAAAA); c = (b * 97) ^ a; mix = a ^ (b << 1) ^ (c >> 2); mix = (mix << 3) | (mix >> 5); array[i] = mix; } } uint32_t cs = 0; for(i = 0; i < n_int16; i++) cs += array[i]; bench_checksum += cs; } void benchmark_int32(volatile uint32_t *array) { uint32_t loop, i; uint32_t a, b, c, mix; for(loop = 0; loop < loops_int32; loop++) { for(i = 0; i < n_int32; i++) { a = array[i]; b = (a * 12345UL) + (i ^ 0xAAAA5555UL); c = (b * 98765UL) ^ a; mix = a ^ (b << 1) ^ (c >> 2); mix = (mix << 3) | (mix >> 5); array[i] = mix & 0xFFFF; } } uint32_t cs = 0; for(i = 0; i < n_int32; i++) cs += array[i] & 0xFFFF; bench_checksum += cs; } void benchmark_float(volatile float *array) { uint32_t loop, i; float a, b, c, mix; for(loop = 0; loop < loops_float; loop++) { for(i = 0; i < n_float; i++) { a = array[i]; b = a * 1.2345f + (float)i; c = b * 0.9876f - a; mix = a + b - c; array[i] = mix; } } uint32_t cs = 0; for(i = 0; i < n_float; i++) cs += (uint32_t)(array[i] * 10.0f); bench_checksum += cs; } void run_benchmark() { volatile uint8_t array8[n_int8]; volatile uint16_t array16[n_int16]; volatile uint32_t array32[n_int32]; volatile float arrayf[n_float]; uint32_t i; int16_t fval; for(i = 0; i < n_int8; i++) array8[i] = i * 3 + 1; for(i = 0; i < n_int16; i++) array16[i] = i * 7 + 11; for(i = 0; i < n_int32; i++) array32[i] = i * 123 + 456; for(i = 0; i < n_float; i++) arrayf[i] = (float)i * 0.5f + 1.0f; printf("\n\rint_8 Benchmark\n\r"); prog_millis8 = systick_millis; benchmark_int8(array8); prog_millis8 = systick_millis - prog_millis8; printf("Zeit: %d.%d sek\n\r", (uint16_t)(prog_millis8 / 1000), (uint16_t)((prog_millis8 % 1000)/10)); printf("-----------------------------\n\r"); printf("\n\rint_16 Benchmark\n\r"); prog_millis16 = systick_millis; benchmark_int16(array16); prog_millis16 = systick_millis - prog_millis16; printf("Zeit: %d.%d sek\n\r", (uint16_t)(prog_millis16 / 1000), (uint16_t)((prog_millis16 % 1000)/10)); printf("-----------------------------\n\r"); printf("\n\rint32 Benchmark\n\r"); prog_millis32 = systick_millis; benchmark_int32(array32); prog_millis32 = systick_millis - prog_millis32; printf("Zeit: %d.%d sek\n\r", (uint16_t)(prog_millis32 / 1000), (uint16_t)((prog_millis32 % 1000)/10)); printf("-----------------------------\n\r"); printf("\n\rfloat Benchmark\n\r"); prog_millisfl = systick_millis; benchmark_float(arrayf); prog_millisfl = systick_millis - prog_millisfl; fval = (int16_t)(arrayf[0] * 10.0f); printfkomma = 1; printf("float done: %k\n\r", fval); printf("Zeit: %d.%d sek\n\r", (uint16_t)(prog_millisfl / 1000), (uint16_t)((prog_millisfl % 1000)/10)); printf("-----------------------------\n\r"); printf("Checksumme: %x\n\r", bench_checksum); } int main(void) { uint32_t gesamtzeit; timer1_init(); uart_init(); printf("\n\r --------------------------------------\n\r"); printf( " ATmega328p: (Pseudo)benchmark \n\r"); printf( " \n\r"); printf( " 21.11.2025 korrigierte Version \n\r"); printf( " --------------------------------------\n\n\r"); run_benchmark(); gesamtzeit = prog_millis8 + prog_millis16 + prog_millis32 + prog_millisfl; printf("\n\rZeit gesamt: %d.%d sek\n\r", (uint16_t)(gesamtzeit/1000), (uint16_t)((gesamtzeit%1000)/10)); printf("Gesamt-Checksumme: %x\n\r", bench_checksum); while(1); }
