ROM VER: 2.1.0 CFG 0e B . . . pagesize = 00000800 no_of_pages_in_block = 00000040 * * * * * Detected PXB4583el V1.2-2000 .[piglet] Suceeded (AVM) EVA Revision: 1.3578 (C) Copyright 2005 AVM Date: Nov 27 2018 Time: 13:38:30 (2) 3 0x0-0x46409 [NAND:] 512MB MACRONIX 2048 Pagesize 128k Blocksize 4096 Blocks HW [SYSTEM:] GRX5 (ID 0x24 Revision 2) on 1000MHz/600MHz/666MHz #Loading compressed kernel to 0x85284A30 ..................................................................................................................................................Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 ------------------------------------------- Switching to Bootcore Console ------------------------------------------- [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000000c00059638b ases 0x00000001 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 00019074 (MIPS 4KEc) [ 0.000000][ T0] MIPS: machine is GRX550 ANYWAN BOOTCORE (MIPS 4Kec) [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 02000000 @ 0e000000 (usable) [ 0.000000][ T0] memory: 00001bed @ 0e7bc030 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 0dfc0000 (reserved) [ 0.000000][ T0] Initial ramdisk at: 0x8e000000 (4194304 bytes) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000000c0005d638b icache.flags 0x00000000 dcache.flags 0x00000004 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 16 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 16 bytes [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000000c0005d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] Normal [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x000000000e000000-0x000000000fffffff] [ 0.000000][ T0] On node 0 totalpages: 8192 [ 0.000000][ T0] free_area_init_node: node 0, pgdat 8e7bb1c4, node_mem_map 8f005a00 [ 0.000000][ T0] Normal zone: 64 pages used for memmap [ 0.000000][ T0] Normal zone: 0 pages reserved [ 0.000000][ T0] Normal zone: 8192 pages, LIFO batch:0 [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000][ T0] pcpu-alloc: [0] 0 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200n8r root=/dev/ram rw loglevel=8 [ 0.000000][ T0] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Memory: 23752K/32768K available (2931K kernel code, 461K rwdata, 680K rodata, 208K init, 262K bss, 9016K reserved, 0K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] grx500_bootcore_register_static_irq: irq_in = 0x0000001f, irq_out = 0x0000001f [ 0.000000][ T0] grx500_bootcore_register_static_irq: mapper_reg = 0x0000015c, mapper_offset = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: int_line = 0x0000001f, map_address = 0x0000015c, num = 0x00000000 [ 0.000000][ T0] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x0000001f [ 0.000000][ T0] CPU Clock: 300MHz [ 0.000000][ T0] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns [ 0.000019][ T0] sched_clock: 32 bits at 150MHz, resolution 6ns, wraps every 14316557820ns [ 0.016982][ T0] : grx500_bootcore_console_init: call register [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.028785][ T0] console [ttyLTQ0] enabled [ 0.041329][ T0] bootconsole [early0] disabled [ 0.041329][ T0] bootconsole [early0] disabled [ 0.054935][ T0] bootconsole [early0] disabled [ 0.054935][ T0] bootconsole [early0] disabled [ 0.064285][ T0] Calibrating delay loop... 299.26 BogoMIPS (lpj=598528) [ 0.107048][ T0] pid_max: default: 32768 minimum: 301 [ 0.113281][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.120435][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.134913][ T1] Performance counters: No available PMU. [ 0.143954][ T1] devtmpfs: initialized [ 0.153242][ T1] ngi: Protecting Bootcore: [0x2e000000, 0x2fffffff] [ 0.159655][ T1] ngi: 512MB attached. Protecting: [0x40000000, 0x9fffffff] [ 0.166669][ T1] ngi: Unattached: [0x60000000, 0x9fffffff] [ 0.172370][ T1] ngi: Unattached: [0x40000000, 0x5fffffff] [ 0.178795][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.189133][ T1] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.196233][ T1] pinctrl core: initialized pinctrl subsystem [ 0.204941][ T1] NET: Registered protocol family 16 [ 0.227350][ T1] irq: no irq domain found for /interrupt-controller@0x14900140 ! [ 0.327836][ T1] clocksource: Switched to clocksource MIPS [ 0.356192][ T1] NET: Registered protocol family 2 [ 0.361718][ T1] IP idents hash table entries: 2048 (order: 2, 16384 bytes) [ 0.370746][ T1] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.378428][ T1] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.385362][ T1] TCP: Hash tables configured (established 1024 bind 1024) [ 0.392911][ T1] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.399418][ T1] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.406845][ T1] NET: Registered protocol family 1 [ 0.416387][ T1] Unpacking initramfs... [ 1.158423][ T1] Freeing initrd memory: 4096K [ 1.165737][ T1] No memory allocated for crashlog [ 1.179003][ T1] workingset: timestamp_bits=30 max_order=13 bucket_order=0 [ 1.260440][ T1] Serial: grx500_bootcore driver init [ 1.274319][ T1] NET: Registered protocol family 10 [ 1.292561][ T1] NET: Registered protocol family 17 [ 1.305932][ T1] Serial: grx500_bootcore driver startup [ 1.311402][ T1] grx500_bootcore_register_static_irq: irq_in = 0x0000001c, irq_out = 0x00000008 [ 1.320152][ T1] grx500_bootcore_register_static_irq: mapper_reg = 0x00000158, mapper_offset = 0x00000003 [ 1.329908][ T1] EXCEP_remap_line: int_line = 0x00000008, map_address = 0x00000158, num = 0x00000003 [ 1.339323][ T1] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x00040000 [ 1.352450][ T1] Freeing unused kernel memory: 208K [ 1.357493][ T1] This architecture does not have kernel memory protection. [ 1.596766][ T195] eip123_hw: module license 'Proprietary' taints kernel. [ 1.603574][ T195] Disabling lock debugging due to kernel taint [ 1.614876][ T195] eip123: no symbol version for eip123_hw_asset_derive [ 1.623364][ T195] eip123 1e000000.eip123: Detected hardware version 2.2.2 [ 1.630311][ T195] eip123 1e000000.eip123: my_id=0 master_id=0 num_mailboxes=4 mailbox_size=256 [ 1.638897][ T195] eip123 1e000000.eip123: Configured mailbox lockout: 0x00000000 [ 1.646412][ T195] eip123 1e000000.eip123: Linked mailbox number 1 [ 1.679904][ T195] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=0 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0 [ 1.915838][ T195] eip123 1e000000.eip123: eip123_hw init successful [ 1.975869][ T195] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c [ 1.984972][ T195] eip123 1e000000.eip123: Could not find rootkey in OTP [ 2.020044][ T198] random: crng init done [ 2.024979][ T110] shm-rng-seed shm-rng-seed@3dfb0000: Added 4088 random bytes to the shared memory area [ 3.794230][ T262] eip123 1e000000.eip123: Unlinked mailboxes ê 3.811385][ T181] interaptiv_start: starting interaptiv ------------------------------------------- Switching to Interaptiv Console ------------------------------------------- .. Device Tree Blob for SubRevision 4 not found. Using Device Tree Blob of SubRevision 0 [ 0.000000][ T0] shm-rng-seed-mem@3dfb0000: Added 4088 random bytes to the system pool [ 0.000000][ T0] OF: fdt:[0x33920000, 0x34be3b70) is not contained in the RAM region at [0x20000000, 0x2e000000) [ 0.000000][ T0] Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e69638b ases 0x00000030 [ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.000000][ T0] SoC: GRX500 rev 1.2 [ 0.000000][ T0] bootconsole [early0] enabled [ 0.000000][ T0] CPU0 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.000000][ T0] Enhanced Virtual Addressing (EVA Legacy 512MB) activated [ 0.000000][ T0] MIPS: machine is AVM7590 (GRX550, HW226) Main model [ 0.000000][ T0] Coherence Manager IOCU detected [ 0.000000][ T0] Hardware DMA cache coherency disabled [ 0.000000][ T0] OF: reserved mem: initialized node shm-rng-seed-mem@3dfb0000, compatible id avm,shm-rng-seed-early [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'urlader': base 0x20010000, size 0x00030000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'VMB': base 0x20000000, size 0x00001000 [ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'avm_reboot_string': base 0x20001000, size 0x00000200 [ 0.000000][ T0] Determined physical RAM map: [ 0.000000][ T0] memory: 10000000 @ 30000000 (usable) [ 0.000000][ T0] memory: 0e000000 @ 20000000 (usable) [ 0.000000][ T0] memory: 0000cf6d @ 3454a038 (reserved) [ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved) [ 0.000000][ T0] memory: 00040000 @ 2dfc0000 (reserved) [ 0.000000][ T0] memory: 00400000 @ 20100000 (reserved) [ 0.000000][ T0] memory: 00030000 @ 20010000 (reserved) [ 0.000000][ T0] memory: 00001200 @ 20000000 (reserved) [ 0.000000][ T0] Kernel relocated by 0x13420000 [ 0.000000][ T0] .text @ 0x93920000 [ 0.000000][ T0] .data @ 0x941e2874 [ 0.000000][ T0] .bss @ 0x94730000 [ 0.000000][ T0] Initrd not found or empty - disabling initrd [ 0.000000][ T0] cma: Reserved 64 MiB at 0x24000000 [ 0.000000][ T0] SMPCMP: initialized the EVA stub code: 400@0x28029480 [ 0.000000][ T0] SMPCMP: CPU0: cmp_smp_setup [ 0.000000][ T0] VPE topology {2,2} total 4 [ 0.000000][ T0] Detected 3 available secondary CPU(s) [ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.000000][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.000000][ T0] Zone ranges: [ 0.000000][ T0] DMA [mem 0x0000000020000000-0x0000000027ffffff] [ 0.000000][ T0] Normal [mem 0x0000000028000000-0x000000003fffffff] [ 0.000000][ T0] Movable zone start for each node [ 0.000000][ T0] Early memory node ranges [ 0.000000][ T0] node 0: [mem 0x0000000020000000-0x000000002dffffff] [ 0.000000][ T0] node 0: [mem 0x0000000030000000-0x000000003fffffff] [ 0.000000][ T0] Initmem setup node 0 [mem 0x0000000020000000-0x000000003fffffff] [ 0.000000][ T0] [fw-info] Version 08.20 buildnr=122916 buildtype=1 [ 0.000000][ T0] [module-mem] Use 0x3f0cb000-0x3fc17fff (mapped at 9f0cb000-9fc17fff) for 95 modules [ 0.000000][ T0] percpu: Embedded 12 pages/cpu s18288 r8192 d22672 u49152 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121728 [ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200 pcmlink.abmode=0x8103 Piglet_noemif.piglet_dectmode=0x110 Piglet_noemif.piglet_bitfile=bitfile.bit audit=1 slub_debug=fl [ 0.000000][ T0] audit: enabled (after initialization) [ 0.000000][ T0] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000][ T0] Writing ErrCtl register=00000000 [ 0.000000][ T0] Readback ErrCtl register=00000000 [ 0.000000][ T0] Memory: 385240K/491520K available (8745K kernel code, 1849K rwdata, 1892K rodata, 1688K init, 4814K bss, 40744K reserved, 65536K cma-reserved) [ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000][ T0] Hierarchical RCU implementation. [ 0.000000][ T0] NR_IRQS:527 [ 0.000000][ T0] EIC is off [ 0.000000][ T0] VINT is on [ 0.000000][ T0] CPU Clock: 1000000000Hz mips_hpt_frequency 500000000Hz [ 0.000000][ T0] clocksource: gptc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302233 ns [ 0.010146][ T0] Calibrating delay loop... 718.84 BogoMIPS (lpj=1437696) [ 0.046807][ T0] pid_max: default: 32768 minimum: 301 [ 0.052302][ T0] Security Framework initialized [ 0.057083][ T0] AppArmor: AppArmor initialized [ 0.061976][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.069296][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.078843][ T1] CCA is coherent, multi-core is fine [ 0.084503][ T1] avm_register_cpuid: cpu_id=0: LINUX core=0 tc=0 [ 0.090740][ T1] Performance counters: mips/interAptiv PMU enabled, 2 32-bit counters available to each CPU, irq 9 GOT IPI to launch from CPU 1 GOT IPI to launch from CPU 2 GOT IPI to launch from CPU 3 [ 0.109267][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.109312][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.109318][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.109337][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.109344][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.109350][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.109360][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.109365][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.109563][ T0] CPU1 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.139602][ T0] avm_register_cpuid: cpu_id=1: LINUX core=0 tc=1 [ 0.142047][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.142085][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.142089][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.142107][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.142114][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.142120][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.142130][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.142134][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.142269][ T0] CPU2 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.169881][ T0] avm_register_cpuid: cpu_id=2: LINUX core=1 tc=0 [ 0.172358][ T0] avm_check_isa_features: isa_level 0x00000031 [ 0.172395][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030 [ 0.172398][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S) [ 0.172417][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020 [ 0.172422][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.172427][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes [ 0.172437][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes. [ 0.172442][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b [ 0.172576][ T0] CPU3 revision is: 0001a120 (MIPS interAptiv (multi)) [ 0.200184][ T0] avm_register_cpuid: cpu_id=3: LINUX core=1 tc=1 [ 0.200455][ T1] Brought up 4 CPUs [ 0.470632][ T1] avm_yield_setup: YIELD_PCMFRAME_ID : id=0x0004000f: cpu=0 tc=4 prio=3 signal=15 [ 0.480261][ T1] avm_yield_setup: YIELD_PCMLINK_ID : id=0x0003000c: cpu=0 tc=3 prio=2 signal=12 [ 0.489896][ T1] avm_yield_setup: YIELD_MONITOR_IPI0_ID : id=0x0002000e: cpu=0 tc=2 prio=1 signal=14 [ 0.499531][ T1] avm_yield_setup: YIELD_PROFILE_IPI0_ID : id=0x0002000d: cpu=0 tc=2 prio=1 signal=13 [ 0.509166][ T1] avm_yield_setup: YIELD_GPTC_ID : id=0x0005000b: cpu=0 tc=5 prio=3 signal=11 [ 0.519339][ T3] [0][yield_context_init] cpu=0 tc=2 mask=6000 tc_prio=1 [ 0.526486][ T29] [0][yield_context_init] cpu=0 tc=3 mask=1000 tc_prio=2 [ 0.533643][ T29] [0][yield_context_init] cpu=0 tc=4 mask=8000 tc_prio=3 [ 0.540751][ T29] [0][yield_context_init] cpu=0 tc=5 mask=0800 tc_prio=3 [ 0.547758][ T1] avm_yield_setup: YIELD_MONITOR_IPI1_ID : id=0x0202000e: cpu=2 tc=2 prio=1 signal=14 [ 0.557209][ T1] avm_yield_setup: YIELD_PROFILE_IPI1_ID : id=0x0202000d: cpu=2 tc=2 prio=1 signal=13 [ 0.567249][ T21] [2][yield_context_init] cpu=2 tc=2 mask=6000 tc_prio=1 [ 0.575097][ T1] devtmpfs: initialized [ 0.594323][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.604902][ T1] futex hash table entries: 1024 (order: 3, 32768 bytes) [ 0.616583][ T1] pinctrl core: initialized pinctrl subsystem [ 0.624037][ T1] NET: Registered protocol family 16 [ 0.633581][ T1] dma-grx500 1e300000.dma: dma3 base address be300000 chained_irq 29 irq_base 30 [ 0.645457][ T1] dma-grx500 1e300000.dma: Init done - rev: a, ports: 1, channels: 64 [ 0.655905][ T1] dma-grx500 1c100000.dma: dma2tx base address bc100000 chained_irq 100 irq_base 101 [ 0.666759][ T1] dma-grx500 1c100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.675241][ T1] dma-grx500 1c200000.dma: dma2rx base address bc200000 chained_irq 117 irq_base 118 [ 0.686584][ T1] dma-grx500 1c200000.dma: Init done - rev: a, ports: 1, channels: 32 [ 0.695550][ T1] dma-grx500 1a100000.dma: dma1tx base address ba100000 chained_irq 150 irq_base 151 [ 0.706420][ T1] dma-grx500 1a100000.dma: Init done - rev: a, ports: 1, channels: 16 [ 0.714817][ T1] dma-grx500 1a200000.dma: dma1rx base address ba200000 chained_irq 167 irq_base 168 [ 0.725529][ T1] dma-grx500 1a200000.dma: Init done - rev: a, ports: 1, channels: 12 [ 0.740757][ T1] dma0-grx500 16e00000.dma: base address b6e00000 chained_irq 218 irq_base 219 [ 0.749495][ T1] dma0-grx500 16e00000.dma: Init done - hw rev: A, ports: 4, channels: 16 [ 0.758171][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 0, reg: 0xb6c80000, pinbase: 0, pin number: 32, pinmap: 0xf1efefff [ 0.769832][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 1, reg: 0xb6c80100, pinbase: 32, pin number: 32, pinmap: 0x3bff0c1f [ 0.781965][ T1] intel-pinctrl 16c80000.pinctrl: Total 14 groups, 12 functions [ 0.790353][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00000 [ 0.798301][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00100 [ 0.815279][ T1] gic_timer_probe [ 0.818728][ T1] gic_timer_probe: irq=287 freq=1000000000 [ 0.863116][ T1] avm_alloc_page_extension node_extension_table[0] entries=131072 (size=524288) alloced [ 0.873190][ T1] Reboot Status is: NMI-Watchdog-Reset(NMI) NMI(2) [ 0.879529][ T1] Unable to get node cqm for prx300-cqm [ 0.884851][ T1] add_cqm_dev(#152): parse_dts fail for prx300-cqm [ 0.891448][ T1] No rcu reset for cbm [ 0.895266][ T1] No syscon phandle specified for wan mux [ 0.900912][ T1] Invalid args in ltq_dqm_ports [ 0.905679][ T1] Invalid args in ltq_eqm_ports [ 0.980437][ T1] [cbm] { cbm_xrx500_probe : 5697 }reserving 18874368 bytes @ 84000000 for CBM [ 1.020220][ T1] [cbm] { cbm_xrx500_probe : 5707 }reserving 8388608 bytes @ 85200000 for CBM [ 1.028847][ T1] [cbm] { cbm_xrx500_probe : 5722 }94 irq [ 1.034568][ T1] [cbm] { cbm_xrx500_probe : 5745 }2 [ 1.039714][ T1] [drv_tmu_ll] { get_cbm_clock : 7605 }CBM Clock: 0Hz=0MHZ [ 1.046820][ T1] [drv_tmu_ll] { get_cbm_clock : 7608 }Wrong cbm clock [ 1.053593][ T1] Initializing TMU with Base Address=be700000: ... [ 1.062839][ T1] TMU Initialization Done [ 1.066865][ T1] 0x84000000 0x1200000 0x800 [ 1.071377][ T1] 0x84000000 0x1200000 [ 1.075361][ T1] 0x85200000 0x800000 0x2000 [ 1.079876][ T1] 0x85200000 0x800000 [ 1.084096][ T1] [cbm] { init_fsqm_buf_std : 1173 }init fsqm std successfully [ 1.091359][ T1] [cbm] { init_fsqm_buf_jumbo : 1213 }init fsqm jbo successfully [ 1.098962][ T1] [cbm] { init_fsqm : 1236 }fsqm init successfully [ 1.105387][ T1] [cbm] { init_cbm_basic : 1271 }PHY ADDR STD 0x24000000 [ 1.112330][ T1] [cbm] { init_cbm_basic : 1272 }PHY ADDR JBO 0x25200000 [ 1.119515][ T1] [cbm] { init_cbm_basic : 1290 }init basic CBM successfully [ 1.126570][ T1] [cbm] { cbm_hw_init : 2206 }CBM HW init [ 1.132330][ T1] [cbm] { setup_DMA_p2p : 5102 }setup_DMA_p2p executed [ 1.138985][ T1] [cbm] { reserved_ports_highest : 5161 }2 2 19 35 [ 1.145411][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.151085][ T1] [cbm] { assign_port_from_DT : 654 }0x0 2 [ 1.156778][ T1] [cbm] { assign_port_from_DT : 654 }0x20 2 [ 1.162768][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.167629][ T1] [cbm] { reserved_ports_highest : 5161 }1 1 18 34 [ 1.174047][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.179702][ T1] [cbm] { assign_port_from_DT : 654 }0x80 1 [ 1.185508][ T1] [cbm] { reserved_ports_highest : 5161 }3 3 20 36 [ 1.191929][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.197580][ T1] [cbm] { assign_port_from_DT : 654 }0x2000000 3 [ 1.203823][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.208864][ T1] [cbm] { reserved_ports_highest : 5161 }6 6 0 16 [ 1.215196][ T1] [cbm] { dma_port_enable : 4670 }6 0x4 [ 1.220671][ T1] [cbm] { reserved_ports_highest : 5161 }7 7 1 17 [ 1.227004][ T1] [cbm] { dma_port_enable : 4670 }7 0x4 [ 1.232481][ T1] [cbm] { reserved_ports_highest : 5161 }8 8 2 18 [ 1.238806][ T1] [cbm] { dma_port_enable : 4670 }8 0x4 [ 1.244281][ T1] [cbm] { reserved_ports_highest : 5161 }9 9 3 19 [ 1.250609][ T1] [cbm] { dma_port_enable : 4670 }9 0x4 [ 1.256143][ T1] [cbm] { reserved_ports_highest : 5161 }10 10 4 20 [ 1.262594][ T1] [cbm] { dma_port_enable : 4670 }10 0x4 [ 1.268154][ T1] [cbm] { reserved_ports_highest : 5161 }11 11 5 21 [ 1.274653][ T1] [cbm] { dma_port_enable : 4670 }11 0x4 [ 1.280217][ T1] [cbm] { reserved_ports_highest : 5161 }12 12 6 22 [ 1.286718][ T1] [cbm] { dma_port_enable : 4670 }12 0x4 [ 1.292282][ T1] [cbm] { reserved_ports_highest : 5161 }13 13 7 23 [ 1.298785][ T1] [cbm] { dma_port_enable : 4670 }13 0x4 [ 1.304348][ T1] [cbm] { reserved_ports_highest : 5161 }14 14 8 24 [ 1.310850][ T1] [cbm] { dma_port_enable : 4670 }14 0x4 [ 1.316414][ T1] [cbm] { reserved_ports_highest : 5161 }15 15 9 25 [ 1.322915][ T1] [cbm] { dma_port_enable : 4670 }15 0x4 [ 1.328479][ T1] [cbm] { reserved_ports_highest : 5161 }16 16 10 26 [ 1.335067][ T1] [cbm] { dma_port_enable : 4670 }16 0x4 [ 1.340632][ T1] [cbm] { reserved_ports_highest : 5161 }17 17 11 27 [ 1.347220][ T1] [cbm] { dma_port_enable : 4670 }17 0x4 [ 1.352784][ T1] [cbm] { reserved_ports_highest : 5161 }18 18 -16 0 [ 1.359373][ T1] [cbm] { dma_port_enable : 4670 }18 0x4 [ 1.364952][ T1] [cbm] { reserved_ports_highest : 5161 }19 19 12 28 [ 1.371525][ T1] [cbm] { dma_port_enable : 4670 }19 0x4 [ 1.377089][ T1] [cbm] { reserved_ports_highest : 5161 }20 20 13 29 [ 1.383677][ T1] [cbm] { dma_port_enable : 4670 }20 0x4 [ 1.389240][ T1] [cbm] { init_special_ports : 5168 }20 [ 1.394701][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.399735][ T1] [cbm] { reserved_ports_highest : 5161 }21 21 14 30 [ 1.406333][ T1] [cbm] { dma_port_enable : 4670 }21 0x4 [ 1.411895][ T1] [cbm] { init_special_ports : 5168 }21 [ 1.417356][ T1] [cbm] { cbm_add_to_list : 450 }1 [ 1.422390][ T1] [cbm] { reserved_ports_highest : 5161 }22 22 25 41 [ 1.428988][ T1] [cbm] { dma_port_enable : 4670 }22 0x4 [ 1.434553][ T1] [cbm] { reserved_ports_highest : 5161 }23 23 15 31 [ 1.441141][ T1] [cbm] { init_cbm_dqm_ldma_port : 1476 }23 [ 1.446965][ T1] [cbm] { reserved_ports_highest : 5161 }5 5 21 37 [ 1.453381][ T1] [cbm] { init_cbm_dqm_scpu_port : 1457 }5 [ 1.459287][ T1] [cbm] { reserved_ports_highest : 5161 }4 4 16 32 [ 1.465532][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }4 [ 1.471182][ T1] [cbm] { assign_port_from_DT : 654 }0x18 4 [ 1.476991][ T1] [cbm] { reserved_ports_highest : 5161 }24 24 22 38 [ 1.483585][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }24 [ 1.489325][ T1] [cbm] { assign_port_from_DT : 654 }0x8 24 [ 1.495132][ T1] [cbm] { reserved_ports_highest : 5161 }25 25 23 39 [ 1.501729][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }25 [ 1.507465][ T1] [cbm] { assign_port_from_DT : 654 }0x8 25 [ 1.513275][ T1] [cbm] { reserved_ports_highest : 5161 }26 26 24 40 [ 1.519868][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }26 [ 1.525608][ T1] [cbm] { assign_port_from_DT : 654 }0x8 26 [ 1.531415][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }0 [ 1.537057][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }1 [ 1.542700][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }2 [ 1.548341][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }3 [ 1.553984][ T1] [cbm] { dma_port_enable : 4670 }5 0x1 [ 1.559459][ T1] [cbm] { dma_port_enable : 4670 }5 0x2 [ 1.564921][ T1] [cbm] { dma_port_enable : 4670 }6 0x1 [ 1.570391][ T1] [cbm] { dma_port_enable : 4670 }6 0x2 [ 1.575858][ T1] [cbm] { dma_port_enable : 4670 }7 0x1 [ 1.581333][ T1] [cbm] { dma_port_enable : 4670 }7 0x2 [ 1.586795][ T1] [cbm] { dma_port_enable : 4670 }8 0x1 [ 1.592265][ T1] [cbm] { dma_port_enable : 4670 }8 0x2 [ 1.597732][ T1] [cbm] { dma_toe_port_enable : 4697 }9 0x1 [ 1.603549][ T1] [cbm] { dma_vrx318_port_enable : 4709 }15 0x1 [ 1.609721][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }0 [ 1.615352][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1 [ 1.620993][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2 [ 1.626637][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3 [ 1.632281][ T1] Load spreader init successfully [ 1.637383][ T1] [cbm] { cbm_xrx500_probe : 5801 }CBM Clock: 0Hz [ 1.643565][ T1] [cbm] { cbm_xrx500_probe : 5803 }EQM delay Enabled [ 1.650161][ T1] [cbm] { igp_delay_set : 4782 }port0 delay16 [ 1.656149][ T1] [cbm] { igp_delay_set : 4782 }port1 delay16 [ 1.662139][ T1] [cbm] { igp_delay_set : 4782 }port2 delay16 [ 1.668127][ T1] [cbm] { igp_delay_set : 4782 }port3 delay16 [ 1.674118][ T1] [cbm] { igp_delay_set : 4782 }port4 delay16 [ 1.680106][ T1] [cbm] { igp_delay_set : 4782 }port5 delay16 [ 1.686096][ T1] [cbm] { igp_delay_set : 4782 }port6 delay16 [ 1.692085][ T1] [cbm] { igp_delay_set : 4782 }port7 delay16 [ 1.698075][ T1] [cbm] { igp_delay_set : 4782 }port8 delay16 [ 1.704063][ T1] [cbm] { igp_delay_set : 4782 }port9 delay16 [ 1.710054][ T1] [cbm] { igp_delay_set : 4782 }port10 delay16 [ 1.716129][ T1] [cbm] { igp_delay_set : 4782 }port11 delay16 [ 1.722207][ T1] [cbm] { igp_delay_set : 4782 }port12 delay16 [ 1.728281][ T1] [cbm] { igp_delay_set : 4782 }port13 delay16 [ 1.734359][ T1] [cbm] { igp_delay_set : 4782 }port14 delay16 [ 1.740434][ T1] [cbm] { igp_delay_set : 4782 }port15 delay16 [ 1.746514][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x2 2 0 30 [ 1.753128][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x1 2 14 0 [ 1.759711][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x2 2 0 31 [ 1.766307][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x1 2 15 0 [ 1.772905][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x2 1 0 6 [ 1.779414][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x1 1 0 0 [ 1.785924][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x2 1 0 11 [ 1.792521][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x1 1 5 0 [ 1.799069][ T1] [cbm] { cbm_xrx500_probe : 5850 }CBM: Init Done !! [ 1.800313][ T1] pstore: using zlib compression [ 1.811626][ T1] pstore: Registered ramoops as persistent store backend [ 1.818494][ T1] ramoops: attached 0x400000@0x20100000, ecc: 0/0 [ 1.856683][ T1] SCSI subsystem initialized [ 1.861751][ T1] usbcore: registered new interface driver usbfs [ 1.868082][ T1] usbcore: registered new interface driver hub [ 1.874080][ T1] usbcore: registered new device driver usb [ 1.880545][ T1] mp8864 0-0068: MP8864 probe started. [ 1.890830][ T1] mp8864 0-0068: [MP8864 Init] Status is 0x11 Vsel is 0x37 Syscntl is 0xe5 [ 1.899138][ T1] i2c-gpio i2c: using pins 501 (SDA) and 502 (SCL) [ 1.905723][ T1] try to register spd_mon driver [ 1.905992][ T1] spdmon 16080110.speedm: base address: 0xb6080110 [ 1.917136][ T1] spdmon 16080110.speedm: PHY base address: 0x16080110 [ 1.924202][ T1] spdmon 16080110.speedm: spd_mon driver : init done !! [ 1.935299][ T1] spd_mon driver registered [ 1.940907][ T1] AVM PA for Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 1.940907][ T1] (early init) [ 1.957518][ T1] NET: Registered protocol family 8 [ 1.962459][ T1] NET: Registered protocol family 20 [ 1.968164][ T1] clocksource: Switched to clocksource gptc [ 1.998293][ T1] AppArmor: AppArmor Filesystem Enabled [ 2.007059][ T1] NET: Registered protocol family 2 [ 2.012266][ T1] IP idents hash table entries: 8192 (order: 4, 65536 bytes) [ 2.044571][ T1] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 2.052263][ T1] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.059455][ T1] TCP: Hash tables configured (established 4096 bind 4096) [ 2.066610][ T1] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.073125][ T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.080505][ T1] NET: Registered protocol family 1 [ 2.087266][ T1] yield_probe: cpu 0 irq 275 [ 2.091807][ T1] yield_probe: cpu 1 irq 276 [ 2.096161][ T1] yield_probe: cpu 2 irq 277 [ 2.100644][ T1] yield_probe: cpu 3 irq 278 [ 2.105163][ T1] yield_probe: interrupts set up [ 2.112349][ T1] audit: initializing netlink subsys (enabled) [ 2.118383][ T1] audit: type=2000 audit(1.440:1): initialized [ 2.124755][ T1] No memory allocated for crashlog [ 2.130122][ T1] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 2.165855][ T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.172283][ T1] ANTFS Module: Version 2.56 [ 2.177030][ T1] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 2.190173][ T1] fuse init (API version 7.26) [ 2.203983][ T1] io scheduler noop registered [ 2.208483][ T1] io scheduler deadline registered (default) [ 2.214902][ T1] bthelper_probe: core 0 initialized [ 2.219912][ T1] bthelper_probe: core 1 initialized [ 2.227594][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe slim phy[0] init success! [ 2.236171][ T1] intel-pcie-slim-phy 18000000.pciephy: PCIe slim phy[1] init success! [ 2.244613][ T1] intel-pcie-slim-phy 18a00000.pciephy: PCIe slim phy[2] init success! [ 2.253125][ T1] 1a400000.phy supply vbus not found, using dummy regulator [ 2.260583][ T1] 1a600000.phy supply vbus not found, using dummy regulator [ 2.376181][ T1] OF: PCI: host bridge /pcie@18900000 ranges: [ 2.382000][ T1] OF: PCI: MEM 0xb8000000..0xbaffffff -> 0xb8000000 [ 2.388642][ T1] OF: PCI: IO 0xbb800000..0xbb80ffff -> 0xbb800000 [ 2.397706][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe LCPLL SSC Mode Enabled [ 2.539143][ T1] intel-pcie 18900000.pcie: PCI host bridge to bus 0000:00 [ 2.546073][ T1] pci_bus 0000:00: root bus resource [bus 00-08] [ 2.552283][ T1] pci_bus 0000:00: root bus resource [mem 0xb8000000-0xbaffffff] [ 2.559919][ T1] pci_bus 0000:00: root bus resource [io 0xbb800000-0xbb80ffff] [ 2.567990][ T1] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.577272][ T1] pci 0000:00:00.0: PCI bridge to [bus 01-08] [ 2.583320][ T1] pci 0000:00:00.0: BAR 8: assigned [mem 0xb8000000-0xb81fffff] [ 2.590657][ T1] pci 0000:00:00.0: BAR 9: assigned [mem 0xb8200000-0xb82fffff pref] [ 2.598630][ T1] pci 0000:00:00.0: BAR 7: assigned [io 0xbb800000-0xbb800fff] [ 2.606188][ T1] pci 0000:01:00.0: BAR 0: assigned [mem 0xb8000000-0xb81fffff 64bit] [ 2.614265][ T1] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.619980][ T1] pci 0000:00:00.0: bridge window [io 0xbb800000-0xbb800fff] [ 2.627532][ T1] pci 0000:00:00.0: bridge window [mem 0xb8000000-0xb81fffff] [ 2.635082][ T1] pci 0000:00:00.0: bridge window [mem 0xb8200000-0xb82fffff pref] [ 2.643219][ T1] pcieport 0000:00:00.0: enabling device (0000 -> 0003) [ 2.650175][ T1] intel-pcie 18900000.pcie: Intel AXI PCIe Root Complex Port 0 Init Done [ 2.764190][ T1] OF: PCI: host bridge /pcie@18400000 ranges: [ 2.769991][ T1] OF: PCI: MEM 0xb4000000..0xb6ffffff -> 0xb4000000 [ 2.776650][ T1] OF: PCI: IO 0xb7800000..0xb780ffff -> 0xb7800000 [ 2.784457][ T1] intel-pcie-slim-phy 18000000.pciephy: SSC has been enabled, count: 2! [ 3.900182][ T1] intel-pcie 18400000.pcie: intel_pcie_wait_phy_link_up port 1 timeout [ 3.908172][ T1] intel-pcie-slim-phy 18000000.pciephy: SSC in use, count: 1! [ 3.915578][ T1] intel-pcie: probe of 18400000.pcie failed with error -145 [ 4.028187][ T1] OF: PCI: host bridge /pcie@18e00000 ranges: [ 4.033978][ T1] OF: PCI: MEM 0xbc000000..0xbeffffff -> 0xbc000000 [ 4.040643][ T1] OF: PCI: IO 0xbf800000..0xbf80ffff -> 0xbf800000 [ 4.048442][ T1] intel-pcie-slim-phy 18a00000.pciephy: SSC has been enabled, count: 2! [ 4.178168][ T1] intel-pcie 18e00000.pcie: PCI host bridge to bus 0002:00 [ 4.185136][ T1] pci_bus 0002:00: root bus resource [bus 00-08] [ 4.191308][ T1] pci_bus 0002:00: root bus resource [mem 0xbc000000-0xbeffffff] [ 4.198945][ T1] pci_bus 0002:00: root bus resource [io 0xbf800000-0xbf80ffff] [ 4.207050][ T1] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.216355][ T1] pci 0002:00:00.0: PCI bridge to [bus 01-08] [ 4.222446][ T1] pci 0002:00:00.0: BAR 8: assigned [mem 0xbc000000-0xbc7fffff] [ 4.229788][ T1] pci 0002:00:00.0: BAR 9: assigned [mem 0xbc800000-0xbc8fffff pref] [ 4.237761][ T1] pci 0002:00:00.0: BAR 7: assigned [io 0xbf800000-0xbf800fff] [ 4.245316][ T1] pci 0002:01:00.0: BAR 0: assigned [mem 0xbc000000-0xbc7fffff] [ 4.252867][ T1] pci 0002:00:00.0: PCI bridge to [bus 01] [ 4.258588][ T1] pci 0002:00:00.0: bridge window [io 0xbf800000-0xbf800fff] [ 4.266141][ T1] pci 0002:00:00.0: bridge window [mem 0xbc000000-0xbc7fffff] [ 4.273692][ T1] pci 0002:00:00.0: bridge window [mem 0xbc800000-0xbc8fffff pref] [ 4.281873][ T1] pcieport 0002:00:00.0: enabling device (0000 -> 0003) [ 4.288760][ T1] intel-pcie 18e00000.pcie: Intel AXI PCIe Root Complex Port 2 Init Done [ 4.298823][ T1] [mips_tc_init] dma_zalloc_coherent dev->name=(null) sizeof(struct mips_tc_sg_mem)=1680 shared_phy_mem=0x2380b000 [ 4.310610][ T1] [mips_tc_init] dma_zalloc_coherent shared_vir_uncached_mem=a380b000 shared_vir_cached_mem=8380b000 shared_working_vir_mem=8380b000 [ 4.324392][ T1] =MIPS TC Shared memory: a380b000 8380b000 8380b000 | Data: a3810000 [ 4.332327][ T1] UMT initialize success on processor: 0 ! [ 4.337971][ T1] HW MCPY driver: Version: 1.1.0, Init Done! [ 4.344969][ T1] 16600000.serial: ttyLTQ0 at MMIO 0x16600000 (irq = 210, base_baud = 0) is a lantiq,asc [ 4.354691][ T1] console [ttyLTQ0] enabled [ 4.354691][ T1] console [ttyLTQ0] enabled [ 4.363289][ T1] bootconsole [early0] disabled [ 4.363289][ T1] bootconsole [early0] disabled [ 4.373385][ T1] 16700000.serial: ttyLTQ1 at MMIO 0x16700000 (irq = 213, base_baud = 0) is a lantiq,asc [ 4.383329][ T29] random: crng init done [ 4.386124][ T1] avm_net_trace: Up and running. [ 4.391327][ T1] [avm_power]avm_power_pm_qos_init [ 4.396100][ T1] [loadcontrol] set auto - scale=1 [ 4.400676][ T1] [avm] configured: watchdog event debug [ 4.400681][ T1] [ 4.408941][ T1] Register push button event to receive the set_factory_kernel event [ 4.417094][ T1] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0) [ 4.424508][ T1] [grx:watchdog] start on cpu0 [ 4.428292][ C1] [grx:watchdog] start on cpu1 [ 4.432854][ C2] [grx:watchdog] start on cpu2 [ 4.437452][ C3] [grx:watchdog] start on cpu3 [ 4.444519][ T1] brd: module loaded [ 4.448240][ T1] zram: Added device: zram0 [ 4.453565][ T1] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc [ 4.459190][ T1] nand: Macronix MX30LF4GE8AB [ 4.463679][ T1] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64 [ 4.471940][ T1] macronix_nand_ecc_init: enabling ECC (hidden_ecc: 0): [ 4.478699][ T1] nand_avm_init_fixup: applying nand options fixup [ 4.485054][ T1] Scanning device for bad blocks [ 5.132736][ T1] 5 fixed-partitions partitions found on MTD device 17c00000.nand-parts [ 5.139473][ T1] Creating 5 MTD partitions on "17c00000.nand-parts": [ 5.146103][ T1] 0x000000500000-0x000000d00000 : "kernel" [ 5.154077][ T1] 0x000000000000-0x000000100000 : "urlader" [ 5.160439][ T1] 0x000000100000-0x000000500000 : "nand-tffs" [ 5.166727][ T1] [TFFS3_Init] Called. [ 5.169226][ T1] [TFFS3_CACHE_Configure] Setting up caching for backend nand [ 5.176497][ T1] [TFFS3-CACHE] Caching module for TFFS 3.x [ 5.182216][ T1] [TFFS3-NAND] NAND storage backend for TFFS 3.x on mtd2 [ 5.523343][ T1] [TFFS3-NAND] Initialisation successful, 32/32/32 NAND blocks active, fill rate 13% [ 5.531257][ T1] tffs/panic: Reboot after panic detected [ 5.536779][ T1] [TFFS_Cache] Allocate segement buffer cache (size=2024) [ 5.545307][ T1] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0) [ 5.554389][ T1] [TFFS3-NANDSTAT][tffs_erase_stat_init] Erase counts: (min/max/mean): 367/4682/3307 - 0 bad blocks [ 5.563649][ T1] 0x000000d00000-0x000001500000 : "reserved-kernel" [ 5.571890][ T1] 0x000001500000-0x000020000000 : "ubi" [ 5.595304][ T1] lro_sram_membase_res0 from DT: a2013000 [ 5.599818][ T1] ltq_toe_membase: e2000000 and lro_sram_membase_res0: e2013000 [ 5.607618][ T1] TOE Init Done !! [ 6.256862][ T1] i2c /dev entries driver [ 6.261721][ T1] ltq_thermal 16000000.ssx4:ts@080000: ltq_thermal_probe: is done [ 6.272902][ T1] AVM PA 2.179-master for Linux Linux version 4.9.337 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g4d8c6f1f) ) #1 SMP 2025-07-10 [ 6.272902][ T1] (late init) [ 6.289621][ T1] Mirror/redirect action on [ 6.293332][ T1] u32 classifier [ 6.296655][ T1] Performance counters on [ 6.301162][ T1] input device check on [ 6.305503][ T1] Actions configured [ 6.309825][ T1] ipip: IPv4 and MPLS over IPv4 tunneling driver [ 6.316710][ T1] Initializing XFRM netlink socket [ 6.320774][ T1] IPsec XFRM device driver [ 6.326760][ T1] NET: Registered protocol family 10 [ 6.333242][ T1] NET: Registered protocol family 17 [ 6.337088][ T1] NET: Registered protocol family 15 [ 6.342422][ T1] Bridge flood ratelimiter registered [ 6.347351][ T1] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 6.360936][ T1] lec:lane_module_init: lec.c: initialized [ 6.366547][ T1] mpoa:atm_mpoa_init: mpc.c: initialized [ 6.372054][ T1] KOAM is loaded successfully. [ 6.376699][ T1] l2tp_core: L2TP core driver, V2.0 [ 6.381644][ T1] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 6.388198][ T1] l2tp_netlink: L2TP netlink interface [ 6.393315][ T1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 6.399796][ T1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 6.407174][ T1] 8021q: 802.1Q VLAN Support v1.8 [ 6.413876][ T1] audit: type=1400 audit(5.736:2): apparmor="STATUS" info="AppArmor sha1 policy hashing enabled" pid=1 comm="swapper/0" [ 6.424805][ T1] AppArmor: AppArmor sha1 policy hashing enabled [ 6.435112][ T1] ubi0: attaching mtd4 [ 7.085328][ T1] ubi0: scanning is finished [ 7.125866][ T1] ubi0: attached mtd4 (name "ubi", size 491 MiB) [ 7.130641][ T1] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 7.138156][ T1] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 7.145620][ T1] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 7.153258][ T1] ubi0: good PEBs: 3928, bad PEBs: 0, corrupted PEBs: 0 [ 7.160033][ T1] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128 [ 7.167962][ T1] ubi0: max/mean erase counter: 38/25, WL threshold: 4096, image sequence number: 1435277261 [ 7.177921][ T1] ubi0: available PEBs: 0, total reserved PEBs: 3928, PEBs reserved for bad PEB handling: 80 [ 7.187923][ T695] ubi0: background thread "ubi_bgt0d" started, PID 695 [ 7.189647][ T1] [announce_root] filesystem (/dev/mtdblock5) will be used as[ 7.211137][ T1] VFS: Mounted root (squashfs filesystem) readonly on device 31:5. [ 7.222837][ T1] devtmpfs: mounted [ 7.231352][ T1] Freeing unused kernel: 1688k freed [ 7.235103][ T1] This architecture does not have kernel memory protection. [ 8.593655][ T733] eip123_hw: loading out-of-tree module taints kernel. [ 8.598967][ T733] eip123_hw: module license 'Proprietary' taints kernel. [ 8.605857][ T733] Disabling lock debugging due to kernel taint [ 8.612392][ T733] [module-mem] give 0x5000 bytes at 9f0cd000 to module 'eip123_hw' (0xb46000 bytes left) [ 8.649139][ T733] [module-mem] give 0x2000 bytes at 9f0d2000 to module 'eip123' (0xb44000 bytes left) [ 8.657347][ T733] eip123: no symbol version for eip123_hw_asset_derive [ 8.664762][ T733] eip123 1e000000.eip123: Detected hardware version 2.2.2 [ 8.670762][ T733] eip123 1e000000.eip123: my_id=3 master_id=0 num_mailboxes=4 mailbox_size=256 [ 8.679509][ T733] eip123 1e000000.eip123: Linked mailbox number 1 [ 8.712199][ T733] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=3 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0 [ 8.808297][ T733] eip123 1e000000.eip123: Device responded with error_src=0x2 error=0x2 opcode=0x11 [ 9.120272][ T733] eip123 1e000000.eip123: eip123_hw init successful [ 9.180279][ T733] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c [ 9.188176][ T733] eip123 1e000000.eip123: Could not find rootkey in OTP [ 10.198822][ T0] [0]system-load 34% loadavg 0.8 0.2 0.1 - pgstat: sum=113116 free=101089 slab=2384 alloc=1058/s fault=329/s ai_sys:0.40/s 0x9f0ce6bc endian_convert_array+0x30/0x3c [eip12 (sleep 1) [ 10.528535][ T784] [1]system-load 31% loadavg 0.8 0.2 0.1 - task runtime:25% max:ar7cfgctl 15% pgstat: sum=113116 free=100895 slab=2394 alloc=1104/s fault=336/s (sleep 3) [ 12.379996][ T799] [module-mem] module 'hui' reserved size 188416 is to great for demand size 180224 - waste 8192 (module_alloc_waste=8192) [ 12.391244][ T799] [module-mem] give 0x2c000 bytes at 9f0d4000 to module 'hui' (0xb18000 bytes left) [ 12.407248][ T799] [hui] Initialize hardware user interface [ 12.416559][ T799] [avm_connect][state_machine_init] starting event worker thread [ 12.686085][ T845] [avm_debug] redirecting kernel-messages [ 44.699172][ C1] avm_set_reset_status: NMI-Watchdog-Reset(NMI) - NMI(3)UP(44)UTC(44)FW(08.20)HW(226)HWS(4)BV(1.3578)BN(122916)FS(08.20)BT(1)BD(0) [ 44.711494][ C1] CPU1 NMI taken (err)epc=0x93d352f8 __udelay+0x48/0x58 [#1]: [ 44.718387][ C1] CPU: 1 PID: 1482 Comm: modprobe Tainted: P O 4.9.337 #1 [ 44.726452][ C1] task: 9e25ae60 task.stack: 9d588000 [ 44.731656][ C1] $ 0 : 00000000 00000001 000ec996 00106256 [ 44.737558][ C1] $ 4 : 00000001 ac778000 000b09b7 ffff00fe [ 44.743461][ C1] $ 8 : 00000100 0000fc00 00000000 000001c5 [ 44.749364][ C1] $12 : 00000000 00006000 00000000 003d0900 [ 44.755267][ C1] $16 : 00000001 bf2001c0 00000004 00ff0000 [ 44.761170][ C1] $20 : 00000001 ffffffff 9f140000 93d352b0 [ 44.767073][ C1] $24 : 00000000 93dec524 [ 44.772976][ C1] $28 : 9d588000 9d58ba40 9f1396ec 9f135d0c [ 44.778879][ C1] Hi : 000b09b7 [ 44.782439][ C1] Lo : af250000 [ 44.785999][ C1] ac1Hi: 00000000 ac1Lo: 00000000 [ 44.790860][ C1] ac2Hi: 00000000 ac2Lo: 00000000 [ 44.795721][ C1] ac3Hi: 00000000 ac3Lo: 00000000 [ 44.800582][ C1] dspcontrol: 00000000 [ 44.804487][ C1] Status: 1108fc03 KERNEL EXL IE [ 44.809352][ C1] Cause : 50800000 exc_code:0 [ 44.813960][ C1] epc : 93d352f8 0x93d352f8 __udelay+0x48/0x58 [ 44.820121][ C1] errepc: 93d352f8 0x93d352f8 __udelay+0x48/0x58 [ 44.826402][ C1] ra : 9f135d0c 0x9f135d0c dect_loader+0x2b8/0x1f2c [Piglet_noemif] [ 44.834351][ C1] Tainted: P O [ 44.838692][ C1] PrId : 0001a120 (MIPS interAptiv (multi)) [ 44.845030][ C1] Classified pointer on registers: [ 44.849457][ C1] $22 : 9f140000 xrx500_dcmode0_xmit+0x34/0x248 [dc_mode_hw] [ 44.856753][ C1] $23 : 93d352b0 __udelay+0x0/0x58 [ 44.861824][ C1] $25 : 93dec524 uart_poll_get_char+0x0/0x10c [ 44.867827][ C1] $28 : 9d588000 [threadinfo(modprobe): 9d588000+0x0] [ 44.874464][ C1] $29 : 9d58ba40 [stack(modprobe): 9d588000+0x3a40] [ 44.881017][ C1] $30 : 9f1396ec log_piglet+0x0/0x1e0 [Piglet_noemif] [ 44.887697][ C1] $31 : 9f135d0c dect_loader+0x2b8/0x1f2c [Piglet_noemif] [ 44.894681][ C1] Modules linked in: net_upstream_drv(O) offload_qos(O) offload_pa(O) offload_dp(O) ktestdrive(O) offload_util(O) kspeedtest(O) kdsldmod(PO) kskbtrace(O) cchardev(O) cprocfsmod(O) dc_mode_hw(O) Piglet_noemif(PO+) directconnect_datapath(O) ltq_eth_drv_xrx500 eip97(O) cpunet(O) xrx500_phy_fw vrx518(O) hui(O) eip123(O) eip123_hw(PO) [ 44.925418][ C1] Process modprobe (pid: 1482, threadinfo=9d588000, task=9e25ae60, tls=77a6dd9c) [ 44.934353][ C1] Stack : 00000000 9f13b824 00002580 ffff00fe 00000000 0000d982 00000001 93deac5c [ 44.943379][ C1] 941a384c 9f140000 93988478 c09b3000 9f1396ec c09f7986 c09f7982 00000001 [ 44.952407][ C1] 0000000a 00000000 00000002 00000001 00000000 ffffffff 00000000 939d0000 [ 44.961435][ C1] 00000001 9f13bfc8 9f13bfe4 00000000 9f140000 00000001 9f13da34 9f140000 [ 44.970463][ C1] 943d0000 00000000 9f13bfc8 9f13bfd0 9d588000 9d58bb18 9f1358cc 9f138218 [ 44.979491][ C1] ... [ 44.982653][ C1] Classified pointer on stack: [ 44.987221][ C1] 9f13b824 [module-alloc: 0x9f13b824 (Piglet_noemif + 0x7824) size: 45056] [ 44.995761][ C1] 93deac5c avm_tty_poll_get_char+0x0/0x1c [ 45.001222][ C1] 941a384c _cond_resched+0x0/0x48 [ 45.006066][ C1] 9f140000 xrx500_dcmode0_xmit+0x34/0x248 [dc_mode_hw] [ 45.012754][ C1] 93988478 ___might_sleep+0x0/0x11c [ 45.017848][ C1] c09b3000 [vmalloc : size:204800 start:c09b3000+0x0 alloced by:0x9f134e70 ihex2bin+0x60/0xabc [Piglet_noemif]] [ 45.029455][ C1] 9f1396ec log_piglet+0x0/0x1e0 [Piglet_noemif] [ 45.035544][ C1] c09f7986 [vmalloc : size:204800 start:c09ea000+0xd986 alloced by:0x9f134e70 ihex2bin+0x60/0xabc [Piglet_noemif]] [ 45.047436][ C1] c09f7982 [vmalloc : size:204800 start:c09ea000+0xd982 alloced by:0x9f134e70 ihex2bin+0x60/0xabc [Piglet_noemif]] [ 45.059449][ C1] 939d0000 hrtimer_run_queues+0x104/0x188 [ 45.064860][ C1] 9f13bfc8 [module-alloc: 0x9f13bfc8 (Piglet_noemif + 0x7fc8) size: 45056] [ 45.073255][ C1] 9f13bfe4 [module-alloc: 0x9f13bfe4 (Piglet_noemif + 0x7fe4) size: 45056] [ 45.081697][ C1] 9f140000 xrx500_dcmode0_xmit+0x34/0x248 [dc_mode_hw] [ 45.088382][ C1] 9f13da34 [module-alloc: 0x9f13da34 (Piglet_noemif + 0x9a34) size: 45056] [ 45.096780][ C1] 9f140000 xrx500_dcmode0_xmit+0x34/0x248 [dc_mode_hw] [ 45.103486][ C1] 9f13bfc8 [module-alloc: 0x9f13bfc8 (Piglet_noemif + 0x7fc8) size: 45056] [ 45.111884][ C1] 9f13bfd0 [module-alloc: 0x9f13bfd0 (Piglet_noemif + 0x7fd0) size: 45056] [ 45.120305][ C1] 9d588000 [threadinfo(modprobe): 9d588000+0x0] [ 45.126381][ C1] 9d58bb18 [stack(modprobe): 9d588000+0x3b18] [ 45.132328][ C1] 9f1358cc replace_tag+0x0/0x188 [Piglet_noemif] [ 45.138486][ C1] 9f138218 dect_file_process+0x898/0xc6c [Piglet_noemif] [ 45.145345][ C1] Call Trace: [ 45.148431][ C1] [<93d352f8>] 0x93d352f8 __udelay+0x48/0x58 [ 45.154300][ C1] [<9f135d0c>] 0x9f135d0c dect_loader+0x2b8/0x1f2c [Piglet_noemif] [ 45.162056][ C1] [<9f137d84>] 0x9f137d84 dect_file_process+0x404/0xc6c [Piglet_noemif] [ 45.170216][ C1] [<9f139cd0>] 0x9f139cd0 piglet_loader_thread+0xe8/0x5e8 [Piglet_noemif] [ 45.178551][ C1] [] 0xc09ae264 init_module+0x264/0x2d0 [Piglet_noemif] [ 45.186152][ C1] [<9392097c>] 0x9392097c do_one_initcall+0x5c/0x1c0 [ 45.192623][ C1] [<939ee6f4>] 0x939ee6f4 do_init_module+0x68/0x224 [ 45.199043][ C1] [<939f0d54>] 0x939f0d54 load_module+0x14ac/0x1690 [ 45.205466][ C1] [<939f1270>] 0x939f1270 SyS_finit_module+0xfc/0x138 [ 45.212075][ C1] [<939379a0>] 0x939379a0 syscall_common+0x34/0x54 [ 45.218393][ C1] Code: 70441802 00661021 00000000 <1440ffff> 2442ffff 03e00008 00000000 8f83000c 000310c0 [ 45.228805][ C1] [ 45.230988][ C1] ---- CPU_ID=0 CORE0 TC0 ----- (LINUX) [ 45.236364][ C1] Status: 1100fc00 KERNEL [ 45.240707][ C1] current: swapper/0 (pid: 0, threadinfo=943bc000, task=943db280, sp=943bfe48 tls=0x00000000) [ 45.250769][ C1] Call Trace: [ 45.253911][ C1] [<939286fc>] 0x939286fc r4k_wait_irqoff+0x20/0x40 [ 45.260344][ C1] [<939aac6c>] 0x939aac6c cpu_startup_entry+0x148/0x19c [ 45.267108][ C1] [<9458ac78>] 0x9458ac78 start_kernel+0x4ec/0x52c [ 45.273439][ C1] ---- CORE0 TC2 ----- (YIELD-Thread) [ 45.278641][ C1] current: CPU0-YIELD-TC2 (pid: 0, threadinfo=9ecfc000, task=9ecf8620, sp=9ecffec0 tls=0x00000000) [ 45.289137][ C1] Call Trace: [ 45.289141][ C1] [ 45.294496][ C1] Unhandled kernel unaligned access[#2]: [ 45.299909][ C1] CPU: 1 PID: 1482 Comm: modprobe Tainted: P D O 4.9.337 #1 [ 45.307978][ C1] task: 9e25ae60 task.stack: 9d588000 [ 45.313183][ C1] $ 0 : 00000000 00000000 00000000 588665ac [ 45.319086][ C1] $ 4 : 588665ac 00000001 00000000 93df1394 [ 45.324989][ C1] $ 8 : 00000018 00000000 00000000 315d5b20 [ 45.330892][ C1] $12 : 00000000 000004de 00000000 00000000 [ 45.336795][ C1] $16 : 9ecffec0 942c359c 943d0000 94360000 [ 45.342698][ C1] $20 : 00000000 9ecffec4 94750000 94750000 [ 45.348601][ C1] $24 : 00000018 00000000 [ 45.354504][ C1] $28 : 9d588000 9d58b5f8 94760000 9392d7dc [ 45.360408][ C1] Hi : 0000001c [ 45.363967][ C1] Lo : e8f5c303 [ 45.367527][ C1] ac1Hi: 00000000 ac1Lo: 00000000 [ 45.372388][ C1] ac2Hi: 00000000 ac2Lo: 00000000 [ 45.377249][ C1] ac3Hi: 00000000 ac3Lo: 00000000 [ 45.382110][ C1] dspcontrol: 00000000 [ 45.386016][ C1] Status: 1100fc02 KERNEL EXL [ 45.390619][ C1] Cause : 40800810 exc_code:4 AdEL [ 45.395565][ C1] BadVA : 9ecffec0 [ 45.399141][ C1] epc : 9392d8d0 0x9392d8d0 show_backtrace+0x194/0x1c4 [ 45.405991][ C1] errepc: 93d352f8 0x93d352f8 __udelay+0x48/0x58 [ 45.412155][ C1] ra : 9392d7dc 0x9392d7dc show_backtrace+0xa0/0x1c4 [ 45.418917][ C1] Tainted: P D O [ 45.423258][ C1] PrId : 0001a120 (MIPS interAptiv (multi)) [ 45.429241][ C1] Classified pointer on registers: [ 45.434023][ C1] $ 7 : 93df1394 lqasc_console_putchar+0x0/0x2c [ 45.440391][ C1] $16 : 9ecffec0 [page O3[7]: type:alloc] [ 45.445882][ C1] $21 : 9ecffec4 [page O3[7]: type:alloc] [ 45.451529][ C1] $28 : 9d588000 [threadinfo(modprobe): 9d588000+0x0] [ 45.458163][ C1] $29 : 9d58b5f8 [stack(modprobe): 9d588000+0x35f8] [ 45.464675][ C1] $31 : 9392d7dc show_backtrace+0xa0/0x1c4 [ 45.470392][ C1] Modules linked in: net_upstream_drv(O) offload_qos(O) offload_pa(O) offload_dp(O) ktestdrive(O) offload_util(O) kspeedtest(O) kdsldmod(PO) kskbtrace(O) cchardev(O) cprocfsmod(O) dc_mode_hw(O) Piglet_noemif(PO+) directconnect_datapath(O) ltq_eth_drv_xrx500 eip97(O) cpunet(O) xrx500_phy_fw vrx518(O) hui(O) eip123(O) eip123_hw(PO) [ 45.501129][ C1] Process modprobe (pid: 1482, threadinfo=9d588000, task=9e25ae60, tls=77a6dd9c) [ 45.510064][ C1] Stack : 9d58b60c 00000000 00000afb 00000000 94307da0 9ecffec0 deadbeef 588665ac [ 45.519091][ C1] 943d0000 943d0000 00000000 94750000 00000002 94756930 9d58b748 93d335a0 [ 45.528119][ C1] 94736c98 9ecf895c 00000000 9ecfc000 9ecf8620 9ecffec0 00000008 00000000 [ 45.537147][ C1] 00000002 94756930 94307d58 94732558 94307d0c 94210000 94300000 9ecfc000 [ 45.546176][ C1] 9ecf8620 00000000 94307c3c 00000000 00000034 00000000 00000000 80000001 [ 45.555204][ C1] ... [ 45.558337][ C1] Classified pointer on stack: [ 45.562933][ C1] 9d58b60c [stack(modprobe): 9d588000+0x360c] [ 45.568932][ C1] 9ecffec0 [page O3[7]: type:alloc] [ 45.573908][ C1] 9d58b748 [stack(modprobe): 9d588000+0x3748] [ 45.579781][ C1] 93d335a0 arch_trigger_all_cpu_backtrace+0x3b4/0x430 [ 45.586400][ C1] 9ecf895c [page O3[0]: type:alloc] [ 45.591455][ C1] 9ecfc000 [page O3[4]: type:alloc] [ 45.596468][ C1] 9ecf8620 [page O3[0]: type:alloc] [ 45.601503][ C1] 9ecffec0 [page O3[7]: type:alloc] [ 45.606595][ C1] 9ecfc000 [page O3[4]: type:alloc] [ 45.611572][ C1] 9ecf8620 [page O3[0]: type:alloc] [ 45.616716][ C1] 80000001 [page: type:alloc] [ 45.621119][ C1] 80000000 [page: type:alloc] [ 45.625664][ C1] 9d58b7c0 [stack(modprobe): 9d588000+0x37c0] [ 45.631545][ C1] 9f140000 xrx500_dcmode0_xmit+0x34/0x248 [dc_mode_hw] [ 45.638193][ C1] Call Trace: [ 45.641329][ C1] [<9392d8d0>] 0x9392d8d0 show_backtrace+0x194/0x1c4 [ 45.647842][ C1] [<93d335a0>] 0x93d335a0 arch_trigger_all_cpu_backtrace+0x3b4/0x430 [ 45.655755][ C1] [<93e190cc>] 0x93e190cc die_notifier+0x144/0x194 [ 45.662087][ C1] [<9397f84c>] 0x9397f84c notifier_call_chain+0x6c/0xb0 [ 45.668848][ C1] [<9397f964>] 0x9397f964 __atomic_notifier_call_chain+0x24/0x3c [ 45.676402][ C1] [<93980290>] 0x93980290 notify_die+0x50/0x80 [ 45.682390][ C1] [<9392daec>] 0x9392daec die+0x4c/0x12c [ 45.687875][ C1] [<93e20b88>] 0x93e20b88 nmi_notify_last+0x68/0x74 [ 45.694283][ C1] [<9397f84c>] 0x9397f84c notifier_call_chain+0x6c/0xb0 [ 45.701054][ C1] [<9397fa74>] 0x9397fa74 raw_notifier_call_chain+0x14/0x20 [ 45.708175][ C1] [<9392f638>] 0x9392f638 nmi_exception_handler+0x74/0xa8 [ 45.715116][ C1] [<93926b18>] 0x93926b18 nmi_handler+0x14c/0x154 [ 45.721361][ C1] Code: 0ce55768 00000000 02801025 <7e10002f> 1000ffcb 00000000 0ce5ee95 02002025 10400004 [ 45.731772][ C1] [ 45.733949][ C1] ---[ end trace 5ea6fb4d9ea40b4f ]--- [ 45.768843][ C1] Kernel panic - not syncing: Fatal exception in interrupt [ 45.774529][ C1] Kernel relocated by 0x13420000 [ 45.779188][ C1] .text @ 0x93920000 [ 45.783008][ C1] .data @ 0x941e2874 [ 45.786827][ C1] .bss @ 0x94730000 [ 45.820138][ C1] Rebooting in 1 seconds..
