----------------------------BEGIN_WLAN_SUBSYSTEM_LOG---------------------------- --BEGIN_META-- module: wland_ath class: WLAN-Subsystem Restart count: 1 reason: Error getting channel list --END_META-- --BEGIN_WLAND_GENERAL-- wland boot time: 01.01.1970 01:00:50/[50.680] Clock resolution: 0 sec, 1 nsec Used FD count: 27 Country: 049, Language: de Last transaction from : reconfig event: 01.01.1970 01:00:00/[0.000] commit start: 01.01.1970 01:00:00/[0.000] commit success: 01.01.1970 01:00:00/[0.000] device_opmode=AP Active clients: 0 Disconnected clients: 0 Cfgex master status count: 0, time: 01.01.1970 01:00:00/[0.000] Cfgex slave count: 0, applied count: 0, applied fail count: 0, last was not applied Last received version: 0, time: 01.01.1970 01:00:00/[0.000] Last applied version: 0, time: 01.01.1970 01:00:00/[0.000] Nexus comm state: master, id: 44:4e:6d:69:78:93 Init count ok: 1, fail: 0 FD count connected: 0, closed: 0 FD time last connected: 01.01.1970 01:00:00/[0.000], closed: 01.01.1970 01:00:00/[0.000] --END_WLAND_GENERAL-- --BEGIN_WLANCFG_SSIDS-- ssid = "4ghz"; ssid_scnd = "5ghz"; ssid_thrd = "FRITZ!Box 7590 DS"; ssid_frth = "FRITZ!Box 7590 DS"; hidden_ssid = 0; WDS_ssid = ""; guest_ssid_set = no; guest_ssid = "FRITZ! Gastzugang"; STA_ssid = ""; STA_ssid_scnd = ""; STA_ssid_thrd = ""; STA_ssid_frth = ""; --END_WLANCFG_SSIDS-- --BEGIN_WLANCFG_EMPTY_PSKS-- Empty PSKs: guest_pskvalue STA_pskvalue STA_pskvalue_scnd STA_pskvalue_thrd STA_pskvalue_frth WLAN key is set in Urlader-Env --END_WLANCFG_EMPTY_PSKS-- --BEGIN_WLAND_SUPPORT-- 1970-01-01 01:00:50.682 - [50.682] [INFO ] main():733: BUILD: Jul 11 2025, 10:10:24 (has no little RAM) 1970-01-01 01:00:50.748 - [50.748] [INFO ] _nexus_comm_init():773: Initialize Nexus API (api=0) 1970-01-01 01:00:50.750 - [50.750] [INFO ] _wland_triggered_reboot_count_read():129: Reboot count: 0 1970-01-01 01:00:50.751 - [50.751] [INFO ] wlanser_config_init():999: ENTER(cfg_product='/etc/default/%s/wlan_product.cfg', cfg_profiles'/etc/default/%s/wlan_product_profiles.cfg', trans=0x0x76e51700) 1970-01-01 01:00:50.780 - [50.780] [ERROR] cfg_mgr_protected_global_settings_get():1196: Invalid NULL pointer 1970-01-01 01:00:50.781 - [50.781] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.781 - [50.781] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.781 - [50.781] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.781 - [50.781] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.781 - [50.781] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.782 - [50.781] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.782 - [50.782] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.782 - [50.782] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.782 - [50.782] [ERROR] cfg_get_highest_wlan_mode():202: Valuedef for wlan mode not found! 1970-01-01 01:00:50.782 - [50.782] [INFO ] wlanser_config_init():1020: Read and apply product config: Init transaction succeeded 1970-01-01 01:00:50.814 - [50.814] [INFO ] wland_nexus_mgr_init():95: Nexus Role not known yet, but will be propagated later via nexus role observer. 1970-01-01 01:00:56.155 - [56.155] [INFO ] wland_hal: handle_nl_ifname_event():754: No HW found for lan 1970-01-01 01:00:56.517 - [56.517] [ERROR] station_module: sta_module_get_role_state_info():6031: Role '301' is in state 'UNCONFIGURED', no role infos can be collected. 1970-01-01 01:00:56.517 - [56.517] [ERROR] get_role_state_info():242: sta_module_get_role_state_info() failed for role '301'! 1970-01-01 01:00:56.522 - [56.521] [ERROR] station_module: sta_module_get_role_state_info():6031: Role '302' is in state 'UNCONFIGURED', no role infos can be collected. 1970-01-01 01:00:56.522 - [56.522] [ERROR] get_role_state_info():242: sta_module_get_role_state_info() failed for role '302'! 1970-01-01 01:00:56.543 - [56.543] [ERROR] station_module: sta_module_get_role_state_info():6031: Role '308' is in state 'UNCONFIGURED', no role infos can be collected. 1970-01-01 01:00:56.543 - [56.543] [ERROR] get_role_state_info():242: sta_module_get_role_state_info() failed for role '308'! 1970-01-01 01:00:56.549 - [56.548] [ERROR] station_module: sta_module_get_role_state_info():6031: Role '309' is in state 'UNCONFIGURED', no role infos can be collected. 1970-01-01 01:00:56.549 - [56.549] [ERROR] get_role_state_info():242: sta_module_get_role_state_info() failed for role '309'! 1970-01-01 01:00:58.556 - [58.556] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 101! 1970-01-01 01:00:58.556 - [58.556] [ERROR] channel_mgr_channel_list_get():420: Failed to update channel list for radio 101, use stored. 1970-01-01 01:00:58.557 - [58.556] [ERROR] channel_mgr_channel_list_get():427: No channel list is available for radio 101! 1970-01-01 01:00:58.559 - [58.559] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 111! 1970-01-01 01:00:58.559 - [58.559] [ERROR] channel_mgr_channel_list_get():420: Failed to update channel list for radio 111, use stored. 1970-01-01 01:00:58.559 - [58.559] [ERROR] channel_mgr_channel_list_get():427: No channel list is available for radio 111! 1970-01-01 01:01:01.067 - [61.066] [INFO ] wland_hal: handle_nl_ifname_event():754: No HW found for lan 1970-01-01 01:01:01.067 - [61.067] [INFO ] wland_hal: handle_nl_ifname_event():754: No HW found for lan 1970-01-01 01:01:01.070 - [61.069] [INFO ] wland_hal: handle_nl_ifname_event():754: No HW found for guest 1970-01-01 01:01:01.071 - [61.070] [INFO ] wland_hal: handle_nl_ifname_event():754: No HW found for guest 1970-01-01 01:01:14.585 - [74.585] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 101! 1970-01-01 01:01:14.585 - [74.585] [ERROR] channel_mgr_channel_list_get():420: Failed to update channel list for radio 101, use stored. 1970-01-01 01:01:14.586 - [74.586] [ERROR] channel_mgr_channel_list_get():427: No channel list is available for radio 101! 1970-01-01 01:01:14.587 - [74.587] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 111! 1970-01-01 01:01:14.588 - [74.587] [ERROR] channel_mgr_channel_list_get():420: Failed to update channel list for radio 111, use stored. 1970-01-01 01:01:14.588 - [74.588] [ERROR] channel_mgr_channel_list_get():427: No channel list is available for radio 111! 1970-01-01 01:01:30.608 - [90.607] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 101! 1970-01-01 01:01:30.608 - [90.608] [ERROR] channel_mgr_channel_list_get():420: Failed to update channel list for radio 101, use stored. 1970-01-01 01:01:30.608 - [90.608] [ERROR] channel_mgr_channel_list_get():427: No channel list is available for radio 101! 1970-01-01 01:01:30.610 - [90.610] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 111! 1970-01-01 01:01:30.610 - [90.610] [ERROR] channel_mgr_channel_list_get():420: Failed to update channel list for radio 111, use stored. 1970-01-01 01:01:30.610 - [90.610] [ERROR] channel_mgr_channel_list_get():427: No channel list is available for radio 111! 1970-01-01 01:01:46.621 - [106.621] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 101! 1970-01-01 01:01:46.622 - [106.621] [ERROR] channel_mgr_channel_list_get():420: Failed to update channel list for radio 101, use stored. 1970-01-01 01:01:46.622 - [106.622] [ERROR] channel_mgr_channel_list_get():427: No channel list is available for radio 101! 1970-01-01 01:01:46.622 - [106.622] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 111! 1970-01-01 01:01:46.623 - [106.622] [ERROR] channel_mgr_channel_list_get():420: Failed to update channel list for radio 111, use stored. 1970-01-01 01:01:46.623 - [106.623] [ERROR] channel_mgr_channel_list_get():427: No channel list is available for radio 111! 1970-01-01 01:01:53.904 - [113.903] [ERROR] wland_hal: wifi_registration_timer_cb():293: wait for hardware interfaces timed out 1970-01-01 01:01:53.905 - [113.905] [ERROR] wland_hal: lib_hal_env_get_channel_list():509: WLAN hardware not yet initialized 1970-01-01 01:01:53.905 - [113.905] [ERROR] channel_mgr_hal_channel_list_get():209: Currently not able to fetch channel list from HAL for radio 101, status: FAIL_NOT_APPLICABLE 1970-01-01 01:01:53.905 - [113.905] [ERROR] _channel_mgr_channel_list_update():105: channel_mgr_hal_channel_list_get() failed for radio 101! 1970-01-01 01:01:53.905 - [113.905] [ERROR] _channel_mgr_handle_cfg_state_update():318: Failed to update channel list for radio 101! --END_WLAND_SUPPORT-- --BEGIN_ACS_DECISION_INFO-- --END_ACS_DECISION_INFO-- --BEGIN_DEV_DEBUG-- 1.633446][ T575] Support not added yet for Service 92 [ 61.633453][ T575] No EXT_MSG send INIT now [ 61.633501][ T575] chunk 0 len 13568 requested , ptr 0x25a6c000 [ 61.633516][ T575] chunk 1 len 54272 requested , ptr 0x25b80000 [ 61.633528][ T575] chunk 2 len 217088 requested , ptr 0x25b90000 [ 61.633540][ T575] chunk 3 len 32768 requested , ptr 0x25b78000 [ 61.633553][ T575] chunk 4 len 1080656 requested , ptr 0x25bd0000 [ 61.633565][ T575] chunk 5 len 107520 requested , ptr 0x25ce0000 [ 61.633577][ T575] chunk 6 len 12288 requested , ptr 0x25bc8000 [ 61.633590][ T575] chunk 7 len 1041216 requested , ptr 0x25d00000 [ 61.633601][ T575] chunk 8 len 0 requested , ptr 0x25af0000 [ 61.634254][ T575] smart_log_init: Smart logging Enabled buf=9db20000 (size=65536) [ 61.634278][ T575] Not enabling smart log FW initiated packetlog feature since packetlog is not available at host [ 61.646779][ C0] wmi_control_rx :event handler is not registered: event id 0x9047 [ 61.681103][ C0] wmi_control_rx :event handler is not registered: event id 0x9047 [ 61.694715][ C0] wmi_control_rx :event handler is not registered: event id 0x9047 [ 61.708433][ C0] wmi_control_rx :event handler is not registered: event id 0x9047 [ 61.713625][ C0] Version = 16777216 3 status = 0 [ 61.713760][ T154] ol_ath_connect_htc() WMI is ready [ 61.713912][ T154] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0 [ 61.713931][ C0] target uses HTT version 2.2; host uses 2.2 [ 61.719986][ T154] ol_ath_attach() connect HTC. [ 61.720002][ T154] bypasswmi : 0 [ 61.720028][ T154] ol_regdmn_start: reg-domain param: regdmn=0, countryName=, wModeSelect=FFFFFFFF, netBand=FFFFFFFF, extendedChanMode=0. [ 61.720118][ T154] ol_regdmn_init_channels: !avail mode 0x7f9001 (0x2) flags 0x2150 [ 61.720225][ T154] ol_regdmn_init_channels: !avail mode 0x7f9001 (0x4) flags 0xa0 [ 61.720240][ T154] ol_regdmn_init_channels: !avail mode 0x7f9001 (0x8) flags 0xc0 [ 61.720255][ T154] ol_regdmn_init_channels: !avail mode 0x7f9001 (0x20) flags 0xd0 [ 61.720270][ T154] ol_regdmn_init_channels: !avail mode 0x7f9001 (0x40) flags 0x150 [ 61.720285][ T154] ol_regdmn_init_channels: !avail mode 0x7f9001 (0x800) flags 0x10080 [ 61.720298][ T154] ol_regdmn_init_channels: !avail mode 0x7f9001 (0x2000) flags 0x20080 [ 61.720312][ T154] ol_regdmn_init_channels: !avail mode 0x7f9001 (0x4000) flags 0x40080 [ 61.720525][ T154] Add VHT80 channel: 5210 [ 61.720534][ T154] Add VHT80 channel: 5290 [ 61.720544][ T154] Add VHT80 channel: 5530 [ 61.720552][ T154] Add VHT80 channel: 5610 [ 61.720561][ T154] Add VHT80 channel: 5690 [ 61.720571][ T154] Add VHT80 channel: 5775 [ 61.720628][ T154] Skipping VHT80 channel 5825 [ 61.720658][ T154] Add VHT160/VHT80_80 pri80 and sec80 centers: 5210,5290 [ 61.720668][ T154] Add VHT160/VHT80_80 pri80 and sec80 centers: 5290,5210 [ 61.720680][ T154] Add VHT160/VHT80_80 pri80 and sec80 centers: 5530,5610 [ 61.720690][ T154] Add VHT160/VHT80_80 pri80 and sec80 centers: 5610,5530 [ 61.723733][ T154] ol_ath_phyerr_attach: called [ 61.723777][ T154] AVM/WLAN: cc=840. Clearing potential non valid maxpwr entries [ 61.723972][ T154] freq=58 [ 61.723987][ T154] freq=106 [ 61.723995][ T154] freq=122 [ 61.724208][ T154] OL Resmgr Init-ed [ 61.724785][ T154] ieee80211_cbs_init [ 61.724795][ T154] CBS Inited [ 61.724825][ T154] ieee80211_bsteering_attach: Band steering initialized [ 61.724935][ T154] acfg_attach: 3075: Netlink socket created:950361c0 [ 61.724959][ T154] ol_if_spectral_setup [ 61.725027][ T154] SPECTRAL : get_capability not registered [ 61.725035][ T154] HAL_CAP_PHYDIAG : Capable [ 61.725050][ T154] SPECTRAL : Need to fix the capablity check for RADAR (spectral_attach : 242) [ 61.725058][ T154] SPECTRAL : get_capability not registered [ 61.725065][ T154] HAL_CAP_RADAR : Capable [ 61.725079][ T154] SPECTRAL : Need to fix the capablity check for SPECTRAL (spectral_attach : 247) [ 61.725087][ T154] SPECTRAL : get_capability not registered [ 61.725095][ T154] HAL_CAP_SPECTRAL_SCAN : Capable [ 61.725105][ T154] SPECTRAL : get_tsf64 not registered [ 61.725145][ T154] spectral_init_netlink 85 NULL SKB [ 61.725171][ T154] GreenAP on wifi0: Attached [ 61.725180][ T154] Green-AP : Attached [ 61.725189][ T154] rate power table override is only supported for AR98XX [ 61.725383][ T154] ol_if_dfs_setup: called [ 61.725564][ T154] ol_if_dfs_attach: called; ptr=9db3198c, radar_info=9fd5fadc [ 61.725577][ T154] dfs_attach: event log enabled by default [ 61.728569][ T154] ol_ath_rtt_meas_report_attach: called [ 61.728594][ T154] ol_ath_lowi_wmi_event_attach: called [ 61.728633][ T154] >>>> CB Set 00000000 [ 61.731166][ T154] ol_ath_attach() UMAC attach . [ 61.731181][ T154] BURSTING enabled by default [ 61.731529][ T154] ol_ath_attach: Set global_ic[1] ..ptr:9269c450 [ 61.731663][ T154] ath_lowi_if_netlink_init LOWI Netlink successfully created [ 61.731697][ T154] cfr_netlink_init CFR Netlink successfully created [ 61.731848][ T154] ath_adhoc_netlink_init NETLINK_KERNEL_CREATE FAILED [ 61.731910][ T154] osif_wrap_attach:455 osif wrap attached [ 61.731976][ T154] osif_wrap_devt_init:416 osif wrap dev table init done [ 61.731993][ T154] Wrap Attached: Wrap_com =95095f80 ic->ic_wrap_com=95095f80 &wrap_com->wc_devt=95095f80 [ 61.732010][ T154] __ol_ath_attach: needed_headroom reservation 60 [ 61.738473][ T154] AVM/WLAN: __ol_ath_thermal_mitigation_attach -> temperature callback registered for wifi0 as Wifi-5GHz! [ 61.738519][ T154] ol_ath_thermal_mitigation_attach: -- [ 61.738802][ T154] ol_ath_pci_probe num_radios=0, wifi_radios[0].sc = 9db804a0 wifi_radio_type = 2 [ 61.738893][ T154] ath_sysfs_diag_init: diag_fsattr [ 62.106887][ T0] [1]system-load 35% loadavg 1.93 0.56 0.20 - task runtime:11% max:kworker/u8:3 7% pgstat: sum=113116 free=63914 slab=6293 alloc=1783/s fault=1139/s (sleep 0) [ 62.599999][ T575] [wifi0] FWLOG: [60561] WAL_DBGID_RST_STATS ( 0x1, 0x1, 0x1464, 0x0 ) [ 62.600157][ T575] [wifi0] FWLOG: [60639] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 ) [ 62.600314][ T575] [wifi0] FWLOG: [60639] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 ) [ 62.600435][ T575] [wifi0] FWLOG: [60639] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 ) [ 62.600555][ T575] [wifi0] FWLOG: [60639] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 ) [ 62.600675][ T575] [wifi0] FWLOG: [60653] WAL_DBGID_PDEV_INFO_PRINT ( 0x16, 0xa10, 0x810, 0x10, 0x0 ) [ 62.600794][ T575] [wifi0] FWLOG: [60653] WAL_DBGID_PDEV_INFO_PRINT ( 0x16, 0x10, 0x0, 0x10, 0x12 ) [ 64.710165][ C0] Switching to Tx Mode-0 [ 65.151569][ T29] shm-rng-seed shm-rng-seed@3dfb0000: Credited 4088 bytes of entropy in the system pool [ 69.643708][ T2249] [module-mem] module 'xhci_hcd' reserved size 172032 is to great for demand size 163840 - waste 8192 (module_alloc_waste=229376) [ 69.643736][ T2249] [module-mem] give 0x28000 bytes at 927e9000 to module 'xhci_hcd' (0x16c000 bytes left) [ 69.684356][ T2252] [module-mem] give 0x2000 bytes at 92811000 to module 'xhci_plat_hcd' (0x16a000 bytes left) [ 69.685964][ T2252] xhci-hcd xhci-hcd.2.auto: no of_node; not parsing pinctrl DT [ 69.686085][ T2252] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 69.686135][ T2252] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 69.687622][ T2252] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f664 hci version 0x100 quirks 0x02010010 [ 69.687758][ T2252] xhci-hcd xhci-hcd.2.auto: irq 292, io mem 0x1a300000 [ 69.688152][ T2252] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 69.688165][ T2252] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 69.688175][ T2252] usb usb1: Product: xHCI Host Controller [ 69.688184][ T2252] usb usb1: Manufacturer: Linux 4.9.337 xhci-hcd [ 69.688193][ T2252] usb usb1: SerialNumber: xhci-hcd.2.auto [ 69.689110][ T2252] usb usb1: no of_node; not parsing pinctrl DT [ 69.689747][ T2252] hub 1-0:1.0: no of_node; not parsing pinctrl DT [ 69.689844][ T2252] hub 1-0:1.0: USB hub found [ 69.690003][ T2252] hub 1-0:1.0: 1 port detected [ 69.690935][ T2252] avm_net_trace: New net trace device 'usb1' registered with minor 201. [ 69.690973][ T2252] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 69.691007][ T2252] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 69.691065][ T2252] xHCI: delay VBUS POWER on for 100 ms [ 69.691789][ T34] avm_net_trace: udev device avm_net_trace201 created [ 69.692052][ T2252] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 69.692424][ T2252] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 69.692440][ T2252] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 69.692449][ T2252] usb usb2: Product: xHCI Host Controller [ 69.692458][ T2252] usb usb2: Manufacturer: Linux 4.9.337 xhci-hcd [ 69.692467][ T2252] usb usb2: SerialNumber: xhci-hcd.2.auto [ 69.693835][ T2252] usb usb2: no of_node; not parsing pinctrl DT [ 69.694674][ T2252] hub 2-0:1.0: no of_node; not parsing pinctrl DT [ 69.694902][ T2252] hub 2-0:1.0: USB hub found [ 69.695071][ T2252] hub 2-0:1.0: 1 port detected [ 69.695597][ T2252] AVM: disable USB3 bus#2 port#0 config=0 [ 69.696630][ T2252] avm_net_trace: New net trace device 'usb2' registered with minor 202. [ 69.696747][ T2252] xhci-hcd xhci-hcd.3.auto: no of_node; not parsing pinctrl DT [ 69.696993][ T2252] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 69.697075][ T2252] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3 [ 69.698736][ T34] avm_net_trace: udev device avm_net_trace202 created [ 69.704426][ T2252] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220f664 hci version 0x100 quirks 0x02010010 [ 69.704609][ T2252] xhci-hcd xhci-hcd.3.auto: irq 293, io mem 0x1a500000 [ 69.705668][ T2252] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 69.705698][ T2252] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 69.705716][ T2252] usb usb3: Product: xHCI Host Controller [ 69.705730][ T2252] usb usb3: Manufacturer: Linux 4.9.337 xhci-hcd [ 69.705744][ T2252] usb usb3: SerialNumber: xhci-hcd.3.auto [ 69.707160][ T2252] usb usb3: no of_node; not parsing pinctrl DT [ 69.708133][ T2252] hub 3-0:1.0: no of_node; not parsing pinctrl DT [ 69.708259][ T2252] hub 3-0:1.0: USB hub found [ 69.708464][ T2252] hub 3-0:1.0: 1 port detected [ 69.709287][ T2252] avm_net_trace: New net trace device 'usb3' registered with minor 203. [ 69.709329][ T2252] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 69.709375][ T2252] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4 [ 69.709428][ T2252] xHCI: delay VBUS POWER on for 100 ms [ 69.710017][ T2252] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 69.710613][ T2252] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 69.710643][ T2252] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 69.710657][ T2252] usb usb4: Product: xHCI Host Controller [ 69.710669][ T2252] usb usb4: Manufacturer: Linux 4.9.337 xhci-hcd [ 69.710683][ T2252] usb usb4: SerialNumber: xhci-hcd.3.auto [ 69.711764][ T29] avm_net_trace: udev device avm_net_trace203 created [ 69.713192][ T2252] usb usb4: no of_node; not parsing pinctrl DT [ 69.714107][ T2252] hub 4-0:1.0: no of_node; not parsing pinctrl DT [ 69.714206][ T2252] hub 4-0:1.0: USB hub found [ 69.714386][ T2252] hub 4-0:1.0: 1 port detected [ 69.714722][ T2252] AVM: disable USB3 bus#4 port#0 config=0 [ 69.715311][ T2252] avm_net_trace: New net trace device 'usb4' registered with minor 204. [ 69.720582][ T29] avm_net_trace: udev device avm_net_trace204 created [ 69.811519][ T29] xHCI: delayed VBUS POWER on --END_DEV_DEBUG-- --BEGIN_WPA_SUPP-- --END_WPA_SUPP-- --BEGIN_HOSTAPD-- --END_HOSTAPD-- --BEGIN_HOSTAPD_SOCKETS-- --END_HOSTAPD_SOCKETS-- --BEGIN_WPA_SUPP_SOCKETS-- --END_WPA_SUPP_SOCKETS-- --BEGIN_PCIDEV-- 0000 1bef0030 120 0 0 0 0 0 0 0 0 0 0 0 0 0 0 pcieport 0100 168c0046 120 b8000004 0 0 0 0 0 0 200000 0 0 0 0 0 0 ath_ol_pci 0000 1bef0030 121 0 0 0 0 0 0 0 0 0 0 0 0 0 0 pcieport 0100 808609a9 c8 bc000000 0 0 0 0 0 0 800000 0 0 0 0 0 0 vrx518 --END_PCIDEV-- ----------------------------END_WLAN_SUBSYSTEM_LOG---------------------------- Jan 1 1970 01:02:38 ctlmgr[1756]: [ERROR] dgramserver: 130(-) (allocated): bind([fd40:cf07:2a11::464e:6dff:fe69:7893]:1900) failed - Address not available (126) telefon: SIGCHLD PID 2539 received! telefon: SIGCHLD PID 2540 received!
