Socket_RecvFrom_Tcp: Test started Socket_RecvFrom_Tcp: Bound to TCP port 49194 Socket_RecvFrom_Tcp: Subtest " Check returned error codes " started Socket_RecvFrom_Tcp: Subtest " Check returned error codes " passed Socket_RecvFrom_Tcp: Subtest " Check expected recv length is reported" started Socket_RecvFrom_Tcp: Subtest " Check expected recv length is reported" passed Socket_RecvFrom_Tcp: Testing Receive with send data length 64 Socket_RecvFrom_Tcp: Transfer speed (receive) was 113.68 KByte/s Socket_RecvFrom_Tcp: Testing Receive with send data length 128 Socket_RecvFrom_Tcp: Transfer speed (receive) was 209.15 KByte/s Socket_RecvFrom_Tcp: Testing Receive with send data length 256 Socket_RecvFrom_Tcp: Transfer speed (receive) was 365.19 KByte/s Socket_RecvFrom_Tcp: Testing Receive with send data length 512 Socket_RecvFrom_Tcp: Transfer speed (receive) was 587.83 KByte/s Socket_RecvFrom_Tcp: Testing Receive with send data length 1024 Socket_RecvFrom_Tcp: Transfer speed (receive) was 856.90 KByte/s Socket_RecvFrom_Tcp: Testing Receive with send data length 1472 Socket_RecvFrom_Tcp: Transfer speed (receive) was 717.00 KByte/s Socket_RecvFrom_Tcp: Testing partial receive with send data length 64 Socket_RecvFrom_Tcp: Transfer speed (receive) was 35.42 KByte/s Socket_RecvFrom_Tcp: Testing partial receive with send data length 128 Socket_RecvFrom_Tcp: Transfer speed (receive) was 42.47 KByte/s Socket_RecvFrom_Tcp: Testing partial receive with send data length 256 Socket_RecvFrom_Tcp: Transfer speed (receive) was 50.28 KByte/s Socket_RecvFrom_Tcp: Testing partial receive with send data length 512 Socket_RecvFrom_Tcp: Transfer speed (receive) was 100.57 KByte/s Socket_RecvFrom_Tcp: Testing partial receive with send data length 1024 Socket_RecvFrom_Tcp: Transfer speed (receive) was 201.10 KByte/s Socket_RecvFrom_Tcp: Testing partial receive with send data length 1472 Socket_RecvFrom_Tcp: Transfer speed (receive) was 290.91 KByte/s Socket_RecvFrom_Tcp: Testing partial receive with send data length 1500 Socket_RecvFrom_Tcp: Transfer speed (receive) was 295.74 KByte/s Socket_RecvFrom_Tcp: Testing partial receive with send data length 2048 Socket_RecvFrom_Tcp: Transfer speed (receive) was 402.83 KByte/s Socket_RecvFrom_Tcp: Test PASSED Socket_RecvFrom_Udp: Test started Socket_RecvFrom_Udp: Bound to UDP port 49178 Socket_RecvFrom_Udp: Subtest " Check returned error codes " started Socket_RecvFrom_Udp: Subtest " Check returned error codes " passed Socket_RecvFrom_Udp: Testing Receive with data length 64 Socket_RecvFrom_Udp: Transfer speed (receive) was 125.24 KByte/s Socket_RecvFrom_Udp: Testing Receive with data length 128 Socket_RecvFrom_Udp: Transfer speed (receive) was 233.58 KByte/s Socket_RecvFrom_Udp: Testing Receive with data length 256 Socket_RecvFrom_Udp: Transfer speed (receive) was 398.13 KByte/s Socket_RecvFrom_Udp: Testing Receive with data length 512 Socket_RecvFrom_Udp: Transfer speed (receive) was 632.88 KByte/s Socket_RecvFrom_Udp: Testing Receive with data length 1024 Socket_RecvFrom_Udp: Transfer speed (receive) was 907.00 KByte/s Socket_RecvFrom_Udp: Testing Receive with data length 1472 Socket_RecvFrom_Udp: Transfer speed (receive) was 1051.43 KByte/s Socket_RecvFrom_Udp: Test PASSED Socket_SendTo_Udp: Test started Socket_SendTo_Udp: Bound to UDP port 52063 Socket_SendTo_Udp: Testing Send with data length 1 Socket_SendTo_Udp: Transfer speed (send) was 2.58 KByte/s Socket_SendTo_Udp: Testing Send with data length 2 Socket_SendTo_Udp: Transfer speed (send) was 5.18 KByte/s Socket_SendTo_Udp: Testing Send with data length 4 Socket_SendTo_Udp: Transfer speed (send) was 10.18 KByte/s Socket_SendTo_Udp: Testing Send with data length 8 Socket_SendTo_Udp: Transfer speed (send) was 20.46 KByte/s Socket_SendTo_Udp: Testing Send with data length 32 Socket_SendTo_Udp: Transfer speed (send) was 81.63 KByte/s Socket_SendTo_Udp: Testing Send with data length 64 Socket_SendTo_Udp: Transfer speed (send) was 160.00 KByte/s Socket_SendTo_Udp: Testing Send with data length 128 Socket_SendTo_Udp: Transfer speed (send) was 311.44 KByte/s Socket_SendTo_Udp: Testing Send with data length 256 Socket_SendTo_Udp: Transfer speed (send) was 577.88 KByte/s Socket_SendTo_Udp: Testing Send with data length 512 Socket_SendTo_Udp: Transfer speed (send) was 1036.44 KByte/s Socket_SendTo_Udp: Testing Send with data length 1024 Socket_SendTo_Udp: Transfer speed (send) was 1729.73 KByte/s Socket_SendTo_Udp: Testing Send with data length 1472 Socket_SendTo_Udp: Transfer speed (send) was 1875.16 KByte/s Socket_SendTo_Udp: Test PASSED Socket_SendTo_Tcp: Test started Socket_SendTo_Tcp: Subtest "Test single packet request" started Socket_SendTo_Tcp: Testing transmission with data length 64 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 1.32 KByte/s (Transferred 6.6 KByte) Socket_SendTo_Tcp: Testing transmission with data length 128 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 2.62 KByte/s (Transferred 13.1 KByte) Socket_SendTo_Tcp: Testing transmission with data length 256 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 5.26 KByte/s (Transferred 26.5 KByte) Socket_SendTo_Tcp: Testing transmission with data length 511 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 10.48 KByte/s (Transferred 52.9 KByte) Socket_SendTo_Tcp: Testing transmission with data length 512 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 10.50 KByte/s (Transferred 53.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 735 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 15.03 KByte/s (Transferred 75.4 KByte) Socket_SendTo_Tcp: Testing transmission with data length 736 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 15.08 KByte/s (Transferred 75.5 KByte) Socket_SendTo_Tcp: Testing transmission with data length 737 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 15.09 KByte/s (Transferred 75.6 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1024 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 20.95 KByte/s (Transferred 105.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1025 Socket_SendTo_Tcp: Early stop measurement due long delays Socket_SendTo_Tcp: Transfer speed (send) was 21.00 KByte/s (Transferred 105.1 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1459 Socket_SendTo_Tcp: Transfer speed (send) was 1282.07 KByte/s (Transferred 1459.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1460 Socket_SendTo_Tcp: Transfer speed (send) was 1264.07 KByte/s (Transferred 1460.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1461 Socket_SendTo_Tcp: Transfer speed (send) was 1270.43 KByte/s (Transferred 1461.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1472 Socket_SendTo_Tcp: Transfer speed (send) was 1277.78 KByte/s (Transferred 1472.0 KByte) Socket_SendTo_Tcp: Subtest "Test single packet request" passed Socket_SendTo_Tcp: Subtest "Test multi packet request with 2 packets" started Socket_SendTo_Tcp: Subtest "" started Socket_SendTo_Tcp: Testing transmission with data length 64 Socket_SendTo_Tcp: Transfer speed (send) was 137.65 KByte/s (Transferred 688.4 KByte) Socket_SendTo_Tcp: Testing transmission with data length 128 Socket_SendTo_Tcp: Transfer speed (send) was 266.92 KByte/s (Transferred 1346.9 KByte) Socket_SendTo_Tcp: Testing transmission with data length 256 Socket_SendTo_Tcp: Transfer speed (send) was 509.10 KByte/s (Transferred 2546.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 511 Socket_SendTo_Tcp: Transfer speed (send) was 940.57 KByte/s (Transferred 4703.8 KByte) Socket_SendTo_Tcp: Testing transmission with data length 512 Socket_SendTo_Tcp: Transfer speed (send) was 937.56 KByte/s (Transferred 4737.5 KByte) Socket_SendTo_Tcp: Testing transmission with data length 735 Socket_SendTo_Tcp: Transfer speed (send) was 1250.69 KByte/s (Transferred 6254.7 KByte) Socket_SendTo_Tcp: Testing transmission with data length 736 Socket_SendTo_Tcp: Transfer speed (send) was 1259.57 KByte/s (Transferred 6299.1 KByte) Socket_SendTo_Tcp: Testing transmission with data length 737 Socket_SendTo_Tcp: Transfer speed (send) was 1247.27 KByte/s (Transferred 6301.2 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1024 Socket_SendTo_Tcp: Transfer speed (send) was 1572.36 KByte/s (Transferred 7931.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1025 Socket_SendTo_Tcp: Transfer speed (send) was 1571.38 KByte/s (Transferred 7930.7 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1459 Socket_SendTo_Tcp: Transfer speed (send) was 1932.22 KByte/s (Transferred 9663.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1460 Socket_SendTo_Tcp: Transfer speed (send) was 1937.53 KByte/s (Transferred 9689.6 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1461 Socket_SendTo_Tcp: Transfer speed (send) was 1930.30 KByte/s (Transferred 9653.4 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1472 Socket_SendTo_Tcp: Transfer speed (send) was 1950.87 KByte/s (Transferred 9756.3 KByte) Socket_SendTo_Tcp: Subtest "" passed Socket_SendTo_Tcp: Subtest "Test multi packet request with 2 packets" passed Socket_SendTo_Tcp: Subtest "Test multi packet request with 3 packets" started Socket_SendTo_Tcp: Subtest "" started Socket_SendTo_Tcp: Testing transmission with data length 64 Socket_SendTo_Tcp: Transfer speed (send) was 146.11 KByte/s (Transferred 739.4 KByte) Socket_SendTo_Tcp: Testing transmission with data length 128 Socket_SendTo_Tcp: Transfer speed (send) was 285.58 KByte/s (Transferred 1443.9 KByte) Socket_SendTo_Tcp: Testing transmission with data length 256 Socket_SendTo_Tcp: Transfer speed (send) was 544.36 KByte/s (Transferred 2751.8 KByte) Socket_SendTo_Tcp: Testing transmission with data length 511 Socket_SendTo_Tcp: Transfer speed (send) was 1009.39 KByte/s (Transferred 5105.5 KByte) Socket_SendTo_Tcp: Testing transmission with data length 512 Socket_SendTo_Tcp: Transfer speed (send) was 1012.57 KByte/s (Transferred 5113.5 KByte) Socket_SendTo_Tcp: Testing transmission with data length 735 Socket_SendTo_Tcp: Transfer speed (send) was 1395.62 KByte/s (Transferred 7050.7 KByte) Socket_SendTo_Tcp: Testing transmission with data length 736 Socket_SendTo_Tcp: Transfer speed (send) was 1400.62 KByte/s (Transferred 7070.3 KByte) Socket_SendTo_Tcp: Testing transmission with data length 737 Socket_SendTo_Tcp: Transfer speed (send) was 1413.84 KByte/s (Transferred 7072.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1024 Socket_SendTo_Tcp: Transfer speed (send) was 1731.90 KByte/s (Transferred 8753.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1025 Socket_SendTo_Tcp: Transfer speed (send) was 1733.85 KByte/s (Transferred 8745.5 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1459 Socket_SendTo_Tcp: Transfer speed (send) was 2331.47 KByte/s (Transferred 11662.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1460 Socket_SendTo_Tcp: Transfer speed (send) was 2347.32 KByte/s (Transferred 11741.3 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1461 Socket_SendTo_Tcp: Transfer speed (send) was 2359.96 KByte/s (Transferred 11802.1 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1472 Socket_SendTo_Tcp: Transfer speed (send) was 2372.94 KByte/s (Transferred 11869.4 KByte) Socket_SendTo_Tcp: Subtest "" passed Socket_SendTo_Tcp: Subtest "Test multi packet request with 3 packets" passed Socket_SendTo_Tcp: Subtest "Test multi packet request with 4 packets" started Socket_SendTo_Tcp: Subtest "" started Socket_SendTo_Tcp: Testing transmission with data length 64 Socket_SendTo_Tcp: Transfer speed (send) was 165.99 KByte/s (Transferred 838.6 KByte) Socket_SendTo_Tcp: Testing transmission with data length 128 Socket_SendTo_Tcp: Transfer speed (send) was 331.93 KByte/s (Transferred 1660.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 256 Socket_SendTo_Tcp: Transfer speed (send) was 643.03 KByte/s (Transferred 3244.8 KByte) Socket_SendTo_Tcp: Testing transmission with data length 511 Socket_SendTo_Tcp: Transfer speed (send) was 1225.71 KByte/s (Transferred 6131.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 512 Socket_SendTo_Tcp: Transfer speed (send) was 1228.11 KByte/s (Transferred 6143.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 735 Socket_SendTo_Tcp: Transfer speed (send) was 1694.70 KByte/s (Transferred 8476.9 KByte) Socket_SendTo_Tcp: Testing transmission with data length 736 Socket_SendTo_Tcp: Transfer speed (send) was 1708.50 KByte/s (Transferred 8545.9 KByte) Socket_SendTo_Tcp: Testing transmission with data length 737 Socket_SendTo_Tcp: Transfer speed (send) was 1706.22 KByte/s (Transferred 8534.5 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1024 Socket_SendTo_Tcp: Transfer speed (send) was 2164.33 KByte/s (Transferred 10826.0 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1025 Socket_SendTo_Tcp: Transfer speed (send) was 2135.75 KByte/s (Transferred 10785.5 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1459 Socket_SendTo_Tcp: Transfer speed (send) was 2436.30 KByte/s (Transferred 12186.4 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1460 Socket_SendTo_Tcp: Transfer speed (send) was 2439.02 KByte/s (Transferred 12197.6 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1461 Socket_SendTo_Tcp: Transfer speed (send) was 2439.07 KByte/s (Transferred 12200.2 KByte) Socket_SendTo_Tcp: Testing transmission with data length 1472 Socket_SendTo_Tcp: Transfer speed (send) was 2459.44 KByte/s (Transferred 12302.1 KByte) Socket_SendTo_Tcp: Subtest "" passed Socket_SendTo_Tcp: Subtest "Test multi packet request with 4 packets" passed Socket_SendTo_Tcp: Closing remote socket Socket_SendTo_Tcp: Subtest "Test error on closed socket" started Socket_SendTo_Tcp: Send data on remotely closed socket Socket_SendTo_Tcp: Subtest "Test error on closed socket" passed Socket_SendTo_Tcp: Test PASSED
