''' ESPNow visualizer - Receives data from the serial line - Display graphics dynamically - saves data when closing the window made with the help of Perplexity 2026-01-31 mchris ''' import serial import csv import matplotlib.pyplot as plt import matplotlib.animation as animation from datetime import datetime, date import numpy as np import sys from collections import deque import matplotlib.dates as mdates # ------------------------------------------------------------ # Configuration # ------------------------------------------------------------ PORT = '/dev/ttyUSB0' BAUD = 115200 FILENAME = 'sensor_data.csv' MAX_POINTS = 10000 # ------------------------------------------------------------ # Data buffers # ------------------------------------------------------------ data_buffers = { 'temp': deque(maxlen=MAX_POINTS), 'pressure': deque(maxlen=MAX_POINTS), 'humidity': deque(maxlen=MAX_POINTS), 'vbat': deque(maxlen=MAX_POINTS), 'counter': deque(maxlen=MAX_POINTS), 'time': deque(maxlen=MAX_POINTS) # datetime objects for x‑axis } # ------------------------------------------------------------ # CSV initialization # ------------------------------------------------------------ with open(FILENAME, 'w', newline='') as csvfile: writer = csv.writer(csvfile) writer.writerow([ 'timestamp', 'temperature', 'pressure', 'humidity', 'vbat', 'counter' ]) # ------------------------------------------------------------ # Serial connection # ------------------------------------------------------------ try: ser = serial.Serial(PORT, BAUD, timeout=1) ser.flushInput() print(f"Connected to {PORT} at {BAUD} baud") except serial.SerialException as e: print(f"Serial error: {e}") sys.exit(1) # ------------------------------------------------------------ # Plot setup - FIXED X-AXIS DISPLAY # ------------------------------------------------------------ fig, axes = plt.subplots(3, 2, figsize=(12, 10), sharex='col') # Share x-axis by column fig.suptitle('Real-time Sensor Data', fontsize=16) plots = [ ('temp', axes[0, 0], 'Temperature (°C)', 'tab:blue'), ('pressure', axes[0, 1], 'Pressure (hPa)', 'tab:green'), ('humidity', axes[1, 0], 'Humidity (%)', 'tab:red'), ('vbat', axes[2, 0], 'VBAT (V)', 'orange'), ('counter', axes[1, 1], 'Counter', 'tab:purple') ] #axes[1, 1].axis('off') # counter position lines = {} for key, ax, ylabel, color in plots: line, = ax.plot([], [], color=color, linewidth=2, label=key) lines[key] = line ax.set_ylabel(ylabel) ax.legend() ax.grid(True, alpha=0.3) # Format x‑axis as HH:MM:SS on EVERY subplot ax.xaxis.set_major_formatter(mdates.DateFormatter('%H:%M:%S')) # Show x-labels on ALL plots (not just bottom row) ax.tick_params(axis='x', labelbottom=True) # Hide the unused subplot axes[2, 1].axis('off') # Rotate all x-labels for readability fig.autofmt_xdate() plt.tight_layout() # ------------------------------------------------------------ # Animation callbacks # ------------------------------------------------------------ def init(): for line in lines.values(): line.set_data([], []) return list(lines.values()) def update(frame): try: raw = ser.readline().decode('utf-8').strip() if raw: parts = raw.split(',') if len(parts) == 6: ts_str = parts[0].strip() # e.g. "07:26:50" temp = float(parts[1]) pressure = float(parts[2]) humidity = float(parts[3]) vbat = float(parts[4]) counter = float(parts[5]) # Parse "HH:MM:SS" to a datetime object with today's date t_only = datetime.strptime(ts_str, '%H:%M:%S').time() ts = datetime.combine(date.today(), t_only) data_buffers['temp'].append(temp) data_buffers['pressure'].append(pressure) data_buffers['humidity'].append(humidity) data_buffers['vbat'].append(vbat) data_buffers['counter'].append(counter) data_buffers['time'].append(ts) # Log to CSV using the same timestamp with open(FILENAME, 'a', newline='') as csvfile: writer = csv.writer(csvfile) writer.writerow([ ts.isoformat(), temp, pressure, humidity, vbat, counter ]) print( f"{ts_str}: " f"T={temp:.2f}°C " f"P={pressure:.1f} " f"RH={humidity:.1f}% " f"V={vbat:.3f} " f"C={counter}" ) except (ValueError, IndexError): # Ignore malformed lines pass # Convert datetime objects to matplotlib's float format xdata = mdates.date2num(list(data_buffers['time'])) for key in lines: ydata = np.asarray(data_buffers[key]) lines[key].set_data(xdata, ydata) # Rescale axes for ax in (axes[0,0], axes[0,1], axes[1,0], axes[1,1], axes[2,0]): ax.relim() ax.autoscale_view() return list(lines.values()) # ------------------------------------------------------------ # Animation # ------------------------------------------------------------ ani = animation.FuncAnimation( fig, update, init_func=init, interval=100, blit=False, cache_frame_data=False ) try: plt.show() finally: ser.close() print(f"Data saved to {FILENAME}")
