#include <avr/io.h>
#include <util/delay.h>
    F_CPU = 8 MHz
    Attiny2313     POLLIN FUNK AVR   BRÜCKE
    PB2   OC0A                11 an J4
    PD5   OC0B    PD5/LED2    31 an J4
    PB3   OC1A                12 an J4 --+
    PB4   OC1B                13 an J4   |
                  PD6/LED1    32 an J4 --+
#if 0
unsigned char pwmtable_8D[32] = {
   0*8,  1*8,  2*8,  3*8,  4*8,  5*8,  6*8,  7*8,
   8*8,  9*8, 10*8, 11*8, 12*8, 13*8, 14*8, 15*8,
  16*8, 17*8, 18*8, 19*8, 20*8, 21*8, 22*8, 23*8,
  24*8, 25*8, 26*8, 27*8, 28*8, 29*8, 30*8, 31*8 
#endif 
0, 1, 2, 2, 2, 3, 3, 4, 5, 6, 7, 8, 10, 11, 
13, 16, 19, 23, 27, 32, 38, 45, 54, 64, 76,
91, 108, 128, 152, 181, 215, 255
void init_fade(void) 
  DDRB = (1<<PB2) | (1<<PB3) | (1<<PB4);
  DDRD = (1<<PD5);
  // 8-Bit Timer0 
  // Clear OC0A/OC0B on compare-match when up counting
  // Set OC0A/OC0B on compare-match on TOP
  TCCR0A = (1<<COM0A1) | (1<<COM0B1) | (1<<WGM01) | (1<<WGM00); // 0xA3 Mode 3 Fast-PWM TOP=0xFF
  TCCR0B = (1<<CS02);  // precaler 256 -> ~122 Hz PWM frequency 
  // 16-Bit Timer1
  // Set OC0A/OC0B on compare-match on TOP (=0xFF)
  TCCR1A = (1<<COM1A1) | (1<<COM1B1) | (1<<WGM10); // // 0xA1
  TCCR1B = (1<<WGM12);  // 0x08 Mode 5 non-inverted PWM on OC1A, 8 Bit Fast PWM
  TCCR1B |= (1<<CS02);  // precaler 256 -> ~122 Hz PWM frequency 
void fade(void) 
  unsigned char tmp;
  for(tmp=0; tmp<=31; tmp++){
    OCR0B = *(pwmtable_8D+31-tmp); // LED2 ausfaden
    OCR1A = *(pwmtable_8D+tmp);    // gleichzeitig LED1 einfaden
    _delay_ms(50);
  _delay_ms(1000);
    OCR0B = *(pwmtable_8D+tmp);    //LED2 wieder einfaden
    OCR1A = *(pwmtable_8D+31-tmp); //LED1 ausfaden
    _delay_ms(50);
  _delay_ms(1000);
int main(void)
  init_fade();
  while(1)
    fade();
