printenv DMC SL1 HardwareFeatures spinor=0xEF4014,cpu=0x2170,spinand=0xEFAA20 HWRevision 263 HWSubRevision 1 ProductID Fritz_Box_HW263 SerialNumber N104691A0642843 annex Ohne autoload yes bootloaderVersion 1.11005 firstfreeaddress 0x81155080 firmware_info 263.07.21 firmware_version avm flashsize nor_size=0 sflash_size=1MB nand_size=64MB linux_fs_start 0 maca DC:15:C8:A8:B7:3F macb DC:15:C8:A8:B7:40 macwlan DC:15:C8:A8:B7:41 macwlan2 DC:15:C8:A8:B7:42 macdsl DC:15:C8:A8:B7:3C memsize 0x08000000 mtd0 0x0,0x1900000 mtd1 0x0,0x600000 mtd2 0x0,0x20000 mtd3 0x20000,0x90000 mtd4 0x90000,0x100000 mtd5 0x600000,0xC00000 mtd6 0xC00000,0x4000000 my_ipaddress 192.168.178.1 prompt Eva_AVM usb_board_mac DC:15:C8:A8:B7:3D usb_rndis_mac DC:15:C8:A8:B7:3E wlan_key 61875080424645183943 wlan_ssid FRITZ!Repeater#600 Eva_AVM >go .......................................................ExecuteProgram [ 0.000000] Linux version 4.4.60 (jenkins@dxbuildxjplxpsq19p1xdrgflyx600v2) (gcc version 5.5.0 (Buildroot 2018.11.4-ge994e975e) ) #1 Mon Oct 26 15:30:29 CET 2020 [ 0.000000] DT @ 8071f030: d0 0d fe ed 00 00 17 6c [ 0.000000] MIPS: machine is AVM FRITZ!Repeater 600v2 [ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc) [ 0.000000] Set Port base [ 0.000000] detect_sys_type [ 0.000000] SoC: Qualcomm Atheros QCA5502 ver 1 rev 0 [ 0.000000] [plat_mem_setup] memsize 0x8000000, memstart 0x00000000 [ 0.000000] Determined physical RAM map: [ 0.000000] memory: 08000000 @ 00000000 (usable) [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff] [ 0.000000] [fw-info] Version 07.21 [ 0.000000] [module-mem] Use 0x01106000-0x0157afff (mapped at 81106000-8157afff) for 30 modules [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 [ 0.000000] Kernel command line: go console=ttyS0,115200n8r ethaddr=DC:15:C8:A8:B7:3F [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes) [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Writing ErrCtl register=00000000 [ 0.000000] Readback ErrCtl register=00000000 [ 0.000000] [mips_nmi_setup] setup NMI vector to base 0x80000380 [ 0.000000] Memory: 116648K/131072K available (4676K kernel code, 572K rwdata, 1712K rodata, 284K init, 965K bss, 14424K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] [nmi] VA:PA c0000000:40000000 wired at entry 0x1 [ 0.000000] NR_IRQS:91 [ 0.000000] Clocks: CPU:775.000MHz, DDR:650.000MHz, AHB:258.333MHz, Ref:25.000MHz [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 4932285024 ns [ 0.000007] sched_clock: 32 bits at 387MHz, resolution 2ns, wraps every 5541893118ns [ 0.219148] console [ttyS0] enabled [ 0.222771] Calibrating delay loop... 385.02 BogoMIPS (lpj=770048) [ 0.257406] pid_max: default: 32768 minimum: 301 [ 0.262256] Security Framework initialized [ 0.266429] AppArmor: AppArmor initialized [ 0.270649] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.277433] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.285706] Performance counters: mips/74K PMU enabled, 4 32-bit counters available to each CPU, irq 21 [ 0.298424] devtmpfs: initialized [ 0.304809] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.314839] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.321877] NET: Registered protocol family 16 [ 0.327240] cpuidle: using governor ladder [ 0.331431] cpuidle: using governor menu [ 0.335450] Creating Config Table [ 0.338951] Enabling UART-Input for Pin 18 [ 0.345799] MIPS: machine is AVM FritzRepeater 600v2 [ 0.351242] avm_check_cpu_features: mips-options: 0x40006d638b icache.flags 0x00000000 dcache.flags 0x00000004 isa_level 0x00000031 ases 00000051 [ 0.364889] avm_alloc_page_extension node_extension_table[0] entries=32768 (size=131072) alloced [ 0.374025] Reboot Status is: Power-On [ 0.378045] no support for hwid 263 [ 0.381584] [avmnet] [avmnet_cfg_init] Driver version: 6.317-vr9_mc_vlan_jz72603Mon Oct 26 15:30:08 CET 2020 [ 0.392120] pstore: Registered ramoops as persistent store backend [ 0.398450] ramoops: attached 0x80000@0xf80000, ecc: 0/0 [ 0.408854] SCSI subsystem initialized [ 0.412932] usbcore: registered new interface driver usbfs [ 0.418602] usbcore: registered new interface driver hub [ 0.424067] usbcore: registered new device driver usb [ 0.430018] AVM PA for Linux version 4.4.60 (jenkins@dxbuildxjplxpsq19p1xdrgflyx600v2) (gcc version 5.5.0 (Buildroot 2018.11.4-ge994e975e) ) #1 Mon Oct 26 15:30:29 CET 2020 [ 0.430018] (early init) [ 0.448902] clocksource: Switched to clocksource MIPS [ 0.454520] AppArmor: AppArmor Filesystem Enabled [ 0.461215] NET: Registered protocol family 2 [ 0.466370] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.473539] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.480042] TCP: Hash tables configured (established 1024 bind 1024) [ 0.486652] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.492639] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.499368] avm_pa: try to activate hw accelaration for pid 1 (ipv4) called from avm_pa_dev_pidhandle_register_with_ingress [ 0.510863] NET: Registered protocol family 1 [ 0.516265] audit: initializing netlink subsys (disabled) [ 0.521890] audit: type=2000 audit(0.216:1): initialized [ 0.541879] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.548232] ANTFS Module: Version 2.46 [ 0.552236] fuse init (API version 7.23) [ 0.557948] io scheduler noop registered [ 0.561979] io scheduler deadline registered (default) [ 0.572389] ttyS0 at MMIO 0x18020000 (irq = 19, base_baud = 1562500) is a PORT_16550A [ 0.581196] [loadcontrol] set auto - scale=1 [ 0.585582] [avm] configured: watchdog event debug [ 0.590541] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0) [ 0.597639] [ath:watchdog] activate nmi-mode [ 0.602279] Register push button event to receive the set_factory_kernel event [ 0.610774] AVM Simple Profiling enabled Version 3.0 [ 0.615877] [simple-profiling]:4 performance counters implemented, OLD_34K [ 0.623401] avm_net_trace: Up and running. [ 0.629716] m25p80 spi0.0: s25fl008k (1024 Kbytes) [ 0.634632] [TFFS3_Register_Panic_CB] registering panic callback for mtd spi0.0 [ 0.642156] 3 avm_of_mtd partitions found on MTD device spi0.0 [ 0.648125] Creating 3 MTD partitions on "spi0.0": [ 0.653056] 0x000000000000-0x000000020000 : "urlader" [ 0.659532] 0x000000020000-0x000000090000 : "tffs (1)" [ 0.665981] 0x000000090000-0x000000100000 : "tffs (2)" [ 0.672513] Registering ATH-flash-driver... [ 0.676941] tun: Universal TUN/TAP device driver, 1.6 [ 0.682082] tun: (C) 1999-2004 Max Krasnyansky [ 0.688678] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.695415] ehci-pci: EHCI PCI platform driver [ 0.700212] usbcore: registered new interface driver usblp [ 0.705912] usbcore: registered new interface driver usb-storage [ 0.712057] i2c /dev entries driver [ 0.723605] nand: device found, Manufacturer ID: 0xef, Chip ID: 0xaa [ 0.730108] nand: Winbond W25N01GV 128MiB 3.3V [ 0.734669] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64 [ 0.742491] Scanning device for bad blocks [ 0.919866] 3 avm_of_mtd partitions found on MTD device spi0.1 [ 0.925819] Creating 3 MTD partitions on "spi0.1": [ 0.930748] 0x000000000000-0x000000600000 : "kernel0" [ 0.937279] 0x000000600000-0x000000c00000 : "kernel1" [ 0.943681] 0x000000c00000-0x000004000000 : "ubi" [ 0.950011] AVM PA for Linux Linux version 4.4.60 (jenkins@dxbuildxjplxpsq19p1xdrgflyx600v2) (gcc version 5.5.0 (Buildroot 2018.11.4-ge994e975e) ) #1 Mon Oct 26 15:30:29 CET 2020 [ 0.950011] (late init) [ 0.969605] gre: GRE over IPv4 demultiplexor driver [ 0.975769] NET: Registered protocol family 10 [ 0.982027] avm_pa: try to activate hw accelaration for pid 2 (ipv6) called from avm_pa_dev_pidhandle_register_with_ingress [ 0.993609] NET: Registered protocol family 17 [ 0.998413] Bridge broadcast ratelimiter registered [ 1.003401] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 1.016425] Bridge firewalling registered [ 1.020540] l2tp_core: L2TP core driver, V2.0 [ 1.024989] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 1.030965] l2tp_netlink: L2TP netlink interface [ 1.035743] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 1.041800] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 1.048656] 8021q: 802.1Q VLAN Support v1.8 [ 1.053048] [nmi] copy_nmi_trampoline done [ 1.058451] [TFFS3_Init] Called. [ 1.061755] [TFFS3_Init] No storage module registered, trying legacy fallback [ 1.069069] [TFFS3_CACHE_Configure] Setting up caching for backend legacy [ 1.076050] [TFFS3-CACHE] Caching module for TFFS 3.x [ 1.081252] [TFFS3_LGCY_Setup] using mtd1(tffs (1)), mtd2(tffs (2)) [ 1.087724] [TFFS3_LGCY_Setup] mtd "tffs (1)": segment value 32 [ 1.093807] [TFFS3_LGCY_Setup] mtd "tffs (2)": segment value 33 [ 1.099888] [TFFS3_LGCY_Setup] Using segment 33 (avail: 32 + 33) [ 1.106068] [TFFS3_LGCY_Setup] mtd2 size=0x70000 [ 1.111548] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0) [ 1.119275] Adam2 environment variables API installed. [ 1.127082] UBI: auto-attach mtd5 [ 1.130298] ubi0: attaching mtd5 [ 1.738667] ubi0: scanning is finished [ 1.761669] ubi0: attached mtd5 (name "ubi", size 52 MiB) [ 1.767208] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.774252] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.781239] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.788406] ubi0: good PEBs: 416, bad PEBs: 0, corrupted PEBs: 0 [ 1.794588] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.802028] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1070703713 [ 1.811434] ubi0: available PEBs: 0, total reserved PEBs: 416, PEBs reserved for bad PEB handling: 20 [ 1.820967] ubi0: background thread "ubi_bgt0d" started, PID 37 [ 1.828446] [rootfs] use mtd6 (filesystem) as root [ 1.836307] {avmnet_cfg_netinit} [ 1.839613] [avmnet] No config found for HWRev 263, HWSubRev 1, Profile-ID 0, trying base config for HWSubRev [ 1.849786] [avmnet] No config found for HWRev 263, HWSubRev 1, trying base config for HWRev [ 2.195669] [avmnet_set_macaddr] Setup Mac Addr for Device(eth0): dc:15:c8:a8:b7:3f [ 2.211316] VFS: Mounted root (squashfs filesystem) readonly on device 31:6. [ 2.225054] devtmpfs: mounted [ 2.229592] Freeing unused kernel memory: 284K (80739000 - 80780000) starting pid 47, tty '/dev/ttyS0': '/etc/boot.d/1' [ 3.146677] [module-mem] give 0x27000 bytes at 81107000 to module 'hui' (0x44d000 bytes left) [ 3.160041] [hui] Initialize hardware user interface [ 3.165975] [avm_connect][state_machine_init] starting event worker thread [ 3.173464] avm,hui-generic-led-avm avm_hui:repeater-all-in-one: Using avm-gpios <5, 0, 10> [ 3.182315] avm,hui-generic-button-avm avm_hui:repeater-connect: Using avm-gpios <1> [ 3.234035] [TFFS_Cache] Allocate segement buffer cache (size=32784) [ 3.241112] TFFS Name Table N [Supervisor] Warning: capi.service: could not resolve dependency piglet.service [Supervisor] Warning: kpid.service: could not resolve dependency psetd.service [Supervisor] Warning: ptest_release.service: could not resolve dependency voip.service [Supervisor] Warning: udevadm.service: could not resolve dependency piglet.service [Supervisor] Info: start tffs.service Please press Enter to activate this console. Jan 1 00:00:04 ar7cfgctl[132]: load_config(ar7): open problem - factory default loaded Jan 1 00:00:04 ar7cfgctl[141]: load_config(ar7): open problem - factory default loaded [Supervisor] Info: tffs.service exit success [Supervisor] Info: start rekey.service firmwarecfg config_rekey: nop [Supervisor] Info: rekey.service exit success [Supervisor] Info: start environment.service Jan 1 01:00:05 ar7cfgctl[199]: /var/flash/ar7.cfg: is empty Jan 1 01:00:05 ar7cfgctl[199]: load_config(ar7): file empty - factory default loaded Jan 1 01:00:05 ar7cfgctl[244]: /var/flash/ar7.cfg: is empty Jan 1 01:00:05 ar7cfgctl[244]: load_config(ar7): file empty - factory default loaded Jan 1 00:00:05 ar7cfgctl[252]: /var/flash/ar7.cfg: is empty Jan 1 00:00:05 ar7cfgctl[252]: load_config(ar7): file empty - factory default loaded [Supervisor] Info: environment.service exit success [Supervisor] Info: start flash-update.service [Supervisor] Info: flash-update.service exit success [Supervisor] Info: start oemcheck.service [Supervisor] Error: could not start: /etc/boot.d/core/oemcheck [Supervisor] execvp returned: No such file or directory [Supervisor] Info: oemcheck.service exit error [Supervisor] Info: start watchdog.serv[ 6.204624] AVM_WATCHDOG: System Init Ueberwachung 120 Sekunden ice [Supervisor] Info: watchdog.service exit success [Supervisor] Info: start capi-config.service [Supervisor] Info: start udev.service [Supervisor] Info: start udevadm.service [Supervisor] Info: capi-config.service exit success [Supervisor] Info: start capi.service [Supervisor] Info: capi.service exit success [ 6.667900] udevd[278]: starting version 3.2.5 [ 6.784143] udevd[278]: specified group 'tty' unknown [ 6.789643] udevd[278]: specified group 'dialout' unknown [ 6.795379] udevd[278]: specified group 'kmem' unknown [ 6.800835] udevd[278]: specified group 'input' unknown [ 6.806394] udevd[278]: specified group 'video' unknown [ 6.812011] udevd[278]: specified group 'audio' unknown [ 6.817697] udevd[278]: specified group 'lp' unknown [ 6.823070] udevd[278]: specified group 'disk' unknown [ 6.828522] udevd[278]: specified group 'cdrom' unknown [ 6.834171] udevd[278]: specified group 'tape' unknown [ 6.842125] udevd[278]: starting eudev-3.2.5 [Supervisor] Info: udevadm.service exit success [Supervisor] Info: start modules-load.service modprobe: module kdsldmod not found in modules.dep [ERROR] Failed to load kernel module kdsldmod [ 7.250139] cprocfsmod: module license 'unspecified' taints kernel. [ 7.256565] Disabling lock debugging due to kernel taint [ 7.262145] [module-mem] give 0x3000 bytes at 8112e000 to module 'cprocfsmod' (0x44a000 bytes left) [ 7.274498] [module-mem] give 0x5000 bytes at 81131000 to module 'cchardev' (0x445000 bytes left) [ 7.284622] cchardevice: loaded [ 7.408161] [module-mem] give 0x48000 bytes at 81136000 to module 'krextdmod' (0x3fd000 bytes left) [ 7.426015] krextd: Initialisation of debughandles ... [ 7.431285] krextd: Initialisation of debughandles [OK] [ 7.436624] krextd: Initialisation of procfs ... [ 7.441392] krextd: Initialisation of procfs [OK] [ 7.446214] krextd: Initialisation of kmod_debugctl ... [ 7.451599] krextd: Initialisation of kmod_debugctl [OK] [ 7.457054] krextd: Initialisation of cenv ... [ 7.461621] krextd: Initialisation of cenv [OK] [ 7.466280] krextd: Initialisation of ctimer ... [ 7.471230] krextd: Initialisation of ctimer [OK] [ 7.476027] krextd: Initialisation of kmodcmddev ... [ 7.481136] krextd: Initialisation of kmodcmddev [OK] [ 7.486318] krextd: Initialisation of packettrace ... [ 7.491559] krextd: Initialisation of packettrace [OK] [ 7.496807] krextd: Initialisation of nqos ... [ 7.509099] krextd: Initialisation of nqos [OK] [ 7.513722] krextd: Initialisation of bridgeflt ... [ 7.518744] krextd: Initialisation of bridgeflt [OK] [ 7.523835] krextd: Initialisation of timer ... [ 7.528491] krextd: Initialisation of timer [OK] [ 7.533246] krextd: Initialisation of krextd ... [ 7.537992] krextd: Initialisation of krextd:debughandles ... [ 7.543917] krextd: Initialisation of krextd:debughandles [OK] [ 7.549903] krextd: Initialisation of krextd:global ... [ 7.555300] krextd: Initialisation of krextd:global [OK] [ 7.560744] krextd: Initialisation of krextd:memcache ... [ 7.567392] krextd: Initialisation of krextd:memcache [OK] [ 7.573013] krextd: Initialisation of krextd:igmpcompr ... [ 7.578639] krextd: Initialisation of krextd:igmpcompr [OK] [ 7.584363] krextd: Initialisation of krextd:krextdev ... [ 7.589965] krextd: Initialisation of krextd:krextdev [OK] [ 7.595565] krextd: Initialisation of krextd:krextdev_wland ... [ 7.601710] krextd: Initialisation of krextd:krextdev_wland [OK] [ 7.607843] krextd: Initialisation of krextd:netdevice_notifier ... [ 7.614304] krextd: Initialisation of krextd:netdevice_notifier [OK] [ 7.620831] krextd: Initialisation of krextd:krextdprocfs ... [ 7.626786] krextd: Initialisation of krextd:krextdprocfs [OK] [ 7.632752] krextd: Initialisation of krextd:krextdtimer ... [ 7.638599] krextd: Initialisation of krextd:krextdtimer [OK] [ 7.644487] krextd: Initialisation of krextd [OK] [ 7.649323] krextd: Initialisation [OK] [ 7.700652] [module-mem] give 0x5000 bytes at 8117e000 to module 'zram' (0x3f8000 bytes left) [ 7.715491] zram: Added device: zram0 [Supervisor] Info: modules-load.service exit success [Supervisor] Info: start devnodes.service [Supervisor] Info: devnodes.service exit success [Supervisor] Info: start apparmor.service [Supervisor] Info: start default-files.service [Supervisor] Info: start swap.service [Supervisor] Info: apparmor.service exit success[ 8.132636] zram0: detected capacity change from 0 to 8388608 Setting up swapspace version 1, size = 8384512 bytes [ 8.192889] Adding 8188k swap on /dev/zram0. Priority:-1 extents:1 across:8188k SS [Supervisor] Info: swap.service exit success [ 8.253171] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW [ 8.267584] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=100 mul=10 div=1 offset=0 NormP=1000 mW -> SumNormP=1000 mW [ 8.282618] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=1000 mW [ 8.297312] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=2200 NormP=2200 mW -> SumNormP=3200 mW [ 8.312818] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=0 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=4140 mW [ 8.327535] avm_power: [avm_power_temperature] No cpu sensor registered [Supervisor] Info: default-files.service exit success [Supervisor] Info: start config.service [Supervisor] Info: start debug.service [Supervisor] Info: start sysctl.service net.ipv4.tcp_min_snd_mss = 536 [ 8.463597] sysrq: SysRq : Changing Loglevel [ 8.467932] sysrq: Loglevel set to 4 kernel.panic_on_oops = 1 vm.panic_on_oom = 2 kernel.printk = 4[ 8.482418] [ 8.482418] [avm_debug] redirecting kernel-messages (/dev/debug) net.ipv4.ip_forward = 1 net.ipv4.tcp_min_tso_segs = 100 net.ipv6.conf.all.forwarding = 1 net.ipv6.conf.all.disable_ipv6 = 1 net.ipv6.conf.default.disable_ipv6 = 1 net.ipv6.conf.default.autoconf = 0 net.ipv4.conf.all.rp_filter = 1 net.ipv4.conf.default.rp_filter = 1 [Supervisor] Info: sysctl.service exit success [Supervisor] Info: debug.service exit success Jan 1 01:00:08 rextcfgctl[411]: /var/flash/rext.cfg: is empty [Supervisor] Info: config.service exit success [Supervisor] Info: start avmipcd.service [Supervisor] Info: start boxnotify.service [Supervisor] Info: start inetd.service [Supervisor] Info: start psupport-init-prenet.service [Supervisor] Info: start run_clock.service [Supervisor] Info: inetd.service exit success run_clock demon started [Supervisor] Info: run_clock.service exit success [Supervisor] Info: psupport-init-prenet.service exit success [Supervisor] Info: boxnotify.service exit success [Supervisor] Info: avmipcd.service exit success [Supervisor] Info: start net.service [Supervisor] Info: start avmnexusd.service /etc/ewnw_devfiles.sh: checking /dev files .... /etc/ewnw_devfiles.sh: /dev/kdsldptrace0 already exists /etc/ewnw_devfiles.sh: /dev/kdsldptrace1 already exists /etc/ewnw_devfiles.sh: mknod /dev/knqos c 245 0 /etc/ewnw_devfiles.sh: mknod /dev/avmtrackd c 244 0 /etc/ewnw_devfiles.sh: mknod /dev/bridgeflt c 243 0 /etc/ewnw_devfiles.sh: mknod /dev/krextd c 242 0 /etc/ewnw_devfiles.sh: mknod /dev/krextd_wlan c 241 0 /bin/avmnexusd: '/lib//libavmupnpbig.so.2' is not an ELF file /bin/avmnexusd: '/lib/libavmupnpbig.so.2' is not an ELF file /bin/avmnexusd: '/lib/libavmupnpbig.so.2' is not an ELF file /bin/avmnexusd: can't load library 'libavmupnpbig.so.2' [Supervisor] Info: avmnexusd.service exit error /etc/ewnw_devfiles.sh: /dev files checked Jan 1 01:00:08 ar7cfgctl[456]: /var/flash/ar7.cfg: is empty Jan 1 01:00:08 ar7cfgctl[456]: load_config(ar7): file empty - factory default loaded /sbin/l2tpv3d: '/lib//libavmupnpbig.so.2' is not an ELF file /sbin/l2tpv3d: '/lib/libavmupnpbig.so.2' is not an ELF file /sbin/l2tpv3d: '/lib/libavmupnpbig.so.2' is not an ELF file /sbin/l2tpv3d: can't load library 'libavmupnpbig.so.2' /usr/bin/ctlmgr: '/lib//libavmcrypto.so.0' is not an ELF file /usr/bin/ctlmgr: '/lib/libavmcrypto.so.0' is not an ELF file /usr/bin/ctlmgr: '/lib/libavmcrypto.so.0' is not an ELF file /usr/bin/ctlmgr: can't load library 'libavmcrypto.so.0' /sbin/upnpd: '/lib//libavmupnp.so.2' is not an ELF file /sbin/upnpd: '/lib/libavmupnp.so.2' is not an ELF file /sbin/upnpd: '/lib/libavmupnp.so.2' is not an ELF file /sbin/upnpd: can't load library 'libavmupnp.so.2' /sbin/rextd: '/lib//libavmfbstate.so.1' is not an ELF file /sbin/rextd: '/lib/libavmfbstate.so.1' is not an ELF file /sbin/rextd: '/lib/libavmfbstate.so.1' is not an ELF file /sbin/rextd: can't load library 'libavmfbstate.so.1' rc.wlan: Start WLAN... WLAND:[00489]:01:00.11/[0011.000]:[VER]Registered new module default, DEFAULT, 0 WLAND:[00489]:01:00.11/[0011.000]:[VER]Registered new module global, GLOBAL, 0 WLAND:[00489]:01:00.11/[0011.000]:[ALW]BUILD: Oct 5 2020, 18:58:48 Jan 1 01:00:11 deviceinfod[492]: starting ... (normal) 1970-01-01 01:00:11 deviceinfod[492]: ready (0sec) [Supervisor] Info: net.service exit success [Supervisor] Info: start kpid.service [Supervisor] Info: start meshd.service [Supervisor] Info: start ptest_release.service [Supervisor] Info: ptest_release.service exit success [Supervisor] Info: start configd.service kpid: Sending section usb failed with error -1: sysfs_usb 1 {"sv":"gen/v1","kpi":{}} kpid: Sending section hwpa failed with error -1: sysfs_hwpa 1 {"sv":"gen/v1","kpi":{}} kpid: Sending section system failed with error -1: sysfs_system 1 {"sv":"gen/v1","kpi":{"temperatures":{}}} [Supervisor] Info: configd.service exit success /sbin/meshd: '/lib//libavmfbstate.so.1' is not an ELF file /sbin/meshd: '/lib/libavmfbstate.so.1' is not an ELF file /sbin/meshd: '/lib/libavmfbstate.so.1' is not an ELF file /sbin/meshd: can't load library 'libavmfbstate.so.1' [Supervisor] Info: meshd.service exit error [Supervisor] Info: start meshd_config.service Jan 1 01:00:12 wlancfgctl[515]: /var/flash/wlan.cfg: is empty Jan 1 01:00:12 wlancfgctl[515]: load_config(wlan): factory default loaded aicmd: avmipc_command: avmipc_stream_open failed (-1) [Supervisor] Info: meshd_config.service exit error [Supervisor] Info: all Services loaded.
