APP Version : 13.10 Model : T48 MFG:2025-12-29 Device : MX35UF1G24AD(x1+ISP) @WSON8 Pins Detected Passed! ID: 0x C2 94 03 ......OK! Found Bad Block when erasing : #516 Found Bad Block when erasing : #554 Found Bad Block when erasing : #730 Found Bad Block when erasing : #767 Found Bad Block when erasing : #798 Found Bad Block when erasing : #803 Found Bad Block when erasing : #934 Found Bad Block when erasing : #991 Found Bad Block when erasing : #1004 Erase NAND FLash : Succeeded. Time : 2219 ms Byffer File Size: 139264KB Programming Nand Flash : Succeeded. Time : 55.078 S -- Flash Size :139264 KB Verifying Nand Flash ... Block#0 Verify error Bytes: 1 Block#111 Verify error Bytes: 1 Block#113 Verify error Bytes: 1 Block#120 Verify error Bytes: 1 Block#125 Verify error Bytes: 1 Block#390 Verify error Bytes: 1 Block#512 Verify error Bytes: 1 Block#513 Verify error Bytes: 1 Block#521 Verify error Bytes: 1 Block#544 Verify error Bytes: 1 Block#561 Verify error Bytes: 1 Block#565 Verify error Bytes: 1 Block#606 Verify error Bytes: 1 Block#610 Verify error Bytes: 1 Block#645 Verify error Bytes: 1 Block#646 Verify error Bytes: 1 Block#648 Verify error Bytes: 1 Block#662 Verify error Bytes: 1 Block#663 Verify error Bytes: 1 Block#699 Verify error Bytes: 1 Verify Error Blocks: 20
