---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 15:37:33 03/21/2026 -- Design Name: -- Module Name: Weight_Memory - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity Weight_Memory is Generic (ADDRESS_WIDTH : integer := 11; DATA_WIDTH : integer := 16); Port ( --Control Signals clk : in std_logic; --Port A Singals (read only) Port_A_Adr : in std_logic_vector (ADDRESS_WIDTH-1 downto 0); Port_A_Data_Out : out std_logic_vector (DATA_WIDTH-1 downto 0); --Port B Signals (read/write) Port_B_enable : in std_logic; Port_B_write : in std_logic; Port_B_Adr : in std_logic_vector (ADDRESS_WIDTH-1 downto 0); Port_B_Data_In : in std_logic_vector (DATA_WIDTH-1 downto 0); Port_B_Data_Out : out std_logic_vector (DATA_WIDTH-1 downto 0) ); end Weight_Memory; architecture Behavioral of Weight_Memory is type mem is array(0 to (2**(ADDRESS_WIDTH))-1) of std_logic_vector(DATA_WIDTH-1 downto 0); signal memory : mem := ( x"AE9B", x"3326", x"A687", x"2E08", x"B24D", x"2A9F", x"AD81", x"3216", x"B135", x"2841", x"B022", x"339B", x"A48B", x"2ED9", x"B31C", x"2C3D", x"ACE9", x"31D9", x"A245", x"3158", x"B1EF", x"29D2", x"AFF7", x"3302", x"AC7E", x"2FEB", x"B36C", x"274B", x"B172", x"2DD7", x"AB02", x"31A3", x"A88B", x"32A9", x"AF95", x"252F", x"B0DD", x"3381", x"AC9F", x"3028", x"B2DF", x"2A87", x"AF1A", x"3202", x"A76C", x"30A1", x"B28F", x"2F47", x"AC00", x"2D89", x"B3B6", x"2926", x"B066", x"3262", x"AE62", x"3189", x"AC62", x"335E", x"A820", x"2FD2", x"B1D2", x"33AC", x"ADE3", x"3072", x"B2FD", x"2AC0", x"AFDF", x"31EB", x"A947", x"30F5", x"B2B6", x"2F85", x"AC97", x"2DCA", x"B3C8", x"28AC", x"B0AE", x"3278", x"AEB8", x"3197", x"ACB8", x"3370", x"A883", x"3000", x"B1DB", x"33BE", x"AE10", x"3085", x"B316", x"2B1A", x"B006", x"31F7", x"A9A9", x"3106", x"B366", x"2EB8", others => (others =>'0')); begin Port_A:process begin wait until falling_edge(clk); Port_A_Data_Out <= memory(to_integer(unsigned(Port_A_Adr))); --read operation end process; Port_B:process begin wait until falling_edge(clk); if(Port_B_enable = '0') then Port_B_Data_Out <= (others => 'Z'); else if(Port_B_write = '1') then memory(to_integer(unsigned(Port_B_Adr))) <= Port_B_Data_In; --write operation Port_B_Data_Out <= Port_B_Data_In; --write first mode else Port_B_Data_Out <= memory(to_integer(unsigned(Port_B_Adr))); end if; end if; end process; end Behavioral;
