-------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 09:35:48 03/28/2026 -- Design Name: -- Module Name: D:/Xilinx_Projekts/Neural_Network/Neuron_tb.vhd -- Project Name: Neural_Network -- Target Device: -- Tool versions: -- Description: -- -- VHDL Test Bench Created by ISE for module: Neuron -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- -- Notes: -- This testbench has been automatically generated using types std_logic and -- std_logic_vector for the ports of the unit under test. Xilinx recommends -- that these types always be used for the top-level I/O of a design in order -- to guarantee that the testbench will bind correctly to the post-implementation -- simulation model. -------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; ENTITY Neuron_tb IS END Neuron_tb; ARCHITECTURE behavior OF Neuron_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT Neuron PORT( clk : IN std_logic; reset : IN std_logic; execute : IN std_logic; ready : OUT std_logic; error : OUT std_logic; Layer_page : IN std_logic_vector(3 downto 0); Layer_Input_Number : IN std_logic_vector(6 downto 0); Mem_enable : IN std_logic; Mem_write : IN std_logic; Mem_Adr : IN std_logic_vector(10 downto 0); Mem_Data_In : IN std_logic_vector(15 downto 0); Mem_Data_Out : OUT std_logic_vector(15 downto 0); Input : IN std_logic_vector(15 downto 0); Output : OUT std_logic_vector(15 downto 0) ); END COMPONENT; COMPONENT Input_Memory PORT( clk : IN std_logic; Address : IN std_logic_vector(6 downto 0); Data_out : OUT std_logic_vector(15 downto 0) ); END COMPONENT; --Inputs signal clk : std_logic := '0'; signal reset : std_logic := '0'; signal execute : std_logic := '0'; signal Layer_page : std_logic_vector(3 downto 0) := (others => '0'); signal Layer_Input_Number : std_logic_vector(6 downto 0) := (others => '0'); signal Mem_enable : std_logic := '0'; signal Mem_write : std_logic := '0'; signal Mem_Adr : std_logic_vector(10 downto 0) := (others => '0'); signal Mem_Data_In : std_logic_vector(15 downto 0) := (others => '0'); signal Input : std_logic_vector(15 downto 0) := (others => '0'); signal Address : std_logic_vector(6 downto 0) := (others => '0'); --Outputs signal ready : std_logic; signal error : std_logic; signal Mem_Data_Out : std_logic_vector(15 downto 0); signal Output : std_logic_vector(15 downto 0); signal Data_out : std_logic_vector(15 downto 0); --internal Signals signal Address_counter : unsigned(6 downto 0) := (others => '0'); signal int_execute : std_logic; signal input_state : integer range 0 to 96 := 0; -- Clock period definitions constant clk_period : time := 5 ns; BEGIN tb_Input_Memory: Input_Memory PORT MAP( clk => clk, Address => Address, Data_out => Data_out ); -- Instantiate the Unit Under Test (UUT) uut: Neuron PORT MAP ( clk => clk, reset => reset, execute => int_execute, ready => ready, error => error, Layer_page => Layer_page, Layer_Input_Number => Layer_Input_Number, Mem_enable => Mem_enable, Mem_write => Mem_write, Mem_Adr => Mem_Adr, Mem_Data_In => Mem_Data_In, Mem_Data_Out => Mem_Data_Out, Input => Data_out, Output => Output ); -- Clock process definitions clk_process :process begin clk <= '0'; wait for clk_period/2; clk <= '1'; wait for clk_period/2; end process; stim_Input: process begin wait until rising_edge(clk); if(reset = '1') then Address_counter <= (others => '0'); Layer_Input_Number <= (others => '0'); Layer_page <= (others => '0'); input_state <= 0; int_execute <= '0'; else if(execute = '1') then input_state <= 1; int_execute <= '1'; -- else -- input_state <= 1; end if; case input_state is when 0 => Address_counter <= (others => '0'); when 10 => Address_counter <= (others => '0'); int_execute <= '0'; when others => Address_counter <= Address_counter + 1; input_state <= input_state + 1; end case; Layer_Input_Number <= std_logic_vector(Address_counter); Address <= std_logic_vector(Address_counter); end if; end process; -- Stimulus process stim_proc: process begin -- hold reset state for 100 ns. wait for 100 ns; reset <= '1'; wait for 100ns; reset <= '0'; wait for 100ns; -- insert stimulus here execute <= '1'; wait for 10ns; execute <= '0'; wait; end process; END;
