<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.6.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="100" unitdist="mil" unit="mil" style="lines" multiple="1" display="yes" altdistance="1" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="21" fill="7" visible="yes" active="yes"/>
<layer number="3" name="Route3" color="21" fill="5" visible="yes" active="yes"/>
<layer number="4" name="Route4" color="3" fill="2" visible="yes" active="yes"/>
<layer number="5" name="Route5" color="21" fill="2" visible="yes" active="yes"/>
<layer number="6" name="Route6" color="3" fill="7" visible="yes" active="yes"/>
<layer number="7" name="Route7" color="21" fill="7" visible="yes" active="yes"/>
<layer number="8" name="Route8" color="3" fill="8" visible="yes" active="yes"/>
<layer number="9" name="Route9" color="21" fill="8" visible="yes" active="yes"/>
<layer number="10" name="Route10" color="37" fill="4" visible="yes" active="yes"/>
<layer number="11" name="Route11" color="53" fill="5" visible="yes" active="yes"/>
<layer number="12" name="Route12" color="37" fill="7" visible="yes" active="yes"/>
<layer number="13" name="Route13" color="53" fill="7" visible="yes" active="yes"/>
<layer number="14" name="Route14" color="37" fill="8" visible="yes" active="yes"/>
<layer number="15" name="Route15" color="37" fill="7" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="49" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="34" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="7" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="7" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="12" fill="8" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="11" fill="8" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="41" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="41" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="4" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="5" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="47" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="47" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="7" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="49" fill="7" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="5" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="5" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="5" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="52" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="33" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="36" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="21" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="50" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="20" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="52" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="27" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="53" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="52" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>&lt;b&gt;just for JP Colors &lt;/b&gt;&lt;p&gt;&lt;i&gt;created by J. Paschedag</description>
<packages>
<package name="2562970000">
<description>&lt;b&gt;2562970000-1&lt;/b&gt;&lt;br&gt;
</description>
<pad name="1" x="-4.445" y="4.445" drill="0.9" diameter="1.4" shape="square"/>
<pad name="2" x="-3.175" y="6.985" drill="0.9" diameter="1.4"/>
<pad name="3" x="-1.905" y="4.445" drill="0.9" diameter="1.4"/>
<pad name="4" x="-0.635" y="6.985" drill="0.9" diameter="1.4"/>
<pad name="5" x="0.635" y="4.445" drill="0.9" diameter="1.4"/>
<pad name="6" x="1.905" y="6.985" drill="0.9" diameter="1.4"/>
<pad name="7" x="3.175" y="4.445" drill="0.9" diameter="1.4"/>
<pad name="8" x="4.445" y="6.985" drill="0.9" diameter="1.4"/>
<hole x="-5.715" y="-1.905" drill="3.2"/>
<hole x="5.715" y="-1.905" drill="3.2"/>
<pad name="MH3" x="-7.875" y="-4.955" drill="1.7" diameter="2.55"/>
<pad name="MH4" x="7.875" y="-4.955" drill="1.7" diameter="2.55"/>
<text x="-3.175" y="-5.87" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-3.81" y="-7.775" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
<wire x1="-8" y1="8.195" x2="8" y2="8.195" width="0.1" layer="21"/>
<wire x1="8" y1="8.195" x2="8" y2="-8.505" width="0.1" layer="21"/>
<wire x1="8" y1="-8.505" x2="-8" y2="-8.505" width="0.1" layer="21"/>
<wire x1="-8" y1="-8.505" x2="-8" y2="8.195" width="0.1" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="2562970000">
<wire x1="-2.54" y1="12.7" x2="5.08" y2="12.7" width="0.254" layer="94"/>
<wire x1="5.08" y1="-15.24" x2="5.08" y2="12.7" width="0.254" layer="94"/>
<wire x1="5.08" y1="-15.24" x2="-2.54" y2="-15.24" width="0.254" layer="94"/>
<wire x1="-2.54" y1="12.7" x2="-2.54" y2="-15.24" width="0.254" layer="94"/>
<text x="-3.81" y="17.78" size="1.27" layer="95" ratio="12">&gt;NAME</text>
<text x="-3.81" y="15.24" size="1.27" layer="96" ratio="12">&gt;VALUE</text>
<pin name="1" x="-7.62" y="10.16" length="middle" direction="pas"/>
<pin name="2" x="-7.62" y="7.62" length="middle" direction="pas"/>
<pin name="3" x="-7.62" y="5.08" length="middle" direction="pas"/>
<pin name="4" x="-7.62" y="2.54" length="middle" direction="pas"/>
<pin name="5" x="-7.62" y="0" length="middle" direction="pas"/>
<pin name="6" x="-7.62" y="-2.54" length="middle" direction="pas"/>
<pin name="7" x="-7.62" y="-5.08" length="middle" direction="pas"/>
<pin name="8" x="-7.62" y="-7.62" length="middle" direction="pas"/>
<pin name="MH3" x="-7.62" y="-10.16" length="middle" direction="pas"/>
<pin name="MH4" x="-7.62" y="-12.7" length="middle" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="RJ45C5_R1V_3.2N4N_RL" prefix="X-">
<description>&lt;b&gt;PCB connector RJ45 modular jack, Cat. 5 , THT/THR solder connection, Shielding: Yes, LED: No, Gold over nickel, Tape&lt;/b&gt;&lt;p&gt;
Source: &lt;a href="https://datasheet.weidmueller.com/pdf/en/2562970000/scope/2/"&gt; Datasheet &lt;/a&gt;</description>
<gates>
<gate name="G$1" symbol="2562970000" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2562970000">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="MH3" pad="MH3"/>
<connect gate="G$1" pin="MH4" pad="MH4"/>
</connects>
<technologies>
<technology name="">
<attribute name="DESCRIPTION" value="PCB connector RJ45 modular jack, Cat. 5 , THT/THR solder connection, Shielding: Yes, LED: No, Gold over nickel, Tape" constant="no"/>
<attribute name="HEIGHT" value="16.5mm" constant="no"/>
<attribute name="MANUFACTURER_NAME" value="Weidmuller" constant="no"/>
<attribute name="MANUFACTURER_PART_NUMBER" value="2562970000" constant="no"/>
<attribute name="MOUSER_PART_NUMBER" value="" constant="no"/>
<attribute name="MOUSER_PRICE-STOCK" value="" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
