APP Version : 13.17 Model : T76 MFG:2025-10-29 Device : W25N01GW(x1+ISP) @WSON8 Reminder: Ordinary adapters have high EMI This type of chip is recommended to use a socket with Electromagnetic Shielding! Pin Detected Passed. ID: 0x EF BA 21 ...OK! Erase NAND FLash : Succeeded. Time : 891 ms Byffer File Size: 135168KB Programming Nand Flash : Succeeded. Time : 41.875 S -- Flash Size :135168 KB Verifying Nand Flash ... Block#0 Verify error Bytes: 59709 Block#1 Verify error Bytes: 69023 Block#4 Verify error Bytes: 57835 Block#5 Verify error Bytes: 38912 Block#6 Verify error Bytes: 58616 Block#7 Verify error Bytes: 67584 Block#8 Verify error Bytes: 43548 Block#10 Verify error Bytes: 57344 Block#12 Verify error Bytes: 54502 Block#13 Verify error Bytes: 34728 Block#20 Verify error Bytes: 39222 Block#21 Verify error Bytes: 44004 Block#28 Verify error Bytes: 28589 Block#29 Verify error Bytes: 51542 Block#30 Verify error Bytes: 51200 Block#31 Verify error Bytes: 69632 Block#32 Verify error Bytes: 28723 Block#33 Verify error Bytes: 53251 Block#34 Verify error Bytes: 43008 Block#35 Verify error Bytes: 51200 Block#36 Verify error Bytes: 45007 Block#38 Verify error Bytes: 65269 Block#42 Verify error Bytes: 56790 Block#43 Verify error Bytes: 52670 Block#44 Verify error Bytes: 63443 Block#45 Verify error Bytes: 63488 Block#46 Verify error Bytes: 55278 Block#47 Verify error Bytes: 63488 Block#48 Verify error Bytes: 79872 Block#49 Verify error Bytes: 51182 Block#50 Verify error Bytes: 55296 Block#51 Verify error Bytes: 57327 Block#52 Verify error Bytes: 59392 Block#53 Verify error Bytes: 51200 Block#54 Verify error Bytes: 53248 Block#55 Verify error Bytes: 42990 Block#56 Verify error Bytes: 49152 Block#57 Verify error Bytes: 49135 Block#58 Verify error Bytes: 53248 Block#59 Verify error Bytes: 65536 Block#60 Verify error Bytes: 53230 Block#61 Verify error Bytes: 49152 Block#62 Verify error Bytes: 57344 Block#63 Verify error Bytes: 47104 Block#64 Verify error Bytes: 53248 Block#65 Verify error Bytes: 53248 Block#66 Verify error Bytes: 42990 Block#67 Verify error Bytes: 67584 Block#68 Verify error Bytes: 67567 Block#69 Verify error Bytes: 49152 Block#70 Verify error Bytes: 59374 Block#71 Verify error Bytes: 51183 Block#72 Verify error Bytes: 47104 Block#73 Verify error Bytes: 55296 Block#74 Verify error Bytes: 49152 Block#75 Verify error Bytes: 49152 Block#76 Verify error Bytes: 47104 Block#77 Verify error Bytes: 65519 Block#78 Verify error Bytes: 63488 Block#79 Verify error Bytes: 57344 Block#80 Verify error Bytes: 63488 Block#81 Verify error Bytes: 59392 Block#82 Verify error Bytes: 38912 Block#83 Verify error Bytes: 38912 Block#84 Verify error Bytes: 55278 Block#85 Verify error Bytes: 53248 Block#86 Verify error Bytes: 51200 Block#87 Verify error Bytes: 40960 Block#88 Verify error Bytes: 49152 Block#89 Verify error Bytes: 47104 Block#90 Verify error Bytes: 45056 Block#91 Verify error Bytes: 59374 Block#92 Verify error Bytes: 61423 Block#93 Verify error Bytes: 45037 Block#94 Verify error Bytes: 55278 Block#95 Verify error Bytes: 53231 Block#96 Verify error Bytes: 51200 Block#97 Verify error Bytes: 42990 Block#98 Verify error Bytes: 45056 Block#99 Verify error Bytes: 49152 Block#100 Verify error Bytes: 55296 Block#101 Verify error Bytes: 57326 Block#102 Verify error Bytes: 36864 Block#103 Verify error Bytes: 55296 Block#104 Verify error Bytes: 51200 Block#105 Verify error Bytes: 42991 Block#106 Verify error Bytes: 63096 Block#107 Verify error Bytes: 59171 Block#108 Verify error Bytes: 53006 Block#109 Verify error Bytes: 57122 Block#110 Verify error Bytes: 65287 Block#111 Verify error Bytes: 50971 Block#112 Verify error Bytes: 61189 Block#113 Verify error Bytes: 67322 Block#114 Verify error Bytes: 65286 Block#115 Verify error Bytes: 53050 Block#116 Verify error Bytes: 53017 Block#117 Verify error Bytes: 67333 Block#118 Verify error Bytes: 75498 Block#119 Verify error Bytes: 48947 Block#120 Verify error Bytes: 71391 Block#121 Verify error Bytes: 67293 Block#122 Verify error Bytes: 71400 Block#123 Verify error Bytes: 55094 Block#124 Verify error Bytes: 67306 Block#125 Verify error Bytes: 75493 Block#126 Verify error Bytes: 69370 Block#127 Verify error Bytes: 53040 Block#128 Verify error Bytes: 59174 Block#129 Verify error Bytes: 67285 Block#130 Verify error Bytes: 71417 Block#131 Verify error Bytes: 53051 Block#132 Verify error Bytes: 55089 Block#133 Verify error Bytes: 73413 Block#134 Verify error Bytes: 61198 Block#135 Verify error Bytes: 54690 Block#170 Verify error Bytes: 65274 Block#171 Verify error Bytes: 65258 Block#172 Verify error Bytes: 46918 Block#173 Verify error Bytes: 63253 Block#174 Verify error Bytes: 63213 Block#175 Verify error Bytes: 65283 Block#176 Verify error Bytes: 48965 Block#177 Verify error Bytes: 63237 Block#178 Verify error Bytes: 63200 Block#179 Verify error Bytes: 61170 Block#180 Verify error Bytes: 57135 Block#181 Verify error Bytes: 77527 Block#182 Verify error Bytes: 67333 Block#183 Verify error Bytes: 51010 Block#184 Verify error Bytes: 69397 Block#185 Verify error Bytes: 51006 Block#186 Verify error Bytes: 55086 Block#187 Verify error Bytes: 65254 Block#188 Verify error Bytes: 69365 Block#189 Verify error Bytes: 69365 Block#190 Verify error Bytes: 61217 Block#191 Verify error Bytes: 67291 Block#192 Verify error Bytes: 53031 Block#193 Verify error Bytes: 67301 Block#194 Verify error Bytes: 67345 Block#195 Verify error Bytes: 59148 Block#196 Verify error Bytes: 55066 Block#197 Verify error Bytes: 67322 Block#198 Verify error Bytes: 10545 Block#234 Verify error Bytes: 55296 Block#235 Verify error Bytes: 57344 Block#236 Verify error Bytes: 51153 Block#237 Verify error Bytes: 57344 Block#238 Verify error Bytes: 42961 Block#239 Verify error Bytes: 55296 Block#240 Verify error Bytes: 51200 Block#241 Verify error Bytes: 47104 Block#242 Verify error Bytes: 18432 Block#243 Verify error Bytes: 38912 Block#244 Verify error Bytes: 51200 Block#245 Verify error Bytes: 51200 Block#246 Verify error Bytes: 34816 Block#247 Verify error Bytes: 36864 Block#248 Verify error Bytes: 45056 Block#249 Verify error Bytes: 55296 Block#250 Verify error Bytes: 40960 Block#251 Verify error Bytes: 63488 Block#252 Verify error Bytes: 51200 Block#253 Verify error Bytes: 59345 Block#254 Verify error Bytes: 59392 Block#255 Verify error Bytes: 30720 Block#256 Verify error Bytes: 61440 Block#257 Verify error Bytes: 30720 Block#258 Verify error Bytes: 51200 Block#259 Verify error Bytes: 49105 Block#260 Verify error Bytes: 49152 Block#261 Verify error Bytes: 59392 Block#262 Verify error Bytes: 59392 Block#263 Verify error Bytes: 51153 Block#264 Verify error Bytes: 59392 Block#265 Verify error Bytes: 45056 Block#266 Verify error Bytes: 55249 Block#267 Verify error Bytes: 49152 Block#268 Verify error Bytes: 59345 Block#269 Verify error Bytes: 59392 Block#270 Verify error Bytes: 45056 Block#271 Verify error Bytes: 65536 Block#272 Verify error Bytes: 59392 Block#273 Verify error Bytes: 59392 Block#274 Verify error Bytes: 42961 Block#275 Verify error Bytes: 67537 Block#276 Verify error Bytes: 36864 Block#277 Verify error Bytes: 43008 Block#278 Verify error Bytes: 55249 Block#279 Verify error Bytes: 51200 Block#280 Verify error Bytes: 55296 Block#281 Verify error Bytes: 59392 Block#282 Verify error Bytes: 55296 Block#283 Verify error Bytes: 59392 Block#284 Verify error Bytes: 51200 Block#285 Verify error Bytes: 63441 Block#286 Verify error Bytes: 53201 Block#287 Verify error Bytes: 36864 Block#288 Verify error Bytes: 53201 Block#289 Verify error Bytes: 45056 Block#290 Verify error Bytes: 40960 Block#291 Verify error Bytes: 45056 Block#292 Verify error Bytes: 59392 Block#293 Verify error Bytes: 49152 Block#294 Verify error Bytes: 73728 Block#295 Verify error Bytes: 45056 Block#296 Verify error Bytes: 57344 Block#297 Verify error Bytes: 51200 Block#298 Verify error Bytes: 59392 Block#299 Verify error Bytes: 59392 Block#300 Verify error Bytes: 59345 Block#301 Verify error Bytes: 51200 Block#302 Verify error Bytes: 51153 Block#303 Verify error Bytes: 49152 Block#304 Verify error Bytes: 59392 Block#305 Verify error Bytes: 61440 Block#306 Verify error Bytes: 47104 Block#307 Verify error Bytes: 65536 Block#308 Verify error Bytes: 59392 Block#309 Verify error Bytes: 53248 Block#310 Verify error Bytes: 57344 Block#311 Verify error Bytes: 47057 Block#312 Verify error Bytes: 59345 Block#313 Verify error Bytes: 57344 Block#314 Verify error Bytes: 53248 Block#315 Verify error Bytes: 45056 Block#316 Verify error Bytes: 77450 Block#317 Verify error Bytes: 63236 Block#318 Verify error Bytes: 50963 Block#319 Verify error Bytes: 48938 Block#320 Verify error Bytes: 48932 Block#321 Verify error Bytes: 75450 Block#322 Verify error Bytes: 73376 Block#323 Verify error Bytes: 61179 Block#324 Verify error Bytes: 65243 Block#325 Verify error Bytes: 63284 Block#326 Verify error Bytes: 59126 Block#327 Verify error Bytes: 57060 Block#328 Verify error Bytes: 44811 Block#329 Verify error Bytes: 71396 Block#330 Verify error Bytes: 61196 Block#331 Verify error Bytes: 46924 Block#332 Verify error Bytes: 57061 Block#333 Verify error Bytes: 67275 Block#334 Verify error Bytes: 63222 Block#335 Verify error Bytes: 59116 Block#336 Verify error Bytes: 67277 Block#337 Verify error Bytes: 67289 Block#338 Verify error Bytes: 53015 Block#339 Verify error Bytes: 51032 Block#340 Verify error Bytes: 50974 Block#341 Verify error Bytes: 53201 Block#342 Verify error Bytes: 67307 Block#343 Verify error Bytes: 71409 Block#344 Verify error Bytes: 48950 Block#345 Verify error Bytes: 67317 Block#346 Verify error Bytes: 55126 Block#347 Verify error Bytes: 71312 Block#348 Verify error Bytes: 67325 Block#349 Verify error Bytes: 63160 Block#350 Verify error Bytes: 75438 Block#351 Verify error Bytes: 65219 Block#352 Verify error Bytes: 48935 Block#353 Verify error Bytes: 73345 Block#354 Verify error Bytes: 44838 Block#355 Verify error Bytes: 67278 Block#356 Verify error Bytes: 67260 Block#357 Verify error Bytes: 55030 Block#358 Verify error Bytes: 55071 Block#359 Verify error Bytes: 44872 Block#360 Verify error Bytes: 52972 Block#361 Verify error Bytes: 65203 Block#362 Verify error Bytes: 52995 Block#363 Verify error Bytes: 50926 Block#364 Verify error Bytes: 51022 Block#365 Verify error Bytes: 57059 Block#366 Verify error Bytes: 63203 Block#367 Verify error Bytes: 48838 Block#368 Verify error Bytes: 55296 Block#369 Verify error Bytes: 55296 Block#370 Verify error Bytes: 49152 Block#371 Verify error Bytes: 61440 Block#372 Verify error Bytes: 40960 Block#373 Verify error Bytes: 36864 Block#374 Verify error Bytes: 69276 Block#375 Verify error Bytes: 59072 Block#376 Verify error Bytes: 45056 Block#377 Verify error Bytes: 63137 Block#378 Verify error Bytes: 47057 Block#379 Verify error Bytes: 55296 Block#380 Verify error Bytes: 53044 Block#381 Verify error Bytes: 61199 Block#382 Verify error Bytes: 36864 Block#383 Verify error Bytes: 43008 Block#384 Verify error Bytes: 53248 Block#385 Verify error Bytes: 63488 Block#386 Verify error Bytes: 43008 Block#387 Verify error Bytes: 55296 Block#388 Verify error Bytes: 40960 Block#389 Verify error Bytes: 47104 Block#390 Verify error Bytes: 36864 Block#391 Verify error Bytes: 55296 Block#392 Verify error Bytes: 34816 Block#393 Verify error Bytes: 57297 Block#394 Verify error Bytes: 61440 Block#395 Verify error Bytes: 63488 Block#396 Verify error Bytes: 40960 Block#397 Verify error Bytes: 47104 Block#398 Verify error Bytes: 71633 Block#399 Verify error Bytes: 57344 Block#400 Verify error Bytes: 47104 Block#401 Verify error Bytes: 51200 Block#402 Verify error Bytes: 53248 Block#403 Verify error Bytes: 55296 Block#404 Verify error Bytes: 45056 Block#405 Verify error Bytes: 63488 Block#406 Verify error Bytes: 65489 Block#407 Verify error Bytes: 45056 Block#408 Verify error Bytes: 67584 Block#409 Verify error Bytes: 47104 Block#410 Verify error Bytes: 57344 Block#411 Verify error Bytes: 34816 Block#412 Verify error Bytes: 55249 Block#413 Verify error Bytes: 51200 Block#414 Verify error Bytes: 63441 Block#415 Verify error Bytes: 45009 Block#416 Verify error Bytes: 45056 Block#417 Verify error Bytes: 59392 Block#418 Verify error Bytes: 55296 Block#419 Verify error Bytes: 59392 Block#420 Verify error Bytes: 49152 Block#421 Verify error Bytes: 51153 Block#422 Verify error Bytes: 61440 Block#423 Verify error Bytes: 53248 Block#424 Verify error Bytes: 59392 Block#425 Verify error Bytes: 53248 Block#426 Verify error Bytes: 53248 Block#427 Verify error Bytes: 47104 Block#428 Verify error Bytes: 43008 Block#429 Verify error Bytes: 51153 Block#430 Verify error Bytes: 55296 Block#431 Verify error Bytes: 47104 Block#432 Verify error Bytes: 28672 Block#433 Verify error Bytes: 51200 Block#434 Verify error Bytes: 55249 Block#435 Verify error Bytes: 51153 Block#436 Verify error Bytes: 51200 Block#437 Verify error Bytes: 59392 Block#438 Verify error Bytes: 34816 Block#439 Verify error Bytes: 57344 Block#440 Verify error Bytes: 49152 Block#441 Verify error Bytes: 59392 Block#442 Verify error Bytes: 55296 Block#443 Verify error Bytes: 49105 Block#444 Verify error Bytes: 65536 Block#445 Verify error Bytes: 57297 Block#446 Verify error Bytes: 51200 Block#447 Verify error Bytes: 50995 Block#448 Verify error Bytes: 69632 Block#449 Verify error Bytes: 51153 Block#450 Verify error Bytes: 53248 Block#451 Verify error Bytes: 51200 Block#452 Verify error Bytes: 38912 Block#453 Verify error Bytes: 81873 Block#454 Verify error Bytes: 57344 Block#455 Verify error Bytes: 49152 Block#456 Verify error Bytes: 43008 Block#457 Verify error Bytes: 57344 Block#458 Verify error Bytes: 28672 Block#459 Verify error Bytes: 61440 Block#460 Verify error Bytes: 51200 Block#461 Verify error Bytes: 65489 Block#462 Verify error Bytes: 40960 Block#463 Verify error Bytes: 40960 Block#464 Verify error Bytes: 53248 Block#465 Verify error Bytes: 49152 Block#466 Verify error Bytes: 61393 Block#467 Verify error Bytes: 55296 Block#468 Verify error Bytes: 49152 Block#469 Verify error Bytes: 59345 Block#470 Verify error Bytes: 69585 Block#471 Verify error Bytes: 53248 Block#472 Verify error Bytes: 55249 Block#473 Verify error Bytes: 55296 Block#474 Verify error Bytes: 55296 Block#475 Verify error Bytes: 59392 Block#476 Verify error Bytes: 61440 Block#477 Verify error Bytes: 40960 Block#478 Verify error Bytes: 61393 Block#479 Verify error Bytes: 55296 Block#480 Verify error Bytes: 57344 Block#481 Verify error Bytes: 49152 Block#482 Verify error Bytes: 38912 Block#483 Verify error Bytes: 69585 Block#484 Verify error Bytes: 53248 Block#485 Verify error Bytes: 53201 Block#486 Verify error Bytes: 45056 Block#487 Verify error Bytes: 38912 Block#488 Verify error Bytes: 51200 Block#489 Verify error Bytes: 51200 Block#490 Verify error Bytes: 47104 Block#491 Verify error Bytes: 43008 Block#492 Verify error Bytes: 55296 Block#493 Verify error Bytes: 59392 Block#494 Verify error Bytes: 43008 Block#495 Verify error Bytes: 49152 Block#496 Verify error Bytes: 61440 Block#497 Verify error Bytes: 59392 Block#498 Verify error Bytes: 63197 Block#499 Verify error Bytes: 57090 Block#500 Verify error Bytes: 57140 Block#501 Verify error Bytes: 65278 Block#502 Verify error Bytes: 81508 Block#503 Verify error Bytes: 67262 Block#504 Verify error Bytes: 67275 Block#505 Verify error Bytes: 63197 Block#506 Verify error Bytes: 67255 Block#507 Verify error Bytes: 65180 Block#508 Verify error Bytes: 59036 Block#509 Verify error Bytes: 57096 Block#510 Verify error Bytes: 65192 Block#511 Verify error Bytes: 69280 Block#512 Verify error Bytes: 49104 Block#513 Verify error Bytes: 45056 Block#514 Verify error Bytes: 51152 Block#515 Verify error Bytes: 57344 Block#516 Verify error Bytes: 43008 Block#517 Verify error Bytes: 61440 Block#518 Verify error Bytes: 40960 Block#519 Verify error Bytes: 47104 Block#520 Verify error Bytes: 53200 Block#521 Verify error Bytes: 53200 Block#522 Verify error Bytes: 57344 Block#523 Verify error Bytes: 51200 Block#524 Verify error Bytes: 59392 Block#525 Verify error Bytes: 51200 Block#526 Verify error Bytes: 57344 Block#527 Verify error Bytes: 38912 Block#528 Verify error Bytes: 55296 Block#529 Verify error Bytes: 59344 Block#530 Verify error Bytes: 34816 Block#531 Verify error Bytes: 45056 Block#532 Verify error Bytes: 53200 Block#533 Verify error Bytes: 55296 Block#534 Verify error Bytes: 57296 Block#535 Verify error Bytes: 34816 Block#536 Verify error Bytes: 53248 Block#537 Verify error Bytes: 42960 Block#538 Verify error Bytes: 59392 Block#539 Verify error Bytes: 55296 Block#540 Verify error Bytes: 43008 Block#541 Verify error Bytes: 49152 Block#542 Verify error Bytes: 57344 Block#543 Verify error Bytes: 36864 Block#544 Verify error Bytes: 57296 Block#545 Verify error Bytes: 55296 Block#546 Verify error Bytes: 57344 Block#547 Verify error Bytes: 53248 Block#548 Verify error Bytes: 53248 Block#549 Verify error Bytes: 43008 Block#550 Verify error Bytes: 61440 Block#551 Verify error Bytes: 63488 Block#552 Verify error Bytes: 40960 Block#553 Verify error Bytes: 53248 Block#554 Verify error Bytes: 43008 Block#555 Verify error Bytes: 63488 Block#556 Verify error Bytes: 53248 Block#557 Verify error Bytes: 49152 Block#558 Verify error Bytes: 55296 Block#559 Verify error Bytes: 51200 Block#560 Verify error Bytes: 59344 Block#561 Verify error Bytes: 49152 Block#562 Verify error Bytes: 51200 Block#563 Verify error Bytes: 51200 Block#564 Verify error Bytes: 59392 Block#565 Verify error Bytes: 57296 Block#566 Verify error Bytes: 49104 Block#567 Verify error Bytes: 61440 Block#568 Verify error Bytes: 53248 Block#569 Verify error Bytes: 59344 Block#570 Verify error Bytes: 45056 Block#571 Verify error Bytes: 59392 Block#572 Verify error Bytes: 49152 Block#573 Verify error Bytes: 38912 Block#574 Verify error Bytes: 61156 Block#575 Verify error Bytes: 57344 Block#576 Verify error Bytes: 48885 Block#577 Verify error Bytes: 67262 Block#578 Verify error Bytes: 47104 Block#579 Verify error Bytes: 51152 Block#580 Verify error Bytes: 53054 Block#581 Verify error Bytes: 67296 Block#582 Verify error Bytes: 63191 Block#583 Verify error Bytes: 65299 Block#584 Verify error Bytes: 53248 Block#585 Verify error Bytes: 65488 Block#586 Verify error Bytes: 57296 Block#587 Verify error Bytes: 57344 Block#588 Verify error Bytes: 45056 Block#589 Verify error Bytes: 49104 Block#590 Verify error Bytes: 40960 Block#591 Verify error Bytes: 45056 Block#592 Verify error Bytes: 40960 Block#593 Verify error Bytes: 67584 Block#594 Verify error Bytes: 45056 Block#595 Verify error Bytes: 57344 Block#596 Verify error Bytes: 40960 Block#597 Verify error Bytes: 45056 Block#598 Verify error Bytes: 45056 Block#599 Verify error Bytes: 49152 Block#600 Verify error Bytes: 55296 Block#601 Verify error Bytes: 61392 Block#602 Verify error Bytes: 38912 Block#603 Verify error Bytes: 36816 Block#604 Verify error Bytes: 42960 Block#605 Verify error Bytes: 60755 Block#606 Verify error Bytes: 43098 Block#607 Verify error Bytes: 40995 Block#608 Verify error Bytes: 61489 Block#609 Verify error Bytes: 43423 Block#610 Verify error Bytes: 31472 Block#611 Verify error Bytes: 30720 Block#612 Verify error Bytes: 47104 Block#613 Verify error Bytes: 42960 Block#614 Verify error Bytes: 43008 Block#615 Verify error Bytes: 53200 Block#616 Verify error Bytes: 57344 Block#617 Verify error Bytes: 59392 Block#618 Verify error Bytes: 61440 Block#619 Verify error Bytes: 59392 Block#620 Verify error Bytes: 69632 Block#621 Verify error Bytes: 51200 Block#622 Verify error Bytes: 30759 Block#623 Verify error Bytes: 38912 Block#624 Verify error Bytes: 45056 Block#625 Verify error Bytes: 53248 Block#626 Verify error Bytes: 49191 Block#627 Verify error Bytes: 36864 Block#628 Verify error Bytes: 47104 Block#629 Verify error Bytes: 45139 Block#630 Verify error Bytes: 55296 Block#631 Verify error Bytes: 57296 Block#632 Verify error Bytes: 55296 Block#633 Verify error Bytes: 47104 Block#634 Verify error Bytes: 36864 Block#635 Verify error Bytes: 55296 Block#636 Verify error Bytes: 49104 Block#637 Verify error Bytes: 45056 Block#638 Verify error Bytes: 40960 Block#639 Verify error Bytes: 55296 Block#640 Verify error Bytes: 51200 Block#641 Verify error Bytes: 32768 Block#642 Verify error Bytes: 57296 Block#643 Verify error Bytes: 55296 Block#644 Verify error Bytes: 57296 Block#645 Verify error Bytes: 40960 Block#646 Verify error Bytes: 45056 Block#647 Verify error Bytes: 34768 Block#648 Verify error Bytes: 34768 Block#649 Verify error Bytes: 40960 Block#650 Verify error Bytes: 36864 Block#651 Verify error Bytes: 63194 Block#652 Verify error Bytes: 38754 Block#653 Verify error Bytes: 40764 Block#654 Verify error Bytes: 58855 Block#655 Verify error Bytes: 36797 Block#656 Verify error Bytes: 38941 Block#657 Verify error Bytes: 38897 Block#658 Verify error Bytes: 69579 Block#659 Verify error Bytes: 49151 Block#660 Verify error Bytes: 42996 Block#661 Verify error Bytes: 34804 Block#662 Verify error Bytes: 51220 Block#663 Verify error Bytes: 35252 Block#664 Verify error Bytes: 37699 Block#665 Verify error Bytes: 55296 Block#666 Verify error Bytes: 45056 Block#667 Verify error Bytes: 40960 Block#668 Verify error Bytes: 43008 Block#669 Verify error Bytes: 57344 Block#670 Verify error Bytes: 53248 Block#671 Verify error Bytes: 38912 Block#672 Verify error Bytes: 47104 Block#673 Verify error Bytes: 63488 Block#674 Verify error Bytes: 42960 Block#675 Verify error Bytes: 36816 Block#676 Verify error Bytes: 53248 Block#677 Verify error Bytes: 63488 Block#678 Verify error Bytes: 45056 Block#679 Verify error Bytes: 43008 Block#680 Verify error Bytes: 47104 Block#681 Verify error Bytes: 65488 Block#682 Verify error Bytes: 53248 Block#683 Verify error Bytes: 36864 Block#684 Verify error Bytes: 47056 Block#685 Verify error Bytes: 59392 Block#686 Verify error Bytes: 30720 Block#687 Verify error Bytes: 47104 Block#688 Verify error Bytes: 51200 Block#689 Verify error Bytes: 42960 Block#690 Verify error Bytes: 42960 Block#691 Verify error Bytes: 30720 Block#692 Verify error Bytes: 55087 Block#693 Verify error Bytes: 73328 Block#694 Verify error Bytes: 61164 Block#695 Verify error Bytes: 44906 Block#696 Verify error Bytes: 32589 Block#697 Verify error Bytes: 61097 Block#698 Verify error Bytes: 34679 Block#699 Verify error Bytes: 53026 Block#700 Verify error Bytes: 40822 Block#701 Verify error Bytes: 54999 Block#702 Verify error Bytes: 57101 Block#703 Verify error Bytes: 50942 Block#704 Verify error Bytes: 59133 Block#705 Verify error Bytes: 59190 Block#706 Verify error Bytes: 59077 Block#707 Verify error Bytes: 71423 Block#708 Verify error Bytes: 57092 Block#709 Verify error Bytes: 48960 Block#710 Verify error Bytes: 67314 Block#711 Verify error Bytes: 67250 Block#712 Verify error Bytes: 65225 Block#713 Verify error Bytes: 61187 Block#714 Verify error Bytes: 71382 Block#715 Verify error Bytes: 57073 Block#716 Verify error Bytes: 53004 Block#717 Verify error Bytes: 57141 Block#718 Verify error Bytes: 53034 Block#719 Verify error Bytes: 59183 Block#720 Verify error Bytes: 63169 Block#721 Verify error Bytes: 61172 Block#722 Verify error Bytes: 69303 Block#723 Verify error Bytes: 48939 Block#724 Verify error Bytes: 50958 Block#725 Verify error Bytes: 75495 Block#726 Verify error Bytes: 65288 Block#727 Verify error Bytes: 59154 Block#728 Verify error Bytes: 63273 Block#729 Verify error Bytes: 59163 Block#730 Verify error Bytes: 48914 Block#731 Verify error Bytes: 65298 Block#732 Verify error Bytes: 51017 Block#733 Verify error Bytes: 71325 Block#734 Verify error Bytes: 57171 Block#735 Verify error Bytes: 65234 Block#736 Verify error Bytes: 53022 Block#737 Verify error Bytes: 51200 Block#738 Verify error Bytes: 61087 Block#739 Verify error Bytes: 63193 Block#740 Verify error Bytes: 53009 Block#741 Verify error Bytes: 63165 Block#742 Verify error Bytes: 59110 Block#743 Verify error Bytes: 57103 Block#744 Verify error Bytes: 46850 Block#745 Verify error Bytes: 71374 Block#746 Verify error Bytes: 49152 Block#747 Verify error Bytes: 67584 Block#748 Verify error Bytes: 55248 Block#749 Verify error Bytes: 40960 Block#750 Verify error Bytes: 42960 Block#751 Verify error Bytes: 32768 Block#752 Verify error Bytes: 45056 Block#753 Verify error Bytes: 36864 Block#754 Verify error Bytes: 53248 Block#755 Verify error Bytes: 55296 Block#756 Verify error Bytes: 38864 Block#757 Verify error Bytes: 57344 Block#758 Verify error Bytes: 36864 Block#759 Verify error Bytes: 51200 Block#760 Verify error Bytes: 55296 Block#761 Verify error Bytes: 67536 Block#762 Verify error Bytes: 47056 Block#763 Verify error Bytes: 46937 Block#764 Verify error Bytes: 59089 Block#765 Verify error Bytes: 53248 Block#766 Verify error Bytes: 61160 Block#767 Verify error Bytes: 52968 Block#768 Verify error Bytes: 55042 Block#769 Verify error Bytes: 50901 Block#770 Verify error Bytes: 71325 Block#771 Verify error Bytes: 65226 Block#772 Verify error Bytes: 49152 Block#773 Verify error Bytes: 57296 Block#774 Verify error Bytes: 61177 Block#775 Verify error Bytes: 34816 Block#776 Verify error Bytes: 65195 Block#777 Verify error Bytes: 42960 Block#778 Verify error Bytes: 51200 Block#779 Verify error Bytes: 40912 Block#780 Verify error Bytes: 52997 Block#781 Verify error Bytes: 49104 Block#782 Verify error Bytes: 45008 Block#783 Verify error Bytes: 63488 Block#784 Verify error Bytes: 47104 Block#785 Verify error Bytes: 59392 Block#786 Verify error Bytes: 57344 Block#787 Verify error Bytes: 53248 Block#788 Verify error Bytes: 42960 Block#789 Verify error Bytes: 53248 Block#790 Verify error Bytes: 55296 Block#791 Verify error Bytes: 45056 Block#792 Verify error Bytes: 57344 Block#793 Verify error Bytes: 69354 Block#794 Verify error Bytes: 71340 Block#795 Verify error Bytes: 49152 Block#796 Verify error Bytes: 55296 Block#797 Verify error Bytes: 59123 Block#798 Verify error Bytes: 50966 Block#799 Verify error Bytes: 55032 Block#800 Verify error Bytes: 46882 Block#801 Verify error Bytes: 67309 Block#802 Verify error Bytes: 67288 Block#803 Verify error Bytes: 59111 Block#804 Verify error Bytes: 61131 Block#805 Verify error Bytes: 69257 Block#806 Verify error Bytes: 59160 Block#807 Verify error Bytes: 30624 Block#808 Verify error Bytes: 48977 Block#809 Verify error Bytes: 57059 Block#810 Verify error Bytes: 46940 Block#811 Verify error Bytes: 69348 Block#812 Verify error Bytes: 61237 Block#813 Verify error Bytes: 51200 Block#814 Verify error Bytes: 49104 Block#815 Verify error Bytes: 38912 Block#816 Verify error Bytes: 51200 Block#817 Verify error Bytes: 36816 Block#818 Verify error Bytes: 47104 Block#819 Verify error Bytes: 40960 Block#820 Verify error Bytes: 57344 Block#821 Verify error Bytes: 49152 Block#822 Verify error Bytes: 59392 Block#823 Verify error Bytes: 51152 Block#824 Verify error Bytes: 65536 Block#825 Verify error Bytes: 59392 Block#826 Verify error Bytes: 47104 Block#827 Verify error Bytes: 47104 Block#828 Verify error Bytes: 65536 Block#829 Verify error Bytes: 34816 Block#830 Verify error Bytes: 49152 Block#831 Verify error Bytes: 47104 Block#832 Verify error Bytes: 40960 Block#833 Verify error Bytes: 36864 Block#834 Verify error Bytes: 49104 Block#835 Verify error Bytes: 34816 Block#836 Verify error Bytes: 49104 Block#837 Verify error Bytes: 53200 Block#838 Verify error Bytes: 49152 Block#839 Verify error Bytes: 59392 Block#840 Verify error Bytes: 57344 Block#841 Verify error Bytes: 53248 Block#842 Verify error Bytes: 53200 Block#843 Verify error Bytes: 43008 Block#844 Verify error Bytes: 36864 Block#845 Verify error Bytes: 50959 Block#846 Verify error Bytes: 67254 Block#847 Verify error Bytes: 65206 Block#848 Verify error Bytes: 55006 Block#849 Verify error Bytes: 40779 Block#850 Verify error Bytes: 67274 Block#851 Verify error Bytes: 53002 Block#852 Verify error Bytes: 40960 Block#853 Verify error Bytes: 67247 Block#854 Verify error Bytes: 73359 Block#855 Verify error Bytes: 46918 Block#856 Verify error Bytes: 61162 Block#857 Verify error Bytes: 61184 Block#858 Verify error Bytes: 43008 Block#859 Verify error Bytes: 42705 Block#860 Verify error Bytes: 36723 Block#861 Verify error Bytes: 59153 Block#862 Verify error Bytes: 57296 Block#863 Verify error Bytes: 63259 Block#864 Verify error Bytes: 44917 Block#865 Verify error Bytes: 34816 Block#866 Verify error Bytes: 51200 Block#867 Verify error Bytes: 55296 Block#868 Verify error Bytes: 40960 Block#869 Verify error Bytes: 36864 Block#870 Verify error Bytes: 45056 Block#871 Verify error Bytes: 53248 Block#872 Verify error Bytes: 36864 Block#873 Verify error Bytes: 69584 Block#874 Verify error Bytes: 55248 Block#875 Verify error Bytes: 38912 Block#876 Verify error Bytes: 47104 Block#877 Verify error Bytes: 47056 Block#878 Verify error Bytes: 49152 Block#879 Verify error Bytes: 51200 Block#880 Verify error Bytes: 53248 Block#881 Verify error Bytes: 42960 Block#882 Verify error Bytes: 53248 Block#883 Verify error Bytes: 53248 Block#884 Verify error Bytes: 45056 Block#885 Verify error Bytes: 49104 Block#886 Verify error Bytes: 51152 Block#887 Verify error Bytes: 47104 Block#888 Verify error Bytes: 55296 Block#889 Verify error Bytes: 30720 Block#890 Verify error Bytes: 49152 Block#891 Verify error Bytes: 38864 Block#892 Verify error Bytes: 47104 Block#893 Verify error Bytes: 61440 Block#894 Verify error Bytes: 47104 Block#895 Verify error Bytes: 53201 Block#896 Verify error Bytes: 43008 Block#897 Verify error Bytes: 36864 Block#898 Verify error Bytes: 34816 Block#899 Verify error Bytes: 36864 Block#900 Verify error Bytes: 40912 Block#901 Verify error Bytes: 36864 Block#902 Verify error Bytes: 51200 Block#903 Verify error Bytes: 49152 Block#904 Verify error Bytes: 43008 Block#905 Verify error Bytes: 49152 Block#906 Verify error Bytes: 40960 Block#907 Verify error Bytes: 53248 Block#908 Verify error Bytes: 57344 Block#909 Verify error Bytes: 34816 Block#910 Verify error Bytes: 43008 Block#911 Verify error Bytes: 61440 Block#912 Verify error Bytes: 47104 Block#913 Verify error Bytes: 43008 Block#914 Verify error Bytes: 57296 Block#915 Verify error Bytes: 61440 Block#916 Verify error Bytes: 40960 Block#917 Verify error Bytes: 55296 Block#918 Verify error Bytes: 49152 Block#919 Verify error Bytes: 45056 Block#920 Verify error Bytes: 32768 Block#921 Verify error Bytes: 53248 Block#922 Verify error Bytes: 43008 Block#923 Verify error Bytes: 40912 Block#924 Verify error Bytes: 42960 Block#925 Verify error Bytes: 49152 Block#926 Verify error Bytes: 42960 Block#927 Verify error Bytes: 57296 Block#928 Verify error Bytes: 49152 Block#929 Verify error Bytes: 32768 Block#930 Verify error Bytes: 36864 Block#931 Verify error Bytes: 43008 Block#932 Verify error Bytes: 40912 Block#933 Verify error Bytes: 40960 Block#934 Verify error Bytes: 57296 Block#935 Verify error Bytes: 38912 Block#936 Verify error Bytes: 47104 Block#937 Verify error Bytes: 45008 Block#938 Verify error Bytes: 73304 Block#939 Verify error Bytes: 43008 Block#940 Verify error Bytes: 51200 Block#941 Verify error Bytes: 55296 Block#942 Verify error Bytes: 49152 Block#943 Verify error Bytes: 40960 Block#944 Verify error Bytes: 38912 Block#945 Verify error Bytes: 34816 Block#946 Verify error Bytes: 53248 Block#947 Verify error Bytes: 40960 Block#948 Verify error Bytes: 45056 Block#949 Verify error Bytes: 47104 Block#950 Verify error Bytes: 49152 Block#951 Verify error Bytes: 47056 Block#952 Verify error Bytes: 55248 Block#953 Verify error Bytes: 38912 Block#954 Verify error Bytes: 43008 Block#955 Verify error Bytes: 47104 Block#956 Verify error Bytes: 47056 Block#957 Verify error Bytes: 49152 Block#958 Verify error Bytes: 30720 Block#959 Verify error Bytes: 45008 Block#960 Verify error Bytes: 47056 Block#961 Verify error Bytes: 34816 Block#962 Verify error Bytes: 36816 Block#963 Verify error Bytes: 43008 Block#964 Verify error Bytes: 36864 Block#965 Verify error Bytes: 59392 Block#966 Verify error Bytes: 47104 Block#967 Verify error Bytes: 51152 Block#968 Verify error Bytes: 55296 Block#969 Verify error Bytes: 49152 Block#970 Verify error Bytes: 36864 Block#971 Verify error Bytes: 45056 Block#972 Verify error Bytes: 61392 Block#973 Verify error Bytes: 45056 Block#974 Verify error Bytes: 40960 Block#975 Verify error Bytes: 38912 Block#976 Verify error Bytes: 34816 Block#977 Verify error Bytes: 53248 Block#978 Verify error Bytes: 38864 Block#979 Verify error Bytes: 38864 Block#980 Verify error Bytes: 59392 Block#981 Verify error Bytes: 40960 Block#982 Verify error Bytes: 43008 Block#983 Verify error Bytes: 47104 Block#984 Verify error Bytes: 36816 Block#985 Verify error Bytes: 59392 Block#986 Verify error Bytes: 59392 Block#987 Verify error Bytes: 51200 Block#988 Verify error Bytes: 45008 Block#989 Verify error Bytes: 53248 Block#990 Verify error Bytes: 45056 Block#991 Verify error Bytes: 36864 Block#992 Verify error Bytes: 53200 Block#993 Verify error Bytes: 45056 Block#994 Verify error Bytes: 45008 Block#995 Verify error Bytes: 67536 Block#996 Verify error Bytes: 55296 Block#997 Verify error Bytes: 51200 Block#998 Verify error Bytes: 47104 Block#999 Verify error Bytes: 32768 Block#1000 Verify error Bytes: 49152 Block#1001 Verify error Bytes: 45008 Block#1002 Verify error Bytes: 49104 Block#1003 Verify error Bytes: 38912 Block#1004 Verify error Bytes: 55296 Block#1005 Verify error Bytes: 49152 Block#1006 Verify error Bytes: 43008 Block#1007 Verify error Bytes: 45056 Block#1008 Verify error Bytes: 47104 Block#1009 Verify error Bytes: 38912 Block#1010 Verify error Bytes: 63440 Block#1011 Verify error Bytes: 51200 Block#1012 Verify error Bytes: 45056 Block#1013 Verify error Bytes: 45056 Block#1014 Verify error Bytes: 45009 Block#1015 Verify error Bytes: 40960 Block#1016 Verify error Bytes: 55296 Block#1017 Verify error Bytes: 53201 Block#1018 Verify error Bytes: 59392 Block#1019 Verify error Bytes: 59345 Block#1020 Verify error Bytes: 36864 Block#1021 Verify error Bytes: 55296 Block#1022 Verify error Bytes: 51200 Block#1023 Verify error Bytes: 45056 Verify Error Blocks: 935
