APP Version : 13.17 Model : T76 MFG:2025-10-29 Device : W25N01GW(x1+ISP) @WSON8 Reminder: Ordinary adapters have high EMI This type of chip is recommended to use a socket with Electromagnetic Shielding! Pin Detected Passed. Erase NAND FLash : Succeeded. Time : 1062 ms Byffer File Size: 135168KB Programming Nand Flash : Succeeded. Time : 112.719 S -- Flash Size :135168 KB Verifying Nand Flash ... Block#0 Verify error Bytes: 117520 Block#1 Verify error Bytes: 116143 Block#4 Verify error Bytes: 129506 Block#5 Verify error Bytes: 131072 Block#6 Verify error Bytes: 129506 Block#7 Verify error Bytes: 131072 Block#8 Verify error Bytes: 121439 Block#10 Verify error Bytes: 130720 Block#12 Verify error Bytes: 99047 Block#13 Verify error Bytes: 113829 Block#20 Verify error Bytes: 99047 Block#21 Verify error Bytes: 113829 Block#28 Verify error Bytes: 50586 Block#29 Verify error Bytes: 116642 Block#30 Verify error Bytes: 131072 Block#31 Verify error Bytes: 131072 Block#32 Verify error Bytes: 50586 Block#33 Verify error Bytes: 116642 Block#34 Verify error Bytes: 131072 Block#35 Verify error Bytes: 131072 Block#36 Verify error Bytes: 130721 Block#38 Verify error Bytes: 130721 Block#42 Verify error Bytes: 129409 Block#43 Verify error Bytes: 129640 Block#44 Verify error Bytes: 130984 Block#45 Verify error Bytes: 131055 Block#46 Verify error Bytes: 131054 Block#47 Verify error Bytes: 131055 Block#48 Verify error Bytes: 131054 Block#49 Verify error Bytes: 131054 Block#50 Verify error Bytes: 131055 Block#51 Verify error Bytes: 131055 Block#52 Verify error Bytes: 131054 Block#53 Verify error Bytes: 131054 Block#54 Verify error Bytes: 131055 Block#55 Verify error Bytes: 131054 Block#56 Verify error Bytes: 131055 Block#57 Verify error Bytes: 131055 Block#58 Verify error Bytes: 131054 Block#59 Verify error Bytes: 131055 Block#60 Verify error Bytes: 131054 Block#61 Verify error Bytes: 131054 Block#62 Verify error Bytes: 131055 Block#63 Verify error Bytes: 131054 Block#64 Verify error Bytes: 131055 Block#65 Verify error Bytes: 131055 Block#66 Verify error Bytes: 131054 Block#67 Verify error Bytes: 131054 Block#68 Verify error Bytes: 131055 Block#69 Verify error Bytes: 131055 Block#70 Verify error Bytes: 131054 Block#71 Verify error Bytes: 131055 Block#72 Verify error Bytes: 131054 Block#73 Verify error Bytes: 131054 Block#74 Verify error Bytes: 131055 Block#75 Verify error Bytes: 131054 Block#76 Verify error Bytes: 131055 Block#77 Verify error Bytes: 131055 Block#78 Verify error Bytes: 131053 Block#79 Verify error Bytes: 131055 Block#80 Verify error Bytes: 131054 Block#81 Verify error Bytes: 131054 Block#82 Verify error Bytes: 131055 Block#83 Verify error Bytes: 131054 Block#84 Verify error Bytes: 131054 Block#85 Verify error Bytes: 131054 Block#86 Verify error Bytes: 131055 Block#87 Verify error Bytes: 131054 Block#88 Verify error Bytes: 131054 Block#89 Verify error Bytes: 131055 Block#90 Verify error Bytes: 131054 Block#91 Verify error Bytes: 131054 Block#92 Verify error Bytes: 131055 Block#93 Verify error Bytes: 131053 Block#94 Verify error Bytes: 131054 Block#95 Verify error Bytes: 131055 Block#96 Verify error Bytes: 131054 Block#97 Verify error Bytes: 131054 Block#98 Verify error Bytes: 131055 Block#99 Verify error Bytes: 131054 Block#100 Verify error Bytes: 131054 Block#101 Verify error Bytes: 131054 Block#102 Verify error Bytes: 131055 Block#103 Verify error Bytes: 131054 Block#104 Verify error Bytes: 131055 Block#105 Verify error Bytes: 131055 Block#106 Verify error Bytes: 130420 Block#107 Verify error Bytes: 130582 Block#108 Verify error Bytes: 130533 Block#109 Verify error Bytes: 130534 Block#110 Verify error Bytes: 130557 Block#111 Verify error Bytes: 130527 Block#112 Verify error Bytes: 130554 Block#113 Verify error Bytes: 130580 Block#114 Verify error Bytes: 130582 Block#115 Verify error Bytes: 130557 Block#116 Verify error Bytes: 130562 Block#117 Verify error Bytes: 130602 Block#118 Verify error Bytes: 130566 Block#119 Verify error Bytes: 130570 Block#120 Verify error Bytes: 130577 Block#121 Verify error Bytes: 130509 Block#122 Verify error Bytes: 130591 Block#123 Verify error Bytes: 130539 Block#124 Verify error Bytes: 130546 Block#125 Verify error Bytes: 130578 Block#126 Verify error Bytes: 130587 Block#127 Verify error Bytes: 130554 Block#128 Verify error Bytes: 130570 Block#129 Verify error Bytes: 130520 Block#130 Verify error Bytes: 130572 Block#131 Verify error Bytes: 130573 Block#132 Verify error Bytes: 130583 Block#133 Verify error Bytes: 130535 Block#134 Verify error Bytes: 130541 Block#135 Verify error Bytes: 129979 Block#170 Verify error Bytes: 130423 Block#171 Verify error Bytes: 130555 Block#172 Verify error Bytes: 130552 Block#173 Verify error Bytes: 130538 Block#174 Verify error Bytes: 130558 Block#175 Verify error Bytes: 130568 Block#176 Verify error Bytes: 130564 Block#177 Verify error Bytes: 130558 Block#178 Verify error Bytes: 130539 Block#179 Verify error Bytes: 130545 Block#180 Verify error Bytes: 130563 Block#181 Verify error Bytes: 130551 Block#182 Verify error Bytes: 130565 Block#183 Verify error Bytes: 130582 Block#184 Verify error Bytes: 130563 Block#185 Verify error Bytes: 130528 Block#186 Verify error Bytes: 130583 Block#187 Verify error Bytes: 130522 Block#188 Verify error Bytes: 130542 Block#189 Verify error Bytes: 130583 Block#190 Verify error Bytes: 130587 Block#191 Verify error Bytes: 130532 Block#192 Verify error Bytes: 130566 Block#193 Verify error Bytes: 130544 Block#194 Verify error Bytes: 130592 Block#195 Verify error Bytes: 130545 Block#196 Verify error Bytes: 130565 Block#197 Verify error Bytes: 130593 Block#198 Verify error Bytes: 22565 Block#234 Verify error Bytes: 129064 Block#235 Verify error Bytes: 129063 Block#236 Verify error Bytes: 131025 Block#237 Verify error Bytes: 131025 Block#238 Verify error Bytes: 131025 Block#239 Verify error Bytes: 131025 Block#240 Verify error Bytes: 131025 Block#241 Verify error Bytes: 131025 Block#242 Verify error Bytes: 131025 Block#243 Verify error Bytes: 131025 Block#244 Verify error Bytes: 131025 Block#245 Verify error Bytes: 131025 Block#246 Verify error Bytes: 131025 Block#247 Verify error Bytes: 131025 Block#248 Verify error Bytes: 131025 Block#249 Verify error Bytes: 131025 Block#250 Verify error Bytes: 131025 Block#251 Verify error Bytes: 131025 Block#252 Verify error Bytes: 131025 Block#253 Verify error Bytes: 131025 Block#254 Verify error Bytes: 131025 Block#255 Verify error Bytes: 131025 Block#256 Verify error Bytes: 131025 Block#257 Verify error Bytes: 131025 Block#258 Verify error Bytes: 131025 Block#259 Verify error Bytes: 131025 Block#260 Verify error Bytes: 131025 Block#261 Verify error Bytes: 131025 Block#262 Verify error Bytes: 131025 Block#263 Verify error Bytes: 131025 Block#264 Verify error Bytes: 131025 Block#265 Verify error Bytes: 131025 Block#266 Verify error Bytes: 131025 Block#267 Verify error Bytes: 131025 Block#268 Verify error Bytes: 131025 Block#269 Verify error Bytes: 131025 Block#270 Verify error Bytes: 131025 Block#271 Verify error Bytes: 131025 Block#272 Verify error Bytes: 131025 Block#273 Verify error Bytes: 131025 Block#274 Verify error Bytes: 131025 Block#275 Verify error Bytes: 131025 Block#276 Verify error Bytes: 131025 Block#277 Verify error Bytes: 131025 Block#278 Verify error Bytes: 131025 Block#279 Verify error Bytes: 131025 Block#280 Verify error Bytes: 131025 Block#281 Verify error Bytes: 131025 Block#282 Verify error Bytes: 131025 Block#283 Verify error Bytes: 131025 Block#284 Verify error Bytes: 131025 Block#285 Verify error Bytes: 131025 Block#286 Verify error Bytes: 131025 Block#287 Verify error Bytes: 131025 Block#288 Verify error Bytes: 131025 Block#289 Verify error Bytes: 131025 Block#290 Verify error Bytes: 131025 Block#291 Verify error Bytes: 131025 Block#292 Verify error Bytes: 131025 Block#293 Verify error Bytes: 131025 Block#294 Verify error Bytes: 131025 Block#295 Verify error Bytes: 131025 Block#296 Verify error Bytes: 131025 Block#297 Verify error Bytes: 131025 Block#298 Verify error Bytes: 131025 Block#299 Verify error Bytes: 131025 Block#300 Verify error Bytes: 131025 Block#301 Verify error Bytes: 131025 Block#302 Verify error Bytes: 131025 Block#303 Verify error Bytes: 131025 Block#304 Verify error Bytes: 131024 Block#305 Verify error Bytes: 131024 Block#306 Verify error Bytes: 131025 Block#307 Verify error Bytes: 131025 Block#308 Verify error Bytes: 131025 Block#309 Verify error Bytes: 131025 Block#310 Verify error Bytes: 131025 Block#311 Verify error Bytes: 131025 Block#312 Verify error Bytes: 131025 Block#313 Verify error Bytes: 131025 Block#314 Verify error Bytes: 131025 Block#315 Verify error Bytes: 131025 Block#316 Verify error Bytes: 128429 Block#317 Verify error Bytes: 128465 Block#318 Verify error Bytes: 128471 Block#319 Verify error Bytes: 128446 Block#320 Verify error Bytes: 128429 Block#321 Verify error Bytes: 128464 Block#322 Verify error Bytes: 128423 Block#323 Verify error Bytes: 128420 Block#324 Verify error Bytes: 128454 Block#325 Verify error Bytes: 128420 Block#326 Verify error Bytes: 128425 Block#327 Verify error Bytes: 128455 Block#328 Verify error Bytes: 128432 Block#329 Verify error Bytes: 128467 Block#330 Verify error Bytes: 128462 Block#331 Verify error Bytes: 128380 Block#332 Verify error Bytes: 128435 Block#333 Verify error Bytes: 128395 Block#334 Verify error Bytes: 128470 Block#335 Verify error Bytes: 128415 Block#336 Verify error Bytes: 128420 Block#337 Verify error Bytes: 128397 Block#338 Verify error Bytes: 128406 Block#339 Verify error Bytes: 128482 Block#340 Verify error Bytes: 128462 Block#341 Verify error Bytes: 131025 Block#342 Verify error Bytes: 128448 Block#343 Verify error Bytes: 128481 Block#344 Verify error Bytes: 128450 Block#345 Verify error Bytes: 128465 Block#346 Verify error Bytes: 128501 Block#347 Verify error Bytes: 128435 Block#348 Verify error Bytes: 128451 Block#349 Verify error Bytes: 128304 Block#350 Verify error Bytes: 128437 Block#351 Verify error Bytes: 128468 Block#352 Verify error Bytes: 128433 Block#353 Verify error Bytes: 128427 Block#354 Verify error Bytes: 128435 Block#355 Verify error Bytes: 128430 Block#356 Verify error Bytes: 128418 Block#357 Verify error Bytes: 128419 Block#358 Verify error Bytes: 128403 Block#359 Verify error Bytes: 128457 Block#360 Verify error Bytes: 128386 Block#361 Verify error Bytes: 128414 Block#362 Verify error Bytes: 128426 Block#363 Verify error Bytes: 128384 Block#364 Verify error Bytes: 128436 Block#365 Verify error Bytes: 128392 Block#366 Verify error Bytes: 128405 Block#367 Verify error Bytes: 128343 Block#368 Verify error Bytes: 131025 Block#369 Verify error Bytes: 131025 Block#370 Verify error Bytes: 131025 Block#371 Verify error Bytes: 131025 Block#372 Verify error Bytes: 131025 Block#373 Verify error Bytes: 131025 Block#374 Verify error Bytes: 128349 Block#375 Verify error Bytes: 128397 Block#376 Verify error Bytes: 131025 Block#377 Verify error Bytes: 128386 Block#378 Verify error Bytes: 131025 Block#379 Verify error Bytes: 131025 Block#380 Verify error Bytes: 128411 Block#381 Verify error Bytes: 128479 Block#382 Verify error Bytes: 131025 Block#383 Verify error Bytes: 131025 Block#384 Verify error Bytes: 131025 Block#385 Verify error Bytes: 131025 Block#386 Verify error Bytes: 131025 Block#387 Verify error Bytes: 131025 Block#388 Verify error Bytes: 131025 Block#389 Verify error Bytes: 131025 Block#390 Verify error Bytes: 131025 Block#391 Verify error Bytes: 131025 Block#392 Verify error Bytes: 131025 Block#393 Verify error Bytes: 131025 Block#394 Verify error Bytes: 131025 Block#395 Verify error Bytes: 131025 Block#396 Verify error Bytes: 131025 Block#397 Verify error Bytes: 131025 Block#398 Verify error Bytes: 131025 Block#399 Verify error Bytes: 131025 Block#400 Verify error Bytes: 131025 Block#401 Verify error Bytes: 131025 Block#402 Verify error Bytes: 131025 Block#403 Verify error Bytes: 131025 Block#404 Verify error Bytes: 131025 Block#405 Verify error Bytes: 131025 Block#406 Verify error Bytes: 131025 Block#407 Verify error Bytes: 131025 Block#408 Verify error Bytes: 131025 Block#409 Verify error Bytes: 131025 Block#410 Verify error Bytes: 131025 Block#411 Verify error Bytes: 131025 Block#412 Verify error Bytes: 131025 Block#413 Verify error Bytes: 131025 Block#414 Verify error Bytes: 131025 Block#415 Verify error Bytes: 131025 Block#416 Verify error Bytes: 131025 Block#417 Verify error Bytes: 131025 Block#418 Verify error Bytes: 131025 Block#419 Verify error Bytes: 131025 Block#420 Verify error Bytes: 131025 Block#421 Verify error Bytes: 131025 Block#422 Verify error Bytes: 131025 Block#423 Verify error Bytes: 131025 Block#424 Verify error Bytes: 131025 Block#425 Verify error Bytes: 131025 Block#426 Verify error Bytes: 131025 Block#427 Verify error Bytes: 131025 Block#428 Verify error Bytes: 131025 Block#429 Verify error Bytes: 131025 Block#430 Verify error Bytes: 131025 Block#431 Verify error Bytes: 131025 Block#432 Verify error Bytes: 131025 Block#433 Verify error Bytes: 131025 Block#434 Verify error Bytes: 131025 Block#435 Verify error Bytes: 131025 Block#436 Verify error Bytes: 131025 Block#437 Verify error Bytes: 131025 Block#438 Verify error Bytes: 131025 Block#439 Verify error Bytes: 131025 Block#440 Verify error Bytes: 131025 Block#441 Verify error Bytes: 131025 Block#442 Verify error Bytes: 131025 Block#443 Verify error Bytes: 131025 Block#444 Verify error Bytes: 131025 Block#445 Verify error Bytes: 131025 Block#446 Verify error Bytes: 131025 Block#447 Verify error Bytes: 128374 Block#448 Verify error Bytes: 131025 Block#449 Verify error Bytes: 131025 Block#450 Verify error Bytes: 131025 Block#451 Verify error Bytes: 131025 Block#452 Verify error Bytes: 131025 Block#453 Verify error Bytes: 131025 Block#454 Verify error Bytes: 131025 Block#455 Verify error Bytes: 131025 Block#456 Verify error Bytes: 131025 Block#457 Verify error Bytes: 131025 Block#458 Verify error Bytes: 131025 Block#459 Verify error Bytes: 131025 Block#460 Verify error Bytes: 131025 Block#461 Verify error Bytes: 131025 Block#462 Verify error Bytes: 131025 Block#463 Verify error Bytes: 131025 Block#464 Verify error Bytes: 131025 Block#465 Verify error Bytes: 131025 Block#466 Verify error Bytes: 131025 Block#467 Verify error Bytes: 131025 Block#468 Verify error Bytes: 131025 Block#469 Verify error Bytes: 131025 Block#470 Verify error Bytes: 131025 Block#471 Verify error Bytes: 131025 Block#472 Verify error Bytes: 131025 Block#473 Verify error Bytes: 131025 Block#474 Verify error Bytes: 131025 Block#475 Verify error Bytes: 131025 Block#476 Verify error Bytes: 131025 Block#477 Verify error Bytes: 131025 Block#478 Verify error Bytes: 131025 Block#479 Verify error Bytes: 131025 Block#480 Verify error Bytes: 131025 Block#481 Verify error Bytes: 131025 Block#482 Verify error Bytes: 131025 Block#483 Verify error Bytes: 131025 Block#484 Verify error Bytes: 131025 Block#485 Verify error Bytes: 131025 Block#486 Verify error Bytes: 131025 Block#487 Verify error Bytes: 131025 Block#488 Verify error Bytes: 131025 Block#489 Verify error Bytes: 131025 Block#490 Verify error Bytes: 131025 Block#491 Verify error Bytes: 131025 Block#492 Verify error Bytes: 131025 Block#493 Verify error Bytes: 131025 Block#494 Verify error Bytes: 131025 Block#495 Verify error Bytes: 131025 Block#496 Verify error Bytes: 131025 Block#497 Verify error Bytes: 131025 Block#498 Verify error Bytes: 128409 Block#499 Verify error Bytes: 128448 Block#500 Verify error Bytes: 128432 Block#501 Verify error Bytes: 128351 Block#502 Verify error Bytes: 128436 Block#503 Verify error Bytes: 128408 Block#504 Verify error Bytes: 128439 Block#505 Verify error Bytes: 128360 Block#506 Verify error Bytes: 128365 Block#507 Verify error Bytes: 128350 Block#508 Verify error Bytes: 128357 Block#509 Verify error Bytes: 128417 Block#510 Verify error Bytes: 128351 Block#511 Verify error Bytes: 128368 Block#512 Verify error Bytes: 131024 Block#513 Verify error Bytes: 131024 Block#514 Verify error Bytes: 131024 Block#515 Verify error Bytes: 131024 Block#516 Verify error Bytes: 131024 Block#517 Verify error Bytes: 131024 Block#518 Verify error Bytes: 131024 Block#519 Verify error Bytes: 131024 Block#520 Verify error Bytes: 131024 Block#521 Verify error Bytes: 131024 Block#522 Verify error Bytes: 131024 Block#523 Verify error Bytes: 131024 Block#524 Verify error Bytes: 131024 Block#525 Verify error Bytes: 131024 Block#526 Verify error Bytes: 131024 Block#527 Verify error Bytes: 131024 Block#528 Verify error Bytes: 131024 Block#529 Verify error Bytes: 131024 Block#530 Verify error Bytes: 131024 Block#531 Verify error Bytes: 131024 Block#532 Verify error Bytes: 131024 Block#533 Verify error Bytes: 131024 Block#534 Verify error Bytes: 131024 Block#535 Verify error Bytes: 131024 Block#536 Verify error Bytes: 131024 Block#537 Verify error Bytes: 131024 Block#538 Verify error Bytes: 131024 Block#539 Verify error Bytes: 131024 Block#540 Verify error Bytes: 131024 Block#541 Verify error Bytes: 131024 Block#542 Verify error Bytes: 131024 Block#543 Verify error Bytes: 131024 Block#544 Verify error Bytes: 131024 Block#545 Verify error Bytes: 131024 Block#546 Verify error Bytes: 131024 Block#547 Verify error Bytes: 131024 Block#548 Verify error Bytes: 131024 Block#549 Verify error Bytes: 131024 Block#550 Verify error Bytes: 131024 Block#551 Verify error Bytes: 131024 Block#552 Verify error Bytes: 131024 Block#553 Verify error Bytes: 131024 Block#554 Verify error Bytes: 131024 Block#555 Verify error Bytes: 131024 Block#556 Verify error Bytes: 131024 Block#557 Verify error Bytes: 131024 Block#558 Verify error Bytes: 131024 Block#559 Verify error Bytes: 131024 Block#560 Verify error Bytes: 131024 Block#561 Verify error Bytes: 131024 Block#562 Verify error Bytes: 131024 Block#563 Verify error Bytes: 131024 Block#564 Verify error Bytes: 131024 Block#565 Verify error Bytes: 131024 Block#566 Verify error Bytes: 131024 Block#567 Verify error Bytes: 131024 Block#568 Verify error Bytes: 131024 Block#569 Verify error Bytes: 131024 Block#570 Verify error Bytes: 131024 Block#571 Verify error Bytes: 131024 Block#572 Verify error Bytes: 131024 Block#573 Verify error Bytes: 131024 Block#574 Verify error Bytes: 128450 Block#575 Verify error Bytes: 129062 Block#576 Verify error Bytes: 128410 Block#577 Verify error Bytes: 128409 Block#578 Verify error Bytes: 131024 Block#579 Verify error Bytes: 131024 Block#580 Verify error Bytes: 128457 Block#581 Verify error Bytes: 128461 Block#582 Verify error Bytes: 128418 Block#583 Verify error Bytes: 128455 Block#584 Verify error Bytes: 131024 Block#585 Verify error Bytes: 131024 Block#586 Verify error Bytes: 131024 Block#587 Verify error Bytes: 131024 Block#588 Verify error Bytes: 131024 Block#589 Verify error Bytes: 131024 Block#590 Verify error Bytes: 131024 Block#591 Verify error Bytes: 131024 Block#592 Verify error Bytes: 131024 Block#593 Verify error Bytes: 131025 Block#594 Verify error Bytes: 131024 Block#595 Verify error Bytes: 131024 Block#596 Verify error Bytes: 131024 Block#597 Verify error Bytes: 131024 Block#598 Verify error Bytes: 131024 Block#599 Verify error Bytes: 131024 Block#600 Verify error Bytes: 131024 Block#601 Verify error Bytes: 131024 Block#602 Verify error Bytes: 131024 Block#603 Verify error Bytes: 131024 Block#604 Verify error Bytes: 131024 Block#605 Verify error Bytes: 128287 Block#606 Verify error Bytes: 125004 Block#607 Verify error Bytes: 127017 Block#608 Verify error Bytes: 127013 Block#609 Verify error Bytes: 105434 Block#610 Verify error Bytes: 105438 Block#611 Verify error Bytes: 131024 Block#612 Verify error Bytes: 131024 Block#613 Verify error Bytes: 131024 Block#614 Verify error Bytes: 131024 Block#615 Verify error Bytes: 131024 Block#616 Verify error Bytes: 131024 Block#617 Verify error Bytes: 131024 Block#618 Verify error Bytes: 131024 Block#619 Verify error Bytes: 129063 Block#620 Verify error Bytes: 129063 Block#621 Verify error Bytes: 129063 Block#622 Verify error Bytes: 129063 Block#623 Verify error Bytes: 129063 Block#624 Verify error Bytes: 129063 Block#625 Verify error Bytes: 129063 Block#626 Verify error Bytes: 129063 Block#627 Verify error Bytes: 129063 Block#628 Verify error Bytes: 129063 Block#629 Verify error Bytes: 127011 Block#630 Verify error Bytes: 131024 Block#631 Verify error Bytes: 131024 Block#632 Verify error Bytes: 131024 Block#633 Verify error Bytes: 131024 Block#634 Verify error Bytes: 131024 Block#635 Verify error Bytes: 131024 Block#636 Verify error Bytes: 131024 Block#637 Verify error Bytes: 131024 Block#638 Verify error Bytes: 131024 Block#639 Verify error Bytes: 131024 Block#640 Verify error Bytes: 131024 Block#641 Verify error Bytes: 131024 Block#642 Verify error Bytes: 131024 Block#643 Verify error Bytes: 131024 Block#644 Verify error Bytes: 131024 Block#645 Verify error Bytes: 131024 Block#646 Verify error Bytes: 131024 Block#647 Verify error Bytes: 131024 Block#648 Verify error Bytes: 131024 Block#649 Verify error Bytes: 131024 Block#650 Verify error Bytes: 131024 Block#651 Verify error Bytes: 128368 Block#652 Verify error Bytes: 128321 Block#653 Verify error Bytes: 128342 Block#654 Verify error Bytes: 128063 Block#655 Verify error Bytes: 127815 Block#656 Verify error Bytes: 128998 Block#657 Verify error Bytes: 129001 Block#658 Verify error Bytes: 129002 Block#659 Verify error Bytes: 129003 Block#660 Verify error Bytes: 128973 Block#661 Verify error Bytes: 128963 Block#662 Verify error Bytes: 128967 Block#663 Verify error Bytes: 107940 Block#664 Verify error Bytes: 107941 Block#665 Verify error Bytes: 131024 Block#666 Verify error Bytes: 131024 Block#667 Verify error Bytes: 131024 Block#668 Verify error Bytes: 131024 Block#669 Verify error Bytes: 131024 Block#670 Verify error Bytes: 131024 Block#671 Verify error Bytes: 131024 Block#672 Verify error Bytes: 131024 Block#673 Verify error Bytes: 131024 Block#674 Verify error Bytes: 131024 Block#675 Verify error Bytes: 131024 Block#676 Verify error Bytes: 131024 Block#677 Verify error Bytes: 131024 Block#678 Verify error Bytes: 131024 Block#679 Verify error Bytes: 131024 Block#680 Verify error Bytes: 131024 Block#681 Verify error Bytes: 131024 Block#682 Verify error Bytes: 131024 Block#683 Verify error Bytes: 131024 Block#684 Verify error Bytes: 131024 Block#685 Verify error Bytes: 131024 Block#686 Verify error Bytes: 131024 Block#687 Verify error Bytes: 131024 Block#688 Verify error Bytes: 131024 Block#689 Verify error Bytes: 131024 Block#690 Verify error Bytes: 131024 Block#691 Verify error Bytes: 131024 Block#692 Verify error Bytes: 128390 Block#693 Verify error Bytes: 128327 Block#694 Verify error Bytes: 128354 Block#695 Verify error Bytes: 128323 Block#696 Verify error Bytes: 128447 Block#697 Verify error Bytes: 128392 Block#698 Verify error Bytes: 128439 Block#699 Verify error Bytes: 128480 Block#700 Verify error Bytes: 128435 Block#701 Verify error Bytes: 128399 Block#702 Verify error Bytes: 128414 Block#703 Verify error Bytes: 128421 Block#704 Verify error Bytes: 128436 Block#705 Verify error Bytes: 128488 Block#706 Verify error Bytes: 128330 Block#707 Verify error Bytes: 128469 Block#708 Verify error Bytes: 128415 Block#709 Verify error Bytes: 128411 Block#710 Verify error Bytes: 128419 Block#711 Verify error Bytes: 128379 Block#712 Verify error Bytes: 128442 Block#713 Verify error Bytes: 128452 Block#714 Verify error Bytes: 128369 Block#715 Verify error Bytes: 128387 Block#716 Verify error Bytes: 128425 Block#717 Verify error Bytes: 128480 Block#718 Verify error Bytes: 128400 Block#719 Verify error Bytes: 128482 Block#720 Verify error Bytes: 128471 Block#721 Verify error Bytes: 128470 Block#722 Verify error Bytes: 128473 Block#723 Verify error Bytes: 128482 Block#724 Verify error Bytes: 128456 Block#725 Verify error Bytes: 128499 Block#726 Verify error Bytes: 128510 Block#727 Verify error Bytes: 128506 Block#728 Verify error Bytes: 128497 Block#729 Verify error Bytes: 128494 Block#730 Verify error Bytes: 128459 Block#731 Verify error Bytes: 128439 Block#732 Verify error Bytes: 128443 Block#733 Verify error Bytes: 128453 Block#734 Verify error Bytes: 128482 Block#735 Verify error Bytes: 128463 Block#736 Verify error Bytes: 128445 Block#737 Verify error Bytes: 129062 Block#738 Verify error Bytes: 128437 Block#739 Verify error Bytes: 128414 Block#740 Verify error Bytes: 128397 Block#741 Verify error Bytes: 128371 Block#742 Verify error Bytes: 128445 Block#743 Verify error Bytes: 128428 Block#744 Verify error Bytes: 128439 Block#745 Verify error Bytes: 128433 Block#746 Verify error Bytes: 131024 Block#747 Verify error Bytes: 131024 Block#748 Verify error Bytes: 131024 Block#749 Verify error Bytes: 131024 Block#750 Verify error Bytes: 131024 Block#751 Verify error Bytes: 131024 Block#752 Verify error Bytes: 131024 Block#753 Verify error Bytes: 131024 Block#754 Verify error Bytes: 131024 Block#755 Verify error Bytes: 131024 Block#756 Verify error Bytes: 131024 Block#757 Verify error Bytes: 131024 Block#758 Verify error Bytes: 131024 Block#759 Verify error Bytes: 131024 Block#760 Verify error Bytes: 131024 Block#761 Verify error Bytes: 131024 Block#762 Verify error Bytes: 131024 Block#763 Verify error Bytes: 128373 Block#764 Verify error Bytes: 128396 Block#765 Verify error Bytes: 131024 Block#766 Verify error Bytes: 128424 Block#767 Verify error Bytes: 128431 Block#768 Verify error Bytes: 128381 Block#769 Verify error Bytes: 128405 Block#770 Verify error Bytes: 128342 Block#771 Verify error Bytes: 128456 Block#772 Verify error Bytes: 131024 Block#773 Verify error Bytes: 131024 Block#774 Verify error Bytes: 128433 Block#775 Verify error Bytes: 131024 Block#776 Verify error Bytes: 128350 Block#777 Verify error Bytes: 131024 Block#778 Verify error Bytes: 131024 Block#779 Verify error Bytes: 131024 Block#780 Verify error Bytes: 128449 Block#781 Verify error Bytes: 131024 Block#782 Verify error Bytes: 131024 Block#783 Verify error Bytes: 131024 Block#784 Verify error Bytes: 131024 Block#785 Verify error Bytes: 131024 Block#786 Verify error Bytes: 131024 Block#787 Verify error Bytes: 131024 Block#788 Verify error Bytes: 131024 Block#789 Verify error Bytes: 131024 Block#790 Verify error Bytes: 131024 Block#791 Verify error Bytes: 131024 Block#792 Verify error Bytes: 131024 Block#793 Verify error Bytes: 128432 Block#794 Verify error Bytes: 128443 Block#795 Verify error Bytes: 131024 Block#796 Verify error Bytes: 131024 Block#797 Verify error Bytes: 128370 Block#798 Verify error Bytes: 128439 Block#799 Verify error Bytes: 128441 Block#800 Verify error Bytes: 128439 Block#801 Verify error Bytes: 128419 Block#802 Verify error Bytes: 128425 Block#803 Verify error Bytes: 128387 Block#804 Verify error Bytes: 128370 Block#805 Verify error Bytes: 128397 Block#806 Verify error Bytes: 126446 Block#807 Verify error Bytes: 126510 Block#808 Verify error Bytes: 126508 Block#809 Verify error Bytes: 126470 Block#810 Verify error Bytes: 126492 Block#811 Verify error Bytes: 126503 Block#812 Verify error Bytes: 126485 Block#813 Verify error Bytes: 129062 Block#814 Verify error Bytes: 131024 Block#815 Verify error Bytes: 131024 Block#816 Verify error Bytes: 131024 Block#817 Verify error Bytes: 131024 Block#818 Verify error Bytes: 131024 Block#819 Verify error Bytes: 131024 Block#820 Verify error Bytes: 131024 Block#821 Verify error Bytes: 131024 Block#822 Verify error Bytes: 131024 Block#823 Verify error Bytes: 131024 Block#824 Verify error Bytes: 131024 Block#825 Verify error Bytes: 131024 Block#826 Verify error Bytes: 131024 Block#827 Verify error Bytes: 131024 Block#828 Verify error Bytes: 131024 Block#829 Verify error Bytes: 131024 Block#830 Verify error Bytes: 131024 Block#831 Verify error Bytes: 131024 Block#832 Verify error Bytes: 131024 Block#833 Verify error Bytes: 131024 Block#834 Verify error Bytes: 131024 Block#835 Verify error Bytes: 131024 Block#836 Verify error Bytes: 131024 Block#837 Verify error Bytes: 131024 Block#838 Verify error Bytes: 131024 Block#839 Verify error Bytes: 131024 Block#840 Verify error Bytes: 131024 Block#841 Verify error Bytes: 131024 Block#842 Verify error Bytes: 131024 Block#843 Verify error Bytes: 131024 Block#844 Verify error Bytes: 131024 Block#845 Verify error Bytes: 128416 Block#846 Verify error Bytes: 128413 Block#847 Verify error Bytes: 128419 Block#848 Verify error Bytes: 128426 Block#849 Verify error Bytes: 128446 Block#850 Verify error Bytes: 128430 Block#851 Verify error Bytes: 128405 Block#852 Verify error Bytes: 131024 Block#853 Verify error Bytes: 128448 Block#854 Verify error Bytes: 128393 Block#855 Verify error Bytes: 128434 Block#856 Verify error Bytes: 128431 Block#857 Verify error Bytes: 128435 Block#858 Verify error Bytes: 131024 Block#859 Verify error Bytes: 128393 Block#860 Verify error Bytes: 128409 Block#861 Verify error Bytes: 128365 Block#862 Verify error Bytes: 131024 Block#863 Verify error Bytes: 128435 Block#864 Verify error Bytes: 128437 Block#865 Verify error Bytes: 131024 Block#866 Verify error Bytes: 131024 Block#867 Verify error Bytes: 131024 Block#868 Verify error Bytes: 131024 Block#869 Verify error Bytes: 131024 Block#870 Verify error Bytes: 131024 Block#871 Verify error Bytes: 131024 Block#872 Verify error Bytes: 131024 Block#873 Verify error Bytes: 131024 Block#874 Verify error Bytes: 131024 Block#875 Verify error Bytes: 131024 Block#876 Verify error Bytes: 131024 Block#877 Verify error Bytes: 131024 Block#878 Verify error Bytes: 131024 Block#879 Verify error Bytes: 131024 Block#880 Verify error Bytes: 131024 Block#881 Verify error Bytes: 131024 Block#882 Verify error Bytes: 131024 Block#883 Verify error Bytes: 131024 Block#884 Verify error Bytes: 131024 Block#885 Verify error Bytes: 131024 Block#886 Verify error Bytes: 131024 Block#887 Verify error Bytes: 131024 Block#888 Verify error Bytes: 131024 Block#889 Verify error Bytes: 131024 Block#890 Verify error Bytes: 131025 Block#891 Verify error Bytes: 131024 Block#892 Verify error Bytes: 131024 Block#893 Verify error Bytes: 131025 Block#894 Verify error Bytes: 131024 Block#895 Verify error Bytes: 131025 Block#896 Verify error Bytes: 131024 Block#897 Verify error Bytes: 131024 Block#898 Verify error Bytes: 131024 Block#899 Verify error Bytes: 131024 Block#900 Verify error Bytes: 131024 Block#901 Verify error Bytes: 131024 Block#902 Verify error Bytes: 131024 Block#903 Verify error Bytes: 131024 Block#904 Verify error Bytes: 131024 Block#905 Verify error Bytes: 131024 Block#906 Verify error Bytes: 131025 Block#907 Verify error Bytes: 131025 Block#908 Verify error Bytes: 131024 Block#909 Verify error Bytes: 131024 Block#910 Verify error Bytes: 131024 Block#911 Verify error Bytes: 131024 Block#912 Verify error Bytes: 131024 Block#913 Verify error Bytes: 131024 Block#914 Verify error Bytes: 131024 Block#915 Verify error Bytes: 131024 Block#916 Verify error Bytes: 131024 Block#917 Verify error Bytes: 131024 Block#918 Verify error Bytes: 131024 Block#919 Verify error Bytes: 131024 Block#920 Verify error Bytes: 131024 Block#921 Verify error Bytes: 131024 Block#922 Verify error Bytes: 131024 Block#923 Verify error Bytes: 131024 Block#924 Verify error Bytes: 131024 Block#925 Verify error Bytes: 131024 Block#926 Verify error Bytes: 131024 Block#927 Verify error Bytes: 131024 Block#928 Verify error Bytes: 131024 Block#929 Verify error Bytes: 131024 Block#930 Verify error Bytes: 131024 Block#931 Verify error Bytes: 131024 Block#932 Verify error Bytes: 131024 Block#933 Verify error Bytes: 131024 Block#934 Verify error Bytes: 131024 Block#935 Verify error Bytes: 131024 Block#936 Verify error Bytes: 131024 Block#937 Verify error Bytes: 131024 Block#938 Verify error Bytes: 128423 Block#939 Verify error Bytes: 131024 Block#940 Verify error Bytes: 131024 Block#941 Verify error Bytes: 131024 Block#942 Verify error Bytes: 131024 Block#943 Verify error Bytes: 131024 Block#944 Verify error Bytes: 131024 Block#945 Verify error Bytes: 131024 Block#946 Verify error Bytes: 131024 Block#947 Verify error Bytes: 131024 Block#948 Verify error Bytes: 131024 Block#949 Verify error Bytes: 131024 Block#950 Verify error Bytes: 131024 Block#951 Verify error Bytes: 131024 Block#952 Verify error Bytes: 131024 Block#953 Verify error Bytes: 131024 Block#954 Verify error Bytes: 131024 Block#955 Verify error Bytes: 131024 Block#956 Verify error Bytes: 131024 Block#957 Verify error Bytes: 131024 Block#958 Verify error Bytes: 131024 Block#959 Verify error Bytes: 131024 Block#960 Verify error Bytes: 131024 Block#961 Verify error Bytes: 131024 Block#962 Verify error Bytes: 131024 Block#963 Verify error Bytes: 131024 Block#964 Verify error Bytes: 131024 Block#965 Verify error Bytes: 131024 Block#966 Verify error Bytes: 131024 Block#967 Verify error Bytes: 131024 Block#968 Verify error Bytes: 131024 Block#969 Verify error Bytes: 131024 Block#970 Verify error Bytes: 131024 Block#971 Verify error Bytes: 131024 Block#972 Verify error Bytes: 131024 Block#973 Verify error Bytes: 131024 Block#974 Verify error Bytes: 131024 Block#975 Verify error Bytes: 131024 Block#976 Verify error Bytes: 131024 Block#977 Verify error Bytes: 131024 Block#978 Verify error Bytes: 131024 Block#979 Verify error Bytes: 131024 Block#980 Verify error Bytes: 131024 Block#981 Verify error Bytes: 131024 Block#982 Verify error Bytes: 131024 Block#983 Verify error Bytes: 131024 Block#984 Verify error Bytes: 131024 Block#985 Verify error Bytes: 131024 Block#986 Verify error Bytes: 131024 Block#987 Verify error Bytes: 131024 Block#988 Verify error Bytes: 131024 Block#989 Verify error Bytes: 131024 Block#990 Verify error Bytes: 131024 Block#991 Verify error Bytes: 131024 Block#992 Verify error Bytes: 131024 Block#993 Verify error Bytes: 131024 Block#994 Verify error Bytes: 131024 Block#995 Verify error Bytes: 131024 Block#996 Verify error Bytes: 131024 Block#997 Verify error Bytes: 131024 Block#998 Verify error Bytes: 131024 Block#999 Verify error Bytes: 131024 Block#1000 Verify error Bytes: 131024 Block#1001 Verify error Bytes: 131024 Block#1002 Verify error Bytes: 131024 Block#1003 Verify error Bytes: 131024 Block#1004 Verify error Bytes: 131024 Block#1005 Verify error Bytes: 131024 Block#1006 Verify error Bytes: 131024 Block#1007 Verify error Bytes: 131024 Block#1008 Verify error Bytes: 131024 Block#1009 Verify error Bytes: 131024 Block#1010 Verify error Bytes: 131024 Block#1011 Verify error Bytes: 131024 Block#1012 Verify error Bytes: 131025 Block#1013 Verify error Bytes: 131025 Block#1014 Verify error Bytes: 131025 Block#1015 Verify error Bytes: 131025 Block#1016 Verify error Bytes: 131025 Block#1017 Verify error Bytes: 131025 Block#1018 Verify error Bytes: 131025 Block#1019 Verify error Bytes: 131025 Block#1020 Verify error Bytes: 131025 Block#1021 Verify error Bytes: 131025 Block#1022 Verify error Bytes: 131025 Block#1023 Verify error Bytes: 131025 Verify Error Blocks: 935
