***************************************************** Connecting to MPLAB PICkit 3... Currently loaded firmware on PICkit 3 Firmware Suite Version.....01.56.09 Firmware type..............dsPIC33F/24F/24H Target voltage detected Target device PIC24FJ256GB106 found. Device Revision ID = 4 Reading... The following memory area(s) will be read: program memory: start address = 0x0, end address = 0x2abf7 configuration memory Read complete Erasing... Erase successful Loading code from /dev/shm/IMAGE_PK3_012510.hex... 2026-05-09 22:05:28 +0200 - Hex file loaded successfully. 2026-05-09 22:05:32 +0200 - Programming... Device Erased... Programming... The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0x29fff configuration memory Programming/Verify complete 2026-05-09 22:05:58 +0200 - Programming complete *** Hold In Reset mode is enabled ***
